Core won't start, no error displayed
Gui924
Post by Gui924 »
Hello folders,
I currently have a problem with my GPU slot, as the core doesn't show any errors and the WU is not showing anything abnormal, but the log doesn't show the typical "completed 0 out of xxxxx steps (0%)", and the GPU is not used. Still, it uses the CPU thread as always.
I searched in the forum for similar problems without success, and I tried some things that I have found in the forum like deleing the Core_0x22.exe, or uninstalling and reinstalling the FAH client (while conserving data). I also deleted the slot and put it back, but it didn't solve the problem either and I also saw that it rejected a lot of WU as bad work units.
Here is a part of my log, this is after unpausing the slot, but it is the same on other conditions :
07:27:57:FS01:Unpaused
07:27:57:WU00:FS01:Starting
07:27:57:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\xxxx xxx\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe" -dir 00 -suffix 01 -version 706 -lifeline 1940 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
07:27:57:WU00:FS01:Started FahCore on PID 14632
07:27:57:WU00:FS01:Core PID:16404
07:27:57:WU00:FS01:FahCore 0x22 started
07:27:58:WU00:FS01:0x22:*********************** Log Started 2020-06-15T07:27:57Z ***********************
07:27:58:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:27:58:WU00:FS01:0x22:       Type: 0x22
07:27:58:WU00:FS01:0x22:       Core: Core22
07:27:58:WU00:FS01:0x22:    Website: https://foldingathome.org/
07:27:58:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
07:27:58:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
07:27:58:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
07:27:58:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 14632 -checkpoint 15
07:27:58:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
07:27:58:WU00:FS01:0x22:             0 -gpu 0
07:27:58:WU00:FS01:0x22:     Config: <none>
07:27:58:WU00:FS01:0x22:************************************ Build *************************************
07:27:58:WU00:FS01:0x22:    Version: 0.0.5
07:27:58:WU00:FS01:0x22:       Date: Apr 22 2020
07:27:58:WU00:FS01:0x22:       Time: 04:42:59
07:27:58:WU00:FS01:0x22: Repository: Git
07:27:58:WU00:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
07:27:58:WU00:FS01:0x22:     Branch: HEAD
07:27:58:WU00:FS01:0x22:   Compiler: Visual C++ 2008
07:27:58:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:27:58:WU00:FS01:0x22:   Platform: win32 10
07:27:58:WU00:FS01:0x22:       Bits: 64
07:27:58:WU00:FS01:0x22:       Mode: Release
07:27:58:WU00:FS01:0x22:************************************ System ************************************
07:27:58:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
07:27:58:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
07:27:58:WU00:FS01:0x22:       CPUs: 8
07:27:58:WU00:FS01:0x22:     Memory: 7.90GiB
07:27:58:WU00:FS01:0x22:Free Memory: 1.81GiB
07:27:58:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
07:27:58:WU00:FS01:0x22: OS Version: 6.2
07:27:58:WU00:FS01:0x22:Has Battery: true
07:27:58:WU00:FS01:0x22: On Battery: false
07:27:58:WU00:FS01:0x22: UTC Offset: 2
07:27:58:WU00:FS01:0x22:        PID: 16404
07:27:58:WU00:FS01:0x22:        CWD: C:\Users\xxxx\AppData\Roaming\FAHClient\work
07:27:58:WU00:FS01:0x22:         OS: Windows 10 Home
07:27:58:WU00:FS01:0x22:    OS Arch: AMD64
07:27:58:WU00:FS01:0x22:********************************************************************************
07:27:58:WU00:FS01:0x22:Project: 14564 (Run 747, Clone 1, Gen 76)
07:27:58:WU00:FS01:0x22:Unit: 0x00000080cedfaa925eb08d3ca330514d
07:27:58:WU00:FS01:0x22:Reading tar file core.xml
07:27:58:WU00:FS01:0x22:Reading tar file integrator.xml
07:27:58:WU00:FS01:0x22:Reading tar file state.xml
08:18:33:FS01:Paused
08:18:33:FS01:Shutting core down
08:18:33:WU00:FS01:0x22:WARNING:Console control signal 1 on PID 16404
08:18:33:WU00:FS01:0x22:Exiting, please wait. . .
08:19:34:WARNING:FS01:Killing WU00
08:19:34:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
After that, nothing, I have around 10% CPU use for the FaH_Core22.exe, and the GPU is resting. I can see no hint of any error that occured. The only Warning I can see there is when I pause the slot. I don't know if it can be interpreted as an error.
The current work unit is 14564, but it also did this with another (sorry I can't remember the number). However, what I can say is that I already had both WUs before, as it shows the estimated PPD according to the performance of my graphic card.
The CPU slot works fine (it was previously deleted as my CPU runs very hot when I fold on CPU and GPU).
Thank you for your help, please tell me if you need more info.
Re: Core won't start, no error displayed
Welcome to the F@H Forum Gui924,
Can you please include the first 100 lines which will inform us of what the system configuration is and what the client settings are. If you require guidance, please view this topic: viewtopic.php?f=24&t=26036
Gui924
Post by Gui924 »
Hello,
Sorry about the missing data, are these lines the ones needed ?
*********************** Log Started 2020-06-14T14:56:29Z ***********************
14:56:29:Trying to access database...
14:56:29:Successfully acquired database lock
14:56:29:Downloading GPUs.txt from assign1.foldingathome.org:80
14:56:29:Connecting to assign1.foldingathome.org:80
14:56:30:Read GPUs.txt
14:56:30:Enabled folding slot 00: PAUSED cpu:6 (by user)
14:56:30:Enabled folding slot 01: READY gpu:0:GM206M [GeForce GTX 965M/950]
14:56:30:****************************** FAHClient ******************************
14:56:30:        Version: 7.6.13
14:56:30:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:56:30:      Copyright: 2020 foldingathome.org
14:56:30:       Homepage: https://foldingathome.org/
14:56:30:           Date: Apr 27 2020
14:56:30:           Time: 21:21:01
14:56:30:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
14:56:30:         Branch: master
14:56:30:       Compiler: Visual C++ 2008
14:56:30:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:56:30:       Platform: win32 10
14:56:30:           Bits: 32
14:56:30:           Mode: Release
14:56:30:           Args: --open-web-control
14:56:30:         Config: C:\Users\xxxxx\AppData\Roaming\FAHClient\config.xml
14:56:30:******************************** CBang ********************************
14:56:30:           Date: Apr 24 2020
14:56:30:           Time: 17:07:55
14:56:30:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
14:56:30:           Bits: 32
14:56:30:******************************* System ********************************
14:56:30:            CPU: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
14:56:30:         CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
14:56:30:           CPUs: 8
14:56:30:         Memory: 7.90GiB
14:56:30:    Free Memory: 1.61GiB
14:56:30:        Threads: WINDOWS_THREADS
14:56:30:     OS Version: 6.2
14:56:30:    Has Battery: true
14:56:30:     On Battery: false
14:56:30:     UTC Offset: 2
14:56:30:            PID: 1940
14:56:30:            CWD: C:\Users\xxxxx\AppData\Roaming\FAHClient
14:56:30:  Win32 Service: false
14:56:30:             OS: Windows 10 Home
14:56:30:        OS Arch: AMD64
14:56:30:           GPUs: 1
14:56:30:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GM206M [GeForce GTX 965M/950]
14:56:30:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.2 Driver:10.2
14:56:30:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.50
14:56:30:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.0 Driver:21.20
14:56:30:******************************* libFAH ********************************
14:56:30:           Date: Apr 15 2020
14:56:30:           Time: 14:53:14
14:56:30:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
14:56:30:           Bits: 32
14:56:30:***********************************************************************
14:56:30:<config>
14:56:30:  <!-- Network -->
14:56:30:  <proxy v=':8080'/>
14:56:30:
14:56:30:  <!-- Slot Control -->
14:56:30:  <pause-on-battery v='false'/>
14:56:30:  <power v='medium'/>
14:56:30:
14:56:30:  <!-- User Information -->
14:56:30:  <passkey v='*****'/>
14:56:30:  <user v='Gui924'/>
14:56:30:
14:56:30:  <!-- Folding Slots -->
14:56:30:  <slot id='0' type='CPU'>
14:56:30:    <paused v='true'/>
14:56:30:  </slot>
14:56:30:  <slot id='1' type='GPU'/>
14:56:30:</config>
Thank you.
According to TechPowerUp, your GPU has support for OpenCL 1.2 and Double Precision: https://www.techpowerup.com/gpu-specs/g ... 965m.c2634
Thus, it should be supported. I am not sure why it isn't displaying anything. What happens if you paused the CPU Slot and only let the GPU slot to fold for about 5 to 8 hours. Can you leave it overnight and check back in the morning?
Welcome to Folding@Home!
14:56:30: GPUs: 1
Just because you can, I am betting you are hiding your problem.
I suspect this is a Laptop, and that it uses a technology called Optimus. It uses an Intel GPU until it gets demanding GPU work then switches to the Nvidia GPU. Since F@H is not compatible with Intel GPUs, it is not starting.
https://www.geforce.com/hardware/techno ... technology
I think this line hints you have an Intel GPU
A Decade ago, there were BIOS setting to always use the Nvidia. (this makes your laptop much hotter and greatly reduces battery life) More recently folks have reported that in the Nvidia control Panel in 3D settings there is a setting to always use the Nvidia GPU. At least one person has forced his laptop to use the Nvidia GPU by starting MSI Afterburner and running it in the back ground.
I hope some of these ploys work.
Gui924
Post by Gui924 »
Hello,
As it happens, I was just trying to play with these parameters just now. I updated my Nvidia driver (I should have done that before posting...), and I played with the Optimus settings with the NVidia configuration panel for both FAHClient.exe and Core_0x22.exe, and also changing the global parameter, without success. I've already tried this Optimus trick before as it sometimes chose the wrong graphics cards for games.
It is indeed a laptop, but I've been folding for 3 months with only a problem at the beginning I solved myself (bad NVidia driver was putting my graphics card in the lowest power state).
Should I try to manually put the GPU Index manually in the GPU slot ? Is 0 the right number to put in order to select the NVidia GPU ?
There is also the problem that I don't remember if there was a Windows update before or after this problem occured, I believe it was just after because I tried to reboot several times but I'm not sure.
I can try running the WU for 5-8 hours, I've already tried for around 2 hours without success before.
Thank you for your support.
Gui924
Post by Gui924 »
Hello again,
I tried letting the GPU slot run for about 8 hours, nothing changed at all. I also tried configuring the GPU slot to the NVidia card (0 to everything) instead of the -1 default, without success.
For the moment I'm going to fold on the CPU only, if I find something on my side I'll let you know.
Gui924
Post by Gui924 »
Hello,
I restarted my GPU slot today after removing it for several days and by doing so dismissing the WU I had, and now it works. The core version is the new 0.10 one. I don't know why it works now or why it didn't work back then, I replaced the core with the new one before removing the slot.
At least the problem is solved.
frest1
Post by frest1 »
I can confirm this same issue on HP Z240 and Z2 workstations that have Quadro P4000 and Quadro RTX 4000 GPUs respectively. I’ve noticed this now on four different PCs on maybe 5-6 occasions. It started sometime within a week or so, until then no hiccups whatsoever.
In my case the cure has been: Press pause for the GPU, wait some minute or so until fah is able to kill the stuck core (FahCore_22.exe disappears from taskman), delete the GPU slot and add it again. Starts folding instantly again after this.
At least the Z2 workstations appear to have also secondary, integrated GPUs, if that could be part of problem. But as mentioned, everything worked flawlessly without ANY config changes (other than Win10 updates) until last week..
A bit unpleasant having to keep an eye of my PCs for this issue now..it really does not seem to detect this nor resolve itself at least in 6 hours or so I’ve waited.
EDIT: Fetched some logs for you as well. My own interpretation is that something goes wrong at ":FS01:0x22:Reading tar file state.xml" ?
