Problem with PCI Riser
doctorzaius
My computer for folding has two RTX 2070s and runs Ubuntu (20.04) and works great. I'd like to move one of the GPUs to a 1x-16x riser, mostly to reduce heat and noise. I've tried to to that and it looks like linux sees the card. In particular, the nvidia application is able to report stats about that card (e.g., temperature, fan speed, etc.). But FAH can't add it as a GPU. Where does one even start to trouble shoot this?
doctorzaius
Re: Problem with PCI Riser
Please ignore--its working now.
Welcome to the F@H Forum doctorzaius,
I am glad that you resolved the issue
Please note that for future Donors, it would be nice if you could share your findings to ensure that they too can solve the same issue you faced.
doctorzaius
I'm not entirely sure why it started working. However, I think that removing the GPU (from the client configuration) and then adding it back after switching to the riser was the likely cure. In the first instance, I'm pretty sure I had not removed the GPU.
