(AWS3) 10002: Rcvd short response, expected 512 bytes, got 0
Hi All,
I'm new to the forum, but been folding 24/7 since Covid with a 1080Ti.
Over past week or so, I've been seeing a lot of WUs that have been having trouble sending... after restarting the client many times they seem to go eventually, but take a lot of retries. I've also recently upgraded to v7.6.13, perhaps about the same time this problem started, but can't say for sure.
So even with the windows firewall and anti-virus disabled, I still get this message in the log when WU's are trying to upload:
WARNING:WU04:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
I've currently got 2 in my queue waiting to send to two different servers.
Any clues to help me out here?
Cheers,
wiLik
Cheers,
wiLik
Re: 10002: Received short response, expected 512 bytes, got
Can you please post more of the log, see how to post a log file under viewtopic.php?f=61&t=26036 for various operating systems.
Are you behind a firewall, or running some sort of anti-malware software?
You have already tried the first two things to check, firewall and AV. Are other WUs uploading okay, with just some WUs having trouble uploading and getting this message?
Could you post the preceding messages from the log that show which WU is being uploaded and which server address(es) it is trying. It could point to a problem with the WU or the server that can be checked on.
Other things that can cause the "Received short response" can be a router, either on your network or between you and the server, either blocking or dropping some of the transfer.
Quick update:
Another WU just finished and was sent fine first time! But I regularly get back to my PC and see many WU's, perhaps 8 or so in the queue when I restart the client to 'give them a kick'.
I currently have the windows firewall and my antivirus/malware disabled (Avast), but am obviously still behind my router firewall.
Log below:
Log below:
*********************** Log Started 2020-06-20T21:30:55Z ***********************
21:30:55:Trying to access database...
21:30:55:Successfully acquired database lock
21:30:55:Read GPUs.txt
21:30:56:Enabled folding slot 01: PAUSED gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 (by user)
21:30:56:****************************** FAHClient ******************************
21:30:56: Version: 7.6.13
21:30:56: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:30:56: Copyright: 2020 foldingathome.org
21:30:56: Homepage: https://foldingathome.org/
21:30:56: Date: Apr 27 2020
21:30:56: Time: 21:21:01
21:30:56: Revision: 5a652817f46116b6e135503af97f18e094414e3b
21:30:56: Branch: master
21:30:56: Compiler: Visual C++ 2008
21:30:56: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:30:56: Platform: win32 10
21:30:56: Bits: 32
21:30:56: Mode: Release
21:30:56: Args: --open-web-control
21:30:56: Config: C:\Users\Administrator\AppData\Roaming\FAHClient\config.xml
21:30:56:******************************** CBang ********************************
21:30:56: Date: Apr 24 2020
21:30:56: Time: 17:07:55
21:30:56: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
21:30:56: Bits: 32
21:30:56:******************************* System ********************************
21:30:56: CPU: Intel(R) Core(TM) i7-7820X CPU @ 3.60GHz
21:30:56: CPU ID: GenuineIntel Family 6 Model 85 Stepping 4
21:30:56: CPUs: 16
21:30:56: Memory: 31.69GiB
21:30:56: Free Memory: 25.38GiB
21:30:56: Threads: WINDOWS_THREADS
21:30:56: OS Version: 6.2
21:30:56: Has Battery: false
21:30:56: On Battery: false
21:30:56: UTC Offset: 1
21:30:56: PID: 12468
21:30:56: CWD: C:\Users\Administrator\AppData\Roaming\FAHClient
21:30:56: Win32 Service: false
21:30:56: OS: Windows 10 Enterprise
21:30:56: OS Arch: AMD64
21:30:56: GPUs: 1
21:30:56: GPU 0: Bus:101 Slot:0 Func:0 NVIDIA:8 GP102 [GeForce GTX 1080 Ti]
21:30:56: 11380
21:30:56: CUDA Device 0: Platform:0 Device:0 Bus:101 Slot:0 Compute:6.1 Driver:11.0
21:30:56:OpenCL Device 0: Platform:0 Device:0 Bus:101 Slot:0 Compute:1.2 Driver:445.87
21:30:56:******************************* libFAH ********************************
21:30:56: Date: Apr 15 2020
21:30:56: Time: 14:53:14
21:30:56: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
21:30:56: Bits: 32
21:30:56:***********************************************************************
21:30:56:<config>
21:30:56: <!-- Folding Slot Configuration -->
21:30:56: <cause v='COVID_19'/>
21:30:56: <client-type v='advanced'/>
21:30:56:
21:30:56: <!-- Network -->
21:30:56: <proxy v=':8080'/>
21:30:56:
21:30:56: <!-- Slot Control -->
21:30:56: <power v='full'/>
21:30:56:
21:30:56: <!-- User Information -->
21:30:56: <passkey v='*****'/>
21:30:56: <team v='223518'/>
21:30:56: <user v='wiLik'/>
21:30:56:
21:30:56: <!-- Work Unit Control -->
21:30:56: <next-unit-percentage v='90'/>
21:30:56:
21:30:56: <!-- Folding Slots -->
21:30:56: <slot id='1' type='GPU'>
21:30:56: <paused v='true'/>
21:30:56: </slot>
21:30:56:</config>
21:30:56:WU04:FS01:Sending unit results: id:04 state:SEND error:NO_ERROR project:16448 run:0 clone:1025 gen:78 core:0x22 unit:0x0000007342aa6f325ed18ce214e7a6d6
21:30:56:WU04:FS01:Uploading 42.37MiB to 66.170.111.50
21:30:56:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:14447 run:0 clone:918 gen:57 core:0x22 unit:0x0000005503854c135ea7b89038655b40
21:30:56:WU04:FS01:Connecting to 66.170.111.50:8080
21:30:56:WU02:FS01:Uploading 94.92MiB to 3.133.76.19
21:30:56:WU02:FS01:Connecting to 3.133.76.19:8080
21:30:58:15:127.0.0.1:New Web session
21:31:02:WU04:FS01:Upload 21.10%
21:31:02:WU02:FS01:Upload 8.76%
21:31:08:WU04:FS01:Upload 38.06%
21:31:08:WU02:FS01:Upload 21.40%
21:31:08:FS01:Unpaused
21:31:08:WU00:FS01:Starting
21:31:08:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Administrator\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 706 -lifeline 12468 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:31:08:WU00:FS01:Started FahCore on PID 3484
21:31:08:WU00:FS01:Core PID:3960
21:31:08:WU00:FS01:FahCore 0x21 started
21:31:09:WU00:FS01:0x21:*********************** Log Started 2020-06-20T21:31:09Z ***********************
21:31:09:WU00:FS01:0x21:Project: 16906 (Run 17, Clone 27, Gen 26)
21:31:09:WU00:FS01:0x21:Unit: 0x000000290002894c5ecb32b3a03895cb
21:31:09:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
21:31:09:WU00:FS01:0x21:Machine: 1
21:31:09:WU00:FS01:0x21:Digital signatures verified
21:31:09:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
21:31:09:WU00:FS01:0x21:Version 0.0.20
21:31:09:WU00:FS01:0x21: Found a checkpoint file
21:31:11:WU00:FS01:0x21:Completed 500000 out of 10000000 steps (5%)
21:31:11:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:31:14:WU02:FS01:Upload 32.53%
21:31:14:WU04:FS01:Upload 54.88%
21:31:20:WU02:FS01:Upload 44.25%
21:31:20:WU04:FS01:Upload 72.28%
21:31:26:WU02:FS01:Upload 55.58%
21:31:26:WU04:FS01:Upload 89.10%
21:31:32:WU02:FS01:Upload 67.10%
21:31:38:WU02:FS01:Upload 77.96%
21:31:44:WU02:FS01:Upload 88.89%
21:31:50:WU02:FS01:Upload 99.76%
21:31:56:Removing old file 'configs/config-20200617-074144.xml'
21:31:56:Saving configuration to config.xml
21:31:56:<config>
21:31:56: <!-- Folding Slot Configuration -->
21:31:56: <cause v='COVID_19'/>
21:31:56: <client-type v='advanced'/>
21:31:56:
21:31:56: <!-- Network -->
21:31:56: <proxy v=':8080'/>
21:31:56:
21:31:56: <!-- Slot Control -->
21:31:56: <power v='full'/>
21:31:56:
21:31:56: <!-- User Information -->
21:31:56: <passkey v='*****'/>
