my gtx1050ti not folding, stuck on waiting for idle
Dosoku
Post by Dosoku »
I unticked the on idle option, and I have also gone to configure-slots-folding slots-GPU and removed the idle option. My CPU is folding just fine, it is just my GPU. Any help?
*********************** Log Started 2020-05-29T08:46:42Z ***********************
08:46:42:Trying to access database...
08:46:42:Successfully acquired database lock
08:46:42:Read GPUs.txt
08:46:42:Enabled folding slot 00: READY cpu:5
08:46:42:Enabled folding slot 01: PAUSED gpu:0:GP107 [GeForce GTX 1050 Ti]  2138 (waiting for idle)
08:46:42:****************************** FAHClient ******************************
08:46:42:        Version: 7.6.13
08:46:42:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:46:42:      Copyright: 2020 foldingathome.org
08:46:42:       Homepage: https://foldingathome.org/
08:46:42:           Date: Apr 27 2020
08:46:42:           Time: 21:21:01
08:46:42:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
08:46:42:         Branch: master
08:46:42:       Compiler: Visual C++ 2008
08:46:42:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:46:42:       Platform: win32 10
08:46:42:           Bits: 32
08:46:42:           Mode: Release
08:46:42:           Args: --open-web-control
08:46:42:         Config: C:\Users\m\AppData\Roaming\FAHClient\config.xml
08:46:42:******************************** CBang ********************************
08:46:42:           Date: Apr 24 2020
08:46:42:           Time: 17:07:55
08:46:42:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
08:46:42:           Bits: 32
08:46:42:******************************* System ********************************
08:46:42:            CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
08:46:42:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
08:46:42:           CPUs: 12
08:46:42:         Memory: 15.92GiB
08:46:42:    Free Memory: 9.24GiB
08:46:42:        Threads: WINDOWS_THREADS
08:46:42:     OS Version: 6.2
08:46:42:    Has Battery: false
08:46:42:     On Battery: false
08:46:42:     UTC Offset: 9
08:46:42:            PID: 10108
08:46:42:            CWD: C:\Users\m\AppData\Roaming\FAHClient
08:46:42:  Win32 Service: false
08:46:42:             OS: Windows 10 Home
08:46:42:        OS Arch: AMD64
08:46:42:           GPUs: 1
08:46:42:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP107 [GeForce GTX 1050 Ti] 2138
08:46:42:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:11.0
08:46:42:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:446.14
08:46:42:******************************* libFAH ********************************
08:46:42:           Date: Apr 15 2020
08:46:42:           Time: 14:53:14
08:46:42:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
08:46:42:           Bits: 32
08:46:42:***********************************************************************
08:46:42:<config>
08:46:42:  <!-- Folding Core -->
08:46:42:  <core-priority v='low'/>
08:46:42:
08:46:42:  <!-- Folding Slot Configuration -->
08:46:42:  <cause v='ALZHEIMERS'/>
08:46:42:
08:46:42:  <!-- Network -->
08:46:42:  <proxy v=':8080'/>
08:46:42:
08:46:42:  <!-- Slot Control -->
08:46:42:  <power v='light'/>
08:46:42:
08:46:42:  <!-- User Information -->
08:46:42:  <user v='Dosoku'/>
08:46:42:
08:46:42:  <!-- Folding Slots -->
08:46:42:  <slot id='0' type='CPU'/>
08:46:42:  <slot id='1' type='GPU'/>
08:46:42:</config>
08:46:42:WU00:FS00:Starting
08:46:42:WARNING:WU00:FS00:Changed SMP threads from 10 to 5 this can cause some work units to fail
08:46:42:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\m\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -np 5
08:46:42:WU00:FS00:Started FahCore on PID 5872
08:46:42:WU00:FS00:Core PID:21284
08:46:42:WU00:FS00:FahCore 0xa7 started
08:46:42:WU00:FS00:0xa7:*********************** Log Started 2020-05-29T08:46:42Z ***********************
08:46:42:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:46:42:WU00:FS00:0xa7:       Type: 0xa7
08:46:42:WU00:FS00:0xa7:       Core: Gromacs
08:46:42:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 5872 -checkpoint 15 -np 5
08:46:42:WU00:FS00:0xa7:************************************ CBang *************************************
