No bonus point's
zarluk1
No bonus point's
Post by zarluk1 »
Hello, it only counts normal points without bonus ppd is entered passkey.
GPU works processing the unit WU 4 hour. Why ??
ajm
Re: No bonus point's
Post by ajm »
It looks like you got your bonus:
https://apps.foldingathome.org/wu#proje ... 788&gen=60
https://apps.foldingathome.org/cpu?q=zarluk
You can't make a PPD of 400k+ without QRB.
With the first 200 lines of the log, we would know enough to discuss why the GPU is taking 4 hours and if you got the Quick Return Bonus, and why.
viewtopic.php?f=24&t=26036
zarluk1
Post by zarluk1 »
File Log
*********************** Log Started 2020-06-09T08:17:44Z ***********************
08:17:44:Trying to access database...
08:17:44:Successfully acquired database lock
08:17:44:Read GPUs.txt
08:17:48:Enabled folding slot 01: READY gpu:0:GP106 [GeForce GTX 1060 6GB] 4372
08:17:48:Enabled folding slot 00: READY cpu:7
08:17:48:****************************** FAHClient ******************************
08:17:48:        Version: 7.6.13
08:17:48:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:17:48:      Copyright: 2020 foldingathome.org
08:17:48:       Homepage: https://foldingathome.org/
08:17:48:           Date: Apr 27 2020
08:17:48:           Time: 21:21:01
08:17:48:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
08:17:48:         Branch: master
08:17:48:       Compiler: Visual C++ 2008
08:17:48:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:17:48:       Platform: win32 10
08:17:48:           Bits: 32
08:17:48:           Mode: Release
08:17:48:         Config: C:\Users\PC\AppData\Roaming\FAHClient\config.xml
08:17:48:******************************** CBang ********************************
08:17:48:           Date: Apr 24 2020
08:17:48:           Time: 17:07:55
08:17:48:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
08:17:48:           Bits: 32
08:17:48:******************************* System ********************************
08:17:48:            CPU: Intel(R) Xeon(R) CPU X3470 @ 2.93GHz
08:17:48:         CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
08:17:48:           CPUs: 8
08:17:48:         Memory: 7.99GiB
08:17:48:    Free Memory: 6.82GiB
08:17:48:        Threads: WINDOWS_THREADS
08:17:48:     OS Version: 6.1
08:17:48:    Has Battery: false
08:17:48:     On Battery: false
08:17:48:     UTC Offset: 2
08:17:48:            PID: 4140
08:17:48:            CWD: C:\Users\PC\AppData\Roaming\FAHClient
08:17:48:  Win32 Service: false
08:17:48:             OS: Windows 7 Professional
08:17:48:        OS Arch: AMD64
08:17:48:           GPUs: 1
08:17:48:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 6GB] 4372
08:17:48:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
08:17:48:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:430.86
08:17:48:******************************* libFAH ********************************
08:17:48:           Date: Apr 15 2020
08:17:48:           Time: 14:53:14
08:17:48:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
08:17:48:           Bits: 32
08:17:48:***********************************************************************
08:17:48:<config>
08:17:48:  <!-- Folding Core -->
08:17:48:  <core-priority v='low'/>
08:17:48:
08:17:48:  <!-- Folding Slot Configuration -->
08:17:48:  <cause v='COVID_19'/>
08:17:48:
08:17:48:  <!-- Network -->
08:17:48:  <proxy v=':8080'/>
08:17:48:
08:17:48:  <!-- Slot Control -->
08:17:48:  <power v='FULL'/>
08:17:48:
08:17:48:  <!-- User Information -->
08:17:48:  <passkey v='*****'/>
08:17:48:  <user v='zarluk'/>
08:17:48:
08:17:48:  <!-- Folding Slots -->
08:17:48:  <slot id='1' type='GPU'/>
08:17:48:  <slot id='0' type='CPU'/>
08:17:48:</config>
08:17:48:WU02:FS01:Starting
08:17:48:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\PC\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 4140 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
08:17:48:WU02:FS01:Started FahCore on PID 5080
08:17:48:WU02:FS01:Core PID:3240
08:17:48:WU02:FS01:FahCore 0x22 started
08:17:48:WU01:FS00:Starting
08:17:48:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\PC\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 4140 -checkpoint 15 -np 7
08:17:48:WU01:FS00:Started FahCore on PID 4364
08:17:48:WU01:FS00:Core PID:4392
08:17:48:WU01:FS00:FahCore 0xa7 started
08:17:49:WU02:FS01:0x22:*********************** Log Started 2020-06-09T08:17:48Z ***********************
08:17:49:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
08:17:49:WU02:FS01:0x22:       Type: 0x22
08:17:49:WU02:FS01:0x22:       Core: Core22
08:17:49:WU02:FS01:0x22:    Website: https://foldingathome.org/
08:17:49:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
08:17:49:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
08:17:49:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
08:17:49:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 5080 -checkpoint 15
08:17:49:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
08:17:49:WU02:FS01:0x22:             0 -gpu 0
08:17:49:WU02:FS01:0x22:     Config: <none>
08:17:49:WU02:FS01:0x22:************************************ Build *************************************
08:17:49:WU02:FS01:0x22:    Version: 0.0.5
08:17:49:WU02:FS01:0x22:       Date: Apr 22 2020
08:17:49:WU02:FS01:0x22:       Time: 04:42:59
08:17:49:WU02:FS01:0x22: Repository: Git
08:17:49:WU02:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
08:17:49:WU02:FS01:0x22:     Branch: HEAD
08:17:49:WU02:FS01:0x22:   Compiler: Visual C++ 2008
08:17:49:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:17:49:WU02:FS01:0x22:   Platform: win32 10
08:17:49:WU02:FS01:0x22:       Bits: 64
08:17:49:WU02:FS01:0x22:       Mode: Release
08:17:49:WU02:FS01:0x22:************************************ System ************************************
08:17:49:WU02:FS01:0x22:        CPU: Intel(R) Xeon(R) CPU X3470 @ 2.93GHz
08:17:49:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
08:17:49:WU02:FS01:0x22:       CPUs: 8
08:17:49:WU02:FS01:0x22:     Memory: 7.99GiB
08:17:49:WU02:FS01:0x22:Free Memory: 6.67GiB
08:17:49:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
08:17:49:WU02:FS01:0x22: OS Version: 6.1
08:17:49:WU02:FS01:0x22:Has Battery: false
08:17:49:WU02:FS01:0x22: On Battery: false
08:17:49:WU02:FS01:0x22: UTC Offset: 2
08:17:49:WU02:FS01:0x22:        PID: 3240
08:17:49:WU02:FS01:0x22:        CWD: C:\Users\PC\AppData\Roaming\FAHClient\work
08:17:49:WU02:FS01:0x22:         OS: Windows 7 Professional Service Pack 1
08:17:49:WU02:FS01:0x22:    OS Arch: AMD64
08:17:49:WU02:FS01:0x22:********************************************************************************
08:17:49:WU02:FS01:0x22:Project: 16448 (Run 0, Clone 835, Gen 59)
08:17:49:WU02:FS01:0x22:Unit: 0x0000004e42aa6f325ed18ce3d36dee96
08:17:49:WU02:FS01:0x22:Digital signatures verified
08:17:49:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
08:17:49:WU02:FS01:0x22:Version 0.0.5
08:17:49:WU01:FS00:0xa7:*********************** Log Started 2020-06-09T08:17:49Z ***********************
08:17:49:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:17:49:WU01:FS00:0xa7:       Type: 0xa7
