Web Control constantly loading
Freefalldreams
Post by Freefalldreams »
For the past two days, Web Control has been stuck constantly loading before eventually saying that the client has stopped working and needs to be restarted. Advanced Control shows an active client, but constantly flicking between "Connecting" and "Updating". I've stopped F@H Client both from the bottom toolbar tray and by ending the process in Task Manager (at one point it showed multiple copies of the same process there!). I even uninstalled the whole thing and reinstalled it. I applied for a new passkey for my team. All to no avail...
My most recent log, pt 1:
*********************** Log Started 2020-06-03T00:51:03Z ***********************
00:51:03:Trying to access database...
00:51:03:Successfully acquired database lock
00:51:03:Read GPUs.txt
00:51:03:Enabled folding slot 00: PAUSED cpu:2 (by user)
00:51:03:ERROR:Exception: No available GPUs
00:51:04:ERROR:Exception: Option 'gpu-index' has no default and is not set.
00:51:04:****************************** FAHClient ******************************
00:51:04:        Version: 7.6.13
00:51:04:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:51:04:      Copyright: 2020 foldingathome.org
00:51:04:       Homepage: https://foldingathome.org/
00:51:04:           Date: Apr 27 2020
00:51:04:           Time: 21:21:01
00:51:04:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
00:51:04:         Branch: master
00:51:04:       Compiler: Visual C++ 2008
00:51:04:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:51:04:       Platform: win32 10
00:51:04:           Bits: 32
00:51:04:           Mode: Release
00:51:04:           Args: --open-web-control
00:51:04:         Config: C:\Users\Sara\AppData\Roaming\FAHClient\config.xml
00:51:04:******************************** CBang ********************************
00:51:04:           Date: Apr 24 2020
00:51:04:           Time: 17:07:55
00:51:04:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
00:51:04:           Bits: 32
00:51:04:******************************* System ********************************
00:51:04:            CPU: AMD A6-3420M APU with Radeon(tm) HD Graphics
00:51:04:         CPU ID: AuthenticAMD Family 18 Model 1 Stepping 0
00:51:04:           CPUs: 4
00:51:04:         Memory: 3.48GiB
00:51:04:    Free Memory: 846.45MiB
00:51:04:        Threads: WINDOWS_THREADS
00:51:04:     OS Version: 6.1
00:51:04:    Has Battery: true
00:51:04:     On Battery: false
00:51:04:     UTC Offset: -4
00:51:04:            PID: 8184
00:51:04:            CWD: C:\Users\Sara\AppData\Roaming\FAHClient
00:51:04:  Win32 Service: false
00:51:04:             OS: Windows 7 Home Premium
00:51:04:        OS Arch: AMD64
00:51:04:           GPUs: 0
00:51:04:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
00:51:04:                 specified module could not be found.
00:51:04:
00:51:04:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:1.1 Driver:1.4
00:51:04:******************************* libFAH ********************************
00:51:04:           Date: Apr 15 2020
00:51:04:           Time: 14:53:14
00:51:04:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
00:51:04:           Bits: 32
00:51:04:***********************************************************************
00:51:04:<config>
00:51:04:  <!-- Folding Slot Configuration -->
00:51:04:  <cause v='COVID_19'/>
00:51:04:
00:51:04:  <!-- Slot Control -->
00:51:04:  <power v='MEDIUM'/>
00:51:04:
00:51:04:  <!-- User Information -->
00:51:04:  <passkey v='*****'/>
00:51:04:  <team v='226071'/>
00:51:04:  <user v='Freefalldreams'/>
00:51:04:
00:51:04:  <!-- Folding Slots -->
00:51:04:  <slot id='0' type='CPU'>
00:51:04:    <paused v='true'/>
00:51:04:  </slot>
00:51:04:  <slot id='1' type='GPU'>
00:51:04:  </slot>
00:51:04:</config>
00:51:05:WU00:FS01:Connecting to assign1.foldingathome.org:80
00:51:06:WU00:FS01:Assigned to work server 206.223.170.146
00:51:06:WU00:FS01:Requesting new work unit for slot
00:51:06:ERROR:WU00:FS01:Exception: Option 'gpu-index' has no default and is not set.
