Disabling cables/disabling "Hideconsole" results in error
afkar.aulia
Post by afkar.aulia »
So, it's me again. Previously, disabling GPU and running only on CPU works out fine, and I finally managed to finish 1 WU (yay :D)
However, I got too curious and began to probe around >__<
Since I sometimes bring my laptop to static bicycle, I want to remove the limitation of "folding only when plugged". I also tried to clean up my startup item and accidentally disabled "HideConsole," only to find out later that it's FAH startup. I'm not sure which of these two actions bring significant changes, but the two result in error.
Now the log says that it keeps failing to get new WU. Previously, my CPU slot had completed around 30% WU. I estimate that my laptop can handle 3% of WU per hour. However, the WU suddenly becomes 0% and there is WORK ACK 400 in the log (Which I can't bring back out as the log somehow cannot record up to that point). Now I get an unfair 552 points due to the work being completed (which should be impossible since it needs 23 hours more).
Now it stops folding altogether : ( It keeps saying "Client:Local Online Inactive". I tried to find topic about "local online inactive", but it says that it happens simply when there is no longer any WU (Really? There still should be a lot about covid19). The only other change I recently made is installing cisco webex (which shouldn't interfere, right?)
I have re-enabled "Hideconsole" startup item, but nothing new happens. Restarting does nothing either. And re-enabling the rule to "only fold when on power" does nothing new either.
Here is the current log :
*********************** Log Started 2020-06-17T16:45:34Z ***********************
16:45:34:Trying to access database...
16:45:34:Successfully acquired database lock
16:45:34:Read GPUs.txt
16:45:35:Enabled folding slot 00: READY cpu:2
16:46:09:****************************** FAHClient ******************************
16:46:09:        Version: 7.6.13
16:46:09:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:46:09:      Copyright: 2020 foldingathome.org
16:46:09:       Homepage: https://foldingathome.org/
16:46:09:           Date: Apr 27 2020
16:46:09:           Time: 21:21:01
16:46:09:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
16:46:09:         Branch: master
16:46:09:       Compiler: Visual C++ 2008
16:46:09:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:46:09:       Platform: win32 10
16:46:09:           Bits: 32
16:46:09:           Mode: Release
16:46:09:           Args: --open-web-control
16:46:09:         Config: C:\Users\LENOVO\AppData\Roaming\FAHClient\config.xml
16:46:09:******************************** CBang ********************************
16:46:09:           Date: Apr 24 2020
16:46:09:           Time: 17:07:55
16:46:09:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
16:46:09:           Bits: 32
16:46:09:******************************* System ********************************
16:46:09:            CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
16:46:09:         CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
16:46:09:           CPUs: 2
16:46:09:         Memory: 3.89GiB
16:46:09:    Free Memory: 2.23GiB
16:46:09:        Threads: WINDOWS_THREADS
16:46:09:     OS Version: 6.2
16:46:09:    Has Battery: true
16:46:09:     On Battery: false
16:46:09:     UTC Offset: 7
16:46:09:            PID: 848
16:46:09:            CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient
16:46:09:  Win32 Service: false
16:46:09:             OS: Windows 10 Home
16:46:09:        OS Arch: AMD64
16:46:09:           GPUs: 1
16:46:09:          GPU 0: Bus:0 Slot:1 Func:0 AMD:5 [Radeon R2-R5]
16:46:09:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
16:46:09:                 specified module could not be found.
