System unusable whilst GPU folding
When the GPU is folding my system becomes unusable: cursor slow to track mouse, windows open slowly, etc.
I found that setting that slot id to "on idle" didn't help matters (the slowness continued even when it was marked idle)but, upon further investigation the gpu load seemed to have moved to the cpu's built in gpu. I've created a second slot for the cpu's gpu and set them both to "on idle", which seems to have restores some sense of order, but is this really the best I can do? Can I really not use my system whilst GPU folding is going on?
I would paste my listed system information here, but it appears to be not selectable/copyable in the "Advanced control" application. If you can tell me how to access it, I'll add it!
Re: System unusable whilst GPU folding
here are the official directions:
viewtopic.php?f=24&t=26036
Since we don't know your OS, all of them are there.
*********************** Log Started 2020-05-24T18:17:52Z ***********************
18:17:52:************************* Folding@home Client *************************
18:17:52: Website: https://foldingathome.org/
18:17:52: Copyright: (c) 2009-2018 foldingathome.org
18:17:52: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:17:52: Args:
18:17:52: Config: C:\Users\IanWo\AppData\Roaming\FAHClient\config.xml
18:17:52:******************************** Build ********************************
18:17:52: Version: 7.5.1
18:17:52: Date: May 11 2018
18:17:52: Time: 13:06:32
18:17:52: Repository: Git
18:17:52: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
18:17:52: Branch: master
18:17:52: Compiler: Visual C++ 2008
18:17:52: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:17:52: Platform: win32 10
18:17:52: Bits: 32
18:17:52: Mode: Release
18:17:52:******************************* System ********************************
18:17:52: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
18:17:52: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
18:17:52: CPUs: 16
18:17:52: Memory: 31.73GiB
18:17:52: Free Memory: 25.07GiB
18:17:52: Threads: WINDOWS_THREADS
18:17:52: OS Version: 6.2
18:17:52: Has Battery: true
18:17:52: On Battery: false
18:17:52: UTC Offset: 2
18:17:52: PID: 17668
18:17:52: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient
18:17:52: OS: Windows 10 Enterprise
18:17:52: OS Arch: AMD64
18:17:52: GPUs: 1
18:17:52: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU117M [GeForce GTX 1650 Mobile /
18:17:52: Max-Q]
18:17:52: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
18:17:52:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.45
18:17:52:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
18:17:52: Win32 Service: false
18:17:52:***********************************************************************
18:17:52:<config>
18:17:52: <!-- Network -->
18:17:52: <proxy v=':8080'/>
18:17:52:
18:17:52: <!-- Slot Control -->
18:17:52: <power v='full'/>
18:17:52:
18:17:52: <!-- User Information -->
18:17:52: <passkey v='********************************'/>
18:17:52: <team v='10813'/>
18:17:52: <user v='Ian_Worthington'/>
18:17:52:
18:17:52: <!-- Folding Slots -->
18:17:52: <slot id='0' type='CPU'>
18:17:52: <paused v='true'/>
18:17:52: </slot>
18:17:52: <slot id='1' type='GPU'>
18:17:52: <idle v='true'/>
18:17:52: </slot>
18:17:52:</config>
18:17:52:Trying to access database...
