Project 14447 (Run 0, Clone 1656, Gen 43) WORK_QUIT
pitter98
Post by pitter98 »
I have had two work units fail in the last couple days that completed with no errors, but the work server dumped the results. The first one I didn't catch in the logs, but this last one I did. The work unit was done in about 7 hours for an estimated 250,000 points, so well before the expiration. The client said there was no errors, but the collection server dumped the results and I received no points. System is a 1080 GTX and a Ryzen 2700x and is very stable with very few crashes. No overclocking in the video card and I rarely have any problems with work units. Any ideas?
*********************** Log Started 2020-06-26T23:18:12Z ***********************
23:18:12:****************************** FAHClient ******************************
23:18:12:        Version: 7.6.9
23:18:12:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:18:12:      Copyright: 2020 foldingathome.org
23:18:12:       Homepage: https://foldingathome.org/
23:18:12:           Date: Apr 17 2020
23:18:12:           Time: 11:13:06
23:18:12:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
23:18:12:         Branch: master
23:18:12:       Compiler: Visual C++ 2008
23:18:12:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:18:12:       Platform: win32 10
23:18:12:           Bits: 32
23:18:12:           Mode: Release
23:18:12:         Config: C:\Users\Pitter\AppData\Roaming\FAHClient\config.xml
23:18:12:******************************** CBang ********************************
23:18:12:           Time: 11:10:09
23:18:12:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
23:18:12:           Bits: 32
23:18:12:******************************* System ********************************
23:18:12:            CPU: AMD Ryzen 7 2700X Eight-Core Processor
23:18:12:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
23:18:12:           CPUs: 16
23:18:12:         Memory: 15.93GiB
23:18:12:    Free Memory: 11.33GiB
23:18:12:        Threads: WINDOWS_THREADS
23:18:12:     OS Version: 6.2
23:18:12:    Has Battery: false
23:18:12:     On Battery: false
23:18:12:     UTC Offset: -4
23:18:12:            PID: 17972
23:18:12:            CWD: C:\Users\Pitter\AppData\Roaming\FAHClient
23:18:12:             OS: Windows 10 Enterprise
23:18:12:        OS Arch: AMD64
23:18:12:           GPUs: 1
23:18:12:          GPU 0: Bus:8 Slot:0 Func:0 NVIDIA:8 GP104 [GeForce GTX 1080] 8873
23:18:12:  CUDA Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:6.1 Driver:11.0
23:18:12:OpenCL Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:1.2 Driver:445.87
23:18:12:  Win32 Service: false
23:18:12:******************************* libFAH ********************************
23:18:12:           Date: Apr 15 2020
23:18:12:           Time: 14:53:14
23:18:12:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
23:18:12:           Bits: 32
23:18:12:***********************************************************************
23:18:12:<config>
23:18:12:  <!-- Network -->
23:18:12:  <proxy v=':8080'/>
23:18:12:
23:18:12:  <!-- Slot Control -->
23:18:12:  <power v='full'/>
23:18:12:
23:18:12:  <!-- User Information -->
23:18:12:  <passkey v='*****'/>
23:18:12:  <team v='32'/>
23:18:12:  <user v='Pitter98'/>
23:18:12:
23:18:12:  <!-- Folding Slots -->
23:18:12:  <slot id='0' type='GPU'/>
23:18:12:</config>
23:18:12:Trying to access database...
23:18:12:Successfully acquired database lock
23:18:12:Enabled folding slot 00: READY gpu:0:GP104 [GeForce GTX 1080] 8873
23:18:12:WU00:FS00:Starting
23:18:12:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Pitter\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 17972 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
23:18:12:WU00:FS00:Started FahCore on PID 2580
23:18:12:WU00:FS00:Core PID:2568
23:18:12:WU00:FS00:FahCore 0x22 started
23:18:13:WU00:FS00:0x22:*********************** Log Started 2020-06-26T23:18:12Z ***********************
23:18:13:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
23:18:13:WU00:FS00:0x22:       Core: Core22
23:18:13:WU00:FS00:0x22:       Type: 0x22
23:18:13:WU00:FS00:0x22:    Version: 0.0.10
23:18:13:WU00:FS00:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:18:13:WU00:FS00:0x22:  Copyright: 2020 foldingathome.org
23:18:13:WU00:FS00:0x22:   Homepage: https://foldingathome.org/
23:18:13:WU00:FS00:0x22:       Date: Jun 16 2020
23:18:13:WU00:FS00:0x22:       Time: 14:33:22
23:18:13:WU00:FS00:0x22:   Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
23:18:13:WU00:FS00:0x22:     Branch: core22-0.0.10
23:18:13:WU00:FS00:0x22:   Compiler: Visual C++ 2015
23:18:13:WU00:FS00:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
23:18:13:WU00:FS00:0x22:   Platform: win32 10
23:18:13:WU00:FS00:0x22:       Bits: 64
23:18:13:WU00:FS00:0x22:       Mode: Release
23:18:13:WU00:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:18:13:WU00:FS00:0x22:             <peastman@stanford.edu>
23:18:13:WU00:FS00:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 2580 -checkpoint 15
23:18:13:WU00:FS00:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
23:18:13:WU00:FS00:0x22:             0 -gpu 0
23:18:13:WU00:FS00:0x22:************************************ libFAH ************************************
23:18:13:WU00:FS00:0x22:       Date: Jun 15 2020
23:18:13:WU00:FS00:0x22:       Time: 18:05:04
23:18:13:WU00:FS00:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
23:18:13:WU00:FS00:0x22:     Branch: HEAD
23:18:13:WU00:FS00:0x22:************************************ CBang *************************************
23:18:13:WU00:FS00:0x22:       Time: 14:31:33
23:18:13:WU00:FS00:0x22:   Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
23:18:13:WU00:FS00:0x22:************************************ System ************************************
23:18:13:WU00:FS00:0x22:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
23:18:13:WU00:FS00:0x22:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
23:18:13:WU00:FS00:0x22:       CPUs: 16
23:18:13:WU00:FS00:0x22:     Memory: 15.93GiB
23:18:13:WU00:FS00:0x22:Free Memory: 11.31GiB
23:18:13:WU00:FS00:0x22:    Threads: WINDOWS_THREADS
23:18:13:WU00:FS00:0x22: OS Version: 6.2
23:18:13:WU00:FS00:0x22:Has Battery: false
23:18:13:WU00:FS00:0x22: On Battery: false
23:18:13:WU00:FS00:0x22: UTC Offset: -4
23:18:13:WU00:FS00:0x22:        PID: 2568
23:18:13:WU00:FS00:0x22:        CWD: C:\Users\Pitter\AppData\Roaming\FAHClient\work
23:18:13:WU00:FS00:0x22:********************************************************************************
23:18:13:WU00:FS00:0x22:Project: 13414 (Run 3852, Clone 23, Gen 1)
23:18:13:WU00:FS00:0x22:Unit: 0x0000000312bc7d9a5ef50d5cdacf91b3
23:18:13:WU00:FS00:0x22:Digital signatures verified
23:18:13:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
23:18:13:WU00:FS00:0x22:Version 0.0.10
23:18:13:WU00:FS00:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
23:18:13:WU00:FS00:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
23:18:13:WU00:FS00:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
23:18:13:WU00:FS00:0x22:  Global context and integrator variables write interval: 250 steps (0.025%) [4000 total]
Log snipped to get under 60k character limit
******************************* Date: 2020-06-27 *******************************
******************************* Date: 2020-06-28 *******************************
05:22:55:WU00:FS00:0x22:Completed 590000 out of 1000000 steps (59%)
05:25:13:WU00:FS00:0x22:Completed 600000 out of 1000000 steps (60%)
05:27:31:WU00:FS00:0x22:Completed 610000 out of 1000000 steps (61%)
05:29:49:WU00:FS00:0x22:Completed 620000 out of 1000000 steps (62%)
05:32:07:WU00:FS00:0x22:Completed 630000 out of 1000000 steps (63%)
05:34:26:WU00:FS00:0x22:Completed 640000 out of 1000000 steps (64%)
05:36:44:WU00:FS00:0x22:Completed 650000 out of 1000000 steps (65%)
05:39:03:WU00:FS00:0x22:Completed 660000 out of 1000000 steps (66%)
05:41:21:WU00:FS00:0x22:Completed 670000 out of 1000000 steps (67%)
05:43:43:WU00:FS00:0x22:Completed 680000 out of 1000000 steps (68%)
05:46:05:WU00:FS00:0x22:Completed 690000 out of 1000000 steps (69%)
05:48:27:WU00:FS00:0x22:Completed 700000 out of 1000000 steps (70%)
05:50:52:WU00:FS00:0x22:Completed 710000 out of 1000000 steps (71%)
05:53:14:WU00:FS00:0x22:Completed 720000 out of 1000000 steps (72%)
05:55:38:WU00:FS00:0x22:Completed 730000 out of 1000000 steps (73%)