21:31:56: <team v='223518'/>
21:31:56: <user v='wiLik'/>
21:31:56:
21:31:56: <!-- Work Unit Control -->
21:31:56: <next-unit-percentage v='90'/>
21:31:56:
21:31:56: <!-- Folding Slots -->
21:31:56: <slot id='1' type='GPU'/>
21:31:56:</config>
21:32:03:WARNING:WU04:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
21:32:03:WU04:FS01:Trying to send results to collection server
21:32:03:WU04:FS01:Uploading 42.37MiB to 18.188.125.154
21:32:03:WU04:FS01:Connecting to 18.188.125.154:8080
21:32:09:WU04:FS01:Upload 28.03%
21:32:15:WU04:FS01:Upload 52.37%
21:32:21:WU04:FS01:Upload 77.15%
21:32:22:WARNING:WU02:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
21:32:22:WU02:FS01:Trying to send results to collection server
21:32:22:WU02:FS01:Uploading 94.92MiB to 3.21.157.11
21:32:22:WU02:FS01:Connecting to 3.21.157.11:8080
21:32:28:WU02:FS01:Upload 12.12%
21:32:34:WU02:FS01:Upload 24.17%
21:32:40:WU02:FS01:Upload 36.02%
21:32:46:WU02:FS01:Upload 47.61%
21:32:47:WU00:FS01:0x21:Completed 600000 out of 10000000 steps (6%)
21:32:52:WU02:FS01:Upload 59.39%
21:32:58:WU02:FS01:Upload 71.18%
21:32:58:ERROR:WU04:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:32:58:WU04:FS01:Sending unit results: id:04 state:SEND error:NO_ERROR project:16448 run:0 clone:1025 gen:78 core:0x22 unit:0x0000007342aa6f325ed18ce214e7a6d6
21:32:58:WU04:FS01:Uploading 42.37MiB to 66.170.111.50
21:32:58:WU04:FS01:Connecting to 66.170.111.50:8080
21:33:04:WU04:FS01:Upload 11.06%
21:33:04:WU02:FS01:Upload 82.84%
21:33:10:WU04:FS01:Upload 29.50%
21:33:10:WU02:FS01:Upload 94.49%
21:33:16:WU04:FS01:Upload 46.76%
21:33:22:WU04:FS01:Upload 63.73%
21:33:28:WU04:FS01:Upload 80.84%
21:33:34:WU04:FS01:Upload 97.66%
21:33:44:ERROR:WU02:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:33:44:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:14447 run:0 clone:918 gen:57 core:0x22 unit:0x0000005503854c135ea7b89038655b40
21:33:44:WU02:FS01:Uploading 94.92MiB to 3.133.76.19
21:33:44:WU02:FS01:Connecting to 3.133.76.19:8080
21:33:50:WU02:FS01:Upload 8.76%
21:33:56:WU02:FS01:Upload 21.66%
21:34:02:WU02:FS01:Upload 32.73%
21:34:06:WARNING:WU04:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
21:34:06:WU04:FS01:Trying to send results to collection server
21:34:06:WU04:FS01:Uploading 42.37MiB to 18.188.125.154
21:34:06:WU04:FS01:Connecting to 18.188.125.154:8080
21:34:08:WU02:FS01:Upload 43.99%
21:34:12:WU04:FS01:Upload 16.96%
21:34:14:WU02:FS01:Upload 55.11%
21:34:18:WU04:FS01:Upload 36.88%
21:34:20:WU02:FS01:Upload 66.77%
21:34:21:WU00:FS01:0x21:Completed 700000 out of 10000000 steps (7%)
21:34:24:WU04:FS01:Upload 49.27%
21:34:26:WU02:FS01:Upload 77.44%
21:34:30:WU04:FS01:Upload 67.42%
21:34:32:WU02:FS01:Upload 88.76%
21:34:36:WU04:FS01:Upload 93.67%
21:34:38:WU02:FS01:Upload 97.85%
21:35:09:ERROR:WU04:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:35:09:WU04:FS01:Sending unit results: id:04 state:SEND error:NO_ERROR project:16448 run:0 clone:1025 gen:78 core:0x22 unit:0x0000007342aa6f325ed18ce214e7a6d6
21:35:09:WU04:FS01:Uploading 42.37MiB to 66.170.111.50
21:35:09:WU04:FS01:Connecting to 66.170.111.50:8080
21:35:12:WARNING:WU02:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
21:35:12:WU02:FS01:Trying to send results to collection server
21:35:12:WU02:FS01:Uploading 94.92MiB to 3.21.157.11
21:35:12:WU02:FS01:Connecting to 3.21.157.11:8080
21:35:15:WU04:FS01:Upload 16.67%
21:35:18:WU02:FS01:Upload 8.43%
21:35:21:WU04:FS01:Upload 33.04%
21:35:24:WU02:FS01:Upload 20.35%
21:35:27:WU04:FS01:Upload 48.68%
21:35:30:WU02:FS01:Upload 32.00%
21:35:33:WU04:FS01:Upload 65.79%
21:35:36:WU02:FS01:Upload 43.33%
21:35:39:WU04:FS01:Upload 82.76%
21:35:42:WU02:FS01:Upload 55.05%
21:35:45:WU04:FS01:Upload 96.18%
21:35:48:WU02:FS01:Upload 64.60%
21:35:54:WU02:FS01:Upload 76.12%
21:35:57:WU00:FS01:0x21:Completed 800000 out of 10000000 steps (8%)
21:36:00:WU02:FS01:Upload 86.79%
21:36:06:WU02:FS01:Upload 98.05%
21:36:19:WARNING:WU04:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
21:36:19:WU04:FS01:Trying to send results to collection server
21:36:19:WU04:FS01:Uploading 42.37MiB to 18.188.125.154
21:36:19:WU04:FS01:Connecting to 18.188.125.154:8080
21:36:25:WU04:FS01:Upload 21.54%
21:36:31:WU04:FS01:Upload 49.57%
21:36:37:WU04:FS01:Upload 74.20%
21:36:38:ERROR:WU02:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:36:38:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:14447 run:0 clone:918 gen:57 core:0x22 unit:0x0000005503854c135ea7b89038655b40
21:36:38:WU02:FS01:Uploading 94.92MiB to 3.133.76.19
21:36:38:WU02:FS01:Connecting to 3.133.76.19:8080
21:36:43:WU04:FS01:Upload 98.98%
21:36:44:WU02:FS01:Upload 6.98%
21:36:50:WU02:FS01:Upload 19.43%
21:36:56:WU02:FS01:Upload 30.88%
21:37:02:WU02:FS01:Upload 42.08%
21:37:08:WU02:FS01:Upload 53.14%
21:37:14:WU02:FS01:Upload 64.60%
21:37:15:ERROR:WU04:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:37:20:WU02:FS01:Upload 76.12%
21:37:26:WU02:FS01:Upload 87.38%
21:37:31:WU00:FS01:0x21:Completed 900000 out of 10000000 steps (9%)
21:37:32:WU02:FS01:Upload 98.71%
21:37:46:WU04:FS01:Sending unit results: id:04 state:SEND error:NO_ERROR project:16448 run:0 clone:1025 gen:78 core:0x22 unit:0x0000007342aa6f325ed18ce214e7a6d6
21:37:46:WU04:FS01:Uploading 42.37MiB to 66.170.111.50
21:37:46:WU04:FS01:Connecting to 66.170.111.50:8080
21:37:52:WU04:FS01:Upload 15.78%
21:37:58:WU04:FS01:Upload 35.40%
21:38:04:WU04:FS01:Upload 51.93%
21:38:04:WARNING:WU02:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
21:38:04:WU02:FS01:Trying to send results to collection server
21:38:04:WU02:FS01:Uploading 94.92MiB to 3.21.157.11
21:38:04:WU02:FS01:Connecting to 3.21.157.11:8080
21:38:10:WU02:FS01:Upload 11.19%
21:38:10:WU04:FS01:Upload 69.48%
21:38:16:WU04:FS01:Upload 86.30%
21:38:16:WU02:FS01:Upload 22.91%
21:38:22:WU02:FS01:Upload 34.24%
21:38:28:WU02:FS01:Upload 45.76%
21:38:34:WU02:FS01:Upload 56.96%
21:38:40:WU02:FS01:Upload 68.42%
21:38:46:WU02:FS01:Upload 79.41%
21:38:52:WU02:FS01:Upload 91.07%
21:38:53:WARNING:WU04:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
21:38:53:WU04:FS01:Trying to send results to collection server
21:38:53:WU04:FS01:Uploading 42.37MiB to 18.188.125.154
21:38:53:WU04:FS01:Connecting to 18.188.125.154:8080
21:38:59:WU04:FS01:Upload 16.37%
21:39:05:WU04:FS01:Upload 43.22%
21:39:05:WU00:FS01:0x21:Completed 1000000 out of 10000000 steps (10%)
21:39:11:WU04:FS01:Upload 61.52%
21:39:17:WU04:FS01:Upload 84.09%
21:39:28:ERROR:WU02:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:39:28:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:14447 run:0 clone:918 gen:57 core:0x22 unit:0x0000005503854c135ea7b89038655b40
21:39:28:WU02:FS01:Uploading 94.92MiB to 3.133.76.19
21:39:28:WU02:FS01:Connecting to 3.133.76.19:8080
21:39:34:WU02:FS01:Upload 11.33%
21:39:40:WU02:FS01:Upload 23.11%
21:39:46:WU02:FS01:Upload 34.77%
21:39:52:WU02:FS01:Upload 46.49%
21:39:52:ERROR:WU04:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:39:58:WU02:FS01:Upload 58.41%
21:40:04:WU02:FS01:Upload 70.00%
21:40:10:WU02:FS01:Upload 81.85%
21:40:16:WU02:FS01:Upload 93.64%
21:40:16:FS01:Finishing
21:40:40:WU00:FS01:0x21:Completed 1100000 out of 10000000 steps (11%)
21:40:51:WARNING:WU02:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
21:40:51:WU02:FS01:Trying to send results to collection server
21:40:51:WU02:FS01:Uploading 94.92MiB to 3.21.157.11
21:40:51:WU02:FS01:Connecting to 3.21.157.11:8080