08:17:49:WU01:FS00:0xa7:       Core: Gromacs
08:17:49:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 4364 -checkpoint 15 -np 7
08:17:49:WU01:FS00:0xa7:************************************ CBang *************************************
08:17:49:WU01:FS00:0xa7:       Date: Oct 26 2019
08:17:49:WU01:FS00:0xa7:       Time: 01:38:35
08:17:49:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
08:17:49:WU01:FS00:0xa7:     Branch: master
08:17:49:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
08:17:49:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:17:49:WU01:FS00:0xa7:   Platform: win32 10
08:17:49:WU01:FS00:0xa7:       Bits: 64
08:17:49:WU01:FS00:0xa7:       Mode: Release
08:17:49:WU01:FS00:0xa7:************************************ System ************************************
08:17:49:WU01:FS00:0xa7:        CPU: Intel(R) Xeon(R) CPU X3470 @ 2.93GHz
08:17:49:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
08:17:49:WU01:FS00:0xa7:       CPUs: 8
08:17:49:WU01:FS00:0xa7:     Memory: 7.99GiB
08:17:49:WU01:FS00:0xa7:Free Memory: 6.66GiB
08:17:49:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
08:17:49:WU01:FS00:0xa7: OS Version: 6.1
08:17:49:WU01:FS00:0xa7:Has Battery: false
08:17:49:WU01:FS00:0xa7: On Battery: false
08:17:49:WU01:FS00:0xa7: UTC Offset: 2
08:17:49:WU01:FS00:0xa7:        PID: 4392
08:17:49:WU01:FS00:0xa7:        CWD: C:\Users\PC\AppData\Roaming\FAHClient\work
08:17:49:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
08:17:49:WU01:FS00:0xa7:    Version: 0.0.18
08:17:49:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:17:49:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:17:49:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
08:17:49:WU01:FS00:0xa7:       Time: 01:52:44
08:17:49:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
08:17:49:WU01:FS00:0xa7:************************************ Build *************************************
08:17:49:WU01:FS00:0xa7:       SIMD: sse2
08:17:49:WU01:FS00:0xa7:********************************************************************************
08:17:49:WU01:FS00:0xa7:Project: 14718 (Run 2025, Clone 0, Gen 124)
08:17:49:WU01:FS00:0xa7:Unit: 0x000000892879986c5ea8159994aebe38
08:17:49:WU01:FS00:0xa7:Digital signatures verified
08:17:49:WU01:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
08:17:49:WU01:FS00:0xa7:Calling: mdrun -s frame124.tpr -o frame124.trr -cpi state.cpt -cpt 15 -nt 6
08:17:50:WU01:FS00:0xa7:Steps: first=0 total=250000
08:17:51:WU01:FS00:0xa7:Completed 244067 out of 250000 steps (97%)
08:18:11:3:127.0.0.1:New Web session
08:18:49:WU02:FS01:0x22:Completed 0 out of 600000 steps (0%)
08:18:49:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
08:20:16:WU01:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
08:20:57:WU02:FS01:0x22:Completed 6000 out of 600000 steps (1%)
08:23:05:WU02:FS01:0x22:Completed 12000 out of 600000 steps (2%)
08:25:12:WU02:FS01:0x22:Completed 18000 out of 600000 steps (3%)
08:25:57:WU01:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
08:25:58:WU00:FS00:Connecting to assign1.foldingathome.org:80
08:25:58:WU00:FS00:Assigned to work server 155.247.164.214
08:25:58:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 155.247.164.214
08:25:58:WU00:FS00:Connecting to 155.247.164.214:8080
08:25:59:WU00:FS00:Downloading 2.84MiB
08:26:00:WU00:FS00:Download complete
08:26:00:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14852 run:380 clone:2 gen:75 core:0xa7 unit:0x000000609bf7a4d65ea102d299114daa
08:27:33:WU02:FS01:0x22:Completed 24000 out of 600000 steps (4%)
08:29:39:WU02:FS01:0x22:Completed 30000 out of 600000 steps (5%)
08:31:36:WU01:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
08:31:39:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
08:31:39:WU01:FS00:0xa7:Saving result file dhdl.xvg
08:31:39:WU01:FS00:0xa7:Saving result file frame124.trr
08:31:39:WU01:FS00:0xa7:Saving result file md.log
08:31:39:WU01:FS00:0xa7:Saving result file pullf.xvg
08:31:39:WU01:FS00:0xa7:Saving result file pullx.xvg
08:31:39:WU01:FS00:0xa7:Saving result file science.log
08:31:39:WU01:FS00:0xa7:Saving result file traj_comp.xtc
08:31:39:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
08:31:39:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:31:39:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14718 run:2025 clone:0 gen:124 core:0xa7 unit:0x000000892879986c5ea8159994aebe38
08:31:39:WU01:FS00:Uploading 6.86MiB to 40.121.152.108
08:31:39:WU01:FS00:Connecting to 40.121.152.108:8080
08:31:39:WU00:FS00:Starting
08:31:39:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\PC\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 4140 -checkpoint 15 -np 7
08:31:39:WU00:FS00:Started FahCore on PID 3020
08:31:39:WU00:FS00:Core PID:5124
08:31:39:WU00:FS00:FahCore 0xa7 started
08:31:40:WU00:FS00:0xa7:*********************** Log Started 2020-06-09T08:31:39Z ***********************
08:31:40:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:31:40:WU00:FS00:0xa7:       Type: 0xa7
08:31:40:WU00:FS00:0xa7:       Core: Gromacs
08:31:40:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 3020 -checkpoint 15 -np 7
08:31:40:WU00:FS00:0xa7:************************************ CBang *************************************
08:31:40:WU00:FS00:0xa7:       Date: Oct 26 2019
08:31:40:WU00:FS00:0xa7:       Time: 01:38:35
08:31:40:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
08:31:40:WU00:FS00:0xa7:     Branch: master
08:31:40:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
08:31:40:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:31:40:WU00:FS00:0xa7:   Platform: win32 10
08:31:40:WU00:FS00:0xa7:       Bits: 64
08:31:40:WU00:FS00:0xa7:       Mode: Release
08:31:40:WU00:FS00:0xa7:************************************ System ************************************
08:31:40:WU00:FS00:0xa7:        CPU: Intel(R) Xeon(R) CPU X3470 @ 2.93GHz
08:31:40:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
08:31:40:WU00:FS00:0xa7:       CPUs: 8
08:31:40:WU00:FS00:0xa7:     Memory: 7.99GiB
08:31:40:WU00:FS00:0xa7:Free Memory: 4.97GiB
08:31:40:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
08:31:40:WU00:FS00:0xa7: OS Version: 6.1
08:31:40:WU00:FS00:0xa7:Has Battery: false
08:31:40:WU00:FS00:0xa7: On Battery: false
08:31:40:WU00:FS00:0xa7: UTC Offset: 2
08:31:40:WU00:FS00:0xa7:        PID: 5124
08:31:40:WU00:FS00:0xa7:        CWD: C:\Users\PC\AppData\Roaming\FAHClient\work
08:31:40:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
08:31:40:WU00:FS00:0xa7:    Version: 0.0.18
08:31:40:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:31:40:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:31:40:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
08:31:40:WU00:FS00:0xa7:       Time: 01:52:44
08:31:40:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
08:31:40:WU00:FS00:0xa7:************************************ Build *************************************
08:31:40:WU00:FS00:0xa7:       SIMD: sse2
08:31:40:WU00:FS00:0xa7:********************************************************************************
08:31:40:WU00:FS00:0xa7:Project: 14852 (Run 380, Clone 2, Gen 75)