16:46:09:
16:46:09:OpenCL Device 0: Platform:0 Device:0 Bus:0 Slot:1 Compute:1.2 Driver:2686.5
16:46:09:******************************* libFAH ********************************
16:46:09:           Date: Apr 15 2020
16:46:09:           Time: 14:53:14
16:46:09:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
16:46:09:           Bits: 32
16:46:09:***********************************************************************
16:46:09:<config>
16:46:09:  <!-- Folding Slot Configuration -->
16:46:09:  <cause v='COVID_19'/>
16:46:09:
16:46:09:  <!-- Network -->
16:46:09:  <proxy v=':8080'/>
16:46:09:
16:46:09:  <!-- Slot Control -->
16:46:09:  <power v='FULL'/>
16:46:09:
16:46:09:  <!-- User Information -->
16:46:09:  <passkey v='*****'/>
16:46:09:  <user v='afkar_aulia'/>
16:46:09:
16:46:09:  <!-- Folding Slots -->
16:46:09:  <slot id='0' type='CPU'/>
16:46:09:</config>
16:46:11:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:46:19:6:127.0.0.1:New Web session
16:46:19:7:127.0.0.1:New Web session
16:46:19:9:127.0.0.1:New Web session
16:46:20:13:127.0.0.1:New Web session
16:46:23:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:46:23:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:46:29:22:127.0.0.1:New Web session
16:46:35:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:46:35:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:46:47:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:46:47:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:46:57:30:127.0.0.1:New Web session
16:46:59:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:46:59:ERROR:WU00:FS00:Exception: Could not get an assignment
16:47:00:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:47:12:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:47:12:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:47:24:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:47:24:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:47:36:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:47:36:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:47:48:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:47:48:ERROR:WU00:FS00:Exception: Could not get an assignment
16:48:00:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:48:12:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:48:12:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:48:24:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:48:24:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:48:36:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:48:36:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:48:49:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:48:49:ERROR:WU00:FS00:Exception: Could not get an assignment
16:49:37:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:49:49:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:49:49:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:50:02:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:50:02:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:50:14:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:50:14:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:50:26:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:50:26:ERROR:WU00:FS00:Exception: Could not get an assignment
16:50:45:FS00:Paused
16:50:49:FS00:Unpaused
16:50:49:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:51:01:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:51:01:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:51:13:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:51:13:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:51:26:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:51:26:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:51:38:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:51:38:ERROR:WU00:FS00:Exception: Could not get an assignment
16:52:26:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:52:38:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:52:38:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:52:50:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:52:50:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:53:03:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:53:03:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:53:15:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:53:15:ERROR:WU00:FS00:Exception: Could not get an assignment
16:55:04:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:55:16:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:55:16:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:55:28:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:55:28:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:55:40:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:55:40:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:55:52:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:55:52:ERROR:WU00:FS00:Exception: Could not get an assignment
16:57:26:41:127.0.0.1:New Web session
16:59:18:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:59:30:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:59:30:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:59:42:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:59:42:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:59:54:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
16:59:54:WU00:FS00:Connecting to assign4.foldingathome.org:80
17:00:06:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
17:00:06:ERROR:WU00:FS00:Exception: Could not get an assignment
17:06:09:WU00:FS00:Connecting to assign1.foldingathome.org:80
17:06:21:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
17:06:21:WU00:FS00:Connecting to assign2.foldingathome.org:80
17:06:34:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
17:06:34:WU00:FS00:Connecting to assign3.foldingathome.org:80
17:06:46:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
17:06:46:WU00:FS00:Connecting to assign4.foldingathome.org:80
17:06:58:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
17:06:58:ERROR:WU00:FS00:Exception: Could not get an assignment
17:17:15:WU00:FS00:Connecting to assign1.foldingathome.org:80
17:17:27:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
17:17:27:WU00:FS00:Connecting to assign2.foldingathome.org:80
17:17:39:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
17:17:39:WU00:FS00:Connecting to assign3.foldingathome.org:80
17:17:51:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
17:17:51:WU00:FS00:Connecting to assign4.foldingathome.org:80
17:18:03:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
17:18:03:ERROR:WU00:FS00:Exception: Could not get an assignment
Re: Disabling cables/disabling "Hideconsole" results in erro
Post by foldy »
Seems like a connection issue. Are you behind a firewall? Or can you configure a proxy in fahcontrol to see if that helps? e.g. 140.227.69.49:8080 is a US https proxy. https://www.freeproxylists.net/?c=US&pt ... %5D=0&u=90
Please review this guide on Server connection troubleshooting: viewtopic.php?f=18&t=17794
Adding or removing the hideconsole component will not change what the client does or doesn't do. If you remove it, you MUST leave the window open that shows the output. HideConsole simply means that you don't have that extra clutter on your desktop to contend with.
afkar.aulia
It worked just fine for around a week before. And I didn't tamper with firewall.
I open youtube 720p video on another tab just fine, so it's not about connection speed.
I tried system restore, and still, it shows the same thing.
afkar.aulia
PantherX wrote:Please review this guide on Server connection troubleshooting: viewtopic.php?f=18&t=17794
I cannot find the explanation about why my system says "Fail to read stream" or "fail to get ID," though.
And there shouldn't be any change from the time the app worked.
Uninstalling and reinstalling FAH did nothing. Connection is just as it was.
