stats.foldingathome.org stopped updating
LancasterUni
Post by LancasterUni »
Our team stats stopped updating last night: https://stats.foldingathome.org/team/252914. The data is still updating on https://apps.foldingathome.org/teamstat ... 52914.html, but I was capturing the data periodically via stats programmatically for my own logging and analysis. Is there a known issue, or some announcement I've missed?
Thanks
Re: stats.foldingathome.org stopped updating
Post by foldy »
I heard updates of FAH stats page is not real time but once a day. So just look again tomorrow and it should be updated.
Ghasst
Post by Ghasst »
Noticed the same issue today, typically stats are updated within 30 minutes of a WU being completed. I'm not seeing any of my stats updated since last night.
G3WGV
Hardware configuration: A mishmash of systems little and large, ranging from an Udoo X86 Ultra up to a new beast completed 2020-03-25 with a Ryzen 9 3950X CPU & RTX 2070 GPU. F@H seems to like the 2070!
Points not updating on web control?
Post by G3WGV »
Monday morning-itis?
Since about 23:00 GMT last night the "points earned" display on Web Control hasn't updated on any of my clients, nor on my team stats page. WUs are completing and being uploaded and my stats extremeoverclocking.com are updating OK. I tried pausing then restarting the client on one PC but no change. Anyone else seeing this or is it just me struggling with Monday morning-itis?
Mod Edit: Merged multiple topics into one - PantherX
Radio Amateur, light aircraft owner/pilot, computer nerd, mountaineer, organist (sort of) and, now, folder.
neil_en_suite
Stats not updating
Post by neil_en_suite »
Good Morning All,
I have 5 devices folding, 3 Ubuntu dists (elementary, Kubuntu & Mint) plus 2 Win 10s (both with GPUs)
I have noticed since yesterday that the WU stat count hasn't changed since 31st May, approx 6pm GMT.
I think at least 3 or 4 of the 5 devices have completed at least one WU overnight yet I have not seen any change to the WU count.
The FAH Control client is installed on the Win10's but the Ubuntu dists are running as a service, with the browser for control. All have uploaded successfully until now.
I have tested 7.6.13 on one win10 device to see if there is any change and there is not.
I have looked through the logs and unclear if any line indicates an error. I have included the log from one of the W10 machines below.
If someone can give me guidance on where to find the full log on the ubuntu devices I can add the log from the machine I know should have completed a WU also if that would help.
Thanks,
neil
*********************** Log Started 2020-05-30T23:37:34Z ***********************
23:37:34:****************************** FAHClient ******************************
23:37:34:        Version: 7.6.9
23:37:34:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:37:34:      Copyright: 2020 foldingathome.org
23:37:34:       Homepage: https://foldingathome.org/
23:37:34:           Date: Apr 17 2020
23:37:34:           Time: 11:13:06
23:37:34:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
23:37:34:         Branch: master
23:37:34:       Compiler: Visual C++ 2008
23:37:34:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:37:34:       Platform: win32 10
23:37:34:           Bits: 32
23:37:34:           Mode: Release
23:37:34:           Args: --open-web-control
23:37:34:         Config: C:\Users\neil_\AppData\Roaming\FAHClient\config.xml
23:37:34:******************************** CBang ********************************
23:37:34:           Time: 11:10:09
23:37:34:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
23:37:34:           Bits: 32
23:37:34:******************************* System ********************************
23:37:34:            CPU: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
23:37:34:         CPU ID: GenuineIntel Family 6 Model 69 Stepping 1
23:37:34:           CPUs: 4
23:37:34:         Memory: 15.89GiB
23:37:34:    Free Memory: 13.13GiB
23:37:34:        Threads: WINDOWS_THREADS
23:37:34:     OS Version: 6.2
23:37:34:    Has Battery: true
23:37:34:     On Battery: false
23:37:34:     UTC Offset: 1
23:37:34:            PID: 11724
23:37:34:            CWD: C:\Users\neil_\AppData\Roaming\FAHClient
23:37:34:             OS: Windows 10 Home
23:37:34:        OS Arch: AMD64
23:37:34:           GPUs: 1
23:37:34:          GPU 0: Bus:4 Slot:0 Func:0 NVIDIA:3 GK107 [GeForce GT 745M]
23:37:34:  CUDA Device 0: Platform:0 Device:0 Bus:4 Slot:0 Compute:3.0 Driver:9.1
23:37:34:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:1.2 Driver:20.19
23:37:34:OpenCL Device 2: Platform:1 Device:0 Bus:4 Slot:0 Compute:1.2 Driver:388.57
23:37:34:  Win32 Service: false
23:37:34:******************************* libFAH ********************************
23:37:34:           Date: Apr 15 2020
23:37:34:           Time: 14:53:14
23:37:34:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
23:37:34:           Bits: 32
23:37:34:***********************************************************************
23:37:34:<config>
23:37:34:  <!-- Network -->
23:37:34:  <proxy v=':8080'/>
23:37:34:
23:37:34:  <!-- Slot Control -->
23:37:34:  <power v='medium'/>
23:37:34:
23:37:34:  <!-- User Information -->
23:37:34:  <passkey v='*****'/>
23:37:34:  <team v='262280'/>
23:37:34:  <user v='neil_en_suite'/>
23:37:34:
23:37:34:  <!-- Folding Slots -->
23:37:34:  <slot id='0' type='CPU'/>
23:37:34:  <slot id='1' type='GPU'/>
23:37:34:</config>
23:37:34:Trying to access database...
