cayenne187
Posts: 39 Joined: Thu May 14, 2020 7:56 pm
Hardware configuration: intel i7-4790 3.6ghz 16gb ram win 10 pro GTX970 4gb Radeon RX570 4gb
Post
by cayenne187 » Wed Jun 24, 2020 9:47 am
Please stop these Wu that continually crash and rerun themselves. These WU are tiny, waste my time and electricity and cost me 100000's of points per day.
*********************** Log Started 2020-06-24T06:12:15Z ***********************
06:12:15:Trying to access database...
06:12:15:Successfully acquired database lock
06:12:15:Downloading GPUs.txt from assign1.foldingathome.org:80
06:12:15:Connecting to assign1.foldingathome.org:80
06:12:15:Read GPUs.txt
06:12:16:Enabled folding slot 01: READY gpu:0:GM204 [GeForce GTX 970] 3494
06:12:16:Enabled folding slot 02: READY gpu:1:Ellesmere XT [Radeon RX 470/480/570/580/590]
06:12:16:****************************** FAHClient ******************************
06:12:16: Version: 7.6.13
06:12:16: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:12:16: Copyright: 2020 foldingathome.org
06:12:16: Homepage: https://foldingathome.org/
06:12:16: Date: Apr 27 2020
06:12:16: Time: 21:21:01
06:12:16: Revision: 5a652817f46116b6e135503af97f18e094414e3b
06:12:16: Branch: master
06:12:16: Compiler: Visual C++ 2008
06:12:16: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:12:16: Platform: win32 10
06:12:16: Bits: 32
06:12:16: Mode: Release
06:12:16: Args: --open-web-control
06:12:16: Config: C:\Users\phil\AppData\Roaming\FAHClient\config.xml
06:12:16:******************************** CBang ********************************
06:12:16: Date: Apr 24 2020
06:12:16: Time: 17:07:55
06:12:16: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
06:12:16: Bits: 32
06:12:16:******************************* System ********************************
06:12:16: CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
06:12:16: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
06:12:16: CPUs: 8
06:12:16: Memory: 15.95GiB
06:12:16: Free Memory: 13.27GiB
06:12:16: Threads: WINDOWS_THREADS
06:12:16: OS Version: 6.2
06:12:16: Has Battery: false
06:12:16: On Battery: false
06:12:16: UTC Offset: -4
06:12:16: PID: 5568
06:12:16: CWD: C:\Users\phil\AppData\Roaming\FAHClient
06:12:16: Win32 Service: false
06:12:16: OS: Windows 10 Enterprise
06:12:16: OS Arch: AMD64
06:12:16: GPUs: 2
06:12:16: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GM204 [GeForce GTX 970] 3494
06:12:16: GPU 1: Bus:6 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
06:12:16: 470/480/570/580/590]
06:12:16: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.2 Driver:11.0
06:12:16:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.87
06:12:16:OpenCL Device 1: Platform:1 Device:0 Bus:6 Slot:0 Compute:1.2 Driver:3004.8
06:12:16:******************************* libFAH ********************************
06:12:16: Date: Apr 15 2020
06:12:16: Time: 14:53:14
06:12:16: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
06:12:16: Bits: 32
06:12:16:***********************************************************************
06:12:16:<config>
06:12:16: <!-- Folding Slot Configuration -->
06:12:16: <cause v='COVID_19'/>
06:12:16:
06:12:16: <!-- Network -->
06:12:16: <proxy v=':8080'/>
06:12:16:
06:12:16: <!-- Slot Control -->
06:12:16: <pause-on-battery v='false'/>
06:12:16: <power v='full'/>
06:12:16:
06:12:16: <!-- User Information -->
06:12:16: <passkey v='*****'/>
06:12:16: <user v='cayenne187'/>
06:12:16:
06:12:16: <!-- Folding Slots -->
06:12:16: <slot id='1' type='GPU'>
06:12:16: <gpu-index v='0'/>
06:12:16: </slot>
06:12:16: <slot id='2' type='GPU'/>
06:12:16:</config>
06:12:16:WU03:FS02:Starting
06:12:16:WU03:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 706 -lifeline 5568 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
06:12:16:WU03:FS02:Started FahCore on PID 4128
06:12:17:WU03:FS02:Core PID:8580
06:12:17:WU03:FS02:FahCore 0x22 started
06:12:17:WU02:FS01:Starting
06:12:17:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 5568 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
06:12:17:WU02:FS01:Started FahCore on PID 7268
06:12:17:WU02:FS01:Core PID:5992
06:12:17:WU02:FS01:FahCore 0x22 started
06:12:17:WU03:FS02:0x22:*********************** Log Started 2020-06-24T06:12:17Z ***********************
06:12:17:WU03:FS02:0x22:*************************** Core22 Folding@home Core ***************************
06:12:17:WU03:FS02:0x22: Core: Core22
06:12:17:WU03:FS02:0x22: Type: 0x22
06:12:17:WU03:FS02:0x22: Version: 0.0.10
06:12:17:WU03:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:12:17:WU03:FS02:0x22: Copyright: 2020 foldingathome.org
06:12:17:WU03:FS02:0x22: Homepage: https://foldingathome.org/
06:12:17:WU03:FS02:0x22: Date: Jun 16 2020
06:12:17:WU03:FS02:0x22: Time: 14:33:22
06:12:17:WU03:FS02:0x22: Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
06:12:17:WU03:FS02:0x22: Branch: core22-0.0.10
06:12:17:WU03:FS02:0x22: Compiler: Visual C++ 2015
06:12:17:WU03:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
06:12:17:WU03:FS02:0x22: Platform: win32 10
06:12:17:WU03:FS02:0x22: Bits: 64
06:12:17:WU03:FS02:0x22: Mode: Release
06:12:17:WU03:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
06:12:17:WU03:FS02:0x22: <peastman@stanford.edu>
06:12:17:WU03:FS02:0x22: Args: -dir 03 -suffix 01 -version 706 -lifeline 4128 -checkpoint 15
06:12:17:WU03:FS02:0x22: -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
06:12:17:WU03:FS02:0x22:************************************ libFAH ************************************
06:12:17:WU03:FS02:0x22: Date: Jun 15 2020
06:12:17:WU03:FS02:0x22: Time: 18:05:04
06:12:17:WU03:FS02:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
06:12:17:WU03:FS02:0x22: Branch: HEAD
06:12:17:WU03:FS02:0x22:************************************ CBang *************************************
06:12:17:WU03:FS02:0x22: Time: 14:31:33
06:12:17:WU03:FS02:0x22: Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
06:12:17:WU03:FS02:0x22:************************************ System ************************************
06:12:17:WU03:FS02:0x22: CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
06:12:17:WU03:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
06:12:17:WU03:FS02:0x22: CPUs: 8
06:12:17:WU03:FS02:0x22: Memory: 15.95GiB
06:12:17:WU03:FS02:0x22:Free Memory: 13.19GiB
06:12:17:WU03:FS02:0x22: Threads: WINDOWS_THREADS
06:12:17:WU03:FS02:0x22: OS Version: 6.2
06:12:17:WU03:FS02:0x22:Has Battery: false
06:12:17:WU03:FS02:0x22: On Battery: false
06:12:17:WU03:FS02:0x22: UTC Offset: -4
06:12:17:WU03:FS02:0x22: PID: 8580
06:12:17:WU03:FS02:0x22: CWD: C:\Users\phil\AppData\Roaming\FAHClient\work
06:12:17:WU03:FS02:0x22:********************************************************************************
06:12:17:WU03:FS02:0x22:Project: 13415 (Run 2495, Clone 0, Gen 1)
06:12:17:WU03:FS02:0x22:Unit: 0x0000000112bc7d9a5ef1ae65b11f839c
06:12:17:WU03:FS02:0x22:Reading tar file core.xml
06:12:17:WU03:FS02:0x22:Reading tar file integrator.xml
06:12:17:WU03:FS02:0x22:Reading tar file state.xml
06:12:17:WU03:FS02:0x22:Reading tar file system.xml
06:12:17:WU03:FS02:0x22:Digital signatures verified
06:12:17:WU03:FS02:0x22:Folding@home GPU Core22 Folding@home Core
06:12:17:WU03:FS02:0x22:Version 0.0.10
06:12:17:WU03:FS02:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
06:12:17:WU03:FS02:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
06:12:17:WU03:FS02:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
06:12:17:WU03:FS02:0x22: Global context and integrator variables write interval: 250 steps (0.025%) [4000 total]
06:12:17:WU02:FS01:0x22:*********************** Log Started 2020-06-24T06:12:17Z ***********************
06:12:17:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
06:12:17:WU02:FS01:0x22: Core: Core22
06:12:17:WU02:FS01:0x22: Type: 0x22
06:12:17:WU02:FS01:0x22: Version: 0.0.10
06:12:17:WU02:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:12:17:WU02:FS01:0x22: Copyright: 2020 foldingathome.org
06:12:17:WU02:FS01:0x22: Homepage: https://foldingathome.org/
06:12:17:WU02:FS01:0x22: Date: Jun 16 2020
06:12:17:WU02:FS01:0x22: Time: 14:33:22
06:12:17:WU02:FS01:0x22: Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
06:12:17:WU02:FS01:0x22: Branch: core22-0.0.10
06:12:17:WU02:FS01:0x22: Compiler: Visual C++ 2015
06:12:17:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
06:12:17:WU02:FS01:0x22: Platform: win32 10
06:12:17:WU02:FS01:0x22: Bits: 64
06:12:17:WU02:FS01:0x22: Mode: Release
06:12:17:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
06:12:17:WU02:FS01:0x22: <peastman@stanford.edu>
06:12:17:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 7268 -checkpoint 15
06:12:17:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
06:12:17:WU02:FS01:0x22: 0 -gpu 0
06:12:17:WU02:FS01:0x22:************************************ libFAH ************************************
06:12:17:WU02:FS01:0x22: Date: Jun 15 2020
06:12:17:WU02:FS01:0x22: Time: 18:05:04
06:12:17:WU02:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
06:12:17:WU02:FS01:0x22: Branch: HEAD
06:12:17:WU02:FS01:0x22:************************************ CBang *************************************
06:12:17:WU02:FS01:0x22: Time: 14:31:33
06:12:17:WU02:FS01:0x22: Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
06:12:17:WU02:FS01:0x22:************************************ System ************************************
06:12:17:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
06:12:17:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
06:12:17:WU02:FS01:0x22: CPUs: 8
06:12:17:WU02:FS01:0x22: Memory: 15.95GiB
06:12:17:WU02:FS01:0x22:Free Memory: 13.12GiB
06:12:17:WU02:FS01:0x22: Threads: WINDOWS_THREADS
06:12:17:WU02:FS01:0x22: OS Version: 6.2
06:12:17:WU02:FS01:0x22:Has Battery: false
06:12:17:WU02:FS01:0x22: On Battery: false
06:12:17:WU02:FS01:0x22: UTC Offset: -4
06:12:17:WU02:FS01:0x22: PID: 5992
06:12:17:WU02:FS01:0x22: CWD: C:\Users\phil\AppData\Roaming\FAHClient\work
06:12:17:WU02:FS01:0x22:********************************************************************************
06:12:17:WU02:FS01:0x22:Project: 14253 (Run 933, Clone 4, Gen 94)
06:12:18:WU02:FS01:0x22:Unit: 0x0000008ecedfaa925eaba95f11fdb6ac
06:12:18:WU02:FS01:0x22:Digital signatures verified
06:12:18:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
06:12:18:WU02:FS01:0x22:Version 0.0.10
06:12:18:WU02:FS01:0x22: Checkpoint write interval: 25000 steps (5%) [20 total]
06:12:18:WU02:FS01:0x22: JSON viewer frame write interval: 5000 steps (1%) [100 total]
06:12:18:WU02:FS01:0x22: XTC frame write interval: 20000 steps (4%) [25 total]
06:12:18:WU02:FS01:0x22: Global context and integrator variables write interval: disabled
06:12:26:WU03:FS02:0x22:Completed 0 out of 1000000 steps (0%)
06:12:59:22:127.0.0.1:New Web session
06:13:29:WU03:FS02:0x22:Completed 10000 out of 1000000 steps (1%)
06:14:10:WU02:FS01:0x22:Completed 275000 out of 500000 steps (55%)
06:14:34:WU03:FS02:0x22:Completed 20000 out of 1000000 steps (2%)
06:15:36:WU03:FS02:0x22:Completed 30000 out of 1000000 steps (3%)
06:16:38:WU03:FS02:0x22:Completed 40000 out of 1000000 steps (4%)
06:17:39:WU03:FS02:0x22:Completed 50000 out of 1000000 steps (5%)
06:18:41:WU03:FS02:0x22:Completed 60000 out of 1000000 steps (6%)
06:18:50:WU02:FS01:0x22:Completed 280000 out of 500000 steps (56%)
06:19:43:WU03:FS02:0x22:Completed 70000 out of 1000000 steps (7%)
06:20:45:WU03:FS02:0x22:Completed 80000 out of 1000000 steps (8%)
06:21:46:WU03:FS02:0x22:Completed 90000 out of 1000000 steps (9%)
06:22:48:WU03:FS02:0x22:Completed 100000 out of 1000000 steps (10%)
06:23:30:WU02:FS01:0x22:Completed 285000 out of 500000 steps (57%)
06:23:50:WU03:FS02:0x22:Completed 110000 out of 1000000 steps (11%)
06:24:51:WU03:FS02:0x22:Completed 120000 out of 1000000 steps (12%)
06:25:53:WU03:FS02:0x22:Completed 130000 out of 1000000 steps (13%)
06:26:55:WU03:FS02:0x22:Completed 140000 out of 1000000 steps (14%)
06:27:57:WU03:FS02:0x22:Completed 150000 out of 1000000 steps (15%)
06:28:08:WU02:FS01:0x22:Completed 290000 out of 500000 steps (58%)
06:28:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:28:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:28:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:28:59:WU03:FS02:0x22:Completed 160000 out of 1000000 steps (16%)
06:29:09:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
06:29:09:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:30:02:WU03:FS02:0x22:Completed 170000 out of 1000000 steps (17%)
06:31:03:WU03:FS02:0x22:Completed 180000 out of 1000000 steps (18%)
06:32:05:WU03:FS02:0x22:Completed 190000 out of 1000000 steps (19%)
06:32:45:WU02:FS01:0x22:Completed 295000 out of 500000 steps (59%)
06:33:07:WU03:FS02:0x22:Completed 200000 out of 1000000 steps (20%)
