Project 14447 Faulty WU
pylgrym
Post by pylgrym »
The first WU I've seen on this project and it failed:
https://apps.foldingathome.org/wu#proje ... 385&gen=14
04:16:58:WU01:FS01:Starting
04:16:58:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 5714 -checkp
oint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
04:16:58:WU01:FS01:Started FahCore on PID 8253
04:16:58:WU01:FS01:Core PID:8257
04:16:58:WU01:FS01:FahCore 0x22 started
04:16:58:WU01:FS01:0x22:*********************** Log Started 2020-07-02T04:16:58Z ***********************
04:16:58:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
04:16:58:WU01:FS01:0x22:       Core: Core22
04:16:58:WU01:FS01:0x22:       Type: 0x22
04:16:58:WU01:FS01:0x22:    Version: 0.0.11
04:16:58:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:16:58:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
04:16:58:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
04:16:58:WU01:FS01:0x22:       Date: Jun 27 2020
04:16:58:WU01:FS01:0x22:       Time: 22:50:00
04:16:58:WU01:FS01:0x22:   Revision: cfc2940c5dd1aa80f60daa6e28d4a2a417f74edb
04:16:58:WU01:FS01:0x22:     Branch: core22-0.0.11
04:16:58:WU01:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
04:16:58:WU01:FS01:0x22:    Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
04:16:58:WU01:FS01:0x22:             -funroll-loops
04:16:58:WU01:FS01:0x22:   Platform: linux2 4.19.76-linuxkit
04:16:58:WU01:FS01:0x22:       Bits: 64
04:16:58:WU01:FS01:0x22:       Mode: Release
04:16:58:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
04:16:58:WU01:FS01:0x22:             <peastman@stanford.edu>
04:16:58:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 8253 -checkpoint 15
04:16:58:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
04:16:58:WU01:FS01:0x22:             0 -gpu 0
04:16:58:WU01:FS01:0x22:************************************ libFAH ************************************
04:16:58:WU01:FS01:0x22:       Time: 22:11:04
04:16:58:WU01:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
04:16:58:WU01:FS01:0x22:     Branch: HEAD
04:16:58:WU01:FS01:0x22:************************************ CBang *************************************
04:16:58:WU01:FS01:0x22:       Time: 22:10:11
04:16:58:WU01:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
04:16:58:WU01:FS01:0x22:             -funroll-loops -fPIC
04:16:58:WU01:FS01:0x22:************************************ System ************************************
04:16:58:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
04:16:58:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
04:16:58:WU01:FS01:0x22:       CPUs: 12
04:16:58:WU01:FS01:0x22:     Memory: 31.13GiB
04:16:58:WU01:FS01:0x22:Free Memory: 14.22GiB
04:16:58:WU01:FS01:0x22:    Threads: POSIX_THREADS
04:16:58:WU01:FS01:0x22: OS Version: 4.15
04:16:58:WU01:FS01:0x22:Has Battery: false
04:16:58:WU01:FS01:0x22: On Battery: false
04:16:58:WU01:FS01:0x22: UTC Offset: 1
04:16:58:WU01:FS01:0x22:        PID: 8257
04:16:58:WU01:FS01:0x22:        CWD: /var/lib/fahclient/work
04:16:58:WU01:FS01:0x22:********************************************************************************
04:16:58:WU01:FS01:0x22:Project: 14447 (Run 0, Clone 1385, Gen 14)
04:16:58:WU01:FS01:0x22:Unit: 0x0000001603854c135ea7b88fa9e6b533
04:16:58:WU01:FS01:0x22:Reading tar file core.xml
04:16:58:WU01:FS01:0x22:Reading tar file integrator.xml
04:16:58:WU01:FS01:0x22:Reading tar file state.xml
04:16:58:WU01:FS01:0x22:Reading tar file system.xml
04:16:59:WU01:FS01:0x22:Digital signatures verified
04:16:59:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:16:59:WU01:FS01:0x22:Version 0.0.11
04:16:59:WU01:FS01:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
04:16:59:WU01:FS01:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
04:16:59:WU01:FS01:0x22:  XTC frame write interval: 20000 steps (1%) [100 total]
04:16:59:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
04:17:03:WU01:FS01:0x22:ERROR:exception: Called setPositions() on a Context with the wrong number of positions
04:17:03:WU01:FS01:0x22:Saving result file ../logfile_01.txt
04:17:03:WU01:FS01:0x22:Saving result file science.log
04:17:03:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
04:17:04:WU00:FS01:Upload 7.38%
ESC[93m04:17:04:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)ESC[0m
04:17:04:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14447 run:0 clone:1385 gen:14 core:0x22 unit:0x0000001603854c135ea7b88fa9e6b533
04:17:04:WU01:FS01:Uploading 2.42KiB to 3.133.76.19
04:17:04:WU01:FS01:Connecting to 3.133.76.19:8080
04:17:04:WU02:FS01:Connecting to assign1.foldingathome.org:80
04:17:05:WU01:FS01:Upload complete
04:17:05:WU01:FS01:Server responded WORK_ACK (400)
04:17:05:WU01:FS01:Cleaning up
CPU: No slot; GPU: GeForce GTX 1080; O/S: Ubuntu 18.04 LTS; Machine: Alienware Aurora R7
Re: Project 14447 Faulty WU
This problem has been traced down to a misconfigured project. It has reportedly been corrected.