08:31:40:WU00:FS00:0xa7:Unit: 0x000000609bf7a4d65ea102d299114daa
08:31:40:WU00:FS00:0xa7:Reading tar file core.xml
08:31:40:WU00:FS00:0xa7:Reading tar file frame75.tpr
08:31:40:WU00:FS00:0xa7:Digital signatures verified
08:31:40:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
08:31:40:WU00:FS00:0xa7:Calling: mdrun -s frame75.tpr -o frame75.trr -cpt 15 -nt 6
08:31:40:WU00:FS00:0xa7:Steps: first=0 total=250000
08:31:42:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
08:31:45:WU01:FS00:Upload 7.28%
08:31:46:WU02:FS01:0x22:Completed 36000 out of 600000 steps (6%)
08:31:51:WU01:FS00:Upload 16.39%
08:31:57:WU01:FS00:Upload 24.59%
08:32:03:WU01:FS00:Upload 33.69%
08:32:09:WU01:FS00:Upload 41.89%
08:32:15:WU01:FS00:Upload 50.99%
08:32:21:WU01:FS00:Upload 59.19%
08:32:27:WU01:FS00:Upload 68.29%
08:32:33:WU01:FS00:Upload 77.40%
08:32:39:WU01:FS00:Upload 85.59%
08:32:45:WU01:FS00:Upload 94.70%
08:32:49:WU01:FS00:Upload complete
08:32:49:WU01:FS00:Server responded WORK_ACK (400)
08:32:49:WU01:FS00:Final credit estimate, 1611.00 points
08:32:49:WU01:FS00:Cleaning up
08:34:08:WU02:FS01:0x22:Completed 42000 out of 600000 steps (7%)
08:36:14:WU02:FS01:0x22:Completed 48000 out of 600000 steps (8%)
08:37:21:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
08:38:20:WU02:FS01:0x22:Completed 54000 out of 600000 steps (9%)
08:40:24:WU02:FS01:0x22:Completed 60000 out of 600000 steps (10%)
08:42:43:WU02:FS01:0x22:Completed 66000 out of 600000 steps (11%)
08:43:02:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
08:44:48:WU02:FS01:0x22:Completed 72000 out of 600000 steps (12%)
08:46:52:WU02:FS01:0x22:Completed 78000 out of 600000 steps (13%)
08:48:47:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
08:49:12:WU02:FS01:0x22:Completed 84000 out of 600000 steps (14%)
08:51:16:WU02:FS01:0x22:Completed 90000 out of 600000 steps (15%)
08:53:21:WU02:FS01:0x22:Completed 96000 out of 600000 steps (16%)
08:54:30:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
08:55:38:WU02:FS01:0x22:Completed 102000 out of 600000 steps (17%)
08:57:44:WU02:FS01:0x22:Completed 108000 out of 600000 steps (18%)
08:59:49:WU02:FS01:0x22:Completed 114000 out of 600000 steps (19%)
09:00:10:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
09:01:53:WU02:FS01:0x22:Completed 120000 out of 600000 steps (20%)
09:04:15:WU02:FS01:0x22:Completed 126000 out of 600000 steps (21%)
09:05:33:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
09:06:20:WU02:FS01:0x22:Completed 132000 out of 600000 steps (22%)
09:08:24:WU02:FS01:0x22:Completed 138000 out of 600000 steps (23%)
09:10:45:WU02:FS01:0x22:Completed 144000 out of 600000 steps (24%)
09:10:59:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
09:12:50:WU02:FS01:0x22:Completed 150000 out of 600000 steps (25%)
09:14:54:WU02:FS01:0x22:Completed 156000 out of 600000 steps (26%)
09:16:27:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
09:17:12:WU02:FS01:0x22:Completed 162000 out of 600000 steps (27%)
09:19:17:WU02:FS01:0x22:Completed 168000 out of 600000 steps (28%)
09:21:21:WU02:FS01:0x22:Completed 174000 out of 600000 steps (29%)
09:21:54:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
09:23:25:WU02:FS01:0x22:Completed 180000 out of 600000 steps (30%)
09:25:46:WU02:FS01:0x22:Completed 186000 out of 600000 steps (31%)
09:27:22:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
09:27:50:WU02:FS01:0x22:Completed 192000 out of 600000 steps (32%)
09:29:54:WU02:FS01:0x22:Completed 198000 out of 600000 steps (33%)
09:32:17:WU02:FS01:0x22:Completed 204000 out of 600000 steps (34%)
09:32:49:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
09:34:23:WU02:FS01:0x22:Completed 210000 out of 600000 steps (35%)
09:36:28:WU02:FS01:0x22:Completed 216000 out of 600000 steps (36%)
09:38:22:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
09:38:47:WU02:FS01:0x22:Completed 222000 out of 600000 steps (37%)
09:40:51:WU02:FS01:0x22:Completed 228000 out of 600000 steps (38%)
09:42:57:WU02:FS01:0x22:Completed 234000 out of 600000 steps (39%)
09:43:50:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
09:45:02:WU02:FS01:0x22:Completed 240000 out of 600000 steps (40%)
09:47:22:WU02:FS01:0x22:Completed 246000 out of 600000 steps (41%)
09:49:07:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
09:49:27:WU02:FS01:0x22:Completed 252000 out of 600000 steps (42%)
09:51:31:WU02:FS01:0x22:Completed 258000 out of 600000 steps (43%)
09:53:49:WU02:FS01:0x22:Completed 264000 out of 600000 steps (44%)
09:54:23:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
09:55:55:WU02:FS01:0x22:Completed 270000 out of 600000 steps (45%)
09:57:59:WU02:FS01:0x22:Completed 276000 out of 600000 steps (46%)
09:59:40:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
10:00:17:WU02:FS01:0x22:Completed 282000 out of 600000 steps (47%)
10:02:22:WU02:FS01:0x22:Completed 288000 out of 600000 steps (48%)
10:04:26:WU02:FS01:0x22:Completed 294000 out of 600000 steps (49%)
10:04:58:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
10:06:30:WU02:FS01:0x22:Completed 300000 out of 600000 steps (50%)
10:08:48:WU02:FS01:0x22:Completed 306000 out of 600000 steps (51%)
10:10:29:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
10:10:52:WU02:FS01:0x22:Completed 312000 out of 600000 steps (52%)
10:12:58:WU02:FS01:0x22:Completed 318000 out of 600000 steps (53%)
10:15:16:WU02:FS01:0x22:Completed 324000 out of 600000 steps (54%)
10:15:45:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
10:17:20:WU02:FS01:0x22:Completed 330000 out of 600000 steps (55%)
10:19:25:WU02:FS01:0x22:Completed 336000 out of 600000 steps (56%)
10:21:16:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
10:21:42:WU02:FS01:0x22:Completed 342000 out of 600000 steps (57%)
10:23:46:WU02:FS01:0x22:Completed 348000 out of 600000 steps (58%)
10:25:50:WU02:FS01:0x22:Completed 354000 out of 600000 steps (59%)
10:26:28:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
10:27:55:WU02:FS01:0x22:Completed 360000 out of 600000 steps (60%)
10:30:15:WU02:FS01:0x22:Completed 366000 out of 600000 steps (61%)
10:31:47:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
10:32:19:WU02:FS01:0x22:Completed 372000 out of 600000 steps (62%)
10:34:24:WU02:FS01:0x22:Completed 378000 out of 600000 steps (63%)
10:36:44:WU02:FS01:0x22:Completed 384000 out of 600000 steps (64%)
10:36:57:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
10:38:48:WU02:FS01:0x22:Completed 390000 out of 600000 steps (65%)
10:40:53:WU02:FS01:0x22:Completed 396000 out of 600000 steps (66%)
10:42:24:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
10:43:14:WU02:FS01:0x22:Completed 402000 out of 600000 steps (67%)
10:45:19:WU02:FS01:0x22:Completed 408000 out of 600000 steps (68%)
10:47:24:WU02:FS01:0x22:Completed 414000 out of 600000 steps (69%)
10:47:39:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
10:49:29:WU02:FS01:0x22:Completed 420000 out of 600000 steps (70%)
10:51:48:WU02:FS01:0x22:Completed 426000 out of 600000 steps (71%)
10:53:12:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
10:53:52:WU02:FS01:0x22:Completed 432000 out of 600000 steps (72%)
