F@H ignores "on idle"
I have Folding@Home running on 4 laptops. On one of them the "on idle" often does nothing and it runs all the time killing my performance. Sometimes it'll even be working and then in the middle of gaming it's decided to ignore that setting again.
Same problem on the version I installed back in March and I just updated the other day to see if that would fix it. It did not.
This machine is running Windows 7 Ultimate. The other machines are running the following and appear to not have issues.
Windows 7 Pro
Windows 8.1
Windows 10
This machine has an nVidia cards while all the others only have integrated Intel.
Any ideas?
Windows 7 Pro
Windows 8.1
Windows 10
Any ideas?
Re: F@H ignores "on idle"
Welcome to the F@H Forum unL33T,
Can you please post the log file? Ensure you include the first 100 lines which will inform us of what the system configuration is and what the client settings are. If you require guidance, please view this topic: viewtopic.php?f=24&t=26036
By default, the client doesn't ignore the on idle setting so something has changed. Once we have the log file, it will help us troubleshoot.
*********************** Log Started 2020-06-03T11:43:38Z ***********************
11:43:38:Trying to access database...
11:43:39:Successfully acquired database lock
11:43:39:Downloading GPUs.txt from assign1.foldingathome.org:80
11:43:39:Connecting to assign1.foldingathome.org:80
11:43:39:Read GPUs.txt
11:43:40:Enabled folding slot 01: PAUSED gpu:0:GF106 [Quadro 2000M] 422 (waiting for idle)
11:43:40:****************************** FAHClient ******************************
11:43:40: Version: 7.6.13
11:43:40: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:43:40: Copyright: 2020 foldingathome.org
11:43:40: Homepage: https://foldingathome.org/
11:43:40: Date: Apr 27 2020
11:43:40: Time: 21:21:01
11:43:40: Revision: 5a652817f46116b6e135503af97f18e094414e3b
11:43:40: Branch: master
11:43:40: Compiler: Visual C++ 2008
11:43:40: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:43:40: Platform: win32 10
11:43:40: Bits: 32
11:43:40: Mode: Release
11:43:40: Args: --open-web-control
11:43:40: Config: C:\Users\Jon\AppData\Roaming\FAHClient\config.xml
11:43:40:******************************** CBang ********************************
11:43:40: Date: Apr 24 2020
11:43:40: Time: 17:07:55
11:43:40: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
11:43:40: Bits: 32
11:43:40:******************************* System ********************************
11:43:40: CPU: Intel(R) Core(TM) i7-2860QM CPU @ 2.50GHz
11:43:40: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
11:43:40: CPUs: 8
11:43:40: Memory: 7.88GiB
11:43:40: Free Memory: 5.01GiB
11:43:40: Threads: WINDOWS_THREADS
11:43:40: OS Version: 6.1
11:43:40: Has Battery: true
11:43:40: On Battery: true
11:43:40: UTC Offset: -4
11:43:40: PID: 8344
11:43:40: CWD: C:\Users\Jon\AppData\Roaming\FAHClient
11:43:40: Win32 Service: false
11:43:40: OS: Windows 7 Ultimate
11:43:40: OS Arch: AMD64
11:43:40: GPUs: 1
11:43:40: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:2 GF106 [Quadro 2000M] 422
11:43:40: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:2.1 Driver:9.0
11:43:40:OpenCL Device 1: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.1 Driver:385.90
11:43:40:******************************* libFAH ********************************
11:43:40: Date: Apr 15 2020
11:43:40: Time: 14:53:14
11:43:40: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
11:43:40: Bits: 32
11:43:40:***********************************************************************
11:43:40:<config>
11:43:40: <!-- Network -->
11:43:40: <proxy v=':8080'/>
11:43:40:
11:43:40: <!-- Slot Control -->
11:43:40: <power v='FULL'/>
11:43:40:
11:43:40: <!-- User Information -->
11:43:40: <passkey v='*****'/>
11:43:40: <user v='unL33T'/>
11:43:40:
11:43:40: <!-- Folding Slots -->
11:43:40: <slot id='1' type='GPU'>
11:43:40: <idle v='true'/>
11:43:40: </slot>
11:43:40:</config>
11:43:53:9:127.0.0.1:New Web session
11:46:14:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
12:02:28:WU01:FS01:Starting
12:03:05:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Jon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8344 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
12:03:55:WU01:FS01:Started FahCore on PID 15908
12:04:41:WU01:FS01:Core PID:12684
12:04:42:WU01:FS01:FahCore 0x22 started
12:06:22:WU01:FS01:0x22:*********************** Log Started 2020-06-03T12:06:21Z ***********************
12:06:22:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
12:06:22:WU01:FS01:0x22: Type: 0x22
12:06:22:WU01:FS01:0x22: Core: Core22
12:06:22:WU01:FS01:0x22: Website: https://foldingathome.org/
12:06:22:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
12:06:22:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
12:06:22:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
12:06:22:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 15908 -checkpoint 15
12:06:22:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
12:06:22:WU01:FS01:0x22: 0 -gpu 0
12:06:22:WU01:FS01:0x22: Config: <none>
