missing credit server 155.247.164.214
goodyca
Post by goodyca »
The following WU's were successfully uploaded to the subject server, but no credit was issued. I have checked the WU Status of each at https://apps.foldingathome.org/wu, and they all show as "Not found."
Completion Time and Project Description
06/05/20 03:48 AM Project: 14852 (Run 120, Clone 4, Gen 75)
06/05/20 11:18 AM Project: 14725 (Run 211, Clone 2, Gen 68)
06/05/20 12:33 PM Project: 14725 (Run 17, Clone 1, Gen 80)
06/05/20 09:22 PM Project: 14822 (Run 276, Clone 4, Gen 107)
06/05/20 11:01 PM Project: 14827 (Run 1942, Clone 0, Gen 90)
06/06/20 04:44 AM Project: 14827 (Run 1177, Clone 0, Gen 73)
06/06/20 12:19 PM Project: 14821 (Run 14, Clone 1, Gen 97)
Here is example log file for one of the WU's
10:22:13:WU02:FS00:Connecting to 65.254.110.245:80
10:22:13:WU02:FS00:Assigned to work server 155.247.164.214
10:22:13:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:9 from 155.247.164.214
10:22:13:WU02:FS00:Connecting to 155.247.164.214:8080
10:22:14:WU02:FS00:Downloading 2.80MiB
10:22:14:WU02:FS00:Download complete
10:22:14:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14821 run:14 clone:1 gen:97 core:0xa7 unit:0x0000007d9bf7a4d65e9ef9cdd671d6c3
10:22:15:WU02:FS00:Starting
10:22:15:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 02 -suffix 01 -version 706 -lifeline 1343 -checkpoint 15 -np 9
10:22:15:WU02:FS00:Started FahCore on PID 768020
10:22:15:WU02:FS00:Core PID:768024
10:22:15:WU02:FS00:FahCore 0xa7 started
10:22:16:WU02:FS00:0xa7:*********************** Log Started 2020-06-06T10:22:15Z ***********************
10:22:16:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:22:16:WU02:FS00:0xa7:       Type: 0xa7
10:22:16:WU02:FS00:0xa7:       Core: Gromacs
10:22:16:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 768020 -checkpoint 15 -np
10:22:16:WU02:FS00:0xa7:             9
10:22:16:WU02:FS00:0xa7:************************************ CBang *************************************
10:22:16:WU02:FS00:0xa7:       Date: Nov 5 2019
10:22:16:WU02:FS00:0xa7:       Time: 06:06:57
10:22:16:WU02:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
10:22:16:WU02:FS00:0xa7:     Branch: master
10:22:16:WU02:FS00:0xa7:   Compiler: GNU 8.3.0
10:22:16:WU02:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
10:22:16:WU02:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
10:22:16:WU02:FS00:0xa7:       Bits: 64
10:22:16:WU02:FS00:0xa7:       Mode: Release
10:22:16:WU02:FS00:0xa7:************************************ System ************************************
10:22:16:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-4930K CPU @ 3.40GHz
10:22:16:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 62 Stepping 4
10:22:16:WU02:FS00:0xa7:       CPUs: 12
10:22:16:WU02:FS00:0xa7:     Memory: 15.56GiB
10:22:16:WU02:FS00:0xa7:Free Memory: 2.19GiB
10:22:16:WU02:FS00:0xa7:    Threads: POSIX_THREADS
10:22:16:WU02:FS00:0xa7: OS Version: 5.6
10:22:16:WU02:FS00:0xa7:Has Battery: false
10:22:16:WU02:FS00:0xa7: On Battery: false
10:22:16:WU02:FS00:0xa7: UTC Offset: -5
10:22:16:WU02:FS00:0xa7:        PID: 768024
10:22:16:WU02:FS00:0xa7:        CWD: /var/lib/fahclient/work
10:22:16:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
10:22:16:WU02:FS00:0xa7:    Version: 0.0.18
10:22:16:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:22:16:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:22:16:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
10:22:16:WU02:FS00:0xa7:       Time: 06:13:26
10:22:16:WU02:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
10:22:16:WU02:FS00:0xa7:************************************ Build *************************************
10:22:16:WU02:FS00:0xa7:       SIMD: avx_256
10:22:16:WU02:FS00:0xa7:********************************************************************************
10:22:16:WU02:FS00:0xa7:Project: 14821 (Run 14, Clone 1, Gen 97)
10:22:16:WU02:FS00:0xa7:Unit: 0x0000007d9bf7a4d65e9ef9cdd671d6c3
10:22:16:WU02:FS00:0xa7:Reading tar file core.xml
10:22:16:WU02:FS00:0xa7:Reading tar file frame97.tpr
10:22:16:WU02:FS00:0xa7:Digital signatures verified