06:34:09:WU03:FS02:0x22:Completed 210000 out of 1000000 steps (21%)
06:35:11:WU03:FS02:0x22:Completed 220000 out of 1000000 steps (22%)
06:36:13:WU03:FS02:0x22:Completed 230000 out of 1000000 steps (23%)
06:37:16:WU03:FS02:0x22:Completed 240000 out of 1000000 steps (24%)
06:37:23:WU02:FS01:0x22:Completed 300000 out of 500000 steps (60%)
06:38:19:WU03:FS02:0x22:Completed 250000 out of 1000000 steps (25%)
06:39:23:WU03:FS02:0x22:Completed 260000 out of 1000000 steps (26%)
06:40:27:WU03:FS02:0x22:Completed 270000 out of 1000000 steps (27%)
06:41:31:WU03:FS02:0x22:Completed 280000 out of 1000000 steps (28%)
06:42:05:WU02:FS01:0x22:Completed 305000 out of 500000 steps (61%)
06:42:35:WU03:FS02:0x22:Completed 290000 out of 1000000 steps (29%)
06:43:40:WU03:FS02:0x22:Completed 300000 out of 1000000 steps (30%)
06:44:44:WU03:FS02:0x22:Completed 310000 out of 1000000 steps (31%)
06:45:48:WU03:FS02:0x22:Completed 320000 out of 1000000 steps (32%)
06:46:43:WU02:FS01:0x22:Completed 310000 out of 500000 steps (62%)
06:46:52:WU03:FS02:0x22:Completed 330000 out of 1000000 steps (33%)
06:47:56:WU03:FS02:0x22:Completed 340000 out of 1000000 steps (34%)
06:49:01:WU03:FS02:0x22:Completed 350000 out of 1000000 steps (35%)
06:50:05:WU03:FS02:0x22:Completed 360000 out of 1000000 steps (36%)
06:51:09:WU03:FS02:0x22:Completed 370000 out of 1000000 steps (37%)
06:51:22:WU02:FS01:0x22:Completed 315000 out of 500000 steps (63%)
06:52:14:WU03:FS02:0x22:Completed 380000 out of 1000000 steps (38%)
06:53:19:WU03:FS02:0x22:Completed 390000 out of 1000000 steps (39%)
06:54:24:WU03:FS02:0x22:Completed 400000 out of 1000000 steps (40%)
06:55:29:WU03:FS02:0x22:Completed 410000 out of 1000000 steps (41%)
06:56:06:WU02:FS01:0x22:Completed 320000 out of 500000 steps (64%)
06:56:34:WU03:FS02:0x22:Completed 420000 out of 1000000 steps (42%)
06:57:39:WU03:FS02:0x22:Completed 430000 out of 1000000 steps (43%)
06:58:44:WU03:FS02:0x22:Completed 440000 out of 1000000 steps (44%)
06:59:49:WU03:FS02:0x22:Completed 450000 out of 1000000 steps (45%)
07:00:53:WU02:FS01:0x22:Completed 325000 out of 500000 steps (65%)
07:00:55:WU03:FS02:0x22:Completed 460000 out of 1000000 steps (46%)
07:02:00:WU03:FS02:0x22:Completed 470000 out of 1000000 steps (47%)
07:03:06:WU03:FS02:0x22:Completed 480000 out of 1000000 steps (48%)
07:04:10:WU03:FS02:0x22:Completed 490000 out of 1000000 steps (49%)
07:05:16:WU03:FS02:0x22:Completed 500000 out of 1000000 steps (50%)
07:05:42:WU02:FS01:0x22:Completed 330000 out of 500000 steps (66%)
07:06:21:WU03:FS02:0x22:Completed 510000 out of 1000000 steps (51%)
07:07:25:WU03:FS02:0x22:Completed 520000 out of 1000000 steps (52%)
07:08:28:WU03:FS02:0x22:Completed 530000 out of 1000000 steps (53%)
07:09:33:WU03:FS02:0x22:Completed 540000 out of 1000000 steps (54%)
07:10:28:WU02:FS01:0x22:Completed 335000 out of 500000 steps (67%)
07:10:37:WU03:FS02:0x22:Completed 550000 out of 1000000 steps (55%)
07:11:41:WU03:FS02:0x22:Completed 560000 out of 1000000 steps (56%)
07:12:45:WU03:FS02:0x22:Completed 570000 out of 1000000 steps (57%)
07:13:50:WU03:FS02:0x22:Completed 580000 out of 1000000 steps (58%)
07:14:53:WU03:FS02:0x22:Completed 590000 out of 1000000 steps (59%)
07:15:14:WU02:FS01:0x22:Completed 340000 out of 500000 steps (68%)
07:15:57:WU03:FS02:0x22:Completed 600000 out of 1000000 steps (60%)
07:17:01:WU03:FS02:0x22:Completed 610000 out of 1000000 steps (61%)
07:18:04:WU03:FS02:0x22:Completed 620000 out of 1000000 steps (62%)
07:19:08:WU03:FS02:0x22:Completed 630000 out of 1000000 steps (63%)
07:19:55:WU02:FS01:0x22:Completed 345000 out of 500000 steps (69%)
07:20:12:WU03:FS02:0x22:Completed 640000 out of 1000000 steps (64%)
07:21:15:WU03:FS02:0x22:Completed 650000 out of 1000000 steps (65%)
07:22:19:WU03:FS02:0x22:Completed 660000 out of 1000000 steps (66%)
07:23:22:WU03:FS02:0x22:Completed 670000 out of 1000000 steps (67%)
07:24:26:WU03:FS02:0x22:Completed 680000 out of 1000000 steps (68%)
07:24:34:WU02:FS01:0x22:Completed 350000 out of 500000 steps (70%)
07:25:31:WU03:FS02:0x22:Completed 690000 out of 1000000 steps (69%)
07:26:35:WU03:FS02:0x22:Completed 700000 out of 1000000 steps (70%)
07:27:38:WU03:FS02:0x22:Completed 710000 out of 1000000 steps (71%)
07:28:42:WU03:FS02:0x22:Completed 720000 out of 1000000 steps (72%)
07:29:17:WU02:FS01:0x22:Completed 355000 out of 500000 steps (71%)
07:29:46:WU03:FS02:0x22:Completed 730000 out of 1000000 steps (73%)
07:30:49:WU03:FS02:0x22:Completed 740000 out of 1000000 steps (74%)
07:31:53:WU03:FS02:0x22:Completed 750000 out of 1000000 steps (75%)
07:32:58:WU03:FS02:0x22:Completed 760000 out of 1000000 steps (76%)
07:33:55:WU02:FS01:0x22:Completed 360000 out of 500000 steps (72%)
07:34:04:WU03:FS02:0x22:Completed 770000 out of 1000000 steps (77%)
07:35:09:WU03:FS02:0x22:Completed 780000 out of 1000000 steps (78%)
07:36:15:WU03:FS02:0x22:Completed 790000 out of 1000000 steps (79%)
07:37:20:WU03:FS02:0x22:Completed 800000 out of 1000000 steps (80%)
07:38:26:WU03:FS02:0x22:Completed 810000 out of 1000000 steps (81%)
07:38:32:WU02:FS01:0x22:Completed 365000 out of 500000 steps (73%)
07:39:31:WU03:FS02:0x22:Completed 820000 out of 1000000 steps (82%)
07:40:36:WU03:FS02:0x22:Completed 830000 out of 1000000 steps (83%)
07:41:42:WU03:FS02:0x22:Completed 840000 out of 1000000 steps (84%)
07:42:47:WU03:FS02:0x22:Completed 850000 out of 1000000 steps (85%)
07:43:10:WU02:FS01:0x22:Completed 370000 out of 500000 steps (74%)
07:43:53:WU03:FS02:0x22:Completed 860000 out of 1000000 steps (86%)
07:44:59:WU03:FS02:0x22:Completed 870000 out of 1000000 steps (87%)
07:46:05:WU03:FS02:0x22:Completed 880000 out of 1000000 steps (88%)
07:47:11:WU03:FS02:0x22:Completed 890000 out of 1000000 steps (89%)
07:47:47:WU02:FS01:0x22:Completed 375000 out of 500000 steps (75%)
07:48:18:WU03:FS02:0x22:Completed 900000 out of 1000000 steps (90%)
07:49:24:WU03:FS02:0x22:Completed 910000 out of 1000000 steps (91%)
07:50:29:WU03:FS02:0x22:Completed 920000 out of 1000000 steps (92%)
07:51:35:WU03:FS02:0x22:Completed 930000 out of 1000000 steps (93%)
07:52:27:WU02:FS01:0x22:Completed 380000 out of 500000 steps (76%)
07:52:41:WU03:FS02:0x22:Completed 940000 out of 1000000 steps (94%)
07:53:47:WU03:FS02:0x22:Completed 950000 out of 1000000 steps (95%)
07:54:53:WU03:FS02:0x22:Completed 960000 out of 1000000 steps (96%)
07:55:59:WU03:FS02:0x22:Completed 970000 out of 1000000 steps (97%)
07:57:03:WU02:FS01:0x22:Completed 385000 out of 500000 steps (77%)
07:57:05:WU03:FS02:0x22:Completed 980000 out of 1000000 steps (98%)
07:58:11:WU03:FS02:0x22:Completed 990000 out of 1000000 steps (99%)
07:59:16:WU03:FS02:0x22:Completed 1000000 out of 1000000 steps (100%)
07:59:16:WU03:FS02:0x22:Average performance: 262.614 ns/day
07:59:17:WU03:FS02:0x22:Saving result file ..\logfile_01.txt
07:59:17:WU03:FS02:0x22:Saving result file checkpointState.xml
07:59:17:WU03:FS02:0x22:Saving result file globals.csv
07:59:17:WU03:FS02:0x22:Saving result file positions.xtc
07:59:17:WU03:FS02:0x22:Saving result file science.log
07:59:17:WU03:FS02:0x22:Folding@home Core Shutdown: FINISHED_UNIT
08:01:39:WU02:FS01:0x22:Completed 390000 out of 500000 steps (78%)
08:06:17:WU02:FS01:0x22:Completed 395000 out of 500000 steps (79%)
08:10:53:WU02:FS01:0x22:Completed 400000 out of 500000 steps (80%)
08:15:33:WU02:FS01:0x22:Completed 405000 out of 500000 steps (81%)
08:20:09:WU02:FS01:0x22:Completed 410000 out of 500000 steps (82%)
08:24:44:WU02:FS01:0x22:Completed 415000 out of 500000 steps (83%)
08:29:20:WU02:FS01:0x22:Completed 420000 out of 500000 steps (84%)
08:33:56:WU02:FS01:0x22:Completed 425000 out of 500000 steps (85%)
08:38:36:WU02:FS01:0x22:Completed 430000 out of 500000 steps (86%)
08:43:12:WU02:FS01:0x22:Completed 435000 out of 500000 steps (87%)
08:47:48:WU02:FS01:0x22:Completed 440000 out of 500000 steps (88%)
08:52:25:WU02:FS01:0x22:Completed 445000 out of 500000 steps (89%)
08:57:03:WU02:FS01:0x22:Completed 450000 out of 500000 steps (90%)
09:01:42:WU02:FS01:0x22:Completed 455000 out of 500000 steps (91%)
09:06:18:WU02:FS01:0x22:Completed 460000 out of 500000 steps (92%)
09:10:54:WU02:FS01:0x22:Completed 465000 out of 500000 steps (93%)
09:15:31:WU02:FS01:0x22:Completed 470000 out of 500000 steps (94%)
09:20:08:WU02:FS01:0x22:Completed 475000 out of 500000 steps (95%)
09:24:47:WU02:FS01:0x22:Completed 480000 out of 500000 steps (96%)
09:29:23:WU02:FS01:0x22:Completed 485000 out of 500000 steps (97%)
09:33:59:WU02:FS01:0x22:Completed 490000 out of 500000 steps (98%)
09:38:19:WARNING:WU03:FS02:FahCore returned an unknown error code which probably indicates that it crashed
09:38:19:WARNING:WU03:FS02:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
09:38:19:WU00:FS02:Starting
09:38:19:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 5568 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
09:38:19:WU00:FS02:Started FahCore on PID 10128
09:38:19:WU00:FS02:Core PID:11388
09:38:19:WU00:FS02:FahCore 0x22 started
09:38:20:WU00:FS02:0x22:*********************** Log Started 2020-06-24T09:38:19Z ***********************
09:38:20:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
09:38:20:WU00:FS02:0x22: Core: Core22
09:38:20:WU00:FS02:0x22: Type: 0x22
09:38:20:WU00:FS02:0x22: Version: 0.0.10
09:38:20:WU00:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:38:20:WU00:FS02:0x22: Copyright: 2020 foldingathome.org
09:38:20:WU00:FS02:0x22: Homepage: https://foldingathome.org/
09:38:20:WU00:FS02:0x22: Date: Jun 16 2020
09:38:20:WU00:FS02:0x22: Time: 14:33:22
09:38:20:WU00:FS02:0x22: Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
09:38:20:WU00:FS02:0x22: Branch: core22-0.0.10
09:38:20:WU00:FS02:0x22: Compiler: Visual C++ 2015
09:38:20:WU00:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
09:38:20:WU00:FS02:0x22: Platform: win32 10
09:38:20:WU00:FS02:0x22: Bits: 64
09:38:20:WU00:FS02:0x22: Mode: Release
09:38:20:WU00:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
09:38:20:WU00:FS02:0x22: <peastman@stanford.edu>
09:38:20:WU00:FS02:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 10128 -checkpoint 15
09:38:20:WU00:FS02:0x22: -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
09:38:20:WU00:FS02:0x22:************************************ libFAH ************************************
09:38:20:WU00:FS02:0x22: Date: Jun 15 2020
09:38:20:WU00:FS02:0x22: Time: 18:05:04
09:38:20:WU00:FS02:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
09:38:20:WU00:FS02:0x22: Branch: HEAD
09:38:20:WU00:FS02:0x22:************************************ CBang *************************************
09:38:20:WU00:FS02:0x22: Time: 14:31:33
09:38:20:WU00:FS02:0x22: Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
09:38:20:WU00:FS02:0x22:************************************ System ************************************
09:38:20:WU00:FS02:0x22: CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
09:38:20:WU00:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
09:38:20:WU00:FS02:0x22: CPUs: 8
09:38:20:WU00:FS02:0x22: Memory: 15.95GiB
09:38:20:WU00:FS02:0x22:Free Memory: 11.90GiB
09:38:20:WU00:FS02:0x22: Threads: WINDOWS_THREADS
09:38:20:WU00:FS02:0x22: OS Version: 6.2
09:38:20:WU00:FS02:0x22:Has Battery: false
09:38:20:WU00:FS02:0x22: On Battery: false
09:38:20:WU00:FS02:0x22: UTC Offset: -4
09:38:20:WU00:FS02:0x22: PID: 11388
09:38:20:WU00:FS02:0x22: CWD: C:\Users\phil\AppData\Roaming\FAHClient\work
09:38:20:WU00:FS02:0x22:********************************************************************************
09:38:20:WU00:FS02:0x22:Project: 11760 (Run 0, Clone 941, Gen 89)
09:38:20:WU00:FS02:0x22:Unit: 0x000000aa80fccb0a5e6d7cd26a0dab3d
09:38:20:WU00:FS02:0x22:Digital signatures verified
09:38:20:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
09:38:20:WU00:FS02:0x22:Version 0.0.10
09:38:20:WU00:FS02:0x22: Checkpoint write interval: 100000 steps (5%) [20 total]
09:38:20:WU00:FS02:0x22: JSON viewer frame write interval: 20000 steps (1%) [100 total]
09:38:20:WU00:FS02:0x22: XTC frame write interval: 50000 steps (2.5%) [40 total]
09:38:20:WU00:FS02:0x22: Global context and integrator variables write interval: disabled
09:38:35:WU02:FS01:0x22:Completed 495000 out of 500000 steps (99%)
09:38:36:WU01:FS01:Connecting to assign1.foldingathome.org:80
09:38:36:WU01:FS01:Assigned to work server 140.163.4.241
09:38:36:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 970] 3494 from 140.163.4.241
09:38:36:WU01:FS01:Connecting to 140.163.4.241:8080
09:38:38:WU00:FS02:0x22:Completed 0 out of 2000000 steps (0%)
09:38:47:WU01:FS01:Downloading 7.93MiB
09:38:47:WU01:FS01:Download complete
09:38:48:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11745 run:0 clone:3074 gen:170 core:0x22 unit:0x000001078ca304f15e6a0afe286a2662
Joe_H on Wed Jun 24, 2020 1:39 pm, edited 1 time in total.