10:55:56:WU02:FS01:0x22:Completed 438000 out of 600000 steps (73%)
10:58:15:WU02:FS01:0x22:Completed 444000 out of 600000 steps (74%)
10:58:35:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
11:00:20:WU02:FS01:0x22:Completed 450000 out of 600000 steps (75%)
11:02:25:WU02:FS01:0x22:Completed 456000 out of 600000 steps (76%)
11:03:21:39:127.0.0.1:New Web session
11:04:06:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
11:04:48:WU02:FS01:0x22:Completed 462000 out of 600000 steps (77%)
11:06:52:WU02:FS01:0x22:Completed 468000 out of 600000 steps (78%)
11:08:57:WU02:FS01:0x22:Completed 474000 out of 600000 steps (79%)
11:09:27:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
11:11:01:WU02:FS01:0x22:Completed 480000 out of 600000 steps (80%)
11:13:19:WU02:FS01:0x22:Completed 486000 out of 600000 steps (81%)
11:14:53:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
11:15:25:WU02:FS01:0x22:Completed 492000 out of 600000 steps (82%)
11:17:30:WU02:FS01:0x22:Completed 498000 out of 600000 steps (83%)
11:19:51:WU02:FS01:0x22:Completed 504000 out of 600000 steps (84%)
11:20:06:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
11:21:56:WU02:FS01:0x22:Completed 510000 out of 600000 steps (85%)
11:24:00:WU02:FS01:0x22:Completed 516000 out of 600000 steps (86%)
11:25:20:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
11:26:18:WU02:FS01:0x22:Completed 522000 out of 600000 steps (87%)
11:28:22:WU02:FS01:0x22:Completed 528000 out of 600000 steps (88%)
11:30:27:WU02:FS01:0x22:Completed 534000 out of 600000 steps (89%)
11:30:36:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
11:32:30:WU02:FS01:0x22:Completed 540000 out of 600000 steps (90%)
11:34:51:WU02:FS01:0x22:Completed 546000 out of 600000 steps (91%)
11:35:55:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
11:36:55:WU02:FS01:0x22:Completed 552000 out of 600000 steps (92%)
11:39:01:WU02:FS01:0x22:Completed 558000 out of 600000 steps (93%)
11:41:12:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
11:41:20:WU02:FS01:0x22:Completed 564000 out of 600000 steps (94%)
11:43:24:WU02:FS01:0x22:Completed 570000 out of 600000 steps (95%)
11:45:30:WU02:FS01:0x22:Completed 576000 out of 600000 steps (96%)
11:45:41:55:127.0.0.1:New Web session
11:46:44:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
11:47:50:WU02:FS01:0x22:Completed 582000 out of 600000 steps (97%)
11:49:56:WU02:FS01:0x22:Completed 588000 out of 600000 steps (98%)
11:52:01:WU02:FS01:0x22:Completed 594000 out of 600000 steps (99%)
11:52:02:WU01:FS01:Connecting to assign1.foldingathome.org:80
11:52:02:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
11:52:02:WU01:FS01:Connecting to assign2.foldingathome.org:80
11:52:03:WU01:FS01:Assigned to work server 155.247.166.220
11:52:03:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP106 [GeForce GTX 1060 6GB] 4372 from 155.247.166.220
11:52:03:WU01:FS01:Connecting to 155.247.166.220:8080
11:52:03:ERROR:WU01:FS01:Exception: Server did not assign work unit
11:52:03:WU01:FS01:Connecting to assign1.foldingathome.org:80
11:52:04:WU01:FS01:Assigned to work server 3.133.76.19
11:52:04:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP106 [GeForce GTX 1060 6GB] 4372 from 3.133.76.19
11:52:04:WU01:FS01:Connecting to 3.133.76.19:8080
11:52:15:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
11:52:32:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:53:04:WU01:FS01:Connecting to assign1.foldingathome.org:80
11:53:04:WU01:FS01:Assigned to work server 128.252.203.1
11:53:04:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP106 [GeForce GTX 1060 6GB] 4372 from 128.252.203.1
11:53:04:WU01:FS01:Connecting to 128.252.203.1:8080
11:53:11:WU01:FS01:Downloading 24.10MiB
11:53:17:WU01:FS01:Download 27.75%
11:53:23:WU01:FS01:Download 66.90%
11:53:27:WU01:FS01:Download complete
11:53:27:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16442 run:0 clone:1788 gen:60 core:0x22 unit:0x0000006080fccb015eaa1bf29f739878
11:54:06:WU02:FS01:0x22:Completed 600000 out of 600000 steps (100%)
11:54:21:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
11:54:21:WU02:FS01:0x22:Saving result file checkpointState.xml
11:54:27:WU02:FS01:0x22:Saving result file checkpt.crc
11:54:27:WU02:FS01:0x22:Saving result file positions.xtc
11:54:29:WU02:FS01:0x22:Saving result file science.log
11:54:29:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
11:54:30:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:54:30:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:16448 run:0 clone:835 gen:59 core:0x22 unit:0x0000004e42aa6f325ed18ce3d36dee96
11:54:30:WU02:FS01:Uploading 42.37MiB to 66.170.111.50
11:54:30:WU02:FS01:Connecting to 66.170.111.50:8080
11:54:30:WU01:FS01:Starting
11:54:30:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\PC\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 4140 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
11:54:30:WU01:FS01:Started FahCore on PID 4656
11:54:30:WU01:FS01:Core PID:6888
11:54:30:WU01:FS01:FahCore 0x22 started
11:54:31:WU01:FS01:0x22:*********************** Log Started 2020-06-09T11:54:31Z ***********************
11:54:31:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
11:54:31:WU01:FS01:0x22:       Type: 0x22
11:54:31:WU01:FS01:0x22:       Core: Core22
11:54:31:WU01:FS01:0x22:    Website: https://foldingathome.org/
11:54:31:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
11:54:31:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
11:54:31:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
11:54:31:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 4656 -checkpoint 15
11:54:31:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
11:54:31:WU01:FS01:0x22:             0 -gpu 0
11:54:31:WU01:FS01:0x22:     Config: <none>
11:54:31:WU01:FS01:0x22:************************************ Build *************************************
11:54:31:WU01:FS01:0x22:    Version: 0.0.5
11:54:31:WU01:FS01:0x22:       Date: Apr 22 2020
11:54:31:WU01:FS01:0x22:       Time: 04:42:59
11:54:31:WU01:FS01:0x22: Repository: Git
11:54:31:WU01:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
11:54:31:WU01:FS01:0x22:     Branch: HEAD
11:54:31:WU01:FS01:0x22:   Compiler: Visual C++ 2008
11:54:31:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:54:31:WU01:FS01:0x22:   Platform: win32 10
11:54:31:WU01:FS01:0x22:       Bits: 64
11:54:31:WU01:FS01:0x22:       Mode: Release
11:54:31:WU01:FS01:0x22:************************************ System ************************************
11:54:31:WU01:FS01:0x22:        CPU: Intel(R) Xeon(R) CPU X3470 @ 2.93GHz
11:54:31:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
11:54:31:WU01:FS01:0x22:       CPUs: 8
11:54:31:WU01:FS01:0x22:     Memory: 7.99GiB
11:54:31:WU01:FS01:0x22:Free Memory: 5.64GiB
11:54:31:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
11:54:31:WU01:FS01:0x22: OS Version: 6.1
11:54:31:WU01:FS01:0x22:Has Battery: false
11:54:31:WU01:FS01:0x22: On Battery: false
11:54:31:WU01:FS01:0x22: UTC Offset: 2
11:54:31:WU01:FS01:0x22:        PID: 6888
11:54:31:WU01:FS01:0x22:        CWD: C:\Users\PC\AppData\Roaming\FAHClient\work