00:51:06:WU00:FS01:Connecting to assign1.foldingathome.org:80
00:51:07:WU00:FS01:Assigned to work server 40.114.52.201
00:51:07:WU00:FS01:Requesting new work unit for slot
00:51:07:ERROR:WU00:FS01:Exception: Option 'gpu-index' has no default and is not set.
00:51:08:4:127.0.0.1:New Web session
Freefalldreams
Re: Web Control constantly loading
Log pt 2:
00:51:10:WARNING:8:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468146&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:10:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:12:WARNING:9:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468148&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:12:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:13:WARNING:9:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468149&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:13:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:14:WARNING:9:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468150&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:14:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:15:WARNING:9:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468151&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:15:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:17:WARNING:11:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468155&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:17:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:19:WARNING:12:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468157&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:19:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:20:WARNING:11:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468156&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:20:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:22:WARNING:12:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468158&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:22:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:24:WARNING:15:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468164&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:24:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:25:WARNING:11:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468159&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:25:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:27:WARNING:15:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468165&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:27:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:29:WARNING:16:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468166&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:29:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:30:WARNING:16:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468168&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:30:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:31:WARNING:18:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468172&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:31:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:33:WARNING:19:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468174&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:33:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:35:WARNING:18:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468173&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:35:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:36:WARNING:19:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468175&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:36:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:38:WARNING:22:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468181&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:38:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:40:WARNING:18:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468176&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:40:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:41:WARNING:22:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468182&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:41:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:43:WARNING:23:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468183&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:43:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:44:WARNING:23:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468185&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:44:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:46:WARNING:25:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468189&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:46:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:47:WARNING:26:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468191&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:47:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:49:WARNING:25:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468190&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:49:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:51:WARNING:26:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468192&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:51:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:53:WARNING:29:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468198&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:53:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:54:WARNING:25:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468193&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:54:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:56:WARNING:29:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468199&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:56:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:57:WARNING:30:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468200&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:57:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:51:59:WARNING:29:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468201&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:51:59:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:01:WARNING:33:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468206&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:01:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:03:WARNING:33:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468208&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:03:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:05:WARNING:34:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468207&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:05:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:06:WU00:FS01:Connecting to assign1.foldingathome.org:80
00:52:06:WU00:FS01:Assigned to work server 206.223.170.146
00:52:06:WARNING:33:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468209&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:06:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:07:WU00:FS01:Requesting new work unit for slot
00:52:07:ERROR:WU00:FS01:Exception: Option 'gpu-index' has no default and is not set.
00:52:07:WARNING:37:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468214&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:07:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:09:WARNING:38:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468216&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:09:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:11:WARNING:37:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468215&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:11:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:13:WARNING:38:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468217&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:13:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:15:WARNING:41:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468223&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:15:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:15:ERROR:Exception: Connection terminated
00:52:15:ERROR:Socket not open
00:52:16:WARNING:37:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468218&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:16:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:18:WARNING:41:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468224&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:18:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:19:WARNING:43:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468225&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:19:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:20:ERROR:Exception: Connection terminated
00:52:20:ERROR:Socket not open