Reason: added Code tags to log
Date of last Work Unit 2020-08-04 22:17:53
Total score 63,300,083
Total WUs 1,013
Overall rank (if points are combined) 15,440 of 2,735,299
TPL
Posts: 103 Joined: Sun Apr 19, 2020 11:37 am
Post
by TPL » Wed Jun 24, 2020 10:42 am
Please don't stop, I like this WU. See, I'm greedy for points, I don't want to loose my decent 30k PPD (if everything goes fine).
Posts: 1996 Joined: Sun Mar 22, 2020 5:52 pm
Hardware configuration: 1: 2x Xeon E5-2697v3@2.60GHz, 512GB DDR4 LRDIMM, SSD Raid, Win10 Ent 20H2, Quadro K420 1GB, FAH 7.6.21 2: Xeon E3-1505Mv5@2.80GHz, 32GB DDR4, NVME, Win10 Pro 20H2, Quadro M1000M 2GB, FAH 7.6.21 (actually have two of these) 3: i7-960@3.20GHz, 12GB DDR3, SSD, Win10 Pro 20H2, GTX 750Ti 2GB, GTX 1080Ti 11GB, FAH 7.6.21
Post
by Neil-B » Wed Jun 24, 2020 12:47 pm
... but they are the science and testing that the fah team need doing - you may feel they are getting in the way of your points tally and wasting power but actually they exist because fah needs them to ... tbh I personally support getting the science done and reckon that when points are more important than the science something is badly wrong ... but that is simply my opinion and I accept others may feel otherwise.
TPL
Post
by TPL » Wed Jun 24, 2020 1:42 pm
Of course thats all joking by me. What do I do with that 6k/WU? What do I do with points anyway? But I happen to have old GPU which I can use if I can access this particular WU. Otherwise I remove the slot.
I wouldn't like to do so if possible to go on. That means folding WUs and do some science with it and also make that testing possible. It is on 24/7 anyway, so why not?
My problem is opposite. If I'm getting larger WU for that old piece of junk, I will dump it. Yes I will, because it would take some 2.5 or 3.5 days. Call it cherry picking but I see it wasting of time if I let it continue. What could I achieve, some few points eventually after days but I just slowed down the process for that 24 hours. When timeout is reached and WU maybe reassigned, I still would have 1.5 or 2.5 days left. Naah, I don't let it go to that point. For me it is more honest to dump it right away, let it free so to say.
I like idea of using those older GPUs as well but the problem seems to be addressing those WUs to correct users with correct hardware.
I have another computer with faster GPU as well, so am I after poits with this? No.
If they like me to stop this, I'll do it. But this testing does seem to me like it wouldn't be the case. For now, it seems to work fine for me, I have only had 13415 recently on my old machine.
cayenne187
Post
by cayenne187 » Wed Jun 24, 2020 8:52 pm
it's not the points. it's wasting time and electricity by crashing and running the same WU over and over again. I also feel these smaller WU are better suited for CPU or less powerful GPU processing. right now i am happy, 900000 ppd from 350 watts.
Total WUs 1,013
Posts: 8274 Joined: Tue Apr 21, 2009 4:41 pm
Hardware configuration: Mac Studio M1 Max 32 GB smp6 Mac Hack i7-7700K 48 GB smp4
Post
by Joe_H » Wed Jun 24, 2020 9:26 pm
CPU processing will not finish the projects in the timeframe needed for the COVID Moonshot. Getting them to all go to less powerful GPUs is not easily done, if possible to do at all, with the current server and client software. Part of the goal of the initial runs of projects like this is to gather the necessary data to make those kind of changes
In addition, part of the goal of the new version of Core_22 was to fix that post processing crash of the core that is shown in your log. I will bring that to the attention of the person working on that code. He may or may not have received an error report when the WU was eventually processed and returned, but that is not shown in the section of log you posted. You are the only person shown as returning this WU on the stats, was it from this system or do you have another that might have received the same WU?
cayenne187
Post
by cayenne187 » Wed Jun 24, 2020 9:35 pm
thanks Joe_H. i only have this system. i have received several WU like this in the last week. at least some others were 13415 and they crashed and started again and finished. this particular one kept crashing at the end and then restarting over and over. i don't monitor my fah that much. these flagged me with a fah stopped working window. it was already running again. let me know how else i can help.
Total WUs 1,013
cayenne187
Post
by cayenne187 » Wed Jun 24, 2020 10:11 pm
just received new WU for 13415 on the gtx 970. all previous problems were on the radeon rx 570. let's see if that was the problem. seems like they are aware of the issue. same 2500 point wu on the rx570 was not using the gpu, this one is.
Total WUs 1,013
cayenne187
Post
by cayenne187 » Wed Jun 24, 2020 10:33 pm
Edit by Mod: Added code tags.
09:41:01:WU00:FS02:0x22:Completed 20000 out of 2000000 steps (1%)
09:43:16:WU02:FS01:0x22:Completed 500000 out of 500000 steps (100%)
09:43:16:WU02:FS01:0x22:Average performance: 2.49711 ns/day
09:43:23:WU00:FS02:0x22:Completed 40000 out of 2000000 steps (2%)
09:43:33:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
09:43:33:WU02:FS01:0x22:Saving result file checkpointState.xml
09:43:39:WU02:FS01:0x22:Saving result file positions.xtc
09:43:40:WU02:FS01:0x22:Saving result file science.log
09:43:40:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
09:43:41:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:43:41:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:14253 run:933 clone:4 gen:94 core:0x22 unit:0x0000008ecedfaa925eaba95f11fdb6ac
09:43:41:WU02:FS01:Uploading 39.82MiB to 206.223.170.146
09:43:41:WU01:FS01:Starting
09:43:41:WU02:FS01:Connecting to 206.223.170.146:8080
09:43:41:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 5568 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:43:41:WU01:FS01:Started FahCore on PID 11252
09:43:41:WU01:FS01:Core PID:6640
09:43:41:WU01:FS01:FahCore 0x22 started
09:43:41:WU01:FS01:0x22:*********************** Log Started 2020-06-24T09:43:41Z ***********************
09:43:41:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
09:43:41:WU01:FS01:0x22: Core: Core22
09:43:41:WU01:FS01:0x22: Type: 0x22
09:43:41:WU01:FS01:0x22: Version: 0.0.10
09:43:41:WU01:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:43:41:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
09:43:41:WU01:FS01:0x22: Homepage: https://foldingathome.org/
09:43:41:WU01:FS01:0x22: Date: Jun 16 2020
09:43:41:WU01:FS01:0x22: Time: 14:33:22
09:43:41:WU01:FS01:0x22: Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
09:43:41:WU01:FS01:0x22: Branch: core22-0.0.10
09:43:41:WU01:FS01:0x22: Compiler: Visual C++ 2015
09:43:41:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
09:43:41:WU01:FS01:0x22: Platform: win32 10
09:43:41:WU01:FS01:0x22: Bits: 64
09:43:41:WU01:FS01:0x22: Mode: Release
09:43:41:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
09:43:41:WU01:FS01:0x22: <peastman@stanford.edu>
09:43:41:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 11252 -checkpoint 15
09:43:41:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
09:43:41:WU01:FS01:0x22: 0 -gpu 0
09:43:41:WU01:FS01:0x22:************************************ libFAH ************************************
09:43:41:WU01:FS01:0x22: Date: Jun 15 2020
09:43:41:WU01:FS01:0x22: Time: 18:05:04
09:43:41:WU01:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
09:43:41:WU01:FS01:0x22: Branch: HEAD
09:43:41:WU01:FS01:0x22:************************************ CBang *************************************
09:43:41:WU01:FS01:0x22: Time: 14:31:33
09:43:41:WU01:FS01:0x22: Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
09:43:41:WU01:FS01:0x22:************************************ System ************************************
09:43:41:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
09:43:41:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
09:43:41:WU01:FS01:0x22: CPUs: 8
09:43:41:WU01:FS01:0x22: Memory: 15.95GiB
09:43:41:WU01:FS01:0x22:Free Memory: 12.31GiB
09:43:41:WU01:FS01:0x22: Threads: WINDOWS_THREADS
09:43:41:WU01:FS01:0x22: OS Version: 6.2
09:43:41:WU01:FS01:0x22:Has Battery: false
09:43:41:WU01:FS01:0x22: On Battery: false
09:43:41:WU01:FS01:0x22: UTC Offset: -4
09:43:41:WU01:FS01:0x22: PID: 6640
09:43:41:WU01:FS01:0x22: CWD: C:\Users\phil\AppData\Roaming\FAHClient\work
09:43:41:WU01:FS01:0x22:********************************************************************************
09:43:41:WU01:FS01:0x22:Project: 11745 (Run 0, Clone 3074, Gen 170)
09:43:41:WU01:FS01:0x22:Unit: 0x000001078ca304f15e6a0afe286a2662
09:43:41:WU01:FS01:0x22:Reading tar file core.xml
09:43:41:WU01:FS01:0x22:Reading tar file integrator.xml
09:43:41:WU01:FS01:0x22:Reading tar file state.xml
09:43:42:WU01:FS01:0x22:Reading tar file system.xml
09:43:43:WU01:FS01:0x22:Digital signatures verified
09:43:43:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
09:43:43:WU01:FS01:0x22:Version 0.0.10
09:43:43:WU01:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
09:43:43:WU01:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
09:43:43:WU01:FS01:0x22: XTC frame write interval: 50000 steps (5%) [20 total]
09:43:43:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
09:43:47:WU02:FS01:Upload 40.96%
09:43:53:WU02:FS01:Upload 84.90%
09:43:56:WU02:FS01:Upload complete
09:43:56:WU02:FS01:Server responded WORK_ACK (400)
09:43:56:WU02:FS01:Final credit estimate, 105211.00 points
09:43:56:WU02:FS01:Cleaning up
09:44:07:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
0
12:05:01:WU01:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
12:07:08:WU01:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
12:07:13:WU00:FS02:0x22:Completed 1260000 out of 2000000 steps (63%)
12:09:15:WU01:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
12:09:34:WU00:FS02:0x22:Completed 1280000 out of 2000000 steps (64%)
12:11:23:WU01:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
12:11:55:WU00:FS02:0x22:Completed 1300000 out of 2000000 steps (65%)
******************************* Date: 2020-06-24 *******************************
12:13:30:WU01:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
12:14:17:WU00:FS02:0x22:Completed 1320000 out of 2000000 steps (66%)
12:15:38:WU01:FS01:0x22:Completed 710000 out of 1000000 steps (71%)
12:16:38:WU00:FS02:0x22:Completed 1340000 out of 2000000 steps (67%)
12:17:46:WU01:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
12:18:59:WU00:FS02:0x22:Completed 1360000 out of 2000000 steps (68%)
12:19:53:WU01:FS01:0x22:Completed 730000 out of 1000000 steps (73%)
12:21:20:WU00:FS02:0x22:Completed 1380000 out of 2000000 steps (69%)
12:22:00:WU01:FS01:0x22:Completed 740000 out of 1000000 steps (74%)
12:23:41:WU00:FS02:0x22:Completed 1400000 out of 2000000 steps (70%)
12:24:08:WU01:FS01:0x22:Completed 750000 out of 1000000 steps (75%)
12:26:03:WU00:FS02:0x22:Completed 1420000 out of 2000000 steps (71%)
12:26:16:WU01:FS01:0x22:Completed 760000 out of 1000000 steps (76%)
12:28:23:WU01:FS01:0x22:Completed 770000 out of 1000000 steps (77%)
12:28:24:WU00:FS02:0x22:Completed 1440000 out of 2000000 steps (72%)
12:30:31:WU01:FS01:0x22:Completed 780000 out of 1000000 steps (78%)
12:30:45:WU00:FS02:0x22:Completed 1460000 out of 2000000 steps (73%)
12:32:38:WU01:FS01:0x22:Completed 790000 out of 1000000 steps (79%)
12:33:06:WU00:FS02:0x22:Completed 1480000 out of 2000000 steps (74%)
12:34:45:WU01:FS01:0x22:Completed 800000 out of 1000000 steps (80%)
12:35:27:WU00:FS02:0x22:Completed 1500000 out of 2000000 steps (75%)
12:36:54:WU01:FS01:0x22:Completed 810000 out of 1000000 steps (81%)
12:37:48:WU00:FS02:0x22:Completed 1520000 out of 2000000 steps (76%)
12:39:01:WU01:FS01:0x22:Completed 820000 out of 1000000 steps (82%)
12:40:09:WU00:FS02:0x22:Completed 1540000 out of 2000000 steps (77%)
12:41:08:WU01:FS01:0x22:Completed 830000 out of 1000000 steps (83%)
12:42:30:WU00:FS02:0x22:Completed 1560000 out of 2000000 steps (78%)
12:43:16:WU01:FS01:0x22:Completed 840000 out of 1000000 steps (84%)
12:44:51:WU00:FS02:0x22:Completed 1580000 out of 2000000 steps (79%)
12:45:23:WU01:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
12:47:12:WU00:FS02:0x22:Completed 1600000 out of 2000000 steps (80%)
12:47:32:WU01:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
12:49:34:WU00:FS02:0x22:Completed 1620000 out of 2000000 steps (81%)
12:49:39:WU01:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
12:51:47:WU01:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
12:51:55:WU00:FS02:0x22:Completed 1640000 out of 2000000 steps (82%)
12:53:54:WU01:FS01:0x22:Completed 890000 out of 1000000 steps (89%)
12:54:16:WU00:FS02:0x22:Completed 1660000 out of 2000000 steps (83%)
12:56:01:WU01:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
12:56:37:WU00:FS02:0x22:Completed 1680000 out of 2000000 steps (84%)
12:58:10:WU01:FS01:0x22:Completed 910000 out of 1000000 steps (91%)