I can also connect just fine to http://Client.foldingathome.org
If it helps, the advanced control says that the clients is:
Status: Online
Address: 127.0.0.1:36330
Edit: Anybody knows how to add site as exception to windows firewall? Maybe I'll try that next. Folding@home control and client are already in the list of exception, but who knows? However, it makes no sense that I can connect to http://client.foldingathome.org but fail to connect to http://assign3.foldingathome.org
The only part of the folding client that needs exceptions in a firewall is FAHClient. It needs to be allowed to make TCP connections over ports 8080 and 80 inbound and outbound. Directions on how to do so have been posted here before.
But first, to see if the firewall is the problem, try disabling it temporarily.
afkar.aulia
It's still failing to get ID, even when firewall for current network got completely turned off. The other security app is just avast, which has been cooperating with FAH, so it's unlikely to cause this "connection error."
Is it possible that my small tweaking in "connect when battery is not plugged" cause a snowball of event that activates some system bug? I mean, removing that single tick may not do much, but there may be an error elsewhere that got triggered? Because that truly was what changed when it got error.
Client.foldingathome.org is still connected.
assign3.foldingathome.org is still giving no response, or assign2, or assign1..
This is what I tweaked before (although it seems simple enough, it's somehow in advanced setting). Right after I clicked it, folding process blinked on and off, starting, then back to ready, then starting again, then back to ready. It eventually never starts anymore.
Not sure if this connection tab means something, but here it is:
On a side note, I live in Indonesia, so I'm not sure if there is any difference of system or internet setting or proxy setting or something. But previously, there was also "Core update problem" which I posted in another thread. Not sure if that previous error is related with this one. viewtopic.php?f=61&t=35583
Edit: I just noticed that this guy is doing fine when opened on browser, but still, no folding is happening and no WU is given
картинки
afkar.aulia wrote:It's still failing to get ID, even when firewall for current network got completely turned off. The other security app is just avast, which has been cooperating with FAH, so it's unlikely to cause this "connection error."
I think you've proven that to be untrue. Disable avast, too, and confirm it was the problem.
afkar.aulia
Somehow, it's now working. Probably it's Avast core shield then. How can a software that introduced me to F@H be the one to disturb it? .__.
Now, it's back to core transfer problem.. yet again :D :lol: :lol:
Can't it be easier for normal user with no programming experience? T.T
But well.. I'll try again next week when I'm not busy then
edit: Is it possible to move core_a7.fah to the right directory manually? Downloading using browser is possible, but the FAH control keeps saying core transfer problem
Edit: Ok. Problem solved. It truly is avast. Disabling it completely when FAH is downloading WU up to the core transfer happening solves the issue. Activating avast when it starts folding doesn't create new issue.
Thanks for your patience in explaining to me, everyone.
afkar.aulia wrote:Somehow, it's now working. Probably it's Avast core shield then. How can a software that introduced me to F@H be the one to disturb it? .__.
Could be the usual case of the left hand not communicating with the right one. :roll: Or they were behind in updating some part to match a recent change to the F@h client software.
afkar.aulia wrote:edit: Is it possible to move core_a7.fah to the right directory manually? Downloading using browser is possible, but the FAH control keeps saying core transfer problem
Unfortunately it is not possible. The download is a package that gets unpacked into the folding core itself, and for some installations includes necessary versions of libraries such as .dll files for Windows.
afkar.aulia
I'm still having difficulty finding out which program actually blocks FAH connection. Today I'm having problem with sending 100% project to collection server, even when avast shield are completely off. I'm putting it in this thread as this is supposedly the same problem with my previous one. Window firewall already have FAHclient as exception list.
It didn't help that I installed PUP antivirus from the internet (I forget the name), and then did system restore. It worked out fine, but now it refuses to send completed work and refused to connect to assign server yet again. Is there any easy way to find what blocks what? Any cmd command or something? This "local online inactive" is very annoying, really >__<
*********************** Log Started 2020-07-23T04:41:45Z ***********************
04:41:45:Trying to access database...
04:41:45:Successfully acquired database lock
04:41:46:ERROR:Exception: Could not get IP address for assign1.foldingathome.org: No such host is known.
04:41:46:ERROR:Exception: Could not get IP address for assign2.foldingathome.org: No such host is known.
04:41:46:ERROR:Exception: Could not get IP address for assign3.foldingathome.org: No such host is known.
04:41:46:ERROR:Exception: Could not get IP address for assign4.foldingathome.org: No such host is known.
