Connection to Client broken after Win 10 2004 update
Chris_TG
Post by Chris_TG »
Hi there,
on my workstation the connection between the FAHControl and the client running in the backgroud seems to be broken. This happend right after installing the Windows 10 2004 update.
The FAHControl tries to connect to the client, but the connection gets closed immediately (showing "connecting" the whole time, then a shot flashing of "updating", then "connecting" again).
I tried to un- and re-install the software package keeping my data, but it didn't help.
The client itself seems to run quite fine and crunching data, I checked the config.xml and it also still looks valid to me.
Does the FAHControl have a debugging mode or is there some log I could search for errors?
TIA
Chris
Re: Connection to Client broken after Win 10 2004 update
For log files and their location, please view this topic: viewtopic.php?f=24&t=26036
Once you find it, can you please post it?
Mungo
Post by Mungo »
I'm experiencing exactly the same symptoms - however I'm still on Windows 10 v1809 - the Web and Advanced controls just suddenly stopped working, with the same issue as described.
Looking through my history of log files, I see there was an update to GPUs.txt downloaded on 1st June. From this point the exception "option 'gpu-index' has no default and is not set" is now occuring in the logs at regular intervals. This possibly suggests that my GPU is no longer supported - AMD Radeon HD 6800 Series.
Copy of latest log file here:
*********************** Log Started 2020-06-04T10:53:19Z ***********************
10:53:19:Trying to access database...
10:53:19:Successfully acquired database lock
10:53:19:Read GPUs.txt
10:53:19:Enabled folding slot 00: READY cpu:6
10:53:19:ERROR:Exception: No available GPUs
10:53:19:ERROR:Exception: Option 'gpu-index' has no default and is not set.
10:53:19:****************************** FAHClient ******************************
10:53:19:        Version: 7.6.13
10:53:19:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:53:19:      Copyright: 2020 foldingathome.org
10:53:19:       Homepage: https://foldingathome.org/
10:53:19:           Date: Apr 27 2020
10:53:19:           Time: 21:21:01
10:53:19:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
10:53:19:         Branch: master
10:53:19:       Compiler: Visual C++ 2008
10:53:19:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:53:19:       Platform: win32 10
10:53:19:           Bits: 32
10:53:19:           Mode: Release
10:53:19:           Args: --open-web-control
10:53:19:         Config: C:\Users\Mungo\AppData\Roaming\FAHClient\config.xml
10:53:19:******************************** CBang ********************************
10:53:19:           Date: Apr 24 2020
10:53:19:           Time: 17:07:55
10:53:19:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
10:53:19:           Bits: 32
10:53:19:******************************* System ********************************
10:53:19:            CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
10:53:19:         CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
10:53:19:           CPUs: 8
10:53:19:         Memory: 31.94GiB
10:53:19:    Free Memory: 20.88GiB
10:53:19:        Threads: WINDOWS_THREADS
10:53:19:     OS Version: 6.2
10:53:19:    Has Battery: false
10:53:19:     On Battery: false
10:53:19:     UTC Offset: 1
10:53:19:            PID: 12340
10:53:19:            CWD: C:\Users\Mungo\AppData\Roaming\FAHClient
10:53:19:  Win32 Service: false
10:53:19:             OS: Windows 10 Enterprise
10:53:19:        OS Arch: AMD64
10:53:19:           GPUs: 0
10:53:19:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
10:53:19:                 specified module could not be found.
