Jobs are aborted after reboot
Hi!
Windows 10
CPU + GPU are used by FAH
I think since I updated from FAH 7.6.9 to .13 I have this problem more often. I searched for "reboot abort" in this forum but I found just threads which are too different IMHO.
1. I look into the advanced client and browser client. Both are saying the same value for each CPU and GPU job like 40-80% and 1-5h remaining. Then I shutdown the computer because I don't want to run it over night or I have to reboot for some reason.
2. When I boot again, I have to click in the start menu on Folding@Home to start it (I choose that in the installer, so it's intended behavior). When looking into the advanced client and browser client quite often it happens that one of the jobs (CPU or GPU) has it's old percentage value but it not in green state but yellow. After some seconds it jumps to 0% and becomes green. And it won't jump back to the old value. It really seems to start a new job.
This is really annoying escpecially if it's a 8h job where just 1h was remaining. We got one of the highest prices for electricity here in Europe...
BTW:
- In the browser client the "stop folding -> finish up" function doesn't work. I clicked that before one of my first FAH updates I did but it started the next job. So that job was aborted by the update
Only works in advanced client, IIRC except if it isn't processing anything (then in the end some problem as I mentioned before). But when used also in the browser client the symbols switch to yellow.
- When I reboot the computer I often have the problem that also my browser doesn't find an internet connection although it's via LAN/router. It boots quite fast thanks to SSD. Might FAH have a problem with that? But then it should affect both jobs?
- One time when I clicked pause before shutting down, the client didn't work anymore after the reboot (gpu.txt problem). I had to reinstall the client which means both jobs were aborted.
Please fix these bugs, espcially that ones that appear quite often on my computer.
Thanks.
notting
Windows 10
BTW:
Thanks.
notting
Re: Jobs are aborted after reboot
Welcome to the F@H Forum notting,
Can you please post the log file? Ensure you include the first 100 lines which will inform us of what the system configuration is and what the client settings are. If you require guidance, please view this topic: viewtopic.php?f=24&t=26036
In theory, if you paused the Slots before shutting down the system, it should resume from the last checkpoint. In some rare conditions, it will start at 0% however, if it has corrupted checkpoints, the WU is dumped and it will start a new one. We will know more once we get the log file.
Web Control not having a functional Finish button is a known issue: https://github.com/FoldingAtHome/fah-issues/issues/1415
In theory, F@H should work fine without internet connection as long as it has WUs to fold. You could have discovered a bug but we need the log file to see what is happening and then try to reproduce it.
If you paused the Slots before shutting down, it remembers the paused state so will need to be manually changed to Fold using FAHControl (AKA Advanced Control) or Web Control.
Hi PantherX,
sorry for answering so late and thanks for your help. I thought that I activate e-mail notification when new answers arrive here. Now I found an other setting...
log-20200611-062950.txt
Should I translate non-english parts? (probably the language setting of my OS was used)
Do you need log-20200612-061447.txt?
I think I found one bug more: I definitely have Win10 Pro, not Enterprise. I looked into the corresponding window of Win10.
No, yesterday I clicked pause before shutdown and when I clicked FAH this morning it already run.If you paused the Slots before shutting down, it remembers the paused state so will need to be manually changed to Fold using FAHControl (AKA Advanced Control) or Web Control.
*********************** Log Started 2020-06-10T15:22:22Z ***********************
15:22:22:Trying to access database...
15:22:22:Successfully acquired database lock
15:22:22:Read GPUs.txt
15:22:22:Enabled folding slot 00: READY cpu:14
15:22:23:Enabled folding slot 01: READY gpu:0:GP106 [GeForce GTX 1060 6GB] 4372
15:22:23:****************************** FAHClient ******************************
15:22:23: Version: 7.6.13
15:22:23: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:22:23: Copyright: 2020 foldingathome.org
15:22:23: Homepage: https://foldingathome.org/
15:22:23: Date: Apr 27 2020
15:22:23: Time: 21:21:01
15:22:23: Revision: 5a652817f46116b6e135503af97f18e094414e3b
15:22:23: Branch: master
15:22:23: Compiler: Visual C++ 2008
15:22:23: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:22:23: Platform: win32 10
15:22:23: Bits: 32
15:22:23: Mode: Release
15:22:23: Args: --open-web-control
15:22:23: Config: C:\Users\notting\AppData\Roaming\FAHClient\config.xml
15:22:23:******************************** CBang ********************************
15:22:23: Date: Apr 24 2020
15:22:23: Time: 17:07:55
15:22:23: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
15:22:23: Bits: 32
15:22:23:******************************* System ********************************
15:22:23: CPU: AMD Ryzen 7 1700 Eight-Core Processor
15:22:23: CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
15:22:23: CPUs: 16
15:22:23: Memory: 15.95GiB
15:22:23: Free Memory: 13.51GiB
15:22:23: Threads: WINDOWS_THREADS
15:22:23: OS Version: 6.2
15:22:23: Has Battery: false
15:22:23: On Battery: false
15:22:23: UTC Offset: 2
15:22:23: PID: 11584
15:22:23: CWD: C:\Users\notting\AppData\Roaming\FAHClient
15:22:23: Win32 Service: false
15:22:23: OS: Windows 10 Enterprise
15:22:23: OS Arch: AMD64
15:22:23: GPUs: 1
15:22:23: GPU 0: Bus:38 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 6GB] 4372
15:22:23: CUDA Device 0: Platform:0 Device:0 Bus:38 Slot:0 Compute:6.1 Driver:11.0
15:22:23:OpenCL Device 0: Platform:0 Device:0 Bus:38 Slot:0 Compute:1.2 Driver:446.14
15:22:23:******************************* libFAH ********************************
15:22:23: Date: Apr 15 2020
15:22:23: Time: 14:53:14
15:22:23: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
15:22:23: Bits: 32
15:22:23:***********************************************************************
15:22:23:<config>
15:22:23: <!-- Network -->
15:22:23: <proxy v=':8080'/>
15:22:23:
15:22:23: <!-- Folding Slots -->
15:22:23: <slot id='0' type='CPU'/>
15:22:23: <slot id='1' type='GPU'/>
15:22:23:</config>
15:22:23:WU03:FS00:Starting
15:22:23:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\notting\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 706 -lifeline 11584 -checkpoint 15 -np 14
15:22:23:WU03:FS00:Started FahCore on PID 12092
15:22:23:WU03:FS00:Core PID:12120
15:22:23:WU03:FS00:FahCore 0xa7 started
15:22:23:WU00:FS01:Starting
15:22:23:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\notting\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 11584 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
15:22:24:WU00:FS01:Started FahCore on PID 12188
15:22:24:WU00:FS01:Core PID:12240
15:22:24:WU00:FS01:FahCore 0x22 started
15:22:24:WU03:FS00:0xa7:*********************** Log Started 2020-06-10T15:22:23Z ***********************
15:22:24:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:22:24:WU03:FS00:0xa7: Type: 0xa7
15:22:24:WU03:FS00:0xa7: Core: Gromacs
15:22:24:WU03:FS00:0xa7: Args: -dir 03 -suffix 01 -version 706 -lifeline 12092 -checkpoint 15 -np
15:22:24:WU03:FS00:0xa7: 14
15:22:24:WU03:FS00:0xa7:************************************ CBang *************************************
15:22:24:WU03:FS00:0xa7: Date: Oct 26 2019
15:22:24:WU03:FS00:0xa7: Time: 01:38:25
15:22:24:WU03:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
15:22:24:WU03:FS00:0xa7: Branch: master
15:22:24:WU03:FS00:0xa7: Compiler: Visual C++ 2008
15:22:24:WU03:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:22:24:WU03:FS00:0xa7: Platform: win32 10
15:22:24:WU03:FS00:0xa7: Bits: 64
15:22:24:WU03:FS00:0xa7: Mode: Release