05:58:02:WU00:FS00:0x22:Completed 740000 out of 1000000 steps (74%)
06:00:23:WU00:FS00:0x22:Completed 750000 out of 1000000 steps (75%)
06:02:45:WU00:FS00:0x22:Completed 760000 out of 1000000 steps (76%)
06:05:06:WU00:FS00:0x22:Completed 770000 out of 1000000 steps (77%)
06:07:27:WU00:FS00:0x22:Completed 780000 out of 1000000 steps (78%)
06:09:48:WU00:FS00:0x22:Completed 790000 out of 1000000 steps (79%)
06:12:09:WU00:FS00:0x22:Completed 800000 out of 1000000 steps (80%)
06:14:30:WU00:FS00:0x22:Completed 810000 out of 1000000 steps (81%)
06:16:51:WU00:FS00:0x22:Completed 820000 out of 1000000 steps (82%)
06:19:10:WU00:FS00:0x22:Completed 830000 out of 1000000 steps (83%)
06:21:31:WU00:FS00:0x22:Completed 840000 out of 1000000 steps (84%)
06:23:51:WU00:FS00:0x22:Completed 850000 out of 1000000 steps (85%)
06:26:12:WU00:FS00:0x22:Completed 860000 out of 1000000 steps (86%)
06:28:32:WU00:FS00:0x22:Completed 870000 out of 1000000 steps (87%)
06:30:52:WU00:FS00:0x22:Completed 880000 out of 1000000 steps (88%)
06:33:12:WU00:FS00:0x22:Completed 890000 out of 1000000 steps (89%)
06:35:32:WU00:FS00:0x22:Completed 900000 out of 1000000 steps (90%)
06:37:53:WU00:FS00:0x22:Completed 910000 out of 1000000 steps (91%)
06:40:13:WU00:FS00:0x22:Completed 920000 out of 1000000 steps (92%)
06:42:33:WU00:FS00:0x22:Completed 930000 out of 1000000 steps (93%)
06:44:53:WU00:FS00:0x22:Completed 940000 out of 1000000 steps (94%)
06:47:13:WU00:FS00:0x22:Completed 950000 out of 1000000 steps (95%)
06:49:35:WU00:FS00:0x22:Completed 960000 out of 1000000 steps (96%)
06:51:55:WU00:FS00:0x22:Completed 970000 out of 1000000 steps (97%)
06:54:15:WU00:FS00:0x22:Completed 980000 out of 1000000 steps (98%)
06:56:35:WU00:FS00:0x22:Completed 990000 out of 1000000 steps (99%)
06:56:36:WU01:FS00:Connecting to 65.254.110.245:80
06:56:36:WU01:FS00:Assigned to work server 3.133.76.19
06:56:36:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 3.133.76.19
06:56:36:WU01:FS00:Connecting to 3.133.76.19:8080
06:56:40:WU01:FS00:Downloading 19.29MiB
06:56:42:WU01:FS00:Download complete
06:56:42:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14462 run:0 clone:395 gen:66 core:0x22 unit:0x0000006c03854c135eb39e43cdbed0ba
06:58:55:WU00:FS00:0x22:Completed 1000000 out of 1000000 steps (100%)
06:58:55:WU00:FS00:0x22:Average performance: 123.252 ns/day
06:58:57:WU00:FS00:0x22:Saving result file ..\logfile_01.txt
06:58:57:WU00:FS00:0x22:Saving result file checkpointState.xml
06:58:58:WU00:FS00:0x22:Saving result file globals.csv
06:58:58:WU00:FS00:0x22:Saving result file positions.xtc
06:58:58:WU00:FS00:0x22:Saving result file science.log
06:58:58:WU00:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
06:58:59:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:58:59:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13414 run:1152 clone:53 gen:0 core:0x22 unit:0x0000000012bc7d9a5ef19faab55f724f
06:58:59:WU00:FS00:Uploading 7.45MiB to 18.188.125.154
06:58:59:WU00:FS00:Connecting to 18.188.125.154:8080
06:58:59:WU01:FS00:Starting
06:58:59:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Pitter\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 17972 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
06:58:59:WU01:FS00:Started FahCore on PID 3620
06:58:59:WU01:FS00:Core PID:9040
06:58:59:WU01:FS00:FahCore 0x22 started
06:59:00:WU01:FS00:0x22:*********************** Log Started 2020-06-28T06:58:59Z ***********************
06:59:00:WU01:FS00:0x22:*************************** Core22 Folding@home Core ***************************
06:59:00:WU01:FS00:0x22:       Core: Core22
06:59:00:WU01:FS00:0x22:       Type: 0x22
06:59:00:WU01:FS00:0x22:    Version: 0.0.10
06:59:00:WU01:FS00:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:59:00:WU01:FS00:0x22:  Copyright: 2020 foldingathome.org
06:59:00:WU01:FS00:0x22:   Homepage: https://foldingathome.org/
06:59:00:WU01:FS00:0x22:       Date: Jun 16 2020
06:59:00:WU01:FS00:0x22:       Time: 14:33:22
06:59:00:WU01:FS00:0x22:   Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
06:59:00:WU01:FS00:0x22:     Branch: core22-0.0.10
06:59:00:WU01:FS00:0x22:   Compiler: Visual C++ 2015
06:59:00:WU01:FS00:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
06:59:00:WU01:FS00:0x22:   Platform: win32 10
06:59:00:WU01:FS00:0x22:       Bits: 64
06:59:00:WU01:FS00:0x22:       Mode: Release
06:59:00:WU01:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
06:59:00:WU01:FS00:0x22:             <peastman@stanford.edu>
06:59:00:WU01:FS00:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 3620 -checkpoint 15
06:59:00:WU01:FS00:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
06:59:00:WU01:FS00:0x22:             0 -gpu 0
06:59:00:WU01:FS00:0x22:************************************ libFAH ************************************
06:59:00:WU01:FS00:0x22:       Date: Jun 15 2020
06:59:00:WU01:FS00:0x22:       Time: 18:05:04
06:59:00:WU01:FS00:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
06:59:00:WU01:FS00:0x22:     Branch: HEAD
06:59:00:WU01:FS00:0x22:************************************ CBang *************************************
06:59:00:WU01:FS00:0x22:       Time: 14:31:33
06:59:00:WU01:FS00:0x22:   Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
06:59:00:WU01:FS00:0x22:************************************ System ************************************
06:59:00:WU01:FS00:0x22:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
06:59:00:WU01:FS00:0x22:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
06:59:00:WU01:FS00:0x22:       CPUs: 16
06:59:00:WU01:FS00:0x22:     Memory: 15.93GiB
06:59:00:WU01:FS00:0x22:Free Memory: 10.19GiB
06:59:00:WU01:FS00:0x22:    Threads: WINDOWS_THREADS
06:59:00:WU01:FS00:0x22: OS Version: 6.2
06:59:00:WU01:FS00:0x22:Has Battery: false
06:59:00:WU01:FS00:0x22: On Battery: false
06:59:00:WU01:FS00:0x22: UTC Offset: -4
06:59:00:WU01:FS00:0x22:        PID: 9040
06:59:00:WU01:FS00:0x22:        CWD: C:\Users\Pitter\AppData\Roaming\FAHClient\work
06:59:00:WU01:FS00:0x22:********************************************************************************
06:59:00:WU01:FS00:0x22:Project: 14462 (Run 0, Clone 395, Gen 66)
06:59:00:WU01:FS00:0x22:Unit: 0x0000006c03854c135eb39e43cdbed0ba
06:59:00:WU01:FS00:0x22:Reading tar file core.xml
06:59:00:WU01:FS00:0x22:Reading tar file integrator.xml
06:59:00:WU01:FS00:0x22:Reading tar file state.xml
06:59:00:WU01:FS00:0x22:Reading tar file system.xml
06:59:00:WU01:FS00:0x22:Digital signatures verified
06:59:00:WU01:FS00:0x22:Folding@home GPU Core22 Folding@home Core
06:59:00:WU01:FS00:0x22:Version 0.0.10
06:59:01:WU01:FS00:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
06:59:01:WU01:FS00:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
06:59:01:WU01:FS00:0x22:  XTC frame write interval: 20000 steps (1%) [100 total]
06:59:01:WU01:FS00:0x22:  Global context and integrator variables write interval: disabled
06:59:05:WU00:FS00:Upload complete
06:59:05:WU00:FS00:Server responded WORK_ACK (400)
06:59:05:WU00:FS00:Final credit estimate, 161094.00 points
06:59:05:WU00:FS00:Cleaning up
06:59:17:WU01:FS00:0x22:Completed 0 out of 2000000 steps (0%)
07:02:56:WU01:FS00:0x22:Completed 20000 out of 2000000 steps (1%)
07:06:35:WU01:FS00:0x22:Completed 40000 out of 2000000 steps (2%)
07:10:14:WU01:FS00:0x22:Completed 60000 out of 2000000 steps (3%)
07:13:52:WU01:FS00:0x22:Completed 80000 out of 2000000 steps (4%)
07:17:31:WU01:FS00:0x22:Completed 100000 out of 2000000 steps (5%)
07:21:11:WU01:FS00:0x22:Completed 120000 out of 2000000 steps (6%)
07:24:49:WU01:FS00:0x22:Completed 140000 out of 2000000 steps (7%)
07:28:27:WU01:FS00:0x22:Completed 160000 out of 2000000 steps (8%)
07:32:06:WU01:FS00:0x22:Completed 180000 out of 2000000 steps (9%)
07:35:44:WU01:FS00:0x22:Completed 200000 out of 2000000 steps (10%)
07:39:24:WU01:FS00:0x22:Completed 220000 out of 2000000 steps (11%)
07:43:03:WU01:FS00:0x22:Completed 240000 out of 2000000 steps (12%)
07:46:41:WU01:FS00:0x22:Completed 260000 out of 2000000 steps (13%)
07:50:20:WU01:FS00:0x22:Completed 280000 out of 2000000 steps (14%)
07:53:59:WU01:FS00:0x22:Completed 300000 out of 2000000 steps (15%)
07:57:38:WU01:FS00:0x22:Completed 320000 out of 2000000 steps (16%)
08:01:17:WU01:FS00:0x22:Completed 340000 out of 2000000 steps (17%)
08:04:55:WU01:FS00:0x22:Completed 360000 out of 2000000 steps (18%)
08:08:34:WU01:FS00:0x22:Completed 380000 out of 2000000 steps (19%)