23:37:34:Successfully acquired database lock
23:37:34:Enabled folding slot 00: READY cpu:2
23:37:34:Enabled folding slot 01: READY gpu:0:GK107 [GeForce GT 745M]
23:37:34:WU01:FS01:Starting
23:37:34:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\neil_\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 11724 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
23:37:34:WU01:FS01:Started FahCore on PID 12120
23:37:35:WU01:FS01:Core PID:9400
23:37:35:WU01:FS01:FahCore 0x22 started
23:37:35:WU02:FS00:Starting
23:37:35:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\neil_\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 11724 -checkpoint 15 -np 2
23:37:35:WU02:FS00:Started FahCore on PID 3756
23:37:35:WU02:FS00:Core PID:10880
23:37:35:WU02:FS00:FahCore 0xa7 started
23:37:39:WU02:FS00:0xa7:*********************** Log Started 2020-05-30T23:37:39Z ***********************
23:37:40:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:37:40:WU02:FS00:0xa7:       Type: 0xa7
23:37:40:WU02:FS00:0xa7:       Core: Gromacs
23:37:40:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 3756 -checkpoint 15 -np 2
23:37:40:WU02:FS00:0xa7:************************************ CBang *************************************
23:37:40:WU02:FS00:0xa7:       Date: Oct 26 2019
23:37:40:WU02:FS00:0xa7:       Time: 01:38:25
23:37:40:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:37:40:WU02:FS00:0xa7:     Branch: master
23:37:40:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
23:37:40:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:37:40:WU02:FS00:0xa7:   Platform: win32 10
23:37:41:WU02:FS00:0xa7:       Bits: 64
23:37:41:WU02:FS00:0xa7:       Mode: Release
23:37:41:WU02:FS00:0xa7:************************************ System ************************************
23:37:41:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
23:37:41:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 69 Stepping 1
23:37:41:WU02:FS00:0xa7:       CPUs: 4
23:37:41:WU02:FS00:0xa7:     Memory: 15.89GiB
23:37:41:WU02:FS00:0xa7:Free Memory: 12.50GiB
23:37:41:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
23:37:41:WU02:FS00:0xa7: OS Version: 6.2
23:37:41:WU02:FS00:0xa7:Has Battery: true
23:37:41:WU02:FS00:0xa7: On Battery: false
23:37:41:WU02:FS00:0xa7: UTC Offset: 1
23:37:41:WU02:FS00:0xa7:        PID: 10880
23:37:41:WU02:FS00:0xa7:        CWD: C:\Users\neil_\AppData\Roaming\FAHClient\work
23:37:41:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
23:37:41:WU02:FS00:0xa7:    Version: 0.0.18
23:37:41:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:37:41:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:37:41:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
23:37:41:WU02:FS00:0xa7:       Date: Oct 26 2019
23:37:41:WU02:FS00:0xa7:       Time: 01:52:30
23:37:41:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:37:41:WU02:FS00:0xa7:     Branch: master
23:37:41:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
23:37:41:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:37:41:WU02:FS00:0xa7:   Platform: win32 10
23:37:41:WU02:FS00:0xa7:************************************ Build *************************************
23:37:41:WU02:FS00:0xa7:       SIMD: avx_256
23:37:41:WU02:FS00:0xa7:********************************************************************************
23:37:41:WU02:FS00:0xa7:Project: 14257 (Run 0, Clone 1377, Gen 77)
23:37:41:WU02:FS00:0xa7:Unit: 0x00000056cedfaa925eac9ea988ef5a3c
23:37:41:WU02:FS00:0xa7:Digital signatures verified
23:37:41:WU02:FS00:0xa7:Calling: mdrun -s frame77.tpr -o frame77.trr -x frame77.xtc -cpi state.cpt -cpt 15 -nt 2
23:37:41:WU01:FS01:0x22:*********************** Log Started 2020-05-30T23:37:41Z ***********************
23:37:41:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
23:37:41:WU01:FS01:0x22:       Type: 0x22
23:37:41:WU01:FS01:0x22:       Core: Core22
23:37:41:WU01:FS01:0x22:    Website: https://foldingathome.org/
23:37:41:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
23:37:41:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
23:37:41:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
23:37:41:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 12120 -checkpoint 15
23:37:41:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
23:37:41:WU01:FS01:0x22:             0 -gpu 0
23:37:41:WU01:FS01:0x22:     Config: <none>
23:37:41:WU01:FS01:0x22:************************************ Build *************************************
23:37:41:WU01:FS01:0x22:    Version: 0.0.5
23:37:41:WU01:FS01:0x22:       Date: Apr 22 2020
23:37:41:WU01:FS01:0x22:       Time: 04:42:59
23:37:41:WU01:FS01:0x22: Repository: Git
23:37:41:WU01:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
23:37:41:WU01:FS01:0x22:     Branch: HEAD
23:37:41:WU01:FS01:0x22:   Compiler: Visual C++ 2008
23:37:41:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:37:41:WU01:FS01:0x22:   Platform: win32 10
23:37:42:WU01:FS01:0x22:       Bits: 64
23:37:42:WU01:FS01:0x22:       Mode: Release
23:37:42:WU01:FS01:0x22:************************************ System ************************************
23:37:42:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
23:37:42:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 69 Stepping 1
23:37:42:WU01:FS01:0x22:       CPUs: 4
23:37:42:WU01:FS01:0x22:     Memory: 15.89GiB
23:37:42:WU01:FS01:0x22:Free Memory: 13.13GiB
23:37:42:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
23:37:42:WU01:FS01:0x22: OS Version: 6.2
23:37:42:WU01:FS01:0x22:Has Battery: true
23:37:42:WU01:FS01:0x22: On Battery: false
23:37:42:WU01:FS01:0x22: UTC Offset: 1
23:37:42:WU01:FS01:0x22:        PID: 9400
23:37:42:WU01:FS01:0x22:        CWD: C:\Users\neil_\AppData\Roaming\FAHClient\work
23:37:42:WU01:FS01:0x22:         OS: Windows 10 Home
23:37:42:WU01:FS01:0x22:    OS Arch: AMD64
23:37:42:WU01:FS01:0x22:********************************************************************************
23:37:42:WU01:FS01:0x22:Project: 16434 (Run 553, Clone 0, Gen 57)
23:37:42:WU01:FS01:0x22:Unit: 0x0000004f03854c135e9cbacc046c0e7a
23:37:42:WU01:FS01:0x22:Digital signatures verified
23:37:42:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
23:37:42:WU01:FS01:0x22:Version 0.0.5
23:37:43:WU01:FS01:0x22:  Found a checkpoint file