10:53:19:
10:53:19:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:1800.11
10:53:19:******************************* libFAH ********************************
10:53:19:           Date: Apr 15 2020
10:53:19:           Time: 14:53:14
10:53:19:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
10:53:19:           Bits: 32
10:53:19:***********************************************************************
10:53:19:<config>
10:53:19:  <!-- Folding Slot Configuration -->
10:53:19:  <cause v='COVID_19'/>
10:53:19:
10:53:19:  <!-- Slot Control -->
10:53:19:  <power v='MEDIUM'/>
10:53:19:
10:53:19:  <!-- User Information -->
10:53:19:  <passkey v='*****'/>
10:53:19:  <user v='Mungo'/>
10:53:19:
10:53:19:  <!-- Folding Slots -->
10:53:19:  <slot id='0' type='CPU'/>
10:53:19:  <slot id='1' type='GPU'/>
10:53:19:</config>
10:53:19:WU01:FS00:Starting
10:53:19:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Mungo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 12340 -checkpoint 15 -np 6
10:53:19:WU01:FS00:Started FahCore on PID 6340
10:53:19:WU01:FS00:Core PID:10188
10:53:19:WU01:FS00:FahCore 0xa7 started
10:53:20:WU01:FS00:0xa7:*********************** Log Started 2020-06-04T10:53:19Z ***********************
10:53:20:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:53:20:WU01:FS00:0xa7:       Type: 0xa7
10:53:20:WU01:FS00:0xa7:       Core: Gromacs
10:53:20:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 6340 -checkpoint 15 -np 6
10:53:20:WU01:FS00:0xa7:************************************ CBang *************************************
10:53:20:WU01:FS00:0xa7:       Date: Oct 26 2019
10:53:20:WU01:FS00:0xa7:       Time: 01:38:25
10:53:20:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:53:20:WU01:FS00:0xa7:     Branch: master
10:53:20:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
10:53:20:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:53:20:WU01:FS00:0xa7:   Platform: win32 10
10:53:20:WU01:FS00:0xa7:       Bits: 64
10:53:20:WU01:FS00:0xa7:       Mode: Release
10:53:20:WU01:FS00:0xa7:************************************ System ************************************
10:53:20:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
10:53:20:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
10:53:20:WU01:FS00:0xa7:       CPUs: 8
10:53:20:WU01:FS00:0xa7:     Memory: 31.94GiB
10:53:20:WU01:FS00:0xa7:Free Memory: 20.86GiB
10:53:20:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
10:53:20:WU01:FS00:0xa7: OS Version: 6.2
10:53:20:WU01:FS00:0xa7:Has Battery: false
10:53:20:WU01:FS00:0xa7: On Battery: false
10:53:20:WU01:FS00:0xa7: UTC Offset: 1
10:53:20:WU01:FS00:0xa7:        PID: 10188
10:53:20:WU01:FS00:0xa7:        CWD: C:\Users\Mungo\AppData\Roaming\FAHClient\work
10:53:20:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
10:53:20:WU01:FS00:0xa7:    Version: 0.0.18
10:53:20:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:53:20:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:53:20:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
10:53:20:WU01:FS00:0xa7:       Time: 01:52:30
10:53:20:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:53:20:WU01:FS00:0xa7:************************************ Build *************************************
10:53:20:WU01:FS00:0xa7:       SIMD: avx_256
10:53:20:WU01:FS00:0xa7:********************************************************************************
10:53:20:WU01:FS00:0xa7:Project: 14235 (Run 302, Clone 1, Gen 57)
10:53:20:WU01:FS00:0xa7:Unit: 0x00000040cedfaa925ea3767531620688
10:53:20:WU01:FS00:0xa7:Digital signatures verified
10:53:20:WU01:FS00:0xa7:Calling: mdrun -s frame57.tpr -o frame57.trr -x frame57.xtc -cpi state.cpt -cpt 15 -nt 6
10:53:20:WU01:FS00:0xa7:Steps: first=14250000 total=250000
10:53:23:WU01:FS00:0xa7:Completed 102242 out of 250000 steps (40%)
10:53:23:WU00:FS01:Connecting to assign1.foldingathome.org:80
10:53:24:WU00:FS01:Assigned to work server 40.114.52.201
10:53:24:WU00:FS01:Requesting new work unit for slot
10:53:24:ERROR:WU00:FS01:Exception: Option 'gpu-index' has no default and is not set.
10:53:24:WU00:FS01:Connecting to assign1.foldingathome.org:80
10:53:25:10:127.0.0.1:New Web session
10:53:25:WU00:FS01:Assigned to work server 69.94.66.6
10:53:25:WU00:FS01:Requesting new work unit for slot
10:53:25:ERROR:WU00:FS01:Exception: Option 'gpu-index' has no default and is not set.