08:12:12:WU01:FS00:0x22:Completed 400000 out of 2000000 steps (20%)
08:15:52:WU01:FS00:0x22:Completed 420000 out of 2000000 steps (21%)
08:19:31:WU01:FS00:0x22:Completed 440000 out of 2000000 steps (22%)
08:23:10:WU01:FS00:0x22:Completed 460000 out of 2000000 steps (23%)
08:26:48:WU01:FS00:0x22:Completed 480000 out of 2000000 steps (24%)
08:30:27:WU01:FS00:0x22:Completed 500000 out of 2000000 steps (25%)
08:34:07:WU01:FS00:0
x22:Completed 520000 out of 2000000 steps (26%)
08:37:46:WU01:FS00:0x22:Completed 540000 out of 2000000 steps (27%)
08:41:24:WU01:FS00:0x22:Completed 560000 out of 2000000 steps (28%)
08:45:03:WU01:FS00:0x22:Completed 580000 out of 2000000 steps (29%)
08:48:41:WU01:FS00:0x22:Completed 600000 out of 2000000 steps (30%)
08:52:21:WU01:FS00:0x22:Completed 620000 out of 2000000 steps (31%)
08:56:00:WU01:FS00:0x22:Completed 640000 out of 2000000 steps (32%)
08:59:39:WU01:FS00:0x22:Completed 660000 out of 2000000 steps (33%)
09:03:17:WU01:FS00:0x22:Completed 680000 out of 2000000 steps (34%)
09:06:56:WU01:FS00:0x22:Completed 700000 out of 2000000 steps (35%)
09:10:36:WU01:FS00:0x22:Completed 720000 out of 2000000 steps (36%)
09:14:14:WU01:FS00:0x22:Completed 740000 out of 2000000 steps (37%)
09:17:53:WU01:FS00:0x22:Completed 760000 out of 2000000 steps (38%)
09:21:31:WU01:FS00:0x22:Completed 780000 out of 2000000 steps (39%)
09:25:10:WU01:FS00:0x22:Completed 800000 out of 2000000 steps (40%)
09:28:50:WU01:FS00:0x22:Completed 820000 out of 2000000 steps (41%)
09:32:28:WU01:FS00:0x22:Completed 840000 out of 2000000 steps (42%)
09:36:07:WU01:FS00:0x22:Completed 860000 out of 2000000 steps (43%)
09:39:45:WU01:FS00:0x22:Completed 880000 out of 2000000 steps (44%)
09:43:24:WU01:FS00:0x22:Completed 900000 out of 2000000 steps (45%)
09:47:04:WU01:FS00:0x22:Completed 920000 out of 2000000 steps (46%)
09:50:42:WU01:FS00:0x22:Completed 940000 out of 2000000 steps (47%)
09:54:21:WU01:FS00:0x22:Completed 960000 out of 2000000 steps (48%)
09:58:00:WU01:FS00:0x22:Completed 980000 out of 2000000 steps (49%)
10:01:38:WU01:FS00:0x22:Completed 1000000 out of 2000000 steps (50%)
10:05:18:WU01:FS00:0x22:Completed 1020000 out of 2000000 steps (51%)
10:08:56:WU01:FS00:0x22:Completed 1040000 out of 2000000 steps (52%)
10:12:35:WU01:FS00:0x22:Completed 1060000 out of 2000000 steps (53%)
10:16:14:WU01:FS00:0x22:Completed 1080000 out of 2000000 steps (54%)
10:19:52:WU01:FS00:0x22:Completed 1100000 out of 2000000 steps (55%)
10:23:32:WU01:FS00:0x22:Completed 1120000 out of 2000000 steps (56%)
10:27:11:WU01:FS00:0x22:Completed 1140000 out of 2000000 steps (57%)
10:30:49:WU01:FS00:0x22:Completed 1160000 out of 2000000 steps (58%)
10:34:28:WU01:FS00:0x22:Completed 1180000 out of 2000000 steps (59%)
10:38:07:WU01:FS00:0x22:Completed 1200000 out of 2000000 steps (60%)
10:41:46:WU01:FS00:0x22:Completed 1220000 out of 2000000 steps (61%)
10:45:25:WU01:FS00:0x22:Completed 1240000 out of 2000000 steps (62%)
10:49:04:WU01:FS00:0x22:Completed 1260000 out of 2000000 steps (63%)
10:52:43:WU01:FS00:0x22:Completed 1280000 out of 2000000 steps (64%)
10:56:22:WU01:FS00:0x22:Completed 1300000 out of 2000000 steps (65%)
11:00:02:WU01:FS00:0x22:Completed 1320000 out of 2000000 steps (66%)
11:03:41:WU01:FS00:0x22:Completed 1340000 out of 2000000 steps (67%)
11:07:19:WU01:FS00:0x22:Completed 1360000 out of 2000000 steps (68%)
11:10:58:WU01:FS00:0x22:Completed 1380000 out of 2000000 steps (69%)
11:14:36:WU01:FS00:0x22:Completed 1400000 out of 2000000 steps (70%)
11:18:16:WU01:FS00:0x22:Completed 1420000 out of 2000000 steps (71%)
11:21:55:WU01:FS00:0x22:Completed 1440000 out of 2000000 steps (72%)
11:25:33:WU01:FS00:0x22:Completed 1460000 out of 2000000 steps (73%)
11:29:12:WU01:FS00:0x22:Completed 1480000 out of 2000000 steps (74%)
11:32:50:WU01:FS00:0x22:Completed 1500000 out of 2000000 steps (75%)
11:36:30:WU01:FS00:0x22:Completed 1520000 out of 2000000 steps (76%)
11:40:09:WU01:FS00:0x22:Completed 1540000 out of 2000000 steps (77%)
11:43:47:WU01:FS00:0x22:Completed 1560000 out of 2000000 steps (78%)
11:47:26:WU01:FS00:0x22:Completed 1580000 out of 2000000 steps (79%)
11:51:04:WU01:FS00:0x22:Completed 1600000 out of 2000000 steps (80%)
11:54:44:WU01:FS00:0x22:Completed 1620000 out of 2000000 steps (81%)
11:58:22:WU01:FS00:0x22:Completed 1640000 out of 2000000 steps (82%)
12:02:00:WU01:FS00:0x22:Completed 1660000 out of 2000000 steps (83%)
12:05:39:WU01:FS00:0x22:Completed 1680000 out of 2000000 steps (84%)
12:09:18:WU01:FS00:0x22:Completed 1700000 out of 2000000 steps (85%)
12:12:58:WU01:FS00:0x22:Completed 1720000 out of 2000000 steps (86%)
12:16:36:WU01:FS00:0x22:Completed 1740000 out of 2000000 steps (87%)
12:20:15:WU01:FS00:0x22:Completed 1760000 out of 2000000 steps (88%)
12:23:54:WU01:FS00:0x22:Completed 1780000 out of 2000000 steps (89%)
12:27:33:WU01:FS00:0x22:Completed 1800000 out of 2000000 steps (90%)
12:31:14:WU01:FS00:0x22:Completed 1820000 out of 2000000 steps (91%)
12:34:53:WU01:FS00:0x22:Completed 1840000 out of 2000000 steps (92%)
12:38:32:WU01:FS00:0x22:Completed 1860000 out of 2000000 steps (93%)
12:42:10:WU01:FS00:0x22:Completed 1880000 out of 2000000 steps (94%)
12:45:49:WU01:FS00:0x22:Completed 1900000 out of 2000000 steps (95%)
12:49:29:WU01:FS00:0x22:Completed 1920000 out of 2000000 steps (96%)
12:53:08:WU01:FS00:0x22:Completed 1940000 out of 2000000 steps (97%)
12:56:47:WU01:FS00:0x22:Completed 1960000 out of 2000000 steps (98%)
13:00:25:WU01:FS00:0x22:Completed 1980000 out of 2000000 steps (99%)
13:00:26:WU00:FS00:Connecting to 65.254.110.245:80
13:00:26:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
13:00:26:WU00:FS00:Connecting to 18.218.241.186:80
13:00:26:WU00:FS00:Assigned to work server 3.133.76.19
13:00:26:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 3.133.76.19
13:00:26:WU00:FS00:Connecting to 3.133.76.19:8080
13:01:38:WU00:FS00:Downloading 20.50MiB
13:01:39:WU00:FS00:Download complete
13:01:39:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14447 run:0 clone:1656 gen:43 core:0x22 unit:0x0000004003854c135ea7b88f37668943
13:04:04:WU01:FS00:0x22:Completed 2000000 out of 2000000 steps (100%)
13:04:04:WU01:FS00:0x22:Average performance: 3.16194 ns/day
13:04:10:WU01:FS00:0x22:Saving result file ..\logfile_01.txt
13:04:10:WU01:FS00:0x22:Saving result file checkpointState.xml
13:04:12:WU01:FS00:0x22:Saving result file positions.xtc
13:04:15:WU01:FS00:0x22:Saving result file science.log
13:04:15:WU01:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
13:04:16:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:04:16:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14462 run:0 clone:395 gen:66 core:0x22 unit:0x0000006c03854c135eb39e43cdbed0ba
13:04:16:WU01:FS00:Uploading 88.73MiB to 3.133.76.19
13:04:16:WU01:FS00:Connecting to 3.133.76.19:8080
13:04:16:WU00:FS00:Starting
13:04:16:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Pitter\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 17972 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
13:04:16:WU00:FS00:Started FahCore on PID 17868
13:04:16:WU00:FS00:Core PID:12116
13:04:16:WU00:FS00:FahCore 0x22 started
13:04:16:WU00:FS00:0x22:*********************** Log Started 2020-06-28T13:04:16Z ***********************
13:04:16:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
13:04:16:WU00:FS00:0x22:       Core: Core22
13:04:16:WU00:FS00:0x22:       Type: 0x22
13:04:16:WU00:FS00:0x22:    Version: 0.0.10
13:04:16:WU00:FS00:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:04:16:WU00:FS00:0x22:  Copyright: 2020 foldingathome.org
13:04:16:WU00:FS00:0x22:   Homepage: https://foldingathome.org/
13:04:16:WU00:FS00:0x22:       Date: Jun 16 2020
13:04:16:WU00:FS00:0x22:       Time: 14:33:22
13:04:16:WU00:FS00:0x22:   Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
13:04:16:WU00:FS00:0x22:     Branch: core22-0.0.10
13:04:16:WU00:FS00:0x22:   Compiler: Visual C++ 2015
13:04:16:WU00:FS00:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
13:04:16:WU00:FS00:0x22:   Platform: win32 10
13:04:16:WU00:FS00:0x22:       Bits: 64
13:04:16:WU00:FS00:0x22:       Mode: Release
13:04:16:WU00:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
13:04:16:WU00:FS00:0x22:             <peastman@stanford.edu>
13:04:16:WU00:FS00:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 17868 -checkpoint 15
13:04:16:WU00:FS00:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
13:04:16:WU00:FS00:0x22:             0 -gpu 0