00:52:21:WARNING:47:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468231&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:21:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:23:WARNING:48:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468233&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:23:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:24:WARNING:47:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468232&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:24:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:25:ERROR:Exception: Connection terminated
00:52:25:ERROR:Socket not open
00:52:26:WARNING:41:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468226&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:26:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:27:WARNING:52:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468239&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:27:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:29:WARNING:53:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468241&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:29:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:30:WARNING:52:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468240&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:30:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:30:ERROR:Exception: Connection terminated
00:52:30:ERROR:Socket not open
00:52:32:WARNING:53:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468242&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:32:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:34:WARNING:57:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468248&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:34:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:35:WARNING:52:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468243&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:35:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:35:ERROR:Exception: Connection terminated
00:52:35:ERROR:Socket not open
00:52:37:WARNING:57:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468249&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:37:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:38:WARNING:58:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468250&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:38:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:40:WARNING:57:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468251&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:40:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:42:WARNING:62:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468256&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:42:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:44:WARNING:62:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468258&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:44:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:45:WARNING:62:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468259&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:45:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:46:WARNING:62:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468260&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:46:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:47:WARNING:66:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468264&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:47:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:49:WARNING:67:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468266&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:49:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:50:WARNING:66:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468265&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:50:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:52:WARNING:67:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468267&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:52:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:54:ERROR:Exception: Connection terminated
00:52:54:ERROR:Socket not open
00:52:54:WARNING:71:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468273&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:54:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:56:WARNING:66:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468268&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:56:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:57:WARNING:71:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468274&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:57:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:52:58:ERROR:Exception: Connection terminated
00:52:58:ERROR:Socket not open
00:52:59:WARNING:72:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468275&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:52:59:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:53:00:WARNING:71:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468276&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:53:00:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:53:01:WARNING:77:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468282&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:53:01:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:53:03:WARNING:76:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468281&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:53:03:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:53:03:ERROR:Exception: Connection terminated
00:53:03:ERROR:Socket not open
00:53:04:WARNING:76:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468284&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:53:04:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:53:05:WARNING:76:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468285&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:53:05:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:53:06:WARNING:76:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145468286&sid=da17dab221de97f0845492660c7cf88c: Option 'gpu-index' has no default and is not set.
00:53:06:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:53:08:ERROR:Exception: Connection terminated
00:53:08:ERROR:Socket not open
00:53:13:ERROR:Exception: Connection terminated
00:53:13:ERROR:Socket not open
00:53:18:ERROR:Exception: Connection terminated
00:53:18:ERROR:Socket not open
00:53:23:ERROR:Exception: Connection terminated
00:53:23:ERROR:Socket not open
00:53:28:ERROR:Exception: Connection terminated
00:53:28:ERROR:Socket not open
00:53:33:ERROR:Exception: Connection terminated
00:53:33:ERROR:Socket not open
00:53:43:WU00:FS01:Connecting to assign1.foldingathome.org:80
00:53:43:WU00:FS01:Assigned to work server 206.223.170.146
00:53:44:WU00:FS01:Requesting new work unit for slot
00:53:44:ERROR:WU00:FS01:Exception: Option 'gpu-index' has no default and is not set.
00:55:53:104:127.0.0.1:New Web session
00:55:55:WARNING:112:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145753066&sid=7cbe41bc6daebdf4a24b8fecf23b2677: Option 'gpu-index' has no default and is not set.
00:55:55:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:55:57:WARNING:112:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145753067&sid=7cbe41bc6daebdf4a24b8fecf23b2677: Option 'gpu-index' has no default and is not set.
00:55:57:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:56:00:WARNING:112:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145753068&sid=7cbe41bc6daebdf4a24b8fecf23b2677: Option 'gpu-index' has no default and is not set.
00:56:00:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:56:01:WARNING:115:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145753073&sid=7cbe41bc6daebdf4a24b8fecf23b2677: Option 'gpu-index' has no default and is not set.
00:56:01:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:56:04:WARNING:115:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145753074&sid=7cbe41bc6daebdf4a24b8fecf23b2677: Option 'gpu-index' has no default and is not set.
00:56:04:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:56:06:WARNING:115:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145753076&sid=7cbe41bc6daebdf4a24b8fecf23b2677: Option 'gpu-index' has no default and is not set.
00:56:06:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:56:07:WARNING:115:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145753077&sid=7cbe41bc6daebdf4a24b8fecf23b2677: Option 'gpu-index' has no default and is not set.
00:56:07:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:56:09:WARNING:118:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145753081&sid=7cbe41bc6daebdf4a24b8fecf23b2677: Option 'gpu-index' has no default and is not set.
00:56:09:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:56:12:WARNING:119:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145753083&sid=7cbe41bc6daebdf4a24b8fecf23b2677: Option 'gpu-index' has no default and is not set.
00:56:12:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:56:14:WARNING:119:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145753084&sid=7cbe41bc6daebdf4a24b8fecf23b2677: Option 'gpu-index' has no default and is not set.
