New Ryzen CPUs faster than last gen GPUs?
MeeLee
Post by MeeLee »
I've read a few comments on how well FAH scales on Ryzen CPUs.
One user claims to get 550k PPD on a 3900x, while another claims over 1M PPD on his 3950x.
Is this possible?
I know on a 6 core, 3,2Ghz Intel CPU I can get about 35k PPD, which is a LOT more than the 1k PPD I get from a dual core Atom processor.
But to see 1 Mil PPD on a Ryzen 3950x is quite a lot!
It almost closes the gap between CPU and GPU!
Is it because they're using new instructions (AVX/AVX2)?
Or an adjusted CPU PPD system?
Re: New Ryzen CPUs faster than last gen GPUs?
It's my understanding that large CPU Projects can run a lot more efficiently on large number of CPUs. It would be possible that the large CPU Projects running on 32 threads generate that many points. The AVX2 requirement has been there for a while so it could be down to the implementation by AMD VS that of Intel. I haven't done too much research into that... yet.
HaloJones
Post by HaloJones »
The data submitted to the HFM PPD Database doesn't show those numbers. Granted there's no 3950x but the averages for the 39000X sit around 300K
4070 super
Post by Neil-B »
my slow xeon 32/56 slot makes 175/200k normal variance … double it for how much faster 3950x can run (at least) so 350/400k and adjust upwards a fair bit because of QRB factors ought to push that well past 500k at a guess … then get a 13872 WU drop in (3-4x points than variance) and I would guess a single WU (or Mark 1 eyeball at client) PPD rate of well over 1M might well be possible … as to the sustained rate I really can't comment but the benchmarking thread viewtopic.php?f=38&t=35286 gives indications of just shy of 450PPD but on a benchmarked standard configuration so actual potential achievable in other configurations may rise higher?
MeeLee
Post by MeeLee »
I know that the FLOPS difference between a 3950x and a 3900x is only 10%.
So perhaps the ability to scale more threads vs fewer threads at higher core frequency plays a role?
Or perhaps the +1M PPD user,did it short term on an overclocked Ryzen? Not sure...
ajm
Post by ajm »
I reinstalled FAH on my main machine to have a look. On a 3970x, a 32 CPUs slot now crunching 16424 (739, 2, 83) at around 4.2 GHz (~140 W) predicts a PPD of 406744.
EDIT: Come to think of it, it's rather low. I remember reaching over 350K with 24 CPUs slots on that processor. We'll see later.
EDIT2: Next job is 14808 (1296, 0, 12), now at over 8% announcing a PPD of 458435.
EDIT3: Third job is 16806 (9, 552, 31), now at 9%, PPD of only 344572.
EDIT4: (Note 3td job: 361169 at the end). Forth job: 14532 (929, 1, 20), now at 7%, for a PPD of 568722.
EDIT5: Fifth job: 14820 (139, 2, 74), now at 8%, for a PPD of 441512.
I stop here (I'll add the log later for reference). An overclocked 3950x may well reach 500k, for a while, but 1M? No, not even under liquid nitrogen.
*********************** Log Started 2020-06-04T05:41:47Z ***********************
05:42:04:WU00:FS00:Connecting to assign1.foldingathome.org:80
05:42:05:WU00:FS00:Connecting to assign1.foldingathome.org:80
05:42:05:WU00:FS00:Assigned to work server 168.245.198.125
05:42:05:WU00:FS00:Requesting new work unit for slot 00: READY cpu:15 from 168.245.198.125
05:42:05:WU00:FS00:Connecting to 168.245.198.125:8080
05:42:06:WU00:FS00:Downloading 8.31MiB
05:42:10:WU00:FS00:Download complete
05:42:10:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16424 run:739 clone:2 gen:83 core:0xa7 unit:0x00000063a8f5c67d5e8f6a23851f22bc
05:42:10:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
05:42:10:WU00:FS00:Connecting to cores.foldingathome.org:80
05:42:11:WU00:FS00:FahCore a7: Downloading 6.71MiB
05:42:12:WU00:FS00:FahCore a7: Download complete
05:42:12:WU00:FS00:Valid core signature
05:42:12:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
05:42:12:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
05:42:12:WU00:FS00:Starting
05:42:12:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ajmch\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 18340 -checkpoint 15 -np 15
05:42:12:WU00:FS00:Started FahCore on PID 43300
05:42:13:WU00:FS00:Core PID:56144
05:42:13:WU00:FS00:FahCore 0xa7 started
05:42:13:WU00:FS00:0xa7:*********************** Log Started 2020-06-04T05:42:13Z ***********************
05:42:13:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
05:42:13:WU00:FS00:0xa7:       Type: 0xa7
05:42:13:WU00:FS00:0xa7:       Core: Gromacs
05:42:13:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 43300 -checkpoint 15 -np
05:42:13:WU00:FS00:0xa7:             15
05:42:13:WU00:FS00:0xa7:************************************ CBang *************************************
05:42:13:WU00:FS00:0xa7:       Date: Oct 26 2019
05:42:13:WU00:FS00:0xa7:       Time: 01:38:25
05:42:13:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
05:42:13:WU00:FS00:0xa7:     Branch: master
05:42:13:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
05:42:13:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:42:13:WU00:FS00:0xa7:   Platform: win32 10
05:42:13:WU00:FS00:0xa7:       Bits: 64
05:42:13:WU00:FS00:0xa7:       Mode: Release
05:42:13:WU00:FS00:0xa7:************************************ System ************************************
05:42:13:WU00:FS00:0xa7:        CPU: AMD Ryzen Threadripper 3970X 32-Core Processor
05:42:13:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 49 Stepping 0
05:42:13:WU00:FS00:0xa7:       CPUs: 64
05:42:13:WU00:FS00:0xa7:     Memory: 127.88GiB
05:42:13:WU00:FS00:0xa7:Free Memory: 52.03GiB