13:04:16:WU00:FS00:0x22:************************************ libFAH ************************************
13:04:16:WU00:FS00:0x22:       Date: Jun 15 2020
13:04:16:WU00:FS00:0x22:       Time: 18:05:04
13:04:16:WU00:FS00:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
13:04:16:WU00:FS00:0x22:     Branch: HEAD
13:04:16:WU00:FS00:0x22:************************************ CBang *************************************
13:04:16:WU00:FS00:0x22:       Time: 14:31:33
13:04:16:WU00:FS00:0x22:   Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
13:04:16:WU00:FS00:0x22:************************************ System ************************************
13:04:16:WU00:FS00:0x22:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
13:04:16:WU00:FS00:0x22:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
13:04:16:WU00:FS00:0x22:       CPUs: 16
13:04:16:WU00:FS00:0x22:     Memory: 15.93GiB
13:04:16:WU00:FS00:0x22:Free Memory: 10.09GiB
13:04:16:WU00:FS00:0x22:    Threads: WINDOWS_THREADS
13:04:16:WU00:FS00:0x22: OS Version: 6.2
13:04:16:WU00:FS00:0x22:Has Battery: false
13:04:16:WU00:FS00:0x22: On Battery: false
13:04:16:WU00:FS00:0x22: UTC Offset: -4
13:04:16:WU00:FS00:0x22:        PID: 12116
13:04:16:WU00:FS00:0x22:        CWD: C:\Users\Pitter\AppData\Roaming\FAHClient\work
13:04:16:WU00:FS00:0x22:********************************************************************************
13:04:16:WU00:FS00:0x22:Project: 14447 (Run 0, Clone 1656, Gen 43)
13:04:16:WU00:FS00:0x22:Unit: 0x0000004003854c135ea7b88f37668943
13:04:16:WU00:FS00:0x22:Reading tar file core.xml
13:04:16:WU00:FS00:0x22:Reading tar file integrator.xml
13:04:16:WU00:FS00:0x22:Reading tar file state.xml
13:04:17:WU00:FS00:0x22:Reading tar file system.xml
13:04:17:WU00:FS00:0x22:Digital signatures verified
13:04:17:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
13:04:17:WU00:FS00:0x22:Version 0.0.10
13:04:17:WU00:FS00:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
13:04:17:WU00:FS00:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
13:04:17:WU00:FS00:0x22:  XTC frame write interval: 20000 steps (1%) [100 total]
13:04:17:WU00:FS00:0x22:  Global context and integrator variables write interval: disabled
13:04:35:WU00:FS00:0x22:Completed 0 out of 2000000 steps (0%)
13:05:04:WU01:FS00:Upload 0.14%
13:05:10:WU01:FS00:Upload 10.50%
13:05:16:WU01:FS00:Upload 21.98%
13:05:22:WU01:FS00:Upload 33.39%
13:05:28:WU01:FS00:Upload 44.94%
13:05:34:WU01:FS00:Upload 56.63%
13:05:40:WU01:FS00:Upload 68.11%
13:05:46:WU01:FS00:Upload 79.81%
13:05:52:WU01:FS00:Upload 91.50%
13:05:57:WU01:FS00:Upload complete
13:05:57:WU01:FS00:Server responded WORK_ACK (400)
13:05:57:WU01:FS00:Final credit estimate, 221771.00 points
13:05:57:WU01:FS00:Cleaning up
13:08:49:WU00:FS00:0x22:Completed 20000 out of 2000000 steps (1%)
13:13:02:WU00:FS00:0x22:Completed 40000 out of 2000000 steps (2%)
13:17:14:WU00:FS00:0x22:Completed 60000 out of 2000000 steps (3%)
13:21:26:WU00:FS00:0x22:Completed 80000 out of 2000000 steps (4%)
13:25:39:WU00:FS00:0x22:Completed 100000 out of 2000000 steps (5%)
13:29:53:WU00:FS00:0x22:Completed 120000 out of 2000000 steps (6%)
13:34:05:WU00:FS00:0x22:Completed 140000 out of 2000000 steps (7%)
13:38:18:WU00:FS00:0x22:Completed 160000 out of 2000000 steps (8%)
13:42:30:WU00:FS00:0x22:Completed 180000 out of 2000000 steps (9%)
13:46:43:WU00:FS00:0x22:Completed 200000 out of 2000000 steps (10%)
13:50:57:WU00:FS00:0x22:Completed 220000 out of 2000000 steps (11%)
13:55:10:WU00:FS00:0x22:Completed 240000 out of 2000000 steps (12%)
13:59:22:WU00:FS00:0x22:Completed 260000 out of 2000000 steps (13%)
14:03:35:WU00:FS00:0x22:Completed 280000 out of 2000000 steps (14%)
14:07:47:WU00:FS00:0x22:Completed 300000 out of 2000000 steps (15%)
14:12:01:WU00:FS00:0x22:Completed 320000 out of 2000000 steps (16%)
14:16:14:WU00:FS00:0x22:Completed 340000 out of 2000000 steps (17%)
14:20:26:WU00:FS00:0x22:Completed 360000 out of 2000000 steps (18%)
14:24:39:WU00:FS00:0x22:Completed 380000 out of 2000000 steps (19%)
14:28:51:WU00:FS00:0x22:Completed 400000 out of 2000000 steps (20%)
14:33:05:WU00:FS00:0x22:Completed 420000 out of 2000000 steps (21%)
14:37:18:WU00:FS00:0x22:Completed 440000 out of 2000000 steps (22%)
14:41:30:WU00:FS00:0x22:Completed 460000 out of 2000000 steps (23%)
14:45:43:WU00:FS00:0x22:Completed 480000 out of 2000000 steps (24%)
14:49:56:WU00:FS00:0x22:Completed 500000 out of 2000000 steps (25%)
14:54:10:WU00:FS00:0x22:Completed 520000 out of 2000000 steps (26%)
14:58:22:WU00:FS00:0x22:Completed 540000 out of 2000000 steps (27%)
15:02:35:WU00:FS00:0x22:Completed 560000 out of 2000000 steps (28%)
15:06:48:WU00:FS00:0x22:Completed 580000 out of 2000000 steps (29%)
15:11:00:WU00:FS00:0x22:Completed 600000 out of 2000000 steps (30%)
15:15:14:WU00:FS00:0x22:Completed 620000 out of 2000000 steps (31%)
15:19:27:WU00:FS00:0x22:Completed 640000 out of 2000000 steps (32%)
15:23:40:WU00:FS00:0x22:Completed 660000 out of 2000000 steps (33%)
15:27:52:WU00:FS00:0x22:Completed 680000 out of 2000000 steps (34%)
15:32:05:WU00:FS00:0x22:Completed 700000 out of 2000000 steps (35%)
15:36:19:WU00:FS00:0x22:Completed 720000 out of 2000000 steps (36%)
15:40:32:WU00:FS00:0x22:Completed 740000 out of 2000000 steps (37%)
15:44:48:WU00:FS00:0x22:Completed 760000 out of 2000000 steps (38%)
15:49:06:WU00:FS00:0x22:Completed 780000 out of 2000000 steps (39%)
15:53:24:WU00:FS00:0x22:Completed 800000 out of 2000000 steps (40%)
15:57:43:WU00:FS00:0x22:Completed 820000 out of 2000000 steps (41%)
16:01:59:WU00:FS00:0x22:Completed 840000 out of 2000000 steps (42%)
16:06:14:WU00:FS00:0x22:Completed 860000 out of 2000000 steps (43%)
16:10:29:WU00:FS00:0x22:Completed 880000 out of 2000000 steps (44%)
16:14:45:WU00:FS00:0x22:Completed 900000 out of 2000000 steps (45%)
16:19:01:WU00:FS00:0x22:Completed 920000 out of 2000000 steps (46%)
16:23:17:WU00:FS00:0x22:Completed 940000 out of 2000000 steps (47%)
16:27:32:WU00:FS00:0x22:Completed 960000 out of 2000000 steps (48%)
16:31:47:WU00:FS00:0x22:Completed 980000 out of 2000000 steps (49%)
16:36:02:WU00:FS00:0x22:Completed 1000000 out of 2000000 steps (50%)
16:40:19:WU00:FS00:0x22:Completed 1020000 out of 2000000 steps (51%)
16:44:34:WU00:FS00:0x22:Completed 1040000 out of 2000000 steps (52%)
16:48:49:WU00:FS00:0x22:Completed 1060000 out of 2000000 steps (53%)
16:53:04:WU00:FS00:0x22:Completed 1080000 out of 2000000 steps (54%)
16:57:20:WU00:FS00:0x22:Completed 1100000 out of 2000000 steps (55%)
17:01:36:WU00:FS00:0x22:Completed 1120000 out of 2000000 steps (56%)
17:05:51:WU00:FS00:0x22:Completed 1140000 out of 2000000 steps (57%)
17:10:07:WU00:FS00:0x22:Completed 1160000 out of 2000000 steps (58%)
17:14:22:WU00:FS00:0x22:Completed 1180000 out of 2000000 steps (59%)
17:18:37:WU00:FS00:0x22:Completed 1200000 out of 2000000 steps (60%)
17:22:53:WU00:FS00:0x22:Completed 1220000 out of 2000000 steps (61%)
17:27:09:WU00:FS00:0x22:Completed 1240000 out of 2000000 steps (62%)
17:31:24:WU00:FS00:0x22:Completed 1260000 out of 2000000 steps (63%)
17:35:39:WU00:FS00:0x22:Completed 1280000 out of 2000000 steps (64%)
17:39:54:WU00:FS00:0x22:Completed 1300000 out of 2000000 steps (65%)
17:44:11:WU00:FS00:0x22:Completed 1320000 out of 2000000 steps (66%)
17:48:26:WU00:FS00:0x22:Completed 1340000 out of 2000000 steps (67%)
17:52:41:WU00:FS00:0x22:Completed 1360000 out of 2000000 steps (68%)
17:56:56:WU00:FS00:0x22:Completed 1380000 out of 2000000 steps (69%)
18:01:11:WU00:FS00:0x22:Completed 1400000 out of 2000000 steps (70%)
18:05:28:WU00:FS00:0x22:Completed 1420000 out of 2000000 steps (71%)
18:09:43:WU00:FS00:0x22:Completed 1440000 out of 2000000 steps (72%)
18:13:58:WU00:FS00:0x22:Completed 1460000 out of 2000000 steps (73%)
18:18:14:WU00:FS00:0x22:Completed 1480000 out of 2000000 steps (74%)
18:22:29:WU00:FS00:0x22:Completed 1500000 out of 2000000 steps (75%)
18:26:46:WU00:FS00:0x22:Completed 1520000 out of 2000000 steps (76%)
18:31:01:WU00:FS00:0x22:Completed 1540000 out of 2000000 steps (77%)
18:35:16:WU00:FS00:0x22:Completed 1560000 out of 2000000 steps (78%)
18:39:31:WU00:FS00:0x22:Completed 1580000 out of 2000000 steps (79%)
18:43:46:WU00:FS00:0x22:Completed 1600000 out of 2000000 steps (80%)
18:48:03:WU00:FS00:0x22:Completed 1620000 out of 2000000 steps (81%)
18:52:18:WU00:FS00:0x22:Completed 1640000 out of 2000000 steps (82%)
18:56:34:WU00:FS00:0x22:Completed 1660000 out of 2000000 steps (83%)