12:58:58:WU00:FS02:0x22:Completed 1700000 out of 2000000 steps (85%)
13:00:17:WU01:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
13:01:20:WU00:FS02:0x22:Completed 1720000 out of 2000000 steps (86%)
13:02:24:WU01:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
13:03:41:WU00:FS02:0x22:Completed 1740000 out of 2000000 steps (87%)
13:04:32:WU01:FS01:0x22:Completed 940000 out of 1000000 steps (94%)
13:06:02:WU00:FS02:0x22:Completed 1760000 out of 2000000 steps (88%)
13:06:39:WU01:FS01:0x22:Completed 950000 out of 1000000 steps (95%)
13:08:23:WU00:FS02:0x22:Completed 1780000 out of 2000000 steps (89%)
13:08:48:WU01:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
13:10:44:WU00:FS02:0x22:Completed 1800000 out of 2000000 steps (90%)
13:10:55:WU01:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
13:13:02:WU01:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
13:13:05:WU00:FS02:0x22:Completed 1820000 out of 2000000 steps (91%)
13:15:10:WU01:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
13:15:10:WU02:FS01:Connecting to assign1.foldingathome.org:80
13:15:10:WU02:FS01:Assigned to work server 13.82.98.119
13:15:10:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 970] 3494 from 13.82.98.119
13:15:10:WU02:FS01:Connecting to 13.82.98.119:8080
13:15:12:WU02:FS01:Downloading 131.47MiB
13:15:18:WU02:FS01:Download 47.16%
13:15:24:WU02:FS01:Download 90.66%
13:15:25:WU02:FS01:Download complete
13:15:25:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14415 run:0 clone:1031 gen:105 core:0x22 unit:0x000000ad0d5262775e839e5c28744026
13:15:27:WU00:FS02:0x22:Completed 1840000 out of 2000000 steps (92%)
13:17:17:WU01:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
13:17:17:WU01:FS01:0x22:Average performance: 27.1272 ns/day
13:17:22:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
13:17:22:WU01:FS01:0x22:Saving result file checkpointState.xml
13:17:24:WU01:FS01:0x22:Saving result file positions.xtc
13:17:25:WU01:FS01:0x22:Saving result file science.log
13:17:25:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
13:17:26:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:17:26:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11745 run:0 clone:3074 gen:170 core:0x22 unit:0x000001078ca304f15e6a0afe286a2662
13:17:26:WU01:FS01:Uploading 14.66MiB to 140.163.4.241
13:17:26:WU01:FS01:Connecting to 140.163.4.241:8080
13:17:26:WU02:FS01:Starting
13:17:26:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 5568 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
13:17:26:WU02:FS01:Started FahCore on PID 11256
13:17:26:WU02:FS01:Core PID:8124
13:17:26:WU02:FS01:FahCore 0x22 started
13:17:26:WU02:FS01:0x22:*********************** Log Started 2020-06-24T13:17:26Z ***********************
13:17:26:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
13:17:26:WU02:FS01:0x22: Core: Core22
13:17:26:WU02:FS01:0x22: Type: 0x22
13:17:26:WU02:FS01:0x22: Version: 0.0.10
13:17:26:WU02:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:17:26:WU02:FS01:0x22: Copyright: 2020 foldingathome.org
13:17:26:WU02:FS01:0x22: Homepage: https://foldingathome.org/
13:17:26:WU02:FS01:0x22: Date: Jun 16 2020
13:17:26:WU02:FS01:0x22: Time: 14:33:22
13:17:26:WU02:FS01:0x22: Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
13:17:26:WU02:FS01:0x22: Branch: core22-0.0.10
13:17:26:WU02:FS01:0x22: Compiler: Visual C++ 2015
13:17:26:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
13:17:26:WU02:FS01:0x22: Platform: win32 10
13:17:26:WU02:FS01:0x22: Bits: 64
13:17:26:WU02:FS01:0x22: Mode: Release
13:17:26:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
13:17:26:WU02:FS01:0x22: <peastman@stanford.edu>
13:17:26:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 11256 -checkpoint 15
13:17:26:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
13:17:26:WU02:FS01:0x22: 0 -gpu 0
13:17:26:WU02:FS01:0x22:************************************ libFAH ************************************
13:17:26:WU02:FS01:0x22: Date: Jun 15 2020
13:17:26:WU02:FS01:0x22: Time: 18:05:04
13:17:26:WU02:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
13:17:26:WU02:FS01:0x22: Branch: HEAD
13:17:26:WU02:FS01:0x22:************************************ CBang *************************************
13:17:27:WU02:FS01:0x22: Date: Jun 16 2020
13:17:27:WU02:FS01:0x22: Time: 14:31:33
13:17:27:WU02:FS01:0x22: Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
13:17:27:WU02:FS01:0x22: Branch: HEAD
13:17:27:WU02:FS01:0x22: Compiler: Visual C++ 2015
13:17:27:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
13:17:27:WU02:FS01:0x22: Platform: win32 10
13:17:27:WU02:FS01:0x22: Bits: 64
13:17:27:WU02:FS01:0x22: Mode: Release
13:17:27:WU02:FS01:0x22:************************************ System ************************************
13:17:27:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
13:17:27:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
13:17:27:WU02:FS01:0x22: CPUs: 8
13:17:27:WU02:FS01:0x22: Memory: 15.95GiB
13:17:27:WU02:FS01:0x22:Free Memory: 12.59GiB
13:17:27:WU02:FS01:0x22: Threads: WINDOWS_THREADS
13:17:27:WU02:FS01:0x22: OS Version: 6.2
13:17:27:WU02:FS01:0x22:Has Battery: false
13:17:27:WU02:FS01:0x22: On Battery: false
13:17:27:WU02:FS01:0x22: UTC Offset: -4
13:17:27:WU02:FS01:0x22: PID: 8124
13:17:27:WU02:FS01:0x22: CWD: C:\Users\phil\AppData\Roaming\FAHClient\work
13:17:27:WU02:FS01:0x22:********************************************************************************
13:17:27:WU02:FS01:0x22:Project: 14415 (Run 0, Clone 1031, Gen 105)
13:17:27:WU02:FS01:0x22:Unit: 0x000000ad0d5262775e839e5c28744026
13:17:27:WU02:FS01:0x22:Reading tar file core.xml
13:17:27:WU02:FS01:0x22:Reading tar file integrator.xml
13:17:27:WU02:FS01:0x22:Reading tar file state.xml
13:17:27:WU02:FS01:0x22:Reading tar file system.xml
13:17:27:WU02:FS01:0x22:Digital signatures verified
13:17:27:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
13:17:27:WU02:FS01:0x22:Version 0.0.10
13:17:28:WU02:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
13:17:28:WU02:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
13:17:28:WU02:FS01:0x22: XTC frame write interval: 50000 steps (5%) [20 total]
13:17:28:WU02:FS01:0x22: Global context and integrator variables write interval: disabled
13:17:32:WU01:FS01:Upload complete
13:17:32:WU01:FS01:Server responded WORK_ACK (400)
13:17:32:WU01:FS01:Final credit estimate, 48871.00 points
13:17:32:WU01:FS01:Cleaning up
13:17:48:WU00:FS02:0x22:Completed 1860000 out of 2000000 steps (93%)
13:18:28:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
13:20:10:WU00:FS02:0x22:Completed 1880000 out of 2000000 steps (94%)
13:22:31:WU00:FS02:0x22:Completed 1900000 out of 2000000 steps (95%)
13:23:44:WU02:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
13:24:53:WU00:FS02:0x22:Completed 1920000 out of 2000000 steps (96%)
13:27:13:WU00:FS02:0x22:Completed 1940000 out of 2000000 steps (97%)
13:28:57:WU02:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
13:29:34:WU00:FS02:0x22:Completed 1960000 out of 2000000 steps (98%)
13:31:55:WU00:FS02:0x22:Completed 1980000 out of 2000000 steps (99%)
13:31:56:WU01:FS02:Connecting to assign1.foldingathome.org:80
13:31:56:WU01:FS02:Assigned to work server 128.252.203.10
13:31:56:WU01:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:Ellesmere XT [Radeon RX 470/480/570/580/590] from 128.252.203.10
13:31:56:WU01:FS02:Connecting to 128.252.203.10:8080
13:32:00:WU01:FS02:Downloading 5.82MiB
13:32:00:WU01:FS02:Download complete
13:32:00:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11760 run:0 clone:10423 gen:97 core:0x22 unit:0x000000ab80fccb0a5e6f45512c263ee6
13:34:11:WU02:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
13:34:16:WU00:FS02:0x22:Completed 2000000 out of 2000000 steps (100%)
13:34:16:WU00:FS02:0x22:Average performance: 24.5455 ns/day
13:34:19:WU00:FS02:0x22:Saving result file ..\logfile_01.txt
13:34:19:WU00:FS02:0x22:Saving result file checkpointState.xml
13:34:20:WU00:FS02:0x22:Saving result file positions.xtc
13:34:20:WU00:FS02:0x22:Saving result file science.log
13:34:20:WU00:FS02:0x22:Folding@home Core Shutdown: FINISHED_UNIT
13:34:20:WU03:FS02:Starting
13:34:20:WU03:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 706 -lifeline 5568 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
13:34:20:WU03:FS02:Started FahCore on PID 8276
13:34:20:WU03:FS02:Core PID:10560
13:34:20:WU03:FS02:FahCore 0x22 started
13:34:20:WU00:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:34:20:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:11760 run:0 clone:941 gen:89 core:0x22 unit:0x000000aa80fccb0a5e6d7cd26a0dab3d
13:34:20:WU00:FS02:Uploading 5.71MiB to 128.252.203.10
13:34:20:WU00:FS02:Connecting to 128.252.203.10:8080
13:34:21:WU03:FS02:0x22:*********************** Log Started 2020-06-24T13:34:20Z ***********************
13:34:21:WU03:FS02:0x22:*************************** Core22 Folding@home Core ***************************
13:34:21:WU03:FS02:0x22: Core: Core22
13:34:21:WU03:FS02:0x22: Type: 0x22
13:34:21:WU03:FS02:0x22: Version: 0.0.10
13:34:21:WU03:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:34:21:WU03:FS02:0x22: Copyright: 2020 foldingathome.org
13:34:21:WU03:FS02:0x22: Homepage: https://foldingathome.org/
13:34:21:WU03:FS02:0x22: Date: Jun 16 2020
13:34:21:WU03:FS02:0x22: Time: 14:33:22
13:34:21:WU03:FS02:0x22: Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
13:34:21:WU03:FS02:0x22: Branch: core22-0.0.10
13:34:21:WU03:FS02:0x22: Compiler: Visual C++ 2015
13:34:21:WU03:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
13:34:21:WU03:FS02:0x22: Platform: win32 10
13:34:21:WU03:FS02:0x22: Bits: 64
13:34:21:WU03:FS02:0x22: Mode: Release
13:34:21:WU03:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
13:34:21:WU03:FS02:0x22: <peastman@stanford.edu>
13:34:21:WU03:FS02:0x22: Args: -dir 03 -suffix 01 -version 706 -lifeline 8276 -checkpoint 15
13:34:21:WU03:FS02:0x22: -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
13:34:21:WU03:FS02:0x22:************************************ libFAH ************************************
13:34:21:WU03:FS02:0x22: Date: Jun 15 2020
13:34:21:WU03:FS02:0x22: Time: 18:05:04
13:34:21:WU03:FS02:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
13:34:21:WU03:FS02:0x22: Branch: HEAD
13:34:21:WU03:FS02:0x22:************************************ CBang *************************************
13:34:21:WU03:FS02:0x22: Time: 14:31:33
13:34:21:WU03:FS02:0x22: Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
13:34:21:WU03:FS02:0x22:************************************ System ************************************
13:34:21:WU03:FS02:0x22: CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
13:34:21:WU03:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
13:34:21:WU03:FS02:0x22: CPUs: 8
13:34:21:WU03:FS02:0x22: Memory: 15.95GiB
13:34:21:WU03:FS02:0x22:Free Memory: 12.23GiB
13:34:21:WU03:FS02:0x22: Threads: WINDOWS_THREADS
13:34:21:WU03:FS02:0x22: OS Version: 6.2
13:34:21:WU03:FS02:0x22:Has Battery: false
13:34:21:WU03:FS02:0x22: On Battery: false
13:34:21:WU03:FS02:0x22: UTC Offset: -4
13:34:21:WU03:FS02:0x22: PID: 10560
13:34:21:WU03:FS02:0x22: CWD: C:\Users\phil\AppData\Roaming\FAHClient\work
13:34:21:WU03:FS02:0x22:********************************************************************************
13:34:21:WU03:FS02:0x22:Project: 13415 (Run 2495, Clone 0, Gen 1)
13:34:21:WU03:FS02:0x22:Unit: 0x0000000112bc7d9a5ef1ae65b11f839c
13:34:21:WU03:FS02:0x22:Reading tar file core.xml
13:34:21:WU03:FS02:0x22:Reading tar file integrator.xml
13:34:21:WU03:FS02:0x22:Reading tar file state.xml
13:34:21:WU03:FS02:0x22:Reading tar file system.xml
13:34:21:WU03:FS02:0x22:Digital signatures verified
13:34:21:WU03:FS02:0x22:Folding@home GPU Core22 Folding@home Core
13:34:21:WU03:FS02:0x22:Version 0.0.10
13:34:21:WU03:FS02:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
13:34:21:WU03:FS02:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
13:34:21:WU03:FS02:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
13:34:21:WU03:FS02:0x22: Global context and integrator variables write interval: 250 steps (0.025%) [4000 total]
13:34:24:WU00:FS02:Upload complete
13:34:25:WU00:FS02:Server responded WORK_ACK (400)
13:34:25:WU00:FS02:Final credit estimate, 39286.00 points
13:34:25:WU00:FS02:Cleaning up
13:34:28:WU03:FS02:0x22:Completed 0 out of 1000000 steps (0%)
13:35:31:WU03:FS02:0x22:Completed 10000 out of 1000000 steps (1%)
13:36:32:WU03:FS02:0x22:Completed 20000 out of 1000000 steps (2%)
13:37:34:WU03:FS02:0x22:Completed 30000 out of 1000000 steps (3%)
13:38:36:WU03:FS02:0x22:Completed 40000 out of 1000000 steps (4%)
13:39:24:WU02:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
13:39:37:WU03:FS02:0x22:Completed 50000 out of 1000000 steps (5%)
13:40:39:WU03:FS02:0x22:Completed 60000 out of 1000000 steps (6%)
13:41:41:WU03:FS02:0x22:Completed 70000 out of 1000000 steps (7%)