00:56:14:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:56:15:WARNING:118:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145753082&sid=7cbe41bc6daebdf4a24b8fecf23b2677: Option 'gpu-index' has no default and is not set.
00:56:15:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:56:20:WU00:FS01:Connecting to assign1.foldingathome.org:80
00:56:21:WU00:FS01:Assigned to work server 150.136.14.110
00:56:21:WU00:FS01:Requesting new work unit for slot
00:56:21:ERROR:WU00:FS01:Exception: Option 'gpu-index' has no default and is not set.
00:57:03:138:127.0.0.1:New Web session
00:57:05:WARNING:142:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145820873&sid=0cbea477a691c708a201e7bf8bb130e9: Option 'gpu-index' has no default and is not set.
00:57:05:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:57:06:WARNING:146:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145820874&sid=0cbea477a691c708a201e7bf8bb130e9: Option 'gpu-index' has no default and is not set.
00:57:06:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:57:08:WARNING:147:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145820876&sid=0cbea477a691c708a201e7bf8bb130e9: Option 'gpu-index' has no default and is not set.
00:57:08:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:57:09:WARNING:146:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145820875&sid=0cbea477a691c708a201e7bf8bb130e9: Option 'gpu-index' has no default and is not set.
00:57:09:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:57:11:WARNING:147:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145820877&sid=0cbea477a691c708a201e7bf8bb130e9: Option 'gpu-index' has no default and is not set.
00:57:11:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:57:14:WARNING:150:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145820882&sid=0cbea477a691c708a201e7bf8bb130e9: Option 'gpu-index' has no default and is not set.
00:57:14:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:57:15:WARNING:150:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145820884&sid=0cbea477a691c708a201e7bf8bb130e9: Option 'gpu-index' has no default and is not set.
00:57:15:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:57:17:WARNING:151:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145820883&sid=0cbea477a691c708a201e7bf8bb130e9: Option 'gpu-index' has no default and is not set.
00:57:17:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:57:18:WARNING:155:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145820890&sid=0cbea477a691c708a201e7bf8bb130e9: Option 'gpu-index' has no default and is not set.
00:57:18:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:57:20:WARNING:154:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145820889&sid=0cbea477a691c708a201e7bf8bb130e9: Option 'gpu-index' has no default and is not set.
00:57:20:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:57:21:WARNING:154:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145820892&sid=0cbea477a691c708a201e7bf8bb130e9: Option 'gpu-index' has no default and is not set.
00:57:21:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:57:22:WARNING:154:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145820893&sid=0cbea477a691c708a201e7bf8bb130e9: Option 'gpu-index' has no default and is not set.
00:57:22:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
00:57:23:WARNING:154:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591145820894&sid=0cbea477a691c708a201e7bf8bb130e9: Option 'gpu-index' has no default and is not set.
00:57:23:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:00:35:WU00:FS01:Connecting to assign1.foldingathome.org:80
01:00:35:WU00:FS01:Assigned to work server 128.252.203.1
01:00:36:WU00:FS01:Requesting new work unit for slot
01:00:36:ERROR:WU00:FS01:Exception: Option 'gpu-index' has no default and is not set.
01:07:26:WU00:FS01:Connecting to assign1.foldingathome.org:80
01:07:27:WU00:FS01:Assigned to work server 40.114.52.201
01:07:27:WU00:FS01:Requesting new work unit for slot
01:07:27:ERROR:WU00:FS01:Exception: Option 'gpu-index' has no default and is not set.