15:22:24:WU03:FS00:0xa7:************************************ System ************************************
15:22:24:WU03:FS00:0xa7: CPU: AMD Ryzen 7 1700 Eight-Core Processor
15:22:24:WU03:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
15:22:24:WU03:FS00:0xa7: CPUs: 16
15:22:24:WU03:FS00:0xa7: Memory: 15.95GiB
15:22:24:WU03:FS00:0xa7:Free Memory: 13.49GiB
15:22:24:WU03:FS00:0xa7: Threads: WINDOWS_THREADS
15:22:24:WU03:FS00:0xa7: OS Version: 6.2
15:22:24:WU03:FS00:0xa7:Has Battery: false
15:22:24:WU03:FS00:0xa7: On Battery: false
15:22:24:WU03:FS00:0xa7: UTC Offset: 2
15:22:24:WU03:FS00:0xa7: PID: 12120
15:22:24:WU03:FS00:0xa7: CWD: C:\Users\notting\AppData\Roaming\FAHClient\work
15:22:24:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
15:22:24:WU03:FS00:0xa7: Version: 0.0.18
15:22:24:WU03:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:22:24:WU03:FS00:0xa7: Copyright: 2019 foldingathome.org
15:22:24:WU03:FS00:0xa7: Homepage: https://foldingathome.org/
15:22:24:WU03:FS00:0xa7: Time: 01:52:30
15:22:24:WU03:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
15:22:24:WU03:FS00:0xa7:************************************ Build *************************************
15:22:24:WU03:FS00:0xa7: SIMD: avx_256
15:22:24:WU03:FS00:0xa7:********************************************************************************
15:22:24:WU03:FS00:0xa7:Project: 16801 (Run 9, Clone 329, Gen 80)
15:22:24:WU03:FS00:0xa7:Unit: 0x0000006282ed0b915e959648521c9b8f
15:22:24:WU03:FS00:0xa7:Digital signatures verified
15:22:24:WU03:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
15:22:24:WU03:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
15:22:24:WU03:FS00:0xa7:Calling: mdrun -s frame80.tpr -o frame80.trr -cpi state.cpt -cpt 15 -nt 12
15:22:24:WU00:FS01:0x22:*********************** Log Started 2020-06-10T15:22:24Z ***********************
15:22:24:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:22:24:WU00:FS01:0x22: Type: 0x22
15:22:24:WU00:FS01:0x22: Core: Core22
15:22:24:WU00:FS01:0x22: Website: https://foldingathome.org/
15:22:24:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
15:22:24:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:22:24:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
15:22:24:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 12188 -checkpoint 15
15:22:24:WU00:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
15:22:24:WU00:FS01:0x22: 0 -gpu 0
15:22:24:WU00:FS01:0x22: Config: <none>
15:22:24:WU00:FS01:0x22:************************************ Build *************************************
15:22:24:WU00:FS01:0x22: Version: 0.0.5
15:22:24:WU00:FS01:0x22: Date: Apr 22 2020
15:22:24:WU00:FS01:0x22: Time: 04:42:59
15:22:24:WU00:FS01:0x22: Repository: Git
15:22:24:WU00:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
15:22:24:WU00:FS01:0x22: Branch: HEAD
15:22:24:WU00:FS01:0x22: Compiler: Visual C++ 2008
15:22:24:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:22:24:WU00:FS01:0x22: Platform: win32 10
15:22:24:WU00:FS01:0x22: Bits: 64
15:22:24:WU00:FS01:0x22: Mode: Release
15:22:24:WU00:FS01:0x22:************************************ System ************************************
15:22:24:WU00:FS01:0x22: CPU: AMD Ryzen 7 1700 Eight-Core Processor
15:22:24:WU00:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
15:22:24:WU00:FS01:0x22: CPUs: 16
15:22:24:WU00:FS01:0x22: Memory: 15.95GiB
15:22:24:WU00:FS01:0x22:Free Memory: 13.46GiB
15:22:24:WU00:FS01:0x22: Threads: WINDOWS_THREADS
15:22:24:WU00:FS01:0x22: OS Version: 6.2
15:22:24:WU00:FS01:0x22:Has Battery: false
15:22:24:WU00:FS01:0x22: On Battery: false
15:22:24:WU00:FS01:0x22: UTC Offset: 2
15:22:24:WU00:FS01:0x22: PID: 12240
15:22:24:WU00:FS01:0x22: CWD: C:\Users\notting\AppData\Roaming\FAHClient\work
15:22:24:WU00:FS01:0x22: OS: Windows 10 Pro
15:22:24:WU00:FS01:0x22: OS Arch: AMD64
15:22:24:WU00:FS01:0x22:********************************************************************************
15:22:24:WU00:FS01:0x22:Project: 14561 (Run 0, Clone 899, Gen 87)
15:22:24:WU00:FS01:0x22:Unit: 0x0000008380fccb025e9615c0866c5458
15:22:24:WU00:FS01:0x22:Digital signatures verified
15:22:24:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:22:24:WU00:FS01:0x22:Version 0.0.5
15:22:24:WU00:FS01:0x22: Found a checkpoint file
15:22:25:WU03:FS00:0xa7:Steps: first=40000000 total=500000
15:22:26:WU03:FS00:0xa7:Completed 251301 out of 500000 steps (50%)
15:22:45:9:127.0.0.1:New Web session
15:22:50:21:127.0.0.1:New Web session
15:23:01:WU00:FS01:0x22:ERROR:Guru Meditation #0.270da1c13abe91aa (0.106450809) '00/01/checkpointState.xml'
15:23:01:WU00:FS01:0x22:WARNING:Unexpected exit() call
15:23:01:WU00:FS01:0x22:WARNING:Unexpected exit from science code
15:23:01:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
15:23:01:WU00:FS01:0x22:Saving result file checkpointState.xml
15:23:01:WARNING:WU00:FS01:FahCore returned: BAD_FRAME_CHECKSUM (112 = 0x70)
15:23:01:WARNING:WU00:FS01:Fatal error, dumping
15:23:01:WU00:FS01:Sending unit results: id:00 state:SEND error:DUMPED project:14561 run:0 clone:899 gen:87 core:0x22 unit:0x0000008380fccb025e9615c0866c5458
15:23:01:WU00:FS01:Connecting to 128.252.203.2:8080
15:23:01:WU00:FS01:Server responded WORK_ACK (400)
15:23:01:WU00:FS01:Cleaning up
15:23:02:WU01:FS01:Connecting to assign1.foldingathome.org:80
15:23:02:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:23:02:WU01:FS01:Connecting to assign2.foldingathome.org:80
15:23:02:WU01:FS01:Assigned to work server 140.163.4.241
15:23:02:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP106 [GeForce GTX 1060 6GB] 4372 from 140.163.4.241
15:23:02:WU01:FS01:Connecting to 140.163.4.241:8080
15:23:20:WU01:FS01:Downloading 11.98MiB
15:23:26:WU01:FS01:Download 52.70%
15:23:30:WU01:FS01:Download complete
15:23:30:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11741 run:0 clone:4512 gen:79 core:0x22 unit:0x000000818ca304f15e697d62a3f413ad
15:23:30:WU01:FS01:Starting
15:23:30:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\notting\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 11584 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
15:23:30:WU01:FS01:Started FahCore on PID 11752
15:23:30:WU01:FS01:Core PID:11732
15:23:30:WU01:FS01:FahCore 0x22 started
15:23:31:WU01:FS01:0x22:*********************** Log Started 2020-06-10T15:23:30Z ***********************
15:23:31:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:23:31:WU01:FS01:0x22: Type: 0x22
15:23:31:WU01:FS01:0x22: Core: Core22
15:23:31:WU01:FS01:0x22: Website: https://foldingathome.org/
15:23:31:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
15:23:31:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:23:31:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
15:23:31:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 11752 -checkpoint 15
15:23:31:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
15:23:31:WU01:FS01:0x22: 0 -gpu 0
15:23:31:WU01:FS01:0x22: Config: <none>
15:23:31:WU01:FS01:0x22:************************************ Build *************************************
15:23:31:WU01:FS01:0x22: Version: 0.0.5
15:23:31:WU01:FS01:0x22: Date: Apr 22 2020
15:23:31:WU01:FS01:0x22: Time: 04:42:59
15:23:31:WU01:FS01:0x22: Repository: Git
15:23:31:WU01:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
15:23:31:WU01:FS01:0x22: Branch: HEAD
15:23:31:WU01:FS01:0x22: Compiler: Visual C++ 2008
15:23:31:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:23:31:WU01:FS01:0x22: Platform: win32 10
15:23:31:WU01:FS01:0x22: Bits: 64
15:23:31:WU01:FS01:0x22: Mode: Release
15:23:31:WU01:FS01:0x22:************************************ System ************************************
15:23:31:WU01:FS01:0x22: CPU: AMD Ryzen 7 1700 Eight-Core Processor
15:23:31:WU01:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
15:23:31:WU01:FS01:0x22: CPUs: 16
15:23:31:WU01:FS01:0x22: Memory: 15.95GiB
15:23:31:WU01:FS01:0x22:Free Memory: 13.13GiB
15:23:31:WU01:FS01:0x22: Threads: WINDOWS_THREADS
15:23:31:WU01:FS01:0x22: OS Version: 6.2
15:23:31:WU01:FS01:0x22:Has Battery: false
15:23:31:WU01:FS01:0x22: On Battery: false