21:40:57:WU02:FS01:Upload 9.02%
21:41:03:WU02:FS01:Upload 21.40%
21:41:09:WU02:FS01:Upload 33.19%
21:41:15:WU02:FS01:Upload 44.91%
21:41:21:WU02:FS01:Upload 56.56%
21:41:27:WU02:FS01:Upload 68.81%
21:41:33:WU02:FS01:Upload 80.53%
21:41:39:WU02:FS01:Upload 92.32%
21:42:01:WU04:FS01:Sending unit results: id:04 state:SEND error:NO_ERROR project:16448 run:0 clone:1025 gen:78 core:0x22 unit:0x0000007342aa6f325ed18ce214e7a6d6
21:42:01:WU04:FS01:Uploading 42.37MiB to 66.170.111.50
21:42:01:WU04:FS01:Connecting to 66.170.111.50:8080
21:42:07:WU04:FS01:Upload 21.98%
21:42:13:WU04:FS01:Upload 38.50%
21:42:14:WU00:FS01:0x21:Completed 1200000 out of 10000000 steps (12%)
21:42:14:ERROR:WU02:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:42:19:WU04:FS01:Upload 56.06%
21:42:25:WU04:FS01:Upload 72.58%
21:42:31:WU04:FS01:Upload 90.13%
21:43:07:WARNING:WU04:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
21:43:07:WU04:FS01:Trying to send results to collection server
21:43:07:WU04:FS01:Uploading 42.37MiB to 18.188.125.154
21:43:07:WU04:FS01:Connecting to 18.188.125.154:8080
21:43:13:WU04:FS01:Upload 28.62%
21:43:19:WU04:FS01:Upload 47.21%
21:43:25:WU04:FS01:Upload 69.19%
21:43:31:WU04:FS01:Upload 94.41%
21:43:42:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:14447 run:0 clone:918 gen:57 core:0x22 unit:0x0000005503854c135ea7b89038655b40
21:43:42:WU02:FS01:Uploading 94.92MiB to 3.133.76.19
21:43:42:WU02:FS01:Connecting to 3.133.76.19:8080
21:43:48:WU02:FS01:Upload 9.68%
21:43:50:WU00:FS01:0x21:Completed 1300000 out of 10000000 steps (13%)
21:43:54:WU02:FS01:Upload 21.40%
21:44:00:WU02:FS01:Upload 32.73%
21:44:04:ERROR:WU04:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:44:06:WU02:FS01:Upload 44.12%
21:44:12:WU02:FS01:Upload 55.38%
21:44:18:WU02:FS01:Upload 66.24%
21:44:24:WU02:FS01:Upload 77.50%
21:44:30:WU02:FS01:Upload 88.57%
21:44:36:WU02:FS01:Upload 99.76%
21:45:25:WU00:FS01:0x21:Completed 1400000 out of 10000000 steps (14%)
21:46:59:WU00:FS01:0x21:Completed 1500000 out of 10000000 steps (15%)
It seems to be a bit random, but regularly get back to my PC to see a backlog of WUs that haven't uploaded. For instance today, saw about 8 in the queue waiting to send, stopped and restarted the client, some of them uploaded straight away, but still now have two in the queue which keep getting this error.Joe_H wrote: Are other WUs uploading okay, with just some WUs having trouble uploading and getting this message?
When a WU attempts to upload, the log reports one or two IP addresses and the "Recevied short response..." often indicates a problem witn one of those servers. For example, in the log you posted, I see the following two messages associated with WU04:FS01 although there are a lot of intervening messages.
My guess is that 18.188.125.154 is having a problem. The fact that you were able to upload another WU to another server suggests that the problem is not with your router.
JohnChodera
- Pande Group Member
This may have been due to the assign rate of aws3.foldingathome.org (18.188.125.154) having been set too high for the server to keep up with the WU return rate. I've dropped it to allow it to catch up---please see if this resolves the situation over the next 24 hours.
~ John Chodera // MSKCC
So, just to give an update....
Have given it a few days and this is what I'm currently looking at
I'm sure I've not had problems uploading to other servers, but these 2 seem to be the main culprits...
In my cue I the following waiting to send (collection servers).
3x 3.21.157.11
6x 18.188.125.154
3x 3.21.157.11
6x 18.188.125.154
Will restart client and let you know, cheersJohnChodera wrote:This may have been due to the assign rate of aws3.foldingathome.org (18.188.125.154) having been set too high for the server to keep up with the WU return rate. I've dropped it to allow it to catch up---please see if this resolves the situation over the next 24 hours.
Re: (AWS3) 10002: Rcvd short response, expected 512 bytes, g
I'm changing the title of this topic to be specifically about AWS3 (18.188.125.154) and moving it to problems with a specific server. JohnChoera's response (above) pertained specifically to that server.
I suggest you create a separate topic about 3.21.157.11 (aws2.foldingathome.org) if you're getting the same error message from it. In the future, please paste segments of FAH's log showing the errors. (See the sig block of this post.)
JohnChodera
Please let us know if you're still having issues with uploads to aws3.foldingathome.org!
Just to let you know am still having issues uploading to this server... I'm starting to wonder if any WU's i've done for this server have uploaded or if they've now just expired as some have gone from my queue. I'm going to start logging down WU's that I see hanging around in my queue for reference.
Log after restarting my client yesterday:
https://pastebin.com/DUje421X
I've used pastebin as it was a bit too long to for the forum... let me know if this causes any issues.
After restarting client again, I just saw one WU complete uploading to 18.188.125.154 (11:07:16)!
So obviously it's not completely fubar...
*********************** Log Started 2020-06-28T10:58:19Z ***********************
10:58:19:************************* Folding@home Client *************************
10:58:19: Website: https://foldingathome.org/
10:58:19: Copyright: (c) 2009-2018 foldingathome.org
10:58:19: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:58:19: Args: --open-web-control
10:58:19: Config: C:\Users\Administrator\AppData\Roaming\FAHClient\config.xml
10:58:19:******************************** Build ********************************
10:58:19: Version: 7.5.1
10:58:19: Date: May 11 2018
10:58:19: Time: 13:06:32
10:58:19: Repository: Git
10:58:19: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
10:58:19: Branch: master
10:58:19: Compiler: Visual C++ 2008
10:58:19: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:58:19: Platform: win32 10
10:58:19: Bits: 32
10:58:19: Mode: Release
10:58:19:******************************* System ********************************
10:58:19: CPU: Intel(R) Core(TM) i7-7820X CPU @ 3.60GHz
10:58:19: CPU ID: GenuineIntel Family 6 Model 85 Stepping 4
10:58:19: CPUs: 16
10:58:19: Memory: 31.69GiB
10:58:19: Free Memory: 24.60GiB
10:58:19: Threads: WINDOWS_THREADS
10:58:19: OS Version: 6.2
10:58:19: Has Battery: false
10:58:19: On Battery: false
10:58:19: UTC Offset: 1
10:58:19: PID: 20060
10:58:19: CWD: C:\Users\Administrator\AppData\Roaming\FAHClient
10:58:19: OS: Windows 10 Enterprise
10:58:19: OS Arch: AMD64
10:58:19: GPUs: 1
10:58:19: GPU 0: Bus:101 Slot:0 Func:0 NVIDIA:8 GP102 [GeForce GTX 1080 Ti]
10:58:19: 11380
10:58:19: CUDA Device 0: Platform:0 Device:0 Bus:101 Slot:0 Compute:6.1 Driver:11.0
10:58:19:OpenCL Device 0: Platform:0 Device:0 Bus:101 Slot:0 Compute:1.2 Driver:445.87
10:58:19: Win32 Service: false
10:58:19:***********************************************************************
10:58:19:<config>
10:58:19: <!-- Network -->
10:58:19: <proxy v=':8080'/>
10:58:19:
10:58:19: <!-- Slot Control -->
10:58:19: <power v='full'/>
10:58:19:
10:58:19: <!-- User Information -->
10:58:19: <passkey v='********************************'/>
10:58:19: <team v='223518'/>
10:58:19: <user v='wiLik'/>
10:58:19:
10:58:19: <!-- Folding Slots -->
10:58:19: <slot id='1' type='GPU'/>
10:58:19:</config>
10:58:19:Trying to access database...
