GPU stuck on download
dellfoldgpu
Hi Have a Dell Latitude e6430 laptop running a NVIDIA NVS 5200M Graphics Card, the card has the latest driver from NVIDIA. version 392.59.
I have set my laptop under NVIDIA control panel/ manage 3d settings to use the "high performance NVIDIA processor" for all programs
In the folding at home client I can see the slot for the gpu. However it is stuck on downloading and has been for almost a week. I tried idling it and then un-idling it and that hasn't worked.
One thing that looks suspicious to me is that:
1. The work server is always 192.0.2.1
2. the collection server is always 0.0.0.0
Perhaps this is the problem?
Re: GPU stuck on download
Currently there is no work available for your NVS 5200M, and that generation of GPUs is currently being reviewed as to whether they will remain on the supported list. The issue is related to the Fermi based GPUs from then only supporting OpenCL 1.1, the GPU folding core software currently being used was developed for OpenCL 1.2 and only tested on GPUs that supported that.
These cards worked on some projects, but failed on others depending on which OpenCL commands were used. However many of the projects being done for COVID-19 do need those. The issue is worse for first generation Fermi chips (GF10n) such as the GF108 used in the NVS 5200M. Second generation Fermi GF11n chips are missing fewer items, but would also need parts of the OpenCL 1.2 commands emulated with additional code. This would require a new folding core, related development and testing, and in the end would be slower.
For the time being yuoo can do CPU folding projects. Some of these older cards may be usable if a CUDA instead of OpenCL based folding core is released at some point in the future for use on nVidia GPUs. But there is currently no time frame announced on when that might happen.
As for the Work Server address being 192.0.2.1, that is being done on the server level to redirect the request from the active Work Servers. It indicates there is no available work for the devices connected to that request.
dellfoldgpu
Hi Joe_H,
Thanks this is helpful to know. So it's sounds like the best course of action is to keep folding with the cpu and leave the gpu "ready" in case work becomes available? (Or even if work became available would I have to take other actions?)
Best,
Matt
Best,
Matt
if you remove the gpu slot, your cpu may speed up.
For now I would suggest either pausing or removing the GPU slot. Whether or not the Fermi GPUs will ever get assignments should get announced, and the slot can be added back if they do start assigning to them again. If the CUDA based core will be using them will be at least months from now, if not next year.
GreenHouse
Hello, Joe_H,
I also had same problem. As, I just upgraded my old GPU GT710 to GTX1650. Is it my newe GPU not able to get the WU too?
Here is the LOGS:
Thank you
Here is the LOGS:
*********************** Log Started 2020-09-25T02:51:01Z ***********************
02:51:12:FS01:Unpaused
02:51:21:WU01:FS01:Connecting to assign1.foldingathome.org:80
02:51:23:WU01:FS01:Assigned to work server 192.0.2.1
02:51:23:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
02:51:23:WU01:FS01:Connecting to 192.0.2.1:8080
02:51:44:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:51:44:WU01:FS01:Connecting to 192.0.2.1:80
02:52:05:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:52:05:WU01:FS01:Connecting to assign1.foldingathome.org:80
02:52:06:WU01:FS01:Assigned to work server 192.0.2.1
02:52:06:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
02:52:06:WU01:FS01:Connecting to 192.0.2.1:8080
02:52:27:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:52:27:WU01:FS01:Connecting to 192.0.2.1:80
02:52:48:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:53:05:WU01:FS01:Connecting to assign1.foldingathome.org:80
02:53:06:WU01:FS01:Assigned to work server 192.0.2.1
02:53:06:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
02:53:06:WU01:FS01:Connecting to 192.0.2.1:8080
02:53:27:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:53:27:WU01:FS01:Connecting to 192.0.2.1:80
02:53:48:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:54:43:WU01:FS01:Connecting to assign1.foldingathome.org:80
02:54:43:WU01:FS01:Assigned to work server 192.0.2.1
02:54:43:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
02:54:43:WU01:FS01:Connecting to 192.0.2.1:8080
02:55:04:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:55:04:WU01:FS01:Connecting to 192.0.2.1:80
02:55:25:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:57:20:WU01:FS01:Connecting to assign1.foldingathome.org:80
02:57:20:WU01:FS01:Assigned to work server 192.0.2.1
02:57:20:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
02:57:21:WU01:FS01:Connecting to 192.0.2.1:8080
02:57:42:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:57:42:WU01:FS01:Connecting to 192.0.2.1:80
02:58:03:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:01:34:WU01:FS01:Connecting to assign1.foldingathome.org:80
03:01:35:WU01:FS01:Assigned to work server 192.0.2.1
03:01:35:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
03:01:35:WU01:FS01:Connecting to 192.0.2.1:8080
03:01:56:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:01:56:WU01:FS01:Connecting to 192.0.2.1:80
03:02:17:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:08:25:WU01:FS01:Connecting to assign1.foldingathome.org:80
03:08:26:WU01:FS01:Assigned to work server 192.0.2.1
03:08:26:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
03:08:26:WU01:FS01:Connecting to 192.0.2.1:8080
03:08:47:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:08:47:WU01:FS01:Connecting to 192.0.2.1:80
03:09:08:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:19:31:WU01:FS01:Connecting to assign1.foldingathome.org:80
03:19:32:WU01:FS01:Assigned to work server 192.0.2.1
03:19:32:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
03:19:32:WU01:FS01:Connecting to 192.0.2.1:8080
03:19:53:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:19:53:WU01:FS01:Connecting to 192.0.2.1:80
03:20:14:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:37:28:WU01:FS01:Connecting to assign1.foldingathome.org:80
03:37:28:WU01:FS01:Assigned to work server 192.0.2.1
03:37:28:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
03:37:28:WU01:FS01:Connecting to 192.0.2.1:8080
03:37:49:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:37:49:WU01:FS01:Connecting to 192.0.2.1:80
03:38:11:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:06:41:ERROR:WU01:FS01:Exception: Could not get IP address for assign1.foldingathome.org: No such host is known.
