Ok, which is it: ":::" or ":0:0:" ?
ITgreybeard
Hardware configuration: Custom build: Win 7 Pro/64 on Asus P7P55D Deluxe 2.8GHz Intel Core i7 860, 4~8 cores, 8GB memory. Graphics: ATI FirePro V4800 (FireGL V).
Post by ITgreybeard »
My elderly but still-supported (by AMD) FirePro V4800 graphics card has the latest drivers (drivers 2015, encompassing application package 2020).
The local gpus.txt file lists the V4800 as:
0x1002:0x68c9:0:0:RV830 [FirePro V3800 (FireGL V)],
which agrees with "fahclient --lspci" except for an extra value in the middle:
0x1b73:0x1100:5:0:0:Fresco Logic:Fresco Logic xHCI (USB3) Controller FL1100 Series
0x8086:0xd131:0:0:0:Intel Corporation:DMI Device
0x8086:0x3b4c:0:28:5:Intel Corporation:PCI-to-PCI Bridge
0x1002:0xaa60:1:0:1:Advanced Micro Devices, Inc. [AMD/ATI]:High Definition Audio Bus
0x8086:0xd151:0:16:1:Intel Corporation:QPI Device
0x8086:0xd155:0:8:0:Intel Corporation:Registers
0x197b:0x2363:3:0:0:JMicron Technology Corp.:JMicron JMB36X Controller
0x197b:0x2363:3:0:1:JMicron Technology Corp.:JMicron JMB36X Controller
0x8086:0x3b34:0:29:0:Intel Corporation:Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B34
0x8086:0x244e:0:30:0:Intel Corporation:PCI-to-PCI Bridge
0x8086:0x3b4e:0:28:6:Intel Corporation:PCI-to-PCI Bridge
0x1002:0x68c8:1:0:0:Advanced Micro Devices, Inc. [AMD/ATI]:ATI FirePro V4800 (FireGL V)
0x8086:0x3b42:0:28:0:Intel Corporation:PCI-to-PCI Bridge
0x8086:0xd138:0:3:0:Intel Corporation:PCI-to-PCI Bridge
0x8086:0xd157:0:8:2:Intel Corporation:Registers
0x10ec:0x8167:7:4:0:Realtek Semiconductor Co., Ltd.:Realtek PCI GBE Family Controller
0x8086:0xd150:0:16:0:Intel Corporation:QPI Device
0x8086:0x3b50:0:28:7:Intel Corporation:PCI-to-PCI Bridge
0x8086:0x3b22:0:31:2:Intel Corporation:Standard SATA AHCI Controller
0x8086:0xd158:0:8:3:Intel Corporation:Registers
0x8086:0x3b3c:0:26:0:Intel Corporation:Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B3C
0x1106:0x3044:7:3:0:VIA Technologies, Inc.:VIA 1394 OHCI Compliant Host Controller
0x10ec:0x8168:2:0:0:Realtek Semiconductor Co., Ltd.:Realtek PCIe GbE Family Controller
0x8086:0x3b30:0:31:3:Intel Corporation:Intel(R) PCH SMBus Controller - 3B30 (Intel(R) SMBus 2.0 Driver)
0x8086:0x3b02:0:31:0:Intel Corporation:LPC Controller
0x8086:0xd156:0:8:1:Intel Corporation:Registers
0x8086:0x3b56:0:27:0:Intel Corporation:High Definition Audio Controller
0x8086:0x3b4a:0:28:4:Intel Corporation:PCI-to-PCI Bridge
But the online version of gpus.txt at https://apps.foldingathome.org/GPUs.txt lists the V4800 as follows:
0x1002:0x68c8:::Redwood [FirePro V4800 (FireGL V)]
whose missing values supposedly signal a deprecated device.
But I wonder about the deprecation, given gpu_z's finding that the card supports OpenCL 1.2:
Image and Image
3 Lenovo laptops for low-power draw, all Win10Pro: 1. Lenovo Yoga 6-13 AMD 5700U 8-core/16-thread 16GB Memory NVME; 2. Lenovo X1 Yoga 3G Intel i5-8350U 4-core/8-thread 16GB Memory NVME; 3. Lenovo Flex-14 AMD 4300U 4-core/8-thread 20GB Memory NVME.
Re: Ok, which is it: ":::" or ":0:0:" ?
The current requirement is the card needs to support both OpenCL 1.2 or better and Double Precision (FP64) calculations. Your Forepro V4800 supports the first, but not the second - https://www.techpowerup.com/gpu-specs/f ... v4800.c572.
The third and fourth fields filled with either a zero or left empty in the GPUs.txt entry indicate that the device is unsupported. The values in the output of lspci are just bus locations, and are not copied into GPUs.txt.
Welcome to Folding@Home!
It is a ten year old design. (think dog years) It is a great many generations old (Terascale 2, Terascale 3, GCN1.0 to 5.0, and now Navi)
Core_22( the current latest science for GPUs) requires Double Precision floating point math (FP64) which your GPU lacks. Earlier Cores for GPUs did not, but the demands of science march on.
If you need to fit a GPU in a single slot, a GT 1030 is as well as you can do, but if you have dual slots you could buy a GTX 1650 that would not use more electrical power than the FirePro V4800. (I am not familiar with AMD)
https://www.amazon.com/dp/B07646VQ6T
https://www.amazon.com/dp/B07QF1H9YR
If you are not constrained by size or power, your budget is the limit.