I filtered out the CPU slot lines (FS00):
*********************** Log Started 2020-06-18T12:43:56Z ***********************
12:43:56:****************************** FAHClient ******************************
12:43:56:        Version: 7.6.9
12:43:56:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:43:56:      Copyright: 2020 foldingathome.org
12:43:56:       Homepage: https://foldingathome.org/
12:43:56:           Date: Apr 17 2020
12:43:56:           Time: 11:13:06
12:43:56:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
12:43:56:         Branch: master
12:43:56:       Compiler: Visual C++ 2008
12:43:56:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:43:56:       Platform: win32 10
12:43:56:           Bits: 32
12:43:56:           Mode: Release
12:43:56:         Config: C:\Program Files (x86)\FAHClient\workdir\config.xml
12:43:56:******************************** CBang ********************************
12:43:56:           Time: 11:10:09
12:43:56:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
12:43:56:           Bits: 32
12:43:56:******************************* System ********************************
12:43:56:            CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
12:43:56:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
12:43:56:           CPUs: 16
12:43:56:         Memory: 31.85GiB
12:43:56:    Free Memory: 28.48GiB
12:43:56:        Threads: WINDOWS_THREADS
12:43:56:     OS Version: 6.2
12:43:56:    Has Battery: false
12:43:56:     On Battery: false
12:43:56:     UTC Offset: 3
12:43:56:            PID: 7048
12:43:56:            CWD: C:\Program Files (x86)\FAHClient\workdir
12:43:56:             OS: Windows 10 Enterprise
12:43:56:        OS Arch: AMD64
12:43:56:           GPUs: 1
12:43:56:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU104GL [Quadro RTX 4000]
12:43:56:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
12:43:56:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.50
12:43:56:  Win32 Service: false
12:43:56:******************************* libFAH ********************************
12:43:56:           Date: Apr 15 2020
12:43:56:           Time: 14:53:14
12:43:56:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
12:43:56:           Bits: 32
12:43:56:***********************************************************************
12:43:56:<config>
12:43:56:  <!-- HTTP Server -->
12:43:56:  <allow v='127.0.0.1 192.168.0.0/24'/>
12:43:56:
12:43:56:  <!-- Network -->
12:43:56:  <proxy v=':1234'/>
12:43:56:
12:43:56:  <!-- Remote Command Server -->
12:43:56:  <password v='*****'/>
12:43:56:
12:43:56:  <!-- Slot Control -->
12:43:56:  <pause-on-battery v='false'/>
12:43:56:
12:43:56:  <!-- User Information -->
12:43:56:  <passkey v='*****'/>
12:43:56:  <user v='USERNAME'/>
12:43:56:
12:43:56:  <!-- Folding Slots -->
12:43:56:  <slot id='0' type='CPU'>
12:43:56:    <cpus v='8'/>
12:43:56:  </slot>
12:43:56:  <slot id='1' type='GPU'/>
12:43:56:</config>
******************************* Date: 2020-06-28 *******************************
07:08:11:WU01:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
07:25:36:WU01:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
07:25:37:WU02:FS01:Connecting to 65.254.110.245:80
07:25:37:WU02:FS01:Assigned to work server 3.133.76.19
07:25:37:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:TU104GL [Quadro RTX 4000] from 3.133.76.19
07:25:37:WU02:FS01:Connecting to 3.133.76.19:8080
07:25:42:WU02:FS01:Downloading 19.29MiB
07:25:48:WU02:FS01:Download 75.15%
07:25:49:WU02:FS01:Download complete
07:25:49:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14462 run:0 clone:1730 gen:10 core:0x22 unit:0x0000000e03854c135eb39e42f33d4d99
07:28:06:WU01:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
07:28:06:WU01:FS01:0x22:Average performance: 115.354 ns/day
07:28:08:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
07:28:08:WU01:FS01:0x22:Saving result file checkpointState.xml
07:28:09:WU01:FS01:0x22:Saving result file globals.csv
07:28:09:WU01:FS01:0x22:Saving result file positions.xtc
07:28:09:WU01:FS01:0x22:Saving result file science.log
07:28:09:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
07:28:10:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
07:28:10:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13414 run:1898 clone:53 gen:0 core:0x22 unit:0x0000000012bc7d9a5ef1aef30e2f726d
07:28:10:WU01:FS01:Uploading 7.45MiB to 18.188.125.154
07:28:10:WU01:FS01:Connecting to 18.188.125.154:8080
07:28:10:WU02:FS01:Starting
07:28:10:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Program Files (x86)\FAHClient\workdir\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe" -dir 02 -suffix 01 -version 706 -lifeline 7048 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
07:28:10:WU02:FS01:Started FahCore on PID 10196
07:28:10:WU02:FS01:Core PID:16400
07:28:10:WU02:FS01:FahCore 0x22 started
07:28:10:WU02:FS01:0x22:*********************** Log Started 2020-06-28T07:28:10Z ***********************
07:28:10:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:28:10:WU02:FS01:0x22:       Core: Core22
07:28:10:WU02:FS01:0x22:       Type: 0x22
07:28:10:WU02:FS01:0x22:    Version: 0.0.10
07:28:10:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:28:10:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
07:28:10:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
07:28:10:WU02:FS01:0x22:       Date: Jun 16 2020
07:28:10:WU02:FS01:0x22:       Time: 14:33:22
07:28:10:WU02:FS01:0x22:   Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
07:28:10:WU02:FS01:0x22:     Branch: core22-0.0.10
07:28:10:WU02:FS01:0x22:   Compiler: Visual C++ 2015
07:28:10:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
07:28:10:WU02:FS01:0x22:   Platform: win32 10
07:28:10:WU02:FS01:0x22:       Bits: 64
07:28:10:WU02:FS01:0x22:       Mode: Release
07:28:10:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:28:10:WU02:FS01:0x22:             <peastman@stanford.edu>
07:28:10:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 10196 -checkpoint 15
07:28:10:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
07:28:10:WU02:FS01:0x22:             0 -gpu 0
07:28:10:WU02:FS01:0x22:************************************ libFAH ************************************
07:28:10:WU02:FS01:0x22:       Date: Jun 15 2020
07:28:10:WU02:FS01:0x22:       Time: 18:05:04
07:28:10:WU02:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
07:28:10:WU02:FS01:0x22:     Branch: HEAD
07:28:10:WU02:FS01:0x22:************************************ CBang *************************************
07:28:10:WU02:FS01:0x22:       Time: 14:31:33
07:28:10:WU02:FS01:0x22:   Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
07:28:10:WU02:FS01:0x22:************************************ System ************************************
07:28:10:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
07:28:10:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
07:28:10:WU02:FS01:0x22:       CPUs: 16
07:28:10:WU02:FS01:0x22:     Memory: 31.85GiB
07:28:10:WU02:FS01:0x22:Free Memory: 25.68GiB
07:28:10:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
07:28:10:WU02:FS01:0x22: OS Version: 6.2
07:28:10:WU02:FS01:0x22:Has Battery: false
07:28:10:WU02:FS01:0x22: On Battery: false
07:28:10:WU02:FS01:0x22: UTC Offset: 3
07:28:10:WU02:FS01:0x22:        PID: 16400
07:28:10:WU02:FS01:0x22:        CWD: C:\Program Files (x86)\FAHClient\workdir\work
07:28:10:WU02:FS01:0x22:********************************************************************************
07:28:10:WU02:FS01:0x22:Project: 14462 (Run 0, Clone 1730, Gen 10)
07:28:10:WU02:FS01:0x22:Unit: 0x0000000e03854c135eb39e42f33d4d99
07:28:10:WU02:FS01:0x22:Reading tar file core.xml
07:28:10:WU02:FS01:0x22:Reading tar file integrator.xml
07:28:10:WU02:FS01:0x22:Reading tar file state.xml
07:28:11:WU02:FS01:0x22:Reading tar file system.xml
07:28:11:WU02:FS01:0x22:Digital signatures verified
07:28:11:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:28:11:WU02:FS01:0x22:Version 0.0.10
07:28:11:WU02:FS01:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
07:28:11:WU02:FS01:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
07:28:11:WU02:FS01:0x22:  XTC frame write interval: 20000 steps (1%) [100 total]
07:28:11:WU02:FS01:0x22:  Global context and integrator variables write interval: disabled
07:28:16:WU01:FS01:Upload 31.86%
07:28:22:WU01:FS01:Upload 65.40%
07:28:27:WU02:FS01:0x22:Completed 0 out of 2000000 steps (0%)
07:28:28:WU01:FS01:Upload 98.10%
07:28:29:WU01:FS01:Upload complete
07:28:29:WU01:FS01:Server responded WORK_ACK (400)
07:28:29:WU01:FS01:Final credit estimate, 157641.00 points
07:28:29:WU01:FS01:Cleaning up
07:30:58:WU02:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
07:53:29:WU02:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
08:18:33:WU02:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
09:58:44:WU02:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
11:35:55:WU02:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
11:35:56:WU00:FS01:Connecting to 65.254.110.245:80
11:35:56:WU00:FS01:Assigned to work server 128.252.203.2
11:35:56:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:TU104GL [Quadro RTX 4000] from 128.252.203.2
11:35:56:WU00:FS01:Connecting to 128.252.203.2:8080
11:36:10:WU00:FS01:Downloading 42.55MiB
11:36:16:WU00:FS01:Download 33.34%
11:36:22:WU00:FS01:Download 69.77%
11:36:27:WU00:FS01:Download complete
11:36:27:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14561 run:0 clone:1840 gen:116 core:0x22 unit:0x000000b380fccb025e9615bff672c1a2
11:38:24:WU02:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
11:38:24:WU02:FS01:0x22:Average performance: 4.63271 ns/day
11:38:29:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
11:38:29:WU02:FS01:0x22:Saving result file checkpointState.xml
11:38:31:WU02:FS01:0x22:Saving result file positions.xtc
11:38:34:WU02:FS01:0x22:Saving result file science.log
11:38:34:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
11:38:35:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:38:35:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:14462 run:0 clone:1730 gen:10 core:0x22 unit:0x0000000e03854c135eb39e42f33d4d99
11:38:35:WU02:FS01:Uploading 88.73MiB to 3.133.76.19
11:38:35:WU02:FS01:Connecting to 3.133.76.19:8080
11:38:35:WU00:FS01:Starting
11:38:35:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Program Files (x86)\FAHClient\workdir\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe" -dir 00 -suffix 01 -version 706 -lifeline 7048 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
11:38:35:WU00:FS01:Started FahCore on PID 17116
11:38:35:WU00:FS01:Core PID:17768
11:38:35:WU00:FS01:FahCore 0x22 started
11:38:36:WU00:FS01:0x22:*********************** Log Started 2020-06-28T11:38:35Z ***********************
11:38:36:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
11:38:36:WU00:FS01:0x22:       Core: Core22
11:38:36:WU00:FS01:0x22:       Type: 0x22
11:38:36:WU00:FS01:0x22:    Version: 0.0.10
11:38:36:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:38:36:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
11:38:36:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
11:38:36:WU00:FS01:0x22:       Date: Jun 16 2020
11:38:36:WU00:FS01:0x22:       Time: 14:33:22
11:38:36:WU00:FS01:0x22:   Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
11:38:36:WU00:FS01:0x22:     Branch: core22-0.0.10
11:38:36:WU00:FS01:0x22:   Compiler: Visual C++ 2015
11:38:36:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
11:38:36:WU00:FS01:0x22:   Platform: win32 10
11:38:36:WU00:FS01:0x22:       Bits: 64
11:38:36:WU00:FS01:0x22:       Mode: Release
11:38:36:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
11:38:36:WU00:FS01:0x22:             <peastman@stanford.edu>
11:38:36:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 17116 -checkpoint 15
11:38:36:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
11:38:36:WU00:FS01:0x22:             0 -gpu 0
11:38:36:WU00:FS01:0x22:************************************ libFAH ************************************
11:38:36:WU00:FS01:0x22:       Date: Jun 15 2020
11:38:36:WU00:FS01:0x22:       Time: 18:05:04
11:38:36:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
11:38:36:WU00:FS01:0x22:     Branch: HEAD
11:38:36:WU00:FS01:0x22:************************************ CBang *************************************
11:38:36:WU00:FS01:0x22:       Time: 14:31:33
11:38:36:WU00:FS01:0x22:   Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
11:38:36:WU00:FS01:0x22:************************************ System ************************************
11:38:36:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
11:38:36:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
11:38:36:WU00:FS01:0x22:       CPUs: 16
11:38:36:WU00:FS01:0x22:     Memory: 31.85GiB
11:38:36:WU00:FS01:0x22:Free Memory: 25.96GiB
11:38:36:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
11:38:36:WU00:FS01:0x22: OS Version: 6.2
11:38:36:WU00:FS01:0x22:Has Battery: false
11:38:36:WU00:FS01:0x22: On Battery: false
11:38:36:WU00:FS01:0x22: UTC Offset: 3
11:38:36:WU00:FS01:0x22:        PID: 17768
11:38:36:WU00:FS01:0x22:        CWD: C:\Program Files (x86)\FAHClient\workdir\work
11:38:36:WU00:FS01:0x22:********************************************************************************
11:38:36:WU00:FS01:0x22:Project: 14561 (Run 0, Clone 1840, Gen 116)
11:38:36:WU00:FS01:0x22:Unit: 0x000000b380fccb025e9615bff672c1a2
11:38:36:WU00:FS01:0x22:Reading tar file core.xml
11:38:36:WU00:FS01:0x22:Reading tar file integrator.xml
11:38:36:WU00:FS01:0x22:Reading tar file state.xml
11:38:37:WU00:FS01:0x22:ERROR:Invalid checksum in tar header calculated=3573 expected=10
11:38:37:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
11:38:37:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
11:38:37:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:38:37:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14561 run:0 clone:1840 gen:116 core:0x22 unit:0x000000b380fccb025e9615bff672c1a2
11:38:37:WU00:FS01:Uploading 1.58KiB to 128.252.203.2
11:38:37:WU00:FS01:Connecting to 128.252.203.2:8080
11:38:37:WU00:FS01:Upload complete
11:38:37:WU00:FS01:Server responded WORK_ACK (400)
11:38:37:WU00:FS01:Cleaning up
11:38:37:WU03:FS01:Connecting to 65.254.110.245:80
11:38:38:WU03:FS01:Assigned to work server 128.252.203.10
11:38:38:WU03:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104GL [Quadro RTX 4000] from 128.252.203.10
11:38:38:WU03:FS01:Connecting to 128.252.203.10:8080
11:38:45:WU03:FS01:Downloading 15.43MiB
11:38:51:WU03:FS01:Download 76.57%
11:38:52:WU03:FS01:Download complete
11:38:52:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:11759 run:0 clone:3891 gen:98 core:0x22 unit:0x000000be80fccb0a5e6d7cb3623206cd
11:38:52:WU03:FS01:Starting
11:38:52:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Program Files (x86)\FAHClient\workdir\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe" -dir 03 -suffix 01 -version 706 -lifeline 7048 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
11:38:52:WU03:FS01:Started FahCore on PID 7096
11:38:52:WU03:FS01:Core PID:6628
11:38:52:WU03:FS01:FahCore 0x22 started
11:38:52:WU02:FS01:Upload 0.21%