01:10:55:175:127.0.0.1:New Web session
01:10:58:WARNING:183:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655045&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:10:58:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:00:WARNING:184:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655047&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:00:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:01:WARNING:183:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655046&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:01:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:03:WARNING:184:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655048&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:03:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:05:WARNING:187:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655054&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:05:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:06:WARNING:183:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655049&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:06:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:08:WARNING:187:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655055&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:08:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:10:WARNING:188:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655056&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:10:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:11:WARNING:188:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655058&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:11:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:12:WARNING:190:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655062&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:12:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:14:WARNING:191:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655064&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:14:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:18:WARNING:190:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655063&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:18:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:19:WARNING:193:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655069&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:19:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:21:WARNING:194:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655071&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:21:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:22:WARNING:193:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655070&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:22:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:24:WARNING:194:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655072&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:24:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:26:WARNING:197:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655078&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:26:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:27:WARNING:193:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655073&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:27:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:29:WARNING:197:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655079&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:29:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:30:WARNING:198:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655080&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:30:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:31:WARNING:198:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655082&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:31:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:33:WARNING:200:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655086&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:33:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:35:WARNING:201:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655088&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:35:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:36:WARNING:200:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655087&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:36:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:38:WARNING:201:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655089&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:38:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:40:WARNING:204:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655095&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:40:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:41:WARNING:201:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655091&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:41:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:44:WARNING:204:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655096&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:44:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:45:WARNING:205:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655097&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:45:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:46:WARNING:205:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655099&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:46:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:47:WARNING:207:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655103&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:47:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:49:WARNING:208:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655105&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:49:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:51:WARNING:207:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655104&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:51:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:53:WARNING:208:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655106&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:53:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:55:WARNING:211:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655112&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:55:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:56:WARNING:207:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655107&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:56:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:58:WARNING:211:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655113&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:58:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:11:59:WARNING:212:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655114&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:11:59:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:00:WARNING:212:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655116&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:00:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:02:WARNING:214:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655120&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:02:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:04:WARNING:215:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655122&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:04:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:05:WARNING:214:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655121&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:05:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:07:WARNING:215:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655123&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:07:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:09:WARNING:218:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655129&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:09:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:10:WARNING:214:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655124&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:10:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:12:WARNING:218:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655130&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:12:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:13:WARNING:219:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655131&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:13:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:15:WARNING:218:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655132&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:15:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:16:WARNING:223:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655138&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:16:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:17:WARNING:222:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655137&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:17:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:19:WARNING:223:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655139&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:19:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:21:WARNING:226:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655145&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:23:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:23:WARNING:223:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655141&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:25:WARNING:227:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655146&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:25:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:26:ERROR:Exception: Connection terminated
01:12:26:ERROR:Socket not open
01:12:27:WARNING:231:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655152&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:27:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:29:WARNING:227:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655148&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:29:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:30:ERROR:Exception: Connection terminated
01:12:30:ERROR:Socket not open
01:12:31:WARNING:231:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655153&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:31:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:32:WARNING:232:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655154&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:32:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:34:WARNING:231:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655155&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:34:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:35:WARNING:237:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655161&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:35:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:35:ERROR:Exception: Connection terminated
01:12:35:ERROR:Socket not open
01:12:38:WARNING:236:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655160&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:38:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:40:WARNING:241:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655167&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:40:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:40:ERROR:Exception: Connection terminated
01:12:40:ERROR:Socket not open
01:12:42:WARNING:243:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655169&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:42:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:43:WARNING:241:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655168&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:43:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:45:ERROR:Exception: Connection terminated
01:12:45:ERROR:Socket not open
01:12:46:WARNING:237:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655162&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:46:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:47:WARNING:241:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655171&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:47:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:49:WARNING:247:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655175&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:49:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:50:WARNING:247:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655177&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:50:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:51:ERROR:Exception: Connection terminated
01:12:51:ERROR:Socket not open
01:12:52:WARNING:248:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655176&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:52:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:53:WARNING:247:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655178&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:53:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:54:WARNING:252:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655183&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:54:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:55:ERROR:Exception: Connection terminated
01:12:55:ERROR:Socket not open
01:12:56:WARNING:254:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655185&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:56:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:12:58:WARNING:252:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655184&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:12:58:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:00:WARNING:254:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655186&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:13:00:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:00:ERROR:Exception: Connection terminated
01:13:00:ERROR:Socket not open
01:13:02:WARNING:258:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655192&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:13:02:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:03:WARNING:252:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655187&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:13:03:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:05:WARNING:258:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655193&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:13:05:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:05:ERROR:Exception: Connection terminated
01:13:05:ERROR:Socket not open
01:13:06:WARNING:259:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655194&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:13:06:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:08:WARNING:258:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146655195&sid=483e0c81cb99490eb9afaeddb59ecf30: Option 'gpu-index' has no default and is not set.
