I have seen on many threads advice on what settings to use for items like Internet Connections and large or small WU or even WU without deadlines. I was wondering if I could get some suggestions on what is most stable and effective for the options given in the graphical client. Mainly upload and download of work.
Thank you in advance for the help.
Suggestions on F@H settings
Taylor_Roehr
Team 46258 Milwaukee School of Engineering since 02.04.08
Folding at ~1450 ppd
http://folding.extremeoverclocking.com/ ... =&u=318852
Re: Suggestions on F@H settings
The default settings are the recommended settings. Anything after that is a customization for your computing environment. If you have a broadband connection, enable large work units, and you will get a few more points. That's about it.
Taylor_Roehr
When not using the IE settings is the proxy just "localhost"?
codysluder
Do not use either IE Settings or Proxy.
When you are not using a proxy, the setting doesn't matter.
ChelseaOilman
Follow this suggestion so your finished WUs aren't repeatedly uploaded.codysluder wrote:Do not use either IE Settings or Proxy.
Hi Taylor_Roehr (team 46258),
Your WU (P2963 R81 C10 G28) was added to the stats database on 2008-06-22 00:28:45 for 132 points of credit.
Your WU (P2963 R81 C10 G28) was added to the stats database on 2008-06-22 06:30:36 for 0 points of credit.
Your WU (P2963 R81 C10 G28) was added to the stats database on 2008-06-26 12:33:13 for 0 points of credit.