05:42:13:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
05:42:13:WU00:FS00:0xa7: OS Version: 6.2
05:42:13:WU00:FS00:0xa7:Has Battery: true
05:42:13:WU00:FS00:0xa7: On Battery: false
05:42:14:WU00:FS00:0xa7: UTC Offset: 2
05:42:14:WU00:FS00:0xa7:        PID: 56144
05:42:14:WU00:FS00:0xa7:        CWD: C:\Users\ajmch\AppData\Roaming\FAHClient\work
05:42:14:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
05:42:14:WU00:FS00:0xa7:    Version: 0.0.18
05:42:14:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:42:14:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
05:42:14:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
05:42:14:WU00:FS00:0xa7:       Date: Oct 26 2019
05:42:14:WU00:FS00:0xa7:       Time: 01:52:30
05:42:14:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
05:42:14:WU00:FS00:0xa7:     Branch: master
05:42:14:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
05:42:14:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:42:14:WU00:FS00:0xa7:   Platform: win32 10
05:42:14:WU00:FS00:0xa7:       Bits: 64
05:42:14:WU00:FS00:0xa7:       Mode: Release
05:42:14:WU00:FS00:0xa7:************************************ Build *************************************
05:42:14:WU00:FS00:0xa7:       SIMD: avx_256
05:42:14:WU00:FS00:0xa7:********************************************************************************
05:42:14:WU00:FS00:0xa7:Project: 16424 (Run 739, Clone 2, Gen 83)
05:42:14:WU00:FS00:0xa7:Unit: 0x00000063a8f5c67d5e8f6a23851f22bc
05:42:14:WU00:FS00:0xa7:Reading tar file core.xml
05:42:14:WU00:FS00:0xa7:Reading tar file frame83.tpr
05:42:14:WU00:FS00:0xa7:Digital signatures verified
05:42:14:WU00:FS00:0xa7:Calling: mdrun -s frame83.tpr -o frame83.trr -x frame83.xtc -cpt 15 -nt 15
05:42:14:WU00:FS00:0xa7:Steps: first=20750000 total=250000
05:42:15:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
05:42:46:FS00:Shutting core down
05:42:46:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 56144
05:42:46:WU00:FS00:0xa7:Exiting, please wait. . .
05:42:47:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
05:42:47:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
05:42:48:WU00:FS00:Starting
05:42:48:WARNING:WU00:FS00:Changed SMP threads from 15 to 31 this can cause some work units to fail
05:42:48:WARNING:WU00:FS00:AS lowered CPUs from 31 to 15
05:42:48:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ajmch\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 18340 -checkpoint 15 -np 15
05:42:48:WU00:FS00:Started FahCore on PID 51460
05:42:48:WU00:FS00:Core PID:55320
05:42:48:WU00:FS00:FahCore 0xa7 started
05:42:48:WU00:FS00:0xa7:*********************** Log Started 2020-06-04T05:42:48Z ***********************
05:42:48:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
05:42:48:WU00:FS00:0xa7:       Type: 0xa7
05:42:48:WU00:FS00:0xa7:       Core: Gromacs
05:42:48:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 51460 -checkpoint 15 -np
05:42:48:WU00:FS00:0xa7:             15
05:42:48:WU00:FS00:0xa7:************************************ CBang *************************************
05:42:48:WU00:FS00:0xa7:       Date: Oct 26 2019
05:42:48:WU00:FS00:0xa7:       Time: 01:38:25
05:42:48:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
05:42:48:WU00:FS00:0xa7:     Branch: master
05:42:48:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
05:42:48:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:42:48:WU00:FS00:0xa7:   Platform: win32 10
05:42:48:WU00:FS00:0xa7:       Bits: 64
05:42:48:WU00:FS00:0xa7:       Mode: Release
05:42:48:WU00:FS00:0xa7:************************************ System ************************************
05:42:48:WU00:FS00:0xa7:        CPU: AMD Ryzen Threadripper 3970X 32-Core Processor
05:42:48:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 49 Stepping 0
05:42:48:WU00:FS00:0xa7:       CPUs: 64
05:42:48:WU00:FS00:0xa7:     Memory: 127.88GiB
05:42:48:WU00:FS00:0xa7:Free Memory: 52.01GiB
05:42:48:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
05:42:48:WU00:FS00:0xa7: OS Version: 6.2
05:42:48:WU00:FS00:0xa7:Has Battery: true
05:42:48:WU00:FS00:0xa7: On Battery: false
05:42:48:WU00:FS00:0xa7: UTC Offset: 2
05:42:48:WU00:FS00:0xa7:        PID: 55320
05:42:48:WU00:FS00:0xa7:        CWD: C:\Users\ajmch\AppData\Roaming\FAHClient\work
05:42:48:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
05:42:48:WU00:FS00:0xa7:    Version: 0.0.18
05:42:48:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:42:48:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
05:42:48:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
05:42:48:WU00:FS00:0xa7:       Time: 01:52:30
05:42:48:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
05:42:48:WU00:FS00:0xa7:************************************ Build *************************************
05:42:48:WU00:FS00:0xa7:       SIMD: avx_256
05:42:48:WU00:FS00:0xa7:********************************************************************************
05:42:48:WU00:FS00:0xa7:Project: 16424 (Run 739, Clone 2, Gen 83)
05:42:48:WU00:FS00:0xa7:Unit: 0x00000063a8f5c67d5e8f6a23851f22bc
05:42:48:WU00:FS00:0xa7:Digital signatures verified
05:42:48:WU00:FS00:0xa7:Calling: mdrun -s frame83.tpr -o frame83.trr -x frame83.xtc -cpi state.cpt -cpt 15 -nt 15
05:42:48:WU00:FS00:0xa7:Steps: first=20750000 total=250000
05:42:50:WU00:FS00:0xa7:Completed 1482 out of 250000 steps (0%)
05:43:08:FS00:Shutting core down
05:43:08:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 55320
05:43:08:WU00:FS00:0xa7:Exiting, please wait. . .
