FahCore returned: CORE_OUTDATED (110 = 0x6e)
NathanJanssens
Post by NathanJanssens »
Hi all,
I'm experiencing an issue that I haven't run into before. Maybe anyone can help to see if it's anything to be "worried about", or maybe can easily be fixed....?
00:32:47:WU01:FS01:Started FahCore on PID 15816
00:32:47:WU01:FS01:Core PID:248
00:32:47:WU01:FS01:FahCore 0x22 started
00:32:48:WU01:FS01:0x22:*********************** Log Started 2020-06-19T00:32:47Z ***********************
00:32:48:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
00:32:48:WU01:FS01:0x22:       Type: 0x22
00:32:48:WU01:FS01:0x22:       Core: Core22
00:32:48:WU01:FS01:0x22:    Website: https://foldingathome.org/
00:32:48:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
00:32:48:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
00:32:48:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
00:32:48:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 15816 -checkpoint 15
00:32:48:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
00:32:48:WU01:FS01:0x22:     Config: <none>
00:32:48:WU01:FS01:0x22:************************************ Build *************************************
00:32:48:WU01:FS01:0x22:    Version: 0.0.5
00:32:48:WU01:FS01:0x22:       Date: Apr 22 2020
00:32:48:WU01:FS01:0x22:       Time: 04:42:59
00:32:48:WU01:FS01:0x22: Repository: Git
00:32:48:WU01:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
00:32:48:WU01:FS01:0x22:     Branch: HEAD
00:32:48:WU01:FS01:0x22:   Compiler: Visual C++ 2008
00:32:48:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:32:48:WU01:FS01:0x22:   Platform: win32 10
00:32:48:WU01:FS01:0x22:       Bits: 64
00:32:48:WU01:FS01:0x22:       Mode: Release
00:32:48:WU01:FS01:0x22:************************************ System ************************************
00:32:48:WU01:FS01:0x22:        CPU: AMD Ryzen 7 3750H with Radeon Vega Mobile Gfx
00:32:48:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 24 Stepping 1
00:32:48:WU01:FS01:0x22:       CPUs: 8
00:32:48:WU01:FS01:0x22:     Memory: 13.92GiB
00:32:48:WU01:FS01:0x22:Free Memory: 10.01GiB
00:32:48:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
00:32:48:WU01:FS01:0x22: OS Version: 6.2
00:32:48:WU01:FS01:0x22:Has Battery: true
00:32:48:WU01:FS01:0x22: On Battery: false
00:32:48:WU01:FS01:0x22: UTC Offset: 2
00:32:48:WU01:FS01:0x22:        PID: 248
00:32:48:WU01:FS01:0x22:        CWD: C:\Users\janss\AppData\Roaming\FAHClient\work
00:32:48:WU01:FS01:0x22:         OS: Windows 10 Home
00:32:48:WU01:FS01:0x22:    OS Arch: AMD64
00:32:48:WU01:FS01:0x22:********************************************************************************
00:32:48:WU01:FS01:0x22:Project: 11745 (Run 0, Clone 9682, Gen 39)
00:32:48:WU01:FS01:0x22:Unit: 0x000000368ca304f15e6bc3740df5d5be
00:32:48:WU01:FS01:0x22:Reading tar file core.xml
00:32:48:WU01:FS01:0x22:Reading tar file integrator.xml
00:32:48:WU01:FS01:0x22:Reading tar file state.xml
00:32:49:WU01:FS01:0x22:Reading tar file system.xml
00:32:50:WU01:FS01:0x22:Digital signatures verified
00:32:50:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
00:32:50:WU01:FS01:0x22:Version 0.0.5
00:33:28:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
00:33:28:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:35:21:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
03:41:06:WU01:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
03:41:06:WU03:FS01:Connecting to assign1.foldingathome.org:80
03:41:07:WU03:FS01:Assigned to work server 18.188.125.154
03:41:07:WU03:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Navi 14 [Radeon RX 5500/5500M / Pro 5500M] from 18.188.125.154
03:41:07:WU03:FS01:Connecting to 18.188.125.154:8080
03:41:07:WU03:FS01:Downloading 440.30KiB
03:41:09:WU03:FS01:Download complete
03:41:09:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:13413 run:44 clone:9 gen:1 core:0x22 unit:0x0000000112bc7d9a5ee796e07052f481
03:43:00:WU01:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
03:43:07:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
03:43:07:WU01:FS01:0x22:Saving result file checkpointState.xml
03:43:12:WU01:FS01:0x22:Saving result file checkpt.crc
03:43:12:WU01:FS01:0x22:Saving result file positions.xtc
03:43:14:WU01:FS01:0x22:Saving result file science.log
03:43:14:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
03:43:16:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:43:16:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11745 run:0 clone:9682 gen:39 core:0x22 unit:0x000000368ca304f15e6bc3740df5d5be
03:43:16:WU01:FS01:Uploading 14.65MiB to 140.163.4.241
03:43:16:WU03:FS01:Starting
03:43:16:WU01:FS01:Connecting to 140.163.4.241:8080
03:43:16:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\*****\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 706 -lifeline 12864 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
03:43:16:WU03:FS01:Started FahCore on PID 10368
03:43:16:WU03:FS01:Core PID:4756
03:43:16:WU03:FS01:FahCore 0x22 started
03:43:16:WARNING:WU03:FS01:FahCore returned: CORE_OUTDATED (110 = 0x6e)
elblat
Re: FahCore returned: CORE_OUTDATED (110 = 0x6e)
Post by elblat »
I had a similar issue last night. I've got a dual GPU system, and one GPU updated and kept right on folding but the other got hung on "Updating" for a while. In advanced control I tried "Pause" and then "Fold" on that slot and it immediately started the WU and has been folding subsequent WUs since.
5800X + 4090 + Win11 | 5600X+ 3070 + 3070 + 2060 + Ubuntu 20.04 | 5600X + 3080 Ti + 3060 Ti + Ubuntu 20.04
ajm
Post by ajm »
The core is the software that does the actual work on the donor's machines and there is a new one in town for GPUs: viewtopic.php?f=74&t=35624
Normally, it just downloads and it's done. Well, it did on my systems. I've read that during beta testing it happened that it didn't and that a reboot would do the trick.
Since only part of the log is shown, do you happen to have more than one GPU folding slot on your system? The core can not be updated while another GPU slot is actively using it. Pausing folding, and then starting just the folding slot that needs to update the core will allow this to happen. Once the folding core has been downloaded and installed, other slots can be started again.
If you do not have more than one GPU folding slot, then it is possible either that the updated core has not been made ready at the download location or that the download is not working for another reason. For that we would need to see more of the log file to get an idea where the problem is.
NathanJanssens
Thanks for the replies. I indeed have another GPU folding, so that is probably the reason then. I will update if the suggested solutions do not work.