15:23:31:WU01:FS01:0x22: UTC Offset: 2
15:23:31:WU01:FS01:0x22: PID: 11732
15:23:31:WU01:FS01:0x22: CWD: C:\Users\notting\AppData\Roaming\FAHClient\work
15:23:31:WU01:FS01:0x22: OS: Windows 10 Pro
15:23:31:WU01:FS01:0x22: OS Arch: AMD64
15:23:31:WU01:FS01:0x22:********************************************************************************
15:23:31:WU01:FS01:0x22:Project: 11741 (Run 0, Clone 4512, Gen 79)
15:23:31:WU01:FS01:0x22:Unit: 0x000000818ca304f15e697d62a3f413ad
15:23:31:WU01:FS01:0x22:Reading tar file core.xml
15:23:31:WU01:FS01:0x22:Reading tar file integrator.xml
15:23:31:WU01:FS01:0x22:Reading tar file state.xml
15:23:33:WU01:FS01:0x22:Reading tar file system.xml
15:23:35:WU01:FS01:0x22:Digital signatures verified
15:23:35:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:23:35:WU01:FS01:0x22:Version 0.0.5
15:24:00:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
15:24:00:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:25:04:WU03:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
15:26:46:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
15:28:35:WU03:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
15:29:33:WU01:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
15:32:07:WU03:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
15:32:19:WU01:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
15:35:05:WU01:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
15:35:40:WU03:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
15:37:51:WU01:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
15:39:13:WU03:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
15:40:44:WU01:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
15:42:46:WU03:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
15:43:29:WU01:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
15:46:16:WU01:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
15:46:17:WU03:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
15:49:03:WU01:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
15:49:49:WU03:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
15:51:50:WU01:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
15:53:22:WU03:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
15:54:44:WU01:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
15:56:54:WU03:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
15:57:32:WU01:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
16:00:22:WU01:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
16:00:27:WU03:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
16:03:09:WU01:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
16:04:01:WU03:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
16:05:54:WU01:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
16:07:35:WU03:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
16:08:48:WU01:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
16:11:10:WU03:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
16:11:33:WU01:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
16:14:19:WU01:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
16:14:45:WU03:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
16:17:05:WU01:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
16:18:20:WU03:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
16:19:51:WU01:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
16:21:55:WU03:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
16:22:44:WU01:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
16:25:30:WU01:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
16:25:33:WU03:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
16:28:18:WU01:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
16:29:05:WU03:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
16:31:05:WU01:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
16:32:37:WU03:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
16:33:51:WU01:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
16:36:10:WU03:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
16:36:44:WU01:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
16:39:29:WU01:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
16:39:44:WU03:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
16:42:14:WU01:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
16:43:16:WU03:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
16:44:59:WU01:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
16:46:51:WU03:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
16:47:45:WU01:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
16:50:24:WU03:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
16:50:39:WU01:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
16:53:25:WU01:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
16:53:57:WU03:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
16:56:12:WU01:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
16:57:29:WU03:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
16:58:59:WU01:FS01:0x22:Completed 340000 out of 1000000 steps (34%)
17:01:00:WU03:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
17:01:46:WU01:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
17:04:34:WU03:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
17:04:40:WU01:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
17:07:27:WU01:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
17:08:07:WU03:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
17:10:14:WU01:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
17:11:39:WU03:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
17:13:02:WU01:FS01:0x22:Completed 390000 out of 1000000 steps (39%)
17:15:14:WU03:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
17:15:48:WU01:FS01:0x22:Completed 400000 out of 1000000 steps (40%)
17:18:43:WU01:FS01:0x22:Completed 410000 out of 1000000 steps (41%)
17:18:48:WU03:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
17:21:31:WU01:FS01:0x22:Completed 420000 out of 1000000 steps (42%)
17:22:22:WU03:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
17:24:19:WU01:FS01:0x22:Completed 430000 out of 1000000 steps (43%)
17:25:54:WU03:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
17:27:05:WU01:FS01:0x22:Completed 440000 out of 1000000 steps (44%)
17:29:26:WU03:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
17:29:52:WU01:FS01:0x22:Completed 450000 out of 1000000 steps (45%)
17:32:45:WU01:FS01:0x22:Completed 460000 out of 1000000 steps (46%)
17:32:58:WU03:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
17:35:30:WU01:FS01:0x22:Completed 470000 out of 1000000 steps (47%)
17:36:30:WU03:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
17:38:18:WU01:FS01:0x22:Completed 480000 out of 1000000 steps (48%)
17:40:03:WU03:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
17:41:04:WU01:FS01:0x22:Completed 490000 out of 1000000 steps (49%)
17:43:35:WU03:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
17:43:50:WU01:FS01:0x22:Completed 500000 out of 1000000 steps (50%)
17:46:43:WU01:FS01:0x22:Completed 510000 out of 1000000 steps (51%)
17:47:09:WU03:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
17:49:28:WU01:FS01:0x22:Completed 520000 out of 1000000 steps (52%)
17:50:42:WU03:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
17:52:14:WU01:FS01:0x22:Completed 530000 out of 1000000 steps (53%)
17:54:15:WU03:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
17:55:01:WU01:FS01:0x22:Completed 540000 out of 1000000 steps (54%)
17:57:47:WU03:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
17:57:49:WU01:FS01:0x22:Completed 550000 out of 1000000 steps (55%)
18:00:47:WU01:FS01:0x22:Completed 560000 out of 1000000 steps (56%)
18:01:17:WU03:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
18:03:37:WU01:FS01:0x22:Completed 570000 out of 1000000 steps (57%)
18:04:47:WU03:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
18:05:23:ERROR:Receive error: 10054: Eine vorhandene Verbindung wurde vom Remotehost geschlossen.