13:42:43:WU03:FS02:0x22:Completed 80000 out of 1000000 steps (8%)
13:43:45:WU03:FS02:0x22:Completed 90000 out of 1000000 steps (9%)
13:44:38:WU02:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
13:44:47:WU03:FS02:0x22:Completed 100000 out of 1000000 steps (10%)
13:45:49:WU03:FS02:0x22:Completed 110000 out of 1000000 steps (11%)
13:46:51:WU03:FS02:0x22:Completed 120000 out of 1000000 steps (12%)
13:47:53:WU03:FS02:0x22:Completed 130000 out of 1000000 steps (13%)
13:48:55:WU03:FS02:0x22:Completed 140000 out of 1000000 steps (14%)
13:49:53:WU02:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
13:49:57:WU03:FS02:0x22:Completed 150000 out of 1000000 steps (15%)
13:50:59:WU03:FS02:0x22:Completed 160000 out of 1000000 steps (16%)
13:52:01:WU03:FS02:0x22:Completed 170000 out of 1000000 steps (17%)
13:53:03:WU03:FS02:0x22:Completed 180000 out of 1000000 steps (18%)
13:54:05:WU03:FS02:0x22:Completed 190000 out of 1000000 steps (19%)
13:55:05:WU02:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
13:55:07:WU03:FS02:0x22:Completed 200000 out of 1000000 steps (20%)
13:56:09:WU03:FS02:0x22:Completed 210000 out of 1000000 steps (21%)
13:57:11:WU03:FS02:0x22:Completed 220000 out of 1000000 steps (22%)
13:58:14:WU03:FS02:0x22:Completed 230000 out of 1000000 steps (23%)
13:59:16:WU03:FS02:0x22:Completed 240000 out of 1000000 steps (24%)
14:00:18:WU03:FS02:0x22:Completed 250000 out of 1000000 steps (25%)
14:00:19:WU02:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
14:01:22:WU03:FS02:0x22:Completed 260000 out of 1000000 steps (26%)
14:02:26:WU03:FS02:0x22:Completed 270000 out of 1000000 steps (27%)
14:03:30:WU03:FS02:0x22:Completed 280000 out of 1000000 steps (28%)
14:04:34:WU03:FS02:0x22:Completed 290000 out of 1000000 steps (29%)
14:05:33:WU02:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
14:05:38:WU03:FS02:0x22:Completed 300000 out of 1000000 steps (30%)
14:06:42:WU03:FS02:0x22:Completed
14:07:46:WU03:FS02:0x22:Completed 320000 out of 1000000 steps (32%)
14:08:51:WU03:FS02:0x22:Completed 330000 out of 1000000 steps (33%)
14:09:55:WU03:FS02:0x22:Completed 340000 out of 1000000 steps (34%)
14:10:46:WU02:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
14:11:01:WU03:FS02:0x22:Completed 350000 out of 1000000 steps (35%)
14:12:05:WU03:FS02:0x22:Completed 360000 out of 1000000 steps (36%)
14:13:10:WU03:FS02:0x22:Completed 370000 out of 1000000 steps (37%)
14:14:14:WU03:FS02:0x22:Completed 380000 out of 1000000 steps (38%)
14:15:19:WU03:FS02:0x22:Completed 390000 out of 1000000 steps (39%)
14:16:02:WU02:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
14:16:24:WU03:FS02:0x22:Completed 400000 out of 1000000 steps (40%)
14:17:28:WU03:FS02:0x22:Completed 410000 out of 1000000 steps (41%)
14:18:33:WU03:FS02:0x22:Completed 420000 out of 1000000 steps (42%)
14:19:37:WU03:FS02:0x22:Completed 430000 out of 1000000 steps (43%)
14:20:42:WU03:FS02:0x22:Completed 440000 out of 1000000 steps (44%)
14:21:15:WU02:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
14:21:47:WU03:FS02:0x22:Completed 450000 out of 1000000 steps (45%)
14:22:51:WU03:FS02:0x22:Completed 460000 out of 1000000 steps (46%)
14:23:56:WU03:FS02:0x22:Completed 470000 out of 1000000 steps (47%)
14:25:00:WU03:FS02:0x22:Completed 480000 out of 1000000 steps (48%)
14:26:05:WU03:FS02:0x22:Completed 490000 out of 1000000 steps (49%)
14:26:28:WU02:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
14:27:10:WU03:FS02:0x22:Completed 500000 out of 1000000 steps (50%)
14:28:12:WU03:FS02:0x22:Completed 510000 out of 1000000 steps (51%)
14:29:15:WU03:FS02:0x22:Completed 520000 out of 1000000 steps (52%)
14:30:19:WU03:FS02:0x22:Completed 530000 out of 1000000 steps (53%)
14:31:22:WU03:FS02:0x22:Completed 540000 out of 1000000 steps (54%)
14:31:41:WU02:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
14:32:25:WU03:FS02:0x22:Completed 550000 out of 1000000 steps (55%)
14:33:28:WU03:FS02:0x22:Completed 560000 out of 1000000 steps (56%)
14:34:31:WU03:FS02:0x22:Completed 570000 out of 1000000 steps (57%)
14:35:35:WU03:FS02:0x22:Completed 580000 out of 1000000 steps (58%)
14:36:38:WU03:FS02:0x22:Completed 590000 out of 1000000 steps (59%)
14:36:54:WU02:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
14:37:41:WU03:FS02:0x22:Completed 600000 out of 1000000 steps (60%)
14:38:45:WU03:FS02:0x22:Completed 610000 out of 1000000 steps (61%)
14:39:49:WU03:FS02:0x22:Completed 620000 out of 1000000 steps (62%)
14:40:52:WU03:FS02:0x22:Completed 630000 out of 1000000 steps (63%)
14:41:55:WU03:FS02:0x22:Completed 640000 out of 1000000 steps (64%)
14:42:09:WU02:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
14:42:59:WU03:FS02:0x22:Completed 650000 out of 1000000 steps (65%)
14:44:03:WU03:FS02:0x22:Completed 660000 out of 1000000 steps (66%)
14:45:06:WU03:FS02:0x22:Completed 670000 out of 1000000 steps (67%)
14:46:10:WU03:FS02:0x22:Completed 680000 out of 1000000 steps (68%)
14:47:14:WU03:FS02:0x22:Completed 690000 out of 1000000 steps (69%)
14:47:22:WU02:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
14:48:17:WU03:FS02:0x22:Completed 700000 out of 1000000 steps (70%)
14:49:21:WU03:FS02:0x22:Completed 710000 out of 1000000 steps (71%)
14:50:25:WU03:FS02:0x22:Completed 720000 out of 1000000 steps (72%)
14:51:28:WU03:FS02:0x22:Completed 730000 out of 1000000 steps (73%)
14:52:32:WU03:FS02:0x22:Completed 740000 out of 1000000 steps (74%)
14:52:35:WU02:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
14:53:35:WU03:FS02:0x22:Completed 750000 out of 1000000 steps (75%)
14:54:41:WU03:FS02:0x22:Completed 760000 out of 1000000 steps (76%)
14:55:46:WU03:FS02:0x22:Completed 770000 out of 1000000 steps (77%)
14:56:52:WU03:FS02:0x22:Completed 780000 out of 1000000 steps (78%)
14:57:48:WU02:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
14:57:58:WU03:FS02:0x22:Completed 790000 out of 1000000 steps (79%)
14:59:04:WU03:FS02:0x22:Completed 800000 out of 1000000 steps (80%)
15:00:09:WU03:FS02:0x22:Completed 810000 out of 1000000 steps (81%)
15:01:15:WU03:FS02:0x22:Completed 820000 out of 1000000 steps (82%)
15:02:21:WU03:FS02:0x22:Completed 830000 out of 1000000 steps (83%)
15:03:01:WU02:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
15:03:28:WU03:FS02:0x22:Completed 840000 out of 1000000 steps (84%)
15:04:33:WU03:FS02:0x22:Completed 850000 out of 1000000 steps (85%)
15:05:40:WU03:FS02:0x22:Completed 860000 out of 1000000 steps (86%)
15:06:45:WU03:FS02:0x22:Completed 870000 out of 1000000 steps (87%)
15:07:51:WU03:FS02:0x22:Completed 880000 out of 1000000 steps (88%)
15:08:17:WU02:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
15:08:58:WU03:FS02:0x22:Completed 890000 out of 1000000 steps (89%)
15:10:04:WU03:FS02:0x22:Completed 900000 out of 1000000 steps (90%)
15:11:09:WU03:FS02:0x22:Completed 910000 out of 1000000 steps (91%)
15:12:15:WU03:FS02:0x22:Completed 920000 out of 1000000 steps (92%)
15:13:21:WU03:FS02:0x22:Completed 930000 out of 1000000 steps (93%)
15:13:30:WU02:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
15:14:28:WU03:FS02:0x22:Completed 940000 out of 1000000 steps (94%)
15:15:34:WU03:FS02:0x22:Completed 950000 out of 1000000 steps (95%)
15:16:40:WU03:FS02:0x22:Completed 960000 out of 1000000 steps (96%)
15:17:46:WU03:FS02:0x22:Completed 970000 out of 1000000 steps (97%)
15:18:43:WU02:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
15:18:52:WU03:FS02:0x22:Completed 980000 out of 1000000 steps (98%)
15:19:58:WU03:FS02:0x22:Completed 990000 out of 1000000 steps (99%)
15:21:05:WU03:FS02:0x22:Completed 1000000 out of 1000000 steps (100%)
15:21:05:WU03:FS02:0x22:Average performance: 261.027 ns/day
15:21:05:WU03:FS02:0x22:Saving result file ..\logfile_01.txt
15:21:05:WU03:FS02:0x22:Saving result file checkpointState.xml
15:21:05:WU03:FS02:0x22:Saving result file globals.csv
15:21:05:WU03:FS02:0x22:Saving result file positions.xtc
15:21:05:WU03:FS02:0x22:Saving result file science.log
15:21:05:WU03:FS02:0x22:Folding@home Core Shutdown: FINISHED_UNIT
15:21:06:WU03:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:21:06:WU03:FS02:Sending unit results: id:03 state:SEND error:NO_ERROR project:13415 run:2495 clone:0 gen:1 core:0x22 unit:0x0000000112bc7d9a5ef1ae65b11f839c
15:21:06:WU03:FS02:Uploading 553.14KiB to 18.188.125.154
15:21:06:WU03:FS02:Connecting to 18.188.125.154:8080
15:21:06:WU01:FS02:Starting
15:21:06:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 5568 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
15:21:06:WU01:FS02:Started FahCore on PID 3004
15:21:06:WU01:FS02:Core PID:11468
15:21:06:WU01:FS02:FahCore 0x22 started
15:21:06:WU03:FS02:Upload complete
15:21:06:WU03:FS02:Server responded WORK_ACK (400)
15:21:06:WU03:FS02:Final credit estimate, 4072.00 points
15:21:06:WU03:FS02:Cleaning up
21:24:05:WU00:FS02:0x22:Completed 190000 out of 500000 steps (38%)
21:26:19:WU02:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
21:27:23:WU00:FS02:0x22:Completed 195000 out of 500000 steps (39%)
21:30:39:WU00:FS02:0x22:Completed 200000 out of 500000 steps (40%)
21:31:36:WU02:FS01:0x22:Completed 940000 out of 1000000 steps (94%)
21:34:00:WU00:FS02:0x22:Completed 205000 out of 500000 steps (41%)
21:36:52:WU02:FS01:0x22:Completed 950000 out of 1000000 steps (95%)
21:37:17:WU00:FS02:0x22:Completed 210000 out of 500000 steps (42%)
21:40:33:WU00:FS02:0x22:Completed 215000 out of 500000 steps (43%)
21:42:11:WU02:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
21:43:50:WU00:FS02:0x22:Completed 220000 out of 500000 steps (44%)
21:47:06:WU00:FS02:0x22:Completed 225000 out of 500000 steps (45%)
21:47:25:WU02:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
21:50:27:WU00:FS02:0x22:Completed 230000 out of 500000 steps (46%)
21:52:39:WU02:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
21:53:43:WU00:FS02:0x22:Completed 235000 out of 500000 steps (47%)
21:57:01:WU00:FS02:0x22:Completed 240000 out of 500000 steps (48%)
21:57:54:WU02:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
21:57:55:WU01:FS01:Connecting to assign1.foldingathome.org:80
21:57:55:WU01:FS01:Assigned to work server 18.188.125.154
21:57:55:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 970] 3494 from 18.188.125.154
21:57:55:WU01:FS01:Connecting to 18.188.125.154:8080
21:57:56:WU01:FS01:Downloading 433.35KiB
21:57:56:WU01:FS01:Download complete
21:57:56:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13415 run:3025 clone:17 gen:1 core:0x22 unit:0x0000000212bc7d9a5ef1ae44871becb8
22:00:17:WU00:FS02:0x22:Completed 245000 out of 500000 steps (49%)
22:03:08:WU02:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
22:03:08:WU02:FS01:0x22:Average performance: 5.4892 ns/day
22:03:19:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
22:03:19:WU02:FS01:0x22:Saving result file checkpointState.xml
22:03:20:WU02:FS01:0x22:Saving result file positions.xtc
22:03:20:WU02:FS01:0x22:Saving result file science.log
22:03:20:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
22:03:21:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:03:21:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:14415 run:0 clone:1031 gen:105 core:0x22 unit:0x000000ad0d5262775e839e5c28744026
22:03:21:WU02:FS01:Uploading 87.80MiB to 13.82.98.119
22:03:21:WU02:FS01:Connecting to 13.82.98.119:8080
22:03:21:WU01:FS01:Starting
22:03:21:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 5568 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
22:03:21:WU01:FS01:Started FahCore on PID 6616
22:03:21:WU01:FS01:Core PID:9296
22:03:21:WU01:FS01:FahCore 0x22 started
22:03:22:WU01:FS01:0x22:*********************** Log Started 2020-06-24T22:03:21Z ***********************
22:03:22:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
22:03:22:WU01:FS01:0x22: Core: Core22
22:03:22:WU01:FS01:0x22: Type: 0x22
22:03:22:WU01:FS01:0x22: Version: 0.0.10
22:03:22:WU01:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:03:22:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
22:03:22:WU01:FS01:0x22: Homepage: https://foldingathome.org/
22:03:22:WU01:FS01:0x22: Date: Jun 16 2020
22:03:22:WU01:FS01:0x22: Time: 14:33:22
22:03:22:WU01:FS01:0x22: Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
22:03:22:WU01:FS01:0x22: Branch: core22-0.0.10
22:03:22:WU01:FS01:0x22: Compiler: Visual C++ 2015
22:03:22:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
22:03:22:WU01:FS01:0x22: Platform: win32 10
22:03:22:WU01:FS01:0x22: Bits: 64
22:03:22:WU01:FS01:0x22: Mode: Release
22:03:22:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
22:03:22:WU01:FS01:0x22: <peastman@stanford.edu>
22:03:22:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 6616 -checkpoint 15
22:03:22:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
22:03:22:WU01:FS01:0x22: 0 -gpu 0
22:03:22:WU01:FS01:0x22:************************************ libFAH ************************************
22:03:22:WU01:FS01:0x22: Date: Jun 15 2020
