Points on Web Control, but no donor stats
RaindropsKeepFalling
I've been running this since last Monday, and on my Web Control it says I've 992 "Estimated Points". But on the donors page I get "No Results" when I search on my name. Have I not yet completed a work unit, hence I simply have to wait for a few more days? My Folding@Home username is RaindropsKeepFalling, the same as my name on this forum.
Actually, I'm not really interested in getting points: I'm just hoping that the work being done on my machine does actually get uploaded and used. I had a bad experience once before on a distributed computing project where my work units weren't getting uploaded and after a long time I enquired. I was told there was a bug in the automated upload process, and I got pointed to instructions on how to upload manually, but after a lot of struggling I couldn't get the manual upload process to work either so I simply gave up and uninstalled it.
Re: Points on Web Control, but no donor stats
Welcome to the Folding@home community-driven support forum.
You won't be listed until you complete, return a work unit and it gets updated into the DB which can take an hour or two.
Haven't noticed any uploading problems recently but if you do have any problem don't hesitate to post ... it's a good idea to include the first 100 lines (use Code tags) of your log.txt file ... it saves a lot of back & forth.
In addition to bollix47's true and excellent post, the Biochemist's in charge of all this do not need the stats, so the stats server is the oldest, crankiest, server they have. Stats are frequently broken or late, again because there is no downside to the folks paying for the stats.
I would suspect it will be a month before you show up in the stats, and if it takes 5 days to get 1000 points you may never show up on the stats.
Most of my Work Units on my slowest PC still have 2 day timeout and a 4 day expiration, so your current rig may never complete a Work Unit. (If you want to post the first 200 lines of your log, we can try to speed up your folding) viewtopic.php?f=24&t=26036
Thanks both.
Yes, not really bothered if I don't appear in the stats, just want to advance the project (I chose the COVID-19 one because I'm in an at-risk group myself, plus I've friends/relatives who are especially vulnerable).JimboPalmer wrote:I would suspect it will be a month before you show up in the stats, and if it takes 5 days to get 1000 points you may never show up on the stats.
Yes, I've come to realise I've a very slow machine compared to others. Here are the first 200 lines of my log as suggested:JimboPalmer wrote:Most of my Work Units on my slowest PC still have 2 day timeout and a 4 day expiration, so your current rig may never complete a Work Unit. (If you want to post the first 200 lines of your log, we can try to speed up your folding) viewtopic.php?f=24&t=26036
*********************** Log Started 2020-06-26T07:11:29Z ***********************
07:11:29:Trying to access database...
07:11:31:Successfully acquired database lock
07:11:32:Read GPUs.txt
07:11:40:Enabled folding slot 00: READY cpu:1
07:12:46:Enabled folding slot 01: PAUSED gpu:0:Mullins [Radeon APU A4-6000 R2] (waiting for idle)
07:12:46:****************************** FAHClient ******************************
07:12:46: Version: 7.6.13
07:12:46: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:12:46: Copyright: 2020 foldingathome.org
07:12:46: Homepage: https://foldingathome.org/
07:12:46: Date: Apr 27 2020
07:12:46: Time: 21:21:01
07:12:46: Revision: 5a652817f46116b6e135503af97f18e094414e3b
07:12:46: Branch: master
07:12:46: Compiler: Visual C++ 2008
07:12:46: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:12:46: Platform: win32 10
07:12:46: Bits: 32
07:12:46: Mode: Release
07:12:46: Config: C:\Users\[REDACTED]\AppData\Roaming\FAHClient\config.xml
07:12:46:******************************** CBang ********************************
07:12:46: Date: Apr 24 2020
07:12:46: Time: 17:07:55
07:12:46: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
07:12:46: Bits: 32
07:12:46:******************************* System ********************************
07:12:46: CPU: AMD A8-7410 APU with AMD Radeon R5 Graphics
07:12:46: CPU ID: AuthenticAMD Family 22 Model 48 Stepping 1
07:12:46: CPUs: 4
07:12:46: Memory: 6.94GiB
07:12:46: Free Memory: 4.25GiB
07:12:46: Threads: WINDOWS_THREADS
07:12:46: OS Version: 6.2
07:12:46: Has Battery: true
07:12:46: On Battery: false
07:12:46: UTC Offset: 1
07:12:46: PID: 17304
07:12:46: CWD: C:\Users\[REDACTED]\AppData\Roaming\FAHClient
07:12:46: Win32 Service: false
07:12:46: OS: Windows 10 Home
07:12:46: OS Arch: AMD64
07:12:46: GPUs: 1
07:12:46: GPU 0: Bus:0 Slot:1 Func:0 AMD:5 Mullins [Radeon APU A4-6000 R2]
07:12:46: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
07:12:46: specified module could not be found.