12:06:22:WU01:FS01:0x22:************************************ Build *************************************
12:06:22:WU01:FS01:0x22: Version: 0.0.5
12:06:22:WU01:FS01:0x22: Date: Apr 22 2020
12:06:22:WU01:FS01:0x22: Time: 04:42:59
12:06:22:WU01:FS01:0x22: Repository: Git
12:06:22:WU01:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
12:06:22:WU01:FS01:0x22: Branch: HEAD
12:06:22:WU01:FS01:0x22: Compiler: Visual C++ 2008
12:06:22:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:06:22:WU01:FS01:0x22: Platform: win32 10
12:06:22:WU01:FS01:0x22: Bits: 64
12:06:22:WU01:FS01:0x22: Mode: Release
12:06:22:WU01:FS01:0x22:************************************ System ************************************
12:06:22:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-2860QM CPU @ 2.50GHz
12:06:22:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
12:06:22:WU01:FS01:0x22: CPUs: 8
12:06:22:WU01:FS01:0x22: Memory: 7.88GiB
12:06:22:WU01:FS01:0x22:Free Memory: 630.18MiB
12:06:22:WU01:FS01:0x22: Threads: WINDOWS_THREADS
12:06:22:WU01:FS01:0x22: OS Version: 6.1
12:06:22:WU01:FS01:0x22:Has Battery: true
12:06:22:WU01:FS01:0x22: On Battery: false
12:06:22:WU01:FS01:0x22: UTC Offset: -4
12:06:22:WU01:FS01:0x22: PID: 12684
12:06:22:WU01:FS01:0x22: CWD: C:\Users\Jon\AppData\Roaming\FAHClient\work
12:06:22:WU01:FS01:0x22: OS: Windows 7 Ultimate Service Pack 1
12:06:22:WU01:FS01:0x22: OS Arch: AMD64
12:06:22:WU01:FS01:0x22:********************************************************************************
12:06:22:WU01:FS01:0x22:Project: 13409 (Run 349, Clone 26, Gen 0)
12:06:22:WU01:FS01:0x22:Unit: 0x0000000312bc7d9a5ed4a8a19811e9d6
12:06:22:WU01:FS01:0x22:Digital signatures verified
12:06:22:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
12:06:22:WU01:FS01:0x22:Version 0.0.5
12:07:02:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
12:07:02:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
12:15:37:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
12:19:35:WU01:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
12:23:30:WU01:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
12:27:25:WU01:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
12:31:19:WU01:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
12:35:17:WU01:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
12:39:07:WU01:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
12:42:54:WU01:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
12:46:44:WU01:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
12:50:35:WU01:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
12:54:23:WU01:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
12:58:14:WU01:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
13:02:02:WU01:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
13:05:53:WU01:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
13:09:45:WU01:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
13:13:42:WU01:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
13:17:36:WU01:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
13:21:31:WU01:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
13:25:22:WU01:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
13:29:17:WU01:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
13:33:08:WU01:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
13:36:58:WU01:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
13:40:51:WU01:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
13:44:44:WU01:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
13:48:35:WU01:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
13:52:50:WU01:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
13:56:55:WU01:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
14:00:56:WU01:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
14:04:56:WU01:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
14:08:55:WU01:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
14:12:57:WU01:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
14:16:58:WU01:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
14:20:59:WU01:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
14:25:00:WU01:FS01:0x22:Completed 340000 out of 1000000 steps (34%)
14:29:00:WU01:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
14:33:03:WU01:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
14:37:05:WU01:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
14:41:13:WU01:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
14:45:16:WU01:FS01:0x22:Completed 390000 out of 1000000 steps (39%)
14:49:23:WU01:FS01:0x22:Completed 400000 out of 1000000 steps (40%)
14:53:23:WU01:FS01:0x22:Completed 410000 out of 1000000 steps (41%)
14:57:24:WU01:FS01:0x22:Completed 420000 out of 1000000 steps (42%)
15:01:25:WU01:FS01:0x22:Completed 430000 out of 1000000 steps (43%)
15:05:27:WU01:FS01:0x22:Completed 440000 out of 1000000 steps (44%)
15:09:29:WU01:FS01:0x22:Completed 450000 out of 1000000 steps (45%)
15:13:31:WU01:FS01:0x22:Completed 460000 out of 1000000 steps (46%)
15:17:29:WU01:FS01:0x22:Completed 470000 out of 1000000 steps (47%)
15:21:34:WU01:FS01:0x22:Completed 480000 out of 1000000 steps (48%)