23:37:43:WU02:FS00:0xa7:Steps: first=19250000 total=250000
23:37:47:WU02:FS00:0xa7:Completed 132642 out of 250000 steps (53%)
23:37:53:10:127.0.0.1:New Web session
23:38:51:WU01:FS01:0x22:Completed 2220000 out of 2500000 steps (88%)
23:38:51:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
23:46:45:WU02:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
23:49:38:WU01:FS01:0x22:Completed 2225000 out of 2500000 steps (89%)
23:55:41:WU02:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
00:04:21:WU02:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
00:13:32:WU02:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
00:22:12:WU02:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
00:30:55:WU02:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
00:39:38:WU02:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
00:43:07:WU01:FS01:0x22:Completed 2250000 out of 2500000 steps (90%)
00:48:17:WU02:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
00:56:56:WU02:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
01:05:36:WU02:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
01:14:16:WU02:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
01:23:02:WU02:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
01:31:40:WU02:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
01:36:31:WU01:FS01:0x22:Completed 2275000 out of 2500000 steps (91%)
01:40:23:WU02:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
01:49:03:WU02:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
01:57:42:WU02:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
02:06:20:WU02:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
02:15:22:WU02:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
02:24:06:WU02:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
02:29:54:WU01:FS01:0x22:Completed 2300000 out of 2500000 steps (92%)
02:32:48:WU02:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
02:41:29:WU02:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
02:50:07:WU02:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
02:58:45:WU02:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
03:08:14:WU02:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
03:16:53:WU02:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
03:23:32:WU01:FS01:0x22:Completed 2325000 out of 2500000 steps (93%)
03:25:31:WU02:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
03:34:06:WU02:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
03:42:46:WU02:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
03:51:23:WU02:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
04:00:02:WU02:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
04:08:39:WU02:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
04:16:53:WU01:FS01:0x22:Completed 2350000 out of 2500000 steps (94%)
04:17:30:WU02:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
04:26:08:WU02:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
04:34:45:WU02:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
04:43:29:WU02:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
04:52:06:WU02:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
05:00:50:WU02:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
05:09:30:WU02:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
05:10:15:WU01:FS01:0x22:Completed 2375000 out of 2500000 steps (95%)
05:18:09:WU02:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
05:26:50:WU02:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
05:35:28:WU02:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
******************************* Date: 2020-05-31 *******************************
05:44:09:WU02:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
05:52:47:WU02:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
06:01:25:WU02:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
06:03:40:WU01:FS01:0x22:Completed 2400000 out of 2500000 steps (96%)
06:10:05:WU02:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
06:19:04:WU02:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
06:19:05:WU00:FS00:Connecting to 65.254.110.245:80
06:19:05:WU00:FS00:Assigned to work server 155.247.164.214
06:19:05:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 155.247.164.214
06:19:05:WU00:FS00:Connecting to 155.247.164.214:8080
06:19:07:WU00:FS00:Downloading 2.84MiB
06:19:07:WU00:FS00:Download complete
06:19:07:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14852 run:392 clone:1 gen:77 core:0xa7 unit:0x000000579bf7a4d65ea103bc5751021c
06:27:51:WU02:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
06:27:56:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
06:27:56:WU02:FS00:0xa7:Saving result file frame77.trr
06:27:56:WU02:FS00:0xa7:Saving result file frame77.xtc
06:27:56:WU02:FS00:0xa7:Saving result file md.log
06:27:56:WU02:FS00:0xa7:Saving result file science.log
06:27:56:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
06:27:56:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:27:56:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14257 run:0 clone:1377 gen:77 core:0xa7 unit:0x00000056cedfaa925eac9ea988ef5a3c
06:27:56:WU02:FS00:Uploading 2.92MiB to 206.223.170.146
06:27:56:WU02:FS00:Connecting to 206.223.170.146:8080
06:27:56:WU00:FS00:Starting
06:27:56:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\neil_\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 11724 -checkpoint 15 -np 2
06:27:56:WU00:FS00:Started FahCore on PID 10744
06:27:56:WU00:FS00:Core PID:13724
06:27:56:WU00:FS00:FahCore 0xa7 started
06:27:57:WU00:FS00:0xa7:*********************** Log Started 2020-05-31T06:27:56Z ***********************
06:27:57:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:27:57:WU00:FS00:0xa7:       Type: 0xa7
06:27:57:WU00:FS00:0xa7:       Core: Gromacs
06:27:57:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10744 -checkpoint 15 -np
06:27:57:WU00:FS00:0xa7:             2
06:27:57:WU00:FS00:0xa7:************************************ CBang *************************************
06:27:57:WU00:FS00:0xa7:       Date: Oct 26 2019
06:27:57:WU00:FS00:0xa7:       Time: 01:38:25
06:27:57:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
06:27:57:WU00:FS00:0xa7:     Branch: master
06:27:57:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
