Foliant
Posts: 103 Joined: Wed May 13, 2020 4:39 pm
Post
by Foliant » Thu Jul 02, 2020 8:21 pm
Not actually a request but i noticed that a "GTX 760 Ti" is listed as a "GTX 670".
Maybe someone can update or explain that?
Regards,
Patrick
24/7
1x i5 3470 @2Cores
1x GTX750 (GM107)
2x GTX750Ti (GM107)
Posts: 20822 Joined: Thu Nov 29, 2007 10:13 pm
Post
by bruce » Thu Jul 02, 2020 8:37 pm
Accirdubg to my infromation, GK104 [GeForce GTX 670] has the Binary IDs of 10de 1189.
The codes 10de 1187 are for the GK104 [GeForce GTX 760]
Please post the output from GPU-Z or FAHCLIENT --lspci showing what you have.
Foliant
Post
by Foliant » Fri Jul 03, 2020 10:04 pm
Here we go:
FAHClient --lspci
0x1002:0x5a14:0:0:0:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1002:0x5a16:0:2:0:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1002:0x5a17:0:3:0:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1002:0x4391:0:17:0:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1002:0x4397:0:18:0:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1002:0x4396:0:18:2:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1002:0x4397:0:19:0:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1002:0x4396:0:19:2:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1002:0x4385:0:20:0:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1002:0x439c:0:20:1:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1002:0x439d:0:20:3:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1002:0x4384:0:20:4:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1002:0x4399:0:20:5:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1002:0x43a0:0:21:0:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1002:0x43a3:0:21:3:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1002:0x4397:0:22:0:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1002:0x4396:0:22:2:Advanced Micro Devices, Inc. [AMD/ATI]:
0x1022:0x1200:0:24:0:Advanced Micro Devices, Inc. [AMD]:
0x1022:0x1201:0:24:1:Advanced Micro Devices, Inc. [AMD]:
0x1022:0x1202:0:24:2:Advanced Micro Devices, Inc. [AMD]:
0x1022:0x1203:0:24:3:Advanced Micro Devices, Inc. [AMD]:
0x1022:0x1204:0:24:4:Advanced Micro Devices, Inc. [AMD]:
0x10de:0x1189:1:0:0:NVIDIA Corporation:
0x10de:0x0e0a:1:0:1:NVIDIA Corporation:
0x10de:0x1082:2:0:0:NVIDIA Corporation:
0x10de:0x0e09:2:0:1:NVIDIA Corporation:
0x10ec:0x8168:5:0:0:Realtek Semiconductor Co., Ltd.:
lspci |grep VGA
01:00.0 VGA compatible controller: NVIDIA Corporation GK104 [GeForce GTX 670] (rev a1)
02:00.0 VGA compatible controller: NVIDIA Corporation GF110 [GeForce GTX 560 Ti OEM] (rev a1)
24/7
1x i5 3470 @2Cores
1x GTX750 (GM107)
2x GTX750Ti (GM107)
Posts: 8352 Joined: Tue Apr 21, 2009 4:41 pm
Hardware configuration: Mac Studio M1 Max 32 GB smp6 Mac Hack i7-7700K 48 GB smp4
Post
by Joe_H » Fri Jul 03, 2020 10:31 pm
I looked up the two entries and did a little research. The entries in GPUs.txt that match up with your lspci output are the following:
0x10de:0x1189:2:4:GK104 [GeForce GTX 670] 2634
0x10de:0x1082:2:4:GF114 [GeForce GTX 560 Ti] 1263
The research showed that the OEM card called a GTX 760 ti was a rebadged GTX 670. That is why it is identified that way in the file. The specs for number of shaders, base clock, boost clock, etc. are the same for both cards.
Foliant
Post
by Foliant » Sun Jul 05, 2020 5:05 pm
Joe_H wrote: the OEM card called a GTX 760 ti was a rebadged GTX 670
Thank you, i did know some cards are just rebrands of older ones. I did not even think about my 760TI could be one of them.
Regards
Patrick
24/7
1x i5 3470 @2Cores
1x GTX750 (GM107)
2x GTX750Ti (GM107)
Post
by Joe_H » Sun Jul 05, 2020 5:42 pm
Given the time frame, I suspect the GTX 760 ti was just supplied as an OEM card to fill a performance gap in the GT 700 line of cards. Many of that series were just reissues of the previous generation cards, perhaps with a bump in clock speed or a change in chip process that was just a minor revision. About the only totally new cards were the high end GTX 780 and above, and the Maxwell chip based GTX 750 and 750 ti
Post
by bruce » Tue Jul 07, 2020 5:57 am
Rebrand recggnized
0x10de:0x1189:2:4:GK104 [GeForce GTX 670/GTX 760Ti OEM] 2634
The true GTX 670 is shipped with a Base Clock of 915 MHz and a Boost Clock of 980 MHz
The OEM GTX 760 Ti is also shipped with a Base Clock of 915 MHz and a Boost Clock of 980 MHz
Is your default clock rate different?
Foliant
Post
by Foliant » Wed Jul 08, 2020 5:59 pm
Im normaly running it underclocked by 190 MHz.
Its cooler, drawing less power and i cant see the performance going down.
24/7
1x i5 3470 @2Cores
1x GTX750 (GM107)
2x GTX750Ti (GM107)
Foliant
Post
by Foliant » Tue Aug 25, 2020 7:08 am
Hallo,
I found another GPU with a wrong Name.
The GPU Im testing is a GT
X 650
GPUs.txt is listing: 0x10de:0x0fc6:2:3:GK107 [GeForce GT 650] 812
I cant find any info about a GT 650 - except a GT 650
M
lspci
06:00.0 VGA compatible controller: NVIDIA Corporation GK107 [GeForce GTX 650] (rev a1)
FAHClient --lspci
0x10de:0x0fc6:6:0:0:NVIDIA Corporation:
0x10de:0x0e1b:6:0:1:NVIDIA Corporation:
Regards
Patrick
24/7
1x i5 3470 @2Cores
1x GTX750 (GM107)
2x GTX750Ti (GM107)
Posts: 6545 Joined: Sun Dec 02, 2007 10:38 am
Post
by toTOW » Tue Aug 25, 2020 9:37 am
Although it doesn't change anything, I fixed it.
Foliant
Post
by Foliant » Tue Aug 25, 2020 2:54 pm
It stops confusion if some oddball like me is trying to fold with older Hardware.
Not a game changer but good for accuracy.
24/7
1x i5 3470 @2Cores
1x GTX750 (GM107)
2x GTX750Ti (GM107)
Post
by bruce » Tue Aug 25, 2020 3:01 pm
GPUs.txt is complex and it's possible to make mistakes. It's about to get more complex.