15:25:36:WU01:FS01:0x22:Completed 490000 out of 1000000 steps (49%)
15:29:40:WU01:FS01:0x22:Completed 500000 out of 1000000 steps (50%)
15:33:46:WU01:FS01:0x22:Completed 510000 out of 1000000 steps (51%)
15:37:42:WU01:FS01:0x22:Completed 520000 out of 1000000 steps (52%)
15:42:48:WU01:FS01:0x22:Completed 530000 out of 1000000 steps (53%)
15:47:50:WU01:FS01:0x22:Completed 540000 out of 1000000 steps (54%)
15:52:37:WU01:FS01:0x22:Completed 550000 out of 1000000 steps (55%)
15:56:41:WU01:FS01:0x22:Completed 560000 out of 1000000 steps (56%)
16:00:36:WU01:FS01:0x22:Completed 570000 out of 1000000 steps (57%)
16:04:29:WU01:FS01:0x22:Completed 580000 out of 1000000 steps (58%)
16:08:19:WU01:FS01:0x22:Completed 590000 out of 1000000 steps (59%)
16:12:12:WU01:FS01:0x22:Completed 600000 out of 1000000 steps (60%)
16:16:05:WU01:FS01:0x22:Completed 610000 out of 1000000 steps (61%)
16:19:57:WU01:FS01:0x22:Completed 620000 out of 1000000 steps (62%)
16:23:54:WU01:FS01:0x22:Completed 630000 out of 1000000 steps (63%)
16:27:47:WU01:FS01:0x22:Completed 640000 out of 1000000 steps (64%)
16:31:44:WU01:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
16:35:41:WU01:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
16:39:38:WU01:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
16:43:33:WU01:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
16:47:27:WU01:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
16:51:18:WU01:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
16:55:10:WU01:FS01:0x22:Completed 710000 out of 1000000 steps (71%)
16:59:05:WU01:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
17:03:03:WU01:FS01:0x22:Completed 730000 out of 1000000 steps (73%)
17:07:03:WU01:FS01:0x22:Completed 740000 out of 1000000 steps (74%)
17:10:58:WU01:FS01:0x22:Completed 750000 out of 1000000 steps (75%)
17:15:10:WU01:FS01:0x22:Completed 760000 out of 1000000 steps (76%)
17:19:14:WU01:FS01:0x22:Completed 770000 out of 1000000 steps (77%)
17:23:20:WU01:FS01:0x22:Completed 780000 out of 1000000 steps (78%)
17:27:25:WU01:FS01:0x22:Completed 790000 out of 1000000 steps (79%)
17:31:28:WU01:FS01:0x22:Completed 800000 out of 1000000 steps (80%)
17:35:34:WU01:FS01:0x22:Completed 810000 out of 1000000 steps (81%)
17:39:36:WU01:FS01:0x22:Completed 820000 out of 1000000 steps (82%)
******************************* Date: 2020-06-03 *******************************
17:43:41:WU01:FS01:0x22:Completed 830000 out of 1000000 steps (83%)
17:47:49:WU01:FS01:0x22:Completed 840000 out of 1000000 steps (84%)
17:51:58:WU01:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
17:56:50:WU01:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
18:01:03:WU01:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
18:05:22:WU01:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
18:09:33:WU01:FS01:0x22:Completed 890000 out of 1000000 steps (89%)
18:13:38:WU01:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
18:17:45:WU01:FS01:0x22:Completed 910000 out of 1000000 steps (91%)
18:21:53:WU01:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
18:26:01:WU01:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
18:30:05:WU01:FS01:0x22:Completed 940000 out of 1000000 steps (94%)
18:34:12:WU01:FS01:0x22:Completed 950000 out of 1000000 steps (95%)
18:38:16:WU01:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
18:42:20:WU01:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
18:46:26:WU01:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
18:50:34:WU01:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
18:50:35:WU00:FS01:Connecting to assign1.foldingathome.org:80
18:50:35:WU00:FS01:Assigned to work server 140.163.4.231
18:50:35:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GF106 [Quadro 2000M] 422 from 140.163.4.231
18:50:35:WU00:FS01:Connecting to 140.163.4.231:8080
18:50:57:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
18:50:57:WU00:FS01:Connecting to assign1.foldingathome.org:80
18:50:57:WU00:FS01:Assigned to work server 18.188.125.154
18:50:57:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GF106 [Quadro 2000M] 422 from 18.188.125.154
18:50:57:WU00:FS01:Connecting to 18.188.125.154:8080
18:50:58:WU00:FS01:Downloading 437.60KiB
18:50:58:WU00:FS01:Download complete
18:50:58:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13409 run:608 clone:17 gen:0 core:0x22 unit:0x0000000512bc7d9a5ed4a889cf95f746
18:54:37:WU01:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
18:54:42:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
18:54:42:WU01:FS01:0x22:Saving result file checkpointState.xml
18:54:43:WU01:FS01:0x22:Saving result file checkpt.crc
18:54:43:WU01:FS01:0x22:Saving result file globals.csv
18:54:43:WU01:FS01:0x22:Saving result file positions.xtc
18:54:43:WU01:FS01:0x22:Saving result file science.log
18:54:43:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
18:54:50:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:54:50:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13409 run:349 clone:26 gen:0 core:0x22 unit:0x0000000312bc7d9a5ed4a8a19811e9d6
18:54:50:WU01:FS01:Uploading 519.60KiB to 18.188.125.154
