Progress bar restarts to zero?
afkar.aulia
After several days of folding, progress bar of GPU restarts to 0. Is this normal? I do not fold continuously, so I just do it for several hours a day, and I don't join any team. Is there time limit of each project or something?
Also, the name of the project under GPU bar keeps changing. There are three project numbers that my computer is working on because of it (only one shows at a time, but the next time it starts, it might show a different project), and none of them has ever been completed.
Is there anything wrong with the way I'm doing it?
Re: Progress bar restarts to zero?
Yes, there are time limits for each work unit. It does look like you are having an issue, though.
In order to look into it, we would have to see your log. Please read these instructions for posting your log:
Windows: viewtopic.php?p=327412&f=24#p327412
Linux: viewtopic.php?p=327413&f=24#p327413
Apple: viewtopic.php?p=327414&f=24#p327414
afkar.aulia
Two things might be happening.
First, the good news.
You are assigned a Work Unit (WU) to be processed. It has two types of deadlines, a Preferred Deadline (aka Timeout) and a Final Deadline. If you have a fast system and you run 24x7 you shouldn't have to worry about the deadlines. If you have a slow system and you stop folding overnight, you need to pay attention to them.
In either case, when you finish a WU, the client will automatically return the result to the server and request a new assignment. The title and numbers associated with the WU will change accordingly.
Now the potentially bad news.
There's a known shutdown bug in one or more of the FAHCores. Even if you do a normal Windows shutdown, the checkpoint file may be corrupted and when you restart, you'll be forced to get a new assignment. The (temporary) work-around is do a PAUSE before you do a shutdown.
afkar.aulia
*********************** Log Started 2020-06-15T01:59:38Z ***********************
01:59:38:Trying to access database...
01:59:38:Successfully acquired database lock
01:59:38:Read GPUs.txt
01:59:39:Enabled folding slot 00: READY cpu:1
01:59:44:Enabled folding slot 01: READY gpu:0:[Radeon R2-R5]
01:59:44:****************************** FAHClient ******************************
01:59:44: Version: 7.6.13
01:59:44: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:59:44: Copyright: 2020 foldingathome.org
01:59:44: Homepage: https://foldingathome.org/
01:59:44: Date: Apr 27 2020
01:59:44: Time: 21:21:01
01:59:44: Revision: 5a652817f46116b6e135503af97f18e094414e3b
01:59:44: Branch: master
01:59:44: Compiler: Visual C++ 2008
01:59:44: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:59:44: Platform: win32 10
01:59:44: Bits: 32
01:59:44: Mode: Release
01:59:44: Config: C:\Users\LENOVO\AppData\Roaming\FAHClient\config.xml
01:59:44:******************************** CBang ********************************
01:59:44: Date: Apr 24 2020
01:59:44: Time: 17:07:55
01:59:44: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
01:59:44: Bits: 32
01:59:44:******************************* System ********************************
01:59:44: CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
01:59:44: CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
01:59:44: CPUs: 2
01:59:44: Memory: 3.89GiB
01:59:44: Free Memory: 2.06GiB
01:59:44: Threads: WINDOWS_THREADS
01:59:44: OS Version: 6.2
01:59:44: Has Battery: true
01:59:44: On Battery: false
01:59:44: UTC Offset: 7
01:59:44: PID: 7776
01:59:44: CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient
01:59:44: Win32 Service: false
01:59:44: OS: Windows 10 Home
01:59:44: OS Arch: AMD64
01:59:44: GPUs: 1
01:59:44: GPU 0: Bus:0 Slot:1 Func:0 AMD:5 [Radeon R2-R5]
01:59:44: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
01:59:44: specified module could not be found.
