Hi
I'm trying to get F@H to run on my built in GPU as well as my Nvidia GTX 970. It's detected and running fine on my CPU and normal GPU, but I can't get it to run on my iGPU. Can someone tell me what I'm doing wrong? iGPU is enabled in BIOS and shows up in Device Manager fine.
Thanks
Run F@H on GPU and iGPU
Re: Run F@H on GPU and iGPU
Welcome to the F@H Forum SteveV1,
Please note that currently, F@H only supports GPUs from AMD and Nvidia which have OpenCL 1.2 and Double Precision support. Thus, it is unlikely that your iGPU is currently supported by F@H.
internal GPU in AMD APU should work (my 3200G does) ... and some time ago intel had a CPU series with built-in AMD GPU that may work too (but afaik driver support has ended)
Just a note, F@H has never supported an intel driver, even for an AMD GPU, so getting that odd combination to run is non trivial.mad_martn wrote:internal GPU in AMD APU should work (my 3200G does) ... and some time ago intel had a CPU series with built-in AMD GPU that may work too (but afaik driver support has ended)
they used AMD graphics drivers, JFTR: https://www.tomshardware.com/news/amd-p ... aby-lake-gJimboPalmer wrote:Just a note, F@H has never supported an intel driver, even for an AMD GPU, so getting that odd combination to run is non trivial.mad_martn wrote:internal GPU in AMD APU should work (my 3200G does) ... and some time ago intel had a CPU series with built-in AMD GPU that may work too (but afaik driver support has ended)
I have a Ryzen 4900HS with a Renoir, Vega based iGPU. It shows up as listed but doesn't receive any work so far.
tulai, I would start a thread about that. Fewer people will see it tacked on to this thread.
When You start your thread, Include the first 200 lines of the log, so we have the PC's perspective as well as yours.
viewtopic.php?f=24&t=26036