05:43:09:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
05:43:09:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
05:43:48:WU00:FS00:Starting
05:43:48:WARNING:WU00:FS00:Changed SMP threads from 31 to 32 this can cause some work units to fail
05:43:48:WARNING:WU00:FS00:AS lowered CPUs from 32 to 15
05:43:48:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ajmch\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 18340 -checkpoint 15 -np 15
05:43:48:WU00:FS00:Started FahCore on PID 36588
05:43:48:WU00:FS00:Core PID:57572
05:43:48:WU00:FS00:FahCore 0xa7 started
05:43:48:WU00:FS00:0xa7:*********************** Log Started 2020-06-04T05:43:48Z ***********************
05:43:48:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
05:43:48:WU00:FS00:0xa7:       Type: 0xa7
05:43:48:WU00:FS00:0xa7:       Core: Gromacs
05:43:48:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 36588 -checkpoint 15 -np
05:43:48:WU00:FS00:0xa7:             15
05:43:48:WU00:FS00:0xa7:************************************ CBang *************************************
05:43:48:WU00:FS00:0xa7:       Date: Oct 26 2019
05:43:48:WU00:FS00:0xa7:       Time: 01:38:25
05:43:48:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
05:43:48:WU00:FS00:0xa7:     Branch: master
05:43:48:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
05:43:48:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:43:48:WU00:FS00:0xa7:   Platform: win32 10
05:43:48:WU00:FS00:0xa7:       Bits: 64
05:43:48:WU00:FS00:0xa7:       Mode: Release
05:43:48:WU00:FS00:0xa7:************************************ System ************************************
05:43:48:WU00:FS00:0xa7:        CPU: AMD Ryzen Threadripper 3970X 32-Core Processor
05:43:48:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 49 Stepping 0
05:43:48:WU00:FS00:0xa7:       CPUs: 64
05:43:48:WU00:FS00:0xa7:     Memory: 127.88GiB
05:43:48:WU00:FS00:0xa7:Free Memory: 51.94GiB
05:43:48:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
05:43:48:WU00:FS00:0xa7: OS Version: 6.2
05:43:48:WU00:FS00:0xa7:Has Battery: true
05:43:48:WU00:FS00:0xa7: On Battery: false
05:43:48:WU00:FS00:0xa7: UTC Offset: 2
05:43:48:WU00:FS00:0xa7:        PID: 57572
05:43:48:WU00:FS00:0xa7:        CWD: C:\Users\ajmch\AppData\Roaming\FAHClient\work
05:43:48:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
05:43:48:WU00:FS00:0xa7:    Version: 0.0.18
05:43:48:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:43:48:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
05:43:48:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
05:43:48:WU00:FS00:0xa7:       Time: 01:52:30
05:43:48:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
05:43:48:WU00:FS00:0xa7:************************************ Build *************************************
05:43:48:WU00:FS00:0xa7:       SIMD: avx_256
05:43:48:WU00:FS00:0xa7:********************************************************************************
05:43:48:WU00:FS00:0xa7:Project: 16424 (Run 739, Clone 2, Gen 83)
05:43:48:WU00:FS00:0xa7:Unit: 0x00000063a8f5c67d5e8f6a23851f22bc
05:43:48:WU00:FS00:0xa7:Digital signatures verified
05:43:48:WU00:FS00:0xa7:Calling: mdrun -s frame83.tpr -o frame83.trr -x frame83.xtc -cpi state.cpt -cpt 15 -nt 15
05:43:48:WU00:FS00:0xa7:Steps: first=20750000 total=250000
05:43:50:WU00:FS00:0xa7:Completed 2362 out of 250000 steps (0%)
05:43:53:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
07:07:53:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
07:07:54:WU02:FS00:Connecting to assign1.foldingathome.org:80
07:07:54:WU02:FS00:Assigned to work server 3.21.157.11
07:07:54:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:32 from 3.21.157.11
07:07:54:WU02:FS00:Connecting to 3.21.157.11:8080
07:07:55:WU02:FS00:Downloading 2.82MiB
07:07:56:WU02:FS00:Download complete
07:07:56:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14808 run:1296 clone:0 gen:12 core:0xa7 unit:0x0000000f03159d0b5ec09db954b86359
07:08:45:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
07:08:47:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
07:08:47:WU00:FS00:0xa7:Saving result file frame83.trr
07:08:47:WU00:FS00:0xa7:Saving result file frame83.xtc
07:08:47:WU00:FS00:0xa7:Saving result file md.log
07:08:47:WU00:FS00:0xa7:Saving result file science.log
07:08:47:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
07:08:48:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
07:08:48:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16424 run:739 clone:2 gen:83 core:0xa7 unit:0x00000063a8f5c67d5e8f6a23851f22bc
07:08:48:WU00:FS00:Uploading 6.99MiB to 168.245.198.125
07:08:48:WU00:FS00:Connecting to 168.245.198.125:8080
07:08:48:WU02:FS00:Starting
07:08:48:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ajmch\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 18340 -checkpoint 15 -np 32