07:12:46:
07:12:46:OpenCL Device 0: Platform:0 Device:0 Bus:0 Slot:1 Compute:1.2 Driver:1800.11
07:12:46:******************************* libFAH ********************************
07:12:46: Date: Apr 15 2020
07:12:46: Time: 14:53:14
07:12:46: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
07:12:46: Bits: 32
07:12:46:***********************************************************************
07:12:46:<config>
07:12:46: <!-- Folding Slot Configuration -->
07:12:46: <cause v='COVID_19'/>
07:12:46:
07:12:46: <!-- Slot Control -->
07:12:46: <power v='LIGHT'/>
07:12:46:
07:12:46: <!-- Folding Slots -->
07:12:46: <slot id='0' type='CPU'/>
07:12:46: <slot id='1' type='GPU'/>
07:12:46:</config>
07:12:47:WU01:FS01:Starting
07:12:47:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\[REDACTED]\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 17304 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
07:12:49:WU01:FS01:Started FahCore on PID 3336
07:12:51:WU01:FS01:Core PID:19180
07:12:51:WU01:FS01:FahCore 0x22 started
07:12:52:WU00:FS00:Starting
07:12:52:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\[REDACTED]\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 17304 -checkpoint 15 -np 1
07:12:52:WU00:FS00:Started FahCore on PID 18576
07:12:53:WU01:FS01:0x22:*********************** Log Started 2020-06-26T07:12:52Z ***********************
07:12:53:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:12:53:WU01:FS01:0x22: Core: Core22
07:12:53:WU01:FS01:0x22: Type: 0x22
07:12:53:WU01:FS01:0x22: Version: 0.0.10
07:12:53:WU01:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:12:53:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
07:12:53:WU01:FS01:0x22: Homepage: https://foldingathome.org/
07:12:53:WU01:FS01:0x22: Date: Jun 16 2020
07:12:53:WU01:FS01:0x22: Time: 14:33:22
07:12:53:WU01:FS01:0x22: Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
07:12:53:WU01:FS01:0x22: Branch: core22-0.0.10
07:12:53:WU01:FS01:0x22: Compiler: Visual C++ 2015
07:12:53:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
07:12:53:WU01:FS01:0x22: Platform: win32 10
07:12:53:WU01:FS01:0x22: Bits: 64
07:12:53:WU01:FS01:0x22: Mode: Release
07:12:53:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:12:53:WU01:FS01:0x22: <peastman@stanford.edu>
07:12:53:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 3336 -checkpoint 15
07:12:53:WU01:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
07:12:53:WU01:FS01:0x22:************************************ libFAH ************************************
07:12:53:WU01:FS01:0x22: Date: Jun 15 2020
07:12:53:WU01:FS01:0x22: Time: 18:05:04
07:12:53:WU01:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
07:12:53:WU01:FS01:0x22: Branch: HEAD
07:12:53:WU01:FS01:0x22:************************************ CBang *************************************
07:12:53:WU01:FS01:0x22: Time: 14:31:33
07:12:53:WU01:FS01:0x22: Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
07:12:53:WU01:FS01:0x22:************************************ System ************************************
07:12:53:WU01:FS01:0x22: CPU: AMD A8-7410 APU with AMD Radeon R5 Graphics
07:12:53:WU01:FS01:0x22: CPU ID: AuthenticAMD Family 22 Model 48 Stepping 1
07:12:53:WU01:FS01:0x22: CPUs: 4
07:12:53:WU01:FS01:0x22: Memory: 6.94GiB
07:12:53:WU01:FS01:0x22:Free Memory: 4.03GiB
07:12:53:WU01:FS01:0x22: Threads: WINDOWS_THREADS
07:12:53:WU01:FS01:0x22: OS Version: 6.2
07:12:53:WU01:FS01:0x22:Has Battery: true
07:12:53:WU01:FS01:0x22: On Battery: false
07:12:53:WU01:FS01:0x22: UTC Offset: 1
07:12:53:WU01:FS01:0x22: PID: 19180
07:12:53:WU01:FS01:0x22: CWD: C:\Users\[REDACTED]\AppData\Roaming\FAHClient\work
07:12:53:WU01:FS01:0x22:********************************************************************************
07:12:53:WU01:FS01:0x22:Project: 13415 (Run 1673, Clone 24, Gen 0)
07:12:53:WU01:FS01:0x22:Unit: 0x0000000012bc7d9a5ef1ae981ea31701
07:12:53:WU01:FS01:0x22:Digital signatures verified
07:12:53:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:12:53:WU01:FS01:0x22:Version 0.0.10
07:12:55:WU01:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
07:12:55:WU01:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
07:12:55:WU01:FS01:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
07:12:55:WU01:FS01:0x22: Global context and integrator variables write interval: 250 steps (0.025%) [4000 total]
07:12:56:WU00:FS00:Core PID:17252
07:12:56:WU00:FS00:FahCore 0xa7 started
07:12:59:WU00:FS00:0xa7:*********************** Log Started 2020-06-26T07:12:58Z ***********************
07:12:59:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:12:59:WU00:FS00:0xa7: Type: 0xa7
07:12:59:WU00:FS00:0xa7: Core: Gromacs
07:12:59:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 18576 -checkpoint 15 -np
07:12:59:WU00:FS00:0xa7: 1
07:12:59:WU00:FS00:0xa7:************************************ CBang *************************************
07:12:59:WU00:FS00:0xa7: Date: Oct 26 2019
