I realised my FAH had stopped running for a few days so I downloaded the latest file version yesterday and all was good again. I switched off my laptop as normal last night (though there was a pc update waiting to start on shut down) and now this morning I find FAH is not running again so I would appreciate some guidance as to what could be going wrong
07:01:54:Trying to access database...
07:01:55:Successfully acquired database lock
07:01:55:Downloading GPUs.txt from assign1.foldingathome.org:80
07:01:55:Connecting to assign1.foldingathome.org:80
07:01:57:Read GPUs.txt
07:01:57:Enabled folding slot 00: READY cpu:1
07:02:02:Enabled folding slot 01: PAUSED gpu:0:Mullins [Radeon APU A4-6000 R2] (waiting for idle)
07:02:02:****************************** FAHClient ******************************
07:02:02: Version: 7.6.13
07:02:02: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:02:02: Copyright: 2020 foldingathome.org
07:02:02: Homepage: https://foldingathome.org/
07:02:02: Date: Apr 27 2020
07:02:02: Time: 21:21:01
07:02:02: Revision: 5a652817f46116b6e135503af97f18e094414e3b
07:02:02: Branch: master
07:02:02: Compiler: Visual C++ 2008
07:02:02: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:02:02: Platform: win32 10
07:02:02: Bits: 32
07:02:02: Mode: Release
07:02:02: Config: C:\Program Files (x86)\FAHClient\config.xml
07:02:02:******************************** CBang ********************************
07:02:02: Date: Apr 24 2020
07:02:02: Time: 17:07:55
07:02:02: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
07:02:02: Bits: 32
07:02:02:******************************* System ********************************
07:02:02: CPU: AMD A8-7410 APU with AMD Radeon R5 Graphics
07:02:02: CPU ID: AuthenticAMD Family 22 Model 48 Stepping 1
07:02:02: CPUs: 4
07:02:02: Memory: 6.94GiB
07:02:02: Free Memory: 3.04GiB
07:02:02: Threads: WINDOWS_THREADS
07:02:02: OS Version: 6.2
07:02:02: Has Battery: true
07:02:02: On Battery: false
07:02:02: UTC Offset: 1
07:02:02: PID: 1092
07:02:02: CWD: C:\Program Files (x86)\FAHClient
07:02:02: Win32 Service: false
07:02:02: OS: Windows 10 Home
07:02:02: OS Arch: AMD64
07:02:02: GPUs: 1
07:02:02: GPU 0: Bus:0 Slot:1 Func:0 AMD:5 Mullins [Radeon APU A4-6000 R2]
07:02:02: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
07:02:02: specified module could not be found.
07:02:02:
07:02:02:OpenCL Device 0: Platform:0 Device:0 Bus:0 Slot:1 Compute:1.2 Driver:2348.4
07:02:02:******************************* libFAH ********************************
07:02:02: Date: Apr 15 2020
07:02:02: Time: 14:53:14
07:02:02: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
07:02:02: Bits: 32
07:02:02:***********************************************************************
07:02:03:<config>
07:02:03: <!-- Folding Slots -->
07:02:03: <slot id='0' type='CPU'/>
07:02:03: <slot id='1' type='GPU'/>
07:02:03:</config>
07:02:03:WU00:FS00:Connecting to assign1.foldingathome.org:80
07:02:04:WU00:FS00:Assigned to work server 69.94.66.7
07:02:04:WU00:FS00:Requesting new work unit for slot 00: READY cpu:1 from 69.94.66.7
07:02:04:WU00:FS00:Connecting to 69.94.66.7:8080
07:02:04:WU00:FS00:Downloading 2.83MiB
07:02:06:WU00:FS00:Download complete
07:02:06:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14379 run:2177 clone:2 gen:161 core:0xa7 unit:0x000000ba455e42075e932f9a7b10767f
07:02:07:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
07:02:07:WU00:FS00:Connecting to cores.foldingathome.org:80
07:02:08:WU00:FS00:FahCore a7: Downloading 6.71MiB
07:02:11:WU00:FS00:FahCore a7: Download complete
07:02:11:WU00:FS00:Valid core signature
07:02:11:ERROR:WU00:FS00:Exception: Failed to open 'cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe': Failed to open 'cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe': Access is denied.
07:02:11:ERROR:WU00:FS00:: iostream stream error: Access is denied.
