Project: 16448 WU Status: "Error: Project not found"
Tashgan
Post by Tashgan »
Yesterday i got and sucesssfully finished these two WUs from the Project 16448:
Project: 16448 (Run 0, Clone 2023, Gen 10)
Project: 16448 (Run 0, Clone 91, Gen 7)
Until now i got no points for them and if i check the WU Status i only get the Message "Error: Project not found".
The Logfiles shows nothing suspicious:
09:25:24:WU01:FS01:Connecting to assign1.foldingathome.org:80
09:25:24:WU01:FS01:Assigned to work server 66.170.111.50
09:25:24:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:TU104 [GeForce RTX 2080 Super] from 66.170.111.50
09:25:24:WU01:FS01:Connecting to 66.170.111.50:8080
09:25:30:WU01:FS01:Downloading 22.41MiB
09:25:36:WU01:FS01:Download 29.84%
09:25:42:WU01:FS01:Download 70.83%
09:25:46:WU01:FS01:Download complete
09:25:46:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16448 run:0 clone:2023 gen:10 core:0x22 unit:0x0000001142aa6f325ed18ce2177c4713
09:27:06:WU01:FS01:Starting
09:27:06:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Markus\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 3004 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:27:06:WU01:FS01:Started FahCore on PID 14124
09:27:06:WU01:FS01:Core PID:18048
09:27:06:WU01:FS01:FahCore 0x22 started
09:27:07:WU01:FS01:0x22:*********************** Log Started 2020-05-31T09:27:07Z ***********************
09:27:07:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
09:27:07:WU01:FS01:0x22:       Type: 0x22
09:27:07:WU01:FS01:0x22:       Core: Core22
09:27:07:WU01:FS01:0x22:    Website: https://foldingathome.org/
09:27:07:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
09:27:07:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
09:27:07:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
09:27:07:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 14124 -checkpoint 15
09:27:07:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
09:27:07:WU01:FS01:0x22:             0 -gpu 0
09:27:07:WU01:FS01:0x22:     Config: <none>
09:27:07:WU01:FS01:0x22:************************************ Build *************************************
09:27:07:WU01:FS01:0x22:    Version: 0.0.5
09:27:07:WU01:FS01:0x22:       Date: Apr 22 2020
09:27:07:WU01:FS01:0x22:       Time: 04:42:59
09:27:07:WU01:FS01:0x22: Repository: Git
09:27:07:WU01:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
09:27:07:WU01:FS01:0x22:     Branch: HEAD
09:27:07:WU01:FS01:0x22:   Compiler: Visual C++ 2008
09:27:07:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:27:07:WU01:FS01:0x22:   Platform: win32 10
09:27:07:WU01:FS01:0x22:       Bits: 64
09:27:07:WU01:FS01:0x22:       Mode: Release
09:27:07:WU01:FS01:0x22:************************************ System ************************************
09:27:07:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
09:27:07:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
09:27:07:WU01:FS01:0x22:       CPUs: 8
09:27:07:WU01:FS01:0x22:     Memory: 31.94GiB
09:27:07:WU01:FS01:0x22:Free Memory: 23.22GiB
09:27:07:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
09:27:07:WU01:FS01:0x22: OS Version: 6.2
09:27:07:WU01:FS01:0x22:Has Battery: false
09:27:07:WU01:FS01:0x22: On Battery: false
09:27:07:WU01:FS01:0x22: UTC Offset: 2
09:27:07:WU01:FS01:0x22:        PID: 18048
09:27:07:WU01:FS01:0x22:        CWD: C:\Users\Markus\AppData\Roaming\FAHClient\work
09:27:07:WU01:FS01:0x22:         OS: Windows 10 Pro
09:27:07:WU01:FS01:0x22:    OS Arch: AMD64
09:27:07:WU01:FS01:0x22:********************************************************************************
09:27:07:WU01:FS01:0x22:Project: 16448 (Run 0, Clone 2023, Gen 10)
09:27:07:WU01:FS01:0x22:Unit: 0x0000001142aa6f325ed18ce2177c4713
09:27:07:WU01:FS01:0x22:Reading tar file core.xml