11:54:31:WU01:FS01:0x22:         OS: Windows 7 Professional Service Pack 1
11:54:31:WU01:FS01:0x22:    OS Arch: AMD64
11:54:31:WU01:FS01:0x22:********************************************************************************
11:54:31:WU01:FS01:0x22:Project: 16442 (Run 0, Clone 1788, Gen 60)
11:54:31:WU01:FS01:0x22:Unit: 0x0000006080fccb015eaa1bf29f739878
11:54:31:WU01:FS01:0x22:Reading tar file core.xml
11:54:31:WU01:FS01:0x22:Reading tar file integrator.xml
11:54:31:WU01:FS01:0x22:Reading tar file state.xml
11:54:33:WU01:FS01:0x22:Reading tar file system.xml
11:54:35:WU01:FS01:0x22:Digital signatures verified
11:54:35:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
11:54:35:WU01:FS01:0x22:Version 0.0.5
11:54:36:WU02:FS01:Upload 0.59%
11:54:43:WU02:FS01:Upload 1.33%
11:54:49:WU02:FS01:Upload 2.07%
11:54:55:WU02:FS01:Upload 2.80%
11:55:01:WU02:FS01:Upload 3.54%
11:55:07:WU02:FS01:Upload 4.28%
11:55:13:WU02:FS01:Upload 5.02%
11:55:19:WU02:FS01:Upload 5.75%
11:55:25:WU02:FS01:Upload 6.49%
11:55:27:WU01:FS01:0x22:Completed 0 out of 700000 steps (0%)
11:55:27:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
11:55:31:WU02:FS01:Upload 7.23%
11:55:37:WU02:FS01:Upload 7.97%
11:55:43:WU02:FS01:Upload 8.70%
11:55:49:WU02:FS01:Upload 9.44%
11:55:55:WU02:FS01:Upload 10.18%
11:56:01:WU02:FS01:Upload 10.92%
11:56:07:WU02:FS01:Upload 11.65%
11:56:13:WU02:FS01:Upload 12.39%
11:56:19:WU02:FS01:Upload 13.13%
11:56:25:WU02:FS01:Upload 13.87%
11:56:31:WU02:FS01:Upload 14.60%
11:56:37:WU02:FS01:Upload 15.34%
11:56:43:WU02:FS01:Upload 16.08%
11:56:49:WU02:FS01:Upload 16.82%
11:56:55:WU02:FS01:Upload 17.55%
11:57:01:WU02:FS01:Upload 18.29%
11:57:07:WU02:FS01:Upload 19.03%
11:57:13:WU02:FS01:Upload 19.77%
11:57:19:WU02:FS01:Upload 20.50%
11:57:25:WU02:FS01:Upload 21.24%
11:57:31:WU02:FS01:Upload 21.98%
11:57:37:WU02:FS01:Upload 22.72%
11:57:44:WU02:FS01:Upload 23.60%
11:57:49:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
11:57:50:WU02:FS01:Upload 24.34%
11:57:56:WU02:FS01:Upload 25.08%
11:58:02:WU02:FS01:Upload 25.81%
11:58:08:WU02:FS01:Upload 26.55%
11:58:10:WU01:FS01:0x22:Completed 7000 out of 700000 steps (1%)
11:58:14:WU02:FS01:Upload 27.29%
11:58:20:WU02:FS01:Upload 28.03%
11:58:26:WU02:FS01:Upload 28.76%
11:58:32:WU02:FS01:Upload 29.50%
11:58:38:WU02:FS01:Upload 30.24%
11:58:45:WU02:FS01:Upload 31.12%
11:58:51:WU02:FS01:Upload 31.86%
11:58:57:WU02:FS01:Upload 32.60%
11:59:03:WU02:FS01:Upload 33.34%
11:59:09:WU02:FS01:Upload 34.07%
11:59:15:WU02:FS01:Upload 34.81%
11:59:21:WU02:FS01:Upload 35.55%
11:59:27:WU02:FS01:Upload 36.29%
11:59:34:WU02:FS01:Upload 37.17%
11:59:40:WU02:FS01:Upload 37.91%
11:59:46:WU02:FS01:Upload 38.65%
11:59:52:WU02:FS01:Upload 39.38%
11:59:58:WU02:FS01:Upload 40.12%
12:00:04:WU02:FS01:Upload 40.86%
12:00:10:WU02:FS01:Upload 41.60%
12:00:17:WU02:FS01:Upload 42.48%
12:00:23:WU02:FS01:Upload 43.22%
12:00:29:WU02:FS01:Upload 43.96%
12:00:35:WU02:FS01:Upload 44.69%
12:00:41:WU02:FS01:Upload 45.43%
12:00:47:WU02:FS01:Upload 46.17%
12:00:53:WU02:FS01:Upload 46.91%
12:00:54:WU01:FS01:0x22:Completed 14000 out of 700000 steps (2%)
12:00:59:WU02:FS01:Upload 47.64%
12:01:06:WU02:FS01:Upload 48.53%
12:01:12:WU02:FS01:Upload 49.27%
12:01:18:WU02:FS01:Upload 50.00%
12:01:24:WU02:FS01:Upload 50.74%
12:01:30:WU02:FS01:Upload 51.48%
12:01:36:WU02:FS01:Upload 52.22%
12:01:42:WU02:FS01:Upload 52.95%
12:01:49:WU02:FS01:Upload 53.84%
12:01:55:WU02:FS01:Upload 54.58%
12:02:01:WU02:FS01:Upload 55.31%
12:02:07:WU02:FS01:Upload 56.05%
12:02:13:WU02:FS01:Upload 56.79%
12:02:19:WU02:FS01:Upload 57.53%
12:02:25:WU02:FS01:Upload 58.27%
12:02:31:WU02:FS01:Upload 59.00%
12:02:37:WU02:FS01:Upload 59.74%
12:02:43:WU02:FS01:Upload 60.48%
12:02:50:WU02:FS01:Upload 61.36%
12:02:56:WU02:FS01:Upload 62.10%
12:03:02:WU02:FS01:Upload 62.84%
12:03:08:WU02:FS01:Upload 63.58%
12:03:15:WU02:FS01:Upload 64.46%
12:03:21:WU02:FS01:Upload 65.20%
12:03:27:WU02:FS01:Upload 65.94%
12:03:33:WU02:FS01:Upload 66.67%
12:03:39:WU02:FS01:Upload 67.41%
12:03:45:WU02:FS01:Upload 68.15%
12:03:51:WU02:FS01:Upload 68.89%
12:03:57:WU01:FS01:0x22:Completed 21000 out of 700000 steps (3%)
12:03:57:WU02:FS01:Upload 69.62%
12:04:01:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
12:04:03:WU02:FS01:Upload 70.36%
12:04:09:WU02:FS01:Upload 71.10%
12:04:15:WU02:FS01:Upload 71.84%
12:04:22:WU02:FS01:Upload 72.72%
12:04:28:WU02:FS01:Upload 73.46%
12:04:34:WU02:FS01:Upload 74.20%
12:04:40:WU02:FS01:Upload 74.93%
12:04:46:WU02:FS01:Upload 75.67%
12:04:52:WU02:FS01:Upload 76.41%
12:04:58:WU02:FS01:Upload 77.15%
12:05:04:WU02:FS01:Upload 77.88%
12:05:10:WU02:FS01:Upload 78.62%
12:05:16:WU02:FS01:Upload 79.36%
12:05:22:WU02:FS01:Upload 80.10%
12:05:28:WU02:FS01:Upload 80.83%
12:05:34:WU02:FS01:Upload 81.57%
12:05:40:WU02:FS01:Upload 82.31%
12:05:46:WU02:FS01:Upload 83.05%
12:05:52:WU02:FS01:Upload 83.78%
12:05:59:WU02:FS01:Upload 84.67%
12:06:05:WU02:FS01:Upload 85.41%
12:06:11:WU02:FS01:Upload 86.14%
12:06:17:WU02:FS01:Upload 86.88%
12:06:23:WU02:FS01:Upload 87.62%
12:06:29:WU02:FS01:Upload 88.36%
12:06:36:WU02:FS01:Upload 89.24%
12:06:40:WU01:FS01:0x22:Completed 28000 out of 700000 steps (4%)
12:06:42:WU02:FS01:Upload 89.98%
12:06:48:WU02:FS01:Upload 90.72%
12:06:54:WU02:FS01:Upload 91.45%
12:07:00:WU02:FS01:Upload 92.19%
12:07:06:WU02:FS01:Upload 92.93%
12:07:12:WU02:FS01:Upload 93.67%
12:07:18:WU02:FS01:Upload 94.40%
12:07:25:WU02:FS01:Upload 95.29%
12:07:31:WU02:FS01:Upload 96.03%
12:07:37:WU02:FS01:Upload 96.76%
12:07:43:WU02:FS01:Upload 97.50%
12:07:50:WU02:FS01:Upload 98.39%
12:07:56:WU02:FS01:Upload 99.12%
12:08:02:WU02:FS01:Upload 99.86%
12:08:04:WU02:FS01:Upload complete
12:08:04:WU02:FS01:Server responded WORK_ACK (400)
12:08:04:WU02:FS01:Final credit estimate, 61134.00 points
12:08:04:WU02:FS01:Cleaning up
12:09:24:WU01:FS01:0x22:Completed 35000 out of 700000 steps (5%)
12:09:49:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
12:10:43:85:127.0.0.1:New Web session
12:12:24:WU01:FS01:0x22:Completed 42000 out of 700000 steps (6%)
12:15:07:WU01:FS01:0x22:Completed 49000 out of 700000 steps (7%)
12:15:54:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
12:17:51:WU01:FS01:0x22:Completed 56000 out of 700000 steps (8%)
12:19:09:111:127.0.0.1:New Web session
12:19:09:110:127.0.0.1:New Web session
12:20:53:WU01:FS01:0x22:Completed 63000 out of 700000 steps (9%)
12:21:54:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
12:23:33:WU01:FS01:0x22:Completed 70000 out of 700000 steps (10%)
12:26:14:WU01:FS01:0x22:Completed 77000 out of 700000 steps (11%)
12:27:30:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
12:29:13:WU01:FS01:0x22:Completed 84000 out of 700000 steps (12%)
12:31:54:WU01:FS01:0x22:Completed 91000 out of 700000 steps (13%)
12:33:02:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
12:34:35:WU01:FS01:0x22:Completed 98000 out of 700000 steps (14%)
12:37:31:WU01:FS01:0x22:Completed 105000 out of 700000 steps (15%)
12:38:39:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
12:40:09:WU01:FS01:0x22:Completed 112000 out of 700000 steps (16%)
12:42:50:WU01:FS01:0x22:Completed 119000 out of 700000 steps (17%)
