UHD Graphics 630 GPU Being Recognized over GTX 1070
Konadreamer
Post by Konadreamer »
For some reason, when I shutdown and restart my computer, the FAH client is now picking up the onboard chipset graphics (UHD Graphics 630) over my robust Nvidia GTX 1070 Mobile graphics GPU (GP104BM). I have to go into the advanced interface, add GPU slot, and then it will add the GTX 1070. I then delete the UHD 630 graphics slot and start folding and all is well. But when I pause the WU's and reboot my computer, it keeps loading the UHD Graphics 630 slot and dumps the GTX 1070 slot. I went so far as to disable the UHD 630 Graphics, but it still does the same thing when I restart the computer. I even disabled the UHD 630 Graphics via Device Manager, but that didn't fix the issue. It's not a big deal to keep re-adding the GTX 1070 slot, but it's just annoying to have to do so. The only thing I can think may have happened is I once started the computer but wasn't plugged into my power adapter and was running on battery instead, but I'm not sure this is the genesis of this issue. Is there some way I can lock in the GTX 1070 and lock out the UHD 630 so reboots don't cause this anomaly?
Alienware 17 R5
Intel Core i7-8750H
Windows 10
GTX 1070 Graphics (GP104BM)
32 GB RAM
Re: UHD Graphics 630 GPU Being Recognized over GTX 1070
post your log please
If this is a laptop, it may use Nvidia Optimus, where an Intel iGPU is used until heavy graphics loads cause it to switch to a Nvidia GPU.
Our problem is that F@H does not support Intel GPUs.
https://www.geforce.com/hardware/techno ... technology
no one solution fixes this issue, I will list some 'fixes'.
In older laptops there were BIOS setting to set the GPU, I have not found any recently..
Recently the Nvidia Control panel had a setting under 3D settings to choose to always use Nvidia.
At least one user found that if he always had MSI Afterburner running before he started Folding, it never switched to Intel. That is cumbersome at best, but it worked for him.
I hope one of these works for you!
According to my information, the UHD 630 is NOt supported by FAH.
Which OpenCL package are you using. Uninstalling Intel's OpenCL drivers often helps. I think that's another method to disable Optimus.
Have you tried adding a second GPU slot and then disabling the one that's pointing to the Inel GPU? Pause-on-start=true.
Konadreamer
bruce wrote:post your log please
Here's the log:
*********************** Log Started 2020-06-02T17:33:44Z ***********************
17:33:44:****************************** FAHClient ******************************
17:33:44:        Version: 7.6.9
17:33:44:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:33:44:      Copyright: 2020 foldingathome.org
17:33:44:       Homepage: https://foldingathome.org/
17:33:44:           Date: Apr 17 2020
17:33:44:           Time: 11:13:06
17:33:44:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
17:33:44:         Branch: master
17:33:44:       Compiler: Visual C++ 2008
17:33:44:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:33:44:       Platform: win32 10
17:33:44:           Bits: 32
17:33:44:           Mode: Release
17:33:44:         Config: C:\Users\Paul H\AppData\Roaming\FAHClient\config.xml
17:33:44:******************************** CBang ********************************
17:33:44:           Time: 11:10:09
17:33:44:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
17:33:44:           Bits: 32
17:33:44:******************************* System ********************************
17:33:44:            CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
17:33:44:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
17:33:44:           CPUs: 12
17:33:44:         Memory: 31.86GiB
17:33:44:    Free Memory: 28.70GiB
17:33:44:        Threads: WINDOWS_THREADS
17:33:44:     OS Version: 6.2
17:33:44:    Has Battery: true
17:33:44:     On Battery: false
17:33:44:     UTC Offset: -5
17:33:44:            PID: 9500
17:33:44:            CWD: C:\Users\Paul H\AppData\Roaming\FAHClient
17:33:44:             OS: Windows 10 Home
17:33:44:        OS Arch: AMD64
17:33:44:           GPUs: 2
17:33:44:          GPU 0: Bus:0 Slot:2 Func:0 INTEL:0 Gen9p5/GT2 [UHD Graphics 630]
17:33:44:          GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:5 GP104BM [GeForce GTX 1070 Mobile]
17:33:44:                 6463
17:33:44:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.1
17:33:44:OpenCL Device 1: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:431.53
17:33:44:  Win32 Service: false
17:33:44:******************************* libFAH ********************************
17:33:44:           Date: Apr 15 2020
17:33:44:           Time: 14:53:14
17:33:44:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
17:33:44:           Bits: 32
17:33:44:***********************************************************************
17:33:44:<config>
17:33:44:  <!-- Network -->
17:33:44:  <proxy v=':8080'/>
17:33:44:
17:33:44:  <!-- Slot Control -->
17:33:44:  <power v='medium'/>
17:33:44:
17:33:44:  <!-- User Information -->
17:33:44:  <passkey v='*****'/>
17:33:44:  <team v='182116'/>
17:33:44:  <user v='Konadreamer'/>
17:33:44:
17:33:44:  <!-- Folding Slots -->
17:33:44:  <slot id='0' type='CPU'>
17:33:44:    <cpus v='5'/>
17:33:44:  </slot>
17:33:44:  <slot id='1' type='GPU'/>
17:33:44:</config>
17:33:44:Trying to access database...
17:33:44:Successfully acquired database lock
17:33:44:Enabled folding slot 00: READY cpu:5
17:33:44:Enabled folding slot 01: READY gpu:0:Gen9p5/GT2 [UHD Graphics 630]
17:33:44:ERROR:No compute devices matched GPU #0 {
17:33:44:ERROR:  "vendor": 32902,
17:33:44:ERROR:  "device": 16027,
17:33:44:ERROR:  "type": 3,
17:33:44:ERROR:  "species": 0,
17:33:44:ERROR:  "description": "Gen9p5/GT2 [UHD Graphics 630]"
17:33:44:ERROR:}.  You may need to update your graphics drivers.