09:27:07:WU01:FS01:0x22:Reading tar file integrator.xml
09:27:07:WU01:FS01:0x22:Reading tar file state.xml
09:27:07:WU01:FS01:0x22:Reading tar file system.xml
09:27:08:WU01:FS01:0x22:Digital signatures verified
09:27:08:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
09:27:08:WU01:FS01:0x22:Version 0.0.5
09:27:26:WU01:FS01:0x22:Completed 0 out of 600000 steps (0%)
09:27:26:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
09:28:08:WU01:FS01:0x22:Completed 6000 out of 600000 steps (1%)
09:28:50:WU01:FS01:0x22:Completed 12000 out of 600000 steps (2%)
09:29:32:WU01:FS01:0x22:Completed 18000 out of 600000 steps (3%)
10:37:39:WU01:FS01:0x22:Completed 588000 out of 600000 steps (98%)
10:38:21:WU01:FS01:0x22:Completed 594000 out of 600000 steps (99%)
10:39:02:WU01:FS01:0x22:Completed 600000 out of 600000 steps (100%)
10:39:07:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
10:39:07:WU01:FS01:0x22:Saving result file checkpointState.xml
10:39:10:WU01:FS01:0x22:Saving result file checkpt.crc
10:39:10:WU01:FS01:0x22:Saving result file positions.xtc
10:39:11:WU01:FS01:0x22:Saving result file science.log
10:39:11:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
10:39:11:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
10:39:11:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:16448 run:0 clone:2023 gen:10 core:0x22 unit:0x0000001142aa6f325ed18ce2177c4713
10:39:11:WU01:FS01:Uploading 42.37MiB to 66.170.111.50
10:39:11:WU01:FS01:Connecting to 66.170.111.50:8080
10:39:17:WU01:FS01:Upload 3.84%
10:39:23:WU01:FS01:Upload 8.56%
10:39:29:WU01:FS01:Upload 13.28%
10:41:11:WU01:FS01:Upload 91.75%
10:41:17:WU01:FS01:Upload 96.32%
10:41:22:WU01:FS01:Upload complete
10:41:22:WU01:FS01:Server responded WORK_ACK (400)
10:41:22:WU01:FS01:Final credit estimate, 109486.00 points
10:41:23:WU01:FS01:Cleaning up
19:39:17:WU00:FS01:Connecting to assign1.foldingathome.org:80
19:39:17:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:39:17:WU00:FS01:Connecting to assign2.foldingathome.org:80
19:39:18:WU00:FS01:Assigned to work server 66.170.111.50
19:39:18:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:TU104 [GeForce RTX 2080 Super] from 66.170.111.50
19:39:18:WU00:FS01:Connecting to 66.170.111.50:8080
19:39:24:WU00:FS01:Downloading 22.41MiB
19:39:30:WU00:FS01:Download 32.91%
19:39:36:WU00:FS01:Download 75.01%
19:39:39:WU00:FS01:Download complete
19:39:39:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16448 run:0 clone:91 gen:7 core:0x22 unit:0x0000000a42aa6f325ed18ce3ea2e352f
19:40:02:WU00:FS01:Starting
19:40:02:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Markus\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 6628 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
19:40:02:WU00:FS01:Started FahCore on PID 8328
19:40:02:WU00:FS01:Core PID:15304
19:40:02:WU00:FS01:FahCore 0x22 started
19:40:02:WU00:FS01:0x22:*********************** Log Started 2020-05-31T19:40:02Z ***********************
19:40:02:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
19:40:02:WU00:FS01:0x22:       Type: 0x22
19:40:02:WU00:FS01:0x22:       Core: Core22
19:40:02:WU00:FS01:0x22:    Website: https://foldingathome.org/
19:40:02:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
19:40:02:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
19:40:02:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
19:40:02:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8328 -checkpoint 15
19:40:02:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
19:40:02:WU00:FS01:0x22:             0 -gpu 0
19:40:02:WU00:FS01:0x22:     Config: <none>
19:40:02:WU00:FS01:0x22:************************************ Build *************************************
19:40:02:WU00:FS01:0x22:    Version: 0.0.5
19:40:02:WU00:FS01:0x22:       Date: Apr 22 2020