07:12:59:WU00:FS00:0xa7: Time: 01:38:25
07:12:59:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
07:12:59:WU00:FS00:0xa7: Branch: master
07:12:59:WU00:FS00:0xa7: Compiler: Visual C++ 2008
07:12:59:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:12:59:WU00:FS00:0xa7: Platform: win32 10
07:12:59:WU00:FS00:0xa7: Bits: 64
07:12:59:WU00:FS00:0xa7: Mode: Release
07:12:59:WU00:FS00:0xa7:************************************ System ************************************
07:12:59:WU00:FS00:0xa7: CPU: AMD A8-7410 APU with AMD Radeon R5 Graphics
07:12:59:WU00:FS00:0xa7: CPU ID: AuthenticAMD Family 22 Model 48 Stepping 1
07:12:59:WU00:FS00:0xa7: CPUs: 4
07:12:59:WU00:FS00:0xa7: Memory: 6.94GiB
07:12:59:WU00:FS00:0xa7:Free Memory: 3.97GiB
07:12:59:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
07:12:59:WU00:FS00:0xa7: OS Version: 6.2
07:12:59:WU00:FS00:0xa7:Has Battery: true
07:12:59:WU00:FS00:0xa7: On Battery: false
07:12:59:WU00:FS00:0xa7: UTC Offset: 1
07:12:59:WU00:FS00:0xa7: PID: 17252
07:12:59:WU00:FS00:0xa7: CWD: C:\Users\[REDACTED]\AppData\Roaming\FAHClient\work
07:12:59:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
07:12:59:WU00:FS00:0xa7: Version: 0.0.18
07:12:59:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:12:59:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
07:12:59:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
07:12:59:WU00:FS00:0xa7: Time: 01:52:30
07:12:59:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
07:12:59:WU00:FS00:0xa7:************************************ Build *************************************
07:12:59:WU00:FS00:0xa7: SIMD: avx_256
07:12:59:WU00:FS00:0xa7:********************************************************************************
07:12:59:WU00:FS00:0xa7:Project: 16424 (Run 1560, Clone 0, Gen 126)
07:12:59:WU00:FS00:0xa7:Unit: 0x0000009ba8f5c67d5e8f6973f7e91f9e
07:12:59:WU00:FS00:0xa7:Digital signatures verified
07:12:59:WU00:FS00:0xa7:Calling: mdrun -s frame126.tpr -o frame126.trr -x frame126.xtc -cpi state.cpt -cpt 15 -nt 1
07:13:00:WU00:FS00:0xa7:ERROR:Guru Meditation #0.a943d41870d8b882 (0.4479048) '00/01/frame126.trr'
I notice your CPU slot is using 1 thread but your CPU exposes 4. The defalult setting would be 3. If you're on a laptop which probably has limite cooling capabiltes, that might be the best setting, but I'd try either 3 or 2 if that doesn't overheat your system. If you're depending on the slider to configure your slots, I you can move it to FULL.
If you mean the "Power" slider on the Web Control, I've just now moved it from Light to Full.bruce wrote:I notice your CPU slot is using 1 thread but your CPU exposes 4. The defalult setting would be 3. If you're on a laptop which probably has limite cooling capabiltes, that might be the best setting, but I'd try either 3 or 2 if that doesn't overheat your system. If you're depending on the slider to configure your slots, I you can move it to FULL.
That is a really old driver.
https://www.amd.com/en/support/apu/amd- ... 5-graphics
I strongly recommend FULL. Or at least MEDIUM.
I could not see how long it took to complete 1% on the CPU and on the GPU as the log quit.
You are folding anonymously, if you want to tune your folding for better science I recommend a User Name and Passkey (I also belong to a team but I am not sure that that helps tuning)
Tracking your points over time tells you what works and what doesn't.
https://folding.extremeoverclocking.com ... =&u=429597
(if you look at Points Months you can see me buying a GTX 1060 last winter and a GTX 1650 this spring, if you look at Work Units Monthly, you can see me retire and the 55 (old, slow) PCs folding as me at my employer go off line)
One thing I noticed was an error message for the CPU WU as the last line of the posted log. This usually indicates a corrupted checkpoint. If the client keeps trrying to process Project: 16424 (Run 1560, Clone 0, Gen 126), we can give you directions on how to remove the WU so your laptop can get another downloaded to work on.
Writing out a checkpoint takes a bit of time. There is a bug where the folding core does not mark itself as not to be interrupted and Windows shutdown can end the process before it has finished. You can avoid this problem by pausing folding and then waiting a short while before shutting down.
We would need to see more of the log, but the IGP that is part of your AMD A8-7410 APU may not be powerful enough to finish GPU WUs within the deadlines.
Thanks again all.
I'm pleased to report that I've achieved one work unit, the stats page shows it already (the data seems have flowed through quite promptly), and my machine's started work on a second work unit automatically.JimboPalmer wrote:the stats server is the oldest, crankiest, server they have. Stats are frequently broken or late.
Yes, it does seem to be moving a bit faster now that I've turned it up to FULL.JimboPalmer wrote:07:12:46: <power v='LIGHT'/>