01:59:44:
01:59:44:OpenCL Device 0: Platform:0 Device:0 Bus:0 Slot:1 Compute:1.2 Driver:2686.5
01:59:44:******************************* libFAH ********************************
01:59:44: Date: Apr 15 2020
01:59:44: Time: 14:53:14
01:59:44: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
01:59:44: Bits: 32
01:59:44:***********************************************************************
01:59:44:<config>
01:59:44: <!-- Folding Slot Configuration -->
01:59:44: <cause v='COVID_19'/>
01:59:44:
01:59:44: <!-- Slot Control -->
01:59:44: <power v='MEDIUM'/>
01:59:44:
01:59:44: <!-- User Information -->
01:59:44: <passkey v='*****'/>
01:59:44: <user v='afkar_aulia'/>
01:59:44:
01:59:44: <!-- Folding Slots -->
01:59:44: <slot id='0' type='CPU'/>
01:59:44: <slot id='1' type='GPU'/>
01:59:44:</config>
01:59:44:WU01:FS01:Starting
01:59:44:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/amd/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 706 -lifeline 7776 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
01:59:44:WU01:FS01:Started FahCore on PID 2120
01:59:45:WU01:FS01:Core PID:3512
01:59:45:WU01:FS01:FahCore 0x21 started
01:59:45:WU00:FS00:Starting
01:59:45:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 7776 -checkpoint 15 -np 1
01:59:46:WU00:FS00:Started FahCore on PID 10068
01:59:47:WU00:FS00:Core PID:9476
01:59:47:WU00:FS00:FahCore 0xa7 started
01:59:48:WU01:FS01:0x21:*********************** Log Started 2020-06-15T01:59:47Z ***********************
01:59:48:WU01:FS01:0x21:Project: 16905 (Run 23, Clone 13, Gen 20)
01:59:48:WU01:FS01:0x21:Unit: 0x000000250002894c5ea45b8ae6d73355
01:59:48:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
01:59:48:WU01:FS01:0x21:Machine: 1
01:59:48:WU01:FS01:0x21:Digital signatures verified
01:59:48:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
01:59:48:WU01:FS01:0x21:Version 0.0.20
01:59:48:WU01:FS01:0x21: Found a checkpoint file
01:59:48:WU00:FS00:0xa7:*********************** Log Started 2020-06-15T01:59:48Z ***********************
01:59:48:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
01:59:48:WU00:FS00:0xa7: Type: 0xa7
01:59:48:WU00:FS00:0xa7: Core: Gromacs
01:59:48:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 10068 -checkpoint 15 -np
01:59:48:WU00:FS00:0xa7: 1
01:59:48:WU00:FS00:0xa7:************************************ CBang *************************************
01:59:48:WU00:FS00:0xa7: Date: Oct 26 2019
01:59:48:WU00:FS00:0xa7: Time: 01:38:25
01:59:48:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
01:59:48:WU00:FS00:0xa7: Branch: master
01:59:48:WU00:FS00:0xa7: Compiler: Visual C++ 2008
01:59:48:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:59:48:WU00:FS00:0xa7: Platform: win32 10
01:59:48:WU00:FS00:0xa7: Bits: 64
01:59:48:WU00:FS00:0xa7: Mode: Release
01:59:48:WU00:FS00:0xa7:************************************ System ************************************
01:59:48:WU00:FS00:0xa7: CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
01:59:48:WU00:FS00:0xa7: CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
01:59:48:WU00:FS00:0xa7: CPUs: 2
01:59:48:WU00:FS00:0xa7: Memory: 3.89GiB
01:59:48:WU00:FS00:0xa7:Free Memory: 1.94GiB
01:59:48:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
01:59:48:WU00:FS00:0xa7: OS Version: 6.2
01:59:48:WU00:FS00:0xa7:Has Battery: true
01:59:48:WU00:FS00:0xa7: On Battery: false
01:59:48:WU00:FS00:0xa7: UTC Offset: 7
01:59:48:WU00:FS00:0xa7: PID: 9476
01:59:48:WU00:FS00:0xa7: CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
01:59:48:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
01:59:48:WU00:FS00:0xa7: Version: 0.0.18
01:59:48:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:59:48:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
01:59:48:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
01:59:48:WU00:FS00:0xa7: Time: 01:52:30
01:59:48:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
01:59:48:WU00:FS00:0xa7:************************************ Build *************************************
01:59:48:WU00:FS00:0xa7: SIMD: avx_256
