List of Project Contributors shows wrong information
rechenzeit
Post by rechenzeit »
When I access the contributors list
https://stats.foldingathome.org/contrib ... 0000-10010
and search for my user name "fbuchinger" on that list, I get a match although I've never contributed to this project. Is this a bug or was my subsequent search across all of donations?
Re: List of Project Contributors shows wrong information
Just to be clear, you have maintained a history of every single WU your system(s) folded and across them, you haven't contributed to to those Projects?
I am aware that while the database has a lot of information for the saved WU, the Stats system doesn't have information on WUs contributed per Project for a Donor.
rechenzeit
I deliberately chose this project because according to https://api.foldingathome.org/project it was last modified in September 2018 and I started folding in March 2020. Hence it didn't seem very likely to me that I contributed to this project.
Many of the specialized lookups like the one in your OP were disabled due to the load on the stats servers from the increased participation due to COVID-19. So the API calls to other information are being ignored, and the link is just getting you to the landing page for Donor Statistics and showing the top 100 folders by points earned. The match you got was for the actual total of WUs processed and points earned, not for a specific range of projects. In effect you were going to https://stats.foldingathome.org/donors and https://stats.foldingathome.org/donor/66745553.
Much of the direct API links as used in your post just now are not working, or connecting to old summaries on the servers that have not been updated. They may or may not be turned back on, the stats server is just about keeping up with the current level of entries and requests for individual team and donor stats.
As for username "fbuchinger", I see that a total of 108 WUs have been returned, the first sometime in mid-March, the last about a month later in April.