06:27:57:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:27:57:WU00:FS00:0xa7:   Platform: win32 10
06:27:57:WU00:FS00:0xa7:       Bits: 64
06:27:57:WU00:FS00:0xa7:       Mode: Release
06:27:57:WU00:FS00:0xa7:************************************ System ************************************
06:27:57:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
06:27:57:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 69 Stepping 1
06:27:57:WU00:FS00:0xa7:       CPUs: 4
06:27:57:WU00:FS00:0xa7:     Memory: 15.89GiB
06:27:57:WU00:FS00:0xa7:Free Memory: 12.23GiB
06:27:57:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
06:27:57:WU00:FS00:0xa7: OS Version: 6.2
06:27:57:WU00:FS00:0xa7:Has Battery: true
06:27:57:WU00:FS00:0xa7: On Battery: false
06:27:57:WU00:FS00:0xa7: UTC Offset: 1
06:27:57:WU00:FS00:0xa7:        PID: 13724
06:27:57:WU00:FS00:0xa7:        CWD: C:\Users\neil_\AppData\Roaming\FAHClient\work
06:27:57:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
06:27:57:WU00:FS00:0xa7:    Version: 0.0.18
06:27:57:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:27:57:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
06:27:57:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
06:27:57:WU00:FS00:0xa7:       Time: 01:52:30
06:27:57:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
06:27:57:WU00:FS00:0xa7:************************************ Build *************************************
06:27:57:WU00:FS00:0xa7:       SIMD: avx_256
06:27:57:WU00:FS00:0xa7:********************************************************************************
06:27:57:WU00:FS00:0xa7:Project: 14852 (Run 392, Clone 1, Gen 77)
06:27:57:WU00:FS00:0xa7:Unit: 0x000000579bf7a4d65ea103bc5751021c
06:27:57:WU00:FS00:0xa7:Reading tar file core.xml
06:27:57:WU00:FS00:0xa7:Reading tar file frame77.tpr
06:27:57:WU00:FS00:0xa7:Digital signatures verified
06:27:57:WU00:FS00:0xa7:Calling: mdrun -s frame77.tpr -o frame77.trr -cpt 15 -nt 2
06:27:57:WU00:FS00:0xa7:Steps: first=0 total=250000
06:28:01:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
06:28:03:WU02:FS00:Upload complete
06:28:03:WU02:FS00:Server responded WORK_ACK (400)
06:28:03:WU02:FS00:Final credit estimate, 1531.00 points
06:28:03:WU02:FS00:Cleaning up
06:39:22:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
06:50:47:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
06:57:17:WU01:FS01:0x22:Completed 2425000 out of 2500000 steps (97%)
07:02:06:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
07:13:29:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
07:24:44:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
07:35:55:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
07:47:20:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
07:50:40:WU01:FS01:0x22:Completed 2450000 out of 2500000 steps (98%)
07:58:42:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
08:10:07:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
08:21:49:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
08:33:17:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
08:44:06:WU01:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
08:44:06:WU02:FS01:Connecting to 65.254.110.245:80
08:44:06:WU02:FS01:Assigned to work server 140.163.4.231
08:44:06:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GK107 [GeForce GT 745M] from 140.163.4.231
08:44:06:WU02:FS01:Connecting to 140.163.4.231:8080
08:44:28:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
08:44:28:WU02:FS01:Connecting to 140.163.4.231:80
08:44:47:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
08:45:37:ERROR:WU02:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
08:45:38:WU02:FS01:Connecting to 65.254.110.245:80
08:45:38:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
08:45:38:WU02:FS01:Connecting to 18.218.241.186:80
08:45:38:WU02:FS01:Assigned to work server 128.252.203.10
08:45:38:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GK107 [GeForce GT 745M] from 128.252.203.10
08:45:38:WU02:FS01:Connecting to 128.252.203.10:8080
08:45:59:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
08:45:59:WU02:FS01:Connecting to 128.252.203.10:80
08:46:21:ERROR:WU02:FS01:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:46:38:WU02:FS01:Connecting to 65.254.110.245:80
08:46:38:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
08:46:38:WU02:FS01:Connecting to 18.218.241.186:80
08:46:38:WU02:FS01:Assigned to work server 140.163.4.231
08:46:38:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GK107 [GeForce GT 745M] from 140.163.4.231
08:46:38:WU02:FS01:Connecting to 140.163.4.231:8080
08:47:02:ERROR:WU02:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
08:48:15:WU02:FS01:Connecting to 65.254.110.245:80
08:48:15:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
08:48:15:WU02:FS01:Connecting to 18.218.241.186:80
08:48:15:WU02:FS01:Assigned to work server 3.133.76.19
08:48:15:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GK107 [GeForce GT 745M] from 3.133.76.19
08:48:15:WU02:FS01:Connecting to 3.133.76.19:8080
08:49:33:WU02:FS01:Downloading 19.29MiB
08:49:39:WU02:FS01:Download 74.52%
08:49:40:WU02:FS01:Download complete
08:49:40:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14462 run:0 clone:847 gen:16 core:0x22 unit:0x0000001d03854c135eb39e42d4462783
08:56:05:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
09:07:28:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
09:18:56:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
09:30:24:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
09:37:27:WU01:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
09:37:43:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
09:37:43:WU01:FS01:0x22:Saving result file checkpointState.xml
09:37:48:WU01:FS01:0x22:Saving result file checkpt.crc
09:37:48:WU01:FS01:0x22:Saving result file positions.xtc
09:37:57:WU01:FS01:0x22:Saving result file science.log
09:37:57:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
09:37:58:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:37:58:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:16434 run:553 clone:0 gen:57 core:0x22 unit:0x0000004f03854c135e9cbacc046c0e7a
09:37:58:WU01:FS01:Uploading 80.77MiB to 3.133.76.19
09:37:58:WU01:FS01:Connecting to 3.133.76.19:8080