01:59:48:WU00:FS00:0xa7:********************************************************************************
01:59:48:WU00:FS00:0xa7:Project: 13851 (Run 0, Clone 12332, Gen 198)
01:59:49:WU00:FS00:0xa7:Unit: 0x000000e8287234c95e730223422fe3f6
01:59:49:WU00:FS00:0xa7:Digital signatures verified
01:59:49:WU00:FS00:0xa7:Calling: mdrun -s frame198.tpr -o frame198.trr -x frame198.xtc -e frame198.edr -cpi state.cpt -cpt 15 -nt 1
01:59:49:WU00:FS00:0xa7:Steps: first=99000000 total=500000
01:59:51:WU00:FS00:0xa7:Completed 199481 out of 500000 steps (39%)
02:00:24:WU01:FS01:0x21:Completed 4000000 out of 10000000 steps (40%)
02:00:24:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:03:35:WU00:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
02:16:38:3:127.0.0.1:New Web session
02:19:29:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
02:19:29:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
02:19:30:WU00:FS00:Starting
02:19:30:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\LENOVO\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 7776 -checkpoint 15 -np 1
02:19:30:WU00:FS00:Started FahCore on PID 1708
02:19:37:WU00:FS00:Core PID:11140
02:19:37:WU00:FS00:FahCore 0xa7 started
02:19:38:WU00:FS00:0xa7:*********************** Log Started 2020-06-15T02:19:38Z ***********************
02:19:38:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:19:38:WU00:FS00:0xa7: Type: 0xa7
02:19:38:WU00:FS00:0xa7: Core: Gromacs
02:19:38:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 1708 -checkpoint 15 -np 1
02:19:38:WU00:FS00:0xa7:************************************ CBang *************************************
02:19:38:WU00:FS00:0xa7: Date: Oct 26 2019
02:19:38:WU00:FS00:0xa7: Time: 01:38:25
02:19:38:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
02:19:38:WU00:FS00:0xa7: Branch: master
02:19:38:WU00:FS00:0xa7: Compiler: Visual C++ 2008
02:19:38:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:19:38:WU00:FS00:0xa7: Platform: win32 10
02:19:38:WU00:FS00:0xa7: Bits: 64
02:19:38:WU00:FS00:0xa7: Mode: Release
02:19:38:WU00:FS00:0xa7:************************************ System ************************************
02:19:38:WU00:FS00:0xa7: CPU: AMD A4-9125 RADEON R3, 4 COMPUTE CORES 2C+2G
02:19:38:WU00:FS00:0xa7: CPU ID: AuthenticAMD Family 21 Model 112 Stepping 0
02:19:38:WU00:FS00:0xa7: CPUs: 2
02:19:38:WU00:FS00:0xa7: Memory: 3.89GiB
02:19:38:WU00:FS00:0xa7:Free Memory: 762.85MiB
02:19:38:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
02:19:38:WU00:FS00:0xa7: OS Version: 6.2
02:19:38:WU00:FS00:0xa7:Has Battery: true
02:19:38:WU00:FS00:0xa7: On Battery: false
02:19:38:WU00:FS00:0xa7: UTC Offset: 7
02:19:38:WU00:FS00:0xa7: PID: 11140
02:19:38:WU00:FS00:0xa7: CWD: C:\Users\LENOVO\AppData\Roaming\FAHClient\work
02:19:38:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
02:19:38:WU00:FS00:0xa7: Version: 0.0.18
02:19:38:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:19:38:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
02:19:38:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
02:19:38:WU00:FS00:0xa7: Time: 01:52:30
02:19:38:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
02:19:38:WU00:FS00:0xa7:************************************ Build *************************************
02:19:38:WU00:FS00:0xa7: SIMD: avx_256
02:19:38:WU00:FS00:0xa7:********************************************************************************
02:19:38:WU00:FS00:0xa7:Project: 13851 (Run 0, Clone 12332, Gen 198)
02:19:38:WU00:FS00:0xa7:Unit: 0x000000e8287234c95e730223422fe3f6
02:19:38:WU00:FS00:0xa7:Digital signatures verified
02:19:38:WU00:FS00:0xa7:Calling: mdrun -s frame198.tpr -o frame198.trr -x frame198.xtc -e frame198.edr -cpi state.cpt -cpt 15 -nt 1
02:19:40:WU00:FS00:0xa7:Steps: first=99000000 total=500000
02:19:57:WU00:FS00:0xa7:Completed 201611 out of 500000 steps (40%)
02:27:00:WARNING:WU01:FS01:Past final deadline 2020-06-15T02:26:59Z, dumping
02:27:00:WU01:FS01:Shutting core down
02:27:00:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 3512
02:27:00:WU01:FS01:0x21:Exiting, please wait. . .