17:33:44:WARNING:WU01:No longer matches Slot 1's configuration and there are no other matching slots, dumping
17:33:44:WU01:FS01:Sending unit results: id:01 state:SEND error:DUMPED project:11745 run:0 clone:5658 gen:69 core:0x22 unit:0x000000778ca304f15e6bc3d2c996edda
17:33:44:WU01:FS01:Connecting to 140.163.4.241:8080
17:33:44:WU00:FS00:Starting
17:33:44:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\Paul H\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 00 -suffix 01 -version 706 -lifeline 9500 -checkpoint 15 -np 5
17:33:44:WU00:FS00:Started FahCore on PID 9524
17:33:44:WU00:FS00:Core PID:12228
17:33:44:WU00:FS00:FahCore 0xa7 started
17:33:45:WU00:FS00:0xa7:*********************** Log Started 2020-06-02T17:33:44Z ***********************
17:33:45:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:33:45:WU00:FS00:0xa7:       Type: 0xa7
17:33:45:WU00:FS00:0xa7:       Core: Gromacs
17:33:45:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9524 -checkpoint 15 -np 5
17:33:45:WU00:FS00:0xa7:************************************ CBang *************************************
17:33:45:WU00:FS00:0xa7:       Date: Oct 26 2019
17:33:45:WU00:FS00:0xa7:       Time: 01:38:25
17:33:45:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:33:45:WU00:FS00:0xa7:     Branch: master
17:33:45:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
17:33:45:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:33:45:WU00:FS00:0xa7:   Platform: win32 10
17:33:45:WU00:FS00:0xa7:       Bits: 64
17:33:45:WU00:FS00:0xa7:       Mode: Release
17:33:45:WU00:FS00:0xa7:************************************ System ************************************
17:33:45:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
17:33:45:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
17:33:45:WU00:FS00:0xa7:       CPUs: 12
17:33:45:WU00:FS00:0xa7:     Memory: 31.86GiB
17:33:45:WU00:FS00:0xa7:Free Memory: 28.65GiB
17:33:45:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
17:33:45:WU00:FS00:0xa7: OS Version: 6.2
17:33:45:WU00:FS00:0xa7:Has Battery: true
17:33:45:WU00:FS00:0xa7: On Battery: false
17:33:45:WU00:FS00:0xa7: UTC Offset: -5
17:33:45:WU00:FS00:0xa7:        PID: 12228
17:33:45:WU00:FS00:0xa7:        CWD: C:\Users\Paul H\AppData\Roaming\FAHClient\work
17:33:45:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
17:33:45:WU00:FS00:0xa7:    Version: 0.0.18
17:33:45:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:33:45:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:33:45:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
17:33:45:WU00:FS00:0xa7:       Time: 01:52:30
17:33:45:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:33:45:WU00:FS00:0xa7:************************************ Build *************************************
17:33:45:WU00:FS00:0xa7:       SIMD: avx_256
17:33:45:WU00:FS00:0xa7:********************************************************************************
17:33:45:WU00:FS00:0xa7:Project: 14809 (Run 2509, Clone 0, Gen 7)
17:33:45:WU00:FS00:0xa7:Unit: 0x0000000c455e42065ec1244583f26c1d
17:33:45:WU00:FS00:0xa7:Digital signatures verified
17:33:45:WU00:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
17:33:45:WU00:FS00:0xa7:Calling: mdrun -s frame7.tpr -o frame7.trr -cpi state.cpt -cpt 15 -nt 4
17:33:45:WU00:FS00:0xa7:Steps: first=0 total=250000
17:33:45:WU03:FS01:Connecting to 65.254.110.245:80
17:33:46:WU01:FS01:Server responded WORK_ACK (400)
17:33:46:WU01:FS01:Cleaning up
17:33:46:WU03:FS01:Assigned to work server 3.21.157.11
17:33:46:WU03:FS01:Requesting new work unit for slot 01: READY gpu:0:Gen9p5/GT2 [UHD Graphics 630] from 3.21.157.11
17:33:46:WU03:FS01:Connecting to 3.21.157.11:8080
17:33:46:WU00:FS00:0xa7:Completed 11408 out of 250000 steps (4%)
17:33:47:WU03:FS01:Downloading 2.82MiB
17:33:47:WU03:FS01:Download complete
17:33:48:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:14826 run:604 clone:0 gen:12 core:0xa7 unit:0x0000001103159d0b5ec0a4d2dc73c30a
17:33:48:WU03:FS01:Starting
17:33:48:ERROR:WU03:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
17:34:25:6:127.0.0.1:New Web session
17:34:48:WU03:FS01:Starting
17:34:48:ERROR:WU03:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
17:34:59:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
17:35:18:Adding folding slot 02: READY gpu:1:GP104BM [GeForce GTX 1070 Mobile] 6463
17:35:18:Removing old file 'configs/config-20200602-171317.xml'
17:35:18:Saving configuration to config.xml
17:35:18:<config>
17:35:18:  <!-- Network -->
17:35:18:  <proxy v=':8080'/>
17:35:18:
17:35:18:  <!-- Slot Control -->
17:35:18:  <power v='medium'/>
17:35:18:
17:35:18:  <!-- User Information -->
17:35:18:  <passkey v='*****'/>
17:35:18:  <team v='182116'/>
17:35:18:  <user v='Konadreamer'/>
17:35:18:
17:35:18:  <!-- Folding Slots -->
17:35:18:  <slot id='0' type='CPU'>
17:35:18:    <cpus v='5'/>
17:35:18:  </slot>
17:35:18:  <slot id='1' type='GPU'/>
17:35:18:  <slot id='2' type='GPU'/>
17:35:18:</config>
17:35:18:WU01:FS02:Connecting to 65.254.110.245:80
17:35:18:WU01:FS02:Assigned to work server 128.252.203.10
17:35:18:WU01:FS02:Requesting new work unit for slot 02: READY gpu:1:GP104BM [GeForce GTX 1070 Mobile] 6463 from 128.252.203.10