09:37:59:WU02:FS01:Starting
09:37:59:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\neil_\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 11724 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
09:37:59:WU02:FS01:Started FahCore on PID 4640
09:37:59:WU02:FS01:Core PID:7148
09:37:59:WU02:FS01:FahCore 0x22 started
09:37:59:WU02:FS01:0x22:*********************** Log Started 2020-05-31T09:37:59Z ***********************
09:37:59:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
09:37:59:WU02:FS01:0x22:       Type: 0x22
09:37:59:WU02:FS01:0x22:       Core: Core22
09:37:59:WU02:FS01:0x22:    Website: https://foldingathome.org/
09:37:59:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
09:37:59:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
09:37:59:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
09:37:59:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 4640 -checkpoint 15
09:37:59:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
09:37:59:WU02:FS01:0x22:             0 -gpu 0
09:37:59:WU02:FS01:0x22:     Config: <none>
09:37:59:WU02:FS01:0x22:************************************ Build *************************************
09:37:59:WU02:FS01:0x22:    Version: 0.0.5
09:37:59:WU02:FS01:0x22:       Date: Apr 22 2020
09:37:59:WU02:FS01:0x22:       Time: 04:42:59
09:37:59:WU02:FS01:0x22: Repository: Git
09:37:59:WU02:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
09:37:59:WU02:FS01:0x22:     Branch: HEAD
09:37:59:WU02:FS01:0x22:   Compiler: Visual C++ 2008
09:37:59:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:37:59:WU02:FS01:0x22:   Platform: win32 10
09:37:59:WU02:FS01:0x22:       Bits: 64
09:37:59:WU02:FS01:0x22:       Mode: Release
09:37:59:WU02:FS01:0x22:************************************ System ************************************
09:37:59:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
09:37:59:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 69 Stepping 1
09:37:59:WU02:FS01:0x22:       CPUs: 4
09:37:59:WU02:FS01:0x22:     Memory: 15.89GiB
09:37:59:WU02:FS01:0x22:Free Memory: 12.53GiB
09:37:59:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
09:37:59:WU02:FS01:0x22: OS Version: 6.2
09:37:59:WU02:FS01:0x22:Has Battery: true
09:37:59:WU02:FS01:0x22: On Battery: false
09:37:59:WU02:FS01:0x22: UTC Offset: 1
09:37:59:WU02:FS01:0x22:        PID: 7148
09:37:59:WU02:FS01:0x22:        CWD: C:\Users\neil_\AppData\Roaming\FAHClient\work
09:37:59:WU02:FS01:0x22:         OS: Windows 10 Home
09:37:59:WU02:FS01:0x22:    OS Arch: AMD64
09:37:59:WU02:FS01:0x22:********************************************************************************
09:37:59:WU02:FS01:0x22:Project: 14462 (Run 0, Clone 847, Gen 16)
09:37:59:WU02:FS01:0x22:Unit: 0x0000001d03854c135eb39e42d4462783
09:37:59:WU02:FS01:0x22:Reading tar file core.xml
09:37:59:WU02:FS01:0x22:Reading tar file integrator.xml
09:37:59:WU02:FS01:0x22:Reading tar file state.xml
09:38:01:WU02:FS01:0x22:Reading tar file system.xml
09:38:03:WU02:FS01:0x22:Digital signatures verified
09:38:03:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
09:38:03:WU02:FS01:0x22:Version 0.0.5
09:38:20:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
09:38:20:WU01:FS01:Connecting to 3.133.76.19:80
09:38:35:WU01:FS01:Upload 0.08%
09:39:09:WU02:FS01:0x22:Completed 0 out of 2000000 steps (0%)
09:39:10:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
09:39:43:WU01:FS01:Upload 1.39%
09:39:43:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
09:39:43:WU01:FS01:Trying to send results to collection server
09:39:43:WU01:FS01:Uploading 80.77MiB to 18.188.125.154
09:39:43:WU01:FS01:Connecting to 18.188.125.154:8080
09:40:57:WU01:FS01:Upload 1.47%
09:41:03:WU01:FS01:Upload 4.02%
09:41:09:WU01:FS01:Upload 6.19%
09:41:15:WU01:FS01:Upload 9.21%
09:41:21:WU01:FS01:Upload 12.46%
09:41:27:WU01:FS01:Upload 14.24%
09:41:33:WU01:FS01:Upload 15.24%
09:41:39:WU01:FS01:Upload 17.33%
09:41:40:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
09:41:45:WU01:FS01:Upload 19.19%
09:41:51:WU01:FS01:Upload 22.36%
09:41:57:WU01:FS01:Upload 25.69%
09:42:05:WU01:FS01:Upload 28.09%
09:42:11:WU01:FS01:Upload 31.11%
09:42:17:WU01:FS01:Upload 33.89%
09:42:24:WU01:FS01:Upload 35.36%
09:42:30:WU01:FS01:Upload 38.07%
09:42:38:WU01:FS01:Upload 40.16%
09:42:44:WU01:FS01:Upload 42.71%
09:42:50:WU01:FS01:Upload 45.81%
09:42:56:WU01:FS01:Upload 48.90%
09:43:02:WU01:FS01:Upload 50.99%
09:43:08:WU01:FS01:Upload 54.09%
09:43:14:WU01:FS01:Upload 57.26%
09:43:20:WU01:FS01:Upload 59.66%
09:43:26:WU01:FS01:Upload 62.60%
09:43:32:WU01:FS01:Upload 65.93%
09:43:38:WU01:FS01:Upload 68.40%
09:43:44:WU01:FS01:Upload 70.11%
09:43:50:WU01:FS01:Upload 72.74%
09:43:56:WU01:FS01:Upload 74.67%
09:44:03:WU01:FS01:Upload 76.99%
09:44:09:WU01:FS01:Upload 79.62%
09:44:15:WU01:FS01:Upload 81.79%
09:44:21:WU01:FS01:Upload 84.11%
09:44:27:WU01:FS01:Upload 86.90%
09:44:34:WU01:FS01:Upload 89.84%
09:44:40:WU01:FS01:Upload 91.39%
09:44:46:WU01:FS01:Upload 92.86%
09:44:52:WU01:FS01:Upload 94.94%
09:44:58:WU01:FS01:Upload 97.34%
09:45:04:WU01:FS01:Upload 99.82%
09:45:10:WU01:FS01:Upload complete
09:45:11:WU01:FS01:Server responded WORK_ACK (400)
09:45:11:WU01:FS01:Final credit estimate, 44500.00 points
09:45:11:WU01:FS01:Cleaning up
09:53:00:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
10:04:16:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
10:15:43:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
10:23:37:19:127.0.0.1:New Web session
10:28:43:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
10:40:41:WU02:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
11:27:05:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
11:38:48:27:127.0.0.1:New Web session
11:42:50:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
11:57:58:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
12:00:27:WU02:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
12:13:01:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
12:31:27:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
12:48:48:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
12:58:26:WU02:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
13:06:02:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
13:23:45:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