04:41:46:ERROR:Exception: Failed to find any IP addresses for assignment servers
04:41:47:Enabled folding slot 00: READY cpu:2
04:41:53:****************************** FAHClient ******************************
04:41:53:        Version: 7.6.13
04:41:53:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:41:53:      Copyright: 2020 foldingathome.org
04:41:53:       Homepage: https://foldingathome.org/
04:41:53:           Date: Apr 27 2020
04:41:53:           Time: 21:21:01
04:41:53:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
04:41:53:         Branch: master
04:41:53:       Compiler: Visual C++ 2008
04:41:53:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:41:53:       Platform: win32 10
04:41:53:           Bits: 32
04:41:53:           Mode: Release
04:41:53:         Config: C:\Users\LENOVO\AppData\Roaming\FAHClient\config.xml
04:41:53:******************************** CBang ********************************
04:41:53:           Date: Apr 24 2020
04:41:53:           Time: 17:07:55
04:41:53:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
04:41:53:           Bits: 32
04:41:53:******************************* System ********************************
04:41:53:            CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
04:41:53:         CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
04:41:53:           CPUs: 2
04:41:53:         Memory: 3.89GiB
04:41:53:    Free Memory: 1.89GiB
04:41:53:        Threads: WINDOWS_THREADS
04:41:53:     OS Version: 6.2
04:41:53:    Has Battery: true
04:41:53:     On Battery: true
04:41:53:     UTC Offset: 7
04:41:53:            PID: 5928
04:41:53:            CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient
04:41:53:  Win32 Service: false
04:41:53:             OS: Windows 10 Home
04:41:53:        OS Arch: AMD64
04:41:53:           GPUs: 0
04:41:53:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
04:41:53:                 specified module could not be found.
04:41:53:
04:41:53:OpenCL Device 0: Platform:0 Device:0 Bus:0 Slot:1 Compute:1.2 Driver:2686.5
04:41:53:******************************* libFAH ********************************
04:41:53:           Date: Apr 15 2020
04:41:53:           Time: 14:53:14
04:41:53:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
04:41:53:           Bits: 32
04:41:53:***********************************************************************
04:41:53:<config>
04:41:53:  <!-- Folding Slot Configuration -->
04:41:53:  <cause v='COVID_19'/>
04:41:53:
04:41:53:  <!-- Network -->
04:41:53:  <proxy v=':8080'/>
04:41:53:
04:41:53:  <!-- Slot Control -->
04:41:53:  <pause-on-battery v='false'/>
04:41:53:  <power v='full'/>
04:41:53:
04:41:53:  <!-- User Information -->
04:41:53:  <passkey v='*****'/>
04:41:53:  <user v='afkar_aulia'/>
04:41:53:
04:41:53:  <!-- Folding Slots -->
04:41:53:  <slot id='0' type='CPU'/>
04:41:53:</config>
04:41:53:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13850 run:0 clone:29843 gen:220 core:0xa7 unit:0x0000010f287234c95e788cf859a1340a
04:41:54:WU00:FS00:Uploading 2.54MiB to 40.114.52.201
04:41:54:WU00:FS00:Connecting to 40.114.52.201:8080
04:41:54:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:41:54:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: No such host is known.
04:41:54:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: No such host is known.
04:41:54:ERROR:WU01:FS00:Exception: Could not get IP address for assign3.foldingathome.org: No such host is known.
04:41:54:ERROR:WU01:FS00:Exception: Could not get IP address for assign4.foldingathome.org: No such host is known.
04:41:54:ERROR:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
04:41:55:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: A socket operation was attempted to an unreachable host.
04:41:55:WU00:FS00:Trying to send results to collection server
04:41:55:WU00:FS00:Uploading 2.54MiB to 52.224.109.74
04:41:55:WU00:FS00:Connecting to 52.224.109.74:8080
04:41:55:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:41:56:ERROR:WU00:FS00:Exception: Failed to connect to 52.224.109.74:80: A socket operation was attempted to an unreachable host.
04:41:56:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13850 run:0 clone:29843 gen:220 core:0xa7 unit:0x0000010f287234c95e788cf859a1340a
04:41:56:WU00:FS00:Uploading 2.54MiB to 40.114.52.201
04:41:56:WU00:FS00:Connecting to 40.114.52.201:8080
04:41:56:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:41:57:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: A socket operation was attempted to an unreachable host.