17:35:18:WU01:FS02:Connecting to 128.252.203.10:8080
17:35:26:Removing old file 'configs/config-20200602-171519.xml'
17:35:26:Saving configuration to config.xml
17:35:26:<config>
17:35:26:  <!-- Network -->
17:35:26:  <proxy v=':8080'/>
17:35:26:
17:35:26:  <!-- Slot Control -->
17:35:26:  <power v='medium'/>
17:35:26:
17:35:26:  <!-- User Information -->
17:35:26:  <passkey v='*****'/>
17:35:26:  <team v='182116'/>
17:35:26:  <user v='Konadreamer'/>
17:35:26:
17:35:26:  <!-- Folding Slots -->
17:35:26:  <slot id='0' type='CPU'>
17:35:26:    <cpus v='5'/>
17:35:26:  </slot>
17:35:26:  <slot id='2' type='GPU'/>
17:35:26:</config>
17:35:26:WARNING:WU03:FS01:Slot ID 1 no longer exists and there are no other matching slots, dumping
17:35:26:WU03:FS01:Sending unit results: id:03 state:SEND error:DUMPED project:14826 run:604 clone:0 gen:12 core:0xa7 unit:0x0000001103159d0b5ec0a4d2dc73c30a
17:35:26:WU03:FS01:Connecting to 3.21.157.11:8080
17:35:26:WU03:FS01:Server responded WORK_ACK (400)
17:35:26:WU03:FS01:Cleaning up
17:35:41:29:127.0.0.1:New Web session
17:35:46:Removing old file 'configs/config-20200602-171526.xml'
17:35:46:Saving configuration to config.xml
17:35:46:<config>
17:35:46:  <!-- Network -->
17:35:46:  <proxy v=':8080'/>
17:35:46:
17:35:46:  <!-- Slot Control -->
17:35:46:  <power v='medium'/>
17:35:46:
17:35:46:  <!-- User Information -->
17:35:46:  <passkey v='*****'/>
17:35:46:  <team v='182116'/>
17:35:46:  <user v='Konadreamer'/>
17:35:46:
17:35:46:  <!-- Folding Slots -->
17:35:46:  <slot id='0' type='CPU'>
17:35:46:    <cpus v='5'/>
17:35:46:  </slot>
17:35:46:  <slot id='2' type='GPU'/>
17:35:46:</config>
17:36:11:WU01:FS02:Downloading 51.19MiB
17:36:17:WU01:FS02:Download 53.11%
17:36:20:WU01:FS02:Download complete
17:36:20:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11763 run:0 clone:4774 gen:71 core:0x22 unit:0x0000008a80fccb0a5e6d81783a1ad086
17:36:20:WU01:FS02:Starting
17:36:20:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\Paul H\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe" -dir 01 -suffix 01 -version 706 -lifeline 9500 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
17:36:20:WU01:FS02:Started FahCore on PID 7960
17:36:20:WU01:FS02:Core PID:13560
17:36:20:WU01:FS02:FahCore 0x22 started
17:36:20:WU01:FS02:0x22:*********************** Log Started 2020-06-02T17:36:20Z ***********************
17:36:20:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
17:36:20:WU01:FS02:0x22:       Type: 0x22
17:36:20:WU01:FS02:0x22:       Core: Core22
17:36:20:WU01:FS02:0x22:    Website: https://foldingathome.org/
17:36:20:WU01:FS02:0x22:  Copyright: (c) 2009-2018 foldingathome.org
17:36:20:WU01:FS02:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
17:36:20:WU01:FS02:0x22:             <rafal.wiewiora@choderalab.org>
17:36:20:WU01:FS02:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 7960 -checkpoint 15
17:36:20:WU01:FS02:0x22:             -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
17:36:20:WU01:FS02:0x22:             0 -gpu 0
17:36:20:WU01:FS02:0x22:     Config: <none>
17:36:20:WU01:FS02:0x22:************************************ Build *************************************
17:36:20:WU01:FS02:0x22:    Version: 0.0.5
17:36:20:WU01:FS02:0x22:       Date: Apr 22 2020
17:36:20:WU01:FS02:0x22:       Time: 04:42:59
17:36:20:WU01:FS02:0x22: Repository: Git
17:36:20:WU01:FS02:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
17:36:20:WU01:FS02:0x22:     Branch: HEAD
17:36:20:WU01:FS02:0x22:   Compiler: Visual C++ 2008
17:36:20:WU01:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:36:20:WU01:FS02:0x22:   Platform: win32 10
17:36:20:WU01:FS02:0x22:       Bits: 64
17:36:20:WU01:FS02:0x22:       Mode: Release
17:36:20:WU01:FS02:0x22:************************************ System ************************************
17:36:20:WU01:FS02:0x22:        CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
17:36:20:WU01:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
17:36:20:WU01:FS02:0x22:       CPUs: 12
17:36:20:WU01:FS02:0x22:     Memory: 31.86GiB
17:36:20:WU01:FS02:0x22:Free Memory: 27.03GiB
17:36:20:WU01:FS02:0x22:    Threads: WINDOWS_THREADS
17:36:20:WU01:FS02:0x22: OS Version: 6.2
17:36:20:WU01:FS02:0x22:Has Battery: true
17:36:20:WU01:FS02:0x22: On Battery: false
17:36:20:WU01:FS02:0x22: UTC Offset: -5
17:36:20:WU01:FS02:0x22:        PID: 13560
17:36:20:WU01:FS02:0x22:        CWD: C:\Users\Paul H\AppData\Roaming\FAHClient\work
17:36:20:WU01:FS02:0x22:         OS: Windows 10 Home
17:36:20:WU01:FS02:0x22:    OS Arch: AMD64
17:36:20:WU01:FS02:0x22:********************************************************************************
17:36:20:WU01:FS02:0x22:Project: 11763 (Run 0, Clone 4774, Gen 71)
17:36:20:WU01:FS02:0x22:Unit: 0x0000008a80fccb0a5e6d81783a1ad086
17:36:20:WU01:FS02:0x22:Reading tar file core.xml
17:36:20:WU01:FS02:0x22:Reading tar file integrator.xml
17:36:20:WU01:FS02:0x22:Reading tar file state.xml
17:36:21:WU01:FS02:0x22:Reading tar file system.xml
17:36:22:WU01:FS02:0x22:Digital signatures verified
17:36:22:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
17:36:22:WU01:FS02:0x22:Version 0.0.5
17:36:37:WU01:FS02:0x22:Completed 0 out of 1000000 steps (0%)