13:40:09:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
13:55:48:WU02:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
13:56:15:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
14:14:13:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
14:19:28:49:127.0.0.1:New Web session
14:33:06:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
14:47:32:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
14:53:30:WU02:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
15:00:43:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
15:13:27:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
15:26:05:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
15:38:45:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
15:50:26:WU02:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
15:51:16:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
16:03:40:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
16:15:13:62:127.0.0.1:New Web session
16:16:23:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
16:29:13:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
16:41:53:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
16:47:34:WU02:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
16:54:17:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
17:06:43:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
17:19:28:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
17:32:21:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
17:44:34:WU02:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
17:45:03:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
17:57:57:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
18:10:40:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
18:23:11:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
18:36:10:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
18:41:32:WU02:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
18:48:31:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
19:00:51:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
19:13:02:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
19:25:08:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
19:37:07:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
19:38:20:WU02:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
19:49:04:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
20:01:01:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
20:12:47:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
20:24:41:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
20:35:16:WU02:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
20:36:47:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
20:48:34:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
21:00:16:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
21:11:56:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
21:23:39:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
21:32:07:WU02:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
21:35:13:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
21:46:48:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
21:58:22:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
22:09:58:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
22:21:40:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
22:29:00:WU02:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
22:33:21:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
22:36:46:75:127.0.0.1:New Web session
22:45:42:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
22:57:45:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
23:09:28:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
23:21:12:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
23:25:50:WU02:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
23:33:07:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
23:46:34:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
23:58:29:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
00:10:14:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
******************************* Date: 2020-06-01 *******************************
00:22:36:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
00:22:58:WU02:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
00:34:40:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
00:47:01:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
00:58:53:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
01:10:50:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
01:19:50:WU02:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
01:22:29:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
01:33:55:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
01:45:17:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
01:56:33:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
02:07:57:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
02:16:47:WU02:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
02:19:22:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
02:30:46:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
02:43:11:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
02:54:39:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
03:06:04:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
03:13:35:WU02:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
03:17:30:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
03:28:52:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
03:40:17:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
03:51:41:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
03:51:41:WU01:FS00:Connecting to 65.254.110.245:80
03:51:41:WU01:FS00:Assigned to work server 40.114.52.201
03:51:41:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 40.114.52.201
03:51:41:WU01:FS00:Connecting to 40.114.52.201:8080
03:51:43:WU01:FS00:Downloading 2.14MiB
03:51:43:WU01:FS00:Download complete
03:51:43:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13851 run:0 clone:26079 gen:145 core:0xa7 unit:0x000000a8287234c95e7886294339fe92
04:03:05:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
04:03:10:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
04:03:10:WU00:FS00:0xa7:Saving result file dhdl.xvg