11:38:53:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:38:53:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:11759 run:0 clone:3891 gen:98 core:0x22 unit:0x000000be80fccb0a5e6d7cb3623206cd
11:38:53:WU03:FS01:Uploading 1.55KiB to 128.252.203.10
11:38:53:WU03:FS01:Connecting to 128.252.203.10:8080
11:38:53:WU00:FS01:Connecting to 65.254.110.245:80
11:38:53:WU03:FS01:Upload complete
11:38:53:WU03:FS01:Server responded WORK_ACK (400)
11:38:53:WU03:FS01:Cleaning up
11:38:53:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:38:53:WU00:FS01:Connecting to 18.218.241.186:80
11:38:54:WU00:FS01:Assigned to work server 140.163.4.231
11:38:54:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104GL [Quadro RTX 4000] from 140.163.4.231
11:38:54:WU00:FS01:Connecting to 140.163.4.231:8080
11:38:58:WU02:FS01:Upload 2.68%
11:39:28:WU02:FS01:Upload 16.91%
11:39:34:WU02:FS01:Upload 19.72%
11:40:28:WU02:FS01:Upload 45.43%
11:40:32:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:40:32:WU00:FS01:Connecting to 65.254.110.245:80
11:40:33:WU00:FS01:Assigned to work server 13.82.98.119
11:40:33:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104GL [Quadro RTX 4000] from 13.82.98.119
11:40:33:WU00:FS01:Connecting to 13.82.98.119:8080
11:40:34:WU02:FS01:Upload 48.25%
11:40:34:WU00:FS01:Downloading 138.26MiB
11:40:40:WU00:FS01:Download 9.99%
11:40:40:WU02:FS01:Upload 51.14%
11:40:46:WU00:FS01:Download 23.64%
11:40:46:WU02:FS01:Upload 53.96%
11:40:52:WU00:FS01:Download 36.89%
11:40:52:WU02:FS01:Upload 56.85%
11:40:58:WU02:FS01:Upload 59.66%
11:40:58:WU00:FS01:Download 49.32%
11:41:04:WU00:FS01:Download 59.99%
11:41:04:WU02:FS01:Upload 62.48%
11:41:10:WU00:FS01:Download 73.41%
11:41:10:WU02:FS01:Upload 65.37%
11:41:16:WU00:FS01:Download 87.51%
11:41:16:WU02:FS01:Upload 68.19%
11:41:21:WU00:FS01:Download complete
11:41:21:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14416 run:0 clone:329 gen:113 core:0x22 unit:0x000000b00d5262775e84c8a68142844e
11:41:21:WU00:FS01:Starting
11:41:21:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Program Files (x86)\FAHClient\workdir\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe" -dir 00 -suffix 01 -version 706 -lifeline 7048 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
11:41:21:WU00:FS01:Started FahCore on PID 12520
11:41:21:WU00:FS01:Core PID:17396
11:41:21:WU00:FS01:FahCore 0x22 started
11:41:21:WU00:FS01:0x22:*********************** Log Started 2020-06-28T11:41:21Z ***********************
11:41:21:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
11:41:21:WU00:FS01:0x22:       Core: Core22
11:41:21:WU00:FS01:0x22:       Type: 0x22
11:41:21:WU00:FS01:0x22:    Version: 0.0.10
11:41:21:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:41:21:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
11:41:21:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
11:41:21:WU00:FS01:0x22:       Date: Jun 16 2020
11:41:21:WU00:FS01:0x22:       Time: 14:33:22
11:41:21:WU00:FS01:0x22:   Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
11:41:21:WU00:FS01:0x22:     Branch: core22-0.0.10
11:41:21:WU00:FS01:0x22:   Compiler: Visual C++ 2015
11:41:21:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
11:41:21:WU00:FS01:0x22:   Platform: win32 10
11:41:21:WU00:FS01:0x22:       Bits: 64
11:41:21:WU00:FS01:0x22:       Mode: Release
11:41:21:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
11:41:21:WU00:FS01:0x22:             <peastman@stanford.edu>
11:41:21:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 12520 -checkpoint 15
11:41:21:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
11:41:21:WU00:FS01:0x22:             0 -gpu 0
11:41:21:WU00:FS01:0x22:************************************ libFAH ************************************
11:41:21:WU00:FS01:0x22:       Date: Jun 15 2020
11:41:21:WU00:FS01:0x22:       Time: 18:05:04
11:41:21:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
11:41:21:WU00:FS01:0x22:     Branch: HEAD
11:41:21:WU00:FS01:0x22:************************************ CBang *************************************
11:41:21:WU00:FS01:0x22:       Time: 14:31:33
11:41:21:WU00:FS01:0x22:   Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
11:41:21:WU00:FS01:0x22:************************************ System ************************************
11:41:21:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
11:41:21:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
11:41:21:WU00:FS01:0x22:       CPUs: 16
11:41:21:WU00:FS01:0x22:     Memory: 31.85GiB
11:41:21:WU00:FS01:0x22:Free Memory: 26.00GiB
11:41:21:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
11:41:21:WU00:FS01:0x22: OS Version: 6.2
11:41:21:WU00:FS01:0x22:Has Battery: false
11:41:21:WU00:FS01:0x22: On Battery: false
11:41:21:WU00:FS01:0x22: UTC Offset: 3
11:41:21:WU00:FS01:0x22:        PID: 17396
11:41:21:WU00:FS01:0x22:        CWD: C:\Program Files (x86)\FAHClient\workdir\work
11:41:21:WU00:FS01:0x22:********************************************************************************
11:41:21:WU00:FS01:0x22:Project: 14416 (Run 0, Clone 329, Gen 113)
11:41:21:WU00:FS01:0x22:Unit: 0x000000b00d5262775e84c8a68142844e
11:41:21:WU00:FS01:0x22:Reading tar file core.xml
11:41:21:WU00:FS01:0x22:Reading tar file integrator.xml
11:41:21:WU00:FS01:0x22:Reading tar file state.xml
11:41:22:WU00:FS01:0x22:Reading tar file system.xml
11:41:22:WU02:FS01:Upload 71.01%
11:41:22:WU00:FS01:0x22:ERROR:112: calculated hash = ada5009d-dc804ff0-01e9f2ab-851136a4-c962d63a
11:41:22:WU00:FS01:0x22:ERROR:work unit hash = 4bcf88c1-39b88e90-7b8c8859-14b2feea-e248bd70
11:41:22:WU00:FS01:0x22:ERROR:Bad work unit. Digital signatures don't match
11:41:22:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
11:41:22:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
11:41:22:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:41:22:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14416 run:0 clone:329 gen:113 core:0x22 unit:0x000000b00d5262775e84c8a68142844e
11:41:22:WU00:FS01:Uploading 5.00KiB to 13.82.98.119
11:41:22:WU00:FS01:Connecting to 13.82.98.119:8080
11:41:22:WU03:FS01:Connecting to 65.254.110.245:80
11:41:22:WU00:FS01:Upload complete
11:41:22:WU00:FS01:Server responded WORK_ACK (400)
11:41:22:WU00:FS01:Cleaning up
11:41:23:WU03:FS01:Assigned to work server 3.133.76.19
11:41:23:WU03:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104GL [Quadro RTX 4000] from 3.133.76.19
11:41:23:WU03:FS01:Connecting to 3.133.76.19:8080
11:41:28:WU02:FS01:Upload 73.89%
11:41:34:WU02:FS01:Upload 76.71%
11:41:38:WU03:FS01:Downloading 17.70MiB
11:41:40:WU02:FS01:Upload 79.60%
11:41:44:WU03:FS01:Download 74.15%
11:41:45:WU03:FS01:Download complete
11:41:45:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:14469 run:0 clone:236 gen:64 core:0x22 unit:0x0000006303854c135eb9852fd5a444ce
11:41:45:WU03:FS01:Starting
11:41:45:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Program Files (x86)\FAHClient\workdir\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe" -dir 03 -suffix 01 -version 706 -lifeline 7048 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
11:41:45:WU03:FS01:Started FahCore on PID 15936
11:41:45:WU03:FS01:Core PID:17164
11:41:45:WU03:FS01:FahCore 0x22 started
11:41:46:WU02:FS01:Upload 81.99%
11:41:46:WU03:FS01:0x22:*********************** Log Started 2020-06-28T11:41:45Z ***********************
11:41:46:WU03:FS01:0x22:*************************** Core22 Folding@home Core ***************************
11:41:46:WU03:FS01:0x22:       Core: Core22
11:41:46:WU03:FS01:0x22:       Type: 0x22
11:41:46:WU03:FS01:0x22:    Version: 0.0.10
11:41:46:WU03:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:41:46:WU03:FS01:0x22:  Copyright: 2020 foldingathome.org
11:41:46:WU03:FS01:0x22:   Homepage: https://foldingathome.org/
11:41:46:WU03:FS01:0x22:       Date: Jun 16 2020
11:41:46:WU03:FS01:0x22:       Time: 14:33:22
11:41:46:WU03:FS01:0x22:   Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
11:41:46:WU03:FS01:0x22:     Branch: core22-0.0.10
11:41:46:WU03:FS01:0x22:   Compiler: Visual C++ 2015
11:41:46:WU03:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
11:41:46:WU03:FS01:0x22:   Platform: win32 10
11:41:46:WU03:FS01:0x22:       Bits: 64
11:41:46:WU03:FS01:0x22:       Mode: Release
11:41:46:WU03:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
11:41:46:WU03:FS01:0x22:             <peastman@stanford.edu>
11:41:46:WU03:FS01:0x22:       Args: -dir 03 -suffix 01 -version 706 -lifeline 15936 -checkpoint 15
11:41:46:WU03:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
11:41:46:WU03:FS01:0x22:             0 -gpu 0
11:41:46:WU03:FS01:0x22:************************************ libFAH ************************************
11:41:46:WU03:FS01:0x22:       Date: Jun 15 2020
11:41:46:WU03:FS01:0x22:       Time: 18:05:04
11:41:46:WU03:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
11:41:46:WU03:FS01:0x22:     Branch: HEAD
11:41:46:WU03:FS01:0x22:************************************ CBang *************************************
11:41:46:WU03:FS01:0x22:       Time: 14:31:33
11:41:46:WU03:FS01:0x22:   Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
11:41:46:WU03:FS01:0x22:************************************ System ************************************
11:41:46:WU03:FS01:0x22:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
11:41:46:WU03:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
11:41:46:WU03:FS01:0x22:       CPUs: 16
11:41:46:WU03:FS01:0x22:     Memory: 31.85GiB
11:41:46:WU03:FS01:0x22:Free Memory: 26.01GiB
11:41:46:WU03:FS01:0x22:    Threads: WINDOWS_THREADS
11:41:46:WU03:FS01:0x22: OS Version: 6.2
11:41:46:WU03:FS01:0x22:Has Battery: false
11:41:46:WU03:FS01:0x22: On Battery: false
11:41:46:WU03:FS01:0x22: UTC Offset: 3
11:41:46:WU03:FS01:0x22:        PID: 17164
11:41:46:WU03:FS01:0x22:        CWD: C:\Program Files (x86)\FAHClient\workdir\work
11:41:46:WU03:FS01:0x22:********************************************************************************
11:41:46:WU03:FS01:0x22:Project: 14469 (Run 0, Clone 236, Gen 64)
11:41:46:WU03:FS01:0x22:Unit: 0x0000006303854c135eb9852fd5a444ce
11:41:46:WU03:FS01:0x22:Reading tar file core.xml
11:41:46:WU03:FS01:0x22:Reading tar file integrator.xml
11:41:46:WU03:FS01:0x22:Reading tar file state.xml
11:41:52:WU02:FS01:Upload 84.32%
11:41:58:WU02:FS01:Upload 87.21%
11:42:04:WU02:FS01:Upload 90.02%
11:42:10:WU02:FS01:Upload 92.91%
11:42:16:WU02:FS01:Upload 95.73%
11:42:22:WU02:FS01:Upload 98.62%
11:42:26:WU02:FS01:Upload complete
11:42:26:WU02:FS01:Server responded WORK_ACK (400)
11:42:26:WU02:FS01:Final credit estimate, 265966.00 points
11:42:26:WU02:FS01:Cleaning up
17:40:51:ERROR:Send error: 10053: Palvelimessa oleva ohjelmisto katkaisi muodostetun yhteyden.
17:49:25:ERROR:Send error: 10060: Yhteyden muodostamisyritys epäonnistui, koska vastapuoli ei vastannut oikein määritetyn ajan kuluessa, tai aiemmin muodostettu yhteys epäonnistui, koska palvelin, johon yritettiin muodostaa yhteys, ei vastannut.
18:15:05:ERROR:Send error: 10053: Palvelimessa oleva ohjelmisto katkaisi muodostetun yhteyden.
18:15:07:ERROR:Send error: 10053: Palvelimessa oleva ohjelmisto katkaisi muodostetun yhteyden.
18:41:47:ERROR:Receive error: 10054: Etäpalvelin sulki aiemmin luodun yhteyden.
18:43:14:FS01:Paused *** COMMENT: it was here I noticed the core had not started, proceeded to pause it, restart fah, giving it one more try and then delete slot ***
18:43:14:FS01:Shutting core down
18:43:14:WU03:FS01:0x22:WARNING:Console control signal 1 on PID 17164
18:43:14:WU03:FS01:0x22:Exiting, please wait. . .
18:43:54:Removing old file 'configs/config-20200610-073609.xml'
18:43:54:Saving configuration to config.xml
18:43:54:<config>
18:43:54:  <!-- HTTP Server -->
18:43:54:  <allow v='127.0.0.1 192.168.0.0/24'/>
18:43:54:
18:43:54:  <!-- Network -->
18:43:54:  <proxy v=':1234'/>
18:43:54:
18:43:54:  <!-- Remote Command Server -->
18:43:54:  <password v='*****'/>
18:43:54:
18:43:54:  <!-- Slot Control -->
18:43:54:  <pause-on-battery v='false'/>
18:43:54:
18:43:54:  <!-- User Information -->
18:43:54:  <passkey v='*****'/>
18:43:54:  <user v='USERNAME'/>
18:43:54:
18:43:54:  <!-- Folding Slots -->
18:43:54:  <slot id='0' type='CPU'>
18:43:54:    <cpus v='8'/>
18:43:54:  </slot>
18:43:54:  <slot id='1' type='GPU'>
18:43:54:    <paused v='true'/>
18:43:54:  </slot>
18:43:54:</config>
18:44:15:WARNING:FS01:Killing WU03
18:44:15:Clean exit
*********************** Log Started 2020-06-28T18:44:30Z ***********************
18:44:30:****************************** FAHClient ******************************
18:44:30:        Version: 7.6.9
18:44:30:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:44:30:      Copyright: 2020 foldingathome.org
18:44:30:       Homepage: https://foldingathome.org/
18:44:30:           Date: Apr 17 2020
18:44:30:           Time: 11:13:06
18:44:30:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
18:44:30:         Branch: master
18:44:30:       Compiler: Visual C++ 2008
18:44:30:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:44:30:       Platform: win32 10
18:44:30:           Bits: 32
18:44:30:           Mode: Release
18:44:30:         Config: C:\Program Files (x86)\FAHClient\workdir\config.xml
18:44:30:******************************** CBang ********************************
18:44:30:           Time: 11:10:09
18:44:30:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
18:44:30:           Bits: 32
18:44:30:******************************* System ********************************
18:44:30:            CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
18:44:30:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
18:44:30:           CPUs: 16
18:44:30:         Memory: 31.85GiB
18:44:30:    Free Memory: 26.01GiB
18:44:30:        Threads: WINDOWS_THREADS
18:44:30:     OS Version: 6.2
18:44:30:    Has Battery: false
18:44:30:     On Battery: false
18:44:30:     UTC Offset: 3
18:44:30:            PID: 13208
18:44:30:            CWD: C:\Program Files (x86)\FAHClient\workdir
18:44:30:             OS: Windows 10 Enterprise
18:44:30:        OS Arch: AMD64
18:44:30:           GPUs: 1
18:44:30:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU104GL [Quadro RTX 4000]
18:44:30:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
18:44:30:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.50
18:44:30:  Win32 Service: false
18:44:30:******************************* libFAH ********************************
18:44:30:           Date: Apr 15 2020
18:44:30:           Time: 14:53:14
18:44:30:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
18:44:30:           Bits: 32
18:44:30:***********************************************************************
18:44:30:<config>
18:44:30:  <!-- HTTP Server -->
18:44:30:  <allow v='127.0.0.1 192.168.0.0/24'/>
18:44:30:
18:44:30:  <!-- Network -->
18:44:30:  <proxy v=':1234'/>
18:44:30:
18:44:30:  <!-- Remote Command Server -->
18:44:30:  <password v='*****'/>
18:44:30:
18:44:30:  <!-- Slot Control -->
18:44:30:  <pause-on-battery v='false'/>
18:44:30:
18:44:30:  <!-- User Information -->
18:44:30:  <passkey v='*****'/>
18:44:30:  <user v='USERNAME'/>
18:44:30:
18:44:30:  <!-- Folding Slots -->
18:44:30:  <slot id='0' type='CPU'>
18:44:30:    <cpus v='8'/>
18:44:30:  </slot>
18:44:30:  <slot id='1' type='GPU'>
18:44:30:    <paused v='true'/>
18:44:30:  </slot>
18:44:30:</config>
18:44:30:Trying to access database...