17:36:37:WU01:FS02:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:37:55:WU01:FS02:0x22:Completed 10000 out of 1000000 steps (1%)
17:37:56:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
17:39:12:WU01:FS02:0x22:Completed 20000 out of 1000000 steps (2%)
17:40:30:WU01:FS02:0x22:Completed 30000 out of 1000000 steps (3%)
17:40:48:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
17:41:48:WU01:FS02:0x22:Completed 40000 out of 1000000 steps (4%)
17:43:08:WU01:FS02:0x22:Completed 50000 out of 1000000 steps (5%)
17:43:38:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
17:44:33:WU01:FS02:0x22:Completed 60000 out of 1000000 steps (6%)
17:45:53:WU01:FS02:0x22:Completed 70000 out of 1000000 steps (7%)
17:46:31:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
17:47:14:WU01:FS02:0x22:Completed 80000 out of 1000000 steps (8%)
17:48:35:WU01:FS02:0x22:Completed 90000 out of 1000000 steps (9%)
17:49:20:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
17:49:57:WU01:FS02:0x22:Completed 100000 out of 1000000 steps (10%)
17:51:22:WU01:FS02:0x22:Completed 110000 out of 1000000 steps (11%)
17:52:10:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
17:52:44:WU01:FS02:0x22:Completed 120000 out of 1000000 steps (12%)
17:54:05:WU01:FS02:0x22:Completed 130000 out of 1000000 steps (13%)
17:55:02:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
17:55:27:WU01:FS02:0x22:Completed 140000 out of 1000000 steps (14%)
17:56:48:WU01:FS02:0x22:Completed 150000 out of 1000000 steps (15%)
17:57:51:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
17:58:13:WU01:FS02:0x22:Completed 160000 out of 1000000 steps (16%)
17:59:34:WU01:FS02:0x22:Completed 170000 out of 1000000 steps (17%)
18:00:43:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
18:00:55:WU01:FS02:0x22:Completed 180000 out of 1000000 steps (18%)
18:02:16:WU01:FS02:0x22:Completed 190000 out of 1000000 steps (19%)
18:03:36:WU01:FS02:0x22:Completed 200000 out of 1000000 steps (20%)
18:03:37:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
18:05:01:WU01:FS02:0x22:Completed 210000 out of 1000000 steps (21%)
18:06:22:WU01:FS02:0x22:Completed 220000 out of 1000000 steps (22%)
18:06:26:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
18:07:46:WU01:FS02:0x22:Completed 230000 out of 1000000 steps (23%)
18:09:05:WU01:FS02:0x22:Completed 240000 out of 1000000 steps (24%)
18:09:38:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
18:10:33:WU01:FS02:0x22:Completed 250000 out of 1000000 steps (25%)
18:11:57:WU01:FS02:0x22:Completed 260000 out of 1000000 steps (26%)
18:12:53:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
18:13:16:WU01:FS02:0x22:Completed 270000 out of 1000000 steps (27%)
18:14:34:WU01:FS02:0x22:Completed 280000 out of 1000000 steps (28%)
18:15:32:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
18:15:53:WU01:FS02:0x22:Completed 290000 out of 1000000 steps (29%)
18:17:11:WU01:FS02:0x22:Completed 300000 out of 1000000 steps (30%)
18:18:12:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
18:18:34:WU01:FS02:0x22:Completed 310000 out of 1000000 steps (31%)
18:19:52:WU01:FS02:0x22:Completed 320000 out of 1000000 steps (32%)
18:20:58:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
18:21:11:WU01:FS02:0x22:Completed 330000 out of 1000000 steps (33%)
18:22:29:WU01:FS02:0x22:Completed 340000 out of 1000000 steps (34%)
18:23:36:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
18:23:47:WU01:FS02:0x22:Completed 350000 out of 1000000 steps (35%)
18:25:10:WU01:FS02:0x22:Completed 360000 out of 1000000 steps (36%)
18:26:16:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
18:26:28:WU01:FS02:0x22:Completed 370000 out of 1000000 steps (37%)
18:27:46:WU01:FS02:0x22:Completed 380000 out of 1000000 steps (38%)
18:28:54:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
18:29:04:WU01:FS02:0x22:Completed 390000 out of 1000000 steps (39%)
18:30:22:WU01:FS02:0x22:Completed 400000 out of 1000000 steps (40%)
18:31:33:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
18:31:45:WU01:FS02:0x22:Completed 410000 out of 1000000 steps (41%)
18:33:03:WU01:FS02:0x22:Completed 420000 out of 1000000 steps (42%)
18:34:15:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
18:34:22:WU01:FS02:0x22:Completed 430000 out of 1000000 steps (43%)
18:35:40:WU01:FS02:0x22:Completed 440000 out of 1000000 steps (44%)
18:36:54:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
18:36:58:WU01:FS02:0x22:Completed 450000 out of 1000000 steps (45%)
18:38:21:WU01:FS02:0x22:Completed 460000 out of 1000000 steps (46%)
18:39:33:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
18:39:39:WU01:FS02:0x22:Completed 470000 out of 1000000 steps (47%)
18:40:59:WU01:FS02:0x22:Completed 480000 out of 1000000 steps (48%)
18:42:12:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
18:42:17:WU01:FS02:0x22:Completed 490000 out of 1000000 steps (49%)
18:43:35:WU01:FS02:0x22:Completed 500000 out of 1000000 steps (50%)
18:44:50:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
18:44:58:WU01:FS02:0x22:Completed 510000 out of 1000000 steps (51%)
18:46:16:WU01:FS02:0x22:Completed 520000 out of 1000000 steps (52%)
18:47:28:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
18:47:34:WU01:FS02:0x22:Completed 530000 out of 1000000 steps (53%)