19:00:49:WU00:FS00:0x22:Completed 1680000 out of 2000000 steps (84%)
19:05:04:WU00:FS00:0x22:Completed 1700000 out of 2000000 steps (85%)
19:09:21:WU00:FS00:0x22:Completed 1720000 out of 2000000 steps (86%)
19:13:36:WU00:FS00:0x22:Completed 1740000 out of 2000000 steps (87%)
19:17:51:WU00:FS00:0x22:Completed 1760000 out of 2000000 steps (88%)
19:22:06:WU00:FS00:0x22:Completed 1780000 out of 2000000 steps (89%)
19:26:21:WU00:FS00:0x22:Completed 1800000 out of 2000000 steps (90%)
19:30:38:WU00:FS00:0x22:Completed 1820000 out of 2000000 steps (91%)
19:34:53:WU00:FS00:0x22:Completed 1840000 out of 2000000 steps (92%)
19:39:08:WU00:FS00:0x22:Completed 1860000 out of 2000000 steps (93%)
19:43:23:WU00:FS00:0x22:Completed 1880000 out of 2000000 steps (94%)
19:47:38:WU00:FS00:0x22:Completed 1900000 out of 2000000 steps (95%)
19:51:55:WU00:FS00:0x22:Completed 1920000 out of 2000000 steps (96%)
19:56:10:WU00:FS00:0x22:Completed 1940000 out of 2000000 steps (97%)
20:00:25:WU00:FS00:0x22:Completed 1960000 out of 2000000 steps (98%)
20:04:40:WU00:FS00:0x22:Completed 1980000 out of 2000000 steps (99%)
20:08:55:WU00:FS00:0x22:Completed 2000000 out of 2000000 steps (100%)
20:08:55:WU00:FS00:0x22:Average performance: 2.71059 ns/day
20:09:01:WU00:FS00:0x22:Saving result file ..\logfile_01.txt
20:09:01:WU00:FS00:0x22:Saving result file checkpointState.xml
20:09:04:WU00:FS00:0x22:Saving result file positions.xtc
20:09:07:WU00:FS00:0x22:Saving result file science.log
20:09:07:WU00:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
20:09:08:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:09:08:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14447 run:0 clone:1656 gen:43 core:0x22 unit:0x0000004003854c135ea7b88f37668943
20:09:08:WU00:FS00:Uploading 94.20MiB to 3.133.76.19
20:09:08:WU00:FS00:Connecting to 3.133.76.19:8080
20:09:29:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
20:09:29:WU00:FS00:Connecting to 3.133.76.19:80
20:09:50:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
20:09:50:WU00:FS00:Trying to send results to collection server
20:09:50:WU00:FS00:Uploading 94.20MiB to 3.21.157.11
20:09:50:WU00:FS00:Connecting to 3.21.157.11:8080
20:09:56:WU00:FS00:Upload 9.22%
20:10:02:WU00:FS00:Upload 20.17%
20:10:08:WU00:FS00:Upload 31.18%
20:10:14:WU00:FS00:Upload 42.40%
20:10:20:WU00:FS00:Upload 53.41%
20:10:26:WU00:FS00:Upload 64.56%
20:10:32:WU00:FS00:Upload 70.00%
20:10:38:WU00:FS00:Upload 80.28%
20:10:44:WU00:FS00:Upload 91.23%
20:10:49:WU00:FS00:Upload complete
20:10:49:WU00:FS00:Server responded WORK_QUIT (404)
20:10:49:WARNING:WU00:FS00:Server did not like results, dumping
20:10:49:WU00:FS00:Cleaning up
pitter98
Re: Project 14447 (Run 0, Clone 1656, Gen 43) WORK_QUIT
Post by pitter98 »
Just wanted to add that I actually did catch both units that got dumped in the logs, but accidentally clipped out the first one. It is attached below.
Project:13414 (Run 3995, Clone 48, Gen 0)
23:18:12:           Bits: 32
23:18:12:           Bits: 32
23:18:12:           CPUs: 16
23:18:12:           GPUs: 1
23:18:12:           Bits: 32
23:18:12:<config>
23:18:12:
23:18:12:
23:18:12:
23:18:12:</config>
23:18:24:WU00:FS00:0x22:Completed 100000 out of 1000000 steps (10%)
02:44:27:WU00:FS00:0x22:Completed 990000 out of 1000000 steps (99%)
02:44:28:WU01:FS00:Connecting to 65.254.110.245:80
02:44:28:WU01:FS00:Assigned to work server 140.163.4.231
02:44:28:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 140.163.4.231
02:44:28:WU01:FS00:Connecting to 140.163.4.231:8080
02:44:50:ERROR:WU01:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
02:44:50:WU01:FS00:Connecting to 65.254.110.245:80
02:44:50:WU01:FS00:Assigned to work server 66.170.111.50
02:44:50:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 66.170.111.50
02:44:50:WU01:FS00:Connecting to 66.170.111.50:8080
02:44:57:WU01:FS00:Downloading 22.41MiB
02:45:03:WU01:FS00:Download 90.08%
02:45:03:WU01:FS00:Download complete
02:45:03:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16448 run:0 clone:2128 gen:124 core:0x22 unit:0x000000bd42aa6f325ed18ce24500142a
02:46:47:WU00:FS00:0x22:Completed 1000000 out of 1000000 steps (100%)
02:46:47:WU00:FS00:0x22:Average performance: 122.902 ns/day
02:46:50:WU00:FS00:0x22:Saving result file ..\logfile_01.txt
02:46:50:WU00:FS00:0x22:Saving result file checkpointState.xml
02:46:51:WU00:FS00:0x22:Saving result file globals.csv
02:46:51:WU00:FS00:0x22:Saving result file positions.xtc
02:46:51:WU00:FS00:0x22:Saving result file science.log
02:46:51:WU00:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
02:46:51:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:46:51:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13414 run:3852 clone:23 gen:1 core:0x22 unit:0x0000000312bc7d9a5ef50d5cdacf91b3
02:46:51:WU00:FS00:Uploading 7.43MiB to 18.188.125.154
02:46:51:WU00:FS00:Connecting to 18.188.125.154:8080
02:46:51:WU01:FS00:Starting
02:46:51:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Pitter\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 17972 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
02:46:51:WU01:FS00:Started FahCore on PID 13872
02:46:51:WU01:FS00:Core PID:1512
02:46:51:WU01:FS00:FahCore 0x22 started
02:46:52:WU01:FS00:0x22:*********************** Log Started 2020-06-27T02:46:51Z ***********************
02:46:52:WU01:FS00:0x22:*************************** Core22 Folding@home Core ***************************
02:46:52:WU01:FS00:0x22:       Core: Core22
02:46:52:WU01:FS00:0x22:       Type: 0x22
02:46:52:WU01:FS00:0x22:    Version: 0.0.10
02:46:52:WU01:FS00:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:46:52:WU01:FS00:0x22:  Copyright: 2020 foldingathome.org
02:46:52:WU01:FS00:0x22:   Homepage: https://foldingathome.org/
02:46:52:WU01:FS00:0x22:       Date: Jun 16 2020
02:46:52:WU01:FS00:0x22:       Time: 14:33:22
02:46:52:WU01:FS00:0x22:   Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
02:46:52:WU01:FS00:0x22:     Branch: core22-0.0.10
02:46:52:WU01:FS00:0x22:   Compiler: Visual C++ 2015
02:46:52:WU01:FS00:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
02:46:52:WU01:FS00:0x22:   Platform: win32 10
02:46:52:WU01:FS00:0x22:       Bits: 64
02:46:52:WU01:FS00:0x22:       Mode: Release
02:46:52:WU01:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
02:46:52:WU01:FS00:0x22:             <peastman@stanford.edu>
02:46:52:WU01:FS00:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 13872 -checkpoint 15
02:46:52:WU01:FS00:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
02:46:52:WU01:FS00:0x22:             0 -gpu 0
02:46:52:WU01:FS00:0x22:************************************ libFAH ************************************
02:46:52:WU01:FS00:0x22:       Date: Jun 15 2020
02:46:52:WU01:FS00:0x22:       Time: 18:05:04
02:46:52:WU01:FS00:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
02:46:52:WU01:FS00:0x22:     Branch: HEAD
02:46:52:WU01:FS00:0x22:************************************ CBang *************************************
02:46:52:WU01:FS00:0x22:       Time: 14:31:33
02:46:52:WU01:FS00:0x22:   Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
02:46:52:WU01:FS00:0x22:************************************ System ************************************
02:46:52:WU01:FS00:0x22:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
02:46:52:WU01:FS00:0x22:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
02:46:52:WU01:FS00:0x22:       CPUs: 16
02:46:52:WU01:FS00:0x22:     Memory: 15.93GiB
02:46:52:WU01:FS00:0x22:Free Memory: 10.88GiB
02:46:52:WU01:FS00:0x22:    Threads: WINDOWS_THREADS
02:46:52:WU01:FS00:0x22: OS Version: 6.2
02:46:52:WU01:FS00:0x22:Has Battery: false
02:46:52:WU01:FS00:0x22: On Battery: false
02:46:52:WU01:FS00:0x22: UTC Offset: -4
02:46:52:WU01:FS00:0x22:        PID: 1512
02:46:52:WU01:FS00:0x22:        CWD: C:\Users\Pitter\AppData\Roaming\FAHClient\work
02:46:52:WU01:FS00:0x22:********************************************************************************
02:46:52:WU01:FS00:0x22:Project: 16448 (Run 0, Clone 2128, Gen 124)
02:46:52:WU01:FS00:0x22:Unit: 0x000000bd42aa6f325ed18ce24500142a
02:46:52:WU01:FS00:0x22:Reading tar file core.xml
02:46:52:WU01:FS00:0x22:Reading tar file integrator.xml
02:46:52:WU01:FS00:0x22:Reading tar file state.xml
02:46:52:WU01:FS00:0x22:Reading tar file system.xml
02:46:53:WU01:FS00:0x22:Digital signatures verified
02:46:53:WU01:FS00:0x22:Folding@home GPU Core22 Folding@home Core
02:46:53:WU01:FS00:0x22:Version 0.0.10