18:06:25:WU01:FS01:0x22:Completed 580000 out of 1000000 steps (58%)
18:08:18:WU03:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
18:09:14:WU01:FS01:0x22:Completed 590000 out of 1000000 steps (59%)
18:11:51:WU03:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
18:11:59:WU01:FS01:0x22:Completed 600000 out of 1000000 steps (60%)
18:14:53:WU01:FS01:0x22:Completed 610000 out of 1000000 steps (61%)
18:15:23:WU03:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
18:15:24:WU00:FS00:Connecting to assign1.foldingathome.org:80
18:15:24:WU00:FS00:Assigned to work server 40.121.152.108
18:15:24:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:14 from 40.121.152.108
18:15:24:WU00:FS00:Connecting to 40.121.152.108:8080
18:15:25:WU00:FS00:Downloading 2.80MiB
18:15:27:WU00:FS00:Download complete
18:15:27:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14817 run:1443 clone:1 gen:84 core:0xa7 unit:0x000000632879986c5ea7515d4aeb6a8b
18:17:41:WU01:FS01:0x22:Completed 620000 out of 1000000 steps (62%)
18:18:55:WU03:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
18:18:57:WU03:FS00:0xa7:Saving result file ..\logfile_01.txt
18:18:57:WU03:FS00:0xa7:Saving result file ener.edr
18:18:57:WU03:FS00:0xa7:Saving result file frame80.trr
18:18:58:WU03:FS00:0xa7:Saving result file md.log
18:18:58:WU03:FS00:0xa7:Saving result file science.log
18:18:58:WU03:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
18:18:58:WU03:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:18:58:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:16801 run:9 clone:329 gen:80 core:0xa7 unit:0x0000006282ed0b915e959648521c9b8f
18:18:58:WU03:FS00:Uploading 8.58MiB to 130.237.11.145
18:18:58:WU00:FS00:Starting
18:18:58:WU03:FS00:Connecting to 130.237.11.145:8080
18:18:58:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\notting\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 11584 -checkpoint 15 -np 14
18:18:59:WU00:FS00:Started FahCore on PID 12652
18:18:59:WU00:FS00:Core PID:12564
18:18:59:WU00:FS00:FahCore 0xa7 started
18:18:59:WU00:FS00:0xa7:*********************** Log Started 2020-06-10T18:18:59Z ***********************
18:18:59:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:18:59:WU00:FS00:0xa7: Type: 0xa7
18:18:59:WU00:FS00:0xa7: Core: Gromacs
18:18:59:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 12652 -checkpoint 15 -np
18:18:59:WU00:FS00:0xa7: 14
18:18:59:WU00:FS00:0xa7:************************************ CBang *************************************
18:18:59:WU00:FS00:0xa7: Date: Oct 26 2019
18:18:59:WU00:FS00:0xa7: Time: 01:38:25
18:18:59:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:18:59:WU00:FS00:0xa7: Branch: master
18:18:59:WU00:FS00:0xa7: Compiler: Visual C++ 2008
18:18:59:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:18:59:WU00:FS00:0xa7: Platform: win32 10
18:18:59:WU00:FS00:0xa7: Bits: 64
18:18:59:WU00:FS00:0xa7: Mode: Release
18:18:59:WU00:FS00:0xa7:************************************ System ************************************
18:18:59:WU00:FS00:0xa7: CPU: AMD Ryzen 7 1700 Eight-Core Processor
18:18:59:WU00:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
18:18:59:WU00:FS00:0xa7: CPUs: 16
18:18:59:WU00:FS00:0xa7: Memory: 15.95GiB
18:18:59:WU00:FS00:0xa7:Free Memory: 11.08GiB
18:18:59:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
18:18:59:WU00:FS00:0xa7: OS Version: 6.2
18:18:59:WU00:FS00:0xa7:Has Battery: false
18:18:59:WU00:FS00:0xa7: On Battery: false
18:18:59:WU00:FS00:0xa7: UTC Offset: 2
18:18:59:WU00:FS00:0xa7: PID: 12564
18:18:59:WU00:FS00:0xa7: CWD: C:\Users\notting\AppData\Roaming\FAHClient\work
18:18:59:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
18:18:59:WU00:FS00:0xa7: Version: 0.0.18
18:18:59:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:18:59:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
18:18:59:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
18:18:59:WU00:FS00:0xa7: Time: 01:52:30
18:18:59:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:18:59:WU00:FS00:0xa7:************************************ Build *************************************
18:18:59:WU00:FS00:0xa7: SIMD: avx_256
18:18:59:WU00:FS00:0xa7:********************************************************************************
18:18:59:WU00:FS00:0xa7:Project: 14817 (Run 1443, Clone 1, Gen 84)
18:18:59:WU00:FS00:0xa7:Unit: 0x000000632879986c5ea7515d4aeb6a8b
18:18:59:WU00:FS00:0xa7:Reading tar file core.xml
18:18:59:WU00:FS00:0xa7:Reading tar file frame84.tpr
18:18:59:WU00:FS00:0xa7:Digital signatures verified
18:18:59:WU00:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
18:18:59:WU00:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
18:18:59:WU00:FS00:0xa7:Calling: mdrun -s frame84.tpr -o frame84.trr -cpt 15 -nt 12
18:18:59:WU00:FS00:0xa7:Steps: first=0 total=250000
18:19:00:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
18:19:19:WU03:FS00:Upload 2.19%
18:19:25:WU03:FS00:Upload 34.98%
18:19:31:WU03:FS00:Upload 72.87%
18:19:39:WU03:FS00:Upload complete
18:19:39:WU03:FS00:Server responded WORK_ACK (400)
18:19:39:WU03:FS00:Final credit estimate, 4338.00 points
18:19:39:WU03:FS00:Cleaning up
18:20:19:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
18:20:27:WU01:FS01:0x22:Completed 630000 out of 1000000 steps (63%)
18:21:38:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
18:22:56:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
18:23:17:WU01:FS01:0x22:Completed 640000 out of 1000000 steps (64%)
18:24:15:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
18:25:33:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
18:26:08:WU01:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
18:26:53:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
18:28:13:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
18:29:01:WU01:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
18:29:34:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
18:30:54:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
18:31:46:WU01:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
18:32:14:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
18:33:33:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
18:34:33:WU01:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
18:34:53:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
18:36:13:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
18:37:19:WU01:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
18:37:33:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
18:38:53:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
18:40:06:WU01:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
18:40:12:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
18:41:32:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
18:42:52:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
18:43:03:WU01:FS01:0x22:Completed 710000 out of 1000000 steps (71%)
18:44:12:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
18:45:32:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
18:45:49:WU01:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
18:46:53:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
18:48:13:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
18:48:36:WU01:FS01:0x22:Completed 730000 out of 1000000 steps (73%)
18:49:33:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
18:50:53:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
18:51:21:WU01:FS01:0x22:Completed 740000 out of 1000000 steps (74%)
18:52:13:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
18:53:33:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