18:44:30:Successfully acquired database lock
18:44:30:Enabled folding slot 00: READY cpu:8
18:44:30:Enabled folding slot 01: PAUSED gpu:0:TU104GL [Quadro RTX 4000] (by user)
18:44:59:FS01:Unpaused
18:44:59:WU03:FS01:Starting
18:44:59:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Program Files (x86)\FAHClient\workdir\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe" -dir 03 -suffix 01 -version 706 -lifeline 13208 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
18:44:59:WU03:FS01:Started FahCore on PID 7928
18:44:59:WU03:FS01:Core PID:6636
18:44:59:WU03:FS01:FahCore 0x22 started
18:45:00:WU03:FS01:0x22:*********************** Log Started 2020-06-28T18:44:59Z ***********************
18:45:00:WU03:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:45:00:WU03:FS01:0x22:       Core: Core22
18:45:00:WU03:FS01:0x22:       Type: 0x22
18:45:00:WU03:FS01:0x22:    Version: 0.0.10
18:45:00:WU03:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:45:00:WU03:FS01:0x22:  Copyright: 2020 foldingathome.org
18:45:00:WU03:FS01:0x22:   Homepage: https://foldingathome.org/
18:45:00:WU03:FS01:0x22:       Date: Jun 16 2020
18:45:00:WU03:FS01:0x22:       Time: 14:33:22
18:45:00:WU03:FS01:0x22:   Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
18:45:00:WU03:FS01:0x22:     Branch: core22-0.0.10
18:45:00:WU03:FS01:0x22:   Compiler: Visual C++ 2015
18:45:00:WU03:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:45:00:WU03:FS01:0x22:   Platform: win32 10
18:45:00:WU03:FS01:0x22:       Bits: 64
18:45:00:WU03:FS01:0x22:       Mode: Release
18:45:00:WU03:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:45:00:WU03:FS01:0x22:             <peastman@stanford.edu>
18:45:00:WU03:FS01:0x22:       Args: -dir 03 -suffix 01 -version 706 -lifeline 7928 -checkpoint 15
18:45:00:WU03:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
18:45:00:WU03:FS01:0x22:             0 -gpu 0
18:45:00:WU03:FS01:0x22:************************************ libFAH ************************************
18:45:00:WU03:FS01:0x22:       Date: Jun 15 2020
18:45:00:WU03:FS01:0x22:       Time: 18:05:04
18:45:00:WU03:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
18:45:00:WU03:FS01:0x22:     Branch: HEAD
18:45:00:WU03:FS01:0x22:************************************ CBang *************************************
18:45:00:WU03:FS01:0x22:       Time: 14:31:33
18:45:00:WU03:FS01:0x22:   Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
18:45:00:WU03:FS01:0x22:************************************ System ************************************
18:45:00:WU03:FS01:0x22:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
18:45:00:WU03:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
18:45:00:WU03:FS01:0x22:       CPUs: 16
18:45:00:WU03:FS01:0x22:     Memory: 31.85GiB
18:45:00:WU03:FS01:0x22:Free Memory: 25.61GiB
18:45:00:WU03:FS01:0x22:    Threads: WINDOWS_THREADS
18:45:00:WU03:FS01:0x22: OS Version: 6.2
18:45:00:WU03:FS01:0x22:Has Battery: false
18:45:00:WU03:FS01:0x22: On Battery: false
18:45:00:WU03:FS01:0x22: UTC Offset: 3
18:45:00:WU03:FS01:0x22:        PID: 6636
18:45:00:WU03:FS01:0x22:        CWD: C:\Program Files (x86)\FAHClient\workdir\work
18:45:00:WU03:FS01:0x22:********************************************************************************
18:45:00:WU03:FS01:0x22:Project: 14469 (Run 0, Clone 236, Gen 64)
18:45:00:WU03:FS01:0x22:Unit: 0x0000006303854c135eb9852fd5a444ce
18:45:00:WU03:FS01:0x22:Reading tar file core.xml
18:45:00:WU03:FS01:0x22:Reading tar file integrator.xml
18:45:00:WU03:FS01:0x22:Reading tar file state.xml
18:45:31:Removing old file 'configs/config-20200610-073825.xml'
18:45:31:Saving configuration to config.xml
18:45:31:<config>
18:45:31:  <!-- HTTP Server -->
18:45:31:  <allow v='127.0.0.1 192.168.0.0/24'/>
18:45:31:
18:45:31:  <!-- Network -->
18:45:31:  <proxy v=':1234'/>
18:45:31:
18:45:31:  <!-- Remote Command Server -->
18:45:31:  <password v='*****'/>
18:45:31:
18:45:31:  <!-- Slot Control -->
18:45:31:  <pause-on-battery v='false'/>
18:45:31:
18:45:31:  <!-- User Information -->
18:45:31:  <passkey v='*****'/>
18:45:31:  <user v='USERNAME'/>
18:45:31:
18:45:31:  <!-- Folding Slots -->
18:45:31:  <slot id='0' type='CPU'>
18:45:31:    <cpus v='8'/>
18:45:31:  </slot>
18:45:31:  <slot id='1' type='GPU'/>
18:45:31:</config>
18:45:35:Removing old file 'configs/config-20200610-073912.xml'
18:45:35:Saving configuration to config.xml
18:45:35:<config>
18:45:35:  <!-- HTTP Server -->
18:45:35:  <allow v='127.0.0.1 192.168.0.0/24'/>
18:45:35:
18:45:35:  <!-- Network -->
18:45:35:  <proxy v=':1234'/>
18:45:35:
18:45:35:  <!-- Remote Command Server -->
18:45:35:  <password v='*****'/>
18:45:35:
18:45:35:  <!-- Slot Control -->
18:45:35:  <pause-on-battery v='false'/>
18:45:35:
18:45:35:  <!-- User Information -->
18:45:35:  <passkey v='*****'/>
18:45:35:  <user v='USERNAME'/>
18:45:35:
18:45:35:  <!-- Folding Slots -->
18:45:35:  <slot id='0' type='CPU'>
18:45:35:    <cpus v='8'/>
18:45:35:  </slot>
18:45:35:</config>
18:45:35:FS01:Shutting core down
18:45:35:WU03:FS01:0x22:WARNING:Console control signal 1 on PID 6636
18:45:35:WU03:FS01:0x22:Exiting, please wait. . .
18:46:32:Removing old file 'configs/config-20200610-075333.xml'
18:46:32:Saving configuration to config.xml
18:46:32:<config>
18:46:32:  <!-- HTTP Server -->
18:46:32:  <allow v='127.0.0.1 192.168.0.0/24'/>
18:46:32:
18:46:32:  <!-- Network -->
18:46:32:  <proxy v=':1234'/>
18:46:32:
18:46:32:  <!-- Remote Command Server -->
18:46:32:  <password v='*****'/>
18:46:32:
18:46:32:  <!-- Slot Control -->
18:46:32:  <pause-on-battery v='false'/>
18:46:32:
18:46:32:  <!-- User Information -->
18:46:32:  <passkey v='*****'/>
18:46:32:  <user v='USERNAME'/>
18:46:32:
18:46:32:  <!-- Folding Slots -->
18:46:32:  <slot id='0' type='CPU'>
18:46:32:    <cpus v='8'/>
18:46:32:  </slot>
18:46:32:</config>
18:46:36:WARNING:FS01:Killing WU03
18:46:36:WU03:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
18:46:36:WARNING:WU03:FS01:Slot ID 1 no longer exists and there are no other matching slots, dumping
18:46:36:WU03:FS01:Sending unit results: id:03 state:SEND error:DUMPED project:14469 run:0 clone:236 gen:64 core:0x22 unit:0x0000006303854c135eb9852fd5a444ce
18:46:36:WU03:FS01:Connecting to 3.133.76.19:8080
18:47:24:Adding folding slot 01: READY gpu:0:TU104GL [Quadro RTX 4000]
18:47:24:Removing old file 'configs/config-20200610-075402.xml'
18:47:24:Saving configuration to config.xml
18:47:24:<config>
18:47:24:  <!-- HTTP Server -->
18:47:24:  <allow v='127.0.0.1 192.168.0.0/24'/>
18:47:24:
18:47:24:  <!-- Network -->
18:47:24:  <proxy v=':1234'/>
18:47:24:
18:47:24:  <!-- Remote Command Server -->
18:47:24:  <password v='*****'/>
18:47:24:
18:47:24:  <!-- Slot Control -->
18:47:24:  <pause-on-battery v='false'/>
18:47:24:
18:47:24:  <!-- User Information -->
18:47:24:  <passkey v='*****'/>
18:47:24:  <user v='USERNAME'/>
18:47:24:
18:47:24:  <!-- Folding Slots -->
18:47:24:  <slot id='0' type='CPU'>
18:47:24:    <cpus v='8'/>
18:47:24:  </slot>
18:47:24:  <slot id='1' type='GPU'/>
18:47:24:</config>
18:47:24:WU01:FS01:Connecting to 65.254.110.245:80
18:47:25:WU01:FS01:Assigned to work server 128.252.203.10
18:47:25:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104GL [Quadro RTX 4000] from 128.252.203.10
18:47:25:WU01:FS01:Connecting to 128.252.203.10:8080
18:47:29:WU01:FS01:Downloading 5.82MiB
18:47:29:WU03:FS01:Server responded WORK_ACK (400)
18:47:29:WU03:FS01:Cleaning up
18:47:33:Removing old file 'configs/config-20200610-075553.xml'
18:47:33:Saving configuration to config.xml
18:47:33:<config>
18:47:33:  <!-- HTTP Server -->
18:47:33:  <allow v='127.0.0.1 192.168.0.0/24'/>
18:47:33:
18:47:33:  <!-- Network -->
18:47:33:  <proxy v=':1234'/>
18:47:33:
18:47:33:  <!-- Remote Command Server -->
18:47:33:  <password v='*****'/>
18:47:33:
18:47:33:  <!-- Slot Control -->
18:47:33:  <pause-on-battery v='false'/>
18:47:33:
18:47:33:  <!-- User Information -->
18:47:33:  <passkey v='*****'/>
18:47:33:  <user v='USERNAME'/>
18:47:33:
18:47:33:  <!-- Folding Slots -->
18:47:33:  <slot id='0' type='CPU'>
18:47:33:    <cpus v='8'/>
18:47:33:  </slot>
18:47:33:  <slot id='1' type='GPU'/>
18:47:33:</config>
18:47:34:WU01:FS01:Download complete
18:47:34:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11760 run:0 clone:7169 gen:62 core:0x22 unit:0x0000007480fccb0a5e6f0e1c49faf646
18:47:34:WU01:FS01:Starting
18:47:34:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Program Files (x86)\FAHClient\workdir\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe" -dir 01 -suffix 01 -version 706 -lifeline 13208 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
18:47:34:WU01:FS01:Started FahCore on PID 5628
18:47:34:WU01:FS01:Core PID:18708
18:47:34:WU01:FS01:FahCore 0x22 started
18:47:34:WU01:FS01:0x22:*********************** Log Started 2020-06-28T18:47:34Z ***********************
18:47:34:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:47:34:WU01:FS01:0x22:       Core: Core22
18:47:34:WU01:FS01:0x22:       Type: 0x22
18:47:34:WU01:FS01:0x22:    Version: 0.0.10
18:47:34:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:47:34:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
18:47:34:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
18:47:34:WU01:FS01:0x22:       Date: Jun 16 2020
18:47:34:WU01:FS01:0x22:       Time: 14:33:22
18:47:34:WU01:FS01:0x22:   Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
18:47:34:WU01:FS01:0x22:     Branch: core22-0.0.10
18:47:34:WU01:FS01:0x22:   Compiler: Visual C++ 2015
18:47:34:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:47:34:WU01:FS01:0x22:   Platform: win32 10
18:47:34:WU01:FS01:0x22:       Bits: 64
18:47:34:WU01:FS01:0x22:       Mode: Release
18:47:34:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:47:34:WU01:FS01:0x22:             <peastman@stanford.edu>
18:47:34:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 5628 -checkpoint 15
18:47:34:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
18:47:34:WU01:FS01:0x22:             0 -gpu 0
18:47:34:WU01:FS01:0x22:************************************ libFAH ************************************
18:47:34:WU01:FS01:0x22:       Date: Jun 15 2020
18:47:34:WU01:FS01:0x22:       Time: 18:05:04
18:47:34:WU01:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
18:47:34:WU01:FS01:0x22:     Branch: HEAD
18:47:34:WU01:FS01:0x22:************************************ CBang *************************************
18:47:34:WU01:FS01:0x22:       Time: 14:31:33
18:47:34:WU01:FS01:0x22:   Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
18:47:34:WU01:FS01:0x22:************************************ System ************************************
18:47:34:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
18:47:34:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
18:47:34:WU01:FS01:0x22:       CPUs: 16
18:47:34:WU01:FS01:0x22:     Memory: 31.85GiB
18:47:34:WU01:FS01:0x22:Free Memory: 25.63GiB
18:47:34:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
18:47:34:WU01:FS01:0x22: OS Version: 6.2
18:47:34:WU01:FS01:0x22:Has Battery: false
18:47:34:WU01:FS01:0x22: On Battery: false
18:47:34:WU01:FS01:0x22: UTC Offset: 3
18:47:34:WU01:FS01:0x22:        PID: 18708
18:47:34:WU01:FS01:0x22:        CWD: C:\Program Files (x86)\FAHClient\workdir\work
18:47:34:WU01:FS01:0x22:********************************************************************************
18:47:34:WU01:FS01:0x22:Project: 11760 (Run 0, Clone 7169, Gen 62)
18:47:34:WU01:FS01:0x22:Unit: 0x0000007480fccb0a5e6f0e1c49faf646
18:47:34:WU01:FS01:0x22:Reading tar file core.xml
18:47:34:WU01:FS01:0x22:Reading tar file integrator.xml
18:47:34:WU01:FS01:0x22:Reading tar file state.xml
18:47:34:WU01:FS01:0x22:Reading tar file system.xml
18:47:34:WU01:FS01:0x22:Digital signatures verified
18:47:34:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:47:34:WU01:FS01:0x22:Version 0.0.10
18:47:34:WU01:FS01:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
18:47:34:WU01:FS01:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
18:47:34:WU01:FS01:0x22:  XTC frame write interval: 50000 steps (2.5%) [40 total]
18:47:34:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
18:47:39:WU01:FS01:0x22:Completed 0 out of 2000000 steps (0%)
18:48:40:WU01:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
18:49:42:WU01:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
18:50:45:WU01:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
18:51:47:WU01:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
frest1
Post by frest1 »
Today this issue came up with one of the HP Z240 / Q P4000 PCs. These machines don't have any integrated GPUs as far as I can tell.