04:03:10:WU00:FS00:0xa7:Saving result file frame77.trr
04:03:10:WU00:FS00:0xa7:Saving result file md.log
04:03:10:WU00:FS00:0xa7:Saving result file pullf.xvg
04:03:10:WU00:FS00:0xa7:Saving result file pullx.xvg
04:03:10:WU00:FS00:0xa7:Saving result file science.log
04:03:10:WU00:FS00:0xa7:Saving result file traj_comp.xtc
04:03:10:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
04:03:10:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
04:03:10:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14852 run:392 clone:1 gen:77 core:0xa7 unit:0x000000579bf7a4d65ea103bc5751021c
04:03:10:WU00:FS00:Uploading 6.80MiB to 155.247.164.214
04:03:10:WU00:FS00:Connecting to 155.247.164.214:8080
04:03:11:WU01:FS00:Starting
04:03:11:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\neil_\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 11724 -checkpoint 15 -np 2
04:03:11:WU01:FS00:Started FahCore on PID 14252
04:03:11:WU01:FS00:Core PID:10084
04:03:11:WU01:FS00:FahCore 0xa7 started
04:03:11:WU01:FS00:0xa7:*********************** Log Started 2020-06-01T04:03:11Z ***********************
04:03:11:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
04:03:11:WU01:FS00:0xa7:       Type: 0xa7
04:03:11:WU01:FS00:0xa7:       Core: Gromacs
04:03:11:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 14252 -checkpoint 15 -np
04:03:11:WU01:FS00:0xa7:             2
04:03:11:WU01:FS00:0xa7:************************************ CBang *************************************
04:03:11:WU01:FS00:0xa7:       Date: Oct 26 2019
04:03:11:WU01:FS00:0xa7:       Time: 01:38:25
04:03:11:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
04:03:11:WU01:FS00:0xa7:     Branch: master
04:03:11:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
04:03:11:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:03:11:WU01:FS00:0xa7:   Platform: win32 10
04:03:11:WU01:FS00:0xa7:       Bits: 64
04:03:11:WU01:FS00:0xa7:       Mode: Release
04:03:11:WU01:FS00:0xa7:************************************ System ************************************
04:03:11:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
04:03:11:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 69 Stepping 1
04:03:11:WU01:FS00:0xa7:       CPUs: 4
04:03:11:WU01:FS00:0xa7:     Memory: 15.89GiB
04:03:11:WU01:FS00:0xa7:Free Memory: 11.49GiB
04:03:11:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
04:03:11:WU01:FS00:0xa7: OS Version: 6.2
04:03:11:WU01:FS00:0xa7:Has Battery: true
04:03:11:WU01:FS00:0xa7: On Battery: false
04:03:11:WU01:FS00:0xa7: UTC Offset: 1
04:03:11:WU01:FS00:0xa7:        PID: 10084
04:03:11:WU01:FS00:0xa7:        CWD: C:\Users\neil_\AppData\Roaming\FAHClient\work
04:03:11:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
04:03:11:WU01:FS00:0xa7:    Version: 0.0.18
04:03:11:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:03:11:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
04:03:11:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
04:03:11:WU01:FS00:0xa7:       Time: 01:52:30
04:03:11:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
04:03:11:WU01:FS00:0xa7:************************************ Build *************************************
04:03:11:WU01:FS00:0xa7:       SIMD: avx_256
04:03:11:WU01:FS00:0xa7:********************************************************************************
04:03:11:WU01:FS00:0xa7:Project: 13851 (Run 0, Clone 26079, Gen 145)
04:03:11:WU01:FS00:0xa7:Unit: 0x000000a8287234c95e7886294339fe92
04:03:11:WU01:FS00:0xa7:Reading tar file core.xml
04:03:11:WU01:FS00:0xa7:Reading tar file frame145.tpr
04:03:11:WU01:FS00:0xa7:Digital signatures verified
04:03:11:WU01:FS00:0xa7:Calling: mdrun -s frame145.tpr -o frame145.trr -x frame145.xtc -e frame145.edr -cpt 15 -nt 2
04:03:11:WU01:FS00:0xa7:Steps: first=72500000 total=500000
04:03:14:WU01:FS00:0xa7:Completed 1 out of 500000 steps (0%)
04:03:16:WU00:FS00:Upload 56.10%
04:03:23:WU00:FS00:Upload complete
04:03:23:WU00:FS00:Server responded WORK_ACK (400)
04:03:23:WU00:FS00:Final credit estimate, 1504.00 points
04:03:23:WU00:FS00:Cleaning up
04:10:28:WU02:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
04:15:24:WU01:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
04:27:30:WU01:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
04:39:39:WU01:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
04:51:59:WU01:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
05:04:13:WU01:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
05:07:19:WU02:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
05:16:23:WU01:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
05:28:36:WU01:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
05:40:50:WU01:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
05:53:00:WU01:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
06:04:15:WU02:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
06:05:12:WU01:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
06:17:24:WU01:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
06:29:39:WU01:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
06:41:53:WU01:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
06:54:27:WU01:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
07:01:02:WU02:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
07:06:45:WU01:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
07:18:56:WU01:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
07:31:03:WU01:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
07:43:16:WU01:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
07:55:24:WU01:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
07:57:58:WU02:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
08:07:35:WU01:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
08:19:47:WU01:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
08:32:05:WU01:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
08:39:48:98:127.0.0.1:New Web session
08:45:06:WU01:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
08:50:20:FS00:Paused
08:50:20:FS01:Paused
08:50:20:FS00:Shutting core down
08:50:20:FS01:Shutting core down
08:50:20:WU02:FS01:0x22:WARNING:Console control signal 1 on PID 7148
08:50:20:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 10084
08:50:20:WU02:FS01:0x22:Exiting, please wait. . .