10:58:19:Successfully acquired database lock
10:58:19:Enabled folding slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380
10:58:19:WU06:FS01:Sending unit results: id:06 state:SEND error:NO_ERROR project:14456 run:0 clone:901 gen:46 core:0x22 unit:0x0000004003854c135eb39a2f1d537f59
10:58:19:WU06:FS01:Uploading 88.05MiB to 3.133.76.19
10:58:19:WU08:FS01:Sending unit results: id:08 state:SEND error:NO_ERROR project:14451 run:0 clone:15 gen:71 core:0x22 unit:0x0000006c03854c135eac4ad0f1df070f
10:58:19:WU06:FS01:Connecting to 3.133.76.19:8080
10:58:19:WU07:FS01:Sending unit results: id:07 state:SEND error:NO_ERROR project:14466 run:0 clone:848 gen:48 core:0x22 unit:0x0000004803854c135eb98530b83e055f
10:58:19:WU08:FS01:Uploading 87.27MiB to 3.133.76.19
10:58:19:WU08:FS01:Connecting to 3.133.76.19:8080
10:58:19:WU07:FS01:Uploading 82.89MiB to 3.133.76.19
10:58:19:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14457 run:0 clone:1337 gen:11 core:0x22 unit:0x0000001103854c135eb39a2ef91e5278
10:58:19:WU07:FS01:Connecting to 3.133.76.19:8080
10:58:19:WU01:FS01:Uploading 88.05MiB to 3.133.76.19
10:58:19:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14463 run:0 clone:1313 gen:21 core:0x22 unit:0x0000002203854c135eb39e42d010982c
10:58:19:WU01:FS01:Connecting to 3.133.76.19:8080
10:58:19:WU00:FS01:Uploading 88.72MiB to 3.133.76.19
10:58:19:WU02:FS01:Starting
10:58:19:WU00:FS01:Connecting to 3.133.76.19:8080
10:58:19:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Administrator\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 20060 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
10:58:19:WU02:FS01:Started FahCore on PID 21828
10:58:19:WU02:FS01:Core PID:17728
10:58:19:WU02:FS01:FahCore 0x22 started
10:58:20:WU02:FS01:0x22:*********************** Log Started 2020-06-28T10:58:19Z ***********************
10:58:20:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
10:58:20:WU02:FS01:0x22: Core: Core22
10:58:20:WU02:FS01:0x22: Type: 0x22
10:58:20:WU02:FS01:0x22: Version: 0.0.10
10:58:20:WU02:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:58:20:WU02:FS01:0x22: Copyright: 2020 foldingathome.org
10:58:20:WU02:FS01:0x22: Homepage: https://foldingathome.org/
10:58:20:WU02:FS01:0x22: Date: Jun 16 2020
10:58:20:WU02:FS01:0x22: Time: 14:33:22
10:58:20:WU02:FS01:0x22: Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
10:58:20:WU02:FS01:0x22: Branch: core22-0.0.10
10:58:20:WU02:FS01:0x22: Compiler: Visual C++ 2015
10:58:20:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
10:58:20:WU02:FS01:0x22: Platform: win32 10
10:58:20:WU02:FS01:0x22: Bits: 64
10:58:20:WU02:FS01:0x22: Mode: Release
10:58:20:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
10:58:20:WU02:FS01:0x22: <peastman@stanford.edu>
10:58:20:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 705 -lifeline 21828 -checkpoint 15
10:58:20:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
10:58:20:WU02:FS01:0x22: 0 -gpu 0
10:58:20:WU02:FS01:0x22:************************************ libFAH ************************************
10:58:20:WU02:FS01:0x22: Date: Jun 15 2020
10:58:20:WU02:FS01:0x22: Time: 18:05:04
10:58:20:WU02:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
10:58:20:WU02:FS01:0x22: Branch: HEAD
10:58:20:WU02:FS01:0x22:************************************ CBang *************************************
10:58:20:WU02:FS01:0x22: Time: 14:31:33
10:58:20:WU02:FS01:0x22: Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
10:58:20:WU02:FS01:0x22:************************************ System ************************************
10:58:20:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i7-7820X CPU @ 3.60GHz
10:58:20:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 85 Stepping 4
10:58:20:WU02:FS01:0x22: CPUs: 16
10:58:20:WU02:FS01:0x22: Memory: 31.69GiB
10:58:20:WU02:FS01:0x22:Free Memory: 24.58GiB
10:58:20:WU02:FS01:0x22: Threads: WINDOWS_THREADS
10:58:20:WU02:FS01:0x22: OS Version: 6.2
10:58:20:WU02:FS01:0x22:Has Battery: false
10:58:20:WU02:FS01:0x22: On Battery: false
10:58:20:WU02:FS01:0x22: UTC Offset: 1
10:58:20:WU02:FS01:0x22: PID: 17728
10:58:20:WU02:FS01:0x22: CWD: C:\Users\Administrator\AppData\Roaming\FAHClient\work
10:58:20:WU02:FS01:0x22:********************************************************************************
10:58:20:WU02:FS01:0x22:Project: 11759 (Run 0, Clone 9101, Gen 150)
10:58:20:WU02:FS01:0x22:Unit: 0x000000ff80fccb0a5e6eafa065334167
10:58:20:WU02:FS01:0x22:Digital signatures verified
10:58:20:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
10:58:20:WU02:FS01:0x22:Version 0.0.10
10:58:20:WU02:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
10:58:20:WU02:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
10:58:20:WU02:FS01:0x22: XTC frame write interval: 50000 steps (5%) [20 total]
10:58:20:WU02:FS01:0x22: Global context and integrator variables write interval: disabled
10:58:23:9:127.0.0.1:New Web connection
10:58:26:WU06:FS01:Upload 0.85%
10:58:26:WU08:FS01:Upload 0.86%
10:58:31:WU02:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
10:58:34:WU07:FS01:Upload 0.90%
10:58:34:WU01:FS01:Upload 0.85%
10:58:50:WU00:FS01:Upload 0.85%
10:58:50:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
10:58:50:WU00:FS01:Trying to send results to collection server
10:58:50:WU00:FS01:Uploading 88.72MiB to 18.188.125.154
10:58:50:WU00:FS01:Connecting to 18.188.125.154:8080
10:58:56:WU00:FS01:Upload 12.54%
10:58:57:WU08:FS01:Upload 1.50%
10:58:57:WARNING:WU08:FS01:Exception: Failed to send results to work server: Transfer failed
10:58:57:WU08:FS01:Trying to send results to collection server
10:58:57:WU08:FS01:Uploading 87.27MiB to 18.188.125.154
10:58:57:WU08:FS01:Connecting to 18.188.125.154:8080
10:58:57:WU06:FS01:Upload 1.56%
10:58:57:WARNING:WU06:FS01:Exception: Failed to send results to work server: Transfer failed
10:58:57:WU06:FS01:Trying to send results to collection server
10:58:57:WU06:FS01:Uploading 88.05MiB to 3.21.157.11
10:58:57:WU06:FS01:Connecting to 3.21.157.11:8080
10:59:02:WU00:FS01:Upload 23.11%
10:59:03:WU06:FS01:Upload 4.97%
10:59:03:WU08:FS01:Upload 4.23%
