stopped working
eduardo_costa
stopped working
Post by eduardo_costa »
Hello all, i have started folding, a few weeks ago, but now it stopped working and i can´t figure it why, can someone help please?
On the advanced control it says is trying to connect to server 127.0.0.1:36330 but it is stopped at there, it changes to "updating" instead of "connecting" rapidly and is repeating this.
I can´t access the log either so, don´t know how to provide further information about that.
Thank You.
Re: stopped working
The Welcome topic - viewtopic.php?f=61&t=26036 - includes directions on how to navigate to your log file and post it. Included are directions for locating the file on your drive. Separate posts are there for each OS, Windows, Linux and OS X.
eduardo_costa
Re: stopped working
Joe_H wrote:The Welcome topic - viewtopic.php?f=61&t=26036 - includes directions on how to navigate to your log file and post it. Included are directions for locating the file on your drive. Separate posts are there for each OS, Windows, Linux and OS X.
Many Thanks with that, here is what i found on the log:
*********************** Log Started 2020-06-11T15:09:29Z ***********************
15:09:29:Trying to access database...
15:09:29:Successfully acquired database lock
15:09:29:Read GPUs.txt
15:09:29:Enabled folding slot 00: PAUSED cpu:1 (by user)
15:09:29:ERROR:Exception: No available GPUs
15:09:29:ERROR:Exception: Option 'gpu-index' has no default and is not set.
15:09:29:****************************** FAHClient ******************************
15:09:29:        Version: 7.6.13
15:09:29:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:09:29:      Copyright: 2020 foldingathome.org
15:09:29:       Homepage: https://foldingathome.org/
15:09:29:           Date: Apr 27 2020
15:09:29:           Time: 21:21:01
15:09:29:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
15:09:29:         Branch: master
15:09:29:       Compiler: Visual C++ 2008
15:09:29:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:09:29:       Platform: win32 10
15:09:29:           Bits: 32
15:09:29:           Mode: Release
15:09:29:         Config: C:\Users\Eduardo Costa\AppData\Roaming\FAHClient\config.xml
15:09:29:******************************** CBang ********************************
15:09:29:           Date: Apr 24 2020
15:09:29:           Time: 17:07:55
15:09:29:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
15:09:29:           Bits: 32
15:09:29:******************************* System ********************************
15:09:29:            CPU: Intel(R) Pentium(R) Dual CPU T3400 @ 2.16GHz
15:09:29:         CPU ID: GenuineIntel Family 6 Model 15 Stepping 13
15:09:29:           CPUs: 2
15:09:29:         Memory: 3.00GiB
15:09:29:    Free Memory: 1.18GiB
15:09:29:        Threads: WINDOWS_THREADS
15:09:29:     OS Version: 6.1
15:09:29:    Has Battery: true
15:09:29:     On Battery: false
15:09:29:     UTC Offset: 1
15:09:29:            PID: 3804
15:09:29:            CWD: C:\Users\Eduardo Costa\AppData\Roaming\FAHClient
15:09:29:  Win32 Service: false
15:09:29:             OS: Windows 7 Ultimate
15:09:29:        OS Arch: AMD64
15:09:29:           GPUs: 0
15:09:29:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.1 Driver:6.5
15:09:29:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.0 Driver:342.1
15:09:29:******************************* libFAH ********************************
15:09:29:           Date: Apr 15 2020
15:09:29:           Time: 14:53:14
15:09:29:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
15:09:29:           Bits: 32
15:09:29:***********************************************************************
15:09:29:<config>
15:09:29:  <!-- Folding Slot Configuration -->
15:09:29:  <cause v='HIGH_PRIORITY'/>
15:09:29:
15:09:29:  <!-- Slot Control -->
15:09:29:  <power v='FULL'/>
15:09:29:
15:09:29:  <!-- User Information -->
15:09:29:  <passkey v='*****'/>
15:09:29:  <user v='Eduardo_Costa'/>
15:09:29:
15:09:29:  <!-- Folding Slots -->
15:09:29:  <slot id='0' type='CPU'>
15:09:29:    <paused v='true'/>
15:09:29:  </slot>
15:09:29:  <slot id='1' type='GPU'>
15:09:29:  </slot>
15:09:29:</config>
15:09:29:WU00:FS01:Connecting to assign1.foldingathome.org:80
15:09:30:WU00:FS01:Assigned to work server 168.245.198.125
15:09:30:WU00:FS01:Requesting new work unit for slot
15:09:30:ERROR:WU00:FS01:Exception: Option 'gpu-index' has no default and is not set.
15:09:31:WU00:FS01:Connecting to assign1.foldingathome.org:80
15:09:32:WU00:FS01:Assigned to work server 168.245.198.125
15:09:32:WU00:FS01:Requesting new work unit for slot
15:09:32:ERROR:WU00:FS01:Exception: Option 'gpu-index' has no default and is not set.
15:09:45:ERROR:Exception: Connection terminated
15:09:45:ERROR:Socket not open
15:09:50:ERROR:Exception: Connection terminated
15:09:50:ERROR:Socket not open
15:09:55:ERROR:Exception: Connection terminated
15:09:55:ERROR:Socket not open
15:10:01:ERROR:Exception: Connection terminated
15:10:01:ERROR:Socket not open
15:10:06:ERROR:Exception: Connection terminated
15:10:06:ERROR:Socket not open
15:10:11:ERROR:Exception: Connection terminated
15:10:11:ERROR:Socket not open
15:10:16:ERROR:Exception: Connection terminated
15:10:16:ERROR:Socket not open
15:10:21:ERROR:Exception: Connection terminated
15:10:21:ERROR:Socket not open
15:10:26:ERROR:Exception: Connection terminated
15:10:26:ERROR:Socket not open
Reason: added Code tags to log
Re: stopped working
Okay, your folding installation has run into a new bug introduced in the latest version of the client software. A log from the time it stopped working would show that the client downloaded a new copy of the GPUs.txt file. The file had an update that moved your GPU from the supported to the unsupported category and the client is not handling that correctly.
You should be able to correct it by going to the config.xml file in the same location as the log file and editing it to remove the following lines:
 <paused v='true'/>
 </slot>
Save that and reboot your system.
An alternate method would be to uninstall including data, and reinstall. Save a copy of the config.xml file to use for copying and pasting setup entries such as your username, team and passkey.