22:03:22:WU01:FS01:0x22: Time: 18:05:04
22:03:22:WU01:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
22:03:22:WU01:FS01:0x22: Branch: HEAD
22:03:22:WU01:FS01:0x22:************************************ CBang *************************************
22:03:22:WU01:FS01:0x22: Time: 14:31:33
22:03:22:WU01:FS01:0x22: Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
22:03:22:WU01:FS01:0x22:************************************ System ************************************
22:03:22:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
22:03:22:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
22:03:22:WU01:FS01:0x22: CPUs: 8
22:03:22:WU01:FS01:0x22: Memory: 15.95GiB
22:03:22:WU01:FS01:0x22:Free Memory: 11.22GiB
22:03:22:WU01:FS01:0x22: Threads: WINDOWS_THREADS
22:03:22:WU01:FS01:0x22: OS Version: 6.2
22:03:22:WU01:FS01:0x22:Has Battery: false
22:03:22:WU01:FS01:0x22: On Battery: false
22:03:22:WU01:FS01:0x22: UTC Offset: -4
22:03:22:WU01:FS01:0x22: PID: 9296
22:03:22:WU01:FS01:0x22: CWD: C:\Users\phil\AppData\Roaming\FAHClient\work
22:03:22:WU01:FS01:0x22:********************************************************************************
22:03:22:WU01:FS01:0x22:Project: 13415 (Run 3025, Clone 17, Gen 1)
22:03:22:WU01:FS01:0x22:Unit: 0x0000000212bc7d9a5ef1ae44871becb8
22:03:22:WU01:FS01:0x22:Reading tar file core.xml
22:03:22:WU01:FS01:0x22:Reading tar file integrator.xml
22:03:22:WU01:FS01:0x22:Reading tar file state.xml
22:03:22:WU01:FS01:0x22:Reading tar file system.xml
22:03:22:WU01:FS01:0x22:Digital signatures verified
22:03:22:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
22:03:22:WU01:FS01:0x22:Version 0.0.10
22:03:22:WU01:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
22:03:22:WU01:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
22:03:22:WU01:FS01:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
22:03:22:WU01:FS01:0x22: Global context and integrator variables write interval: 250 steps (0.025%) [4000 total]
22:03:27:WU02:FS01:Upload 20.86%
22:03:28:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
22:03:33:WU02:FS01:Upload 44.99%
22:03:34:WU00:FS02:0x22:Completed 250000 out of 500000 steps (50%)
22:03:39:WU02:FS01:Upload 73.32%
22:03:45:WU02:FS01:Upload complete
22:03:45:WU02:FS01:Server responded WORK_ACK (400)
22:03:45:WU02:FS01:Final credit estimate, 131687.00 points
22:03:45:WU02:FS01:Cleaning up
22:04:03:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
22:04:38:WU01:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
22:05:13:WU01:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
22:05:48:WU01:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
22:06:23:WU01:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
22:06:55:WU00:FS02:0x22:Completed 255000 out of 500000 steps (51%)
22:06:58:WU01:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
22:07:34:WU01:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
22:08:09:WU01:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
22:08:44:WU01:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
22:09:19:WU01:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
22:09:54:WU01:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
22:10:12:WU00:FS02:0x22:Completed 260000 out of 500000 steps (52%)
22:10:30:WU01:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
22:11:05:WU01:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
22:11:40:WU01:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
22:12:16:WU01:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
22:12:51:WU01:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
22:13:26:WU01:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
22:13:29:WU00:FS02:0x22:Completed 265000 out of 500000 steps (53%)
22:14:02:WU01:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
22:14:37:WU01:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
22:15:13:WU01:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
22:15:48:WU01:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
22:16:24:WU01:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
22:16:46:WU00:FS02:0x22:Completed 270000 out of 500000 steps (54%)
22:16:59:WU01:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
22:17:34:WU01:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
22:18:10:WU01:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
22:18:50:WU01:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
22:19:29:WU01:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
22:20:02:WU00:FS02:0x22:Completed 275000 out of 500000 steps (55%)
22:20:08:WU01:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
22:20:48:WU01:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
22:21:27:WU01:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
22:22:07:WU01:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
22:22:46:WU01:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
22:23:23:WU00:FS02:0x22:Completed 280000 out of 500000 steps (56%)
22:23:25:WU01:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
22:24:05:WU01:FS01:0x22:Completed 340000 out of 1000000 steps (34%)
22:24:45:WU01:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
22:25:25:WU01:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
22:26:04:WU01:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
22:26:39:WU00:FS02:0x22:Completed 285000 out of 500000 steps (57%)
22:26:44:WU01:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
Total WUs 1,013
Post
by Neil-B » Wed Jun 24, 2020 10:38 pm
If you edit your post, select the log text and then click the code button at the top of the editing window then save your post will have the log in a scroll able window which makes your post more manageable
Posts: 20822 Joined: Thu Nov 29, 2007 10:13 pm
Post
by bruce » Wed Jun 24, 2020 11:30 pm
There is (was) a bug in the AMD drivers
Subject: AMD GPU Error sortShortList on some projects which was present in early versions of FAHCore_22 but which has been fixed in later versions. It happened on any AMD GPU prior to the release of Navi. If you do get that error message, you may need to force and update of FAHCore_22.
Most of the errors on 134xx projects, as has already been stated, are due to the new methodology needed for the COVID Moonshot projects. John Chodera is actively monitoring these projects and regularly makes changes to improve the situation.
cayenne187
Posts: 39 Joined: Thu May 14, 2020 7:56 pm
Hardware configuration: intel i7-4790 3.6ghz 16gb ram win 10 pro GTX970 4gb Radeon RX570 4gb
Post
by cayenne187 » Wed Jun 24, 2020 11:42 pm
and so it seems now it's running stable on my gtx 970 albeit slowly.
thx Neil B. try to remember that.
Total WUs 1,013
cayenne187
Post
by cayenne187 » Thu Jun 25, 2020 2:23 am
John is clearly on this. both gpus running stable now on 13415. Thank you!
Edit by Mod to correct code tags. You need a pair of code tags like these [ code] enclosing data between them.[/code]
09:45:46:WU00:FS02:0x22:Completed 60000 out of 2000000 steps (3%)
09:46:18:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
09:48:08:WU00:FS02:0x22:Completed 80000 out of 2000000 steps (4%)
15:21:06:WU01:FS02:0x22:*********************** Log Started 2020-06-24T15:21:06Z ***********************
15:21:06:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
15:21:06:WU01:FS02:0x22: Core: Core22
15:21:06:WU01:FS02:0x22: Type: 0x22
15:21:06:WU01:FS02:0x22: Version: 0.0.10
15:21:06:WU01:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:21:06:WU01:FS02:0x22: Copyright: 2020 foldingathome.org
15:21:06:WU01:FS02:0x22: Homepage: https://foldingathome.org/
15:21:06:WU01:FS02:0x22: Date: Jun 16 2020
15:21:06:WU01:FS02:0x22: Time: 14:33:22
15:21:06:WU01:FS02:0x22: Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
15:21:06:WU01:FS02:0x22: Branch: core22-0.0.10
15:21:06:WU01:FS02:0x22: Compiler: Visual C++ 2015
15:21:06:WU01:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
15:21:06:WU01:FS02:0x22: Platform: win32 10
15:21:06:WU01:FS02:0x22: Bits: 64
15:21:06:WU01:FS02:0x22: Mode: Release
15:21:06:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:21:06:WU01:FS02:0x22: <peastman@stanford.edu>
15:21:06:WU01:FS02:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 3004 -checkpoint 15
15:21:06:WU01:FS02:0x22: -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
15:21:06:WU01:FS02:0x22:************************************ libFAH ************************************
15:21:06:WU01:FS02:0x22: Date: Jun 15 2020
15:21:06:WU01:FS02:0x22: Time: 18:05:04
15:21:06:WU01:FS02:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
15:21:06:WU01:FS02:0x22: Branch: HEAD
15:21:06:WU01:FS02:0x22:************************************ CBang *************************************
15:21:06:WU01:FS02:0x22: Time: 14:31:33
15:21:06:WU01:FS02:0x22: Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
15:21:06:WU01:FS02:0x22:************************************ System ************************************
15:21:06:WU01:FS02:0x22: CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
15:21:06:WU01:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
15:21:06:WU01:FS02:0x22: CPUs: 8
15:21:06:WU01:FS02:0x22: Memory: 15.95GiB
15:21:06:WU01:FS02:0x22:Free Memory: 12.03GiB
15:21:06:WU01:FS02:0x22: Threads: WINDOWS_THREADS
15:21:06:WU01:FS02:0x22: OS Version: 6.2
15:21:06:WU01:FS02:0x22:Has Battery: false
15:21:06:WU01:FS02:0x22: On Battery: false
15:21:06:WU01:FS02:0x22: UTC Offset: -4
15:21:06:WU01:FS02:0x22: PID: 11468
15:21:06:WU01:FS02:0x22: CWD: C:\Users\phil\AppData\Roaming\FAHClient\work
15:21:06:WU01:FS02:0x22:********************************************************************************
15:21:06:WU01:FS02:0x22:Project: 11760 (Run 0, Clone 10423, Gen 97)
15:21:06:WU01:FS02:0x22:Unit: 0x000000ab80fccb0a5e6f45512c263ee6
15:21:06:WU01:FS02:0x22:Reading tar file core.xml
15:21:06:WU01:FS02:0x22:Reading tar file integrator.xml
15:21:06:WU01:FS02:0x22:Reading tar file state.xml
15:21:06:WU01:FS02:0x22:Reading tar file system.xml
15:21:06:WU01:FS02:0x22:Digital signatures verified
15:21:06:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
15:21:06:WU01:FS02:0x22:Version 0.0.10
15:21:06:WU01:FS02:0x22: Checkpoint write interval: 100000 steps (5%) [20 total]
15:21:06:WU01:FS02:0x22: JSON viewer frame write interval: 20000 steps (1%) [100 total]
15:21:06:WU01:FS02:0x22: XTC frame write interval: 50000 steps (2.5%) [40 total]
15:21:06:WU01:FS02:0x22: Global context and integrator variables write interval: disabled
15:21:25:WU01:FS02:0x22:Completed 0 out of 2000000 steps (0%)
15:23:47:WU01:FS02:0x22:Completed 20000 out of 2000000 steps (1%)
15:23:56:WU02:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
15:26:08:WU01:FS02:0x22:Completed 40000 out of 2000000 steps (2%)
19:07:14:WU01:FS02:0x22:Completed 1920000 out of 2000000 steps (96%)
19:08:56:WU02:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
19:09:35:WU01:FS02:0x22:Completed 1940000 out of 2000000 steps (97%)
19:11:56:WU01:FS02:0x22:Completed 1960000 out of 2000000 steps (98%)
19:14:09:WU02:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
19:14:17:WU01:FS02:0x22:Completed 1980000 out of 2000000 steps (99%)
19:14:18:WU00:FS02:Connecting to assign1.foldingathome.org:80
19:14:18:WU00:FS02:Assigned to work server 206.223.170.146
19:14:18:WU00:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:Ellesmere XT [Radeon RX 470/480/570/580/590] from 206.223.170.146
19:14:18:WU00:FS02:Connecting to 206.223.170.146:8080
19:14:33:WU00:FS02:Downloading 44.88MiB
19:14:39:WU00:FS02:Download 75.06%
19:14:40:WU00:FS02:Download complete
19:14:40:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14253 run:558 clone:2 gen:89 core:0x22 unit:0x00000096cedfaa925eab700fffddc45f
19:16:38:WU01:FS02:0x22:Completed 2000000 out of 2000000 steps (100%)
19:16:38:WU01:FS02:0x22:Average performance: 24.4759 ns/day
19:16:40:WU01:FS02:0x22:Saving result file ..\logfile_01.txt
19:16:40:WU01:FS02:0x22:Saving result file checkpointState.xml
19:16:41:WU01:FS02:0x22:Saving result file positions.xtc
19:16:41:WU01:FS02:0x22:Saving result file science.log
19:16:41:WU01:FS02:0x22:Folding@home Core Shutdown: FINISHED_UNIT
19:16:42:WU01:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:16:42:WU01:FS02:Sending unit results: id:01 state:SEND error:NO_ERROR project:11760 run:0 clone:10423 gen:97 core:0x22 unit:0x000000ab80fccb0a5e6f45512c263ee6
19:16:42:WU01:FS02:Uploading 5.71MiB to 128.252.203.10
19:16:42:WU01:FS02:Connecting to 128.252.203.10:8080
19:16:42:WU00:FS02:Starting
19:16:42:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 5568 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
19:16:42:WU00:FS02:Started FahCore on PID 4212
19:16:42:WU00:FS02:Core PID:4652
19:16:42:WU00:FS02:FahCore 0x22 started
19:16:43:WU00:FS02:0x22:*********************** Log Started 2020-06-24T19:16:42Z ***********************
19:16:43:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