07:08:48:WU02:FS00:Started FahCore on PID 57412
07:08:48:WU02:FS00:Core PID:13812
07:08:48:WU02:FS00:FahCore 0xa7 started
07:08:48:WU02:FS00:0xa7:*********************** Log Started 2020-06-04T07:08:48Z ***********************
07:08:48:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:08:48:WU02:FS00:0xa7:       Type: 0xa7
07:08:48:WU02:FS00:0xa7:       Core: Gromacs
07:08:48:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 57412 -checkpoint 15 -np
07:08:48:WU02:FS00:0xa7:             32
07:08:48:WU02:FS00:0xa7:************************************ CBang *************************************
07:08:48:WU02:FS00:0xa7:       Date: Oct 26 2019
07:08:48:WU02:FS00:0xa7:       Time: 01:38:25
07:08:48:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
07:08:48:WU02:FS00:0xa7:     Branch: master
07:08:48:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
07:08:48:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:08:48:WU02:FS00:0xa7:   Platform: win32 10
07:08:48:WU02:FS00:0xa7:       Bits: 64
07:08:48:WU02:FS00:0xa7:       Mode: Release
07:08:48:WU02:FS00:0xa7:************************************ System ************************************
07:08:48:WU02:FS00:0xa7:        CPU: AMD Ryzen Threadripper 3970X 32-Core Processor
07:08:48:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 49 Stepping 0
07:08:48:WU02:FS00:0xa7:       CPUs: 64
07:08:48:WU02:FS00:0xa7:     Memory: 127.88GiB
07:08:48:WU02:FS00:0xa7:Free Memory: 53.09GiB
07:08:48:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
07:08:48:WU02:FS00:0xa7: OS Version: 6.2
07:08:48:WU02:FS00:0xa7:Has Battery: true
07:08:48:WU02:FS00:0xa7: On Battery: false
07:08:48:WU02:FS00:0xa7: UTC Offset: 2
07:08:48:WU02:FS00:0xa7:        PID: 13812
07:08:48:WU02:FS00:0xa7:        CWD: C:\Users\ajmch\AppData\Roaming\FAHClient\work
07:08:48:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
07:08:48:WU02:FS00:0xa7:    Version: 0.0.18
07:08:48:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:08:48:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:08:48:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
07:08:48:WU02:FS00:0xa7:       Time: 01:52:30
07:08:48:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
07:08:48:WU02:FS00:0xa7:************************************ Build *************************************
07:08:48:WU02:FS00:0xa7:       SIMD: avx_256
07:08:48:WU02:FS00:0xa7:********************************************************************************
07:08:48:WU02:FS00:0xa7:Project: 14808 (Run 1296, Clone 0, Gen 12)
07:08:48:WU02:FS00:0xa7:Unit: 0x0000000f03159d0b5ec09db954b86359
07:08:48:WU02:FS00:0xa7:Reading tar file core.xml
07:08:48:WU02:FS00:0xa7:Reading tar file frame12.tpr
07:08:48:WU02:FS00:0xa7:Digital signatures verified
07:08:48:WU02:FS00:0xa7:Calling: mdrun -s frame12.tpr -o frame12.trr -cpt 15 -nt 32
07:08:48:WU02:FS00:0xa7:Steps: first=0 total=250000
07:08:49:WU02:FS00:0xa7:Completed 1 out of 250000 steps (0%)
07:08:54:WU00:FS00:Upload 32.20%
07:09:00:WU00:FS00:Upload 62.61%
07:09:06:WU00:FS00:Upload 96.60%
07:09:06:WU00:FS00:Upload complete
07:09:06:WU00:FS00:Server responded WORK_ACK (400)
07:09:06:WU00:FS00:Final credit estimate, 23861.00 points
07:09:06:WU00:FS00:Cleaning up
07:09:07:WU02:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
07:38:39:WU02:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
07:38:40:WU00:FS00:Connecting to assign1.foldingathome.org:80
07:38:40:WU00:FS00:Assigned to work server 130.237.11.145
07:38:40:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:32 from 130.237.11.145
07:38:40:WU00:FS00:Connecting to 130.237.11.145:8080
07:38:40:WU00:FS00:Downloading 3.14MiB
07:38:41:WU00:FS00:Download complete
07:38:41:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16806 run:9 clone:552 gen:31 core:0xa7 unit:0x0000002682ed0b915eb41bbb1b249d1f
07:38:58:WU02:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
07:38:59:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
07:38:59:WU02:FS00:0xa7:Saving result file dhdl.xvg
07:38:59:WU02:FS00:0xa7:Saving result file frame12.trr
07:38:59:WU02:FS00:0xa7:Saving result file md.log
07:38:59:WU02:FS00:0xa7:Saving result file pullf.xvg
07:38:59:WU02:FS00:0xa7:Saving result file pullx.xvg
07:38:59:WU02:FS00:0xa7:Saving result file science.log
07:38:59:WU02:FS00:0xa7:Saving result file traj_comp.xtc
07:38:59:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
07:39:00:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
07:39:00:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14808 run:1296 clone:0 gen:12 core:0xa7 unit:0x0000000f03159d0b5ec09db954b86359
07:39:00:WU02:FS00:Uploading 6.81MiB to 3.21.157.11
07:39:00:WU02:FS00:Connecting to 3.21.157.11:8080
07:39:00:WU00:FS00:Starting
07:39:00:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ajmch\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 18340 -checkpoint 15 -np 32