Here's the log for this case:
*********************** Log Started 2020-06-27T12:28:28Z ***********************
12:28:28:************************* Folding@home Client *************************
12:28:28:        Website: https://foldingathome.org/
12:28:28:      Copyright: (c) 2009-2018 foldingathome.org
12:28:28:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:28:28:           Args:
12:28:28:         Config: C:\Users\USERNAME\AppData\Roaming\FAHClient\config.xml
12:28:28:******************************** Build ********************************
12:28:28:        Version: 7.5.1
12:28:28:           Date: May 11 2018
12:28:28:           Time: 13:06:32
12:28:28:     Repository: Git
12:28:28:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
12:28:28:         Branch: master
12:28:28:       Compiler: Visual C++ 2008
12:28:28:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:28:28:       Platform: win32 10
12:28:28:           Bits: 32
12:28:28:           Mode: Release
12:28:28:******************************* System ********************************
12:28:28:            CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
12:28:28:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
12:28:28:           CPUs: 8
12:28:28:         Memory: 31.92GiB
12:28:28:    Free Memory: 24.92GiB
12:28:28:        Threads: WINDOWS_THREADS
12:28:28:     OS Version: 6.2
12:28:28:    Has Battery: false
12:28:28:     On Battery: false
12:28:28:     UTC Offset: 3
12:28:28:            PID: 33940
12:28:28:            CWD: C:\Users\USERNAME\AppData\Roaming\FAHClient
12:28:28:             OS: Windows 10 Enterprise
12:28:28:        OS Arch: AMD64
12:28:28:           GPUs: 1
12:28:28:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GP104GL [Quadro P4000]
12:28:28:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
12:28:28:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.92
12:28:28:  Win32 Service: false
12:28:28:***********************************************************************
******************************* Date: 2020-06-29 *******************************
20:38:45:WU01:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
20:38:46:WU00:FS01:Connecting to 65.254.110.245:8080
20:38:47:WU00:FS01:Assigned to work server 18.188.125.154
20:38:47:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104GL [Quadro P4000] from 18.188.125.154
20:38:47:WU00:FS01:Connecting to 18.188.125.154:8080
20:38:48:WU00:FS01:Downloading 434.70KiB
20:38:48:WU00:FS01:Download complete
20:38:48:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13415 run:3490 clone:34 gen:1 core:0x22 unit:0x0000000312bc7d9a5ef50d28b79a8c6a
20:39:12:WU01:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
20:39:12:WU01:FS01:0x22:Average performance: 644.776 ns/day
20:39:12:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
20:39:12:WU01:FS01:0x22:Saving result file checkpointState.xml
20:39:13:WU01:FS01:0x22:Saving result file globals.csv
20:39:13:WU01:FS01:0x22:Saving result file positions.xtc
20:39:13:WU01:FS01:0x22:Saving result file science.log
20:39:13:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
20:39:13:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:39:13:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13415 run:2472 clone:35 gen:0 core:0x22 unit:0x0000000012bc7d9a5ef1ae6afaac320b
20:39:13:WU01:FS01:Uploading 554.06KiB to 18.188.125.154
20:39:13:WU01:FS01:Connecting to 18.188.125.154:8080
20:39:13:WU00:FS01:Starting
20:39:13:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\USERNAME\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 33940 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:39:13:WU00:FS01:Started FahCore on PID 37232
20:39:14:WU00:FS01:Core PID:38452
20:39:14:WU00:FS01:FahCore 0x22 started
20:39:15:WU01:FS01:Upload complete
20:39:15:WU00:FS01:0x22:*********************** Log Started 2020-06-29T20:39:15Z ***********************
20:39:15:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:39:15:WU00:FS01:0x22:       Core: Core22
20:39:15:WU00:FS01:0x22:       Type: 0x22
20:39:15:WU00:FS01:0x22:    Version: 0.0.10
20:39:15:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:39:15:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
20:39:15:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
20:39:15:WU00:FS01:0x22:       Date: Jun 16 2020
20:39:15:WU00:FS01:0x22:       Time: 14:33:22
20:39:15:WU00:FS01:0x22:   Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
20:39:15:WU00:FS01:0x22:     Branch: core22-0.0.10
20:39:15:WU00:FS01:0x22:   Compiler: Visual C++ 2015
20:39:15:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
20:39:15:WU00:FS01:0x22:   Platform: win32 10
20:39:15:WU00:FS01:0x22:       Bits: 64
20:39:15:WU00:FS01:0x22:       Mode: Release
20:39:15:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
20:39:15:WU00:FS01:0x22:             <peastman@stanford.edu>
20:39:15:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 37232 -checkpoint 15
20:39:15:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
20:39:15:WU00:FS01:0x22:             0 -gpu 0
20:39:15:WU00:FS01:0x22:************************************ libFAH ************************************
20:39:15:WU00:FS01:0x22:       Date: Jun 15 2020
20:39:15:WU00:FS01:0x22:       Time: 18:05:04
20:39:15:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
20:39:15:WU00:FS01:0x22:     Branch: HEAD
20:39:15:WU00:FS01:0x22:************************************ CBang *************************************
20:39:15:WU00:FS01:0x22:       Time: 14:31:33
20:39:15:WU00:FS01:0x22:   Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
20:39:15:WU00:FS01:0x22:************************************ System ************************************
20:39:15:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
20:39:15:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
20:39:15:WU00:FS01:0x22:       CPUs: 8
20:39:15:WU00:FS01:0x22:     Memory: 31.92GiB
20:39:15:WU00:FS01:0x22:Free Memory: 948.13MiB
20:39:15:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
20:39:15:WU00:FS01:0x22: OS Version: 6.2
20:39:15:WU00:FS01:0x22:Has Battery: false
20:39:15:WU00:FS01:0x22: On Battery: false
20:39:15:WU00:FS01:0x22: UTC Offset: 3
20:39:15:WU00:FS01:0x22:        PID: 38452
20:39:15:WU00:FS01:0x22:        CWD: C:\Users\USERNAME\AppData\Roaming\FAHClient\work
20:39:15:WU00:FS01:0x22:********************************************************************************
20:39:15:WU00:FS01:0x22:Project: 13415 (Run 3490, Clone 34, Gen 1)
20:39:15:WU00:FS01:0x22:Unit: 0x0000000312bc7d9a5ef50d28b79a8c6a
20:39:15:WU00:FS01:0x22:Reading tar file core.xml
20:39:15:WU00:FS01:0x22:Reading tar file integrator.xml
20:39:15:WU00:FS01:0x22:Reading tar file state.xml
20:39:15:WU01:FS01:Server responded WORK_ACK (400)
20:39:15:WU01:FS01:Final credit estimate, 17864.00 points
20:39:15:WU01:FS01:Cleaning up
21:17:55:FS01:Paused *** COMMENT: it was here I noticed the slot was stuck at 0,00%, proceeded to pausing and deleting the slot ***
21:17:55:FS01:Shutting core down
21:17:55:WU00:FS01:0x22:WARNING:Console control signal 1 on PID 38452
21:17:55:WU00:FS01:0x22:Exiting, please wait. . .
21:18:23:Removing old file 'configs/config-20200608-090211.xml'
21:18:23:Saving configuration to config.xml
21:18:23:<config>
21:18:23:  <!-- HTTP Server -->
21:18:23:  <allow v='127.0.0.1 192.168.0.0/24'/>
21:18:23:
21:18:23:  <!-- Network -->
21:18:23:  <proxy v=':1234'/>
21:18:23:
21:18:23:  <!-- Remote Command Server -->
21:18:23:  <password v='********************************'/>
21:18:23:
21:18:23:  <!-- Slot Control -->
21:18:23:  <pause-on-battery v='false'/>
21:18:23:
21:18:23:  <!-- User Information -->
21:18:23:  <passkey v='********************************'/>
21:18:23:  <user v='USERNAME'/>
21:18:23:
21:18:23:  <!-- Folding Slots -->
21:18:23:  <slot id='1' type='GPU'>
21:18:23:    <paused v='true'/>
21:18:23:  </slot>
21:18:23:</config>
21:18:38:Removing old file 'configs/config-20200609-104826.xml'
21:18:38:Saving configuration to config.xml
21:18:38:<config>
21:18:38:  <!-- HTTP Server -->
21:18:38:  <allow v='127.0.0.1 192.168.0.0/24'/>
21:18:38:
21:18:38:  <!-- Network -->
21:18:38:  <proxy v=':1234'/>
21:18:38:
21:18:38:  <!-- Remote Command Server -->
21:18:38:  <password v='********************************'/>
21:18:38:
21:18:38:  <!-- Slot Control -->
21:18:38:  <pause-on-battery v='false'/>
21:18:38:
21:18:38:  <!-- User Information -->
21:18:38:  <passkey v='********************************'/>
21:18:38:  <user v='USERNAME'/>
21:18:38:
21:18:38:  <!-- Folding Slots -->
21:18:38:</config>
21:18:56:WARNING:FS01:Killing WU00
21:18:56:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
21:18:56:WARNING:WU00:FS01:Slot ID 1 no longer exists and there are no other matching slots, dumping
21:18:56:WU00:FS01:Sending unit results: id:00 state:SEND error:DUMPED project:13415 run:3490 clone:34 gen:1 core:0x22 unit:0x0000000312bc7d9a5ef50d28b79a8c6a
21:18:56:WU00:FS01:Connecting to 18.188.125.154:8080
21:18:57:WU00:FS01:Server responded WORK_ACK (400)
21:18:57:WU00:FS01:Cleaning up
21:19:06:Adding folding slot 00: READY gpu:0:GP104GL [Quadro P4000]
21:19:06:Removing old file 'configs/config-20200609-131318.xml'
21:19:06:Saving configuration to config.xml
21:19:06:<config>
21:19:06:  <!-- HTTP Server -->
21:19:06:  <allow v='127.0.0.1 192.168.0.0/24'/>
21:19:06:
21:19:06:  <!-- Network -->
21:19:06:  <proxy v=':1234'/>
21:19:06:
21:19:06:  <!-- Remote Command Server -->
21:19:06:  <password v='********************************'/>
21:19:06:
21:19:06:  <!-- Slot Control -->
21:19:06:  <pause-on-battery v='false'/>
21:19:06:
21:19:06:  <!-- User Information -->
21:19:06:  <passkey v='********************************'/>
21:19:06:  <user v='USERNAME'/>
21:19:06:
21:19:06:  <!-- Folding Slots -->
21:19:06:  <slot id='0' type='GPU'/>
21:19:06:</config>
21:19:06:WU00:FS00:Connecting to 65.254.110.245:8080
21:19:06:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:19:06:WU00:FS00:Connecting to 18.218.241.186:80
21:19:07:WU00:FS00:Assigned to work server 155.247.166.220
21:19:07:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GP104GL [Quadro P4000] from 155.247.166.220
21:19:07:WU00:FS00:Connecting to 155.247.166.220:8080
21:19:08:ERROR:WU00:FS00:Exception: Server did not assign work unit
21:19:08:WU00:FS00:Connecting to 65.254.110.245:8080
21:19:08:WU00:FS00:Assigned to work server 128.252.203.10
21:19:08:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GP104GL [Quadro P4000] from 128.252.203.10
21:19:08:WU00:FS00:Connecting to 128.252.203.10:8080
21:19:12:WU00:FS00:Downloading 5.82MiB
21:19:15:WU00:FS00:Download complete
21:19:15:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11760 run:0 clone:2508 gen:59 core:0x22 unit:0x0000007580fccb0a5e6d7ced5a547d23
21:19:15:WU00:FS00:Starting
21:19:15:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\USERNAME\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 33940 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:19:15:WU00:FS00:Started FahCore on PID 26412
21:19:15:WU00:FS00:Core PID:39804
21:19:15:WU00:FS00:FahCore 0x22 started
21:19:16:WU00:FS00:0x22:*********************** Log Started 2020-06-29T21:19:15Z ***********************
21:19:16:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
21:19:16:WU00:FS00:0x22:       Core: Core22
21:19:16:WU00:FS00:0x22:       Type: 0x22
21:19:16:WU00:FS00:0x22:    Version: 0.0.10
21:19:16:WU00:FS00:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:19:16:WU00:FS00:0x22:  Copyright: 2020 foldingathome.org
21:19:16:WU00:FS00:0x22:   Homepage: https://foldingathome.org/
21:19:16:WU00:FS00:0x22:       Date: Jun 16 2020
21:19:16:WU00:FS00:0x22:       Time: 14:33:22
21:19:16:WU00:FS00:0x22:   Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
21:19:16:WU00:FS00:0x22:     Branch: core22-0.0.10
21:19:16:WU00:FS00:0x22:   Compiler: Visual C++ 2015
21:19:16:WU00:FS00:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
21:19:16:WU00:FS00:0x22:   Platform: win32 10
21:19:16:WU00:FS00:0x22:       Bits: 64
21:19:16:WU00:FS00:0x22:       Mode: Release
21:19:16:WU00:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
21:19:16:WU00:FS00:0x22:             <peastman@stanford.edu>
21:19:16:WU00:FS00:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 26412 -checkpoint 15
21:19:16:WU00:FS00:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
21:19:16:WU00:FS00:0x22:             0 -gpu 0
21:19:16:WU00:FS00:0x22:************************************ libFAH ************************************
21:19:16:WU00:FS00:0x22:       Date: Jun 15 2020
21:19:16:WU00:FS00:0x22:       Time: 18:05:04
21:19:16:WU00:FS00:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
21:19:16:WU00:FS00:0x22:     Branch: HEAD
21:19:16:WU00:FS00:0x22:************************************ CBang *************************************
21:19:16:WU00:FS00:0x22:       Time: 14:31:33
21:19:16:WU00:FS00:0x22:   Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
21:19:16:WU00:FS00:0x22:************************************ System ************************************
21:19:16:WU00:FS00:0x22:        CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
21:19:16:WU00:FS00:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
21:19:16:WU00:FS00:0x22:       CPUs: 8
21:19:16:WU00:FS00:0x22:     Memory: 31.92GiB
21:19:16:WU00:FS00:0x22:Free Memory: 23.91GiB
21:19:16:WU00:FS00:0x22:    Threads: WINDOWS_THREADS
21:19:16:WU00:FS00:0x22: OS Version: 6.2
21:19:16:WU00:FS00:0x22:Has Battery: false
21:19:16:WU00:FS00:0x22: On Battery: false
21:19:16:WU00:FS00:0x22: UTC Offset: 3
21:19:16:WU00:FS00:0x22:        PID: 39804
21:19:16:WU00:FS00:0x22:        CWD: C:\Users\USERNAME\AppData\Roaming\FAHClient\work
21:19:16:WU00:FS00:0x22:********************************************************************************
21:19:16:WU00:FS00:0x22:Project: 11760 (Run 0, Clone 2508, Gen 59)
21:19:16:WU00:FS00:0x22:Unit: 0x0000007580fccb0a5e6d7ced5a547d23
21:19:16:WU00:FS00:0x22:Reading tar file core.xml
21:19:16:WU00:FS00:0x22:Reading tar file integrator.xml
21:19:16:WU00:FS00:0x22:Reading tar file state.xml
21:19:16:WU00:FS00:0x22:Reading tar file system.xml
21:19:16:WU00:FS00:0x22:Digital signatures verified
21:19:16:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
21:19:16:WU00:FS00:0x22:Version 0.0.10
21:19:16:WU00:FS00:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
21:19:16:WU00:FS00:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
21:19:16:WU00:FS00:0x22:  XTC frame write interval: 50000 steps (2.5%) [40 total]