19:16:43:WU00:FS02:0x22: Core: Core22
19:16:43:WU00:FS02:0x22: Type: 0x22
19:16:43:WU00:FS02:0x22: Version: 0.0.10
19:16:43:WU00:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:16:43:WU00:FS02:0x22: Copyright: 2020 foldingathome.org
19:16:43:WU00:FS02:0x22: Homepage: https://foldingathome.org/
19:16:43:WU00:FS02:0x22: Date: Jun 16 2020
19:16:43:WU00:FS02:0x22: Time: 14:33:22
19:16:43:WU00:FS02:0x22: Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
19:16:43:WU00:FS02:0x22: Branch: core22-0.0.10
19:16:43:WU00:FS02:0x22: Compiler: Visual C++ 2015
19:16:43:WU00:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:16:43:WU00:FS02:0x22: Platform: win32 10
19:16:43:WU00:FS02:0x22: Bits: 64
19:16:43:WU00:FS02:0x22: Mode: Release
19:16:43:WU00:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:16:43:WU00:FS02:0x22: <peastman@stanford.edu>
19:16:43:WU00:FS02:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 4212 -checkpoint 15
19:16:43:WU00:FS02:0x22: -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
19:16:43:WU00:FS02:0x22:************************************ libFAH ************************************
19:16:43:WU00:FS02:0x22: Date: Jun 15 2020
19:16:43:WU00:FS02:0x22: Time: 18:05:04
19:16:43:WU00:FS02:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
19:16:43:WU00:FS02:0x22: Branch: HEAD
19:16:43:WU00:FS02:0x22:************************************ CBang *************************************
19:16:43:WU00:FS02:0x22: Time: 14:31:33
19:16:43:WU00:FS02:0x22: Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
19:16:43:WU00:FS02:0x22:************************************ System ************************************
19:16:43:WU00:FS02:0x22: CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
19:16:43:WU00:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
19:16:43:WU00:FS02:0x22: CPUs: 8
19:16:43:WU00:FS02:0x22: Memory: 15.95GiB
19:16:43:WU00:FS02:0x22:Free Memory: 11.72GiB
19:16:43:WU00:FS02:0x22: Threads: WINDOWS_THREADS
19:16:43:WU00:FS02:0x22: OS Version: 6.2
19:16:43:WU00:FS02:0x22:Has Battery: false
19:16:43:WU00:FS02:0x22: On Battery: false
19:16:43:WU00:FS02:0x22: UTC Offset: -4
19:16:43:WU00:FS02:0x22: PID: 4652
19:16:43:WU00:FS02:0x22: CWD: C:\Users\phil\AppData\Roaming\FAHClient\work
19:16:43:WU00:FS02:0x22:********************************************************************************
19:16:43:WU00:FS02:0x22:Project: 14253 (Run 558, Clone 2, Gen 89)
19:16:43:WU00:FS02:0x22:Unit: 0x00000096cedfaa925eab700fffddc45f
19:16:43:WU00:FS02:0x22:Reading tar file core.xml
19:16:43:WU00:FS02:0x22:Reading tar file integrator.xml
19:16:43:WU00:FS02:0x22:Reading tar file state.xml
19:16:44:WU00:FS02:0x22:Reading tar file system.xml
19:16:45:WU00:FS02:0x22:Digital signatures verified
19:16:45:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
19:16:45:WU00:FS02:0x22:Version 0.0.10
19:16:46:WU00:FS02:0x22: Checkpoint write interval: 25000 steps (5%) [20 total]
19:16:46:WU00:FS02:0x22: JSON viewer frame write interval: 5000 steps (1%) [100 total]
19:16:46:WU00:FS02:0x22: XTC frame write interval: 20000 steps (4%) [25 total]
19:16:46:WU00:FS02:0x22: Global context and integrator variables write interval: disabled
19:16:46:WU01:FS02:Upload complete
19:16:46:WU01:FS02:Server responded WORK_ACK (400)
19:16:46:WU01:FS02:Final credit estimate, 47662.00 points
19:16:46:WU01:FS02:Cleaning up
19:18:34:WU00:FS02:0x22:Completed 0 out of 500000 steps (0%)
19:19:23:WU02:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
19:21:55:WU00:FS02:0x22:Completed 5000 out of 500000 steps (1%)
23:03:01:WU01:FS01:0x22:Completed 940000 out of 1000000 steps (94%)
23:03:42:WU01:FS01:0x22:Completed 950000 out of 1000000 steps (95%)
23:04:24:WU01:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
23:05:05:WU01:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
23:05:46:WU01:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
23:06:08:WU00:FS02:0x22:Completed 345000 out of 500000 steps (69%)
23:06:28:WU01:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
23:06:29:WU02:FS01:Connecting to assign1.foldingathome.org:80
23:06:29:WU02:FS01:Assigned to work server 18.188.125.154
23:06:29:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 970] 3494 from 18.188.125.154
23:06:29:WU02:FS01:Connecting to 18.188.125.154:8080
23:06:29:WU02:FS01:Downloading 440.23KiB
23:06:29:WU02:FS01:Download complete
23:06:29:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13415 run:1574 clone:6 gen:1 core:0x22 unit:0x0000000812bc7d9a5ef1ae9da7105671
23:07:09:WU01:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
23:07:09:WU01:FS01:0x22:Average performance: 417.391 ns/day
23:07:10:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
23:07:10:WU01:FS01:0x22:Saving result file checkpointState.xml
23:07:10:WU01:FS01:0x22:Saving result file globals.csv
23:07:10:WU01:FS01:0x22:Saving result file positions.xtc
23:07:10:WU01:FS01:0x22:Saving result file science.log
23:07:10:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
23:07:10:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:07:10:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13415 run:3025 clone:17 gen:1 core:0x22 unit:0x0000000212bc7d9a5ef1ae44871becb8
23:07:10:WU01:FS01:Uploading 551.75KiB to 18.188.125.154
23:07:10:WU01:FS01:Connecting to 18.188.125.154:8080
23:07:10:WU02:FS01:Starting
23:07:10:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 5568 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
23:07:10:WU02:FS01:Started FahCore on PID 3756
23:07:10:WU02:FS01:Core PID:11096
23:07:10:WU02:FS01:FahCore 0x22 started
23:07:11:WU01:FS01:Upload complete
23:07:11:WU01:FS01:Server responded WORK_ACK (400)
23:07:11:WU01:FS01:Final credit estimate, 13960.00 points
23:07:11:WU01:FS01:Cleaning up
23:07:11:WU02:FS01:0x22:*********************** Log Started 2020-06-24T23:07:10Z ***********************
23:07:11:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
23:07:11:WU02:FS01:0x22: Core: Core22
23:07:11:WU02:FS01:0x22: Type: 0x22
23:07:11:WU02:FS01:0x22: Version: 0.0.10
23:07:11:WU02:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:07:11:WU02:FS01:0x22: Copyright: 2020 foldingathome.org
23:07:11:WU02:FS01:0x22: Homepage: https://foldingathome.org/
23:07:11:WU02:FS01:0x22: Date: Jun 16 2020
23:07:11:WU02:FS01:0x22: Time: 14:33:22
23:07:11:WU02:FS01:0x22: Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
23:07:11:WU02:FS01:0x22: Branch: core22-0.0.10
23:07:11:WU02:FS01:0x22: Compiler: Visual C++ 2015
23:07:11:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
23:07:11:WU02:FS01:0x22: Platform: win32 10
23:07:11:WU02:FS01:0x22: Bits: 64
23:07:11:WU02:FS01:0x22: Mode: Release
23:07:11:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:07:11:WU02:FS01:0x22: <peastman@stanford.edu>
23:07:11:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 3756 -checkpoint 15
23:07:11:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
23:07:11:WU02:FS01:0x22: 0 -gpu 0
23:07:11:WU02:FS01:0x22:************************************ libFAH ************************************
23:07:11:WU02:FS01:0x22: Date: Jun 15 2020
23:07:11:WU02:FS01:0x22: Time: 18:05:04
23:07:11:WU02:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
23:07:11:WU02:FS01:0x22: Branch: HEAD
23:07:11:WU02:FS01:0x22:************************************ CBang *************************************
23:07:11:WU02:FS01:0x22: Time: 14:31:33
23:07:11:WU02:FS01:0x22: Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
23:07:11:WU02:FS01:0x22:************************************ System ************************************
23:07:11:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
23:07:11:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
23:07:11:WU02:FS01:0x22: CPUs: 8
23:07:11:WU02:FS01:0x22: Memory: 15.95GiB
23:07:11:WU02:FS01:0x22:Free Memory: 11.18GiB
23:07:11:WU02:FS01:0x22: Threads: WINDOWS_THREADS
23:07:11:WU02:FS01:0x22: OS Version: 6.2
23:07:11:WU02:FS01:0x22:Has Battery: false
23:07:11:WU02:FS01:0x22: On Battery: false
23:07:11:WU02:FS01:0x22: UTC Offset: -4
23:07:11:WU02:FS01:0x22: PID: 11096
23:07:11:WU02:FS01:0x22: CWD: C:\Users\phil\AppData\Roaming\FAHClient\work
23:07:11:WU02:FS01:0x22:********************************************************************************
23:07:11:WU02:FS01:0x22:Project: 13415 (Run 1574, Clone 6, Gen 1)
23:07:11:WU02:FS01:0x22:Unit: 0x0000000812bc7d9a5ef1ae9da7105671
23:07:11:WU02:FS01:0x22:Reading tar file core.xml
23:07:11:WU02:FS01:0x22:Reading tar file integrator.xml
23:07:11:WU02:FS01:0x22:Reading tar file state.xml
23:07:11:WU02:FS01:0x22:Reading tar file system.xml
23:07:11:WU02:FS01:0x22:Digital signatures verified
23:07:11:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
23:07:11:WU02:FS01:0x22:Version 0.0.10
23:07:11:WU02:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
23:07:11:WU02:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
23:07:11:WU02:FS01:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
23:07:11:WU02:FS01:0x22: Global context and integrator variables write interval: 250 steps (0.025%) [4000 total]
23:07:17:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
23:08:58:WU02:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
23:09:24:WU00:FS02:0x22:Completed 350000 out of 500000 steps (70%)
23:10:37:WU02:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
23:12:16:WU02:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
00:38:00:WU00:FS02:0x22:Completed 485000 out of 500000 steps (97%)
00:39:22:WU02:FS01:0x22:Completed 540000 out of 1000000 steps (54%)
00:41:03:WU02:FS01:0x22:Completed 550000 out of 1000000 steps (55%)
00:41:16:WU00:FS02:0x22:Completed 490000 out of 500000 steps (98%)
00:42:45:WU02:FS01:0x22:Completed 560000 out of 1000000 steps (56%)
00:44:27:WU02:FS01:0x22:Completed 570000 out of 1000000 steps (57%)
00:44:32:WU00:FS02:0x22:Completed 495000 out of 500000 steps (99%)
00:44:32:WU01:FS02:Connecting to assign1.foldingathome.org:80
00:44:32:WU01:FS02:Assigned to work server 18.188.125.154
00:44:32:WU01:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:Ellesmere XT [Radeon RX 470/480/570/580/590] from 18.188.125.154
00:44:32:WU01:FS02:Connecting to 18.188.125.154:8080
00:44:34:WU01:FS02:Downloading 436.24KiB
00:44:34:WU01:FS02:Download complete
00:44:34:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13415 run:1729 clone:18 gen:1 core:0x22 unit:0x0000000512bc7d9a5ef1ae9516c941ec
00:46:08:WU02:FS01:0x22:Completed 580000 out of 1000000 steps (58%)
00:47:48:WU00:FS02:0x22:Completed 500000 out of 500000 steps (100%)
00:47:48:WU00:FS02:0x22:Average performance: 3.52653 ns/day
00:47:52:WU02:FS01:0x22:Completed 590000 out of 1000000 steps (59%)
00:48:07:WU00:FS02:0x22:Saving result file ..\logfile_01.txt
00:48:07:WU00:FS02:0x22:Saving result file checkpointState.xml
00:48:12:WU00:FS02:0x22:Saving result file positions.xtc
00:48:13:WU00:FS02:0x22:Saving result file science.log
00:48:13:WU00:FS02:0x22:Folding@home Core Shutdown: FINISHED_UNIT
00:48:14:WU00:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:48:14:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:14253 run:558 clone:2 gen:89 core:0x22 unit:0x00000096cedfaa925eab700fffddc45f
00:48:14:WU00:FS02:Uploading 39.81MiB to 206.223.170.146
00:48:14:WU00:FS02:Connecting to 206.223.170.146:8080
00:48:14:WU01:FS02:Starting
00:48:14:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 5568 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
00:48:14:WU01:FS02:Started FahCore on PID 7640
00:48:14:WU01:FS02:Core PID:10612
00:48:14:WU01:FS02:FahCore 0x22 started
00:48:15:WU01:FS02:0x22:*********************** Log Started 2020-06-25T00:48:14Z ***********************
00:48:15:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
00:48:15:WU01:FS02:0x22: Core: Core22
00:48:15:WU01:FS02:0x22: Type: 0x22
00:48:15:WU01:FS02:0x22: Version: 0.0.10
00:48:15:WU01:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:48:15:WU01:FS02:0x22: Copyright: 2020 foldingathome.org
00:48:15:WU01:FS02:0x22: Homepage: https://foldingathome.org/
00:48:15:WU01:FS02:0x22: Date: Jun 16 2020
00:48:15:WU01:FS02:0x22: Time: 14:33:22
00:48:15:WU01:FS02:0x22: Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
00:48:15:WU01:FS02:0x22: Branch: core22-0.0.10
00:48:15:WU01:FS02:0x22: Compiler: Visual C++ 2015
00:48:15:WU01:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
00:48:15:WU01:FS02:0x22: Platform: win32 10
00:48:15:WU01:FS02:0x22: Bits: 64
00:48:15:WU01:FS02:0x22: Mode: Release
00:48:15:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
00:48:15:WU01:FS02:0x22: <peastman@stanford.edu>
00:48:15:WU01:FS02:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 7640 -checkpoint 15
00:48:15:WU01:FS02:0x22: -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
00:48:15:WU01:FS02:0x22:************************************ libFAH ************************************
00:48:15:WU01:FS02:0x22: Date: Jun 15 2020
00:48:15:WU01:FS02:0x22: Time: 18:05:04