01:13:08:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:08:264:127.0.0.1:New Web session
01:13:10:WARNING:268:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788055&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:10:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:10:ERROR:Exception: Connection terminated
01:13:11:ERROR:Socket not open
01:13:12:WARNING:270:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788057&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:12:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:13:WARNING:268:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788056&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:13:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:15:WARNING:270:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788058&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:15:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:15:ERROR:Exception: Connection terminated
01:13:15:ERROR:Socket not open
01:13:17:WARNING:274:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788064&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:17:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:19:WARNING:268:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788059&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:19:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:20:WARNING:274:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788065&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:20:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:20:ERROR:Exception: Connection terminated
Freefalldreams
Log pt 3:
01:13:20:ERROR:Socket not open
01:13:22:WARNING:275:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788066&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:22:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:23:WARNING:274:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788067&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:23:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:26:ERROR:Exception: Connection terminated
01:13:26:ERROR:Socket not open
01:13:26:WARNING:279:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788072&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:26:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:27:WARNING:279:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788074&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:27:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:28:WARNING:279:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788075&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:28:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:29:WARNING:279:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788076&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:29:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:30:WARNING:283:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788080&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:30:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:31:ERROR:Exception: Connection terminated
01:13:31:ERROR:Socket not open
01:13:32:WARNING:285:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788082&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:32:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:34:WARNING:283:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788081&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:34:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:35:WARNING:285:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788083&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:35:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:36:ERROR:Exception: Connection terminated
01:13:36:ERROR:Socket not open
01:13:37:WARNING:289:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788089&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:37:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:39:WARNING:283:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788084&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:39:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:41:WARNING:289:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788090&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:41:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:41:ERROR:Exception: Connection terminated
01:13:41:ERROR:Socket not open
01:13:42:WARNING:290:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788091&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:42:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:43:WARNING:290:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788093&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:43:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:45:WARNING:293:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788097&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:45:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:46:ERROR:Exception: Connection terminated
01:13:46:ERROR:Socket not open
01:13:46:WARNING:295:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788099&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:46:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:48:WARNING:293:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788098&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:48:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:50:WARNING:295:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788100&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:50:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:51:ERROR:Exception: Connection terminated
01:13:51:ERROR:Socket not open
01:13:52:WARNING:299:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788106&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:52:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:53:WARNING:293:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788101&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:53:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:55:WARNING:299:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788107&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:55:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:56:ERROR:Exception: Connection terminated
01:13:56:ERROR:Socket not open
01:13:56:WARNING:300:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788108&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:56:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:13:58:WARNING:299:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788109&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:13:58:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:00:WARNING:304:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788114&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:00:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:01:ERROR:Exception: Connection terminated
01:14:01:ERROR:Socket not open
01:14:01:WARNING:304:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788116&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:01:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:02:WARNING:304:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788117&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:02:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:03:WARNING:304:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788118&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:03:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:05:WARNING:308:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788122&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:05:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:06:ERROR:Exception: Connection terminated
01:14:06:ERROR:Socket not open
01:14:07:WARNING:310:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788124&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:07:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:08:WARNING:308:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788123&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:08:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:10:WARNING:310:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788125&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:10:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:11:ERROR:Exception: Connection terminated
01:14:11:ERROR:Socket not open
01:14:12:WARNING:314:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788131&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:12:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:13:WARNING:308:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788126&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:13:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:15:WARNING:314:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788132&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:15:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:16:ERROR:Exception: Connection terminated
01:14:16:ERROR:Socket not open
01:14:17:WARNING:315:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788133&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:17:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:18:WARNING:315:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788135&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:18:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:19:WARNING:318:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788139&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:19:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:21:WARNING:319:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788141&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:21:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:21:ERROR:Exception: Connection terminated
01:14:21:ERROR:Socket not open
01:14:22:WARNING:318:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788140&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:22:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:24:WARNING:319:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788142&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:24:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:26:ERROR:Exception: Connection terminated