08:50:20:WU01:FS00:0xa7:Exiting, please wait. . .
08:50:20:WU02:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
08:50:21:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
08:50:23:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:51:11:Removing old file 'configs/config-20200525-224356.xml'
08:51:11:Saving configuration to config.xml
08:51:11:<config>
08:51:11:  <!-- Network -->
08:51:11:  <proxy v=':8080'/>
08:51:11:
08:51:11:  <!-- Slot Control -->
08:51:11:  <power v='medium'/>
08:51:11:
08:51:11:  <!-- User Information -->
08:51:11:  <passkey v='*****'/>
08:51:11:  <team v='262280'/>
08:51:11:  <user v='neil_en_suite'/>
08:51:11:
08:51:11:  <!-- Folding Slots -->
08:51:11:  <slot id='0' type='CPU'>
08:51:11:    <paused v='true'/>
08:51:11:  </slot>
08:51:11:  <slot id='1' type='GPU'>
08:51:11:  </slot>
08:51:11:</config>
08:51:11:Clean exit
Thanks for your reports, I will ask around and see what happens :)
fhew
Some stats locations not being updated
Post by fhew »
I've got machines folding non-stop, but yesterday my stats haven't been updating,
at least in some viewers.
The web control, browser viewer, hasn't changed its view of my total points in about 12 hours.
My https://stats.foldingathome.org/donor/Fulko_Hew page is similarly out of date,
as well as my info on : https://stats.foldingathome.org/team/44851
The info at: https://apps.foldingathome.org/cpu also hasn't been updated since last night
But the info on: https://apps.foldingathome.org/teamstats/team44851.html
and at https://folding.extremeoverclocking.com/
IS correct and up-to-date.
So some places are correct, and others are not... what's going on?
f3n1x
Re: Some stats locations not being updated
Post by f3n1x »
I have the same problem... server at folding is not updating.
comixgoddess
Hardware configuration: MacBook Pro 2017
Post by comixgoddess »
I am seeing the same thing. Web Control points haven't changed in over 10 hours despite work units being completed and uploaded, though my total at extremeoverclocking is correct. Hopefully, things will get caught up soon.
DalekSec
Post by DalekSec »
Yup, I'm seeing the same thing here. I thought it was because I had installed passkeys for the first time on all my 6 clients! It seems it's nothing to do with that!! All 6 have completed units, but no update to stats on WUs or points.
joeysfah
Post by joeysfah »
Ditto here, no stats updates since yesterday evening. Multiple WU's have completed, WORK_ACK's logged, but continue folding on newly downloaded WU's. Nothing is accumulating as of a few minutes ago.
FoldingDaath
Post by FoldingDaath »
Same here. No stats since 2020-05-31 22:46 CEST.
It seems points are being recorded - but not the main stats. You can check your team with your ID here: apps.foldingathome.o rg/teamstats/teamID.html - just replace ID with your team #
Reason: merged two 1st posts
It looks like WU stats are being recorded on the database itself, but some lookups through the frontend system are not currently active. One or more of the scripts may have crashed and need restarting.
Randy1411
Post by Randy1411 »
Same here. NO NEW stats since 2020-05-31 23:06 Swisstime! "Date of last Work unit" stop at this time on all 15 clients! All clients are Online and running Fullspeed!
roygrubb
Several WUs completed but points not incrementing
Post by roygrubb »
I have seen several Work Units completed according to the progress bar today, but my points have been stuck at 29,387,497 since last night (about 24 hours).
Date of last Work Unit shows: 2020-05-31 22:56:03
I'm operating an AMD Ryzen 3900X, allocating 1 core and GeForce RTX 2080 Ti, also all 4 cores of an i7-3770
I started on Folding@home on 15th May, and until now have been averaging 2 million points a day.
Any help on why this is happening? The progress bars are all moving normally, it's just that the points earned don't change.
Also the overall rank doesn't change - it's 22,848. Now, if the points were not being counted for 24 hours, I'd expect my overall rank to slip back as other donors passed me. This suggests to me that neither the points or the rank are being updated in my clients.
I'm running Windows 10 on both machines, and both machines are under the same donor identity.
Thanks.