00:48:15:WU01:FS02:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
00:48:15:WU01:FS02:0x22: Branch: HEAD
00:48:15:WU01:FS02:0x22:************************************ CBang *************************************
00:48:15:WU01:FS02:0x22: Time: 14:31:33
00:48:15:WU01:FS02:0x22: Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
00:48:15:WU01:FS02:0x22:************************************ System ************************************
00:48:15:WU01:FS02:0x22: CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
00:48:15:WU01:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:48:15:WU01:FS02:0x22: CPUs: 8
00:48:15:WU01:FS02:0x22: Memory: 15.95GiB
00:48:15:WU01:FS02:0x22:Free Memory: 11.81GiB
00:48:15:WU01:FS02:0x22: Threads: WINDOWS_THREADS
00:48:15:WU01:FS02:0x22: OS Version: 6.2
00:48:15:WU01:FS02:0x22:Has Battery: false
00:48:15:WU01:FS02:0x22: On Battery: false
00:48:15:WU01:FS02:0x22: UTC Offset: -4
00:48:15:WU01:FS02:0x22: PID: 10612
00:48:15:WU01:FS02:0x22: CWD: C:\Users\phil\AppData\Roaming\FAHClient\work
00:48:15:WU01:FS02:0x22:********************************************************************************
00:48:15:WU01:FS02:0x22:Project: 13415 (Run 1729, Clone 18, Gen 1)
00:48:15:WU01:FS02:0x22:Unit: 0x0000000512bc7d9a5ef1ae9516c941ec
00:48:15:WU01:FS02:0x22:Reading tar file core.xml
00:48:15:WU01:FS02:0x22:Reading tar file integrator.xml
00:48:15:WU01:FS02:0x22:Reading tar file state.xml
00:48:15:WU01:FS02:0x22:Reading tar file system.xml
00:48:15:WU01:FS02:0x22:Digital signatures verified
00:48:15:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
00:48:15:WU01:FS02:0x22:Version 0.0.10
00:48:15:WU01:FS02:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
00:48:15:WU01:FS02:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
00:48:15:WU01:FS02:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
00:48:15:WU01:FS02:0x22: Global context and integrator variables write interval: 250 steps (0.025%) [4000 total]
00:48:20:WU00:FS02:Upload 39.56%
00:48:23:WU01:FS02:0x22:Completed 0 out of 1000000 steps (0%)
00:48:26:WU00:FS02:Upload 83.67%
00:48:29:WU00:FS02:Upload complete
00:48:29:WU00:FS02:Server responded WORK_ACK (400)
00:48:29:WU00:FS02:Final credit estimate, 125803.00 points
00:48:29:WU00:FS02:Cleaning up
00:49:25:WU01:FS02:0x22:Completed 10000 out of 1000000 steps (1%)
01:57:43:WU02:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
01:58:00:WU01:FS02:0x22:Completed 660000 out of 1000000 steps (66%)
01:59:03:WU01:FS02:0x22:Completed 670000 out of 1000000 steps (67%)
01:59:34:WU02:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
01:59:35:WU00:FS01:Connecting to assign1.foldingathome.org:80
01:59:35:WU00:FS01:Assigned to work server 18.188.125.154
01:59:35:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 970] 3494 from 18.188.125.154
01:59:35:WU00:FS01:Connecting to 18.188.125.154:8080
01:59:36:WU00:FS01:Downloading 437.29KiB
01:59:36:WU00:FS01:Download complete
01:59:36:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13415 run:1721 clone:19 gen:1 core:0x22 unit:0x0000000412bc7d9a5ef1ae952d1d32de
02:00:06:WU01:FS02:0x22:Completed 680000 out of 1000000 steps (68%)
02:01:09:WU01:FS02:0x22:Completed 690000 out of 1000000 steps (69%)
02:01:23:WU02:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
02:01:23:WU02:FS01:0x22:Average performance: 156.522 ns/day
02:01:23:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
02:01:23:WU02:FS01:0x22:Saving result file checkpointState.xml
02:01:23:WU02:FS01:0x22:Saving result file globals.csv
02:01:23:WU02:FS01:0x22:Saving result file positions.xtc
02:01:23:WU02:FS01:0x22:Saving result file science.log
02:01:24:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
02:01:24:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:01:24:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:13415 run:1574 clone:6 gen:1 core:0x22 unit:0x0000000812bc7d9a5ef1ae9da7105671
02:01:24:WU02:FS01:Uploading 554.76KiB to 18.188.125.154
02:01:24:WU02:FS01:Connecting to 18.188.125.154:8080
02:01:24:WU00:FS01:Starting
02:01:24:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 5568 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
02:01:24:WU00:FS01:Started FahCore on PID 9276
02:01:24:WU00:FS01:Core PID:11616
02:01:24:WU00:FS01:FahCore 0x22 started
02:01:24:WU02:FS01:Upload complete
02:01:24:WU02:FS01:Server responded WORK_ACK (400)
02:01:24:WU02:FS01:Final credit estimate, 8785.00 points
02:01:24:WU02:FS01:Cleaning up
02:01:24:WU00:FS01:0x22:*********************** Log Started 2020-06-25T02:01:24Z ***********************
02:01:24:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
02:01:24:WU00:FS01:0x22: Core: Core22
02:01:24:WU00:FS01:0x22: Type: 0x22
02:01:24:WU00:FS01:0x22: Version: 0.0.10
02:01:24:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:01:24:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
02:01:24:WU00:FS01:0x22: Homepage: https://foldingathome.org/
02:01:25:WU00:FS01:0x22: Date: Jun 16 2020
02:01:25:WU00:FS01:0x22: Time: 14:33:22
02:01:25:WU00:FS01:0x22: Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
02:01:25:WU00:FS01:0x22: Branch: core22-0.0.10
02:01:25:WU00:FS01:0x22: Compiler: Visual C++ 2015
02:01:25:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
02:01:25:WU00:FS01:0x22: Platform: win32 10
02:01:25:WU00:FS01:0x22: Bits: 64
02:01:25:WU00:FS01:0x22: Mode: Release
02:01:25:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
02:01:25:WU00:FS01:0x22: <peastman@stanford.edu>
02:01:25:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 9276 -checkpoint 15
02:01:25:WU00:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
02:01:25:WU00:FS01:0x22: 0 -gpu 0
02:01:25:WU00:FS01:0x22:************************************ libFAH ************************************
02:01:25:WU00:FS01:0x22: Date: Jun 15 2020
02:01:25:WU00:FS01:0x22: Time: 18:05:04
02:01:25:WU00:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
02:01:25:WU00:FS01:0x22: Branch: HEAD
02:01:25:WU00:FS01:0x22:************************************ CBang *************************************
02:01:25:WU00:FS01:0x22: Time: 14:31:33
02:01:25:WU00:FS01:0x22: Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
02:01:25:WU00:FS01:0x22:************************************ System ************************************
02:01:25:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
02:01:25:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
02:01:25:WU00:FS01:0x22: CPUs: 8
02:01:25:WU00:FS01:0x22: Memory: 15.95GiB
02:01:25:WU00:FS01:0x22:Free Memory: 12.31GiB
02:01:25:WU00:FS01:0x22: Threads: WINDOWS_THREADS
02:01:25:WU00:FS01:0x22: OS Version: 6.2
02:01:25:WU00:FS01:0x22:Has Battery: false
02:01:25:WU00:FS01:0x22: On Battery: false
02:01:25:WU00:FS01:0x22: UTC Offset: -4
02:01:25:WU00:FS01:0x22: PID: 11616
02:01:25:WU00:FS01:0x22: CWD: C:\Users\phil\AppData\Roaming\FAHClient\work
02:01:25:WU00:FS01:0x22:********************************************************************************
02:01:25:WU00:FS01:0x22:Project: 13415 (Run 1721, Clone 19, Gen 1)
02:01:25:WU00:FS01:0x22:Unit: 0x0000000412bc7d9a5ef1ae952d1d32de
02:01:25:WU00:FS01:0x22:Reading tar file core.xml
02:01:25:WU00:FS01:0x22:Reading tar file integrator.xml
02:01:25:WU00:FS01:0x22:Reading tar file state.xml
02:01:25:WU00:FS01:0x22:Reading tar file system.xml
02:01:25:WU00:FS01:0x22:Digital signatures verified
02:01:25:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
02:01:25:WU00:FS01:0x22:Version 0.0.10
02:01:25:WU00:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
02:01:25:WU00:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
02:01:25:WU00:FS01:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
02:01:25:WU00:FS01:0x22: Global context and integrator variables write interval: 250 steps (0.025%) [4000 total]
02:09:59:WU00:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
02:10:36:WU00:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
02:10:43:WU01:FS02:0x22:Completed 780000 out of 1000000 steps (78%)
Date of last Work Unit 2020-08-04 22:17:53
Total score 63,300,083
Total WUs 1,013
Overall rank (if points are combined) 15,440 of 2,735,299
cayenne187
Post
by cayenne187 » Thu Jun 25, 2020 3:05 am
crashed again!
02:55:33:WU00:FS01:0x22:Completed 830000 out of 1000000 steps (83%)
02:56:15:WU00:FS01:0x22:Completed 840000 out of 1000000 steps (84%)
02:56:58:WU00:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
02:57:40:WU00:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
02:58:22:WU00:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
02:59:04:WU00:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
02:59:47:WU00:FS01:0x22:Completed 890000 out of 1000000 steps (89%)
03:00:30:WU00:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
03:01:13:WU00:FS01:0x22:Completed 910000 out of 1000000 steps (91%)
03:01:56:WU00:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
03:02:06:WARNING:WU01:FS02:FahCore returned an unknown error code which probably indicates that it crashed
03:02:06:WARNING:WU01:FS02:FahCore returned: UNKNOWN_ENUM (-1073740940 = 0xc0000374)
03:02:06:WU02:FS02:Starting
03:02:06:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 5568 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
03:02:06:WU02:FS02:Started FahCore on PID 6800
03:02:06:WU02:FS02:Core PID:8356
03:02:06:WU02:FS02:FahCore 0x22 started
03:02:07:WU02:FS02:0x22:*********************** Log Started 2020-06-25T03:02:06Z ***********************
03:02:07:WU02:FS02:0x22:*************************** Core22 Folding@home Core ***************************
03:02:07:WU02:FS02:0x22: Core: Core22
03:02:07:WU02:FS02:0x22: Type: 0x22
03:02:07:WU02:FS02:0x22: Version: 0.0.10
03:02:07:WU02:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:02:07:WU02:FS02:0x22: Copyright: 2020 foldingathome.org
03:02:07:WU02:FS02:0x22: Homepage: https://foldingathome.org/
03:02:07:WU02:FS02:0x22: Date: Jun 16 2020
03:02:07:WU02:FS02:0x22: Time: 14:33:22
03:02:07:WU02:FS02:0x22: Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
03:02:07:WU02:FS02:0x22: Branch: core22-0.0.10
03:02:07:WU02:FS02:0x22: Compiler: Visual C++ 2015
03:02:07:WU02:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
03:02:07:WU02:FS02:0x22: Platform: win32 10
03:02:07:WU02:FS02:0x22: Bits: 64
03:02:07:WU02:FS02:0x22: Mode: Release
03:02:07:WU02:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
03:02:07:WU02:FS02:0x22: <peastman@stanford.edu>
03:02:07:WU02:FS02:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 6800 -checkpoint 15
03:02:07:WU02:FS02:0x22: -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
03:02:07:WU02:FS02:0x22:************************************ libFAH ************************************
03:02:07:WU02:FS02:0x22: Date: Jun 15 2020
03:02:07:WU02:FS02:0x22: Time: 18:05:04
03:02:07:WU02:FS02:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
03:02:07:WU02:FS02:0x22: Branch: HEAD
03:02:07:WU02:FS02:0x22:************************************ CBang *************************************
03:02:07:WU02:FS02:0x22: Time: 14:31:33
03:02:07:WU02:FS02:0x22: Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
03:02:07:WU02:FS02:0x22:************************************ System ************************************
03:02:07:WU02:FS02:0x22: CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
03:02:07:WU02:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
03:02:07:WU02:FS02:0x22: CPUs: 8
03:02:07:WU02:FS02:0x22: Memory: 15.95GiB
03:02:07:WU02:FS02:0x22:Free Memory: 11.74GiB
03:02:07:WU02:FS02:0x22: Threads: WINDOWS_THREADS
03:02:07:WU02:FS02:0x22: OS Version: 6.2
03:02:07:WU02:FS02:0x22:Has Battery: false
03:02:07:WU02:FS02:0x22: On Battery: false
03:02:07:WU02:FS02:0x22: UTC Offset: -4
03:02:07:WU02:FS02:0x22: PID: 8356
03:02:07:WU02:FS02:0x22: CWD: C:\Users\phil\AppData\Roaming\FAHClient\work
03:02:07:WU02:FS02:0x22:********************************************************************************
03:02:07:WU02:FS02:0x22:Project: 13415 (Run 1156, Clone 20, Gen 0)
03:02:07:WU02:FS02:0x22:Unit: 0x0000000012bc7d9a5ef19f5694f7a61c
03:02:07:WU02:FS02:0x22:Reading tar file core.xml
03:02:07:WU02:FS02:0x22:Reading tar file integrator.xml
03:02:07:WU02:FS02:0x22:Reading tar file state.xml
03:02:07:WU02:FS02:0x22:Reading tar file system.xml
03:02:07:WU02:FS02:0x22:Digital signatures verified
03:02:07:WU02:FS02:0x22:Folding@home GPU Core22 Folding@home Core
03:02:07:WU02:FS02:0x22:Version 0.0.10
03:02:07:WU02:FS02:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
03:02:07:WU02:FS02:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
03:02:07:WU02:FS02:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
03:02:07:WU02:FS02:0x22: Global context and integrator variables write interval: 250 steps (0.025%) [4000 total]
03:02:14:WU02:FS02:0x22:Completed 0 out of 1000000 steps (0%)
03:02:39:WU00:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
Total WUs 1,013