18:54:50:WU01:FS01:Connecting to 18.188.125.154:8080
18:54:50:WU00:FS01:Starting
18:54:50:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Jon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8344 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
18:54:51:WU01:FS01:Upload complete
18:54:53:WU00:FS01:Started FahCore on PID 13088
18:54:54:WU00:FS01:Core PID:10416
18:54:54:WU00:FS01:FahCore 0x22 started
18:54:55:WU00:FS01:0x22:*********************** Log Started 2020-06-03T18:54:55Z ***********************
18:54:55:WU01:FS01:Server responded WORK_ACK (400)
18:54:55:WU01:FS01:Final credit estimate, 4834.00 points
18:54:55:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:54:55:WU00:FS01:0x22: Type: 0x22
18:54:55:WU00:FS01:0x22: Core: Core22
18:54:55:WU00:FS01:0x22: Website: https://foldingathome.org/
18:54:55:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
18:54:55:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
18:54:55:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
18:54:55:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 13088 -checkpoint 15
18:54:55:WU00:FS01:0x22: -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
18:54:55:WU00:FS01:0x22: 0 -gpu 0
18:54:55:WU00:FS01:0x22: Config: <none>
18:54:55:WU00:FS01:0x22:************************************ Build *************************************
18:54:55:WU00:FS01:0x22: Version: 0.0.5
18:54:55:WU00:FS01:0x22: Date: Apr 22 2020
18:54:55:WU00:FS01:0x22: Time: 04:42:59
18:54:55:WU00:FS01:0x22: Repository: Git
18:54:55:WU00:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
18:54:55:WU00:FS01:0x22: Branch: HEAD
18:54:55:WU00:FS01:0x22: Compiler: Visual C++ 2008
18:54:55:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:54:55:WU00:FS01:0x22: Platform: win32 10
18:54:55:WU00:FS01:0x22: Bits: 64
18:54:55:WU00:FS01:0x22: Mode: Release
18:54:55:WU00:FS01:0x22:************************************ System ************************************
18:54:55:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-2860QM CPU @ 2.50GHz
18:54:55:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
18:54:55:WU00:FS01:0x22: CPUs: 8
18:54:55:WU00:FS01:0x22: Memory: 7.88GiB
18:54:55:WU00:FS01:0x22:Free Memory: 1.90GiB
18:54:55:WU00:FS01:0x22: Threads: WINDOWS_THREADS
18:54:55:WU00:FS01:0x22: OS Version: 6.1
18:54:55:WU00:FS01:0x22:Has Battery: true
18:54:55:WU00:FS01:0x22: On Battery: false
18:54:55:WU00:FS01:0x22: UTC Offset: -4
18:54:55:WU00:FS01:0x22: PID: 10416
18:54:55:WU00:FS01:0x22: CWD: C:\Users\Jon\AppData\Roaming\FAHClient\work
18:54:55:WU00:FS01:0x22: OS: Windows 7 Ultimate Service Pack 1
18:54:55:WU00:FS01:0x22: OS Arch: AMD64
18:54:55:WU00:FS01:0x22:********************************************************************************
18:54:55:WU00:FS01:0x22:Project: 13409 (Run 608, Clone 17, Gen 0)
18:54:55:WU00:FS01:0x22:Unit: 0x0000000512bc7d9a5ed4a889cf95f746
18:54:55:WU00:FS01:0x22:Reading tar file core.xml
18:54:55:WU00:FS01:0x22:Reading tar file integrator.xml
18:54:55:WU00:FS01:0x22:Reading tar file state.xml
18:54:55:WU00:FS01:0x22:Reading tar file system.xml
18:54:55:WU01:FS01:Cleaning up
18:54:55:WU00:FS01:0x22:Digital signatures verified
18:54:55:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:54:55:WU00:FS01:0x22:Version 0.0.5
18:55:16:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
18:55:16:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:59:40:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
19:03:36:WU00:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
19:07:29:WU00:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
19:11:23:WU00:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
19:15:17:WU00:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
19:19:14:WU00:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
19:23:07:WU00:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
19:27:01:WU00:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
19:30:55:WU00:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
19:34:54:WU00:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
19:38:52:WU00:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
19:42:43:WU00:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
19:46:40:WU00:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
19:50:46:WU00:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
19:54:40:WU00:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
19:58:44:WU00:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
20:02:43:WU00:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
20:06:37:WU00:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
20:10:29:WU00:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
20:14:23:WU00:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
20:18:14:WU00:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
20:22:08:WU00:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
20:22:19:FS01:Shutting core down
20:22:34:WU00:FS01:0x22:WARNING:Console control signal 1 on PID 10416
20:22:34:WU00:FS01:0x22:Lost lifeline PID 13088, exiting
20:22:40:WU00:FS01:0x22:Exiting, please wait. . .