07:39:00:WU00:FS00:Started FahCore on PID 43184
07:39:00:WU00:FS00:Core PID:36332
07:39:00:WU00:FS00:FahCore 0xa7 started
07:39:00:WU00:FS00:0xa7:*********************** Log Started 2020-06-04T07:39:00Z ***********************
07:39:00:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:39:00:WU00:FS00:0xa7:       Type: 0xa7
07:39:00:WU00:FS00:0xa7:       Core: Gromacs
07:39:00:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 43184 -checkpoint 15 -np
07:39:00:WU00:FS00:0xa7:             32
07:39:00:WU00:FS00:0xa7:************************************ CBang *************************************
07:39:00:WU00:FS00:0xa7:       Date: Oct 26 2019
07:39:00:WU00:FS00:0xa7:       Time: 01:38:25
07:39:00:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
07:39:00:WU00:FS00:0xa7:     Branch: master
07:39:00:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
07:39:00:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:39:00:WU00:FS00:0xa7:   Platform: win32 10
07:39:00:WU00:FS00:0xa7:       Bits: 64
07:39:00:WU00:FS00:0xa7:       Mode: Release
07:39:00:WU00:FS00:0xa7:************************************ System ************************************
07:39:00:WU00:FS00:0xa7:        CPU: AMD Ryzen Threadripper 3970X 32-Core Processor
07:39:00:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 49 Stepping 0
07:39:00:WU00:FS00:0xa7:       CPUs: 64
07:39:00:WU00:FS00:0xa7:     Memory: 127.88GiB
07:39:00:WU00:FS00:0xa7:Free Memory: 52.68GiB
07:39:00:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
07:39:00:WU00:FS00:0xa7: OS Version: 6.2
07:39:00:WU00:FS00:0xa7:Has Battery: true
07:39:00:WU00:FS00:0xa7: On Battery: false
07:39:00:WU00:FS00:0xa7: UTC Offset: 2
07:39:00:WU00:FS00:0xa7:        PID: 36332
07:39:00:WU00:FS00:0xa7:        CWD: C:\Users\ajmch\AppData\Roaming\FAHClient\work
07:39:00:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
07:39:00:WU00:FS00:0xa7:    Version: 0.0.18
07:39:00:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:39:00:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:39:00:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
07:39:00:WU00:FS00:0xa7:       Time: 01:52:30
07:39:00:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
07:39:00:WU00:FS00:0xa7:************************************ Build *************************************
07:39:00:WU00:FS00:0xa7:       SIMD: avx_256
07:39:00:WU00:FS00:0xa7:********************************************************************************
07:39:00:WU00:FS00:0xa7:Project: 16806 (Run 9, Clone 552, Gen 31)
07:39:00:WU00:FS00:0xa7:Unit: 0x0000002682ed0b915eb41bbb1b249d1f
07:39:00:WU00:FS00:0xa7:Reading tar file core.xml
07:39:00:WU00:FS00:0xa7:Reading tar file frame31.tpr
07:39:00:WU00:FS00:0xa7:Digital signatures verified
07:39:00:WU00:FS00:0xa7:Calling: mdrun -s frame31.tpr -o frame31.trr -cpt 15 -nt 32
07:39:00:WU00:FS00:0xa7:Steps: first=15500000 total=500000
07:39:01:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
07:39:06:WU02:FS00:Upload 44.04%
07:39:12:WU02:FS00:Upload 88.08%
07:39:13:WU02:FS00:Upload complete
07:39:13:WU02:FS00:Server responded WORK_ACK (400)
07:39:13:WU02:FS00:Final credit estimate, 9489.00 points
07:39:13:WU02:FS00:Cleaning up
07:39:49:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
08:56:43:WU00:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
08:57:29:WU00:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
08:57:30:WU01:FS00:Connecting to assign1.foldingathome.org:80
08:57:30:WU01:FS00:Assigned to work server 3.133.76.19
08:57:30:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:32 from 3.133.76.19
08:57:30:WU01:FS00:Connecting to 3.133.76.19:8080
08:57:51:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
08:57:51:WU01:FS00:Connecting to 3.133.76.19:80
08:58:17:WU00:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
08:58:18:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
08:58:18:WU00:FS00:0xa7:Saving result file ener.edr
08:58:18:WU00:FS00:0xa7:Saving result file frame31.trr
08:58:18:WU00:FS00:0xa7:Saving result file md.log
08:58:18:WU00:FS00:0xa7:Saving result file science.log
08:58:18:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
08:58:18:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:58:18:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16806 run:9 clone:552 gen:31 core:0xa7 unit:0x0000002682ed0b915eb41bbb1b249d1f
08:58:18:WU00:FS00:Uploading 8.57MiB to 130.237.11.145
08:58:18:WU00:FS00:Connecting to 130.237.11.145:8080
08:58:22:WU00:FS00:Upload complete
08:58:23:WU00:FS00:Server responded WORK_ACK (400)
08:58:23:WU00:FS00:Final credit estimate, 19214.00 points
08:58:23:WU00:FS00:Cleaning up
08:58:35:WU01:FS00:Downloading 4.28MiB
08:58:36:WU01:FS00:Download complete
08:58:36:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14532 run:929 clone:1 gen:20 core:0xa7 unit:0x0000001e03854c135e9de6373e4484cf