10:53:26:WARNING:14:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004738&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:26:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:28:WARNING:14:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004739&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:28:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:29:WARNING:14:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004740&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:29:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:30:WARNING:14:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004741&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:30:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:31:WARNING:14:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004742&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:31:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:32:WARNING:14:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004743&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:32:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:33:WARNING:14:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004744&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:33:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:34:WARNING:14:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004745&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:34:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:35:WARNING:14:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004746&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:35:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:36:WARNING:14:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004747&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:36:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:37:WARNING:14:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004748&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:37:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:38:WARNING:14:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004749&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:38:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:39:WARNING:14:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004750&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:39:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:40:WARNING:14:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004751&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:40:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:41:WARNING:14:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004752&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:41:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:42:WARNING:14:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004753&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:42:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:43:WARNING:14:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004754&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:43:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:45:WARNING:17:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004759&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:45:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:46:ERROR:Exception: Connection terminated
10:53:46:ERROR:Socket not open
10:53:47:WARNING:18:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004761&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:47:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:48:WARNING:17:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004760&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:48:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:50:WARNING:18:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004763&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:50:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:51:ERROR:Exception: Connection terminated
10:53:51:ERROR:Socket not open
10:53:51:WARNING:17:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004762&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:51:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:53:WARNING:22:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004768&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:53:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:55:WARNING:23:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004770&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:55:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:56:ERROR:Exception: Connection terminated
10:53:56:ERROR:Socket not open
10:53:56:WARNING:22:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004769&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:56:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:58:WARNING:22:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004772&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:58:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:53:59:WARNING:26:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004776&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:53:59:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:01:ERROR:Exception: Connection terminated
10:54:01:ERROR:Socket not open
10:54:01:WARNING:27:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004778&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:01:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:02:WARNING:26:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004777&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:02:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:04:WARNING:27:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004779&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:04:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:05:WARNING:26:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004780&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:05:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:06:ERROR:Exception: Connection terminated
10:54:06:ERROR:Socket not open
10:54:07:WARNING:32:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004785&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:07:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:09:WARNING:33:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004787&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:09:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:10:WARNING:32:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004786&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:10:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:11:ERROR:Exception: Connection terminated
10:54:11:ERROR:Socket not open
10:54:12:WARNING:33:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004788&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:12:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:13:WARNING:32:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004789&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:13:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:14:WARNING:37:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004794&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:14:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:16:ERROR:Exception: Connection terminated
10:54:16:ERROR:Socket not open
10:54:16:WARNING:38:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004796&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:16:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:17:WARNING:37:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004795&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:17:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:19:WARNING:38:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004797&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:19:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:20:WARNING:37:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004798&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:20:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:21:ERROR:Exception: Connection terminated
10:54:21:ERROR:Socket not open
10:54:21:WARNING:43:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004803&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:21:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:23:WARNING:43:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004804&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:23:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:24:WU00:FS01:Connecting to assign1.foldingathome.org:80
10:54:25:WU00:FS01:Assigned to work server 206.223.170.146
10:54:25:WU00:FS01:Requesting new work unit for slot
10:54:25:ERROR:WU00:FS01:Exception: Option 'gpu-index' has no default and is not set.
10:54:25:WARNING:44:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004806&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:25:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:26:ERROR:Exception: Connection terminated
10:54:26:ERROR:Socket not open
10:54:26:WARNING:43:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004805&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:26:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:27:WARNING:48:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004811&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:27:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:29:WARNING:49:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004813&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:29:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:30:WARNING:48:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004812&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:30:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:31:ERROR:Exception: Connection terminated
10:54:31:ERROR:Socket not open
10:54:32:WARNING:49:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004814&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:32:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:34:WARNING:53:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004820&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:34:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:35:WARNING:48:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004815&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:35:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:36:ERROR:Exception: Connection terminated
10:54:36:ERROR:Socket not open
10:54:37:WARNING:53:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004821&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:37:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:38:WARNING:54:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004822&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:38:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:40:WARNING:53:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004823&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:40:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:41:ERROR:Exception: Connection terminated
10:54:41:ERROR:Socket not open
10:54:43:WARNING:58:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004828&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:43:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:45:WARNING:58:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004830&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:45:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:46:ERROR:Exception: Connection terminated
10:54:46:ERROR:Socket not open
10:54:46:WARNING:62:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004834&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:46:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:48:WARNING:64:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004836&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:48:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:49:WARNING:62:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004835&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:49:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:51:ERROR:Exception: Connection terminated
10:54:51:ERROR:Socket not open
10:54:51:WARNING:64:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004837&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:51:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:53:WARNING:68:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004843&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:53:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:54:WARNING:62:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004838&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:54:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:56:ERROR:Exception: Connection terminated
10:54:56:ERROR:Socket not open