02:46:53:WU01:FS00:0x22:  Checkpoint write interval: 30000 steps (5%) [20 total]
02:46:53:WU01:FS00:0x22:  JSON viewer frame write interval: 6000 steps (1%) [100 total]
02:46:53:WU01:FS00:0x22:  XTC frame write interval: 20000 steps (3.3%) [30 total]
02:46:53:WU01:FS00:0x22:  Global context and integrator variables write interval: disabled
02:46:56:WU00:FS00:Upload complete
02:46:56:WU00:FS00:Server responded WORK_ACK (400)
02:46:56:WU00:FS00:Final credit estimate, 150902.00 points
02:46:56:WU00:FS00:Cleaning up
02:47:14:WU01:FS00:0x22:Completed 0 out of 600000 steps (0%)
02:48:38:WU01:FS00:0x22:Completed 6000 out of 600000 steps (1%)
05:02:41:WU01:FS00:0x22:Completed 594000 out of 600000 steps (99%)
05:02:41:WU00:FS00:Connecting to 65.254.110.245:80
05:02:41:WU00:FS00:Assigned to work server 18.188.125.154
05:02:41:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 18.188.125.154
05:02:41:WU00:FS00:Connecting to 18.188.125.154:8080
05:02:43:WU00:FS00:Downloading 9.58MiB
05:02:44:WU00:FS00:Download complete
05:02:44:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13414 run:3149 clone:30 gen:1 core:0x22 unit:0x0000000112bc7d9a5ef50d7c1b0de48c
05:04:02:WU01:FS00:0x22:Completed 600000 out of 600000 steps (100%)
05:04:02:WU01:FS00:0x22:Average performance: 8.44988 ns/day
05:04:08:WU01:FS00:0x22:Saving result file ..\logfile_01.txt
05:04:08:WU01:FS00:0x22:Saving result file checkpointState.xml
05:04:11:WU01:FS00:0x22:Saving result file positions.xtc
05:04:12:WU01:FS00:0x22:Saving result file science.log
05:04:12:WU01:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
05:04:13:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:04:13:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:16448 run:0 clone:2128 gen:124 core:0x22 unit:0x000000bd42aa6f325ed18ce24500142a
05:04:13:WU01:FS00:Uploading 42.37MiB to 66.170.111.50
05:04:13:WU01:FS00:Connecting to 66.170.111.50:8080
05:04:13:WU00:FS00:Starting
05:04:13:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Pitter\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 17972 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
05:04:13:WU00:FS00:Started FahCore on PID 4644
05:04:13:WU00:FS00:Core PID:9592
05:04:13:WU00:FS00:FahCore 0x22 started
05:04:13:WU00:FS00:0x22:*********************** Log Started 2020-06-27T05:04:13Z ***********************
05:04:13:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
05:04:13:WU00:FS00:0x22:       Core: Core22
05:04:13:WU00:FS00:0x22:       Type: 0x22
05:04:13:WU00:FS00:0x22:    Version: 0.0.10
05:04:13:WU00:FS00:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:04:13:WU00:FS00:0x22:  Copyright: 2020 foldingathome.org
05:04:13:WU00:FS00:0x22:   Homepage: https://foldingathome.org/
05:04:13:WU00:FS00:0x22:       Date: Jun 16 2020
05:04:13:WU00:FS00:0x22:       Time: 14:33:22
05:04:13:WU00:FS00:0x22:   Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
05:04:13:WU00:FS00:0x22:     Branch: core22-0.0.10
05:04:13:WU00:FS00:0x22:   Compiler: Visual C++ 2015
05:04:13:WU00:FS00:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
05:04:13:WU00:FS00:0x22:   Platform: win32 10
05:04:13:WU00:FS00:0x22:       Bits: 64
05:04:13:WU00:FS00:0x22:       Mode: Release
05:04:13:WU00:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
05:04:13:WU00:FS00:0x22:             <peastman@stanford.edu>
05:04:13:WU00:FS00:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 4644 -checkpoint 15
05:04:13:WU00:FS00:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
05:04:13:WU00:FS00:0x22:             0 -gpu 0
05:04:13:WU00:FS00:0x22:************************************ libFAH ************************************
05:04:13:WU00:FS00:0x22:       Date: Jun 15 2020
05:04:13:WU00:FS00:0x22:       Time: 18:05:04
05:04:13:WU00:FS00:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
05:04:13:WU00:FS00:0x22:     Branch: HEAD
05:04:13:WU00:FS00:0x22:************************************ CBang *************************************
05:04:13:WU00:FS00:0x22:       Time: 14:31:33
05:04:13:WU00:FS00:0x22:   Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
05:04:13:WU00:FS00:0x22:************************************ System ************************************
05:04:13:WU00:FS00:0x22:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
05:04:13:WU00:FS00:0x22:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
05:04:13:WU00:FS00:0x22:       CPUs: 16
05:04:13:WU00:FS00:0x22:     Memory: 15.93GiB
05:04:13:WU00:FS00:0x22:Free Memory: 10.62GiB
05:04:13:WU00:FS00:0x22:    Threads: WINDOWS_THREADS
05:04:13:WU00:FS00:0x22: OS Version: 6.2
05:04:13:WU00:FS00:0x22:Has Battery: false
05:04:13:WU00:FS00:0x22: On Battery: false
05:04:13:WU00:FS00:0x22: UTC Offset: -4
05:04:13:WU00:FS00:0x22:        PID: 9592
05:04:13:WU00:FS00:0x22:        CWD: C:\Users\Pitter\AppData\Roaming\FAHClient\work
05:04:13:WU00:FS00:0x22:********************************************************************************
05:04:13:WU00:FS00:0x22:Project: 13414 (Run 3149, Clone 30, Gen 1)
05:04:13:WU00:FS00:0x22:Unit: 0x0000000112bc7d9a5ef50d7c1b0de48c
05:04:13:WU00:FS00:0x22:Reading tar file core.xml
05:04:13:WU00:FS00:0x22:Reading tar file integrator.xml
05:04:13:WU00:FS00:0x22:Reading tar file state.xml
05:04:13:WU00:FS00:0x22:Reading tar file system.xml
05:04:14:WU00:FS00:0x22:Digital signatures verified
05:04:14:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
05:04:14:WU00:FS00:0x22:Version 0.0.10
05:04:14:WU00:FS00:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
05:04:14:WU00:FS00:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
05:04:14:WU00:FS00:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
05:04:14:WU00:FS00:0x22:  Global context and integrator variables write interval: 250 steps (0.025%) [4000 total]
05:04:19:WU01:FS00:Upload 3.10%
05:04:25:WU01:FS00:Upload 10.33%
05:04:29:WU00:FS00:0x22:Completed 0 out of 1000000 steps (0%)
05:04:31:WU01:FS00:Upload 18.14%
05:04:37:WU01:FS00:Upload 25.96%
05:04:43:WU01:FS00:Upload 33.63%
05:04:49:WU01:FS00:Upload 41.45%
05:04:55:WU01:FS00:Upload 49.12%
05:05:01:WU01:FS00:Upload 56.94%
05:05:07:WU01:FS00:Upload 64.32%
05:05:13:WU01:FS00:Upload 71.99%
05:05:19:WU01:FS00:Upload 79.66%
05:05:25:WU01:FS00:Upload 87.48%
05:05:31:WU01:FS00:Upload 95.15%
05:05:35:WU01:FS00:Upload complete
05:05:35:WU01:FS00:Server responded WORK_ACK (400)
05:05:35:WU01:FS00:Final credit estimate, 80432.00 points
05:05:35:WU01:FS00:Cleaning up
05:06:48:WU00:FS00:0x22:Completed 10000 out of 1000000 steps (1%)
05:09:06:WU00:FS00:0x22:Completed 20000 out of 1000000 steps (2%)
05:11:25:WU00:FS00:0x22:Completed 30000 out of 1000000 steps (3%)
05:13:43:WU00:FS00:0x22:Completed 40000 out of 1000000 steps (4%)
05:16:02:WU00:FS00:0x22:Completed 50000 out of 1000000 steps (5%)
17:20:55:WU01:FS00:0x22:Completed 290000 out of 1000000 steps (29%)
17:23:16:WU01:FS00:0x22:Completed 300000 out of 1000000 steps (30%)
17:25:38:WU01:FS00:0x22:Completed 310000 out of 1000000 steps (31%)
17:27:59:WU01:FS00:0x22:Completed 320000 out of 1000000 steps (32%)
17:30:20:WU01:FS00:0x22:Completed 330000 out of 1000000 steps (33%)
17:32:41:WU01:FS00:0x22:Completed 340000 out of 1000000 steps (34%)
17:35:02:WU01:FS00:0x22:Completed 350000 out of 1000000 steps (35%)
17:37:24:WU01:FS00:0x22:Completed 360000 out of 1000000 steps (36%)
17:39:45:WU01:FS00:0x22:Completed 370000 out of 1000000 steps (37%)
17:42:06:WU01:FS00:0x22:Completed 380000 out of 1000000 steps (38%)
17:44:26:WU01:FS00:0x22:Completed 390000 out of 1000000 steps (39%)
17:46:47:WU01:FS00:0x22:Completed 400000 out of 1000000 steps (40%)
17:49:09:WU01:FS00:0x22:Completed 410000 out of 1000000 steps (41%)
17:51:30:WU01:FS00:0x22:Completed 420000 out of 1000000 steps (42%)
17:53:51:WU01:FS00:0x22:Completed 430000 out of 1000000 steps (43%)
17:56:12:WU01:FS00:0x22:Completed 440000 out of 1000000 steps (44%)
17:58:33:WU01:FS00:0x22:Completed 450000 out of 1000000 steps (45%)
18:00:55:WU01:FS00:0x22:Completed 460000 out of 1000000 steps (46%)
18:03:16:WU01:FS00:0x22:Completed 470000 out of 1000000 steps (47%)
18:05:37:WU01:FS00:0x22:Completed 480000 out of 1000000 steps (48%)
18:07:57:WU01:FS00:0x22:Completed 490000 out of 1000000 steps (49%)
18:10:20:WU01:FS00:0x22:Completed 500000 out of 1000000 steps (50%)
18:12:40:WU01:FS00:0x22:Completed 510000 out of 1000000 steps (51%)
18:14:59:WU01:FS00:0x22:Completed 520000 out of 1000000 steps (52%)