04:06:47:WU01:FS01:Connecting to assign2.foldingathome.org:80
04:06:48:WU01:FS01:Assigned to work server 192.0.2.1
04:06:48:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
04:06:48:WU01:FS01:Connecting to 192.0.2.1:8080
04:07:09:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:07:09:WU01:FS01:Connecting to 192.0.2.1:80
04:07:30:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:53:40:ERROR:WU01:FS01:Exception: Could not get IP address for assign1.foldingathome.org: No such host is known.
04:53:40:WU01:FS01:Connecting to assign2.foldingathome.org:80
04:53:41:WU01:FS01:Assigned to work server 192.0.2.1
04:53:47:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
04:53:47:WU01:FS01:Connecting to 192.0.2.1:8080
04:54:08:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:54:08:WU01:FS01:Connecting to 192.0.2.1:80
04:54:29:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:53:33:WU01:FS01:Connecting to assign1.foldingathome.org:80
05:53:35:WU01:FS01:Assigned to work server 192.0.2.1
05:53:47:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
05:53:47:WU01:FS01:Connecting to 192.0.2.1:8080
05:54:08:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
05:54:08:WU01:FS01:Connecting to 192.0.2.1:80
05:54:29:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
06:53:30:WU01:FS01:Connecting to assign1.foldingathome.org:80
06:53:31:WU01:FS01:Assigned to work server 192.0.2.1
06:53:47:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
06:53:47:WU01:FS01:Connecting to 192.0.2.1:8080
06:54:08:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
06:54:08:WU01:FS01:Connecting to 192.0.2.1:80
06:54:29:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
07:53:44:WU01:FS01:Connecting to assign1.foldingathome.org:80
07:53:45:WU01:FS01:Assigned to work server 192.0.2.1
07:53:47:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
07:53:47:WU01:FS01:Connecting to 192.0.2.1:8080
07:54:08:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:54:08:WU01:FS01:Connecting to 192.0.2.1:80
07:54:30:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
******************************* Date: 2020-09-25 *******************************
08:53:32:WU01:FS01:Connecting to assign1.foldingathome.org:80
08:53:34:WU01:FS01:Assigned to work server 192.0.2.1
08:53:47:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
08:53:47:WU01:FS01:Connecting to 192.0.2.1:8080
08:54:08:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:54:08:WU01:FS01:Connecting to 192.0.2.1:80
08:54:30:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:53:30:WU01:FS01:Connecting to assign1.foldingathome.org:80
09:53:31:WU01:FS01:Assigned to work server 192.0.2.1
09:53:48:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
09:53:48:WU01:FS01:Connecting to 192.0.2.1:8080
09:54:09:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
09:54:09:WU01:FS01:Connecting to 192.0.2.1:80
09:54:30:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:53:44:ERROR:WU01:FS01:Exception: Could not get IP address for assign3.foldingathome.org: No such host is known.
10:53:47:WU01:FS01:Connecting to assign1.foldingathome.org:80
10:53:48:WU01:FS01:Assigned to work server 192.0.2.1
10:53:48:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
10:53:48:WU01:FS01:Connecting to 192.0.2.1:8080
10:54:09:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
10:54:09:WU01:FS01:Connecting to 192.0.2.1:80
10:54:30:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:39:48:FS01:Paused
12:24:34:FS01:Unpaused
12:24:53:ERROR:WU01:FS01:Exception: Could not get IP address for assign3.foldingathome.org: No such host is known.