18:48:52:WU01:FS02:0x22:Completed 540000 out of 1000000 steps (54%)
18:50:08:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
18:50:10:WU01:FS02:0x22:Completed 550000 out of 1000000 steps (55%)
18:51:32:WU01:FS02:0x22:Completed 560000 out of 1000000 steps (56%)
18:52:48:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
18:52:50:WU01:FS02:0x22:Completed 570000 out of 1000000 steps (57%)
18:54:08:WU01:FS02:0x22:Completed 580000 out of 1000000 steps (58%)
18:55:26:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
18:55:26:WU01:FS02:0x22:Completed 590000 out of 1000000 steps (59%)
18:56:44:WU01:FS02:0x22:Completed 600000 out of 1000000 steps (60%)
18:58:05:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
18:58:07:WU01:FS02:0x22:Completed 610000 out of 1000000 steps (61%)
18:59:25:WU01:FS02:0x22:Completed 620000 out of 1000000 steps (62%)
19:00:43:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
19:00:43:WU01:FS02:0x22:Completed 630000 out of 1000000 steps (63%)
19:02:02:WU01:FS02:0x22:Completed 640000 out of 1000000 steps (64%)
19:03:20:WU01:FS02:0x22:Completed 650000 out of 1000000 steps (65%)
19:03:22:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
19:04:44:WU01:FS02:0x22:Completed 660000 out of 1000000 steps (66%)
19:06:01:WU01:FS02:0x22:Completed 670000 out of 1000000 steps (67%)
19:06:07:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
19:07:19:WU01:FS02:0x22:Completed 680000 out of 1000000 steps (68%)
19:08:38:WU01:FS02:0x22:Completed 690000 out of 1000000 steps (69%)
19:08:46:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
19:09:56:WU01:FS02:0x22:Completed 700000 out of 1000000 steps (70%)
19:11:20:WU01:FS02:0x22:Completed 710000 out of 1000000 steps (71%)
19:11:27:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
19:12:41:WU01:FS02:0x22:Completed 720000 out of 1000000 steps (72%)
19:14:00:WU01:FS02:0x22:Completed 730000 out of 1000000 steps (73%)
19:14:13:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
19:15:19:WU01:FS02:0x22:Completed 740000 out of 1000000 steps (74%)
19:16:38:WU01:FS02:0x22:Completed 750000 out of 1000000 steps (75%)
19:16:53:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
19:18:00:WU01:FS02:0x22:Completed 760000 out of 1000000 steps (76%)
19:19:18:WU01:FS02:0x22:Completed 770000 out of 1000000 steps (77%)
19:19:30:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
19:20:37:WU01:FS02:0x22:Completed 780000 out of 1000000 steps (78%)
19:21:59:WU01:FS02:0x22:Completed 790000 out of 1000000 steps (79%)
19:22:25:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
19:23:23:WU01:FS02:0x22:Completed 800000 out of 1000000 steps (80%)
19:24:51:WU01:FS02:0x22:Completed 810000 out of 1000000 steps (81%)
19:25:20:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
19:26:15:WU01:FS02:0x22:Completed 820000 out of 1000000 steps (82%)
19:27:37:WU01:FS02:0x22:Completed 830000 out of 1000000 steps (83%)
19:28:18:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
19:28:59:WU01:FS02:0x22:Completed 840000 out of 1000000 steps (84%)
19:30:18:WU01:FS02:0x22:Completed 850000 out of 1000000 steps (85%)
19:31:07:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
19:31:42:WU01:FS02:0x22:Completed 860000 out of 1000000 steps (86%)
19:33:01:WU01:FS02:0x22:Completed 870000 out of 1000000 steps (87%)
19:33:50:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
19:34:20:WU01:FS02:0x22:Completed 880000 out of 1000000 steps (88%)
19:35:43:WU01:FS02:0x22:Completed 890000 out of 1000000 steps (89%)
19:36:49:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
19:37:02:WU01:FS02:0x22:Completed 900000 out of 1000000 steps (90%)
19:38:26:WU01:FS02:0x22:Completed 910000 out of 1000000 steps (91%)
19:39:36:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
19:39:45:WU01:FS02:0x22:Completed 920000 out of 1000000 steps (92%)
19:41:05:WU01:FS02:0x22:Completed 930000 out of 1000000 steps (93%)
19:42:24:WU01:FS02:0x22:Completed 940000 out of 1000000 steps (94%)
19:42:29:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
19:43:43:WU01:FS02:0x22:Completed 950000 out of 1000000 steps (95%)
19:45:06:WU01:FS02:0x22:Completed 960000 out of 1000000 steps (96%)
19:45:10:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
19:46:25:WU01:FS02:0x22:Completed 970000 out of 1000000 steps (97%)
19:47:44:WU01:FS02:0x22:Completed 980000 out of 1000000 steps (98%)
19:48:02:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
19:49:04:WU01:FS02:0x22:Completed 990000 out of 1000000 steps (99%)
19:49:05:WU03:FS02:Connecting to 65.254.110.245:80
19:49:05:WU03:FS02:Assigned to work server 18.188.125.154
19:49:05:WU03:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:GP104BM [GeForce GTX 1070 Mobile] 6463 from 18.188.125.154
19:49:05:WU03:FS02:Connecting to 18.188.125.154:8080
19:49:05:WU03:FS02:Downloading 436.01KiB
19:49:06:WU03:FS02:Download complete
19:49:06:WU03:FS02:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:13409 run:493 clone:16 gen:1 core:0x22 unit:0x0000000112bc7d9a5ed4a8950ab8df74
19:50:28:WU01:FS02:0x22:Completed 1000000 out of 1000000 steps (100%)
19:50:34:WU01:FS02:0x22:Saving result file ..\logfile_01.txt
19:50:34:WU01:FS02:0x22:Saving result file checkpointState.xml