10:59:05:WU07:FS01:Upload 1.66%
10:59:05:WARNING:WU07:FS01:Exception: Failed to send results to work server: Transfer failed
10:59:05:WU07:FS01:Trying to send results to collection server
10:59:05:WU07:FS01:Uploading 82.89MiB to 18.188.125.154
10:59:05:WU07:FS01:Connecting to 18.188.125.154:8080
10:59:06:WU01:FS01:Upload 1.56%
10:59:06:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
10:59:06:WU01:FS01:Trying to send results to collection server
10:59:06:WU01:FS01:Uploading 88.05MiB to 18.188.125.154
10:59:06:WU01:FS01:Connecting to 18.188.125.154:8080
10:59:08:WU00:FS01:Upload 34.10%
10:59:09:WU06:FS01:Upload 10.08%
10:59:09:WU08:FS01:Upload 8.45%
10:59:11:WU07:FS01:Upload 1.88%
10:59:12:WU01:FS01:Upload 0.78%
10:59:14:WU00:FS01:Upload 39.87%
10:59:15:WU08:FS01:Upload 13.75%
10:59:15:WU06:FS01:Upload 16.54%
10:59:17:WU07:FS01:Upload 6.18%
10:59:18:WU01:FS01:Upload 3.55%
10:59:20:WU00:FS01:Upload 46.49%
10:59:21:WU06:FS01:Upload 20.59%
10:59:21:WU08:FS01:Upload 17.19%
10:59:23:WU07:FS01:Upload 10.48%
10:59:24:WU01:FS01:Upload 10.22%
10:59:26:WU00:FS01:Upload 54.24%
10:59:27:WU08:FS01:Upload 19.62%
10:59:27:WU06:FS01:Upload 23.71%
10:59:29:WU07:FS01:Upload 14.70%
10:59:30:WU01:FS01:Upload 16.61%
10:59:32:WU00:FS01:Upload 60.30%
10:59:33:WU08:FS01:Upload 23.13%
10:59:33:WU06:FS01:Upload 26.62%
10:59:35:WU07:FS01:Upload 20.13%
10:59:36:WU01:FS01:Upload 23.92%
10:59:38:WU00:FS01:Upload 66.22%
10:59:39:WU08:FS01:Upload 26.50%
10:59:39:WU06:FS01:Upload 29.39%
10:59:41:WU07:FS01:Upload 25.86%
10:59:42:WU01:FS01:Upload 30.73%
10:59:44:WU00:FS01:Upload 71.50%
10:59:45:WU08:FS01:Upload 29.86%
10:59:45:WU06:FS01:Upload 32.30%
10:59:46:WU02:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
10:59:47:WU07:FS01:Upload 32.20%
10:59:48:WU01:FS01:Upload 37.41%
10:59:50:WU00:FS01:Upload 75.87%
10:59:51:WU06:FS01:Upload 35.42%
10:59:51:WU08:FS01:Upload 32.66%
10:59:53:WU07:FS01:Upload 38.23%
10:59:54:WU01:FS01:Upload 43.94%
10:59:56:WU00:FS01:Upload 81.01%
10:59:57:WU06:FS01:Upload 39.33%
10:59:57:WU08:FS01:Upload 35.59%
10:59:59:WU07:FS01:Upload 44.33%
11:00:00:WU01:FS01:Upload 50.47%
11:00:02:WU00:FS01:Upload 87.21%
11:00:03:WU06:FS01:Upload 43.66%
11:00:03:WU08:FS01:Upload 37.46%
11:00:05:WU07:FS01:Upload 50.29%
11:00:06:WU01:FS01:Upload 56.64%
11:00:08:WU00:FS01:Upload 94.05%
11:00:09:WU06:FS01:Upload 48.13%
11:00:09:WU08:FS01:Upload 38.60%
11:00:11:WU07:FS01:Upload 56.10%
11:00:12:WU01:FS01:Upload 62.46%
11:00:15:WU08:FS01:Upload 40.61%
11:00:15:WU06:FS01:Upload 54.30%
11:00:17:WU07:FS01:Upload 62.20%
11:00:18:WU01:FS01:Upload 67.86%
11:00:21:WU06:FS01:Upload 65.45%
11:00:21:WU08:FS01:Upload 43.26%
11:00:23:WU07:FS01:Upload 68.01%
11:00:24:WU01:FS01:Upload 72.61%
11:00:27:WU06:FS01:Upload 76.31%
11:00:27:WU08:FS01:Upload 46.55%
11:00:29:WU07:FS01:Upload 73.29%
11:00:30:WU01:FS01:Upload 76.87%
11:00:33:WU06:FS01:Upload 85.68%
11:00:33:WU08:FS01:Upload 50.06%
11:00:35:WU07:FS01:Upload 80.68%
11:00:36:WU01:FS01:Upload 80.85%
11:00:39:WU08:FS01:Upload 53.36%
11:00:39:WU06:FS01:Upload 92.56%
11:00:41:WU07:FS01:Upload 88.37%
11:00:42:WU01:FS01:Upload 83.97%
11:00:44:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:00:44:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14463 run:0 clone:1313 gen:21 core:0x22 unit:0x0000002203854c135eb39e42d010982c
11:00:44:WU00:FS01:Uploading 88.72MiB to 3.133.76.19
11:00:44:WU00:FS01:Connecting to 3.133.76.19:8080
11:00:45:WU08:FS01:Upload 57.08%
11:00:45:WU06:FS01:Upload 94.91%
11:00:48:WU01:FS01:Upload 87.52%
11:00:51:WU06:FS01:Upload 98.03%
11:00:51:WU08:FS01:Upload 62.31%
11:00:54:WU01:FS01:Upload 94.33%
11:00:57:WU08:FS01:Upload 70.76%
11:01:01:WU02:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
11:01:03:WU08:FS01:Upload 85.01%
11:01:05:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
11:01:05:WU00:FS01:Connecting to 3.133.76.19:80
11:01:05:WU00:FS01:Upload 0.07%
11:01:09:WU08:FS01:Upload 97.47%
11:01:17:ERROR:WU07:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:01:17:WU07:FS01:Sending unit results: id:07 state:SEND error:NO_ERROR project:14466 run:0 clone:848 gen:48 core:0x22 unit:0x0000004803854c135eb98530b83e055f
11:01:17:WU07:FS01:Uploading 82.89MiB to 3.133.76.19
11:01:17:WU07:FS01:Connecting to 3.133.76.19:8080
11:01:24:ERROR:WU06:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:01:24:WU06:FS01:Sending unit results: id:06 state:SEND error:NO_ERROR project:14456 run:0 clone:901 gen:46 core:0x22 unit:0x0000004003854c135eb39a2f1d537f59
11:01:24:WU06:FS01:Uploading 88.05MiB to 3.133.76.19
11:01:24:WU06:FS01:Connecting to 3.133.76.19:8080
11:01:25:WU07:FS01:Upload 0.98%
11:01:28:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:01:28:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14457 run:0 clone:1337 gen:11 core:0x22 unit:0x0000001103854c135eb39a2ef91e5278
11:01:28:WU01:FS01:Uploading 88.05MiB to 3.133.76.19
11:01:28:WU01:FS01:Connecting to 3.133.76.19:8080
11:01:36:WU00:FS01:Upload 0.85%
11:01:36:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
11:01:36:WU00:FS01:Trying to send results to collection server
11:01:36:WU00:FS01:Uploading 88.72MiB to 18.188.125.154
11:01:36:WU00:FS01:Connecting to 18.188.125.154:8080
11:01:41:ERROR:WU08:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:01:41:WU08:FS01:Sending unit results: id:08 state:SEND error:NO_ERROR project:14451 run:0 clone:15 gen:71 core:0x22 unit:0x0000006c03854c135eac4ad0f1df070f
11:01:41:WU08:FS01:Uploading 87.27MiB to 3.133.76.19
11:01:41:WU08:FS01:Connecting to 3.133.76.19:8080
11:01:42:WU00:FS01:Upload 8.24%
11:01:48:WU00:FS01:Upload 21.56%
11:01:54:WU00:FS01:Upload 33.46%
11:01:55:WU07:FS01:Upload 1.66%
11:01:55:WARNING:WU07:FS01:Exception: Failed to send results to work server: Transfer failed
11:01:55:WU06:FS01:Upload 1.63%
11:01:55:WU07:FS01:Trying to send results to collection server
11:01:55:WARNING:WU06:FS01:Exception: Failed to send results to work server: Transfer failed
11:01:55:WU07:FS01:Uploading 82.89MiB to 18.188.125.154
11:01:55:WU06:FS01:Trying to send results to collection server
11:01:55:WU07:FS01:Connecting to 18.188.125.154:8080
11:01:55:WU06:FS01:Uploading 88.05MiB to 3.21.157.11