10:54:56:WARNING:68:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004844&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:56:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:57:WARNING:69:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004845&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:57:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:54:59:WARNING:68:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004846&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:54:59:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:01:WARNING:74:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004852&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:01:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:01:ERROR:Exception: Connection terminated
10:55:01:ERROR:Socket not open
10:55:03:WARNING:74:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004853&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:03:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:04:WARNING:73:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004851&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:04:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:05:WARNING:77:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004858&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:05:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:06:ERROR:Exception: Connection terminated
10:55:06:ERROR:Socket not open
10:55:07:WARNING:79:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004860&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:07:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:08:WARNING:77:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004859&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:08:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:10:WARNING:79:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004861&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:10:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:11:ERROR:Exception: Connection terminated
10:55:11:ERROR:Socket not open
10:55:12:WARNING:83:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004867&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:12:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:14:WARNING:77:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004862&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:14:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:15:WARNING:83:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004868&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:15:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:16:ERROR:Exception: Connection terminated
10:55:16:ERROR:Socket not open
10:55:17:WARNING:84:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004869&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:17:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:18:WARNING:83:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004870&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:18:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:19:WARNING:89:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004876&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:19:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:21:WARNING:88:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004875&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:21:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:21:ERROR:Exception: Connection terminated
10:55:21:ERROR:Socket not open
10:55:22:WARNING:88:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004878&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:22:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:24:WARNING:88:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004879&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:24:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:25:WARNING:92:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004883&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:25:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:26:ERROR:Exception: Connection terminated
10:55:26:ERROR:Socket not open
10:55:27:WARNING:94:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004885&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:27:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:28:WARNING:92:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004884&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:28:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:30:WARNING:92:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004887&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:30:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:31:WARNING:96:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004891&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:31:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:31:ERROR:Exception: Connection terminated
10:55:31:ERROR:Socket not open
10:55:33:WARNING:98:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004893&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:33:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:34:WARNING:96:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004892&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:34:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:36:ERROR:Exception: Connection terminated
10:55:36:ERROR:Socket not open
10:55:36:WARNING:98:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004894&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:36:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:38:WARNING:102:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004900&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:38:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:40:WARNING:96:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004895&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:40:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:41:ERROR:Exception: Connection terminated
10:55:41:ERROR:Socket not open
10:55:41:WARNING:102:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004901&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:41:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:43:WARNING:103:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004902&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:43:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:44:WARNING:102:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004903&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:44:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:45:WARNING:108:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004909&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:45:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:46:ERROR:Exception: Connection terminated
10:55:46:ERROR:Socket not open
10:55:47:WARNING:107:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004908&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:47:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:48:WARNING:108:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004910&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:48:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:50:WARNING:112:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004916&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:50:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:51:ERROR:Exception: Connection terminated
10:55:51:ERROR:Socket not open
10:55:52:WARNING:107:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004911&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:52:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:53:WARNING:114:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004918&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:53:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:54:WARNING:112:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004917&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:54:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:56:WARNING:112:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004920&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:56:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:56:ERROR:Exception: Connection terminated
10:55:56:ERROR:Socket not open
10:55:57:WARNING:117:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004924&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:57:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:55:59:WARNING:118:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004926&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:55:59:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:00:WARNING:117:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004925&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:00:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:01:ERROR:Exception: Connection terminated
10:56:01:ERROR:Socket not open
10:56:02:WU00:FS01:Connecting to assign1.foldingathome.org:80
10:56:02:WU00:FS01:Assigned to work server 40.121.152.108
10:56:02:WU00:FS01:Requesting new work unit for slot
10:56:02:ERROR:WU00:FS01:Exception: Option 'gpu-index' has no default and is not set.
10:56:03:WARNING:118:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004928&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:03:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:04:WARNING:121:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004932&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:04:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:06:WARNING:122:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004934&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:06:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:06:ERROR:Exception: Connection terminated
10:56:06:ERROR:Socket not open
10:56:07:WARNING:121:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004933&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:07:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:09:WARNING:122:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004935&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:09:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:11:WARNING:126:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004941&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:11:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:11:ERROR:Exception: Connection terminated
10:56:11:ERROR:Socket not open
10:56:13:WARNING:121:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004936&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:13:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:14:WARNING:126:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004942&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:14:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:16:WARNING:128:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004943&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:16:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:17:ERROR:Exception: Connection terminated
10:56:17:ERROR:Socket not open
10:56:17:WARNING:128:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004945&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:17:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:18:WARNING:131:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004949&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:18:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:20:WARNING:132:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004951&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:20:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:22:WARNING:131:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004950&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:22:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:22:ERROR:Exception: Connection terminated
10:56:22:ERROR:Socket not open
10:56:23:WARNING:132:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004953&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:23:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:24:WARNING:132:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004954&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:24:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:25:WARNING:135:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004958&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:25:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:27:ERROR:Exception: Connection terminated
10:56:27:ERROR:Socket not open
10:56:27:WARNING:135:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004959&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:27:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:28:WARNING:135:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004960&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:28:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:29:WARNING:135:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004961&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:29:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:31:WARNING:135:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004962&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:31:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:32:ERROR:Exception: Connection terminated
10:56:32:ERROR:Socket not open
10:56:32:WARNING:135:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591268004963&sid=eac229483690c1366e143d61cf59f64f: Option 'gpu-index' has no default and is not set.
