Shutting down any local clients
alphacole1105
Post by alphacole1105 »
I am trying to install the folding for the Covid, but it's stuck on "shutting down any local clients", how do I install, i am running as administrator on windows 10
Re: Shutting down any local clients
Welcome to the F@H Forum alphacole1105,
Generally speaking, that happens when you already have an existing installation of the client. If that's the case, can you please post the log file? Ensure you include the first 100 lines which will inform us of what the system configuration is and what the client settings are. If you require guidance, please view this topic: viewtopic.php?f=24&t=26036
alphacole1105
I have on the console local updating inactive...and can't generate a log but have
*********************** Log Started 2020-06-02T12:03:53Z ***********************
12:03:53:Trying to access database...
12:03:54:Successfully acquired database lock
12:03:54:Downloading GPUs.txt from assign1.foldingathome.org:80
12:03:54:Connecting to assign1.foldingathome.org:80
12:03:54:Read GPUs.txt
12:03:54:Enabled folding slot 00: PAUSED cpu:3 (not configured)
Is there any additional text in the log.txt file or was that all?
alphacole1105
that's all I have..
Humm... the fact that it says not configured means that it is waiting to be configured. Previously, it would wait for 5 minutes before automatically folding anonymously. Can you open up Advanced Control (AKA FAHControl)? What happens when you visit this site: https://client.foldingathome.org/ It should open up Web Control.
alphacole1105
"Connecting to your Folding@home client
Need help?
Is Folding@home installed?
Is Folding@home running?
Try reloading this page.
Try connecting directly.
More help."
That's what is on the webpage.
Post by Neil-B »
That link would normally open the web console for you … Not a scenario I have come across before - my gut instinct is that there is something blocking your connection - maybe AV/Firewall/Proxy/Windows Defender? or even an issue with where the installation has been completed?
In Win 10 the FAH folders should be in the C:\Users\******\AppData\Roaming\FAHClient folder (where ****** is you logged on user name) … The current log should be there and past logs (upto last 16 by default) should be in a sub folder called … If you have had any connections to date that should show somewhere in the current or past logs - details of your system config might show in those along the lines of:
*********************** Log Started 2020-05-14T07:03:19Z ***********************
07:03:19:Trying to access database...
07:03:19:Successfully acquired database lock
07:03:19:Read GPUs.txt
07:03:20:Enabled folding slot 00: PAUSED cpu:6 (by user)
07:03:21:****************************** FAHClient ******************************
07:03:21:        Version: 7.6.13
07:03:21:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:03:21:      Copyright: 2020 foldingathome.org
07:03:21:       Homepage: https://foldingathome.org/
07:03:21:           Date: Apr 27 2020
07:03:21:           Time: 21:21:01
07:03:21:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
07:03:21:         Branch: master
07:03:21:       Compiler: Visual C++ 2008
07:03:21:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:03:21:       Platform: win32 10
07:03:21:           Bits: 32
07:03:21:           Mode: Release
07:03:21:         Config: C:\Users\Innov\AppData\Roaming\FAHClient\config.xml
07:03:21:******************************** CBang ********************************
07:03:21:           Date: Apr 24 2020
07:03:21:           Time: 17:07:55
07:03:21:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
07:03:21:           Bits: 32
07:03:21:******************************* System ********************************
07:03:21:            CPU: Intel(R) Xeon(R) CPU E3-1505M v5 @ 2.80GHz
07:03:21:         CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
07:03:21:           CPUs: 8
07:03:21:         Memory: 31.86GiB
07:03:21:    Free Memory: 27.31GiB
07:03:21:        Threads: WINDOWS_THREADS
07:03:21:     OS Version: 6.2
07:03:21:    Has Battery: true
07:03:21:     On Battery: false
07:03:21:     UTC Offset: 1
07:03:21:            PID: 10356
07:03:21:            CWD: C:\Users\Innov\AppData\Roaming\FAHClient
07:03:21:  Win32 Service: false
07:03:21:             OS: Windows 10 Enterprise
07:03:21:        OS Arch: AMD64
07:03:21:           GPUs: 1
07:03:21:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:4 GM107GLM [Quadro M1000M]
07:03:21:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.0 Driver:10.2
07:03:21:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.74
07:03:21:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
07:03:21:******************************* libFAH ********************************
07:03:21:           Date: Apr 15 2020
07:03:21:           Time: 14:53:14
07:03:21:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
07:03:21:           Bits: 32
07:03:21:***********************************************************************
07:03:21:<config>
07:03:21:  <!-- Logging -->
07:03:21:  <log-rotate-max v='99'/>
07:03:21:
07:03:21:  <!-- Network -->
07:03:21:  <proxy v=':8080'/>
07:03:21:
07:03:21:  <!-- Slot Control -->
07:03:21:  <power v='full'/>
07:03:21:
07:03:21:  <!-- User Information -->
07:03:21:  <passkey v='*****'/>
07:03:21:  <team v='39363'/>
07:03:21:  <user v='Gob-S'/>
07:03:21:
07:03:21:  <!-- Folding Slots -->
07:03:21:  <slot id='0' type='CPU'>
07:03:21:    <client-type v='beta'/>
07:03:21:    <cpus v='6'/>
07:03:21:    <pause-on-start v='true'/>
07:03:21:  </slot>
07:03:21:</config>
******************************* Date: 2020-05-18 *******************************
12:36:39:FS00:Unpaused
12:36:39:WU00:FS00:Connecting to assign1.foldingathome.org:80
12:36:40:WU00:FS00:Assigned to work server 128.252.203.1
12:36:40:WU00:FS00:Requesting new work unit for slot 00: READY cpu:6 from 128.252.203.1
12:36:40:WU00:FS00:Connecting to 128.252.203.1:8080
12:36:40:WU00:FS00:Downloading 5.82MiB
12:36:46:WU00:FS00:Download 17.20%
Something like this will help if you find it … If you don't it may be that the Client has never connected which would support the AV/Firewall/Proxy/Windows Defender possibility.
Another thought … When setting up did you adjust remote access config at all? … iirc (dim past) you need to ensure 127.0.0.1 is allowed in both options.
FAH's main website was offline briefly last night. I'll bet it works correctly after that was fixed.
alphacole1105
*********************** Log Started 2020-06-06T10:57:18Z ***********************
10:57:18:Trying to access database...
10:57:18:Successfully acquired database lock
10:57:18:Downloading GPUs.txt from assign1.foldingathome.org:80
10:57:18:Connecting to assign1.foldingathome.org:80
10:57:19:Read GPUs.txt
10:57:19:Enabled folding slot 00: PAUSED cpu:3 (not configured)
alphacole1105
Downloaded and working on older computer, but not newer acer?
FAH can be installed on Acer computers. Unfortunately we can't guess what your problem is unless you post the first couple of pages of FAH's log.
alphacole1105
The log I posted is the only log, the other log folder is empty...I can run it on a different home built machine with no problem...