02:27:01:WU02:FS01:Connecting to assign1.foldingathome.org:80
02:27:02:WU02:FS01:Assigned to work server 128.252.203.10
02:27:02:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:[Radeon R2-R5] from 128.252.203.10
02:27:02:WU02:FS01:Connecting to 128.252.203.10:8080
02:27:04:ERROR:WU02:FS01:Exception: Server did not assign work unit
02:27:04:WU02:FS01:Connecting to assign1.foldingathome.org:80
02:27:05:WU02:FS01:Assigned to work server 128.252.203.2
02:27:05:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:[Radeon R2-R5] from 128.252.203.2
02:27:05:WU02:FS01:Connecting to 128.252.203.2:8080
02:27:26:WU01:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
02:28:01:WU01:FS01:Cleaning up
02:28:59:WU02:FS01:Downloading 28.39MiB
02:29:11:WU02:FS01:Download 0.88%
02:29:17:WU02:FS01:Download 1.32%
02:29:23:WU02:FS01:Download 5.94%
02:29:29:WU02:FS01:Download 18.05%
02:29:35:WU02:FS01:Download 27.74%
02:29:41:WU02:FS01:Download 35.88%
02:29:48:WU02:FS01:Download 38.53%
02:29:54:WU02:FS01:Download 39.63%
02:30:02:WU02:FS01:Download 40.29%
02:30:08:WU02:FS01:Download 40.95%
02:30:10:54:127.0.0.1:New Web session
02:30:14:WU02:FS01:Download 42.05%
02:30:20:WU02:FS01:Download 43.37%
02:30:27:WU02:FS01:Download 44.25%
02:30:54:59:127.0.0.1:New Web session
02:30:56:WU02:FS01:Download 46.45%
02:31:03:WU02:FS01:Download 48.43%
02:31:09:WU02:FS01:Download 49.09%
02:31:15:WU02:FS01:Download 49.97%
02:31:22:WU02:FS01:Download 51.08%
02:31:41:WU02:FS01:Download 51.74%
02:31:47:WU02:FS01:Download 54.82%
02:31:53:WU02:FS01:Download 56.80%
02:31:59:WU02:FS01:Download 58.12%
02:32:05:WU02:FS01:Download 59.44%
02:32:11:WU02:FS01:Download 60.76%
02:32:17:WU02:FS01:Download 61.64%
02:32:24:WU02:FS01:Download 62.52%
02:32:30:WU02:FS01:Download 63.18%
02:32:36:WU02:FS01:Download 64.50%
02:32:42:WU02:FS01:Download 68.69%
02:32:54:WU02:FS01:Download 73.53%
02:33:00:WU02:FS01:Download 74.63%
02:33:11:WU02:FS01:Download 75.29%
02:33:18:WU02:FS01:Download 76.17%
02:33:32:WU02:FS01:Download 76.83%
02:33:38:WU02:FS01:Download 77.93%
02:33:44:WU02:FS01:Download 79.03%
02:33:52:WU02:FS01:Download 80.14%
02:33:58:WU02:FS01:Download 80.80%
02:34:05:WU02:FS01:Download 81.46%
02:34:11:WU02:FS01:Download 81.90%
02:34:17:WU02:FS01:Download 82.56%
02:34:24:WU02:FS01:Download 83.44%
02:34:30:WU02:FS01:Download 84.32%
02:34:36:WU02:FS01:Download 85.20%
02:34:43:WU02:FS01:Download 85.86%
02:34:49:WU02:FS01:Download 86.52%
02:35:40:WU02:FS01:Download 87.77%
02:35:44:ERROR:WU02:FS01:Exception: Transfer failed
02:35:45:WU02:FS01:Connecting to assign1.foldingathome.org:80
02:35:47:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
02:35:48:WU02:FS01:Connecting to assign2.foldingathome.org:80
02:35:49:WU02:FS01:Assigned to work server 128.252.203.10
02:35:51:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:[Radeon R2-R5] from 128.252.203.10
02:35:51:WU02:FS01:Connecting to 128.252.203.10:8080
02:35:53:ERROR:WU02:FS01:Exception: Server did not assign work unit
02:37:23:WU02:FS01:Connecting to assign1.foldingathome.org:80
02:37:25:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