08:46:42:WU00:FS00:0xa7:       Date: Oct 26 2019
08:46:42:WU00:FS00:0xa7:       Time: 01:38:25
08:46:42:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
08:46:42:WU00:FS00:0xa7:     Branch: master
08:46:42:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
08:46:42:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:46:42:WU00:FS00:0xa7:   Platform: win32 10
08:46:42:WU00:FS00:0xa7:       Bits: 64
08:46:42:WU00:FS00:0xa7:       Mode: Release
08:46:42:WU00:FS00:0xa7:************************************ System ************************************
08:46:42:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
08:46:42:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
08:46:42:WU00:FS00:0xa7:       CPUs: 12
08:46:42:WU00:FS00:0xa7:     Memory: 15.92GiB
08:46:42:WU00:FS00:0xa7:Free Memory: 9.22GiB
08:46:42:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
08:46:42:WU00:FS00:0xa7: OS Version: 6.2
08:46:42:WU00:FS00:0xa7:Has Battery: false
08:46:42:WU00:FS00:0xa7: On Battery: false
08:46:42:WU00:FS00:0xa7: UTC Offset: 9
08:46:42:WU00:FS00:0xa7:        PID: 21284
08:46:42:WU00:FS00:0xa7:        CWD: C:\Users\m\AppData\Roaming\FAHClient\work
08:46:42:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
08:46:42:WU00:FS00:0xa7:    Version: 0.0.18
08:46:42:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:46:42:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:46:42:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
08:46:42:WU00:FS00:0xa7:       Time: 01:52:30
08:46:42:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
08:46:42:WU00:FS00:0xa7:************************************ Build *************************************
08:46:42:WU00:FS00:0xa7:       SIMD: avx_256
08:46:42:WU00:FS00:0xa7:********************************************************************************
08:46:42:WU00:FS00:0xa7:Project: 16804 (Run 34, Clone 227, Gen 67)
08:46:42:WU00:FS00:0xa7:Unit: 0x0000004c82ed0b915e9df44055653c5d
08:46:42:WU00:FS00:0xa7:Digital signatures verified
08:46:42:WU00:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
08:46:42:WU00:FS00:0xa7:Calling: mdrun -s frame67.tpr -o frame67.trr -cpi state.cpt -cpt 15 -nt 4
08:46:42:WU00:FS00:0xa7:Steps: first=33500000 total=500000
08:46:43:WU00:FS00:0xa7:Completed 82962 out of 500000 steps (16%)
08:46:43:3:127.0.0.1:New Web session
Re: my gtx1050ti not folding, stuck on waiting for idle
Welcome to the F@H Forum Dosoku,
Please set the Folding Power option to Medium or Full. When it is on Light, GPU folding will only occur when the system is idle.
ajm
Post by ajm »
According to your log, your GPU is still paused:
I guess your slider in Advanced Control is on light. Just move it to middle or full.
Then you should edit your CPU slot: Configure -> Slots -> CPU -> Edit -> Enter 4 (instead of -1 I suppose) -> OK -> Save. It is not obligatory, but it would be safer, as for now, FAH has to lower the number of active threads from 5 to 4 before each WU:
Dosoku
Post by Dosoku »
Thanks for the kind support. Even after changing the bar, my GPU would be stuck on download and log would say
 WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
but it seems like there weren't any slots in Alzheimer's. As soon as I changed it to COVIS-19 it started downloading.
Dosoku wrote: it seems like there weren't any slots in Alzheimer's. As soon as I changed it to COVIS-19 it started downloading.
Folding@Home is almost totally focused on COVID-19 at this point, I am set to Any Disease, but get all COVID-19 Work Units.
You can't fault them for this, but it does not allow other focuses.
I get about 190k PPD with my Low Profile GTX 1050 ti on Core_22, closer to 160k PPD on Core_21.
Dosoku wrote:but it seems like there weren't any slots in Alzheimer's. As soon as I changed it to COVIS-19 it started downloading
The setting for disease is supposed to be a preference, so if none are available for Alzheimers then a WU for another project should have downloaded. Changing to COVID-19 may have been just coincidental and there just has not been any GPU WUs available for your 1050ti, or there might be an issue on the server.