18:54:08:WU01:FS01:0x22:Completed 750000 out of 1000000 steps (75%)
18:54:53:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
18:56:13:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
18:57:01:WU01:FS01:0x22:Completed 760000 out of 1000000 steps (76%)
18:57:33:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
18:58:53:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
18:59:47:WU01:FS01:0x22:Completed 770000 out of 1000000 steps (77%)
19:00:13:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
19:01:33:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
19:02:33:WU01:FS01:0x22:Completed 780000 out of 1000000 steps (78%)
19:02:53:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
19:04:13:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
19:05:20:WU01:FS01:0x22:Completed 790000 out of 1000000 steps (79%)
19:05:33:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
19:06:54:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
19:08:06:WU01:FS01:0x22:Completed 800000 out of 1000000 steps (80%)
19:08:14:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
19:09:34:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
19:10:54:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
19:11:02:WU01:FS01:0x22:Completed 810000 out of 1000000 steps (81%)
19:12:14:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
19:13:34:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
19:13:48:WU01:FS01:0x22:Completed 820000 out of 1000000 steps (82%)
19:14:53:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
19:16:14:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
19:16:34:WU01:FS01:0x22:Completed 830000 out of 1000000 steps (83%)
19:17:34:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
19:18:55:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
19:19:19:WU01:FS01:0x22:Completed 840000 out of 1000000 steps (84%)
19:20:16:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
19:21:37:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
19:22:04:WU01:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
19:22:58:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
19:24:19:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
19:24:57:WU01:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
19:25:39:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
19:27:00:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
19:27:42:WU01:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
19:28:20:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
19:29:39:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
19:30:27:WU01:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
19:30:59:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
19:32:19:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
19:33:12:WU01:FS01:0x22:Completed 890000 out of 1000000 steps (89%)
19:33:38:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
19:34:59:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
19:35:57:WU01:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
19:36:19:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
19:37:39:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
19:38:49:WU01:FS01:0x22:Completed 910000 out of 1000000 steps (91%)
19:38:59:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
19:40:18:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
19:41:34:WU01:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
19:41:38:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
19:42:58:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
19:44:17:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
19:44:19:WU01:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
19:45:37:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
19:46:56:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
19:47:04:WU01:FS01:0x22:Completed 940000 out of 1000000 steps (94%)
19:48:16:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
19:49:36:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
19:49:48:WU01:FS01:0x22:Completed 950000 out of 1000000 steps (95%)
19:50:56:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
19:52:16:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
19:52:41:WU01:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
19:53:36:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
19:54:55:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
19:55:26:WU01:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
19:56:14:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
19:57:34:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
19:58:10:WU01:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
19:58:53:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
20:00:13:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
20:00:55:WU01:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
20:00:56:WU02:FS01:Connecting to assign1.foldingathome.org:80
20:00:56:WU02:FS01:Assigned to work server 155.247.166.220
20:00:56:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP106 [GeForce GTX 1060 6GB] 4372 from 155.247.166.220
20:00:56:WU02:FS01:Connecting to 155.247.166.220:8080
20:00:57:WU02:FS01:Downloading 11.59MiB
20:01:03:WU02:FS01:Download 55.00%
20:01:07:WU02:FS01:Download complete
20:01:07:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16906 run:38 clone:43 gen:4 core:0x21 unit:0x0000000c0002894c5ecb32b35ee28be7
20:01:33:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
20:02:52:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
20:03:42:WU01:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
20:03:50:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
20:03:50:WU01:FS01:0x22:Saving result file checkpointState.xml
20:03:55:WU01:FS01:0x22:Saving result file checkpt.crc
20:03:55:WU01:FS01:0x22:Saving result file positions.xtc
20:03:58:WU01:FS01:0x22:Saving result file science.log
20:03:58:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
20:03:59:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:03:59:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11741 run:0 clone:4512 gen:79 core:0x22 unit:0x000000818ca304f15e697d62a3f413ad
20:03:59:WU01:FS01:Uploading 21.92MiB to 140.163.4.241
20:03:59:WU02:FS01:Starting
20:03:59:WU01:FS01:Connecting to 140.163.4.241:8080
20:03:59:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\notting\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 706 -lifeline 11584 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:03:59:WU02:FS01:Started FahCore on PID 32
20:03:59:WU02:FS01:Core PID:2300
20:03:59:WU02:FS01:FahCore 0x21 started
20:04:00:WU02:FS01:0x21:*********************** Log Started 2020-06-10T20:03:59Z ***********************
20:04:00:WU02:FS01:0x21:Project: 16906 (Run 38, Clone 43, Gen 4)
20:04:00:WU02:FS01:0x21:Unit: 0x0000000c0002894c5ecb32b35ee28be7
20:04:00:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
20:04:00:WU02:FS01:0x21:Machine: 1
20:04:00:WU02:FS01:0x21:Reading tar file core.xml
20:04:00:WU02:FS01:0x21:Reading tar file integrator.xml
20:04:00:WU02:FS01:0x21:Reading tar file state.xml
20:04:00:WU02:FS01:0x21:Reading tar file system.xml
20:04:00:WU02:FS01:0x21:Digital signatures verified
20:04:00:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
20:04:00:WU02:FS01:0x21:Version 0.0.20
20:04:05:WU01:FS01:Upload 13.12%
20:04:11:WU01:FS01:Upload 26.80%
20:04:11:WU02:FS01:0x21:Completed 0 out of 10000000 steps (0%)
20:04:11:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:04:14:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
20:04:17:WU01:FS01:Upload 41.35%
20:04:23:WU01:FS01:Upload 56.17%