01:14:26:ERROR:Socket not open
01:14:26:WARNING:323:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788148&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:26:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:28:WARNING:318:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788143&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:28:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:29:WARNING:323:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788149&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:29:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:31:WARNING:325:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788150&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:31:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:31:ERROR:Exception: Connection terminated
01:14:31:ERROR:Socket not open
01:14:32:WARNING:323:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788151&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:32:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:35:WARNING:329:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788156&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:35:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:36:WARNING:329:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788158&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:36:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:36:ERROR:Exception: Connection terminated
01:14:36:ERROR:Socket not open
01:14:37:WARNING:329:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788159&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:37:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:38:WARNING:329:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788160&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:38:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:39:WARNING:333:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788164&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:39:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:41:ERROR:Exception: Connection terminated
01:14:41:ERROR:Socket not open
01:14:41:WARNING:335:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788166&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:41:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:43:WARNING:333:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788165&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:43:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:44:WARNING:335:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788167&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:44:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:46:ERROR:Exception: Connection terminated
01:14:46:ERROR:Socket not open
01:14:46:WARNING:339:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788173&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:46:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:48:WARNING:333:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788168&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:48:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:50:WARNING:339:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788174&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:50:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:51:WARNING:340:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788175&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:51:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:51:ERROR:Exception: Connection terminated
01:14:51:ERROR:Socket not open
01:14:52:WARNING:340:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788177&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:52:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:54:WARNING:343:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788181&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:54:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:55:WARNING:344:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788183&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:55:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:56:ERROR:Exception: Connection terminated
01:14:56:ERROR:Socket not open
01:14:57:WARNING:343:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788182&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:57:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:14:59:WARNING:344:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788184&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:14:59:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:01:WARNING:348:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788190&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:01:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:01:ERROR:Exception: Connection terminated
01:15:01:ERROR:Socket not open
01:15:02:WARNING:343:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788185&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:02:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:04:WARNING:348:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788191&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:04:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:05:WARNING:350:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788192&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:05:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:06:ERROR:Exception: Connection terminated
01:15:06:ERROR:Socket not open
01:15:07:WARNING:348:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788193&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:07:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:09:WARNING:355:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788199&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:09:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:11:ERROR:Exception: Connection terminated
01:15:11:ERROR:Socket not open
01:15:12:WARNING:354:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788198&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:12:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:13:WARNING:358:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788204&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:13:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:15:WARNING:359:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788206&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:15:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:16:ERROR:Exception: Connection terminated
01:15:16:ERROR:Socket not open
01:15:16:WARNING:358:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788205&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:16:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:18:WARNING:359:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788207&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:18:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:20:WARNING:363:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788213&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:20:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:21:ERROR:Exception: Connection terminated
01:15:21:ERROR:Socket not open
01:15:22:WARNING:358:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788208&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:22:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:23:WARNING:363:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788214&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:23:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:25:WARNING:365:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788215&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:25:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:26:WARNING:365:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788217&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:26:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:26:ERROR:Exception: Connection terminated
01:15:26:ERROR:Socket not open
01:15:27:WARNING:368:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788221&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:27:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:29:WARNING:369:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788223&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:29:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:31:WARNING:368:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788222&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:31:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:31:ERROR:Exception: Connection terminated
01:15:31:ERROR:Socket not open
01:15:33:WARNING:369:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788224&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:33:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:34:WARNING:373:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788230&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:34:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:36:WARNING:368:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788225&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:36:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:36:ERROR:Exception: Connection terminated
01:15:36:ERROR:Socket not open
01:15:38:WARNING:373:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788231&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:38:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:39:WARNING:375:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788232&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:39:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:40:WARNING:373:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788233&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:40:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:41:ERROR:Exception: Connection terminated
01:15:41:ERROR:Socket not open