04:41:57:WU00:FS00:Trying to send results to collection server
04:41:57:WU00:FS00:Uploading 2.54MiB to 52.224.109.74
04:41:57:WU00:FS00:Connecting to 52.224.109.74:8080
04:41:57:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:41:58:ERROR:WU00:FS00:Exception: Failed to connect to 52.224.109.74:80: A socket operation was attempted to an unreachable host.
04:42:55:WU01:FS00:Connecting to assign1.foldingathome.org:80
04:42:56:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13850 run:0 clone:29843 gen:220 core:0xa7 unit:0x0000010f287234c95e788cf859a1340a
04:42:56:WU00:FS00:Uploading 2.54MiB to 40.114.52.201
04:42:56:WU00:FS00:Connecting to 40.114.52.201:8080
04:43:02:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:43:02:WU00:FS00:Connecting to 40.114.52.201:80
04:43:02:WU00:FS00:Upload 2.46%
04:43:07:WARNING:WU01:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
04:43:07:WU01:FS00:Connecting to assign2.foldingathome.org:80
04:43:14:WU00:FS00:Upload 12.30%
04:43:14:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
04:43:14:WU00:FS00:Trying to send results to collection server
04:43:15:WU00:FS00:Uploading 2.54MiB to 52.224.109.74
04:43:15:WU00:FS00:Connecting to 52.224.109.74:8080
04:43:19:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:43:19:WU00:FS00:Connecting to 52.224.109.74:80
04:43:19:WARNING:WU01:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
04:43:19:WU01:FS00:Connecting to assign3.foldingathome.org:80
04:43:31:WU00:FS00:Upload 12.30%
04:43:31:ERROR:WU00:FS00:Exception: Transfer failed
04:43:32:WARNING:WU01:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
04:43:32:WU01:FS00:Connecting to assign4.foldingathome.org:80
04:43:44:WARNING:WU01:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
04:43:44:ERROR:WU01:FS00:Exception: Could not get an assignment
04:44:32:WU01:FS00:Connecting to assign1.foldingathome.org:80
04:44:33:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13850 run:0 clone:29843 gen:220 core:0xa7 unit:0x0000010f287234c95e788cf859a1340a
04:44:33:WU00:FS00:Uploading 2.54MiB to 40.114.52.201
04:44:33:WU00:FS00:Connecting to 40.114.52.201:8080
04:44:37:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:44:37:WU00:FS00:Connecting to 40.114.52.201:80
04:44:44:WARNING:WU01:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
04:44:44:WU01:FS00:Connecting to assign2.foldingathome.org:80
04:44:49:WU00:FS00:Upload 12.30%
04:44:49:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
04:44:49:WU00:FS00:Trying to send results to collection server
04:44:49:WU00:FS00:Uploading 2.54MiB to 52.224.109.74
04:44:49:WU00:FS00:Connecting to 52.224.109.74:8080
04:44:53:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:44:53:WU00:FS00:Connecting to 52.224.109.74:80
04:44:56:WARNING:WU01:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
04:44:56:WU01:FS00:Connecting to assign3.foldingathome.org:80
04:45:05:WU00:FS00:Upload 12.30%
04:45:05:ERROR:WU00:FS00:Exception: Transfer failed
04:45:08:WARNING:WU01:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
04:45:08:WU01:FS00:Connecting to assign4.foldingathome.org:80
04:45:20:WARNING:WU01:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
04:45:21:ERROR:WU01:FS00:Exception: Could not get an assignment
04:47:12:WU01:FS00:Connecting to assign1.foldingathome.org:80
04:47:12:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13850 run:0 clone:29843 gen:220 core:0xa7 unit:0x0000010f287234c95e788cf859a1340a
04:47:12:WU00:FS00:Uploading 2.54MiB to 40.114.52.201
04:47:12:WU00:FS00:Connecting to 40.114.52.201:8080
04:47:13:WARNING:WU01:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
04:47:13:WU01:FS00:Connecting to assign2.foldingathome.org:80
04:47:15:WU01:FS00:Assigned to work server 168.245.198.125
04:47:15:WU01:FS00:Requesting new work unit for slot 00: READY cpu:2 from 168.245.198.125
04:47:15:WU01:FS00:Connecting to 168.245.198.125:8080
04:47:16:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:47:16:WU00:FS00:Connecting to 40.114.52.201:80
04:47:16:ERROR:WU01:FS00:Exception: Server did not assign work unit
04:47:19:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: No connection could be made because the target machine actively refused it.