02:37:29:WU02:FS01:Connecting to assign2.foldingathome.org:80
02:37:31:WU02:FS01:Assigned to work server 128.252.203.10
02:37:31:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:[Radeon R2-R5] from 128.252.203.10
02:37:31:WU02:FS01:Connecting to 128.252.203.10:8080
02:37:34:WU02:FS01:Downloading 5.82MiB
02:37:40:WU02:FS01:Download 35.45%
02:37:46:WU02:FS01:Download 51.57%
02:37:52:WU02:FS01:Download 56.94%
02:37:58:WU02:FS01:Download 61.24%
02:38:04:WU02:FS01:Download 69.83%
02:38:10:WU02:FS01:Download 78.43%
02:38:16:WU02:FS01:Download 84.87%
02:38:22:WU02:FS01:Download 92.40%
02:38:28:WU02:FS01:Download 100.00%
02:38:28:WU02:FS01:Download complete
02:38:28:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11760 run:0 clone:8542 gen:49 core:0x22 unit:0x0000006480fccb0a5e6f13f00b8ab2bf
02:38:28:WU02:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
02:38:28:WU02:FS01:Connecting to cores.foldingathome.org:80
02:38:29:WU02:FS01:FahCore 22: Downloading 4.04MiB
02:38:29:ERROR:WU02:FS01:Exception: Transfer failed
02:39:28:WU02:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
02:39:29:WU02:FS01:Connecting to cores.foldingathome.org:80
02:39:30:WU02:FS01:FahCore 22: Downloading 4.04MiB
02:39:31:ERROR:WU02:FS01:Exception: Transfer failed
02:41:05:WU02:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
02:41:05:WU02:FS01:Connecting to cores.foldingathome.org:80
02:41:06:WU02:FS01:FahCore 22: Downloading 4.04MiB
02:41:06:ERROR:WU02:FS01:Exception: Transfer failed
02:43:42:WU02:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
02:43:42:WU02:FS01:Connecting to cores.foldingathome.org:80
02:43:43:WU02:FS01:FahCore 22: Downloading 4.04MiB
02:43:44:ERROR:WU02:FS01:Exception: Transfer failed
02:47:57:WU02:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
02:47:57:WU02:FS01:Connecting to cores.foldingathome.org:80
02:47:57:WU02:FS01:FahCore 22: Downloading 4.04MiB
02:47:58:ERROR:WU02:FS01:Exception: Transfer failed
02:54:48:WU02:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
02:54:48:WU02:FS01:Connecting to cores.foldingathome.org:80
02:54:49:WU02:FS01:FahCore 22: Downloading 4.04MiB
02:54:49:ERROR:WU02:FS01:Exception: Transfer failed
02:57:57:WU00:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
02:58:28:124:127.0.0.1:New Web session
03:05:53:WU02:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
03:05:54:WU02:FS01:Connecting to cores.foldingathome.org:80
03:05:55:WU02:FS01:FahCore 22: Downloading 4.04MiB
03:05:57:ERROR:WU02:FS01:Exception: Transfer failed
03:23:50:WU02:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
03:23:50:WU02:FS01:Connecting to cores.foldingathome.org:80
03:23:51:WU02:FS01:FahCore 22: Downloading 4.04MiB
03:23:52:ERROR:WU02:FS01:Exception: Transfer failed
03:52:52:WU02:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
03:52:52:WU02:FS01:Connecting to cores.foldingathome.org:80
03:52:53:WU02:FS01:FahCore 22: Downloading 4.04MiB
03:52:55:ERROR:WU02:FS01:Exception: Transfer failed
04:21:40:WU00:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
