transfer work uniyts
how do i transfer the work units earned prior to joining a team to the team i joined?
Re: transfer work uniyts
Not possible.
It stays with the team that you had when the team earned those points.
The same would be true if you changed your user-name
as per bruce ... you can't ... points remain associated with the username/team pairing at the time they were earned ... prior to joining the team you have joined the points will be associated with username/"no team" ... that is just the way it is (for various reasons explained better than I can in other topic threads.