20:22:43:WU00:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
20:23:23:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
22:40:43:WU00:FS01:Starting
22:40:44:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Jon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8344 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
22:40:47:WU00:FS01:Started FahCore on PID 4012
22:40:54:WU00:FS01:Core PID:15460
22:40:54:WU00:FS01:FahCore 0x22 started
22:41:26:WU00:FS01:0x22:*********************** Log Started 2020-06-03T22:41:26Z ***********************
22:41:26:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
22:41:26:WU00:FS01:0x22: Type: 0x22
22:41:26:WU00:FS01:0x22: Core: Core22
22:41:26:WU00:FS01:0x22: Website: https://foldingathome.org/
22:41:26:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
22:41:26:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
22:41:26:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
22:41:26:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 4012 -checkpoint 15
22:41:26:WU00:FS01:0x22: -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
22:41:26:WU00:FS01:0x22: 0 -gpu 0
22:41:26:WU00:FS01:0x22: Config: <none>
22:41:26:WU00:FS01:0x22:************************************ Build *************************************
22:41:26:WU00:FS01:0x22: Version: 0.0.5
22:41:26:WU00:FS01:0x22: Date: Apr 22 2020
22:41:26:WU00:FS01:0x22: Time: 04:42:59
22:41:26:WU00:FS01:0x22: Repository: Git
22:41:26:WU00:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
22:41:26:WU00:FS01:0x22: Branch: HEAD
22:41:26:WU00:FS01:0x22: Compiler: Visual C++ 2008
22:41:26:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:41:26:WU00:FS01:0x22: Platform: win32 10
22:41:26:WU00:FS01:0x22: Bits: 64
22:41:26:WU00:FS01:0x22: Mode: Release
22:41:26:WU00:FS01:0x22:************************************ System ************************************
22:41:26:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-2860QM CPU @ 2.50GHz
22:41:26:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
22:41:26:WU00:FS01:0x22: CPUs: 8
22:41:26:WU00:FS01:0x22: Memory: 7.88GiB
22:41:26:WU00:FS01:0x22:Free Memory: 4.31GiB
22:41:26:WU00:FS01:0x22: Threads: WINDOWS_THREADS
22:41:26:WU00:FS01:0x22: OS Version: 6.1
22:41:26:WU00:FS01:0x22:Has Battery: true
22:41:26:WU00:FS01:0x22: On Battery: false
22:41:26:WU00:FS01:0x22: UTC Offset: -4
22:41:26:WU00:FS01:0x22: PID: 15460
22:41:26:WU00:FS01:0x22: CWD: C:\Users\Jon\AppData\Roaming\FAHClient\work
22:41:26:WU00:FS01:0x22: OS: Windows 7 Ultimate Service Pack 1
22:41:26:WU00:FS01:0x22: OS Arch: AMD64
22:41:26:WU00:FS01:0x22:********************************************************************************
22:41:27:WU00:FS01:0x22:Project: 13409 (Run 608, Clone 17, Gen 0)
22:41:27:WU00:FS01:0x22:Unit: 0x0000000512bc7d9a5ed4a889cf95f746
22:41:27:WU00:FS01:0x22:Digital signatures verified
22:41:28:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
22:41:28:WU00:FS01:0x22:Version 0.0.5
22:42:13:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
22:42:13:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
22:45:37:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
22:48:57:WU00:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
22:52:31:WU00:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
22:56:31:WU00:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
23:00:27:WU00:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
23:04:18:WU00:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
23:08:06:WU00:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
23:11:58:WU00:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
23:15:58:WU00:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
23:19:52:WU00:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
23:23:44:WU00:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
23:27:40:WU00:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
23:31:33:WU00:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
23:35:29:WU00:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
23:39:23:WU00:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
******************************* Date: 2020-06-04 *******************************
07:41:05:WARNING:WU00:FS01:Detected clock skew (1 mins 04 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
