Recently, after updating my client I have noticed that the retry/download of new work is problematic.
When I check my machines in the mornings sometimes the Attempts and Next Attempt counter in Unknown and the machines have not returned work for 9-12 hours.
Only way to fix it is reboot the machines and then it connects immediately and downloads work. Pausing -> Folding does not work.
Am I the only one experiencing this? Should I got back to the previous client?
(Not a) 7.6.13 issue
Re: 7.6.13 issue
It seems that you might be encountering this issue: https://github.com/FoldingAtHome/fah-issues/issues/983
Can you please post the log file?
robertmiles
Re: 7.6.13 issue
When I start WEB CONTROL, click on Stop Folding, then Finish up, then stop, this has no effect on any future WUs.
If I click on Stop now instead of Finish up, then stop, then it has the effect I expect - the current WU stops running, and more are not started later until I click on Start folding.
In case it matters, the browser I use is Mozilla Firefox, latest version. I'm running version 7.6.13 Folding@home under 64-bit Windows 10.
Currently folding using only a GPU slot, but I saw this problem before When using both a CPU slot and a GPU slot.
Re: 7.6.13 issue
There is a bug in the current version of Web Control, the Finish option does not work. A problem report has been already put in for this.robertmiles wrote:When I start WEB CONTROL, click on Stop Folding, then Finish up, then stop, this has no effect on any future WUs.
Using the advanced control - FAHControl, the Finish option does work. You can either click on the Finish button dn all folding slots will be set to that status, or right-click on a folding slot and Finish can be set for just that slot.
fayzacantik
Re: 7.6.13 issue
Hi,
usually I got 150k PPD but after 7.6.13 my GTX1050 only give 38k PPD is this normal ?
Re: 7.6.13 issue
There are some projects, mostly project 13414, which have a high variance in points, and they are being investigated.
It has nothing do with the client version, so no need to revert.
