Whitelist RTX 2070 Super Max-Q
WT_NTAP
Post by WT_NTAP »
Can my GPU get added to the whitelist please?
I've looked through the GPU.txt and the current model with the specific line doesn't exist.
0x10de:0x1ed1:1:0:0:NVIDIA Corporation:NVIDIA GeForce RTX 2070 Super with Max-Q Design
Many thanks.
Re: Whitelist RTX 2070 Super Max-Q
I need the binary code. Run GPU-Z or FAHClient --lspci
WT_NTAP
Post by WT_NTAP »
Apologies Bruce, I submitted the post without providing all the necessary info, won't happen again (read over the how-to post).
Log from FAHClient
*********************** Log Started 2020-06-29T16:06:16Z ***********************
16:06:16:Trying to access database...
16:06:16:Successfully acquired database lock
16:06:16:Downloading GPUs.txt from assign1.foldingathome.org:80
16:06:16:Connecting to assign1.foldingathome.org:80
16:06:17:Read GPUs.txt
16:06:17:Enabled folding slot 00: PAUSED cpu:7 (not configured)
16:06:18:****************************** FAHClient ******************************
16:06:18:        Version: 7.6.13
16:06:18:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:06:18:      Copyright: 2020 foldingathome.org
16:06:18:       Homepage: https://foldingathome.org/
16:06:18:           Date: Apr 27 2020
16:06:18:           Time: 21:21:01
16:06:18:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
16:06:18:         Branch: master
16:06:18:       Compiler: Visual C++ 2008
16:06:18:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:06:18:       Platform: win32 10
16:06:18:           Bits: 32
16:06:18:           Mode: Release
16:06:18:           Args: --open-web-control
16:06:18:******************************** CBang ********************************
16:06:18:           Date: Apr 24 2020
16:06:18:           Time: 17:07:55
16:06:18:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
16:06:18:           Bits: 32
16:06:18:******************************* System ********************************
16:06:18:            CPU: Intel(R) Core(TM) i7-10875H CPU @ 2.30GHz
16:06:18:         CPU ID: GenuineIntel Family 6 Model 165 Stepping 2
16:06:18:           CPUs: 16
16:06:18:         Memory: 31.79GiB
16:06:18:    Free Memory: 25.07GiB
16:06:18:        Threads: WINDOWS_THREADS
16:06:18:     OS Version: 6.2
16:06:18:    Has Battery: true
16:06:18:     On Battery: false
16:06:18:     UTC Offset: 1
16:06:18:            PID: 3428
16:06:18:            CWD: C:\Users\wtnap\AppData\Roaming\FAHClient
16:06:18:  Win32 Service: false
16:06:18:             OS: Windows 10 Enterprise
16:06:18:        OS Arch: AMD64
16:06:18:           GPUs: 0
16:06:18:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.0
16:06:18:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:451.48
16:06:18:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
16:06:18:******************************* libFAH ********************************
16:06:18:           Date: Apr 15 2020
16:06:18:           Time: 14:53:14
16:06:18:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
16:06:18:           Bits: 32
16:06:18:***********************************************************************
16:06:18:<config>
16:06:18:  <!-- Folding Slots -->
16:06:18:  <slot id='0' type='CPU'/>
16:06:18:</config>
16:06:25:17:127.0.0.1:New Web session
16:06:37:Set client configured
16:06:37:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:06:38:WU00:FS00:Assigned to work server 128.252.203.1
16:06:38:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 128.252.203.1
16:06:38:WU00:FS00:Connecting to 128.252.203.1:8080