04:47:19:WU00:FS00:Trying to send results to collection server
04:47:19:WU00:FS00:Uploading 2.54MiB to 52.224.109.74
04:47:19:WU00:FS00:Connecting to 52.224.109.74:8080
04:47:23:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:47:23:WU00:FS00:Connecting to 52.224.109.74:80
04:47:27:ERROR:WU00:FS00:Exception: Failed to connect to 52.224.109.74:80: No connection could be made because the target machine actively refused it.
04:51:23:WU01:FS00:Connecting to assign1.foldingathome.org:80
04:51:26:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13850 run:0 clone:29843 gen:220 core:0xa7 unit:0x0000010f287234c95e788cf859a1340a
04:51:26:WU00:FS00:Uploading 2.54MiB to 40.114.52.201
04:51:26:WU00:FS00:Connecting to 40.114.52.201:8080
04:51:30:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:51:30:WU00:FS00:Connecting to 40.114.52.201:80
04:51:36:WARNING:WU01:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
04:51:36:WU01:FS00:Connecting to assign2.foldingathome.org:80
04:51:42:WU00:FS00:Upload 9.84%
04:51:42:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
04:51:42:WU00:FS00:Trying to send results to collection server
04:51:42:WU00:FS00:Uploading 2.54MiB to 52.224.109.74
04:51:42:WU00:FS00:Connecting to 52.224.109.74:8080
04:51:46:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:51:46:WU00:FS00:Connecting to 52.224.109.74:80
04:51:48:WARNING:WU01:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
04:51:48:WU01:FS00:Connecting to assign3.foldingathome.org:80
04:51:58:WU00:FS00:Upload 9.84%
04:51:58:ERROR:WU00:FS00:Exception: Transfer failed
04:52:00:WARNING:WU01:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
04:52:00:WU01:FS00:Connecting to assign4.foldingathome.org:80
04:52:13:WARNING:WU01:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
04:52:13:ERROR:WU01:FS00:Exception: Could not get an assignment
04:58:14:WU01:FS00:Connecting to assign1.foldingathome.org:80
04:58:17:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13850 run:0 clone:29843 gen:220 core:0xa7 unit:0x0000010f287234c95e788cf859a1340a
04:58:18:WU00:FS00:Uploading 2.54MiB to 40.114.52.201
04:58:18:WU00:FS00:Connecting to 40.114.52.201:8080
04:58:21:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:58:21:WU00:FS00:Connecting to 40.114.52.201:80
04:58:33:WARNING:WU01:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
04:58:33:WU01:FS00:Connecting to assign2.foldingathome.org:80
04:58:33:WU00:FS00:Upload 9.84%
04:58:34:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
04:58:34:WU00:FS00:Trying to send results to collection server
04:58:34:WU00:FS00:Uploading 2.54MiB to 52.224.109.74
04:58:34:WU00:FS00:Connecting to 52.224.109.74:8080
04:58:37:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:58:37:WU00:FS00:Connecting to 52.224.109.74:80
04:58:52:ERROR:WU00:FS00:Exception: Failed to connect to 52.224.109.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:58:53:WARNING:WU01:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
04:58:53:WU01:FS00:Connecting to assign3.foldingathome.org:80
04:59:05:WARNING:WU01:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
04:59:05:WU01:FS00:Connecting to assign4.foldingathome.org:80
04:59:17:WARNING:WU01:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
04:59:17:ERROR:WU01:FS00:Exception: Could not get an assignment
edit: Now the downloading process of new project has worked, but the upload of the previous project hasn't. Is there any problem with project 13850 or is it connection problem?
The upload is failing to the server indicated because it is down. It is one of a group on Azure down since late last week - viewtopic.php?f=18&t=35826. It is being looked into by F@h support and Azure support.
As for the rest of the connection issues shown in the log, first it appears your system did not have an active connection and took a while to connect and reach a DNS for domain lookup.. Then something is blocking the connection for the download. Someone more familiar with Windows tools for checking may give you some ideas on what to use and find what was blocking.
The essentials are that FAHClient needs to be allowed to communicate over ports 80 and 8080 using HTTP (TCP) for both uploads and downloads of data. Windows firewall has its settings required, as does their anti-malware if active. Each other anti-virus or anti-malware software you install can require setting to allow this.