13:42:16:WARNING:WU00:FS01:Detected clock skew (1 mins 12 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
20:43:15:WARNING:WU00:FS01:Detected clock skew (1 mins 01 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
******************************* Date: 2020-06-05 *******************************
04:44:18:WARNING:WU00:FS01:Detected clock skew (1 mins 01 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
13:45:19:WARNING:WU00:FS01:Detected clock skew (1 mins 03 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
18:51:40:WARNING:WU00:FS01:Past final deadline 2020-06-05T18:51:39Z, dumping
18:51:40:WU00:FS01:Shutting core down
18:51:42:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:51:44:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:51:44:WU01:FS01:Connecting to assign2.foldingathome.org:80
18:51:45:WU01:FS01:Assigned to work server 3.133.76.19
18:51:45:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GF106 [Quadro 2000M] 422 from 3.133.76.19
18:51:45:WU01:FS01:Connecting to 3.133.76.19:8080
18:52:06:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
18:52:06:WU01:FS01:Connecting to 3.133.76.19:80
18:52:27:ERROR:WU01:FS01:Exception: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:52:28:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:52:28:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:52:28:WU01:FS01:Connecting to assign2.foldingathome.org:80
18:52:28:WU01:FS01:Assigned to work server 128.252.203.10
18:52:28:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GF106 [Quadro 2000M] 422 from 128.252.203.10
18:52:28:WU01:FS01:Connecting to 128.252.203.10:8080
18:52:49:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
18:52:49:WU01:FS01:Connecting to 128.252.203.10:80
18:53:39:WU01:FS01:Downloading 30.13MiB
18:53:45:WU01:FS01:Download 30.08%
18:53:51:WU01:FS01:Download 59.12%
18:53:57:WU01:FS01:Download 92.72%
18:53:58:WU01:FS01:Download complete
18:53:58:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11760 run:0 clone:6219 gen:22 core:0x22 unit:0x0000003d80fccb0a5e6f0a7858166ebe
22:39:35:WARNING:FS01:Killing WU00
22:40:07:WU01:FS01:Starting
22:40:07:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Jon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8344 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
22:40:33:WU01:FS01:Started FahCore on PID 15424
22:40:53:WU01:FS01:Core PID:16304
22:40:53:WU01:FS01:FahCore 0x22 started
22:41:00:WU01:FS01:0x22:*********************** Log Started 2020-06-05T22:41:00Z ***********************
22:41:00:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
22:41:00:WU01:FS01:0x22: Type: 0x22
22:41:00:WU01:FS01:0x22: Core: Core22
22:41:00:WU01:FS01:0x22: Website: https://foldingathome.org/
22:41:00:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
22:41:00:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
22:41:00:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
22:41:00:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 15424 -checkpoint 15
22:41:00:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
22:41:00:WU01:FS01:0x22: 0 -gpu 0
22:41:00:WU01:FS01:0x22: Config: <none>
22:41:00:WU01:FS01:0x22:************************************ Build *************************************
22:41:00:WU01:FS01:0x22: Version: 0.0.5
22:41:00:WU01:FS01:0x22: Date: Apr 22 2020
22:41:00:WU01:FS01:0x22: Time: 04:42:59
22:41:00:WU01:FS01:0x22: Repository: Git
22:41:00:WU01:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
22:41:00:WU01:FS01:0x22: Branch: HEAD
22:41:00:WU01:FS01:0x22: Compiler: Visual C++ 2008
22:41:00:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:41:00:WU01:FS01:0x22: Platform: win32 10
22:41:00:WU01:FS01:0x22: Bits: 64
22:41:00:WU01:FS01:0x22: Mode: Release
22:41:00:WU01:FS01:0x22:************************************ System ************************************
22:41:00:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-2860QM CPU @ 2.50GHz
22:41:00:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
22:41:00:WU01:FS01:0x22: CPUs: 8
22:41:00:WU01:FS01:0x22: Memory: 7.88GiB
22:41:00:WU01:FS01:0x22:Free Memory: 5.43GiB
22:41:00:WU01:FS01:0x22: Threads: WINDOWS_THREADS
22:41:00:WU01:FS01:0x22: OS Version: 6.1
22:41:00:WU01:FS01:0x22:Has Battery: true
22:41:00:WU01:FS01:0x22: On Battery: false
22:41:00:WU01:FS01:0x22: UTC Offset: -4
22:41:00:WU01:FS01:0x22: PID: 16304