16:06:38:WU00:FS00:Downloading 1.23MiB
16:06:38:FS00:Paused
16:06:44:WU00:FS00:Download 96.28%
16:06:53:WU00:FS00:Download 100.00%
16:06:53:WU00:FS00:Download complete
16:06:53:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16436 run:0 clone:1621 gen:234 core:0xa7 unit:0x0000011280fccb015ea74e3f8ab9921a
16:07:17:Saving configuration to config.xml
16:07:17:<config>
16:07:17:  <!-- Network -->
16:07:17:  <proxy v=':8080'/>
16:07:17:
16:07:17:  <!-- User Information -->
16:07:17:  <team v='36152'/>
16:07:17:  <user v='WT_NTAP'/>
16:07:17:
16:07:17:  <!-- Folding Slots -->
16:07:17:  <slot id='0' type='CPU'>
16:07:17:    <paused v='true'/>
16:07:17:  </slot>
16:07:17:</config>
Output from FAHClient --lspci
C:\Program Files (x86)\FAHClient>FAHClient.exe --lspci
0x8086:0x06ef:0:20:2:Intel Corporation:Intel(R) Shared SRAM - 06EF
0x10ec:0x8168:59:0:0:Realtek Semiconductor Co., Ltd.:Realtek PCIe GbE Family Controller
0x8086:0x06a4:0:31:5:Intel Corporation:Intel(R) SPI (flash) Controller - 06A4
0x8086:0x06e9:0:21:1:Intel Corporation:Intel(R) Serial IO I2C Host Controller - 06E9
0x8086:0x1903:0:4:0:Intel Corporation:Intel(R) Dynamic Tuning Processor Participant
0x8086:0x06ea:0:21:2:Intel Corporation:Intel(R) Serial IO I2C Host Controller - 06EA
0x8086:0x06c0:0:27:0:Intel Corporation:Intel(R) PCI Express Root Port #17 - 06C0
0x8086:0x15e9:6:0:0:Intel Corporation:USB xHCI Compliant Host Controller
0x8086:0x15e7:2:0:0:Intel Corporation:PCI Express Upstream Switch Port
0x8086:0x9bc4:0:2:0:Intel Corporation:Intel(R) UHD Graphics
0x10de:0x1ad8:1:0:2:NVIDIA Corporation:USB xHCI Compliant Host Controller
0x8086:0x06ed:0:20:0:Intel Corporation:USB xHCI Compliant Host Controller
0x8086:0x06d7:0:23:0:Intel Corporation:Intel(R) Chipset SATA/PCIe RST Premium Controller
0x8086:0x06e0:0:22:0:Intel Corporation:Intel(R) Management Engine Interface
0x8086:0x15e8:4:0:0:Intel Corporation:Thunderbolt(TM) Controller - 15E8
0x8086:0x06e8:0:21:0:Intel Corporation:Intel(R) Serial IO I2C Host Controller - 06E8
0x8086:0x9b44:0:0:0:Intel Corporation:Intel(R) Host Bridge/DRAM Registers - 9B44
0x8086:0x06f9:0:18:0:Intel Corporation:Intel(R) Thermal Subsystem - 06F9
0x8086:0x06b6:0:29:0:Intel Corporation:Intel(R) PCI Express Root Port #15 - 06B6
0x8086:0x06f0:0:20:3:Intel Corporation:Intel(R) Wi-Fi 6 AX201 160MHz
0x8086:0x06c8:0:31:3:Intel Corporation:Intel(R) Smart Sound Technology (Intel(R) SST) Audio Controller
0x8086:0x1911:0:8:0:Intel Corporation:Intel(R) Gaussian Mixture Model - 1911
0x8086:0x068d:0:31:0:Intel Corporation:Intel(R) LPC Controller (HM470) - 068D
0x8086:0x06a3:0:31:4:Intel Corporation:Intel(R) SMBus - 06A3
0x8086:0x15e7:3:0:0:Intel Corporation:PCI Express Downstream Switch Port
0x8086:0x15e7:3:1:0:Intel Corporation:PCI Express Downstream Switch Port
0x8086:0x15e7:3:2:0:Intel Corporation:PCI Express Downstream Switch Port
0x10de:0x10f8:1:0:1:NVIDIA Corporation:High Definition Audio Controller
0x10de:0x1ad9:1:0:3:NVIDIA Corporation:NVIDIA USB Type-C Port Policy Controller
0x8086:0x1901:0:1:0:Intel Corporation:Intel(R) PCIe Controller (x16) - 1901
GPU-Z Output
Device ID 10DE 1ED1 - 1043 165F
Reason: added Code tags to log
I also added 0x1ed3 / TU104BM [GeForce RTX 2080 SUPER Mobile / Max-Q] which was missing ...
WT_NTAP
Post by WT_NTAP »
Thanks bruce, toTOW!
I deleted GPU.txt from the folder, ran the client and it pulled down the updated GPU.txt, and can confirm that the client now sees my GPU. I manually added the slot, and it's now awaiting a WU.
Thanks for awesome turn around!
