Client running 100% TDP all of the sudden
JDE100
Post by JDE100 »
New folder here. I have a new I5-9400 with an Nvidia 1660 TI (non OC). Running on GPU only. First 9 WU's ran perfect at 98% GPU load, 60c and fan at about 65%. 8 pin voltage at 25 watts.
After restarting system this morning the current WU started running at 98% GPU, 80c and fan at 95%. 8 pin voltage at 85 and TDP at 100 and getting temperature and voltage regulated.
Not sure what happened or how to fix? Any help would be appreciated.
Thank you
HaloJones
Re: Client running 100% TDP all of the sudden
Post by HaloJones »
FAH has no way to limit the GPU usage, some projects run at 100%, some at 70%. If you're worried, you can use a tool like MSI Afterburner to set a power limit but FAH is just trying to use the power available to it.
4070 super
bollix47
Post by bollix47 »
If the project you were running was 13416 have a look at:
viewtopic.php?f=19&t=35744
Some runs in that project are taking longer to process ... the situation is being looked into by the project leader.
Ichbin3
Hardware configuration: MSI H81M, G3240, RTX 2080Ti_Rev-A@220W, Ubuntu 18.04
Post by Ichbin3 »
At the terminal (or cmd) run nvidia-smi -h
You can set a power limit via
nvidia-smi -i 0 -pl xxx # instead of xxx set your preferred watt
JDE100
Post by JDE100 »
I ended up dumping the Wu and the next Wu went back to my original results.