19:50:34:WU01:FS02:0x22:Saving result file checkpt.crc
19:50:34:WU01:FS02:0x22:Saving result file positions.xtc
19:50:34:WU01:FS02:0x22:Saving result file science.log
19:50:34:WU01:FS02:0x22:Folding@home Core Shutdown: FINISHED_UNIT
19:50:35:WU01:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:50:35:WU01:FS02:Sending unit results: id:01 state:SEND error:NO_ERROR project:11763 run:0 clone:4774 gen:71 core:0x22 unit:0x0000008a80fccb0a5e6d81783a1ad086
19:50:35:WU01:FS02:Uploading 33.37MiB to 128.252.203.10
19:50:35:WU01:FS02:Connecting to 128.252.203.10:8080
19:50:35:WU03:FS02:Starting
19:50:35:WU03:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\Paul H\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe" -dir 03 -suffix 01 -version 706 -lifeline 9500 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
19:50:35:WU03:FS02:Started FahCore on PID 9752
19:50:35:WU03:FS02:Core PID:3736
19:50:35:WU03:FS02:FahCore 0x22 started
19:50:35:WU03:FS02:0x22:*********************** Log Started 2020-06-02T19:50:35Z ***********************
19:50:35:WU03:FS02:0x22:*************************** Core22 Folding@home Core ***************************
19:50:35:WU03:FS02:0x22:       Type: 0x22
19:50:35:WU03:FS02:0x22:       Core: Core22
19:50:35:WU03:FS02:0x22:    Website: https://foldingathome.org/
19:50:35:WU03:FS02:0x22:  Copyright: (c) 2009-2018 foldingathome.org
19:50:35:WU03:FS02:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
19:50:35:WU03:FS02:0x22:             <rafal.wiewiora@choderalab.org>
19:50:35:WU03:FS02:0x22:       Args: -dir 03 -suffix 01 -version 706 -lifeline 9752 -checkpoint 15
19:50:35:WU03:FS02:0x22:             -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
19:50:35:WU03:FS02:0x22:             0 -gpu 0
19:50:35:WU03:FS02:0x22:     Config: <none>
19:50:35:WU03:FS02:0x22:************************************ Build *************************************
19:50:35:WU03:FS02:0x22:    Version: 0.0.5
19:50:35:WU03:FS02:0x22:       Date: Apr 22 2020
19:50:35:WU03:FS02:0x22:       Time: 04:42:59
19:50:35:WU03:FS02:0x22: Repository: Git
19:50:35:WU03:FS02:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
19:50:35:WU03:FS02:0x22:     Branch: HEAD
19:50:36:WU03:FS02:0x22:   Compiler: Visual C++ 2008
19:50:36:WU03:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:50:36:WU03:FS02:0x22:   Platform: win32 10
19:50:36:WU03:FS02:0x22:       Bits: 64
19:50:36:WU03:FS02:0x22:       Mode: Release
19:50:36:WU03:FS02:0x22:************************************ System ************************************
19:50:36:WU03:FS02:0x22:        CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
19:50:36:WU03:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
19:50:36:WU03:FS02:0x22:       CPUs: 12
19:50:36:WU03:FS02:0x22:     Memory: 31.86GiB
19:50:36:WU03:FS02:0x22:Free Memory: 26.20GiB
19:50:36:WU03:FS02:0x22:    Threads: WINDOWS_THREADS
19:50:36:WU03:FS02:0x22: OS Version: 6.2
19:50:36:WU03:FS02:0x22:Has Battery: true
19:50:36:WU03:FS02:0x22: On Battery: false
19:50:36:WU03:FS02:0x22: UTC Offset: -5
19:50:36:WU03:FS02:0x22:        PID: 3736
19:50:36:WU03:FS02:0x22:        CWD: C:\Users\Paul H\AppData\Roaming\FAHClient\work
19:50:36:WU03:FS02:0x22:         OS: Windows 10 Home
19:50:36:WU03:FS02:0x22:    OS Arch: AMD64
19:50:36:WU03:FS02:0x22:********************************************************************************
19:50:36:WU03:FS02:0x22:Project: 13409 (Run 493, Clone 16, Gen 1)
19:50:36:WU03:FS02:0x22:Unit: 0x0000000112bc7d9a5ed4a8950ab8df74
19:50:36:WU03:FS02:0x22:Reading tar file core.xml
19:50:36:WU03:FS02:0x22:Reading tar file integrator.xml
19:50:36:WU03:FS02:0x22:Reading tar file state.xml
19:50:36:WU03:FS02:0x22:Reading tar file system.xml
19:50:36:WU03:FS02:0x22:Digital signatures verified
19:50:36:WU03:FS02:0x22:Folding@home GPU Core22 Folding@home Core
19:50:36:WU03:FS02:0x22:Version 0.0.5
19:50:45:WU03:FS02:0x22:Completed 0 out of 1000000 steps (0%)
19:50:45:WU03:FS02:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:50:50:WU01:FS02:Upload 0.19%
19:50:56:WU01:FS02:Upload 0.37%
19:50:58:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
19:51:18:WU03:FS02:0x22:Completed 10000 out of 1000000 steps (1%)
19:51:48:WU01:FS02:Upload 0.56%
19:51:50:WU03:FS02:0x22:Completed 20000 out of 1000000 steps (2%)
19:51:54:WU01:FS02:Upload 25.10%
19:52:00:WU01:FS02:Upload 52.64%
19:52:06:WU01:FS02:Upload 79.24%
19:52:10:WU01:FS02:Upload complete
19:52:10:WU01:FS02:Server responded WORK_ACK (400)
19:52:10:WU01:FS02:Final credit estimate, 61832.00 points
19:52:10:WU01:FS02:Cleaning up
19:52:24:WU03:FS02:0x22:Completed 30000 out of 1000000 steps (3%)
19:52:56:WU03:FS02:0x22:Completed 40000 out of 1000000 steps (4%)
19:53:27:WU03:FS02:0x22:Completed 50000 out of 1000000 steps (5%)
19:53:58:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
19:54:00:WU03:FS02:0x22:Completed 60000 out of 1000000 steps (6%)
19:54:32:WU03:FS02:0x22:Completed 70000 out of 1000000 steps (7%)
19:55:04:WU03:FS02:0x22:Completed 80000 out of 1000000 steps (8%)
19:55:37:WU03:FS02:0x22:Completed 90000 out of 1000000 steps (9%)
19:56:10:WU03:FS02:0x22:Completed 100000 out of 1000000 steps (10%)
19:56:40:WU03:FS02:0x22:Completed 110000 out of 1000000 steps (11%)