10:56:32:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
10:56:37:ERROR:Exception: Connection terminated
10:56:37:ERROR:Socket not open
10:56:42:ERROR:Exception: Connection terminated
10:56:42:ERROR:Socket not open
10:56:47:ERROR:Exception: Connection terminated
10:56:47:ERROR:Socket not open
10:56:52:ERROR:Exception: Connection terminated
10:56:52:ERROR:Socket not open
10:56:57:ERROR:Exception: Connection terminated
10:56:57:ERROR:Socket not open
10:57:02:ERROR:Exception: Connection terminated
10:57:02:ERROR:Socket not open
10:57:07:ERROR:Exception: Connection terminated
10:57:07:ERROR:Socket not open
10:57:12:ERROR:Exception: Connection terminated
10:57:12:ERROR:Socket not open
10:57:17:ERROR:Exception: Connection terminated
10:57:17:ERROR:Socket not open
10:57:22:ERROR:Exception: Connection terminated
10:57:22:ERROR:Socket not open
10:57:27:ERROR:Exception: Connection terminated
10:57:27:ERROR:Socket not open
10:57:32:ERROR:Exception: Connection terminated
10:57:32:ERROR:Socket not open
10:57:37:ERROR:Exception: Connection terminated
10:57:37:ERROR:Socket not open
10:57:42:ERROR:Exception: Connection terminated
10:57:42:ERROR:Socket not open
10:57:47:ERROR:Exception: Connection terminated
10:57:47:ERROR:Socket not open
10:57:52:ERROR:Exception: Connection terminated
10:57:52:ERROR:Socket not open
10:57:57:ERROR:Exception: Connection terminated
10:57:57:ERROR:Socket not open
10:58:02:ERROR:Exception: Connection terminated
10:58:02:ERROR:Socket not open
10:58:07:ERROR:Exception: Connection terminated
10:58:07:ERROR:Socket not open
10:58:12:ERROR:Exception: Connection terminated
10:58:12:ERROR:Socket not open
10:58:17:ERROR:Exception: Connection terminated
10:58:17:ERROR:Socket not open
10:58:22:ERROR:Exception: Connection terminated
10:58:22:ERROR:Socket not open
10:58:27:ERROR:Exception: Connection terminated
10:58:27:ERROR:Socket not open
10:58:32:ERROR:Exception: Connection terminated
10:58:32:ERROR:Socket not open
10:58:38:ERROR:Exception: Connection terminated
10:58:38:ERROR:Socket not open
10:58:39:WU00:FS01:Connecting to assign1.foldingathome.org:80
10:58:39:WU00:FS01:Assigned to work server 155.247.164.214
10:58:39:WU00:FS01:Requesting new work unit for slot
10:58:39:ERROR:WU00:FS01:Exception: Option 'gpu-index' has no default and is not set.
10:58:43:ERROR:Exception: Connection terminated
10:58:43:ERROR:Socket not open
10:58:48:ERROR:Exception: Connection terminated
10:58:48:ERROR:Socket not open
10:58:53:ERROR:Exception: Connection terminated
10:58:53:ERROR:Socket not open
10:58:58:ERROR:Exception: Connection terminated
10:58:58:ERROR:Socket not open
10:59:03:ERROR:Exception: Connection terminated
10:59:03:ERROR:Socket not open
10:59:08:ERROR:Exception: Connection terminated
10:59:08:ERROR:Socket not open
Your log is the second report like this that I have seen. It may be an unintended side effect of the change in status in the latest GPUs.txt file for a number of GPUs that only support Single Precision calculations. The last projects that did not require some use of Double Precision ended last year, and it appears the decision has been reached that all future GPU projects will require mixed precision. Only the Radeon HD 6900 cards in that series have DP support.
Since Web Control and FAHControl are not working for you, you might be able to fix this with a careful edit to the config.xml file with FAHClient not running. You would just remove the line containing "<slot id='1' type='GPU'/>". and save.