08:58:36:WU01:FS00:Starting
08:58:36:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ajmch\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 18340 -checkpoint 15 -np 32
08:58:36:WU01:FS00:Started FahCore on PID 49736
08:58:36:WU01:FS00:Core PID:51160
08:58:36:WU01:FS00:FahCore 0xa7 started
08:58:37:WU01:FS00:0xa7:*********************** Log Started 2020-06-04T08:58:36Z ***********************
08:58:37:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:58:37:WU01:FS00:0xa7:       Type: 0xa7
08:58:37:WU01:FS00:0xa7:       Core: Gromacs
08:58:37:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 49736 -checkpoint 15 -np
08:58:37:WU01:FS00:0xa7:             32
08:58:37:WU01:FS00:0xa7:************************************ CBang *************************************
08:58:37:WU01:FS00:0xa7:       Date: Oct 26 2019
08:58:37:WU01:FS00:0xa7:       Time: 01:38:25
08:58:37:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
08:58:37:WU01:FS00:0xa7:     Branch: master
08:58:37:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
08:58:37:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:58:37:WU01:FS00:0xa7:   Platform: win32 10
08:58:37:WU01:FS00:0xa7:       Bits: 64
08:58:37:WU01:FS00:0xa7:       Mode: Release
08:58:37:WU01:FS00:0xa7:************************************ System ************************************
08:58:37:WU01:FS00:0xa7:        CPU: AMD Ryzen Threadripper 3970X 32-Core Processor
08:58:37:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 49 Stepping 0
08:58:37:WU01:FS00:0xa7:       CPUs: 64
08:58:37:WU01:FS00:0xa7:     Memory: 127.88GiB
08:58:37:WU01:FS00:0xa7:Free Memory: 51.09GiB
08:58:37:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
08:58:37:WU01:FS00:0xa7: OS Version: 6.2
08:58:37:WU01:FS00:0xa7:Has Battery: true
08:58:37:WU01:FS00:0xa7: On Battery: false
08:58:37:WU01:FS00:0xa7: UTC Offset: 2
08:58:37:WU01:FS00:0xa7:        PID: 51160
08:58:37:WU01:FS00:0xa7:        CWD: C:\Users\ajmch\AppData\Roaming\FAHClient\work
08:58:37:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
08:58:37:WU01:FS00:0xa7:    Version: 0.0.18
08:58:37:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:58:37:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:58:37:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
08:58:37:WU01:FS00:0xa7:       Time: 01:52:30
08:58:37:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
08:58:37:WU01:FS00:0xa7:************************************ Build *************************************
08:58:37:WU01:FS00:0xa7:       SIMD: avx_256
08:58:37:WU01:FS00:0xa7:********************************************************************************
08:58:37:WU01:FS00:0xa7:Project: 14532 (Run 929, Clone 1, Gen 20)
08:58:37:WU01:FS00:0xa7:Unit: 0x0000001e03854c135e9de6373e4484cf
08:58:37:WU01:FS00:0xa7:Reading tar file core.xml
08:58:37:WU01:FS00:0xa7:Reading tar file frame20.tpr
08:58:37:WU01:FS00:0xa7:Digital signatures verified
08:58:37:WU01:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpt 15 -nt 32
08:58:37:WU01:FS00:0xa7:Steps: first=5000000 total=250000
08:58:38:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
08:58:58:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
09:27:26:WU01:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
09:27:43:WU01:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
09:27:44:WU00:FS00:Connecting to assign1.foldingathome.org:80
09:27:44:WU00:FS00:Assigned to work server 40.121.152.108
09:27:44:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:32 from 40.121.152.108
09:27:44:WU00:FS00:Connecting to 40.121.152.108:8080
09:27:45:WU00:FS00:Downloading 2.82MiB
09:27:46:WU00:FS00:Download complete
09:27:46:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14820 run:139 clone:2 gen:74 core:0xa7 unit:0x000000582879986c5eaa28ce5f24f23f
09:28:01:WU01:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
09:28:02:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
09:28:02:WU01:FS00:0xa7:Saving result file frame20.trr
09:28:02:WU01:FS00:0xa7:Saving result file frame20.xtc
09:28:02:WU01:FS00:0xa7:Saving result file md.log
09:28:02:WU01:FS00:0xa7:Saving result file science.log
09:28:02:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
09:28:03:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:28:03:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14532 run:929 clone:1 gen:20 core:0xa7 unit:0x0000001e03854c135e9de6373e4484cf
09:28:03:WU01:FS00:Uploading 3.54MiB to 3.133.76.19
09:28:03:WU00:FS00:Starting
09:28:03:WU01:FS00:Connecting to 3.133.76.19:8080
09:28:03:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ajmch\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 18340 -checkpoint 15 -np 32
09:28:03:WU00:FS00:Started FahCore on PID 30632
09:28:03:WU00:FS00:Core PID:44848
09:28:03:WU00:FS00:FahCore 0xa7 started