12:44:06:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
12:45:45:WU01:FS01:0x22:Completed 126000 out of 700000 steps (18%)
12:48:26:WU01:FS01:0x22:Completed 133000 out of 700000 steps (19%)
12:49:21:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
12:51:06:WU01:FS01:0x22:Completed 140000 out of 700000 steps (20%)
12:54:02:WU01:FS01:0x22:Completed 147000 out of 700000 steps (21%)
12:54:35:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
12:56:41:WU01:FS01:0x22:Completed 154000 out of 700000 steps (22%)
12:59:37:WU01:FS01:0x22:Completed 161000 out of 700000 steps (23%)
12:59:57:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
13:02:17:WU01:FS01:0x22:Completed 168000 out of 700000 steps (24%)
13:04:56:WU01:FS01:0x22:Completed 175000 out of 700000 steps (25%)
13:05:31:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
13:07:53:WU01:FS01:0x22:Completed 182000 out of 700000 steps (26%)
13:10:33:WU01:FS01:0x22:Completed 189000 out of 700000 steps (27%)
13:11:00:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
13:13:13:WU01:FS01:0x22:Completed 196000 out of 700000 steps (28%)
13:16:09:WU01:FS01:0x22:Completed 203000 out of 700000 steps (29%)
13:16:36:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
13:18:50:WU01:FS01:0x22:Completed 210000 out of 700000 steps (30%)
13:21:30:WU01:FS01:0x22:Completed 217000 out of 700000 steps (31%)
13:21:55:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
13:24:26:WU01:FS01:0x22:Completed 224000 out of 700000 steps (32%)
13:27:06:WU01:FS01:0x22:Completed 231000 out of 700000 steps (33%)
13:27:29:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
13:29:46:WU01:FS01:0x22:Completed 238000 out of 700000 steps (34%)
13:32:44:WU01:FS01:0x22:Completed 245000 out of 700000 steps (35%)
13:33:14:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
13:35:25:WU01:FS01:0x22:Completed 252000 out of 700000 steps (36%)
13:38:05:WU01:FS01:0x22:Completed 259000 out of 700000 steps (37%)
13:38:59:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
13:41:02:WU01:FS01:0x22:Completed 266000 out of 700000 steps (38%)
13:43:42:WU01:FS01:0x22:Completed 273000 out of 700000 steps (39%)
13:44:40:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
13:46:22:WU01:FS01:0x22:Completed 280000 out of 700000 steps (40%)
13:49:23:WU01:FS01:0x22:Completed 287000 out of 700000 steps (41%)
13:50:14:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
13:52:05:WU01:FS01:0x22:Completed 294000 out of 700000 steps (42%)
13:55:04:WU01:FS01:0x22:Completed 301000 out of 700000 steps (43%)
13:56:15:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
13:57:43:WU01:FS01:0x22:Completed 308000 out of 700000 steps (44%)
14:00:24:WU01:FS01:0x22:Completed 315000 out of 700000 steps (45%)
14:01:45:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
14:03:19:WU01:FS01:0x22:Completed 322000 out of 700000 steps (46%)
14:06:00:WU01:FS01:0x22:Completed 329000 out of 700000 steps (47%)
14:07:14:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
14:08:39:WU01:FS01:0x22:Completed 336000 out of 700000 steps (48%)
14:11:35:WU01:FS01:0x22:Completed 343000 out of 700000 steps (49%)
14:12:43:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
14:14:17:WU01:FS01:0x22:Completed 350000 out of 700000 steps (50%)
14:16:57:WU01:FS01:0x22:Completed 357000 out of 700000 steps (51%)
******************************* Date: 2020-06-09 *******************************
14:18:14:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
14:19:54:WU01:FS01:0x22:Completed 364000 out of 700000 steps (52%)
14:22:34:WU01:FS01:0x22:Completed 371000 out of 700000 steps (53%)
14:23:37:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
14:25:13:WU01:FS01:0x22:Completed 378000 out of 700000 steps (54%)
14:28:10:WU01:FS01:0x22:Completed 385000 out of 700000 steps (55%)
14:29:13:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
14:30:51:WU01:FS01:0x22:Completed 392000 out of 700000 steps (56%)
14:33:32:WU01:FS01:0x22:Completed 399000 out of 700000 steps (57%)
14:34:35:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
14:36:27:WU01:FS01:0x22:Completed 406000 out of 700000 steps (58%)
14:39:07:WU01:FS01:0x22:Completed 413000 out of 700000 steps (59%)
14:40:00:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
14:41:47:WU01:FS01:0x22:Completed 420000 out of 700000 steps (60%)
14:44:43:WU01:FS01:0x22:Completed 427000 out of 700000 steps (61%)
14:45:24:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
14:47:23:WU01:FS01:0x22:Completed 434000 out of 700000 steps (62%)
14:50:17:WU01:FS01:0x22:Completed 441000 out of 700000 steps (63%)
14:50:54:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
14:52:57:WU01:FS01:0x22:Completed 448000 out of 700000 steps (64%)
14:55:37:WU01:FS01:0x22:Completed 455000 out of 700000 steps (65%)
14:56:20:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
14:58:34:WU01:FS01:0x22:Completed 462000 out of 700000 steps (66%)
15:01:15:WU01:FS01:0x22:Completed 469000 out of 700000 steps (67%)
15:01:51:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
15:03:56:WU01:FS01:0x22:Completed 476000 out of 700000 steps (68%)
15:06:50:WU01:FS01:0x22:Completed 483000 out of 700000 steps (69%)
15:07:30:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
15:09:31:WU01:FS01:0x22:Completed 490000 out of 700000 steps (70%)
15:12:11:WU01:FS01:0x22:Completed 497000 out of 700000 steps (71%)
15:12:58:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
15:15:09:WU01:FS01:0x22:Completed 504000 out of 700000 steps (72%)
15:17:49:WU01:FS01:0x22:Completed 511000 out of 700000 steps (73%)
15:18:28:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
15:20:29:WU01:FS01:0x22:Completed 518000 out of 700000 steps (74%)
15:23:26:WU01:FS01:0x22:Completed 525000 out of 700000 steps (75%)
15:24:01:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
15:26:07:WU01:FS01:0x22:Completed 532000 out of 700000 steps (76%)
15:28:47:WU01:FS01:0x22:Completed 539000 out of 700000 steps (77%)
15:29:29:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
15:31:43:WU01:FS01:0x22:Completed 546000 out of 700000 steps (78%)
15:34:22:WU01:FS01:0x22:Completed 553000 out of 700000 steps (79%)
15:35:03:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
15:36:06:148:127.0.0.1:New Web session
15:37:03:WU01:FS01:0x22:Completed 560000 out of 700000 steps (80%)
15:40:05:WU01:FS01:0x22:Completed 567000 out of 700000 steps (81%)
15:41:09:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
15:42:46:WU01:FS01:0x22:Completed 574000 out of 700000 steps (82%)
15:45:42:WU01:FS01:0x22:Completed 581000 out of 700000 steps (83%)
15:47:03:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
15:48:23:WU01:FS01:0x22:Completed 588000 out of 700000 steps (84%)
15:51:02:WU01:FS01:0x22:Completed 595000 out of 700000 steps (85%)
15:52:43:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
15:53:57:WU01:FS01:0x22:Completed 602000 out of 700000 steps (86%)
15:56:39:WU01:FS01:0x22:Completed 609000 out of 700000 steps (87%)
15:58:21:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
15:59:22:WU01:FS01:0x22:Completed 616000 out of 700000 steps (88%)