22:41:00:WU01:FS01:0x22: CWD: C:\Users\Jon\AppData\Roaming\FAHClient\work
22:41:00:WU01:FS01:0x22: OS: Windows 7 Ultimate Service Pack 1
22:41:00:WU01:FS01:0x22: OS Arch: AMD64
22:41:00:WU01:FS01:0x22:********************************************************************************
22:41:01:WU01:FS01:0x22:Project: 11760 (Run 0, Clone 6219, Gen 22)
22:41:01:WU01:FS01:0x22:Unit: 0x0000003d80fccb0a5e6f0a7858166ebe
22:41:01:WU01:FS01:0x22:Reading tar file core.xml
22:41:01:WU01:FS01:0x22:Reading tar file integrator.xml
22:41:01:WU01:FS01:0x22:Reading tar file state.xml
22:41:09:WU01:FS01:0x22:Reading tar file system.xml
22:41:12:WU01:FS01:0x22:Digital signatures verified
22:41:13:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
22:41:13:WU01:FS01:0x22:Version 0.0.5
22:41:55:WU01:FS01:0x22:Completed 0 out of 2000000 steps (0%)
22:41:55:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
22:42:23:WU00:FS01:Cleaning up
22:42:39:FS01:Paused
22:42:40:FS01:Shutting core down
22:42:40:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 16304
22:42:40:WU01:FS01:0x22:Exiting, please wait. . .
22:42:40:WU01:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
22:42:40:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
22:42:59:FS01:Unpaused
22:42:59:WU01:FS01:Starting
22:42:59:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Jon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8344 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
22:42:59:WU01:FS01:Started FahCore on PID 4164
22:42:59:WU01:FS01:Core PID:7692
22:42:59:WU01:FS01:FahCore 0x22 started
22:43:00:WU01:FS01:0x22:*********************** Log Started 2020-06-05T22:42:59Z ***********************
22:43:00:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
22:43:00:WU01:FS01:0x22: Type: 0x22
22:43:00:WU01:FS01:0x22: Core: Core22
22:43:00:WU01:FS01:0x22: Website: https://foldingathome.org/
22:43:00:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
22:43:00:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
22:43:00:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
22:43:00:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 4164 -checkpoint 15
22:43:00:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
22:43:00:WU01:FS01:0x22: 0 -gpu 0
22:43:00:WU01:FS01:0x22: Config: <none>
22:43:00:WU01:FS01:0x22:************************************ Build *************************************
22:43:00:WU01:FS01:0x22: Version: 0.0.5
22:43:00:WU01:FS01:0x22: Date: Apr 22 2020
22:43:00:WU01:FS01:0x22: Time: 04:42:59
22:43:00:WU01:FS01:0x22: Repository: Git
22:43:00:WU01:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
22:43:00:WU01:FS01:0x22: Branch: HEAD
22:43:00:WU01:FS01:0x22: Compiler: Visual C++ 2008
22:43:00:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:43:00:WU01:FS01:0x22: Platform: win32 10
22:43:00:WU01:FS01:0x22: Bits: 64
22:43:00:WU01:FS01:0x22: Mode: Release
22:43:00:WU01:FS01:0x22:************************************ System ************************************
22:43:00:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-2860QM CPU @ 2.50GHz
22:43:00:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
22:43:00:WU01:FS01:0x22: CPUs: 8
22:43:00:WU01:FS01:0x22: Memory: 7.88GiB
22:43:00:WU01:FS01:0x22:Free Memory: 5.38GiB
22:43:00:WU01:FS01:0x22: Threads: WINDOWS_THREADS
22:43:00:WU01:FS01:0x22: OS Version: 6.1
22:43:00:WU01:FS01:0x22:Has Battery: true
22:43:00:WU01:FS01:0x22: On Battery: false
22:43:00:WU01:FS01:0x22: UTC Offset: -4
22:43:00:WU01:FS01:0x22: PID: 7692
22:43:00:WU01:FS01:0x22: CWD: C:\Users\Jon\AppData\Roaming\FAHClient\work
22:43:00:WU01:FS01:0x22: OS: Windows 7 Ultimate Service Pack 1
22:43:00:WU01:FS01:0x22: OS Arch: AMD64
22:43:00:WU01:FS01:0x22:********************************************************************************
22:43:00:WU01:FS01:0x22:Project: 11760 (Run 0, Clone 6219, Gen 22)
22:43:00:WU01:FS01:0x22:Unit: 0x0000003d80fccb0a5e6f0a7858166ebe
22:43:00:WU01:FS01:0x22:Digital signatures verified
22:43:00:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
22:43:00:WU01:FS01:0x22:Version 0.0.5
22:43:04:WU01:FS01:0x22:Completed 0 out of 2000000 steps (0%)
22:43:04:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
22:43:20:FS01:Paused
22:43:20:FS01:Shutting core down
22:43:20:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 7692
22:43:20:WU01:FS01:0x22:Exiting, please wait. . .
