Work Unit stuck at 99.99%
topsphere
Post by topsphere »
I'm super new and this is only the third Work Unite I've worked on. I wanted to watch the Web Control complete a Work Unit but as it got to 99.99% it just stayed at that figure. 30 mins later now and it is stuck at 99.9%.
As I'm so new I'm not sure if it is normal for F@H to spend a long time on the very last 0.01% of a WU, or whether I've somehow done something wrong?
ajm
Re: Work Unit stuck at 99.99%
Post by ajm »
It looks like an issue. But in order to sort it out, we have to look at your log, to see which hardware you are using, on which system, and what happened.
You'll find instructions here for Windows: viewtopic.php?p=327412&f=24#p327412
Here for Linux: viewtopic.php?p=327412&f=24#p327413
Here fore Apple: viewtopic.php?p=327412&f=24#p327414