16:02:18:WU01:FS01:0x22:Completed 623000 out of 700000 steps (89%)
16:04:00:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
16:04:59:WU01:FS01:0x22:Completed 630000 out of 700000 steps (90%)
16:07:41:WU01:FS01:0x22:Completed 637000 out of 700000 steps (91%)
16:09:18:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
16:10:39:WU01:FS01:0x22:Completed 644000 out of 700000 steps (92%)
16:13:19:WU01:FS01:0x22:Completed 651000 out of 700000 steps (93%)
16:14:54:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
16:15:59:WU01:FS01:0x22:Completed 658000 out of 700000 steps (94%)
16:18:56:WU01:FS01:0x22:Completed 665000 out of 700000 steps (95%)
16:20:27:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
16:21:35:WU01:FS01:0x22:Completed 672000 out of 700000 steps (96%)
16:24:17:WU01:FS01:0x22:Completed 679000 out of 700000 steps (97%)
16:26:28:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
16:27:14:WU01:FS01:0x22:Completed 686000 out of 700000 steps (98%)
16:29:55:WU01:FS01:0x22:Completed 693000 out of 700000 steps (99%)
16:29:56:WU02:FS01:Connecting to assign1.foldingathome.org:80
16:29:56:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:29:56:WU02:FS01:Connecting to assign2.foldingathome.org:80
16:29:57:WU02:FS01:Assigned to work server 206.223.170.146
16:29:57:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP106 [GeForce GTX 1060 6GB] 4372 from 206.223.170.146
16:29:57:WU02:FS01:Connecting to 206.223.170.146:8080
16:30:06:WU02:FS01:Downloading 38.52MiB
16:30:12:WU02:FS01:Download 18.34%
16:30:18:WU02:FS01:Download 32.62%
16:30:24:WU02:FS01:Download 43.97%
16:30:30:WU02:FS01:Download 54.03%
16:30:36:WU02:FS01:Download 66.69%
16:30:42:WU02:FS01:Download 78.37%
16:30:48:WU02:FS01:Download 89.41%
16:30:53:WU02:FS01:Download complete
16:30:53:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14251 run:120 clone:3 gen:70 core:0x22 unit:0x0000006acedfaa925eab03238c03ed1c
16:32:14:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
16:32:35:WU01:FS01:0x22:Completed 700000 out of 700000 steps (100%)
16:32:50:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
16:32:50:WU01:FS01:0x22:Saving result file checkpointState.xml
16:32:58:WU01:FS01:0x22:Saving result file checkpt.crc
16:32:58:WU01:FS01:0x22:Saving result file positions.xtc
16:33:01:WU01:FS01:0x22:Saving result file science.log
16:33:01:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
16:33:02:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:33:02:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:16442 run:0 clone:1788 gen:60 core:0x22 unit:0x0000006080fccb015eaa1bf29f739878
16:33:02:WU01:FS01:Uploading 50.40MiB to 128.252.203.1
16:33:02:WU01:FS01:Connecting to 128.252.203.1:8080
16:33:02:WU02:FS01:Starting
16:33:02:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\PC\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 4140 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
16:33:02:WU02:FS01:Started FahCore on PID 4604
16:33:02:WU02:FS01:Core PID:1524
16:33:02:WU02:FS01:FahCore 0x22 started
16:33:03:WU02:FS01:0x22:*********************** Log Started 2020-06-09T16:33:02Z ***********************
16:33:03:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
16:33:03:WU02:FS01:0x22:       Type: 0x22
16:33:03:WU02:FS01:0x22:       Core: Core22
16:33:03:WU02:FS01:0x22:    Website: https://foldingathome.org/
16:33:03:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
16:33:03:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
16:33:03:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
16:33:03:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 4604 -checkpoint 15
16:33:03:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
16:33:03:WU02:FS01:0x22:             0 -gpu 0
16:33:03:WU02:FS01:0x22:     Config: <none>
16:33:03:WU02:FS01:0x22:************************************ Build *************************************
16:33:03:WU02:FS01:0x22:    Version: 0.0.5
16:33:03:WU02:FS01:0x22:       Date: Apr 22 2020
16:33:03:WU02:FS01:0x22:       Time: 04:42:59
16:33:03:WU02:FS01:0x22: Repository: Git
16:33:03:WU02:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
16:33:03:WU02:FS01:0x22:     Branch: HEAD
16:33:03:WU02:FS01:0x22:   Compiler: Visual C++ 2008
16:33:03:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:33:03:WU02:FS01:0x22:   Platform: win32 10
16:33:03:WU02:FS01:0x22:       Bits: 64
16:33:03:WU02:FS01:0x22:       Mode: Release
16:33:03:WU02:FS01:0x22:************************************ System ************************************
16:33:03:WU02:FS01:0x22:        CPU: Intel(R) Xeon(R) CPU X3470 @ 2.93GHz
16:33:03:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
16:33:03:WU02:FS01:0x22:       CPUs: 8
16:33:03:WU02:FS01:0x22:     Memory: 7.99GiB
16:33:03:WU02:FS01:0x22:Free Memory: 5.54GiB
16:33:03:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
16:33:03:WU02:FS01:0x22: OS Version: 6.1
16:33:03:WU02:FS01:0x22:Has Battery: false
16:33:03:WU02:FS01:0x22: On Battery: false
16:33:03:WU02:FS01:0x22: UTC Offset: 2
16:33:03:WU02:FS01:0x22:        PID: 1524
16:33:03:WU02:FS01:0x22:        CWD: C:\Users\PC\AppData\Roaming\FAHClient\work
16:33:03:WU02:FS01:0x22:         OS: Windows 7 Professional Service Pack 1
16:33:03:WU02:FS01:0x22:    OS Arch: AMD64
16:33:03:WU02:FS01:0x22:********************************************************************************
16:33:03:WU02:FS01:0x22:Project: 14251 (Run 120, Clone 3, Gen 70)
16:33:03:WU02:FS01:0x22:Unit: 0x0000006acedfaa925eab03238c03ed1c
16:33:03:WU02:FS01:0x22:Reading tar file core.xml
16:33:03:WU02:FS01:0x22:Reading tar file integrator.xml
16:33:03:WU02:FS01:0x22:Reading tar file state.xml
16:33:05:WU02:FS01:0x22:Reading tar file system.xml
16:33:07:WU02:FS01:0x22:Digital signatures verified
16:33:07:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
16:33:07:WU02:FS01:0x22:Version 0.0.5
16:33:08:WU01:FS01:Upload 0.99%
16:33:14:WU01:FS01:Upload 1.98%
16:33:20:WU01:FS01:Upload 2.98%
16:33:26:WU01:FS01:Upload 3.97%
16:33:32:WU01:FS01:Upload 4.96%
16:33:38:WU01:FS01:Upload 5.95%
16:33:44:WU01:FS01:Upload 6.94%
16:33:50:WU01:FS01:Upload 7.81%
16:33:56:WU01:FS01:Upload 8.80%
16:34:02:WU01:FS01:Upload 9.80%
16:34:08:WU01:FS01:Upload 10.79%
16:34:14:WU01:FS01:Upload 11.78%
16:34:20:WU01:FS01:Upload 12.77%
16:34:26:WU02:FS01:0x22:Completed 0 out of 500000 steps (0%)
16:34:26:WU01:FS01:Upload 13.76%
16:34:26:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:34:32:WU01:FS01:Upload 14.76%
16:34:38:WU01:FS01:Upload 15.75%
16:34:44:WU01:FS01:Upload 16.74%
16:34:50:WU01:FS01:Upload 17.73%
16:34:56:WU01:FS01:Upload 18.72%
16:35:02:WU01:FS01:Upload 19.72%
16:35:08:WU01:FS01:Upload 20.71%
16:35:14:WU01:FS01:Upload 21.70%
16:35:20:WU01:FS01:Upload 22.69%
16:35:26:WU01:FS01:Upload 23.68%
16:35:32:WU01:FS01:Upload 24.68%
16:35:38:WU01:FS01:Upload 25.54%
16:35:44:WU01:FS01:Upload 26.54%
16:35:50:WU01:FS01:Upload 27.53%
16:35:56:WU01:FS01:Upload 28.52%
16:36:02:WU01:FS01:Upload 29.51%
16:36:08:WU01:FS01:Upload 30.51%
16:36:14:WU01:FS01:Upload 31.50%
16:36:20:WU01:FS01:Upload 32.49%
16:36:26:WU01:FS01:Upload 33.48%
16:36:32:WU01:FS01:Upload 34.47%
16:36:38:WU01:FS01:Upload 35.47%