19:56:58:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
19:57:12:WU03:FS02:0x22:Completed 120000 out of 1000000 steps (12%)
19:57:44:WU03:FS02:0x22:Completed 130000 out of 1000000 steps (13%)
19:58:16:WU03:FS02:0x22:Completed 140000 out of 1000000 steps (14%)
19:58:47:WU03:FS02:0x22:Completed 150000 out of 1000000 steps (15%)
19:59:20:WU03:FS02:0x22:Completed 160000 out of 1000000 steps (16%)
19:59:51:WU03:FS02:0x22:Completed 170000 out of 1000000 steps (17%)
19:59:53:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
20:00:22:WU03:FS02:0x22:Completed 180000 out of 1000000 steps (18%)
20:00:52:WU03:FS02:0x22:Completed 190000 out of 1000000 steps (19%)
20:01:22:WU03:FS02:0x22:Completed 200000 out of 1000000 steps (20%)
20:01:53:WU03:FS02:0x22:Completed 210000 out of 1000000 steps (21%)
20:02:26:WU03:FS02:0x22:Completed 220000 out of 1000000 steps (22%)
20:02:44:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
20:02:58:WU03:FS02:0x22:Completed 230000 out of 1000000 steps (23%)
20:03:31:WU03:FS02:0x22:Completed 240000 out of 1000000 steps (24%)
20:04:05:WU03:FS02:0x22:Completed 250000 out of 1000000 steps (25%)
20:04:42:WU03:FS02:0x22:Completed 260000 out of 1000000 steps (26%)
20:05:18:WU03:FS02:0x22:Completed 270000 out of 1000000 steps (27%)
20:05:42:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
20:05:53:WU03:FS02:0x22:Completed 280000 out of 1000000 steps (28%)
20:06:28:WU03:FS02:0x22:Completed 290000 out of 1000000 steps (29%)
20:07:03:WU03:FS02:0x22:Completed 300000 out of 1000000 steps (30%)
20:07:39:WU03:FS02:0x22:Completed 310000 out of 1000000 steps (31%)
20:08:14:WU03:FS02:0x22:Completed 320000 out of 1000000 steps (32%)
20:08:28:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
20:08:52:WU03:FS02:0x22:Completed 330000 out of 1000000 steps (33%)
20:09:30:WU03:FS02:0x22:Completed 340000 out of 1000000 steps (34%)
20:10:08:WU03:FS02:0x22:Completed 350000 out of 1000000 steps (35%)
20:10:46:WU03:FS02:0x22:Completed 360000 out of 1000000 steps (36%)
20:11:24:WU03:FS02:0x22:Completed 370000 out of 1000000 steps (37%)
20:11:36:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
20:12:02:WU03:FS02:0x22:Completed 380000 out of 1000000 steps (38%)
20:12:41:WU03:FS02:0x22:Completed 390000 out of 1000000 steps (39%)
20:13:19:WU03:FS02:0x22:Completed 400000 out of 1000000 steps (40%)
20:13:58:WU03:FS02:0x22:Completed 410000 out of 1000000 steps (41%)
20:14:36:WU03:FS02:0x22:Completed 420000 out of 1000000 steps (42%)
20:14:51:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
20:15:13:WU03:FS02:0x22:Completed 430000 out of 1000000 steps (43%)
20:15:48:WU03:FS02:0x22:Completed 440000 out of 1000000 steps (44%)
20:16:24:WU03:FS02:0x22:Completed 450000 out of 1000000 steps (45%)
20:17:00:WU03:FS02:0x22:Completed 460000 out of 1000000 steps (46%)
20:17:37:WU03:FS02:0x22:Completed 470000 out of 1000000 steps (47%)
20:17:41:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
20:18:14:WU03:FS02:0x22:Completed 480000 out of 1000000 steps (48%)
20:18:50:WU03:FS02:0x22:Completed 490000 out of 1000000 steps (49%)
20:19:25:WU03:FS02:0x22:Completed 500000 out of 1000000 steps (50%)
20:19:56:WU03:FS02:0x22:Completed 510000 out of 1000000 steps (51%)
20:20:26:WU03:FS02:0x22:Completed 520000 out of 1000000 steps (52%)
20:20:32:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
20:20:56:WU03:FS02:0x22:Completed 530000 out of 1000000 steps (53%)
20:21:26:WU03:FS02:0x22:Completed 540000 out of 1000000 steps (54%)
20:21:56:WU03:FS02:0x22:Completed 550000 out of 1000000 steps (55%)
20:22:27:WU03:FS02:0x22:Completed 560000 out of 1000000 steps (56%)
20:22:57:WU03:FS02:0x22:Completed 570000 out of 1000000 steps (57%)
20:23:15:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
20:23:27:WU03:FS02:0x22:Completed 580000 out of 1000000 steps (58%)
20:23:57:WU03:FS02:0x22:Completed 590000 out of 1000000 steps (59%)
20:24:28:WU03:FS02:0x22:Completed 600000 out of 1000000 steps (60%)
20:24:58:WU03:FS02:0x22:Completed 610000 out of 1000000 steps (61%)
20:25:28:WU03:FS02:0x22:Completed 620000 out of 1000000 steps (62%)
20:25:58:WU03:FS02:0x22:Completed 630000 out of 1000000 steps (63%)
20:25:59:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
20:26:28:WU03:FS02:0x22:Completed 640000 out of 1000000 steps (64%)
20:26:59:WU03:FS02:0x22:Completed 650000 out of 1000000 steps (65%)
20:27:30:WU03:FS02:0x22:Completed 660000 out of 1000000 steps (66%)
20:28:01:WU03:FS02:0x22:Completed 670000 out of 1000000 steps (67%)
20:28:32:WU03:FS02:0x22:Completed 680000 out of 1000000 steps (68%)
bollix47
Post by bollix47 »
I've seen the same behaviour on a desktop with an onboard 630 & two discreet GPUs whenever there's a brownout.
Basically, the 630 is disabled & the two GPUs are GPU0 & GPU1. However, after the reboot caused by the brownout GPU0, a 2060, is replaced by the 630 and of course crashes the WU and cannot get another. I usually need to do a complete shutdown & start up (ie not a reboot) before I can sort out the mess and get FAH to go back to normal.
The anomoly has only started happening since the release of 7.6. Here's a log showing the client's setup. As long as there's no brownout everything works fine.