11:01:55:WU06:FS01:Connecting to 3.21.157.11:8080
11:02:00:WU00:FS01:Upload 44.03%
11:02:00:WU01:FS01:Upload 1.56%
11:02:00:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
11:02:00:WU01:FS01:Trying to send results to collection server
11:02:00:WU01:FS01:Uploading 88.05MiB to 18.188.125.154
11:02:00:WU01:FS01:Connecting to 18.188.125.154:8080
11:02:01:WU07:FS01:Upload 5.50%
11:02:01:WU06:FS01:Upload 3.90%
11:02:06:WU01:FS01:Upload 11.78%
11:02:06:WU00:FS01:Upload 47.48%
11:02:07:WU07:FS01:Upload 9.58%
11:02:07:WU06:FS01:Upload 7.10%
11:02:12:WU01:FS01:Upload 19.73%
11:02:12:WU00:FS01:Upload 51.50%
11:02:13:WU07:FS01:Upload 15.16%
11:02:13:WU06:FS01:Upload 11.64%
11:02:13:WU08:FS01:Upload 1.58%
11:02:13:WARNING:WU08:FS01:Exception: Failed to send results to work server: Transfer failed
11:02:13:WU08:FS01:Trying to send results to collection server
11:02:13:WU08:FS01:Uploading 87.27MiB to 18.188.125.154
11:02:13:WU08:FS01:Connecting to 18.188.125.154:8080
11:02:16:WU02:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
11:02:18:WU01:FS01:Upload 26.40%
11:02:18:WU00:FS01:Upload 56.43%
11:02:19:WU06:FS01:Upload 14.76%
11:02:19:WU08:FS01:Upload 6.23%
11:02:19:WU07:FS01:Upload 18.32%
11:02:24:WU00:FS01:Upload 61.15%
11:02:24:WU01:FS01:Upload 32.23%
11:02:25:WU08:FS01:Upload 11.24%
11:02:25:WU06:FS01:Upload 18.67%
11:02:25:WU07:FS01:Upload 22.32%
11:02:30:WU01:FS01:Upload 37.41%
11:02:30:WU00:FS01:Upload 66.36%
11:02:31:WU06:FS01:Upload 23.50%
11:02:31:WU08:FS01:Upload 15.97%
11:02:31:WU07:FS01:Upload 26.62%
11:02:36:WU00:FS01:Upload 70.24%
11:02:36:WU01:FS01:Upload 42.16%
11:02:37:WU06:FS01:Upload 29.46%
11:02:37:WU07:FS01:Upload 32.35%
11:02:37:WU08:FS01:Upload 19.34%
11:02:42:WU00:FS01:Upload 73.55%
11:02:42:WU01:FS01:Upload 45.85%
11:02:43:WU07:FS01:Upload 39.66%
11:02:43:WU06:FS01:Upload 33.50%
11:02:43:WU08:FS01:Upload 22.42%
11:02:48:WU01:FS01:Upload 49.62%
11:02:48:WU00:FS01:Upload 76.29%
11:02:49:WU07:FS01:Upload 45.77%
11:02:49:WU08:FS01:Upload 25.35%
11:02:49:WU06:FS01:Upload 36.70%
11:02:54:WU01:FS01:Upload 53.87%
11:02:54:WU00:FS01:Upload 79.25%
11:02:55:WU06:FS01:Upload 40.11%
11:02:55:WU08:FS01:Upload 28.43%
11:02:55:WU07:FS01:Upload 51.95%
11:03:00:WU01:FS01:Upload 60.40%
11:03:00:WU00:FS01:Upload 82.70%
11:03:01:WU08:FS01:Upload 32.23%
11:03:01:WU07:FS01:Upload 56.55%
11:03:01:WU06:FS01:Upload 44.37%
11:03:06:WU01:FS01:Upload 67.57%
11:03:06:WU00:FS01:Upload 86.72%
11:03:07:WU07:FS01:Upload 60.85%
11:03:07:WU08:FS01:Upload 36.24%
11:03:07:WU06:FS01:Upload 48.77%
11:03:12:WU01:FS01:Upload 72.33%
11:03:12:WU00:FS01:Upload 90.59%
11:03:13:WU07:FS01:Upload 65.07%
11:03:13:WU08:FS01:Upload 42.47%
11:03:13:WU06:FS01:Upload 51.75%
11:03:18:WU01:FS01:Upload 77.65%
11:03:18:WU00:FS01:Upload 94.19%
11:03:19:WU07:FS01:Upload 70.42%
11:03:19:WU08:FS01:Upload 49.77%
11:03:19:WU06:FS01:Upload 54.37%
11:03:24:WU00:FS01:Upload 97.71%
11:03:24:WU01:FS01:Upload 82.76%
11:03:25:WU08:FS01:Upload 55.72%
11:03:25:WU07:FS01:Upload 76.68%
11:03:25:WU06:FS01:Upload 57.71%
11:03:30:WU01:FS01:Upload 87.73%
11:03:31:WU07:FS01:Upload 84.30%
11:03:31:WU02:FS01:0x22:Completed 340000 out of 1000000 steps (34%)
11:03:31:WU08:FS01:Upload 61.66%
11:03:31:WU06:FS01:Upload 62.11%
11:03:36:WU01:FS01:Upload 93.34%
11:03:37:WU07:FS01:Upload 92.06%
11:03:37:WU08:FS01:Upload 67.46%
11:03:37:WU06:FS01:Upload 66.65%
11:03:42:WU01:FS01:Upload 98.95%
11:03:43:WU07:FS01:Upload 99.22%
11:03:43:WU08:FS01:Upload 72.62%
11:03:43:WU06:FS01:Upload 72.12%
11:03:49:WU06:FS01:Upload 82.84%
11:03:49:WU08:FS01:Upload 80.93%
11:03:55:WU08:FS01:Upload 91.89%
11:03:55:WU06:FS01:Upload 92.21%
11:03:58:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:03:58:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14463 run:0 clone:1313 gen:21 core:0x22 unit:0x0000002203854c135eb39e42d010982c
11:03:58:WU00:FS01:Uploading 88.72MiB to 3.133.76.19
11:03:58:WU00:FS01:Connecting to 3.133.76.19:8080
11:04:14:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:04:14:ERROR:WU07:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:04:14:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14457 run:0 clone:1337 gen:11 core:0x22 unit:0x0000001103854c135eb39a2ef91e5278
11:04:14:WU01:FS01:Uploading 88.05MiB to 3.133.76.19
11:04:14:WU07:FS01:Sending unit results: id:07 state:SEND error:NO_ERROR project:14466 run:0 clone:848 gen:48 core:0x22 unit:0x0000004803854c135eb98530b83e055f
11:04:14:WU01:FS01:Connecting to 3.133.76.19:8080
11:04:14:WU07:FS01:Uploading 82.89MiB to 3.133.76.19
11:04:14:WU07:FS01:Connecting to 3.133.76.19:8080
11:04:30:ERROR:WU08:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:04:30:WU08:FS01:Sending unit results: id:08 state:SEND error:NO_ERROR project:14451 run:0 clone:15 gen:71 core:0x22 unit:0x0000006c03854c135eac4ad0f1df070f
11:04:30:WU08:FS01:Uploading 87.27MiB to 3.133.76.19
11:04:30:WU08:FS01:Connecting to 3.133.76.19:8080
11:04:31:ERROR:WU06:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:04:31:WU06:FS01:Sending unit results: id:06 state:SEND error:NO_ERROR project:14456 run:0 clone:901 gen:46 core:0x22 unit:0x0000004003854c135eb39a2f1d537f59
11:04:31:WU06:FS01:Uploading 88.05MiB to 3.133.76.19
11:04:31:WU06:FS01:Connecting to 3.133.76.19:8080
11:04:33:WU00:FS01:Upload 1.48%
11:04:33:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
11:04:33:WU00:FS01:Trying to send results to collection server
11:04:33:WU00:FS01:Uploading 88.72MiB to 18.188.125.154
11:04:33:WU00:FS01:Connecting to 18.188.125.154:8080
11:04:39:WU00:FS01:Upload 7.12%
11:04:45:WU00:FS01:Upload 20.36%
11:04:46:WU02:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
11:04:46:WU01:FS01:Upload 1.49%
11:04:46:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
11:04:46:WU01:FS01:Trying to send results to collection server
11:04:46:WU01:FS01:Uploading 88.05MiB to 18.188.125.154
11:04:46:WU01:FS01:Connecting to 18.188.125.154:8080
11:04:46:WU07:FS01:Upload 1.51%
11:04:47:WARNING:WU07:FS01:Exception: Failed to send results to work server: Transfer failed
11:04:47:WU07:FS01:Trying to send results to collection server