16:36:44:WU01:FS01:Upload 36.46%
16:36:50:WU01:FS01:Upload 37.45%
16:36:56:WU01:FS01:Upload 38.44%
16:37:02:WU01:FS01:Upload 39.43%
16:37:08:WU01:FS01:Upload 40.43%
16:37:14:WU01:FS01:Upload 41.29%
16:37:20:WU01:FS01:Upload 42.29%
16:37:26:WU01:FS01:Upload 43.28%
16:37:32:WU01:FS01:Upload 44.27%
16:37:38:WU01:FS01:Upload 45.26%
16:37:44:WU01:FS01:Upload 46.25%
16:37:47:WU02:FS01:0x22:Completed 5000 out of 500000 steps (1%)
16:37:50:WU01:FS01:Upload 47.25%
16:37:56:WU01:FS01:Upload 48.24%
16:38:02:WU01:FS01:Upload 49.23%
16:38:08:WU01:FS01:Upload 50.22%
16:38:09:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
16:38:14:WU01:FS01:Upload 51.21%
16:38:20:WU01:FS01:Upload 52.21%
16:38:26:WU01:FS01:Upload 53.07%
16:38:32:WU01:FS01:Upload 54.07%
16:38:38:WU01:FS01:Upload 55.06%
16:38:44:WU01:FS01:Upload 56.05%
16:38:50:WU01:FS01:Upload 57.04%
16:38:56:WU01:FS01:Upload 58.03%
16:39:02:WU01:FS01:Upload 59.03%
16:39:08:WU01:FS01:Upload 60.02%
16:39:14:WU01:FS01:Upload 61.01%
16:39:20:WU01:FS01:Upload 62.00%
16:39:26:WU01:FS01:Upload 62.99%
16:39:32:WU01:FS01:Upload 63.99%
16:39:38:WU01:FS01:Upload 64.98%
16:39:44:WU01:FS01:Upload 65.97%
16:39:50:WU01:FS01:Upload 66.96%
16:39:56:WU01:FS01:Upload 67.95%
16:40:02:WU01:FS01:Upload 68.95%
16:40:08:WU01:FS01:Upload 69.81%
16:40:14:WU01:FS01:Upload 70.81%
16:40:20:WU01:FS01:Upload 71.80%
16:40:26:WU01:FS01:Upload 72.79%
16:40:32:WU01:FS01:Upload 73.78%
16:40:38:WU01:FS01:Upload 74.77%
16:40:44:WU01:FS01:Upload 75.77%
16:40:50:WU01:FS01:Upload 76.76%
16:40:56:WU01:FS01:Upload 77.75%
16:41:02:WU01:FS01:Upload 78.74%
16:41:03:WU02:FS01:0x22:Completed 10000 out of 500000 steps (2%)
16:41:08:WU01:FS01:Upload 79.73%
16:41:14:WU01:FS01:Upload 80.73%
16:41:20:WU01:FS01:Upload 81.72%
16:41:26:WU01:FS01:Upload 82.71%
16:41:32:WU01:FS01:Upload 83.70%
16:41:38:WU01:FS01:Upload 84.69%
16:41:44:WU01:FS01:Upload 85.69%
16:41:50:WU01:FS01:Upload 86.68%
16:41:56:WU01:FS01:Upload 87.67%
16:42:02:WU01:FS01:Upload 88.66%
16:42:08:WU01:FS01:Upload 89.66%
16:42:14:WU01:FS01:Upload 90.65%
16:42:20:WU01:FS01:Upload 91.64%
16:42:26:WU01:FS01:Upload 92.63%
16:42:32:WU01:FS01:Upload 93.62%
16:42:38:WU01:FS01:Upload 94.62%
16:42:44:WU01:FS01:Upload 95.61%
16:42:50:WU01:FS01:Upload 96.60%
16:42:56:WU01:FS01:Upload 97.59%
16:43:02:WU01:FS01:Upload 98.58%
16:43:08:WU01:FS01:Upload 99.58%
16:43:12:WU01:FS01:Upload complete
16:43:12:WU01:FS01:Server responded WORK_ACK (400)
16:43:12:WU01:FS01:Final credit estimate, 79351.00 points
16:43:12:WU01:FS01:Cleaning up
16:43:57:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
16:44:19:WU02:FS01:0x22:Completed 15000 out of 500000 steps (3%)
16:47:33:WU02:FS01:0x22:Completed 20000 out of 500000 steps (4%)
16:49:36:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
16:51:12:WU02:FS01:0x22:Completed 25000 out of 500000 steps (5%)
16:54:26:WU02:FS01:0x22:Completed 30000 out of 500000 steps (6%)
16:55:13:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
16:57:39:WU02:FS01:0x22:Completed 35000 out of 500000 steps (7%)
17:00:50:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
17:00:54:WU02:FS01:0x22:Completed 40000 out of 500000 steps (8%)
17:04:34:WU02:FS01:0x22:Completed 45000 out of 500000 steps (9%)
17:06:26:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
17:07:48:WU02:FS01:0x22:Completed 50000 out of 500000 steps (10%)
17:11:04:WU02:FS01:0x22:Completed 55000 out of 500000 steps (11%)
17:11:59:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
17:13:45:FS01:Shutting core down
17:13:45:FS00:Shutting core down
17:13:45:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 5124
17:13:45:WU00:FS00:0xa7:Exiting, please wait. . .
17:13:46:WU02:FS01:0x22:WARNING:Console control signal 1 on PID 1524
17:13:46:WU02:FS01:0x22:Exiting, please wait. . .
17:13:46:WU02:FS01:0x22:Lost lifeline PID 4604, exiting
17:13:46:WU02:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
17:13:47:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
17:13:48:Clean exit
Welcome to Folding@home!
Firstly, your PC is doing fine!
You have an older CPU, as are many of mine, so it does SSE2, as it is not new enough for AVX_256.
https://ark.intel.com/content/www/us/en ... 3-ghz.html
it has 8 threads, (F@H calls them CPUs) and one is used to feed data to the GTX 1060 6GB.
Because 7 threads is Prime, and F@H hates primes and prime factors over 3, it only uses 6 threads.
-nt 6 hints it is using 6 threads
You can adjust this manually, or let F@H make the adjustment for you.
But really, looking good! (My PC with a GTX 1060 6 gb does about 400,000 PPD)
To adjust manually:
Type the number you want, 6, and click save.
zarluk1
Post by zarluk1 »
ajm wrote:It looks like you got your bonus:
https://apps.foldingathome.org/bonus
I have currently processed 78 units WU how to check if I have met the required criteria for qbr GPU ??
ajm
Post by ajm »
You enter your username at the said address and the field "Bonus Active" tells you that:
zarluk1
Post by zarluk1 »
GPU 400 PPD score the value marked in red
ajm
Post by ajm »
Yes, so? That's about right for a 1060. You could get up to 480k in ideal conditions:
https://docs.google.com/spreadsheets/d/ ... Ek/pubhtml
zarluk1
Post by zarluk1 »
received 83,661.9 instead of 418 021
Dora CPU matters or not
ajm
Post by ajm »
Ah, but it's only normal: 418k is what you get in a whole day, that is, if your card folds during 24h - that is what it says: Points per day.
For that particular WU, you get what is indicated above "Estimated points". The exact amount is calculated when the crunched WU is returned to the server.
kiore
Post by kiore »
zarluk1 wrote:received 83,661.9 instead of 418 021
This is the amount of points for the project the PPD is the amount estimated to be generated over a 24hrs period so it calculates that you could do nearly 5 projects like this per day.
Post by Neil-B »
So if you look to the right of where you have circled in red you will see 84185 Estimated Points … This is what the client estimates your WU to be worth but there are a few variables as it is the time sent from the server and received by the server that count and the client cannot be sure of the last until it has been sent - this is why your actual points for that WU of 83,661.9 were slightly different/lower - you logs should have a line such as "16:30:55:WU01:FS01:Final credit estimate, 10588.00 points" which give the best Estimate, but this is still just an estimate - The final points are confirmed by the server to the stats system.
PPD is simply the client estimating what Total Points Per Day (not per WU) you might be able to achieve if run continuously on identical WUs (even WUs within a Project can have some variation) … This isn't any form of promise that that is what you get - It is used mostly for people to get a quick idea if there are issues with their kit as after a while one gets used to the range of PPDs that ones kit tends to produce - Some WUs produce higher points, others lower - and it can depend on the type of kit - Some WUs the faster GPUs may score lower points than usual whereas the slower GPUs are getting higher points than normal.