Otherwise a reinstall after uninstalling the client and data files should get things working correctly again.
Chris_TG
Post by Chris_TG »
Hi there,
the hint with the GPUs.txt was good: It seems that this updated definition-file makes my client crash somehow. I found the following lines in the log:
05:50:54:ERROR:Exception: No available GPUs
05:50:54:ERROR:Exception: Option 'gpu-index' has no default and is not set.
And later:
05:51:03:WARNING:17:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591249856220&sid=6f3ea334b5c451bad01a77d861d09478: Option 'gpu-index' has no default and is not set.
05:51:03:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
So I manually removed the GPU-slot from my config.xml and at least the CPU slot now folds again and I can access the FAHControl again.
A few thoughts about this:
- It's okay if the devs decide to block any GPU that has been on the "grey list" before, but it's not okay that this leads to an inaccessible GUI in FAHControl.
- IMHO you should change the startup-behaviour if something goes wrong when the client starts.
- Maybe try it a few times but then it should stop and give the user the chance to review/correct any settings instead of trying endlessly and keeping the UI inaccessible.
Just my 2 cents
cheers
Chris
The first report could have been a coincidence, but with the reported problems here it is looking to be an error in how the client handles this. I will try to put together a problem report on the development site later today.
The GPU and hardware detection stage of the client was modified in the most recent release to correct another problem that had been seen. So in fixing one bug, another appears to have been created.
Mungo
Post by Mungo »
Just to say that removing the GPU slot configuration has also fixed my issue.
Thanks for your help :wink:
NigelC
Post by NigelC »
Yes, no sooner than finished Win 10 2004 update, and it breaks this. Removing GPU line as noted worked.
js2010
Post by js2010 »
By the way, firewall rules get reset after a feature update.
I think they call that a security upgrade.
OleBasementHacker
Post by OleBasementHacker »
Not sure what happened.. between Windows updates and a power failure the other day. My FAH control can no longer connect to the client.
02:36:09:ERROR:Exception: No available GPUs
02:36:09:ERROR:Exception: Option 'gpu-index' has no default and is not set.
02:36:09:WARNING:WU01:No longer matches Slot 1's configuration and there are no other matching slots, dumping
02:36:10:WU02:FS00:Starting
See this type of thing multiple times...
19:36:06:WU02:FS00:0xa7:Project: 16805 (Run 14, Clone 114, Gen 28)
19:36:06:WU02:FS00:0xa7:Unit: 0x0000002b82ed0b915eb41f41b7ed03bf
19:36:06:WU02:FS00:0xa7:Digital signatures verified
19:36:06:WU02:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
19:36:06:WU02:FS00:0xa7:Calling: mdrun -s frame28.tpr -o frame28.trr -cpi state.cpt -cpt 15 -nt 4
19:36:06:WU02:FS00:0xa7:ERROR:Guru Meditation #348e1c8d8f43d47.c244bec2d1695e93 (11901120.14281224) '02/01/frame28.trr'
19:36:06:WU02:FS00:0xa7:WARNING:Unexpected exit() call
19:36:06:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
19:36:06:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
19:36:06:WU02:FS00:0xa7:Saving result file ener.edr
19:36:06:WU02:FS00:0xa7:ERROR:Guru Meditation #799410ebc9b1719.5e00dca41dbb2a9 (34360.35044) '02/01/ener.edr'
19:36:09:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
19:36:09:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
I'm also getting lots of logs
01:41:19:WARNING:Command server access denied
01:41:24:WARNING:Command server access denied
I tried installing the latest version, but it didn't seem to change anything.
Not sure how to remove or change current settings.
Dave.
Your first error message was
That's a pretty big clue.
Later, it says:
10:53:19: GPUs: 0
Whenever WindowsUpdate installs new video drivers, they remove support for OpenCL, so it breaks FAH. The fix is to go to nvidia.com and install the drivers from their site. Either install the same version that Windows has installed or a later version. That download will include both OpenCL and CUDA.
Besides the driver install, the Guru Meditation error messages point towards file corruption in the work files for the CPU project. Whether those were from the power failure or from something connected with the Windows Update can't be determined from the information here.
Cruddson001
Post by Cruddson001 »
Hi I have the same issue except I was never folding on my GPU (HD 6800 series) and I am using Windows build 18363.900 (version 1909).
My folding did also stop working around the same time as a windows update.
Please excuse my ignorance however how do I edit the config.xml file to manually removed the GPU-slot?