20:04:29:WU01:FS01:Upload 70.72%
20:04:35:WU01:FS01:Upload 85.26%
20:04:41:WU01:FS01:Upload 99.80%
20:04:44:WU01:FS01:Upload complete
20:04:44:WU01:FS01:Server responded WORK_ACK (400)
20:04:44:WU01:FS01:Final credit estimate, 86326.00 points
20:04:44:WU01:FS01:Cleaning up
20:05:34:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
20:06:53:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
20:07:30:WU02:FS01:0x21:Completed 100000 out of 10000000 steps (1%)
20:08:13:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
20:09:33:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
20:10:51:WU02:FS01:0x21:Completed 200000 out of 10000000 steps (2%)
20:10:53:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
20:12:14:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
20:13:34:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
20:14:11:WU02:FS01:0x21:Completed 300000 out of 10000000 steps (3%)
20:14:55:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
20:16:16:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
20:17:32:WU02:FS01:0x21:Completed 400000 out of 10000000 steps (4%)
20:17:37:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
20:18:58:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
20:20:18:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
20:20:53:WU02:FS01:0x21:Completed 500000 out of 10000000 steps (5%)
20:21:38:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
20:22:59:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
20:24:17:WU02:FS01:0x21:Completed 600000 out of 10000000 steps (6%)
20:24:18:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
20:25:38:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
20:26:58:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
20:27:37:WU02:FS01:0x21:Completed 700000 out of 10000000 steps (7%)
20:28:17:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
20:29:37:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
20:30:57:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
20:30:58:WU01:FS00:Connecting to assign1.foldingathome.org:80
20:30:58:WU01:FS00:Assigned to work server 40.121.152.108
20:30:58:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:14 from 40.121.152.108
20:30:58:WU01:FS00:Connecting to 40.121.152.108:8080
20:30:59:WU01:FS00:Downloading 2.79MiB
20:30:59:WU02:FS01:0x21:Completed 800000 out of 10000000 steps (8%)
20:31:01:WU01:FS00:Download complete
20:31:01:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14719 run:2824 clone:0 gen:126 core:0xa7 unit:0x000000882879986c5ea962af82859e55
20:32:17:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
20:32:19:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
20:32:19:WU00:FS00:0xa7:Saving result file dhdl.xvg
20:32:19:WU00:FS00:0xa7:Saving result file frame84.trr
20:32:19:WU00:FS00:0xa7:Saving result file md.log
20:32:19:WU00:FS00:0xa7:Saving result file pullf.xvg
20:32:19:WU00:FS00:0xa7:Saving result file pullx.xvg
20:32:19:WU00:FS00:0xa7:Saving result file science.log
20:32:19:WU00:FS00:0xa7:Saving result file traj_comp.xtc
20:32:19:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
20:32:20:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:32:20:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14817 run:1443 clone:1 gen:84 core:0xa7 unit:0x000000632879986c5ea7515d4aeb6a8b
20:32:20:WU00:FS00:Uploading 6.75MiB to 40.121.152.108
20:32:20:WU00:FS00:Connecting to 40.121.152.108:8080
20:32:20:WU01:FS00:Starting
20:32:20:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\notting\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 11584 -checkpoint 15 -np 14
20:32:20:WU01:FS00:Started FahCore on PID 5580
20:32:20:WU01:FS00:Core PID:9604
20:32:20:WU01:FS00:FahCore 0xa7 started
20:32:20:WU01:FS00:0xa7:*********************** Log Started 2020-06-10T20:32:20Z ***********************
20:32:20:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:32:20:WU01:FS00:0xa7: Type: 0xa7
20:32:20:WU01:FS00:0xa7: Core: Gromacs
20:32:20:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 5580 -checkpoint 15 -np
20:32:20:WU01:FS00:0xa7: 14
20:32:20:WU01:FS00:0xa7:************************************ CBang *************************************
20:32:20:WU01:FS00:0xa7: Date: Oct 26 2019
20:32:20:WU01:FS00:0xa7: Time: 01:38:25
20:32:20:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:32:20:WU01:FS00:0xa7: Branch: master
20:32:20:WU01:FS00:0xa7: Compiler: Visual C++ 2008
20:32:20:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:32:20:WU01:FS00:0xa7: Platform: win32 10
20:32:20:WU01:FS00:0xa7: Bits: 64
20:32:20:WU01:FS00:0xa7: Mode: Release
20:32:20:WU01:FS00:0xa7:************************************ System ************************************
20:32:20:WU01:FS00:0xa7: CPU: AMD Ryzen 7 1700 Eight-Core Processor
20:32:20:WU01:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
20:32:20:WU01:FS00:0xa7: CPUs: 16
20:32:20:WU01:FS00:0xa7: Memory: 15.95GiB
20:32:20:WU01:FS00:0xa7:Free Memory: 11.56GiB
20:32:20:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
20:32:20:WU01:FS00:0xa7: OS Version: 6.2
20:32:20:WU01:FS00:0xa7:Has Battery: false
20:32:20:WU01:FS00:0xa7: On Battery: false
20:32:20:WU01:FS00:0xa7: UTC Offset: 2
20:32:20:WU01:FS00:0xa7: PID: 9604
20:32:20:WU01:FS00:0xa7: CWD: C:\Users\notting\AppData\Roaming\FAHClient\work
20:32:20:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
20:32:20:WU01:FS00:0xa7: Version: 0.0.18
20:32:20:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:32:20:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
20:32:20:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
20:32:20:WU01:FS00:0xa7: Time: 01:52:30
20:32:20:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:32:20:WU01:FS00:0xa7:************************************ Build *************************************
20:32:20:WU01:FS00:0xa7: SIMD: avx_256
20:32:20:WU01:FS00:0xa7:********************************************************************************
20:32:20:WU01:FS00:0xa7:Project: 14719 (Run 2824, Clone 0, Gen 126)
20:32:20:WU01:FS00:0xa7:Unit: 0x000000882879986c5ea962af82859e55
20:32:20:WU01:FS00:0xa7:Reading tar file core.xml
20:32:20:WU01:FS00:0xa7:Reading tar file frame126.tpr
20:32:20:WU01:FS00:0xa7:Digital signatures verified
20:32:20:WU01:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
20:32:20:WU01:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
20:32:20:WU01:FS00:0xa7:Calling: mdrun -s frame126.tpr -o frame126.trr -cpt 15 -nt 12
20:32:20:WU01:FS00:0xa7:Steps: first=0 total=250000
20:32:21:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
20:32:26:WU00:FS00:Upload 43.54%
20:32:32:WU00:FS00:Upload 88.01%
20:32:34:WU00:FS00:Upload complete
20:32:34:WU00:FS00:Server responded WORK_ACK (400)
20:32:34:WU00:FS00:Final credit estimate, 4689.00 points
20:32:34:WU00:FS00:Cleaning up
20:33:39:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
20:34:18:WU02:FS01:0x21:Completed 900000 out of 10000000 steps (9%)
20:34:58:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
20:36:16:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
20:37:35:WU01:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
20:37:38:WU02:FS01:0x21:Completed 1000000 out of 10000000 steps (10%)
20:38:54:WU01:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
20:40:11:WU01:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
20:40:59:WU02:FS01:0x21:Completed 1100000 out of 10000000 steps (11%)
20:41:29:WU01:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
20:42:47:WU01:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
20:44:05:WU01:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