09:28:03:WU00:FS00:0xa7:*********************** Log Started 2020-06-04T09:28:03Z ***********************
09:28:03:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:28:03:WU00:FS00:0xa7:       Type: 0xa7
09:28:03:WU00:FS00:0xa7:       Core: Gromacs
09:28:03:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 30632 -checkpoint 15 -np
09:28:03:WU00:FS00:0xa7:             32
09:28:03:WU00:FS00:0xa7:************************************ CBang *************************************
09:28:03:WU00:FS00:0xa7:       Date: Oct 26 2019
09:28:03:WU00:FS00:0xa7:       Time: 01:38:25
09:28:03:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
09:28:03:WU00:FS00:0xa7:     Branch: master
09:28:03:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
09:28:03:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:28:03:WU00:FS00:0xa7:   Platform: win32 10
09:28:03:WU00:FS00:0xa7:       Bits: 64
09:28:03:WU00:FS00:0xa7:       Mode: Release
09:28:03:WU00:FS00:0xa7:************************************ System ************************************
09:28:03:WU00:FS00:0xa7:        CPU: AMD Ryzen Threadripper 3970X 32-Core Processor
09:28:03:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 49 Stepping 0
09:28:03:WU00:FS00:0xa7:       CPUs: 64
09:28:04:WU00:FS00:0xa7:     Memory: 127.88GiB
09:28:04:WU00:FS00:0xa7:Free Memory: 49.82GiB
09:28:04:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
09:28:04:WU00:FS00:0xa7: OS Version: 6.2
09:28:04:WU00:FS00:0xa7:Has Battery: true
09:28:04:WU00:FS00:0xa7: On Battery: false
09:28:04:WU00:FS00:0xa7: UTC Offset: 2
09:28:04:WU00:FS00:0xa7:        PID: 44848
09:28:04:WU00:FS00:0xa7:        CWD: C:\Users\ajmch\AppData\Roaming\FAHClient\work
09:28:04:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
09:28:04:WU00:FS00:0xa7:    Version: 0.0.18
09:28:04:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:28:04:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:28:04:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
09:28:04:WU00:FS00:0xa7:       Date: Oct 26 2019
09:28:04:WU00:FS00:0xa7:       Time: 01:52:30
09:28:04:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
09:28:04:WU00:FS00:0xa7:     Branch: master
09:28:04:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
09:28:04:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:28:04:WU00:FS00:0xa7:   Platform: win32 10
09:28:04:WU00:FS00:0xa7:       Bits: 64
09:28:04:WU00:FS00:0xa7:       Mode: Release
09:28:04:WU00:FS00:0xa7:************************************ Build *************************************
09:28:04:WU00:FS00:0xa7:       SIMD: avx_256
09:28:04:WU00:FS00:0xa7:********************************************************************************
09:28:04:WU00:FS00:0xa7:Project: 14820 (Run 139, Clone 2, Gen 74)
09:28:04:WU00:FS00:0xa7:Unit: 0x000000582879986c5eaa28ce5f24f23f
09:28:04:WU00:FS00:0xa7:Reading tar file core.xml
09:28:04:WU00:FS00:0xa7:Reading tar file frame74.tpr
09:28:04:WU00:FS00:0xa7:Digital signatures verified
09:28:04:WU00:FS00:0xa7:Calling: mdrun -s frame74.tpr -o frame74.trr -cpt 15 -nt 32
09:28:04:WU00:FS00:0xa7:Steps: first=0 total=250000
09:28:04:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
09:28:17:WU01:FS00:Upload 3.53%
09:28:23:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
09:28:42:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
09:29:01:WU01:FS00:Upload 5.30%
09:29:01:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
09:29:07:WU01:FS00:Upload 81.28%
09:29:08:WU01:FS00:Upload complete
09:29:08:WU01:FS00:Server responded WORK_ACK (400)
09:29:08:WU01:FS00:Final credit estimate, 10821.00 points
09:29:08:WU01:FS00:Cleaning up
09:29:20:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
09:59:58:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
10:00:17:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
10:00:18:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
10:00:18:WU00:FS00:0xa7:Saving result file dhdl.xvg
10:00:18:WU00:FS00:0xa7:Saving result file frame74.trr
10:00:18:WU00:FS00:0xa7:Saving result file md.log
10:00:18:WU00:FS00:0xa7:Saving result file pullf.xvg
10:00:18:WU00:FS00:0xa7:Saving result file pullx.xvg
10:00:18:WU00:FS00:0xa7:Saving result file science.log
10:00:18:WU00:FS00:0xa7:Saving result file traj_comp.xtc
10:00:18:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
10:00:18:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
10:00:18:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14820 run:139 clone:2 gen:74 core:0xa7 unit:0x000000582879986c5eaa28ce5f24f23f
10:00:18:WU00:FS00:Uploading 6.80MiB to 40.121.152.108
10:00:18:WU00:FS00:Connecting to 40.121.152.108:8080
10:00:24:WU00:FS00:Upload 45.95%
10:00:29:WU00:FS00:Upload complete
10:00:29:WU00:FS00:Server responded WORK_ACK (400)
10:00:29:WU00:FS00:Final credit estimate, 9597.00 points
10:00:29:WU00:FS00:Cleaning up
MeeLee
Post by MeeLee »
Thanks for confirming.