21:19:16:WU00:FS00:0x22:  Global context and integrator variables write interval: disabled
21:19:20:WU00:FS00:0x22:Completed 0 out of 2000000 steps (0%)
21:19:24:Removing old file 'configs/config-20200610-055746.xml'
21:19:24:Saving configuration to config.xml
21:19:24:<config>
21:19:24:  <!-- HTTP Server -->
21:19:24:  <allow v='127.0.0.1 192.168.0.0/24'/>
21:19:24:
21:19:24:  <!-- Network -->
21:19:24:  <proxy v=':1234'/>
21:19:24:
21:19:24:  <!-- Remote Command Server -->
21:19:24:  <password v='********************************'/>
21:19:24:
21:19:24:  <!-- Slot Control -->
21:19:24:  <pause-on-battery v='false'/>
21:19:24:
21:19:24:  <!-- User Information -->
21:19:24:  <passkey v='********************************'/>
21:19:24:  <user v='USERNAME'/>
21:19:24:
21:19:24:  <!-- Folding Slots -->
21:19:24:  <slot id='0' type='GPU'/>
21:19:24:</config>
21:20:55:WU00:FS00:0x22:Completed 20000 out of 2000000 steps (1%)
21:22:30:WU00:FS00:0x22:Completed 40000 out of 2000000 steps (2%)
EDIT: Right after reporting this, also noticed the same thing on the HP Z2 / Q RTX4000 machine (same one as in my previous post above). Again, something seems to go wrong at ":FS01:0x22:Reading tar file state.xml", log here:
21:24:43:WU02:FS01:0x22:Completed 3960000 out of 4000000 steps (99%)
21:24:44:WU00:FS01:Connecting to 65.254.110.245:80
21:24:44:WU00:FS01:Assigned to work server 18.188.125.154
21:24:44:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:TU104GL [Quadro RTX 4000] from 18.188.125.154
21:24:44:WU00:FS01:Connecting to 18.188.125.154:8080
21:24:49:WU00:FS01:Downloading 9.20MiB
21:24:55:WU00:FS01:Download 72.68%
21:24:56:WU00:FS01:Download complete
21:24:56:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13414 run:2525 clone:69 gen:0 core:0x22 unit:0x0000000012bc7d9a5ef1aecbae3ba19e
21:26:33:WU02:FS01:0x22:Completed 4000000 out of 4000000 steps (100%)
21:26:33:WU02:FS01:0x22:Average performance: 15.7664 ns/day
21:26:35:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
21:26:35:WU02:FS01:0x22:Saving result file checkpointState.xml
21:26:36:WU02:FS01:0x22:Saving result file positions.xtc
21:26:36:WU02:FS01:0x22:Saving result file science.log
21:26:36:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
21:26:36:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:26:36:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:14543 run:0 clone:867 gen:61 core:0x22 unit:0x0000005b80fccb045e7fc1bf4e771ef6
21:26:36:WU02:FS01:Uploading 8.89MiB to 128.252.203.4
21:26:36:WU00:FS01:Starting
21:26:36:WU02:FS01:Connecting to 128.252.203.4:8080
21:26:36:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Program Files (x86)\FAHClient\workdir\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe" -dir 00 -suffix 01 -version 706 -lifeline 13208 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:26:36:WU00:FS01:Started FahCore on PID 6956
21:26:36:WU00:FS01:Core PID:9792
21:26:36:WU00:FS01:FahCore 0x22 started
21:26:37:WU00:FS01:0x22:*********************** Log Started 2020-06-29T21:26:37Z ***********************
21:26:37:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:26:37:WU00:FS01:0x22:       Core: Core22
21:26:37:WU00:FS01:0x22:       Type: 0x22
21:26:37:WU00:FS01:0x22:    Version: 0.0.10
21:26:37:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:26:37:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
21:26:37:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
21:26:37:WU00:FS01:0x22:       Date: Jun 16 2020
21:26:37:WU00:FS01:0x22:       Time: 14:33:22
21:26:37:WU00:FS01:0x22:   Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
21:26:37:WU00:FS01:0x22:     Branch: core22-0.0.10
21:26:37:WU00:FS01:0x22:   Compiler: Visual C++ 2015
21:26:37:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
21:26:37:WU00:FS01:0x22:   Platform: win32 10
21:26:37:WU00:FS01:0x22:       Bits: 64
21:26:37:WU00:FS01:0x22:       Mode: Release
21:26:37:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
21:26:37:WU00:FS01:0x22:             <peastman@stanford.edu>
21:26:37:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 6956 -checkpoint 15
21:26:37:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
21:26:37:WU00:FS01:0x22:             0 -gpu 0
21:26:37:WU00:FS01:0x22:************************************ libFAH ************************************
21:26:37:WU00:FS01:0x22:       Date: Jun 15 2020
21:26:37:WU00:FS01:0x22:       Time: 18:05:04
21:26:37:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
21:26:37:WU00:FS01:0x22:     Branch: HEAD
21:26:37:WU00:FS01:0x22:************************************ CBang *************************************
21:26:37:WU00:FS01:0x22:       Time: 14:31:33
21:26:37:WU00:FS01:0x22:   Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
21:26:37:WU00:FS01:0x22:************************************ System ************************************
21:26:37:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
21:26:37:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
21:26:37:WU00:FS01:0x22:       CPUs: 16
21:26:37:WU00:FS01:0x22:     Memory: 31.85GiB
21:26:37:WU00:FS01:0x22:Free Memory: 26.33GiB
21:26:37:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
21:26:37:WU00:FS01:0x22: OS Version: 6.2
21:26:37:WU00:FS01:0x22:Has Battery: false
21:26:37:WU00:FS01:0x22: On Battery: false
21:26:37:WU00:FS01:0x22: UTC Offset: 3
21:26:37:WU00:FS01:0x22:        PID: 9792
21:26:37:WU00:FS01:0x22:        CWD: C:\Program Files (x86)\FAHClient\workdir\work
21:26:37:WU00:FS01:0x22:********************************************************************************
21:26:37:WU00:FS01:0x22:Project: 13414 (Run 2525, Clone 69, Gen 0)
21:26:37:WU00:FS01:0x22:Unit: 0x0000000012bc7d9a5ef1aecbae3ba19e
21:26:37:WU00:FS01:0x22:Reading tar file core.xml
21:26:37:WU00:FS01:0x22:Reading tar file integrator.xml
21:26:37:WU00:FS01:0x22:Reading tar file state.xml
21:26:42:WU02:FS01:Upload 63.26%
21:26:45:WU02:FS01:Upload complete
21:26:45:WU02:FS01:Server responded WORK_ACK (400)
21:26:45:WU02:FS01:Final credit estimate, 174464.00 points
21:26:45:WU02:FS01:Cleaning up
21:37:35:FS01:Paused *** COMMENT: Noticed the slot was stuck at 0,00% ***
21:37:35:FS01:Shutting core down
21:37:36:WU00:FS01:0x22:WARNING:Console control signal 1 on PID 9792
21:37:36:WU00:FS01:0x22:Exiting, please wait. . .
21:37:57:Removing old file 'configs/config-20200610-075604.xml'
21:37:57:Saving configuration to config.xml
21:37:57:<config>
21:37:57:  <!-- HTTP Server -->
21:37:57:  <allow v='127.0.0.1 10.15.0.0/24 192.168.0.0/24'/>
21:37:57:
21:37:57:  <!-- Network -->
21:37:57:  <proxy v=':1234'/>
21:37:57:
21:37:57:  <!-- Remote Command Server -->
21:37:57:  <password v='*****'/>
21:37:57:
21:37:57:  <!-- Slot Control -->
21:37:57:  <pause-on-battery v='false'/>
21:37:57:
21:37:57:  <!-- User Information -->
21:37:57:  <passkey v='*****'/>
21:37:57:  <user v='USERNAME'/>
21:37:57:
21:37:57:  <!-- Folding Slots -->
21:37:57:  <slot id='0' type='CPU'>
21:37:57:    <cpus v='8'/>
21:37:57:  </slot>
21:37:57:  <slot id='1' type='GPU'>
21:37:57:    <paused v='true'/>
21:37:57:  </slot>
21:37:57:</config>
21:38:36:WARNING:FS01:Killing WU00
21:38:36:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
21:39:44:Removing old file 'configs/config-20200610-130913.xml'
21:39:44:Saving configuration to config.xml
21:39:44:<config>
21:39:44:  <!-- HTTP Server -->
21:39:44:  <allow v='127.0.0.1 10.15.0.0/24 192.168.0.0/24'/>
21:39:44:
21:39:44:  <!-- Network -->
21:39:44:  <proxy v=':1234'/>
21:39:44:
21:39:44:  <!-- Remote Command Server -->
21:39:44:  <password v='*****'/>
21:39:44:
21:39:44:  <!-- Slot Control -->
21:39:44:  <pause-on-battery v='false'/>
21:39:44:
21:39:44:  <!-- User Information -->
21:39:44:  <passkey v='*****'/>
21:39:44:  <user v='USERNAME'/>
21:39:44:
21:39:44:  <!-- Folding Slots -->
21:39:44:  <slot id='0' type='CPU'>
21:39:44:    <cpus v='8'/>
21:39:44:  </slot>
21:39:44:</config>
21:39:44:WARNING:WU00:Slot ID 1 no longer exists and there are no other matching slots, dumping
21:39:44:WU00:Sending unit results: id:00 state:SEND error:DUMPED project:13414 run:2525 clone:69 gen:0 core:0x22 unit:0x0000000012bc7d9a5ef1aecbae3ba19e
21:39:44:WU00:Connecting to 18.188.125.154:8080
21:39:45:WU00:Server responded WORK_ACK (400)
21:39:45:WU00:Cleaning up
21:39:54:Adding folding slot 01: READY gpu:0:TU104GL [Quadro RTX 4000]
21:39:54:Removing old file 'configs/config-20200612-045241.xml'
21:39:54:Saving configuration to config.xml
21:39:54:<config>
21:39:54:  <!-- HTTP Server -->
21:39:54:  <allow v='127.0.0.1 10.15.0.0/24 192.168.0.0/24'/>
21:39:54:
21:39:54:  <!-- Network -->
21:39:54:  <proxy v=':1234'/>
21:39:54:
21:39:54:  <!-- Remote Command Server -->
21:39:54:  <password v='*****'/>
21:39:54:
21:39:54:  <!-- Slot Control -->
21:39:54:  <pause-on-battery v='false'/>
21:39:54:
21:39:54:  <!-- User Information -->
21:39:54:  <passkey v='*****'/>
21:39:54:  <user v='USERNAME'/>
21:39:54:
21:39:54:  <!-- Folding Slots -->
21:39:54:  <slot id='0' type='CPU'>
21:39:54:    <cpus v='8'/>
21:39:54:  </slot>
21:39:54:  <slot id='1' type='GPU'/>
21:39:54:</config>
21:39:54:WU00:FS01:Connecting to 65.254.110.245:80
21:39:54:WU00:FS01:Assigned to work server 18.188.125.154
21:39:54:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104GL [Quadro RTX 4000] from 18.188.125.154
21:39:54:WU00:FS01:Connecting to 18.188.125.154:8080
21:39:59:Removing old file 'configs/config-20200612-045318.xml'
21:39:59:Saving configuration to config.xml
21:39:59:<config>
21:39:59:  <!-- HTTP Server -->
21:39:59:  <allow v='127.0.0.1 10.15.0.0/24 192.168.0.0/24'/>
21:39:59:
21:39:59:  <!-- Network -->
21:39:59:  <proxy v=':1234'/>
21:39:59:
21:39:59:  <!-- Remote Command Server -->
21:39:59:  <password v='*****'/>
21:39:59:
21:39:59:  <!-- Slot Control -->
21:39:59:  <pause-on-battery v='false'/>
21:39:59:
21:39:59:  <!-- User Information -->
21:39:59:  <passkey v='*****'/>
21:39:59:  <user v='USERNAME'/>
21:39:59:
21:39:59:  <!-- Folding Slots -->
21:39:59:  <slot id='0' type='CPU'>
21:39:59:    <cpus v='8'/>
21:39:59:  </slot>
21:39:59:  <slot id='1' type='GPU'/>
21:39:59:</config>
21:40:00:WU00:FS01:Downloading 9.34MiB
21:40:06:WU00:FS01:Download 99.03%
21:40:06:WU00:FS01:Download complete
21:40:06:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13414 run:2876 clone:69 gen:0 core:0x22 unit:0x0000000012bc7d9a5ef1aeb19a8aeb12
21:40:06:WU00:FS01:Starting
21:40:06:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Program Files (x86)\FAHClient\workdir\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe" -dir 00 -suffix 01 -version 706 -lifeline 13208 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:40:06:WU00:FS01:Started FahCore on PID 8704
21:40:06:WU00:FS01:Core PID:7792
21:40:06:WU00:FS01:FahCore 0x22 started
21:40:07:WU00:FS01:0x22:*********************** Log Started 2020-06-29T21:40:07Z ***********************
21:40:07:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:40:07:WU00:FS01:0x22:       Core: Core22
21:40:07:WU00:FS01:0x22:       Type: 0x22
21:40:07:WU00:FS01:0x22:    Version: 0.0.10
21:40:07:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:40:07:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
21:40:07:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
21:40:07:WU00:FS01:0x22:       Date: Jun 16 2020
21:40:07:WU00:FS01:0x22:       Time: 14:33:22
21:40:07:WU00:FS01:0x22:   Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
21:40:07:WU00:FS01:0x22:     Branch: core22-0.0.10
21:40:07:WU00:FS01:0x22:   Compiler: Visual C++ 2015
21:40:07:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
21:40:07:WU00:FS01:0x22:   Platform: win32 10
21:40:07:WU00:FS01:0x22:       Bits: 64
21:40:07:WU00:FS01:0x22:       Mode: Release
21:40:07:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
21:40:07:WU00:FS01:0x22:             <peastman@stanford.edu>
21:40:07:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8704 -checkpoint 15
21:40:07:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
21:40:07:WU00:FS01:0x22:             0 -gpu 0
21:40:07:WU00:FS01:0x22:************************************ libFAH ************************************
21:40:07:WU00:FS01:0x22:       Date: Jun 15 2020
21:40:07:WU00:FS01:0x22:       Time: 18:05:04
21:40:07:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
21:40:07:WU00:FS01:0x22:     Branch: HEAD
21:40:07:WU00:FS01:0x22:************************************ CBang *************************************
21:40:07:WU00:FS01:0x22:       Time: 14:31:33
21:40:07:WU00:FS01:0x22:   Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
21:40:07:WU00:FS01:0x22:************************************ System ************************************
21:40:07:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
21:40:07:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
21:40:07:WU00:FS01:0x22:       CPUs: 16
21:40:07:WU00:FS01:0x22:     Memory: 31.85GiB
21:40:07:WU00:FS01:0x22:Free Memory: 26.12GiB
21:40:07:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
21:40:07:WU00:FS01:0x22: OS Version: 6.2
21:40:07:WU00:FS01:0x22:Has Battery: false
21:40:07:WU00:FS01:0x22: On Battery: false
21:40:07:WU00:FS01:0x22: UTC Offset: 3
21:40:07:WU00:FS01:0x22:        PID: 7792
21:40:07:WU00:FS01:0x22:        CWD: C:\Program Files (x86)\FAHClient\workdir\work
21:40:07:WU00:FS01:0x22:********************************************************************************
21:40:07:WU00:FS01:0x22:Project: 13414 (Run 2876, Clone 69, Gen 0)
21:40:07:WU00:FS01:0x22:Unit: 0x0000000012bc7d9a5ef1aeb19a8aeb12
21:40:07:WU00:FS01:0x22:Reading tar file core.xml
21:40:07:WU00:FS01:0x22:Reading tar file integrator.xml
21:40:07:WU00:FS01:0x22:Reading tar file state.xml
21:40:07:WU00:FS01:0x22:Reading tar file system.xml
21:40:07:WU00:FS01:0x22:Digital signatures verified
21:40:07:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:40:07:WU00:FS01:0x22:Version 0.0.10
21:40:07:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
21:40:07:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
21:40:07:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
21:40:07:WU00:FS01:0x22:  Global context and integrator variables write interval: 250 steps (0.025%) [4000 total]
21:40:19:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
21:42:04:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
Re: Core won't start, no error displayed
Version: 0.0.10 has a problem with file compression. Version: 0.0.11 has been released to beta within the past hour. I'm not sure of it's status.