19:40:02:WU00:FS01:0x22:       Time: 04:42:59
19:40:02:WU00:FS01:0x22: Repository: Git
19:40:02:WU00:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
19:40:02:WU00:FS01:0x22:     Branch: HEAD
19:40:02:WU00:FS01:0x22:   Compiler: Visual C++ 2008
19:40:02:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:40:02:WU00:FS01:0x22:   Platform: win32 10
19:40:02:WU00:FS01:0x22:       Bits: 64
19:40:02:WU00:FS01:0x22:       Mode: Release
19:40:02:WU00:FS01:0x22:************************************ System ************************************
19:40:02:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
19:40:02:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
19:40:02:WU00:FS01:0x22:       CPUs: 8
19:40:02:WU00:FS01:0x22:     Memory: 31.94GiB
19:40:02:WU00:FS01:0x22:Free Memory: 26.81GiB
19:40:02:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
19:40:02:WU00:FS01:0x22: OS Version: 6.2
19:40:02:WU00:FS01:0x22:Has Battery: false
19:40:02:WU00:FS01:0x22: On Battery: false
19:40:02:WU00:FS01:0x22: UTC Offset: 2
19:40:02:WU00:FS01:0x22:        PID: 15304
19:40:02:WU00:FS01:0x22:        CWD: C:\Users\Markus\AppData\Roaming\FAHClient\work
19:40:02:WU00:FS01:0x22:         OS: Windows 10 Pro
19:40:02:WU00:FS01:0x22:    OS Arch: AMD64
19:40:02:WU00:FS01:0x22:********************************************************************************
19:40:02:WU00:FS01:0x22:Project: 16448 (Run 0, Clone 91, Gen 7)
19:40:02:WU00:FS01:0x22:Unit: 0x0000000a42aa6f325ed18ce3ea2e352f
19:40:02:WU00:FS01:0x22:Reading tar file core.xml
19:40:02:WU00:FS01:0x22:Reading tar file integrator.xml
19:40:02:WU00:FS01:0x22:Reading tar file state.xml
19:40:02:WU00:FS01:0x22:Reading tar file system.xml
19:40:03:WU00:FS01:0x22:Digital signatures verified
19:40:03:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:40:03:WU00:FS01:0x22:Version 0.0.5
19:40:20:WU00:FS01:0x22:Completed 0 out of 600000 steps (0%)
19:40:20:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:41:03:WU00:FS01:0x22:Completed 6000 out of 600000 steps (1%)
19:41:45:WU00:FS01:0x22:Completed 12000 out of 600000 steps (2%)
19:42:27:WU00:FS01:0x22:Completed 18000 out of 600000 steps (3%)
20:50:50:WU00:FS01:0x22:Completed 588000 out of 600000 steps (98%)
20:51:31:WU00:FS01:0x22:Completed 594000 out of 600000 steps (99%)
20:52:12:WU00:FS01:0x22:Completed 600000 out of 600000 steps (100%)
20:52:17:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
20:52:17:WU00:FS01:0x22:Saving result file checkpointState.xml
20:52:20:WU00:FS01:0x22:Saving result file checkpt.crc
20:52:20:WU00:FS01:0x22:Saving result file positions.xtc
20:52:21:WU00:FS01:0x22:Saving result file science.log
20:52:21:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
20:52:21:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:52:22:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:16448 run:0 clone:91 gen:7 core:0x22 unit:0x0000000a42aa6f325ed18ce3ea2e352f
20:52:22:WU00:FS01:Uploading 42.37MiB to 66.170.111.50
20:52:22:WU00:FS01:Connecting to 66.170.111.50:8080
20:52:28:WU00:FS01:Upload 4.57%
20:52:34:WU00:FS01:Upload 9.15%
20:52:40:WU00:FS01:Upload 13.72%
20:54:22:WU00:FS01:Upload 92.48%
20:54:28:WU00:FS01:Upload 97.06%
20:54:33:WU00:FS01:Upload complete
20:54:33:WU00:FS01:Server responded WORK_ACK (400)
20:54:33:WU00:FS01:Final credit estimate, 110006.00 points
20:54:33:WU00:FS01:Cleaning up
Re: Project: 16448 WU Status: "Error: Project not found"
This project is being run on a new server, so it is possible the connection to update WU stats is not working correctly. I will send a message to the person managing the server.
This has been checked into and should be fixed now.
Tashgan
Post by Tashgan »
Thank you for the quick reaction. The WU Status works now and the credit has ben counted. :D