01:15:42:WARNING:380:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788239&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:42:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:43:WARNING:378:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788238&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:43:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:45:WARNING:380:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788240&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:45:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:46:ERROR:Exception: Connection terminated
01:15:46:ERROR:Socket not open
01:15:47:WARNING:383:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788246&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:47:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:48:WARNING:378:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788241&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:48:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:50:WARNING:383:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788247&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:50:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:51:WARNING:385:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788248&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:51:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:51:ERROR:Exception: Connection terminated
01:15:51:ERROR:Socket not open
01:15:52:WARNING:385:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788250&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:52:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:54:WARNING:388:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788254&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:54:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:56:WARNING:389:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788256&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:56:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:56:ERROR:Exception: Connection terminated
01:15:56:ERROR:Socket not open
01:15:57:WARNING:388:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788255&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:57:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:15:59:WARNING:389:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788257&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:15:59:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:01:WARNING:393:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788263&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:01:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:01:ERROR:Exception: Connection terminated
01:16:02:ERROR:Socket not open
01:16:02:WARNING:388:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788258&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:02:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:04:WARNING:393:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788264&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:04:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:05:WARNING:395:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788265&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:05:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:06:ERROR:Exception: Connection terminated
01:16:06:ERROR:Socket not open
01:16:07:WARNING:393:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788266&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:07:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:08:WARNING:400:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788272&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:08:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:09:WARNING:399:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788271&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:09:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:11:WARNING:400:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788273&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:11:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:11:ERROR:Exception: Connection terminated
01:16:11:ERROR:Socket not open
01:16:12:WARNING:399:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788274&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:12:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:13:WARNING:404:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788279&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:13:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:15:WARNING:405:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788281&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:15:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:16:ERROR:Exception: Connection terminated
01:16:16:ERROR:Socket not open
01:16:17:WARNING:404:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788280&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:17:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:19:WARNING:405:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788282&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:19:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:21:WARNING:409:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788288&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:21:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:21:ERROR:Exception: Connection terminated
01:16:21:ERROR:Socket not open
01:16:22:WARNING:404:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788283&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:22:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:24:WARNING:409:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788289&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:24:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:25:WARNING:411:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788290&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:25:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:26:WARNING:411:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788292&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:26:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:26:ERROR:Exception: Connection terminated
01:16:26:ERROR:Socket not open
01:16:28:WARNING:414:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788296&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:28:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:30:WARNING:415:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788298&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:30:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:31:WARNING:414:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788297&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:31:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:31:ERROR:Exception: Connection terminated
01:16:31:ERROR:Socket not open
01:16:33:WARNING:415:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788299&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:33:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:35:WARNING:419:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788305&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:35:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:36:WARNING:414:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788300&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:36:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:36:ERROR:Exception: Connection terminated
01:16:36:ERROR:Socket not open
01:16:38:WARNING:419:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788306&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:38:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:39:WARNING:420:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788307&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:39:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:41:WARNING:419:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788308&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:41:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:41:ERROR:Exception: Connection terminated
01:16:41:ERROR:Socket not open
01:16:42:WARNING:425:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788314&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:42:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:43:WARNING:424:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788313&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:43:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:45:WARNING:425:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788315&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:45:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:46:WARNING:424:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1591146788316&sid=d2fec2dd9b7833301e5031cb6e3a4089: Option 'gpu-index' has no default and is not set.
01:16:46:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
01:16:47:ERROR:Exception: Connection terminated
01:16:47:ERROR:Socket not open
Re: Web Control constantly loading
From what is shown in the log, you have no usable GPU for folding. So start by removing the GPU slot.
If that does not get things working better, uninstall the client including the data files and reinstall after that. You do not need to get a new passkey.
Beyond that, as long as you have that Windows 7 system updated with all the patches that were put out until MS ended support in January you should be okay.
Freefalldreams
Post by Freefalldreams »
Yes, it's an old laptop and the client always assigned me CPU-only tasks until one time last week when, for no apparent reason, it assigned me a GPU task I had not a chance of completing in time, and after it timed out, this problem started. Now that I've uninstalled AND cleared data, everything's back to normal -- only better, as now Web Control doesn't even show a potential GPU slot. I had to log back into my team, but now things are working great again! Thank you very much!
Then I would like to pass on the apologies of someone else working on F@h support. With the history of the your problem, this probably happened when they added a number of Intel IGPs to the GPUs.txt file, and your system may have pulled down an update while there was an error in the definitions. The client mishandled that error and created GPU folding slots for some. A corrected GPUs.txt file is now out there for download to the client.