Your I7 cpu does not have an iGP. That shouldn't matter. You should only be get assignments for you CPU or for your [Quadro RTX 4000]
frest1
Post by frest1 »
Great, thanks for the info bruce. Looking forward to getting the 0.0.11 at some point then!
Yes, thought so too that the i7 computers (with P4000) do not have an iGPU, but the i9-9900Ks on the other computers (with RTX 4000) do. Someone just speculated that an iGPU might have something to do with this problem. But apparently it's likely the compression issue in version 0.0.10 then.
Checking one list, the i7-7700K is listed as having Intel's HD Graphics 630 as an iGPU. Depending on the logic board, presence of a GPU card in the system, and BIOS settings that iGPU may be disabled and not show up as available hardware.
frest1
Post by frest1 »
Unfortunately just had the ”stuck at 0,00%” happen on the HP Z2 (i9 & RTX 4000) client with core version 0.0.11 as well, again at ”state.xml”, log below. If it might have something to do with the problem, this PC has been running headless with RDP used to log a user in. However, before core version 0.0.10 came out, there had not been any problems during the whole time this PC had been folding. And nothing has changed configuration-wise.
18:09:36:WU00:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
18:10:58:WU00:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
18:10:58:WU01:FS01:Connecting to 65.254.110.245:80
18:10:58:WU01:FS01:Assigned to work server 3.133.76.19
18:10:58:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:TU104GL [Quadro RTX 4000] from 3.133.76.19
18:10:58:WU01:FS01:Connecting to 3.133.76.19:8080
18:10:59:ERROR:WU01:FS01:Exception: Server did not assign work unit
18:11:00:WU01:FS01:Connecting to 65.254.110.245:80
18:11:00:WU01:FS01:Assigned to work server 3.133.76.19
18:11:00:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:TU104GL [Quadro RTX 4000] from 3.133.76.19
18:11:00:WU01:FS01:Connecting to 3.133.76.19:8080
18:11:03:WU01:FS01:Downloading 4.15MiB
18:11:05:WU01:FS01:Download complete
18:11:05:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16433 run:1096 clone:4 gen:12 core:0x22 unit:0x0000001103854c135e9a4efebe3d644a
18:11:16:WU02:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
18:12:20:WU00:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
18:12:20:WU00:FS01:0x22:Average performance: 42.1463 ns/day
18:12:24:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
18:12:24:WU00:FS01:0x22:Saving result file checkpointState.xml
18:12:26:WU00:FS01:0x22:Saving result file positions.xtc
18:12:26:WU00:FS01:0x22:Saving result file science.log
18:12:26:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
18:12:26:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:12:26:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11759 run:0 clone:9500 gen:63 core:0x22 unit:0x0000006280fccb0a5e6eafca19d8741b
18:12:26:WU00:FS01:Uploading 14.15MiB to 128.252.203.10
18:12:26:WU00:FS01:Connecting to 128.252.203.10:8080
18:12:26:WU01:FS01:Starting
18:12:26:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Program Files (x86)\FAHClient\workdir\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe" -dir 01 -suffix 01 -version 706 -lifeline 13208 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
18:12:26:WU01:FS01:Started FahCore on PID 7272
18:12:26:WU01:FS01:Core PID:8220
18:12:26:WU01:FS01:FahCore 0x22 started
18:12:27:WU01:FS01:0x22:*********************** Log Started 2020-07-01T18:12:26Z ***********************
18:12:27:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:12:27:WU01:FS01:0x22:       Core: Core22
18:12:27:WU01:FS01:0x22:       Type: 0x22
18:12:27:WU01:FS01:0x22:    Version: 0.0.11
18:12:27:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:12:27:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
18:12:27:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
18:12:27:WU01:FS01:0x22:       Date: Jun 26 2020
18:12:27:WU01:FS01:0x22:       Time: 19:49:16
18:12:27:WU01:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
18:12:27:WU01:FS01:0x22:     Branch: core22-0.0.11
18:12:27:WU01:FS01:0x22:   Compiler: Visual C++ 2015
18:12:27:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:12:27:WU01:FS01:0x22:   Platform: win32 10
18:12:27:WU01:FS01:0x22:       Bits: 64
18:12:27:WU01:FS01:0x22:       Mode: Release
18:12:27:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:12:27:WU01:FS01:0x22:             <peastman@stanford.edu>
18:12:27:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 7272 -checkpoint 15
18:12:27:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
18:12:27:WU01:FS01:0x22:             0 -gpu 0
18:12:27:WU01:FS01:0x22:************************************ libFAH ************************************
18:12:27:WU01:FS01:0x22:       Time: 19:47:12
18:12:27:WU01:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
18:12:27:WU01:FS01:0x22:     Branch: HEAD
18:12:27:WU01:FS01:0x22:************************************ CBang *************************************
18:12:27:WU01:FS01:0x22:       Time: 19:46:11
18:12:27:WU01:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
18:12:27:WU01:FS01:0x22:     Branch: master
18:12:27:WU01:FS01:0x22:************************************ System ************************************
18:12:27:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
18:12:27:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
18:12:27:WU01:FS01:0x22:       CPUs: 16
18:12:27:WU01:FS01:0x22:     Memory: 31.85GiB
18:12:27:WU01:FS01:0x22:Free Memory: 25.68GiB
18:12:27:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
18:12:27:WU01:FS01:0x22: OS Version: 6.2
18:12:27:WU01:FS01:0x22:Has Battery: false
18:12:27:WU01:FS01:0x22: On Battery: false
18:12:27:WU01:FS01:0x22: UTC Offset: 3
18:12:27:WU01:FS01:0x22:        PID: 8220
18:12:27:WU01:FS01:0x22:        CWD: C:\Program Files (x86)\FAHClient\workdir\work
18:12:27:WU01:FS01:0x22:********************************************************************************
18:12:27:WU01:FS01:0x22:Project: 16433 (Run 1096, Clone 4, Gen 12)
18:12:27:WU01:FS01:0x22:Unit: 0x0000001103854c135e9a4efebe3d644a
18:12:27:WU01:FS01:0x22:Reading tar file core.xml
18:12:27:WU01:FS01:0x22:Reading tar file integrator.xml
18:12:27:WU01:FS01:0x22:Reading tar file state.xml
18:12:27:WU01:FS01:0x22:Reading tar file system.xml
18:12:27:WU01:FS01:0x22:Digital signatures verified
18:12:27:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:12:27:WU01:FS01:0x22:Version 0.0.11
18:12:27:WU01:FS01:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
18:12:27:WU01:FS01:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
18:12:27:WU01:FS01:0x22:  XTC frame write interval: 20000 steps (1%) [100 total]
18:12:27:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
18:12:32:WU00:FS01:Upload 15.01%
18:12:35:WU01:FS01:0x22:ERROR:exception: Called setPositions() on a Context with the wrong number of positions
18:12:35:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
18:12:35:WU01:FS01:0x22:Saving result file science.log
18:12:35:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
18:12:36:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:12:36:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:16433 run:1096 clone:4 gen:12 core:0x22 unit:0x0000001103854c135e9a4efebe3d644a
18:12:36:WU01:FS01:Uploading 2.45KiB to 3.133.76.19
18:12:36:WU01:FS01:Connecting to 3.133.76.19:8080
18:12:36:WU03:FS01:Connecting to 65.254.110.245:80
18:12:36:WU01:FS01:Upload complete
18:12:36:WU01:FS01:Server responded WORK_ACK (400)
18:12:36:WU01:FS01:Cleaning up
18:12:37:WU03:FS01:Assigned to work server 18.188.125.154
18:12:37:WU03:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104GL [Quadro RTX 4000] from 18.188.125.154
18:12:37:WU03:FS01:Connecting to 18.188.125.154:8080
18:12:38:WU00:FS01:Upload 32.68%
18:12:44:WU00:FS01:Upload 49.90%
18:12:50:WU00:FS01:Upload 67.12%
18:12:56:WU00:FS01:Upload 84.34%
18:13:02:WU00:FS01:Upload complete
18:13:02:WU00:FS01:Server responded WORK_ACK (400)
18:13:02:WU00:FS01:Final credit estimate, 123305.00 points
18:13:02:WU00:FS01:Cleaning up
18:13:50:WU02:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
18:14:04:WU03:FS01:Downloading 9.21MiB
18:14:10:WU03:FS01:Download 95.68%
18:14:10:WU03:FS01:Download complete
18:14:10:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:13414 run:5877 clone:11 gen:0 core:0x22 unit:0x0000000012bc7d9a5efc2cbf7e5a5562
18:14:10:WU03:FS01:Starting
18:14:10:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Program Files (x86)\FAHClient\workdir\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe" -dir 03 -suffix 01 -version 706 -lifeline 13208 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
18:14:10:WU03:FS01:Started FahCore on PID 17484
18:14:10:WU03:FS01:Core PID:6736
18:14:10:WU03:FS01:FahCore 0x22 started
18:14:10:WU03:FS01:0x22:*********************** Log Started 2020-07-01T18:14:10Z ***********************
18:14:10:WU03:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:14:10:WU03:FS01:0x22:       Core: Core22
18:14:10:WU03:FS01:0x22:       Type: 0x22
18:14:10:WU03:FS01:0x22:    Version: 0.0.11
18:14:10:WU03:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:14:10:WU03:FS01:0x22:  Copyright: 2020 foldingathome.org
18:14:10:WU03:FS01:0x22:   Homepage: https://foldingathome.org/
18:14:10:WU03:FS01:0x22:       Date: Jun 26 2020
18:14:10:WU03:FS01:0x22:       Time: 19:49:16
18:14:10:WU03:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
18:14:10:WU03:FS01:0x22:     Branch: core22-0.0.11
18:14:10:WU03:FS01:0x22:   Compiler: Visual C++ 2015
18:14:10:WU03:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:14:10:WU03:FS01:0x22:   Platform: win32 10
18:14:10:WU03:FS01:0x22:       Bits: 64
18:14:10:WU03:FS01:0x22:       Mode: Release
18:14:10:WU03:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:14:10:WU03:FS01:0x22:             <peastman@stanford.edu>
18:14:10:WU03:FS01:0x22:       Args: -dir 03 -suffix 01 -version 706 -lifeline 17484 -checkpoint 15
18:14:10:WU03:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
18:14:10:WU03:FS01:0x22:             0 -gpu 0
18:14:10:WU03:FS01:0x22:************************************ libFAH ************************************
18:14:10:WU03:FS01:0x22:       Time: 19:47:12
18:14:10:WU03:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
18:14:10:WU03:FS01:0x22:     Branch: HEAD
18:14:10:WU03:FS01:0x22:************************************ CBang *************************************
18:14:10:WU03:FS01:0x22:       Time: 19:46:11
18:14:10:WU03:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
18:14:10:WU03:FS01:0x22:     Branch: master
18:14:10:WU03:FS01:0x22:************************************ System ************************************
18:14:10:WU03:FS01:0x22:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
18:14:10:WU03:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
18:14:10:WU03:FS01:0x22:       CPUs: 16
18:14:10:WU03:FS01:0x22:     Memory: 31.85GiB
18:14:10:WU03:FS01:0x22:Free Memory: 25.72GiB
18:14:10:WU03:FS01:0x22:    Threads: WINDOWS_THREADS
18:14:10:WU03:FS01:0x22: OS Version: 6.2
18:14:10:WU03:FS01:0x22:Has Battery: false
18:14:10:WU03:FS01:0x22: On Battery: false
18:14:10:WU03:FS01:0x22: UTC Offset: 3
18:14:10:WU03:FS01:0x22:        PID: 6736
18:14:10:WU03:FS01:0x22:        CWD: C:\Program Files (x86)\FAHClient\workdir\work
18:14:10:WU03:FS01:0x22:********************************************************************************
18:14:10:WU03:FS01:0x22:Project: 13414 (Run 5877, Clone 11, Gen 0)
18:14:10:WU03:FS01:0x22:Unit: 0x0000000012bc7d9a5efc2cbf7e5a5562
18:14:10:WU03:FS01:0x22:Reading tar file core.xml
18:14:10:WU03:FS01:0x22:Reading tar file integrator.xml
18:14:10:WU03:FS01:0x22:Reading tar file state.xml
18:16:33:WU02:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
18:19:19:WU02:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
18:22:05:WU02:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
18:24:52:WU02:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
18:27:38:WU02:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
18:30:25:WU02:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
18:33:11:WU02:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
18:35:57:WU02:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
18:38:44:WU02:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
18:41:30:WU02:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
18:44:16:WU02:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
18:47:02:WU02:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
18:47:03:WU00:FS00:Connecting to 65.254.110.245:80
18:47:03:WU00:FS00:Assigned to work server 40.114.52.201
18:47:04:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:8 from 40.114.52.201
18:47:04:WU00:FS00:Connecting to 40.114.52.201:8080
18:47:04:WU00:FS00:Downloading 1.49MiB
18:47:05:WU00:FS00:Download complete
18:47:05:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14580 run:0 clone:1034 gen:304 core:0xa7 unit:0x00000173287234c95e7a34b7e24a4e58
******************************* Date: 2020-07-01 *******************************
18:49:48:WU02:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
18:49:52:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
18:49:52:WU02:FS00:0xa7:Saving result file frame88.trr
18:49:52:WU02:FS00:0xa7:Saving result file frame88.xtc
18:49:52:WU02:FS00:0xa7:Saving result file md.log
18:49:52:WU02:FS00:0xa7:Saving result file science.log
18:49:52:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
18:49:52:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:49:52:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:16432 run:421 clone:3 gen:88 core:0xa7 unit:0x0000006ba8f5c67d5e97dc47d8858d8d
18:49:52:WU02:FS00:Uploading 8.47MiB to 168.245.198.125
18:49:52:WU00:FS00:Starting
18:49:52:WU02:FS00:Connecting to 168.245.198.125:8080
18:49:52:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Program Files (x86)\FAHClient\workdir\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 00 -suffix 01 -version 706 -lifeline 13208 -checkpoint 15 -np 8
18:49:52:WU00:FS00:Started FahCore on PID 18672
18:49:53:WU00:FS00:Core PID:15788
18:49:53:WU00:FS00:FahCore 0xa7 started
18:49:53:WU00:FS00:0xa7:*********************** Log Started 2020-07-01T18:49:53Z ***********************
18:49:53:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:49:53:WU00:FS00:0xa7:       Type: 0xa7
18:49:53:WU00:FS00:0xa7:       Core: Gromacs
18:49:53:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 18672 -checkpoint 15 -np
18:49:53:WU00:FS00:0xa7:             8
18:49:53:WU00:FS00:0xa7:************************************ CBang *************************************