22:43:20:WU01:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
22:43:21:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
22:44:09:Removing old file 'configs/config-20200329-224127.xml'
22:44:09:Saving configuration to config.xml
22:44:09:<config>
22:44:09: <!-- Network -->
22:44:09: <proxy v=':8080'/>
22:44:09:
22:44:09: <!-- Slot Control -->
22:44:09: <power v='FULL'/>
22:44:09:
22:44:09: <!-- User Information -->
22:44:09: <passkey v='*****'/>
22:44:09: <user v='unL33T'/>
22:44:09:
22:44:09: <!-- Folding Slots -->
22:44:09: <slot id='1' type='GPU'>
22:44:09: <idle v='true'/>
22:44:09: <paused v='true'/>
22:44:09: </slot>
22:44:09:</config>
FYI, that log was pulled while paused. As soon as I unpause it, even though I am currently typing this, it start folding.
[I normally fold 24/7 so my 'on Idle' experience is very limited]
Welcome to Folding@Home!
I recently ran into this with regard to "Finish", but I think it works with "On Idle" as well.
Clicking "Fold" ends "Pause", "Finish", and "On Idle". You may have only wanted to end one of those, but that is not how "Fold" works.
Again, very limited testing.
Your GPU slot is correctly configured to fold on idle:
However, this might be the issue:
Set the Folding Power to Light and it should only fold on the GPU when the system is idle.
According to this:PantherX wrote:Your GPU slot is correctly configured to fold on idle:
https://foldingathome.org/faqs/fah-v7/v ... er-slider/
That would set the CPU to only fold at 50% and completely disable GPU folding.
If that is the issue, why does it sometimes work? For example, when I came to read the previous comment on this computer last night, folding stopped as soon as I started using the computer. Same with again this morning as I am tying this. But earlier yesterday it wasn't working properly and at other times it has appeared to be working (stops folding when I'm using the computer) and then will just start itself even though I'm still using the computer (usually in the middle of a game, Counter Strike Source, specifically if it makes any difference).
I would assume (possibly incorrectly) that if that setting was the issue it would either ignore the "on idle" all the time or not...? It's really a confusing issue to me.
Ultimately the "On Idle" setting is dependent on how the OS reports that status. So if the OS does not update that status reliably, the client may not detect that either your system has gone idle or has stopped being idle. I do not know how often the client checks for Windows, but it normally is "On Idle" if there is no keyboard or mouse input, and the system has either blanked the screen or started a screen saver.
I am not discounting there possibly being bugs in the client in connection with the detection of Idle.
From experience here on the forum, tracking down causes for the client not doing the executed in connection with "On Idle" can be a pain. The wierdest report was a few years ago when one person finally tracked it down to his mouse. At the sensitivity it was set to, leaving the mouse connected and sitting on the desk with the computer read the vibrations from the fans as mouse input. Disconnecting the mouse or placing it on something soft to absorb the vibration was enough to fix things for him.
Not suggesting this is the problem in your case, but trying to illustrate the cause could be in some unexpected place.
Thanks for the suggestion. Unfortunately I don't think this would apply as that would cause the opposite problem, F@H never detecting idle and therefore never running whereas I have the opposite issue where it will start folding while I'm using the computer.Joe_H wrote:Disconnecting the mouse or placing it on something soft to absorb the vibration was enough to fix things for him.
It's very strange to me that often it works just fine but screws up just often enough to be really annoying and I have to remember to manually pause it before gaming because it just might change it's mind even if it appears to be working fine.
Maybe the Source engine is somehow preventing F@H from properly capturing mouse and keyboard activity?
F@H does not capture mouse or Keyboard activity. F@H gets a On Idle signal from the OS.unL33T wrote:Maybe the Source engine is somehow preventing F@H from properly capturing mouse and keyboard activity?
It is unclear to me why your OS would be signalling On Idle durring a game.
Understood. Thank you.