20:44:17:WU02:FS01:0x21:Completed 1200000 out of 10000000 steps (12%)
20:45:22:WU01:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
20:46:44:WU01:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
20:47:38:WU02:FS01:0x21:Completed 1300000 out of 10000000 steps (13%)
20:48:02:WU01:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
20:49:20:WU01:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
20:50:37:WU01:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
20:50:57:WU02:FS01:0x21:Completed 1400000 out of 10000000 steps (14%)
20:51:55:WU01:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
20:53:13:WU01:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
20:54:16:WU02:FS01:0x21:Completed 1500000 out of 10000000 steps (15%)
20:54:31:WU01:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
20:55:49:WU01:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
20:57:07:WU01:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
20:57:35:WU02:FS01:0x21:Completed 1600000 out of 10000000 steps (16%)
20:58:25:WU01:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
20:59:43:WU01:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
21:00:54:WU02:FS01:0x21:Completed 1700000 out of 10000000 steps (17%)
21:01:01:WU01:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
21:02:20:WU01:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
21:03:39:WU01:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
21:04:16:WU02:FS01:0x21:Completed 1800000 out of 10000000 steps (18%)
21:04:57:WU01:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
21:06:15:WU01:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
21:07:33:WU02:FS01:0x21:Completed 1900000 out of 10000000 steps (19%)
21:07:34:WU01:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
21:08:52:WU01:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
21:10:11:WU01:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
21:10:51:WU02:FS01:0x21:Completed 2000000 out of 10000000 steps (20%)
21:11:29:WU01:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
21:12:48:WU01:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
21:14:06:WU01:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
21:14:10:WU02:FS01:0x21:Completed 2100000 out of 10000000 steps (21%)
21:15:25:WU01:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
21:16:43:WU01:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
21:17:28:WU02:FS01:0x21:Completed 2200000 out of 10000000 steps (22%)
21:18:02:WU01:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
21:19:21:WU01:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
21:20:39:WU01:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
21:20:47:WU02:FS01:0x21:Completed 2300000 out of 10000000 steps (23%)
21:21:57:WU01:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
******************************* Date: 2020-06-10 *******************************
21:23:16:WU01:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
21:24:06:WU02:FS01:0x21:Completed 2400000 out of 10000000 steps (24%)
21:24:34:WU01:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
21:25:53:WU01:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
21:27:12:WU01:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
21:27:26:WU02:FS01:0x21:Completed 2500000 out of 10000000 steps (25%)
21:28:30:WU01:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
21:29:48:WU01:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
21:30:46:WU02:FS01:0x21:Completed 2600000 out of 10000000 steps (26%)
21:31:06:WU01:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
21:32:25:WU01:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
21:33:44:WU01:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
21:34:05:WU02:FS01:0x21:Completed 2700000 out of 10000000 steps (27%)
21:35:02:WU01:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
21:36:21:WU01:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
21:37:25:WU02:FS01:0x21:Completed 2800000 out of 10000000 steps (28%)
21:37:39:WU01:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
21:38:59:WU01:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
21:39:01:ERROR:Receive error: 10054: Eine vorhandene Verbindung wurde vom Remotehost geschlossen.
21:39:02:WARNING:WU02:FS01:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
21:39:02:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
21:39:02:WARNING:WU01:FS00:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
21:39:02:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
21:39:02:WU02:FS01:Starting
21:39:02:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\notting\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 706 -lifeline 11584 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:39:02:WU02:FS01:Started FahCore on PID 192
21:39:02:WU02:FS01:FahCore 0x21 started
21:39:02:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
21:39:02:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
21:39:02:WU01:FS00:Starting
21:39:02:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\notting\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 11584 -checkpoint 15 -np 14
21:39:02:WU01:FS00:Started FahCore on PID 9072
21:39:03:WU01:FS00:FahCore 0xa7 started
21:39:03:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:39:03:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
This indicates that the last Slot state was folding:
This indicates an issue with the checkpoint file caused due to storage issues:
My guess is that when you paused the Slots, you may not have waited for enough time for the checkpoint to be successfully written and for the new configuration to be saved. This is an example of what the Slot configuration should look like when I pause one of them:
I suggest that you pause your slots and verify that you can view this in the new configuration file:
<paused v='true'/>
and then reboot your system. It should work since I have tested that behavior in the past when I manually paused the slots and then rebooted the system:
17:53:52:WU01:FS00:0xa8:Completed 35000 out of 125000 steps (28%)
17:54:06:WU04:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
17:54:54:FS00:Paused
17:54:54:FS00:Shutting core down
17:54:55:WU01:FS00:0xa8:WARNING:Console control signal 1 on PID 13108
17:54:55:WU01:FS00:0xa8:Exiting, please wait. . .
17:54:56:WU01:FS00:0xa8:Folding@home Core Shutdown: INTERRUPTED
17:54:57:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:55:10:Removing old file 'configs/config-20200610-211707.xml'
17:55:10:Saving configuration to config.xml
17:55:10:<config>
17:55:10: <!-- Folding Core -->
17:55:10: <checkpoint v='30'/>
17:55:10: <core-priority v='low'/>
17:55:10:
17:55:10: <!-- Network -->
17:55:10: <proxy v=':8080'/>
17:55:10:
17:55:10: <!-- Slot Control -->
17:55:10: <pause-on-start v='true'/>
17:55:10: <power v='full'/>
17:55:10:
17:55:10: <!-- User Information -->
17:55:10: <passkey v='*****'/>
17:55:10: <team v='69411'/>
17:55:10: <user v='PantherX'/>
17:55:10:
17:55:10: <!-- Work Unit Control -->
17:55:10: <next-unit-percentage v='100'/>
17:55:10:
17:55:10: <!-- Folding Slots -->
17:55:10: <slot id='0' type='CPU'>
17:55:10: <client-type v='beta'/>
17:55:10: <cpus v='6'/>
17:55:10: <paused v='true'/>
17:55:10: </slot>
17:55:10: <slot id='1' type='GPU'>
17:55:10: </slot>
17:55:10:</config>
17:55:45:WU04:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
17:57:19:WU04:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
<paused v='true'/>
*********************** Log Started 2020-06-09T20:03:57Z ***********************
20:03:57:Trying to access database...