18:49:53:WU00:FS00:0xa7:       Date: Oct 26 2019
18:49:53:WU00:FS00:0xa7:       Time: 01:38:25
18:49:53:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:49:53:WU00:FS00:0xa7:     Branch: master
18:49:53:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
18:49:53:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:49:53:WU00:FS00:0xa7:   Platform: win32 10
18:49:53:WU00:FS00:0xa7:       Bits: 64
18:49:53:WU00:FS00:0xa7:       Mode: Release
18:49:53:WU00:FS00:0xa7:************************************ System ************************************
18:49:53:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
18:49:53:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
18:49:53:WU00:FS00:0xa7:       CPUs: 16
18:49:53:WU00:FS00:0xa7:     Memory: 31.85GiB
18:49:53:WU00:FS00:0xa7:Free Memory: 26.04GiB
18:49:53:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
18:49:53:WU00:FS00:0xa7: OS Version: 6.2
18:49:53:WU00:FS00:0xa7:Has Battery: false
18:49:53:WU00:FS00:0xa7: On Battery: false
18:49:53:WU00:FS00:0xa7: UTC Offset: 3
18:49:53:WU00:FS00:0xa7:        PID: 15788
18:49:53:WU00:FS00:0xa7:        CWD: C:\Program Files (x86)\FAHClient\workdir\work
18:49:53:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
18:49:53:WU00:FS00:0xa7:    Version: 0.0.18
18:49:53:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:49:53:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
18:49:53:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
18:49:53:WU00:FS00:0xa7:       Time: 01:52:30
18:49:53:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:49:53:WU00:FS00:0xa7:************************************ Build *************************************
18:49:53:WU00:FS00:0xa7:       SIMD: avx_256
18:49:53:WU00:FS00:0xa7:********************************************************************************
18:49:53:WU00:FS00:0xa7:Project: 14580 (Run 0, Clone 1034, Gen 304)
18:49:53:WU00:FS00:0xa7:Unit: 0x00000173287234c95e7a34b7e24a4e58
18:49:53:WU00:FS00:0xa7:Reading tar file core.xml
18:49:53:WU00:FS00:0xa7:Reading tar file frame304.tpr
18:49:53:WU00:FS00:0xa7:Digital signatures verified
18:49:53:WU00:FS00:0xa7:Calling: mdrun -s frame304.tpr -o frame304.trr -x frame304.xtc -cpt 15 -nt 8
18:49:53:WU00:FS00:0xa7:Steps: first=152000000 total=500000
18:49:53:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
18:49:58:WU02:FS00:Upload 19.93%
18:50:04:WU02:FS00:Upload 44.28%
18:50:10:WU02:FS00:Upload 68.63%
18:50:16:WU02:FS00:Upload 92.99%
18:50:18:WU02:FS00:Upload complete
18:50:18:WU02:FS00:Server responded WORK_ACK (400)
18:50:18:WU02:FS00:Final credit estimate, 16802.00 points
18:50:18:WU02:FS00:Cleaning up
18:50:47:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
18:51:41:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
18:52:35:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
18:53:28:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
18:54:22:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
18:55:16:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
18:56:10:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
18:57:03:WU00:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
18:57:56:WU00:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
18:58:50:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
18:59:43:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
19:00:37:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
19:01:30:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
19:02:24:WU00:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
19:03:17:WU00:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
19:04:11:WU00:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
19:05:05:WU00:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
19:05:58:WU00:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
19:06:52:WU00:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
19:07:45:WU00:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
19:08:39:WU00:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
19:09:32:WU00:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
19:10:26:WU00:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
19:11:19:WU00:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
19:12:13:WU00:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
19:13:07:WU00:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
19:14:00:WU00:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
19:14:54:WU00:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
19:15:48:WU00:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
19:16:42:WU00:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
19:17:35:WU00:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
19:18:29:WU00:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
19:19:22:WU00:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
19:20:16:WU00:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
19:21:10:WU00:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
19:22:03:WU00:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
19:22:56:WU00:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
19:23:50:WU00:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
19:24:43:WU00:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
19:25:37:WU00:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
19:26:30:WU00:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
19:27:24:WU00:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
19:28:17:WU00:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
19:29:11:WU00:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
19:30:05:WU00:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
19:30:58:WU00:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
19:31:21:Removing old file 'configs/config-20200612-045520.xml'
19:31:21:Saving configuration to config.xml
19:31:21:<config>
19:31:21:  <!-- HTTP Server -->
19:31:21:  <allow v='127.0.0.1 10.15.0.0/24 192.168.0.0/24'/>
19:31:21:
19:31:21:  <!-- Network -->
19:31:21:  <proxy v=':1234'/>
19:31:21:
19:31:21:  <!-- Remote Command Server -->
19:31:21:  <password v='*****'/>
19:31:21:
19:31:21:  <!-- Slot Control -->
19:31:21:  <pause-on-battery v='false'/>
19:31:21:
19:31:21:  <!-- User Information -->
19:31:21:  <passkey v='*****'/>
19:31:21:  <user v='USERNAME'/>
19:31:21:
19:31:21:  <!-- Folding Slots -->
19:31:21:  <slot id='0' type='CPU'>
19:31:21:    <cpus v='8'/>
19:31:21:  </slot>
19:31:21:</config>
19:31:21:FS01:Shutting core down
19:31:21:WU03:FS01:0x22:WARNING:Console control signal 1 on PID 6736
19:31:21:WU03:FS01:0x22:Exiting, please wait. . .
19:31:53:WU00:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
19:32:06:Removing old file 'configs/config-20200612-045722.xml'
19:32:06:Saving configuration to config.xml
19:32:06:<config>
19:32:06:  <!-- HTTP Server -->
19:32:06:  <allow v='127.0.0.1 10.15.0.0/24 192.168.0.0/24'/>
19:32:06:
19:32:06:  <!-- Network -->
19:32:06:  <proxy v=':1234'/>
19:32:06:
19:32:06:  <!-- Remote Command Server -->
19:32:06:  <password v='*****'/>
19:32:06:
19:32:06:  <!-- Slot Control -->
19:32:06:  <pause-on-battery v='false'/>
19:32:06:
19:32:06:  <!-- User Information -->
19:32:06:  <passkey v='*****'/>
19:32:06:  <user v='USERNAME'/>
19:32:06:
19:32:06:  <!-- Folding Slots -->
19:32:06:  <slot id='0' type='CPU'>
19:32:06:    <cpus v='8'/>
19:32:06:  </slot>
19:32:06:</config>
19:32:22:WARNING:FS01:Killing WU03
19:32:22:WU03:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
19:32:22:WARNING:WU03:FS01:Slot ID 1 no longer exists and there are no other matching slots, dumping
19:32:22:WU03:FS01:Sending unit results: id:03 state:SEND error:DUMPED project:13414 run:5877 clone:11 gen:0 core:0x22 unit:0x0000000012bc7d9a5efc2cbf7e5a5562
19:32:22:WU03:FS01:Connecting to 18.188.125.154:8080
19:32:43:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
19:32:43:WU03:FS01:Connecting to 18.188.125.154:80
19:32:45:WU00:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
19:33:32:Adding folding slot 01: READY gpu:0:TU104GL [Quadro RTX 4000]
19:33:32:Removing old file 'configs/config-20200625-232542.xml'
19:33:32:Saving configuration to config.xml
19:33:32:<config>
19:33:32:  <!-- HTTP Server -->
19:33:32:  <allow v='127.0.0.1 10.15.0.0/24 192.168.0.0/24'/>
19:33:32:
19:33:32:  <!-- Network -->
19:33:32:  <proxy v=':1234'/>
19:33:32:
19:33:32:  <!-- Remote Command Server -->
19:33:32:  <password v='*****'/>
19:33:32:
19:33:32:  <!-- Slot Control -->
19:33:32:  <pause-on-battery v='false'/>
19:33:32:
19:33:32:  <!-- User Information -->
19:33:32:  <passkey v='*****'/>
19:33:32:  <user v='USERNAME'/>
19:33:32:
19:33:32:  <!-- Folding Slots -->
19:33:32:  <slot id='0' type='CPU'>
19:33:32:    <cpus v='8'/>
19:33:32:  </slot>
19:33:32:  <slot id='1' type='GPU'/>
19:33:32:</config>
19:33:32:WU01:FS01:Connecting to 65.254.110.245:80
19:33:33:WU01:FS01:Assigned to work server 128.252.203.10
19:33:33:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104GL [Quadro RTX 4000] from 128.252.203.10
19:33:33:WU01:FS01:Connecting to 128.252.203.10:8080
19:33:33:WU00:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
19:33:36:WU01:FS01:Downloading 5.82MiB
19:33:39:WU01:FS01:Download complete
19:33:39:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11760 run:0 clone:7705 gen:59 core:0x22 unit:0x0000007580fccb0a5e6f0e60ae6bc047
19:33:39:WU01:FS01:Starting
19:33:39:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Program Files (x86)\FAHClient\workdir\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe" -dir 01 -suffix 01 -version 706 -lifeline 13208 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
19:33:39:WU01:FS01:Started FahCore on PID 9604
19:33:39:WU01:FS01:Core PID:6304
19:33:39:WU01:FS01:FahCore 0x22 started
19:33:39:WU01:FS01:0x22:*********************** Log Started 2020-07-01T19:33:39Z ***********************
19:33:39:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
19:33:39:WU01:FS01:0x22:       Core: Core22
19:33:39:WU01:FS01:0x22:       Type: 0x22
19:33:39:WU01:FS01:0x22:    Version: 0.0.11
19:33:39:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:33:39:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
19:33:39:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
19:33:39:WU01:FS01:0x22:       Date: Jun 26 2020
19:33:39:WU01:FS01:0x22:       Time: 19:49:16
19:33:39:WU01:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
19:33:39:WU01:FS01:0x22:     Branch: core22-0.0.11
19:33:39:WU01:FS01:0x22:   Compiler: Visual C++ 2015
19:33:39:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:33:39:WU01:FS01:0x22:   Platform: win32 10
19:33:39:WU01:FS01:0x22:       Bits: 64
19:33:39:WU01:FS01:0x22:       Mode: Release
19:33:39:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:33:39:WU01:FS01:0x22:             <peastman@stanford.edu>
19:33:39:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 9604 -checkpoint 15
19:33:39:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
19:33:39:WU01:FS01:0x22:             0 -gpu 0
19:33:39:WU01:FS01:0x22:************************************ libFAH ************************************
19:33:39:WU01:FS01:0x22:       Time: 19:47:12
19:33:39:WU01:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
19:33:39:WU01:FS01:0x22:     Branch: HEAD
19:33:39:WU01:FS01:0x22:************************************ CBang *************************************
19:33:39:WU01:FS01:0x22:       Time: 19:46:11
19:33:39:WU01:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
19:33:39:WU01:FS01:0x22:     Branch: master
19:33:39:WU01:FS01:0x22:************************************ System ************************************
19:33:39:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
19:33:39:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
19:33:39:WU01:FS01:0x22:       CPUs: 16
19:33:39:WU01:FS01:0x22:     Memory: 31.85GiB
19:33:39:WU01:FS01:0x22:Free Memory: 25.96GiB
19:33:39:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
19:33:39:WU01:FS01:0x22: OS Version: 6.2
19:33:39:WU01:FS01:0x22:Has Battery: false
19:33:39:WU01:FS01:0x22: On Battery: false
19:33:39:WU01:FS01:0x22: UTC Offset: 3
19:33:39:WU01:FS01:0x22:        PID: 6304
19:33:39:WU01:FS01:0x22:        CWD: C:\Program Files (x86)\FAHClient\workdir\work
19:33:39:WU01:FS01:0x22:********************************************************************************
19:33:39:WU01:FS01:0x22:Project: 11760 (Run 0, Clone 7705, Gen 59)
19:33:39:WU01:FS01:0x22:Unit: 0x0000007580fccb0a5e6f0e60ae6bc047
19:33:39:WU01:FS01:0x22:Reading tar file core.xml
19:33:39:WU01:FS01:0x22:Reading tar file integrator.xml
19:33:39:WU01:FS01:0x22:Reading tar file state.xml
19:33:39:WU01:FS01:0x22:Reading tar file system.xml
19:33:39:WU01:FS01:0x22:Digital signatures verified
19:33:39:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:33:39:WU01:FS01:0x22:Version 0.0.11
19:33:39:WU01:FS01:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
19:33:39:WU01:FS01:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
19:33:39:WU01:FS01:0x22:  XTC frame write interval: 50000 steps (2.5%) [40 total]
19:33:39:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
19:33:44:WU01:FS01:0x22:Completed 0 out of 2000000 steps (0%)
19:33:54:WARNING:WU03:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
19:33:54:WU03:FS01:Trying to send results to collection server
19:33:54:WU03:FS01:Connecting to 128.252.203.1:8080
19:33:55:WU03:FS01:Server responded WORK_ACK (400)
19:33:55:WU03:FS01:Cleaning up
19:34:08:Removing old file 'configs/config-20200625-232754.xml'
19:34:08:Saving configuration to config.xml
19:34:08:<config>
19:34:08:  <!-- HTTP Server -->
19:34:08:  <allow v='127.0.0.1 10.15.0.0/24 192.168.0.0/24'/>
19:34:08:
19:34:08:  <!-- Network -->
19:34:08:  <proxy v=':1234'/>
19:34:08:
19:34:08:  <!-- Remote Command Server -->
19:34:08:  <password v='*****'/>
19:34:08:
19:34:08:  <!-- Slot Control -->
19:34:08:  <pause-on-battery v='false'/>
19:34:08:
19:34:08:  <!-- User Information -->
19:34:08:  <passkey v='*****'/>
19:34:08:  <user v='USERNAME'/>
19:34:08:
19:34:08:  <!-- Folding Slots -->
19:34:08:  <slot id='0' type='CPU'>
19:34:08:    <cpus v='8'/>
19:34:08:  </slot>
19:34:08:  <slot id='1' type='GPU'/>
19:34:08:</config>
19:34:28:WU00:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
19:34:46:WU01:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
19:35:23:WU00:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
JohnChodera
Pande Group Member
Post by JohnChodera »
Thanks for this report! We're looking into what is going wrong here.
Does the
setPositions()
error happen with all projects, or just 164xx projects?
~ John Chodera // MSKCC