12:24:55:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:24:57:WU01:FS01:Assigned to work server 192.0.2.1
12:24:57:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
12:24:57:WU01:FS01:Connecting to 192.0.2.1:8080
12:25:18:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:25:18:WU01:FS01:Connecting to 192.0.2.1:80
12:25:39:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
12:26:18:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:26:20:WU01:FS01:Assigned to work server 192.0.2.1
12:26:34:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
12:26:34:WU01:FS01:Connecting to 192.0.2.1:8080
12:26:55:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:26:55:WU01:FS01:Connecting to 192.0.2.1:80
12:27:16:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
12:28:53:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:28:54:WU01:FS01:Assigned to work server 192.0.2.1
12:29:11:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
12:29:11:WU01:FS01:Connecting to 192.0.2.1:8080
12:29:32:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:29:32:WU01:FS01:Connecting to 192.0.2.1:80
12:29:53:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
12:33:07:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:33:08:WU01:FS01:Assigned to work server 192.0.2.1
12:33:26:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
12:33:26:WU01:FS01:Connecting to 192.0.2.1:8080
12:33:47:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:33:47:WU01:FS01:Connecting to 192.0.2.1:80
12:34:08:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
12:39:59:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:39:59:WU01:FS01:Assigned to work server 192.0.2.1
12:40:17:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
12:40:17:WU01:FS01:Connecting to 192.0.2.1:8080
12:40:38:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:40:38:WU01:FS01:Connecting to 192.0.2.1:80
12:40:59:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
12:51:04:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:51:05:WU01:FS01:Assigned to work server 192.0.2.1
12:51:22:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
12:51:22:WU01:FS01:Connecting to 192.0.2.1:8080
12:51:43:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:51:43:WU01:FS01:Connecting to 192.0.2.1:80
12:52:05:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
13:09:01:WU01:FS01:Connecting to assign1.foldingathome.org:80
13:09:02:WU01:FS01:Assigned to work server 192.0.2.1
13:09:19:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU117 [GeForce GTX 1650] 3091 from 192.0.2.1
13:09:19:WU01:FS01:Connecting to 192.0.2.1:8080
13:09:40:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
13:09:40:WU01:FS01:Connecting to 192.0.2.1:80
13:10:01:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
13:24:59:FS01:Paused
GreenHouse
Hi JimboPalmer,JimboPalmer wrote:if you remove the gpu slot, your cpu may speed up.
How to remove gpu slot? and How to add it again when it is utilize?
How much is the speeds increase if the gpu removed?
But, I am still confused why this could happenned, as I only upgrade from GT710 to GTX1650, in order to get faster TPF.
Thank you
Welcome to the F@H Forum GreenHouse,
I do know that GeForce GTX 1650 is supported. May I suggest that you uninstall the client (choose the option to delete the data) and then perform a fresh installation? Hopefully, that is all that is required for it to start working again
What JimboPalmer is mentioning is for a specific use case. It is where you can remove the GPU Slot from the client if the GPU is unsupported which will automatically configure the CPU Slot to use all the CPUs. Do note that this can also be achieved manually via Advanced Control (AKA FAHControl).GreenHouse wrote:...How to remove gpu slot? and How to add it again when it is utilize?
How much is the speeds increase if the gpu removed?...
In your case, I am assuming that you physically removed GT710 from the system and then installed GTX 1650 into the correct PCIe slot. Also ensure that you have the latest Nvidia drivers which you downloaded from the Nvidia site and then installed on your system.
Your drivers do not automatically reconfigure themself from supporting a GT710 to ones that support a GTX1650 -- unless you reinstall the drivers. The 710 is a Kepler and the 1650 is a Turing
GreenHouse
I had uninstall the f@h client with delete data. I do reinstall the client in clean.
However, I experience that the cpu run at 50% speed even I slide the throttle to full. But, the GPU still sit there nicely without any job.
Appreciate for further assistance folks....
Thank you
Thank you
1. Install the recommended nVidia proprietary driver for the new GPU.
2. Clean install the latest released FAHClient.
3. Postl the first few page of the log as it starts up.
If you're on windows insider fast ring, geforce 460.15., you're probably getting the wrong driver.
The first WU that is downloaded will only use 1 CPU in most cases. The second WU that is downloaded can use more CPU depending on what the slot was configured for when it was downloaded. The number of CPUs allocated to the slot when the WU first downloads, will be capped at that. You can reduce the number of CPUs once the WU has downloaded but you can't increase it past the cap that is in place when the WU was first downloaded.GreenHouse wrote:...I experience that the cpu run at 50% speed even I slide the throttle to full...
GreenHouse
Hi Bruce, I had done step 1, 2, and 3. While point 3 is still the same content everytime I run the F@H Logs, so, I probably using the same LOGS shown below.bruce wrote:1. Install the recommended nVidia proprietary driver for the new GPU.
And, I am not understand about "windows insider fast ring, gforce 460.15" mean, so, would you mind to elaborate a bit for me, please. As I am ordinary PC user with only daily word and excel usage.
What bruce mentions only applies if you're using Windows 10 Insider Fast Ring. That is beta Windows 10 released for testing by Microsoft. Considering that you're not aware of it, it is highly likely that you're running the released version of Windows 10 (Home/Professional) so that comment doesn't apply to you.GreenHouse wrote:...I am not understand about "windows insider fast ring, gforce 460.15" mean, so, would you mind to elaborate a bit for me, please. As I am ordinary PC user with only daily word and excel usage.