However, it only needs a small boost in frequency to get a big increase in PPD.
Some motherboards actually have 12VRMs, and can provide the 3950 up to 180W for a continuous all core 4,2-4,3Ghz.
My experience with the 3950x is that it barely ever hits 4,150Ghz. Most of the time it's running at 3,85Ghz on all cores.
JimF
Post by JimF »
I have two Ryzen 3950X (Ubuntu 18.04.4) and they are averaging a little over 600 k PPD, with lows around 480 k and highs around 720 k or so.
They have reasonably fast (3200 MHz 14-14-14-31) memory, but are not overclocked or otherwise tweaked in any way. I use fairly ordinary ASRock B450M Steel Legend motherboards.
I also have a couple of Ryzen 3900X (Ubuntu 18.04.4) and used them briefly on Folding. They did around 500 k PPD, and are a good buy.
I don't think 1 M is reasonable either.
MeeLee
Post by MeeLee »
JimF wrote:I have two Ryzen 3950X (Ubuntu 18.04.4) and they are averaging a little over 600 k PPD, with lows around 480 k and highs around 720 k or so.
I'm deducting now.
The 3950x is rated to be 8% faster than the 3900x on online benchmarks.
Your PPD results shows a max of 720k PPD, while the 3900x shows 500k PPD.
You nearly got halfway between 500k and 1M PPD, running a stock 3950, that's reported to be only 8% faster as a 3900x.
Which means if someone is able to overclock the 3950x by 10%, he would hit 1M PPD.
The 3950x is reported to be very overclockable, if you only have the right motherboards.
The $150 motherboards won't do that for you.
JimF
Post by JimF »
MeeLee wrote:The 3950x is reported to be very overclockable, if you only have the right motherboards.
I never overclock, and purposely choose motherboards that don't have extra hardware for it.
MeeLee
Post by MeeLee »
PBO is a form of overclocking. If you have it enabled, you are overclocking.
Building on what MeeLee said, I have read somewhere that some motherboard companies do enable PBO as a default setting. I am aware that some high-end Intel motherboard use a "default" overclock to ensure that their motherboard performs "better" when compared to other vendors during benchmarks.
MeeLee
Post by MeeLee »
PantherX wrote:Building on what MeeLee said, I have read somewhere that some motherboard companies do enable PBO as a default setting. I am aware that some high-end Intel motherboard use a "default" overclock to ensure that their motherboard performs "better" when compared to other vendors during benchmarks.
Yes.
What makes things worse, is that AMD uses PBO by default to overclock (all of a sudden your 65W CPU runs at 95W, and your 105W CPU runs at 145W); and then motherboard manufacturers are trying to compete with one another, using all kinds of trickery, like, increasing the bus speed (from like 100Mhz to 101Mhz or so); just to get the lead on other manufacturers.
This often results in crashes, failed boots, and sometimes, the Motherboard can't even get into BIOS anymore.
Bus overclocks not only overclock the CPU and RAM, it also overclocks the PCIE slots, which doesn't work with many GPUs or SSD drives.
But they're shooting themselves in the foot by such 'tactics', as if a board doesn't work because of an incompatible overclock, they are just going to get more returns on perfectly good boards, if the bus speed was just reset back to 100Mhz.
maigner
Post by maigner »
After running an AMD 3970X (and some last gen GPUs) for a month I wanted to add my perspective.
It's a great CPU for me. I'm usually running many Docker containers (often within a VM) for my development work. After years of dual Xeon boards I made the switch to a single CPU because it has an ample amount of cores and I'm glad I did (increased performance, smaller board size, more mainstream, less pricey).
For F@H, I've tried 1 or 2 CPU slots with 32 cores each and total results are 500K to 700K PPD either way. I guess if I enabled some overclocking and fiddled with settings I might get it closer to 1M PPD. The CPU uses about 280W and hovers around 75 deg C (custom WC loop, liquid metal TIM). It drives my fans and pumps to full speed and I can definitely hear the system working. In contrast, my 3 GV100 cards combined use less than 400W and output 7M+ PPD at ~45 deg C (system stays whisper quiet).
So, from my experience I'll have to answer the topic with 'no'.
However, I'll keep running the CPU slots for a while longer because I really want to support moonshot with everything I got.
MeeLee
Post by MeeLee »
maigner wrote:After running an AMD 3970X (and some last gen GPUs) for a month I wanted to add my perspective.
From what I've read, you'll get higher PPD by running more threads.
If you can get WUs for more than 32 cores, like 48 or higher, you'll definitely surpass 1M PPD.
