Mac prevent me from opening the FAH7.6.13 pkg due to "Apple
newfolder.
Post by newfolder. »
When I try to open up the pkg`, I get an error saying "Apple cannot check it for malicious software" and prevents me from downloading. Do you know how to fix this?
Re: Mac prevent me from opening the FAH7.6.13 pkg due to "Ap
The only way is to use an admin account to override the Gatekeeper settings. Getting the client installer signed by Apple is on a todo list, but may take a while.
NBR
Hardware configuration: 2,3 GHz Dual-Core Intel Core i5 Mac OS
Post by NBR »
If you right-click it an open option will appear. When you click it the same message will appear but there will be an open prompt.