10:22:16:WU02:FS00:0xa7:Calling: mdrun -s frame97.tpr -o frame97.trr -cpt 15 -nt 9
10:22:16:WU02:FS00:0xa7:Steps: first=0 total=250000
10:22:17:WU02:FS00:0xa7:Completed 1 out of 250000 steps (0%)
10:23:27:WU02:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
10:24:36:WU02:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
10:25:45:WU02:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
12:15:30:WU02:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
12:16:44:WU02:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
12:17:55:WU02:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
12:19:06:WU02:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
12:19:08:WU02:FS00:0xa7:Saving result file ../logfile_01.txt
12:19:08:WU02:FS00:0xa7:Saving result file dhdl.xvg
12:19:08:WU02:FS00:0xa7:Saving result file frame97.trr
12:19:08:WU02:FS00:0xa7:Saving result file md.log
12:19:08:WU02:FS00:0xa7:Saving result file pullf.xvg
12:19:08:WU02:FS00:0xa7:Saving result file pullx.xvg
12:19:08:WU02:FS00:0xa7:Saving result file science.log
12:19:08:WU02:FS00:0xa7:Saving result file traj_comp.xtc
12:19:08:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
12:19:09:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:19:09:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14821 run:14 clone:1 gen:97 core:0xa7 unit:0x0000007d9bf7a4d65e9ef9cdd671d6c3
12:19:09:WU02:FS00:Uploading 6.78MiB to 155.247.164.214
12:19:09:WU02:FS00:Connecting to 155.247.164.214:8080
12:19:15:WU02:FS00:Upload 36.88%
12:19:21:WU02:FS00:Upload 71.92%
12:19:27:WU02:FS00:Upload complete
12:19:28:WU02:FS00:Server responded WORK_ACK (400)
12:19:28:WU02:FS00:Final credit estimate, 4971.00 points
12:19:28:WU02:FS00:Cleaning up
TPL
Re: missing credit server 155.247.164.214
Post by TPL »
It seems to have problem. I made quick check and I have at least two not found WUs:
14725 113 0 116
14827 319 1 59
Post by Neil-B »
As long as you are seeing the:
logs for each WU then you will at some point get credited - this can be days or even weeks ... This happens occasionally (not often) and it is possible to build up quite a stack of "owed" WUs (I have got over 100 in the past) ... When the team get round to kicking the stats pipes hard enough you will get them all back in one go - acts as quite a nice "surprise" present :)
Posting here and highlighting the issue is exactly there right thing to do as it gives the team a heads up and lets others know it has been raised :)
I passed on the report to the person in charge of that server.
daibak
Post by daibak »
Unsure if I'm addressing this complaint to the correct server but I seem to be missing 2673.00 points from Sunday 2020-06-07 server 155.247.164.214:8080 too for one WU, if I'm reading the FAHControl log correctly. Thanks for any assistance.
01:49:51:WU01:FS00:Downloading 4.49MiB
01:49:53:WU01:FS00:Download complete
01:49:53:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16805 run:14 clone:215 gen:28 core:0xa7 unit:0x0000002182ed0b915eb4218b49d78982
01:53:47:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
01:53:49:WU00:FS00:0xa7:Saving result file ../logfile_01.txt
01:53:49:WU00:FS00:0xa7:Saving result file dhdl.xvg
01:53:49:WU00:FS00:0xa7:Saving result file frame74.trr
01:53:49:WU00:FS00:0xa7:Saving result file md.log
01:53:50:WU00:FS00:0xa7:Saving result file pullf.xvg
01:53:50:WU00:FS00:0xa7:Saving result file pullx.xvg
01:53:50:WU00:FS00:0xa7:Saving result file science.log
01:53:50:WU00:FS00:0xa7:Saving result file traj_comp.xtc
01:53:50:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
01:53:50:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:53:50:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14852 run:180 clone:2 gen:74 core:0xa7 unit:0x0000005a9bf7a4d65ea1036df1b7f4c2
01:53:50:WU00:FS00:Uploading 6.80MiB to 155.247.164.214
01:53:50:WU00:FS00:Connecting to 155.247.164.214:8080
01:53:56:WU00:FS00:Upload 39.54%
01:54:02:WU00:FS00:Upload 77.24%
01:54:06:WU00:FS00:Upload complete
01:54:06:WU00:FS00:Server responded WORK_ACK (400)
01:54:06:WU00:FS00:Final credit estimate, 2673.00 points
01:54:06:WU00:FS00:Cleaning up
Mod Edit: Changed Quote Tags To Code Tags - PantherX