11:04:47:WU07:FS01:Uploading 82.89MiB to 18.188.125.154
11:04:47:WU07:FS01:Connecting to 18.188.125.154:8080
11:04:51:WU00:FS01:Upload 31.49%
11:04:52:WU01:FS01:Upload 5.68%
11:04:53:WU07:FS01:Upload 5.50%
11:04:57:WU00:FS01:Upload 39.80%
11:04:58:WU01:FS01:Upload 13.34%
11:04:59:WU07:FS01:Upload 12.14%
11:05:03:WU00:FS01:Upload 47.62%
11:05:03:WU08:FS01:Upload 1.50%
11:05:03:WARNING:WU08:FS01:Exception: Failed to send results to work server: Transfer failed
11:05:03:WU08:FS01:Trying to send results to collection server
11:05:03:WU08:FS01:Uploading 87.27MiB to 18.188.125.154
11:05:03:WU08:FS01:Connecting to 18.188.125.154:8080
11:05:04:WU01:FS01:Upload 21.01%
11:05:05:WU07:FS01:Upload 18.40%
11:05:05:WU06:FS01:Upload 1.42%
11:05:06:WARNING:WU06:FS01:Exception: Failed to send results to work server: Transfer failed
11:05:06:WU06:FS01:Trying to send results to collection server
11:05:06:WU06:FS01:Uploading 88.05MiB to 3.21.157.11
11:05:06:WU06:FS01:Connecting to 3.21.157.11:8080
11:05:09:WU00:FS01:Upload 54.17%
11:05:09:WU08:FS01:Upload 1.22%
11:05:10:WU01:FS01:Upload 28.32%
11:05:11:WU07:FS01:Upload 23.37%
11:05:12:WU06:FS01:Upload 0.99%
11:05:15:WU00:FS01:Upload 59.88%
11:05:15:WU08:FS01:Upload 3.80%
11:05:16:WU01:FS01:Upload 35.77%
11:05:17:WU07:FS01:Upload 29.03%
11:05:18:WU06:FS01:Upload 2.98%
11:05:21:WU00:FS01:Upload 64.74%
11:05:21:WU08:FS01:Upload 7.45%
11:05:22:WU01:FS01:Upload 42.16%
11:05:23:WU07:FS01:Upload 34.23%
11:05:24:WU06:FS01:Upload 5.39%
11:05:27:WU00:FS01:Upload 69.04%
11:05:27:WU08:FS01:Upload 11.39%
11:05:28:WU01:FS01:Upload 48.55%
11:05:29:WU07:FS01:Upload 39.28%
11:05:30:WU06:FS01:Upload 8.02%
11:05:33:WU00:FS01:Upload 72.98%
11:05:33:WU08:FS01:Upload 15.54%
11:05:34:WU01:FS01:Upload 54.44%
11:05:35:WU07:FS01:Upload 44.18%
11:05:36:WU06:FS01:Upload 11.00%
11:05:39:WU00:FS01:Upload 77.14%
11:05:39:WU08:FS01:Upload 21.20%
11:05:40:WU01:FS01:Upload 60.12%
11:05:41:WU07:FS01:Upload 48.78%
11:05:42:WU06:FS01:Upload 14.34%
11:05:45:WU08:FS01:Upload 28.36%
11:05:45:WU00:FS01:Upload 80.45%
11:05:46:WU01:FS01:Upload 64.24%
11:05:47:WU07:FS01:Upload 52.48%
11:05:48:WU06:FS01:Upload 17.75%
11:05:51:WU08:FS01:Upload 35.95%
11:05:51:WU00:FS01:Upload 83.48%
11:05:52:WU01:FS01:Upload 68.28%
11:05:53:WU07:FS01:Upload 56.32%
11:05:54:WU06:FS01:Upload 21.44%
11:05:57:WU00:FS01:Upload 87.00%
11:05:57:WU08:FS01:Upload 41.97%
11:05:58:WU01:FS01:Upload 72.47%
11:05:59:WU07:FS01:Upload 60.32%
11:06:00:WU06:FS01:Upload 25.84%
11:06:01:WU02:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
11:06:03:WU08:FS01:Upload 47.20%
11:06:03:WU00:FS01:Upload 90.38%
11:06:04:WU01:FS01:Upload 76.52%
11:06:05:WU07:FS01:Upload 64.39%
11:06:06:WU06:FS01:Upload 30.74%
11:06:09:WU08:FS01:Upload 51.14%
11:06:09:WU00:FS01:Upload 93.55%
11:06:10:WU01:FS01:Upload 80.78%
11:06:11:WU07:FS01:Upload 67.86%
11:06:12:WU06:FS01:Upload 36.56%
11:06:15:WU08:FS01:Upload 54.57%
11:06:15:WU00:FS01:Upload 96.30%
11:06:16:WU01:FS01:Upload 85.60%
11:06:17:WU07:FS01:Upload 71.40%
11:06:18:WU06:FS01:Upload 41.95%
11:06:21:WU00:FS01:Upload 98.77%
11:06:21:WU08:FS01:Upload 57.65%
11:06:22:WU01:FS01:Upload 91.56%
11:06:23:WU07:FS01:Upload 75.47%
11:06:24:WU06:FS01:Upload 47.70%
11:06:27:WU08:FS01:Upload 60.80%
11:06:28:WU01:FS01:Upload 99.02%
11:06:29:WU07:FS01:Upload 79.77%
11:06:30:WU06:FS01:Upload 53.88%
11:06:33:WU08:FS01:Upload 65.96%
11:06:35:WU07:FS01:Upload 86.33%
11:06:36:WU06:FS01:Upload 61.69%
11:06:39:WU08:FS01:Upload 72.69%
11:06:41:WU07:FS01:Upload 92.74%
11:06:42:WU06:FS01:Upload 69.14%
11:06:45:WU08:FS01:Upload 81.57%
11:06:47:WU07:FS01:Upload 99.07%
11:06:48:WU06:FS01:Upload 76.88%
11:06:51:WU08:FS01:Upload 92.17%
11:06:54:WU06:FS01:Upload 87.10%
11:06:56:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:06:56:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14463 run:0 clone:1313 gen:21 core:0x22 unit:0x0000002203854c135eb39e42d010982c
11:06:56:WU00:FS01:Uploading 88.72MiB to 3.133.76.19
11:06:56:WU00:FS01:Connecting to 3.133.76.19:8080
11:06:59:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:06:59:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14457 run:0 clone:1337 gen:11 core:0x22 unit:0x0000001103854c135eb39a2ef91e5278
11:06:59:WU01:FS01:Uploading 88.05MiB to 3.133.76.19
11:06:59:WU01:FS01:Connecting to 3.133.76.19:8080
11:07:04:WU00:FS01:Upload 0.85%
11:07:16:WU02:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
11:07:16:WU07:FS01:Upload complete
11:07:17:WU07:FS01:Server responded WORK_ACK (400)
11:07:17:WU07:FS01:Final credit estimate, 53500.00 points
11:07:17:WU07:FS01:Cleaning up
11:07:27:ERROR:WU08:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:07:27:WU08:FS01:Sending unit results: id:08 state:SEND error:NO_ERROR project:14451 run:0 clone:15 gen:71 core:0x22 unit:0x0000006c03854c135eac4ad0f1df070f
11:07:27:WU08:FS01:Uploading 87.27MiB to 3.133.76.19
11:07:27:WU08:FS01:Connecting to 3.133.76.19:8080
11:07:30:WU01:FS01:Upload 0.92%
11:07:30:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
11:07:30:WU01:FS01:Trying to send results to collection server
11:07:30:WU01:FS01:Uploading 88.05MiB to 18.188.125.154
11:07:30:WU01:FS01:Connecting to 18.188.125.154:8080
11:07:31:ERROR:WU06:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:07:31:WU06:FS01:Sending unit results: id:06 state:SEND error:NO_ERROR project:14456 run:0 clone:901 gen:46 core:0x22 unit:0x0000004003854c135eb39a2f1d537f59
11:07:31:WU06:FS01:Uploading 88.05MiB to 3.133.76.19
11:07:31:WU06:FS01:Connecting to 3.133.76.19:8080
11:07:35:WU08:FS01:Upload 0.86%
11:07:35:WU00:FS01:Upload 1.41%
11:07:35:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
11:07:35:WU00:FS01:Trying to send results to collection server
11:07:35:WU00:FS01:Uploading 88.72MiB to 18.188.125.154
11:07:35:WU00:FS01:Connecting to 18.188.125.154:8080
11:07:36:WU01:FS01:Upload 11.64%
11:07:41:WU00:FS01:Upload 5.71%
11:07:42:WU01:FS01:Upload 24.56%
11:07:47:WU00:FS01:Upload 14.93%
11:07:48:WU01:FS01:Upload 36.84%
11:07:53:WU00:FS01:Upload 24.80%
11:07:54:WU01:FS01:Upload 48.83%
11:07:59:WU00:FS01:Upload 34.31%
11:08:00:WU01:FS01:Upload 60.76%
11:08:03:WU06:FS01:Upload 1.49%