18:17:18:WU01:FS00:0x22:Completed 530000 out of 1000000 steps (53%)
18:19:37:WU01:FS00:0x22:Completed 540000 out of 1000000 steps (54%)
18:21:55:WU01:FS00:0x22:Completed 550000 out of 1000000 steps (55%)
18:24:15:WU01:FS00:0x22:Completed 560000 out of 1000000 steps (56%)
18:26:34:WU01:FS00:0x22:Completed 570000 out of 1000000 steps (57%)
18:28:52:WU01:FS00:0x22:Completed 580000 out of 1000000 steps (58%)
18:31:11:WU01:FS00:0x22:Completed 590000 out of 1000000 steps (59%)
18:33:29:WU01:FS00:0x22:Completed 600000 out of 1000000 steps (60%)
18:35:48:WU01:FS00:0x22:Completed 610000 out of 1000000 steps (61%)
18:38:06:WU01:FS00:0x22:Completed 620000 out of 1000000 steps (62%)
18:40:24:WU01:FS00:0x22:Completed 630000 out of 1000000 steps (63%)
18:42:42:WU01:FS00:0x22:Completed 640000 out of 1000000 steps (64%)
18:45:00:WU01:FS00:0x22:Completed 650000 out of 1000000 steps (65%)
18:47:19:WU01:FS00:0x22:Completed 660000 out of 1000000 steps (66%)
18:49:37:WU01:FS00:0x22:Completed 670000 out of 1000000 steps (67%)
18:51:55:WU01:FS00:0x22:Completed 680000 out of 1000000 steps (68%)
18:54:13:WU01:FS00:0x22:Completed 690000 out of 1000000 steps (69%)
18:56:31:WU01:FS00:0x22:Completed 700000 out of 1000000 steps (70%)
18:58:50:WU01:FS00:0x22:Completed 710000 out of 1000000 steps (71%)
19:01:09:WU01:FS00:0x22:Completed 720000 out of 1000000 steps (72%)
19:03:27:WU01:FS00:0x22:Completed 730000 out of 1000000 steps (73%)
19:05:45:WU01:FS00:0x22:Completed 740000 out of 1000000 steps (74%)
19:08:03:WU01:FS00:0x22:Completed 750000 out of 1000000 steps (75%)
19:10:26:WU01:FS00:0x22:Completed 760000 out of 1000000 steps (76%)
19:12:48:WU01:FS00:0x22:Completed 770000 out of 1000000 steps (77%)
19:15:10:WU01:FS00:0x22:Completed 780000 out of 1000000 steps (78%)
19:17:32:WU01:FS00:0x22:Completed 790000 out of 1000000 steps (79%)
19:19:55:WU01:FS00:0x22:Completed 800000 out of 1000000 steps (80%)
19:22:18:WU01:FS00:0x22:Completed 810000 out of 1000000 steps (81%)
19:24:40:WU01:FS00:0x22:Completed 820000 out of 1000000 steps (82%)
19:27:02:WU01:FS00:0x22:Completed 830000 out of 1000000 steps (83%)
19:29:23:WU01:FS00:0x22:Completed 840000 out of 1000000 steps (84%)
19:31:45:WU01:FS00:0x22:Completed 850000 out of 1000000 steps (85%)
19:34:08:WU01:FS00:0x22:Completed 860000 out of 1000000 steps (86%)
19:36:30:WU01:FS00:0x22:Completed 870000 out of 1000000 steps (87%)
19:38:53:WU01:FS00:0x22:Completed 880000 out of 1000000 steps (88%)
19:41:14:WU01:FS00:0x22:Completed 890000 out of 1000000 steps (89%)
19:43:36:WU01:FS00:0x22:Completed 900000 out of 1000000 steps (90%)
19:45:59:WU01:FS00:0x22:Completed 910000 out of 1000000 steps (91%)
19:48:21:WU01:FS00:0x22:Completed 920000 out of 1000000 steps (92%)
19:50:43:WU01:FS00:0x22:Completed 930000 out of 1000000 steps (93%)
19:53:05:WU01:FS00:0x22:Completed 940000 out of 1000000 steps (94%)
19:55:26:WU01:FS00:0x22:Completed 950000 out of 1000000 steps (95%)
19:57:49:WU01:FS00:0x22:Completed 960000 out of 1000000 steps (96%)
20:00:11:WU01:FS00:0x22:Completed 970000 out of 1000000 steps (97%)
20:02:32:WU01:FS00:0x22:Completed 980000 out of 1000000 steps (98%)
20:04:54:WU01:FS00:0x22:Completed 990000 out of 1000000 steps (99%)
20:04:55:WU00:FS00:Connecting to 65.254.110.245:80
20:04:55:WU00:FS00:Assigned to work server 18.188.125.154
20:04:55:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 18.188.125.154
20:04:55:WU00:FS00:Connecting to 18.188.125.154:8080
20:04:58:WU00:FS00:Downloading 9.39MiB
20:04:58:WU00:FS00:Download complete
20:04:58:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13414 run:3995 clone:48 gen:0 core:0x22 unit:0x0000000112bc7d9a5ef50d55a7b3222e
20:07:16:WU01:FS00:0x22:Completed 1000000 out of 1000000 steps (100%)
20:07:16:WU01:FS00:0x22:Average performance: 121.862 ns/day
20:07:19:WU01:FS00:0x22:Saving result file ..\logfile_01.txt
20:07:19:WU01:FS00:0x22:Saving result file checkpointState.xml
20:07:20:WU01:FS00:0x22:Saving result file globals.csv
20:07:20:WU01:FS00:0x22:Saving result file positions.xtc
20:07:20:WU01:FS00:0x22:Saving result file science.log
20:07:20:WU01:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
20:07:20:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:07:20:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13414 run:1889 clone:45 gen:0 core:0x22 unit:0x0000000112bc7d9a5ef1aef66e77b7d3
20:07:20:WU01:FS00:Uploading 7.45MiB to 18.188.125.154
20:07:20:WU01:FS00:Connecting to 18.188.125.154:8080
20:07:20:WU00:FS00:Starting
20:07:20:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Pitter\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 17972 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:07:20:WU00:FS00:Started FahCore on PID 10120
20:07:20:WU00:FS00:Core PID:13412
20:07:20:WU00:FS00:FahCore 0x22 started
20:07:21:WU00:FS00:0x22:*********************** Log Started 2020-06-27T20:07:20Z ***********************
20:07:21:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
20:07:21:WU00:FS00:0x22:       Core: Core22
20:07:21:WU00:FS00:0x22:       Type: 0x22
20:07:21:WU00:FS00:0x22:    Version: 0.0.10
20:07:21:WU00:FS00:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:07:21:WU00:FS00:0x22:  Copyright: 2020 foldingathome.org
20:07:21:WU00:FS00:0x22:   Homepage: https://foldingathome.org/
20:07:21:WU00:FS00:0x22:       Date: Jun 16 2020
20:07:21:WU00:FS00:0x22:       Time: 14:33:22
20:07:21:WU00:FS00:0x22:   Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
20:07:21:WU00:FS00:0x22:     Branch: core22-0.0.10
20:07:21:WU00:FS00:0x22:   Compiler: Visual C++ 2015
20:07:21:WU00:FS00:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
20:07:21:WU00:FS00:0x22:   Platform: win32 10
20:07:21:WU00:FS00:0x22:       Bits: 64
20:07:21:WU00:FS00:0x22:       Mode: Release
20:07:21:WU00:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
20:07:21:WU00:FS00:0x22:             <peastman@stanford.edu>
20:07:21:WU00:FS00:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10120 -checkpoint 15
20:07:21:WU00:FS00:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
20:07:21:WU00:FS00:0x22:             0 -gpu 0
20:07:21:WU00:FS00:0x22:************************************ libFAH ************************************
20:07:21:WU00:FS00:0x22:       Date: Jun 15 2020
20:07:21:WU00:FS00:0x22:       Time: 18:05:04
20:07:21:WU00:FS00:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
20:07:21:WU00:FS00:0x22:     Branch: HEAD
20:07:21:WU00:FS00:0x22:************************************ CBang *************************************
20:07:21:WU00:FS00:0x22:       Time: 14:31:33
20:07:21:WU00:FS00:0x22:   Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
20:07:21:WU00:FS00:0x22:************************************ System ************************************
20:07:21:WU00:FS00:0x22:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
20:07:21:WU00:FS00:0x22:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
20:07:21:WU00:FS00:0x22:       CPUs: 16
20:07:21:WU00:FS00:0x22:     Memory: 15.93GiB
20:07:21:WU00:FS00:0x22:Free Memory: 10.38GiB
20:07:21:WU00:FS00:0x22:    Threads: WINDOWS_THREADS
20:07:21:WU00:FS00:0x22: OS Version: 6.2
20:07:21:WU00:FS00:0x22:Has Battery: false
20:07:21:WU00:FS00:0x22: On Battery: false
20:07:21:WU00:FS00:0x22: UTC Offset: -4
20:07:21:WU00:FS00:0x22:        PID: 13412
20:07:21:WU00:FS00:0x22:        CWD: C:\Users\Pitter\AppData\Roaming\FAHClient\work
20:07:21:WU00:FS00:0x22:********************************************************************************
20:07:21:WU00:FS00:0x22:Project: 13414 (Run 3995, Clone 48, Gen 0)
20:07:21:WU00:FS00:0x22:Unit: 0x0000000112bc7d9a5ef50d55a7b3222e
20:07:21:WU00:FS00:0x22:Reading tar file core.xml
20:07:21:WU00:FS00:0x22:Reading tar file integrator.xml
20:07:21:WU00:FS00:0x22:Reading tar file state.xml
20:07:21:WU00:FS00:0x22:Reading tar file system.xml
20:07:21:WU00:FS00:0x22:Digital signatures verified
20:07:21:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
20:07:21:WU00:FS00:0x22:Version 0.0.10
20:07:21:WU00:FS00:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
20:07:21:WU00:FS00:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
20:07:21:WU00:FS00:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
20:07:21:WU00:FS00:0x22:  Global context and integrator variables write interval: 250 steps (0.025%) [4000 total]
20:07:26:WU01:FS00:Upload complete
20:07:26:WU01:FS00:Server responded WORK_ACK (400)