04:39:37:219:127.0.0.1:New Web session
04:39:51:WU02:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
04:39:51:WU02:FS01:Connecting to cores.foldingathome.org:80
04:39:52:WU02:FS01:FahCore 22: Downloading 4.04MiB
04:39:52:ERROR:WU02:FS01:Exception: Transfer failed
04:53:10:WU00:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
05:13:41:WU00:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
05:21:55:227:127.0.0.1:New Web session
05:37:31:WU00:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
05:39:51:WU02:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
05:39:51:WU02:FS01:Connecting to cores.foldingathome.org:80
05:39:52:WU02:FS01:FahCore 22: Downloading 4.04MiB
05:39:53:ERROR:WU02:FS01:Exception: Transfer failed
05:44:26:245:127.0.0.1:New Web session-
afkar.aulia
To be honest, I don't mind even if there is no recorded value to my activity, as long as I'm helpful somewhat, as even my smartphone fold@home does not have username.
But it would be a shame if the work is discarded because the time is up.
If it is the case, is there any possibility to pick the smaller work that my computer can handle instead of getting randomly assigned? As you probably already guessed, I'm unfamiliar with coding world. I can open cmd to show hidden files, but that's the most I can do.
There is a core transfer problem, that I don't know of, and I'll have to pass here. But concerning the work-around indicated above by Bruce, that is, to "do a PAUSE before you do a shutdown", you can do that in the taskbar, on the right side, by clicking the ^, then the Advanced Control icon, and chose Pause in the contextual menu that will then open:
It will pause all WUs.
Welcome to the F@H Forum afkar.aulia,
Considering your system and the fact that you only fold few hours a day, this is what I would suggest that you do:
1) Remove the GPU Slot
2) Change the Folding power slider to full
That way, you will only be folding on your CPU and it will hopefully be able to meet the Timeout deadline.
To remove the GPU Slot, open up Advanced Control (AKA FAHControl) -> Configure -> Slots tab -> Select GPU slot -> Click Remove -> Save
- Hardware configuration: 9950x, 9950x3D, 5950x, 5800x3D
7900xtx, RX9070, Radeon 7, 5700xt, 6900xt, Intel B580 - Location: London
As PantherX suggested, best bet is to delete GPU slot altogether. This APU is of ancient design, and I don't know what AMD were thinking releasing it in 2018 again. It would not make deadlines for the most part even if it was folding 24/7, let alone couple of hours a day.
afkar.aulia
Thank you very much. I will try to disable the gpu first
If you want to play with the GPU, get a much more recent driver the version should be over 3000 in this line
But I bet it will never finish in time.
The processing power of the Radeon R3 IGP in that APU is just too low for current GPU projects, about 175 GFLOPS of FP32. Even running 24 hours a day it is not likely to finish on time. It was released as part of the A4-9125 APU 4 years ago, but the IGP technology is based on GCN 3 which is a year or two older.