11:08:04:WARNING:WU06:FS01:Exception: Failed to send results to work server: Transfer failed
11:08:04:WU06:FS01:Trying to send results to collection server
11:08:04:WU06:FS01:Uploading 88.05MiB to 3.21.157.11
11:08:04:WU06:FS01:Connecting to 3.21.157.11:8080
11:08:05:WU00:FS01:Upload 43.96%
11:08:06:WU08:FS01:Upload 1.58%
11:08:06:WU01:FS01:Upload 72.61%
11:08:06:WARNING:WU08:FS01:Exception: Failed to send results to work server: Transfer failed
11:08:06:WU08:FS01:Trying to send results to collection server
11:08:06:WU08:FS01:Uploading 87.27MiB to 18.188.125.154
11:08:06:WU08:FS01:Connecting to 18.188.125.154:8080
11:08:10:WU06:FS01:Upload 1.56%
11:08:11:WU00:FS01:Upload 52.34%
11:08:12:WU01:FS01:Upload 83.33%
11:08:12:WU08:FS01:Upload 1.36%
11:08:16:WU06:FS01:Upload 4.40%
11:08:17:WU00:FS01:Upload 59.46%
11:08:18:WU01:FS01:Upload 91.92%
11:08:18:WU08:FS01:Upload 4.01%
11:08:22:WU06:FS01:Upload 7.10%
11:08:23:WU00:FS01:Upload 67.14%
11:08:24:WU08:FS01:Upload 8.02%
11:08:28:WU06:FS01:Upload 8.02%
11:08:29:WU00:FS01:Upload 78.62%
11:08:30:WU08:FS01:Upload 15.25%
11:08:30:WU02:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
11:08:34:WU06:FS01:Upload 12.64%
11:08:35:WU00:FS01:Upload 88.41%
11:08:36:WU08:FS01:Upload 21.92%
11:08:40:WU06:FS01:Upload 20.09%
11:08:41:WU00:FS01:Upload 97.43%
11:08:42:WU08:FS01:Upload 27.86%
11:08:46:WU06:FS01:Upload 29.10%
11:08:48:WU08:FS01:Upload 37.53%
11:08:52:WU06:FS01:Upload 41.81%
11:08:54:WU08:FS01:Upload 44.55%
11:08:54:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:08:58:WU06:FS01:Upload 55.65%
11:09:00:WU08:FS01:Upload 52.35%
11:09:04:WU06:FS01:Upload 59.34%
11:09:06:WU08:FS01:Upload 68.04%
11:09:10:WU06:FS01:Upload 68.50%
11:09:12:WU08:FS01:Upload 79.85%
11:09:14:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:09:16:WU06:FS01:Upload 79.64%
11:09:18:WU08:FS01:Upload 89.52%
11:09:22:WU06:FS01:Upload 93.34%
11:09:24:WU08:FS01:Upload 93.89%
11:09:34:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14463 run:0 clone:1313 gen:21 core:0x22 unit:0x0000002203854c135eb39e42d010982c
11:09:34:WU00:FS01:Uploading 88.72MiB to 3.133.76.19
11:09:34:WU00:FS01:Connecting to 3.133.76.19:8080
11:09:37:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14457 run:0 clone:1337 gen:11 core:0x22 unit:0x0000001103854c135eb39a2ef91e5278
11:09:37:WU01:FS01:Uploading 88.05MiB to 3.133.76.19
11:09:37:WU01:FS01:Connecting to 3.133.76.19:8080
11:09:44:WU02:FS01:0x22:Completed 390000 out of 1000000 steps (39%)
11:09:44:WU01:FS01:Upload 0.85%
11:09:58:ERROR:WU06:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:09:59:ERROR:WU08:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:10:04:WU00:FS01:Upload 0.92%
11:10:05:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
11:10:05:WU00:FS01:Trying to send results to collection server
11:10:05:WU00:FS01:Uploading 88.72MiB to 18.188.125.154
11:10:05:WU00:FS01:Connecting to 18.188.125.154:8080
11:10:05:WU08:FS01:Sending unit results: id:08 state:SEND error:NO_ERROR project:14451 run:0 clone:15 gen:71 core:0x22 unit:0x0000006c03854c135eac4ad0f1df070f
11:10:05:WU08:FS01:Uploading 87.27MiB to 3.133.76.19
11:10:05:WU08:FS01:Connecting to 3.133.76.19:8080
11:10:09:WU06:FS01:Sending unit results: id:06 state:SEND error:NO_ERROR project:14456 run:0 clone:901 gen:46 core:0x22 unit:0x0000004003854c135eb39a2f1d537f59
11:10:09:WU06:FS01:Uploading 88.05MiB to 3.133.76.19
11:10:09:WU06:FS01:Connecting to 3.133.76.19:8080
11:10:11:WU00:FS01:Upload 10.21%
11:10:14:WU01:FS01:Upload 1.56%
11:10:15:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
11:10:15:WU01:FS01:Trying to send results to collection server
11:10:15:WU01:FS01:Uploading 88.05MiB to 18.188.125.154
11:10:15:WU01:FS01:Connecting to 18.188.125.154:8080
11:10:17:WU00:FS01:Upload 23.67%
11:10:21:WU01:FS01:Upload 9.80%
11:10:23:WU00:FS01:Upload 34.87%
11:10:27:WU01:FS01:Upload 20.80%
11:10:29:WU00:FS01:Upload 44.66%
11:10:33:WU01:FS01:Upload 32.58%
11:10:35:WU00:FS01:Upload 54.67%
11:10:37:WU08:FS01:Upload 1.58%
11:10:37:WARNING:WU08:FS01:Exception: Failed to send results to work server: Transfer failed
11:10:37:WU08:FS01:Trying to send results to collection server
11:10:37:WU08:FS01:Uploading 87.27MiB to 18.188.125.154
11:10:37:WU08:FS01:Connecting to 18.188.125.154:8080
11:10:39:WU01:FS01:Upload 44.08%
11:10:41:WU00:FS01:Upload 64.11%
11:10:42:WU06:FS01:Upload 1.56%
11:10:43:WU08:FS01:Upload 1.65%
11:10:43:WARNING:WU06:FS01:Exception: Failed to send results to work server: Transfer failed
11:10:43:WU06:FS01:Trying to send results to collection server
11:10:43:WU06:FS01:Uploading 88.05MiB to 3.21.157.11
11:10:43:WU06:FS01:Connecting to 3.21.157.11:8080
11:10:45:WU01:FS01:Upload 54.02%
11:10:47:WU00:FS01:Upload 72.14%
11:10:49:WU08:FS01:Upload 4.73%
11:10:49:WU06:FS01:Upload 1.06%
11:10:51:WU01:FS01:Upload 63.03%
11:10:53:WU00:FS01:Upload 79.68%
11:10:55:WU06:FS01:Upload 3.34%
11:10:55:WU08:FS01:Upload 8.88%
11:10:57:WU01:FS01:Upload 70.27%
11:10:58:WU02:FS01:0x22:Completed 400000 out of 1000000 steps (40%)
11:10:59:WU00:FS01:Upload 86.86%
11:11:01:WU08:FS01:Upload 13.03%
11:11:01:WU06:FS01:Upload 6.25%
11:11:03:WU01:FS01:Upload 76.59%
11:11:05:WU00:FS01:Upload 93.76%
11:11:07:WU08:FS01:Upload 17.76%
11:11:07:WU06:FS01:Upload 9.72%
11:11:09:WU01:FS01:Upload 83.26%
11:11:13:WU06:FS01:Upload 14.48%
11:11:13:WU08:FS01:Upload 24.14%
11:11:15:WU01:FS01:Upload 91.21%
11:11:19:WU06:FS01:Upload 20.51%
11:11:19:WU08:FS01:Upload 32.16%
11:11:21:WU01:FS01:Upload 99.51%
11:11:25:WU08:FS01:Upload 41.68%
11:11:25:WU06:FS01:Upload 29.03%
11:11:31:WU06:FS01:Upload 39.25%
11:11:31:WU08:FS01:Upload 52.93%
11:11:37:WU08:FS01:Upload 64.96%
11:11:37:WU06:FS01:Upload 48.62%
Generally we are fine with just extracts from a log that show enough to see what the problem is, not just the error but included context to see where the error was reported. That and the first 100-200 lines of the log to see what the hardware, software, and client configuration are as detected by the software. Repetitive sections can be removed.wiLik wrote:I've used pastebin as it was a bit too long to for the forum... let me know if this causes any issues.