*********************** Log Started 2020-06-01T14:29:57Z ***********************
14:29:57:Trying to access database...
14:29:57:Successfully acquired database lock
14:29:57:Read GPUs.txt
14:29:58:Enabled folding slot 00: PAUSED gpu:0:TU106 [Geforce RTX 2060] (by user)
14:29:58:Enabled folding slot 01: PAUSED gpu:1:GP106 [GeForce GTX 1060 6GB] 4372 (by user)
14:29:58:****************************** FAHClient ******************************
14:29:58:        Version: 7.6.13
14:29:58:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:29:58:      Copyright: 2020 foldingathome.org
14:29:58:       Homepage: https://foldingathome.org/
14:29:58:           Date: Apr 27 2020
14:29:58:           Time: 21:21:01
14:29:58:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
14:29:58:         Branch: master
14:29:58:       Compiler: Visual C++ 2008
14:29:58:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:29:58:       Platform: win32 10
14:29:58:           Bits: 32
14:29:58:           Mode: Release
14:29:58:         Config: C:\Users\bolli\AppData\Roaming\FAHClient\config.xml
14:29:58:******************************** CBang ********************************
14:29:58:           Date: Apr 24 2020
14:29:58:           Time: 17:07:55
14:29:58:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
14:29:58:           Bits: 32
14:29:58:******************************* System ********************************
14:29:58:            CPU: Intel(R) Core(TM) i5-7600K CPU @ 3.80GHz
14:29:58:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
14:29:58:           CPUs: 4
14:29:58:         Memory: 7.87GiB
14:29:58:    Free Memory: 4.98GiB
14:29:58:        Threads: WINDOWS_THREADS
14:29:58:     OS Version: 6.2
14:29:58:    Has Battery: false
14:29:58:     On Battery: false
14:29:58:     UTC Offset: -4
14:29:58:            PID: 9440
14:29:58:            CWD: C:\Users\bolli\AppData\Roaming\FAHClient
14:29:58:  Win32 Service: false
14:29:58:             OS: Windows 10 Enterprise
14:29:58:        OS Arch: AMD64
14:29:58:           GPUs: 2
14:29:58:          GPU 0: Bus:2 Slot:0 Func:0 NVIDIA:7 TU106 [Geforce RTX 2060]
14:29:58:          GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 6GB] 4372
14:29:58:  CUDA Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:7.5 Driver:11.0
14:29:58:  CUDA Device 1: Platform:0 Device:1 Bus:1 Slot:0 Compute:6.1 Driver:11.0
14:29:58:OpenCL Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:1.2 Driver:445.75
14:29:58:OpenCL Device 1: Platform:0 Device:1 Bus:1 Slot:0 Compute:1.2 Driver:445.75
14:29:58:OpenCL Device 2: Platform:1 Device:0 Bus:2 Slot:0 Compute:1.2 Driver:445.75
14:29:58:OpenCL Device 3: Platform:1 Device:1 Bus:1 Slot:0 Compute:1.2 Driver:445.75
14:29:58:******************************* libFAH ********************************
14:29:58:           Date: Apr 15 2020
14:29:58:           Time: 14:53:14
14:29:58:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
14:29:58:           Bits: 32
14:29:58:***********************************************************************
14:29:58:<config>
14:29:58:  <!-- Folding Core -->
14:29:58:  <checkpoint v='30'/>
14:29:58:  <core-priority v='low'/>
14:29:58:
14:29:58:  <!-- HTTP Server -->
14:29:58:  <allow v='127.0.0.1,192.168.2.100-192.168.2.149'/>
14:29:58:
14:29:58:  <!-- Network -->
14:29:58:  <proxy v=':8080'/>
14:29:58:
14:29:58:  <!-- Remote Command Server -->
14:29:58:  <command-allow-no-pass v='127.0.0.1,192.168.2.100-192.168.2.149'/>
14:29:58:
14:29:58:  <!-- Slot Control -->
14:29:58:  <power v='full'/>
14:29:58:
14:29:58:  <!-- User Information -->
14:29:58:  <passkey v='*****'/>
14:29:58:  <team v='39340'/>
14:29:58:  <user v='bollix47'/>
14:29:58:
14:29:58:  <!-- Folding Slots -->
14:29:58:  <slot id='0' type='GPU'>
14:29:58:    <paused v='true'/>
14:29:58:  </slot>
14:29:58:  <slot id='1' type='GPU'>
14:29:58:  </slot>
14:29:58:</config>
Konadreamer
bruce wrote:According to my information, the UHD 630 is NOt supported by FAH.
So, here's the solution I've decided to employ. I'm letting the UHD 630 slot stay active. This allows the GTX 1070 to stop from being deleted whenever I close and restart the FAH client. So now with the GTX 1070 slot being persistent, then I'm just starting the FAH client and then selecting the UHD 630 slot and pausing it. Everything works normally if I do it this way.
Now here's the funny thing. You say that the UHD 630 isn't even a supported GPU. But if I start it and let it run, it pulls a WU and works on it. Not sure how to explain that.
Konadreamer wrote:...I'm letting the UHD 630 slot stay active. This allows the GTX 1070 to stop from being deleted whenever I close and restart the FAH client. So now with the GTX 1070 slot being persistent, then I'm just starting the FAH client and then selecting the UHD 630 slot and pausing it. Everything works normally if I do it this way...
I would suggest that you enter this for the iGPU Slot:
<pause-on-start v='true'/>
That way, you don't have to pause it when rebooting the system and it becomes easy to maintain.
Also, the WU that your iGPU downloads, it is actually a CPU WU as that is what we have observed in few cases here. It has been reported here: https://github.com/FoldingAtHome/fah-issues/issues/1434
Konadreamer
I appreciate the suggestion and I have added that line for that gpu slot. Thanks for your helpful reply. Now back to folding. :D
anandhanju
Post by anandhanju »
You can "lock" the GPU slot to a particular device using its index.
<gpu-index v='1'/>
</slot>
I am curious to see if the GPU index changes or not when the system switches from the iGPU to the dGPU. That's assuming Konadreamer wants to experiment :)
