unable to connect to Folding@home client
rikki-warner
have tried both the browser client and the advanced client and reinstalled with no luck has been 2 day have tried resetting internet pc router ect please advise
NRT_AntiKytherA
Re: unable to connect to Folding@home client
Have you checked your firewall settings are not blocking the fahcontrol or fahclient?
rikki-warner
just check not blockedNRT_AntiKytherA wrote:Have you checked your firewall settings are not blocking the fahcontrol or fahclient?
NRT_AntiKytherA
Have you checked the fahclient is running? It may have failed to start. Anyhow since I don't see any information about the operating system you are using I will leave it here.
Please refer to this for both the troubleshooting information and also how to go about including some information to help others help you more.
viewtopic.php?f=24&t=26036
rikki-warner
got it going look like the last windows 10 up date broke it had to uninstall and start from scrachNRT_AntiKytherA wrote:Have you checked the fahclient is running? It may have failed to start. Anyhow since I don't see any information about the operating system you are using I will leave it here.
WindowsUpdate sometimes decides to update video drivers. When they do, they have been known to simply remove OpenCL. You didn't tell us what GPU you have, so this may not have been your problem. Post the first 100 lines of FAH's log per the instructions in my sig block.
Personally, I've also had problems with FAHClient having the Blocked I/O port bug but that gets corrected if I stop and restart FAHClient. (or reboot).