20:07:26:WU01:FS00:Final credit estimate, 161185.00 points
20:07:26:WU01:FS00:Cleaning up
20:07:36:WU00:FS00:0x22:Completed 0 out of 1000000 steps (0%)
20:09:54:WU00:FS00:0x22:Completed 10000 out of 1000000 steps (1%)
20:12:12:WU00:FS00:0x22:Completed 20000 out of 1000000 steps (2%)
20:14:29:WU00:FS00:0x22:Completed 30000 out of 1000000 steps (3%)
20:16:47:WU00:FS00:0x22:Completed 40000 out of 1000000 steps (4%)
20:19:05:WU00:FS00:0x22:Completed 50000 out of 1000000 steps (5%)
20:21:23:WU00:FS00:0x22:Completed 60000 out of 1000000 steps (6%)
20:23:41:WU00:FS00:0x22:Completed 70000 out of 1000000 steps (7%)
20:25:59:WU00:FS00:0x22:Completed 80000 out of 1000000 steps (8%)
20:28:16:WU00:FS00:0x22:Completed 90000 out of 1000000 steps (9%)
20:30:34:WU00:FS00:0x22:Completed 100000 out of 1000000 steps (10%)
20:32:52:WU00:FS00:0x22:Completed 110000 out of 1000000 steps (11%)
20:35:10:WU00:FS00:0x22:Completed 120000 out of 1000000 steps (12%)
20:37:28:WU00:FS00:0x22:Completed 130000 out of 1000000 steps (13%)
20:39:45:WU00:FS00:0x22:Completed 140000 out of 1000000 steps (14%)
20:42:03:WU00:FS00:0x22:Completed 150000 out of 1000000 steps (15%)
20:44:22:WU00:FS00:0x22:Completed 160000 out of 1000000 steps (16%)
20:46:39:WU00:FS00:0x22:Completed 170000 out of 1000000 steps (17%)
20:48:57:WU00:FS00:0x22:Completed 180000 out of 1000000 steps (18%)
20:51:15:WU00:FS00:0x22:Completed 190000 out of 1000000 steps (19%)
20:53:33:WU00:FS00:0x22:Completed 200000 out of 1000000 steps (20%)
20:55:51:WU00:FS00:0x22:Completed 210000 out of 1000000 steps (21%)
20:58:09:WU00:FS00:0x22:Completed 220000 out of 1000000 steps (22%)
21:00:26:WU00:FS00:0x22:Completed 230000 out of 1000000 steps (23%)
21:02:44:WU00:FS00:0x22:Completed 240000 out of 1000000 steps (24%)
21:05:02:WU00:FS00:0x22:Completed 250000 out of 1000000 steps (25%)
21:07:24:WU00:FS00:0x22:Completed 260000 out of 1000000 steps (26%)
21:09:46:WU00:FS00:0x22:Completed 270000 out of 1000000 steps (27%)
21:12:08:WU00:FS00:0x22:Completed 280000 out of 1000000 steps (28%)
21:14:29:WU00:FS00:0x22:Completed 290000 out of 1000000 steps (29%)
21:16:51:WU00:FS00:0x22:Completed 300000 out of 1000000 steps (30%)
21:19:13:WU00:FS00:0x22:Completed 310000 out of 1000000 steps (31%)
21:21:35:WU00:FS00:0x22:Completed 320000 out of 1000000 steps (32%)
21:23:56:WU00:FS00:0x22:Completed 330000 out of 1000000 steps (33%)
21:26:17:WU00:FS00:0x22:Completed 340000 out of 1000000 steps (34%)
21:28:39:WU00:FS00:0x22:Completed 350000 out of 1000000 steps (35%)
21:31:01:WU00:FS00:0x22:Completed 360000 out of 1000000 steps (36%)
21:33:22:WU00:FS00:0x22:Completed 370000 out of 1000000 steps (37%)
21:35:44:WU00:FS00:0x22:Completed 380000 out of 1000000 steps (38%)
21:38:05:WU00:FS00:0x22:Completed 390000 out of 1000000 steps (39%)
21:40:27:WU00:FS00:0x22:Completed 400000 out of 1000000 steps (40%)
21:42:49:WU00:FS00:0x22:Completed 410000 out of 1000000 steps (41%)
21:45:10:WU00:FS00:0x22:Completed 420000 out of 1000000 steps (42%)
21:47:32:WU00:FS00:0x22:Completed 430000 out of 1000000 steps (43%)
21:49:53:WU00:FS00:0x22:Completed 440000 out of 1000000 steps (44%)
21:52:15:WU00:FS00:0x22:Completed 450000 out of 1000000 steps (45%)
21:54:36:WU00:FS00:0x22:Completed 460000 out of 1000000 steps (46%)
21:56:58:WU00:FS00:0x22:Completed 470000 out of 1000000 steps (47%)
21:59:20:WU00:FS00:0x22:Completed 480000 out of 1000000 steps (48%)
22:01:41:WU00:FS00:0x22:Completed 490000 out of 1000000 steps (49%)
22:04:02:WU00:FS00:0x22:Completed 500000 out of 1000000 steps (50%)
22:06:21:WU00:FS00:0x22:Completed 510000 out of 1000000 steps (51%)
22:08:38:WU00:FS00:0x22:Completed 520000 out of 1000000 steps (52%)
22:10:56:WU00:FS00:0x22:Completed 530000 out of 1000000 steps (53%)
22:13:13:WU00:FS00:0x22:Completed 540000 out of 1000000 steps (54%)
22:15:31:WU00:FS00:0x22:Completed 550000 out of 1000000 steps (55%)
22:17:50:WU00:FS00:0x22:Completed 560000 out of 1000000 steps (56%)
22:20:07:WU00:FS00:0x22:Completed 570000 out of 1000000 steps (57%)
22:22:25:WU00:FS00:0x22:Completed 580000 out of 1000000 steps (58%)
22:24:42:WU00:FS00:0x22:Completed 590000 out of 1000000 steps (59%)
22:27:00:WU00:FS00:0x22:Completed 600000 out of 1000000 steps (60%)
22:29:18:WU00:FS00:0x22:Completed 610000 out of 1000000 steps (61%)
22:31:36:WU00:FS00:0x22:Completed 620000 out of 1000000 steps (62%)
22:33:54:WU00:FS00:0x22:Completed 630000 out of 1000000 steps (63%)
22:36:11:WU00:FS00:0x22:Completed 640000 out of 1000000 steps (64%)
22:38:29:WU00:FS00:0x22:Completed 650000 out of 1000000 steps (65%)
22:40:47:WU00:FS00:0x22:Completed 660000 out of 1000000 steps (66%)
22:43:05:WU00:FS00:0x22:Completed 670000 out of 1000000 steps (67%)
22:45:22:WU00:FS00:0x22:Completed 680000 out of 1000000 steps (68%)
22:47:40:WU00:FS00:0x22:Completed 690000 out of 1000000 steps (69%)
22:49:58:WU00:FS00:0x22:Completed 700000 out of 1000000 steps (70%)
22:52:16:WU00:FS00:0x22:Completed 710000 out of 1000000 steps (71%)
22:54:34:WU00:FS00:0x22:Completed 720000 out of 1000000 steps (72%)
22:56:51:WU00:FS00:0x22:Completed 730000 out of 1000000 steps (73%)
22:59:09:WU00:FS00:0x22:Completed 740000 out of 1000000 steps (74%)
23:01:27:WU00:FS00:0x22:Completed 750000 out of 1000000 steps (75%)
23:03:49:WU00:FS00:0x22:Completed 760000 out of 1000000 steps (76%)
23:06:10:WU00:FS00:0x22:Completed 770000 out of 1000000 steps (77%)
23:08:32:WU00:FS00:0x22:Completed 780000 out of 1000000 steps (78%)
23:10:53:WU00:FS00:0x22:Completed 790000 out of 1000000 steps (79%)
23:13:15:WU00:FS00:0x22:Completed 800000 out of 1000000 steps (80%)
23:15:37:WU00:FS00:0x22:Completed 810000 out of 1000000 steps (81%)
23:17:59:WU00:FS00:0x22:Completed 820000 out of 1000000 steps (82%)
23:20:21:WU00:FS00:0x22:Completed 830000 out of 1000000 steps (83%)
23:22:43:WU00:FS00:0x22:Completed 840000 out of 1000000 steps (84%)
23:25:04:WU00:FS00:0x22:Completed 850000 out of 1000000 steps (85%)
23:27:27:WU00:FS00:0x22:Completed 860000 out of 1000000 steps (86%)
23:29:49:WU00:FS00:0x22:Completed 870000 out of 1000000 steps (87%)
23:32:11:WU00:FS00:0x22:Completed 880000 out of 1000000 steps (88%)
23:34:33:WU00:FS00:0x22:Completed 890000 out of 1000000 steps (89%)
23:36:55:WU00:FS00:0x22:Completed 900000 out of 1000000 steps (90%)
23:39:17:WU00:FS00:0x22:Completed 910000 out of 1000000 steps (91%)
23:41:39:WU00:FS00:0x22:Completed 920000 out of 1000000 steps (92%)
23:44:01:WU00:FS00:0x22:Completed 930000 out of 1000000 steps (93%)
23:46:23:WU00:FS00:0x22:Completed 940000 out of 1000000 steps (94%)
23:48:45:WU00:FS00:0x22:Completed 950000 out of 1000000 steps (95%)
23:51:07:WU00:FS00:0x22:Completed 960000 out of 1000000 steps (96%)
23:53:29:WU00:FS00:0x22:Completed 970000 out of 1000000 steps (97%)
23:55:50:WU00:FS00:0x22:Completed 980000 out of 1000000 steps (98%)
23:58:12:WU00:FS00:0x22:Completed 990000 out of 1000000 steps (99%)
00:00:34:WU00:FS00:0x22:Completed 1000000 out of 1000000 steps (100%)
00:00:34:WU00:FS00:0x22:Average performance: 121.862 ns/day
00:00:36:WU00:FS00:0x22:Saving result file ..\logfile_01.txt
00:00:36:WU00:FS00:0x22:Saving result file checkpointState.xml
00:00:37:WU00:FS00:0x22:Saving result file globals.csv
00:00:37:WU00:FS00:0x22:Saving result file positions.xtc
00:00:37:WU00:FS00:0x22:Saving result file science.log
00:00:37:WU00:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
00:00:38:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:00:38:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13414 run:3995 clone:48 gen:0 core:0x22 unit:0x0000000112bc7d9a5ef50d55a7b3222e
00:00:38:WU00:FS00:Uploading 7.44MiB to 18.188.125.154
00:00:38:WU00:FS00:Connecting to 18.188.125.154:8080
00:00:59:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
00:00:59:WU00:FS00:Connecting to 18.188.125.154:80
00:01:20:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 18.188.125.154:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:01:20:WU00:FS00:Trying to send results to collection server
00:01:20:WU00:FS00:Uploading 7.44MiB to 3.21.157.11
00:01:20:WU00:FS00:Connecting to 3.21.157.11:8080
00:01:24:WU00:FS00:Upload complete
00:01:24:WU00:FS00:Server responded WORK_QUIT (404)
00:01:24:WARNING:WU00:FS00:Server did not like results, dumping
00:01:24:WU00:FS00:Cleaning up
The Collection Server that the WU was uploaded to when the client could not upload to the WS has been having problems as it has filled up. They are aware of the issue and working on clearing space.