20:03:57:Successfully acquired database lock
20:03:58:Read GPUs.txt
20:03:58:Enabled folding slot 00: PAUSED cpu:2 (by user)
20:03:58:Enabled folding slot 01: PAUSED gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 (by user)
20:03:58:****************************** FAHClient ******************************
20:03:58: Version: 7.6.13
20:03:58: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:03:58: Copyright: 2020 foldingathome.org
20:03:58: Homepage: https://foldingathome.org/
20:03:58: Date: Apr 27 2020
20:03:58: Time: 21:21:01
20:03:58: Revision: 5a652817f46116b6e135503af97f18e094414e3b
20:03:58: Branch: master
20:03:58: Compiler: Visual C++ 2008
20:03:58: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:03:58: Platform: win32 10
20:03:58: Bits: 32
20:03:58: Mode: Release
20:03:58: Config: C:\Users\PantherX-H\AppData\Roaming\FAHClient\config.xml
20:03:58:******************************** CBang ********************************
20:03:58: Date: Apr 24 2020
20:03:58: Time: 17:07:55
20:03:58: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
20:03:58: Bits: 32
20:03:58:******************************* System ********************************
20:03:58: CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
20:03:58: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
20:03:58: CPUs: 8
20:03:58: Memory: 31.94GiB
20:03:58: Free Memory: 27.13GiB
20:03:58: Threads: WINDOWS_THREADS
20:03:58: OS Version: 6.2
20:03:58: Has Battery: false
20:03:58: On Battery: false
20:03:58: UTC Offset: 12
20:03:58: PID: 13020
20:03:58: CWD: C:\Users\PantherX-H\AppData\Roaming\FAHClient
20:03:58: Win32 Service: false
20:03:58: OS: Windows 10 Enterprise
20:03:58: OS Arch: AMD64
20:03:58: GPUs: 1
20:03:58: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GP102 [GeForce GTX 1080 Ti] 11380
20:03:58: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
20:03:58:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.19
20:03:58:******************************* libFAH ********************************
20:03:58: Date: Apr 15 2020
20:03:58: Time: 14:53:14
20:03:58: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
20:03:58: Bits: 32
20:03:58:***********************************************************************
20:03:59:<config>
20:03:59: <!-- Folding Core -->
20:03:59: <checkpoint v='30'/>
20:03:59: <core-priority v='low'/>
20:03:59:
20:03:59: <!-- Network -->
20:03:59: <proxy v=':8080'/>
20:03:59:
20:03:59: <!-- Slot Control -->
20:03:59: <pause-on-start v='true'/>
20:03:59: <power v='full'/>
20:03:59:
20:03:59: <!-- User Information -->
20:03:59: <passkey v='*****'/>
20:03:59: <team v='69411'/>
20:03:59: <user v='PantherX'/>
20:03:59:
20:03:59: <!-- Work Unit Control -->
20:03:59: <next-unit-percentage v='100'/>
20:03:59:
20:03:59: <!-- Folding Slots -->
20:03:59: <slot id='0' type='CPU'>
20:03:59: <client-type v='beta'/>
20:03:59: <cpus v='2'/>
20:03:59: <paused v='true'/>
20:03:59: </slot>
20:03:59: <slot id='1' type='GPU'>
20:03:59: </slot>
20:03:59:</config>
20:04:47:FS01:Unpaused
Hi PantherX,
thanks. But like I said, then I had that gpu.txt problem one time...
notting
notting
Now I tested pausing the jobs before shutdown. Didn't have the gpu.txt problem again. But I consider that shutdown behavior as a bug. As far as I unterstand that, by default the client is always in the background at low power which means that the jobs take longer to complete. Normal users won't think of that which means wasting quite much CPU/GPU power and electricity because the jobs are aborted and have to be startet all over again. I think that problem happened like at least once in 1-2 weeks here.
IIRC even the normal Windows Notepad.exe is able to cause a warning during shutdown (where you can even interrupt shutdown) if unsaved files are open. Also the Windows FAH client icon and the web interface don't have a button like "pause and shutdown computer" (which users usually also won't remember...).
notting
notting
Re: Jobs are aborted after reboot
Can you please describe what your GPUs.txt file issue was?
Regarding the checkpoint and shutdown, it is already logged as an issue at GitHub: https://github.com/FoldingAtHome/fah-issues/issues/1468
Welcome to Folding@Home!
Just a minor configuration issue, but you may wish to consider setting the number of CPU threads to 12. (F@H calls them CPUs)
The final -nt 12 I always assume stands for number of threads 12
Configuring it at 12 avoids the client working out a safe number of threads each time.
Configuring the number of Threads manually:
If you have GPUs, F@H reserves one CPU per GPU to feed it data across the PCIE bus.
F@H has difficulty with large primes and their multiples number of CPUs.
7 is always large, 5 is sometimes large, and 3 is never large. Try to choose a number that is a multiple of 2 and/or 3.
1, 2, 3, 4, 6, 8, 9, 12, and 16 are good numbers of CPUs to choose.
5. 10. and 15 may work most of the time. Other numbers will bite you.
Type the number you want, and click save.
FAH didn't start processes at all after shutdown over night and boot at the next day, I searched this forum for that issue. I tryed several things which didn't help. So I reinstalled FAH which was one of the suggestions.PantherX wrote:Can you please describe what your GPUs.txt file issue was?
Thank you! At first it sound like for me that nobody cares about that issue.Regarding the checkpoint and shutdown, it is already logged as an issue at GitHub: https://github.com/FoldingAtHome/fah-issues/issues/1468
notting
I don't unterstand that. I got a AMD 8-core CPU. I don't see virtual cores like when using a Intel CPU with Hyperthreading. You say one FAH "CPU" per physical CPU core plus that one thread is needed per GPU for data traffic from/to GPU.JimboPalmer wrote:Welcome to Folding@Home!
Just a minor configuration issue, but you may wish to consider setting the number of CPU threads to 12. (F@H calls them CPUs) [...]
12 FAH "cpus" - 8 physical cores = 4. But I can't find a piece of information that my physical GPU has 4 cores?!
How probable will that manual setting help and how probable will it cause problems when updating the client?
Thanks.
notting
from your log:
15:22:23: CPUs: 16
So F@H sees 16 threads, and, of course, one is used by your GPU., so 15. I am recommending you use 12 threads, (F@H calls them CPUs) as 15, 14 and 13 have issues with large prime numbers as factors.
The client is setting itself to 12 now, but is doing so fer each Work Unit, rather than one time at startup. The manual setting would only be bad if you upgrade to a newer CPU chip.
15:22:23: CPU: AMD Ryzen 7 1700 Eight-Core Processor
15:22:23: CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
15:22:23: CPUs: 16