18:17:52:Successfully acquired database lock
18:17:52:Enabled folding slot 00: PAUSED cpu:15 (by user)
18:17:52:Enabled folding slot 01: PAUSED gpu:0:TU117M [GeForce GTX 1650 Mobile / Max-Q] (by user)
18:18:59:FS00:Unpaused
18:18:59:FS01:Unpaused
18:18:59:WU02:FS00:Starting
18:18:59:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 17668 -checkpoint 15 -np 15
18:19:00:WU02:FS00:Started FahCore on PID 21308
18:19:02:WU02:FS00:Core PID:5404
18:19:02:WU02:FS00:FahCore 0xa7 started
18:19:02:WU02:FS00:0xa7:*********************** Log Started 2020-05-24T18:19:02Z ***********************
18:19:02:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:19:02:WU02:FS00:0xa7: Type: 0xa7
18:19:02:WU02:FS00:0xa7: Core: Gromacs
18:19:02:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 705 -lifeline 21308 -checkpoint 15 -np
18:19:02:WU02:FS00:0xa7: 15
18:19:02:WU02:FS00:0xa7:************************************ CBang *************************************
18:19:02:WU02:FS00:0xa7: Date: Oct 26 2019
18:19:02:WU02:FS00:0xa7: Time: 01:38:25
18:19:03:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:19:03:WU02:FS00:0xa7: Branch: master
18:19:03:WU02:FS00:0xa7: Compiler: Visual C++ 2008
18:19:03:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:19:03:WU02:FS00:0xa7: Platform: win32 10
18:19:03:WU02:FS00:0xa7: Bits: 64
18:19:03:WU02:FS00:0xa7: Mode: Release
18:19:03:WU02:FS00:0xa7:************************************ System ************************************
18:19:03:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
18:19:03:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
18:19:03:WU02:FS00:0xa7: CPUs: 16
18:19:03:WU02:FS00:0xa7: Memory: 31.73GiB
18:19:03:WU02:FS00:0xa7:Free Memory: 24.66GiB
18:19:03:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
18:19:03:WU02:FS00:0xa7: OS Version: 6.2
18:19:03:WU02:FS00:0xa7:Has Battery: true
18:19:03:WU02:FS00:0xa7: On Battery: false
18:19:03:WU02:FS00:0xa7: UTC Offset: 2
18:19:03:WU02:FS00:0xa7: PID: 5404
18:19:03:WU02:FS00:0xa7: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
18:19:03:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
18:19:03:WU02:FS00:0xa7: Version: 0.0.18
18:19:03:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:19:03:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
18:19:03:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
18:19:03:WU02:FS00:0xa7: Date: Oct 26 2019
18:19:03:WU02:FS00:0xa7: Time: 01:52:30
18:19:03:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:19:03:WU02:FS00:0xa7:************************************ Build *************************************
18:19:03:WU02:FS00:0xa7: SIMD: avx_256
18:19:03:WU02:FS00:0xa7:********************************************************************************
18:19:03:WU02:FS00:0xa7:Project: 14719 (Run 223, Clone 0, Gen 46)
18:19:03:WU02:FS00:0xa7:Unit: 0x000000372879986c5ea968f44ca437a1
18:19:03:WU02:FS00:0xa7:Digital signatures verified
18:19:03:WU02:FS00:0xa7:Calling: mdrun -s frame46.tpr -o frame46.trr -cpi state.cpt -cpt 15 -nt 15
18:19:03:WU02:FS00:0xa7:Steps: first=0 total=250000
18:19:04:WU02:FS00:0xa7:Completed 98325 out of 250000 steps (39%)
18:19:19:FS01:Paused
18:19:50:Removing old file 'configs/config-20200508-170531.xml'
18:19:50:Saving configuration to config.xml
18:19:50:<config>
18:19:50: <!-- Network -->
18:19:50: <proxy v=':8080'/>
18:19:50:
18:19:50: <!-- Slot Control -->
18:19:50: <power v='full'/>
18:19:50:
18:19:50: <!-- User Information -->
18:19:50: <passkey v='********************************'/>
18:19:50: <team v='10813'/>
18:19:50: <user v='Ian_Worthington'/>
18:19:50:
18:19:50: <!-- Folding Slots -->
18:19:50: <slot id='0' type='CPU'/>
18:19:50:</config>
18:19:50:FS00:Shutting core down
18:19:50:WARNING:WU01:Slot ID 1 no longer exists and there are no other matching slots, dumping
18:19:50:WU01:Sending unit results: id:01 state:SEND error:DUMPED project:16441 run:342 clone:2 gen:34 core:0x22 unit:0x0000002c80fccb015ea997ffe0adf4f9
18:19:50:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 5404
18:19:50:WU02:FS00:0xa7:Exiting, please wait. . .
18:19:50:WU01:Connecting to 128.252.203.1:8080
18:19:51:WU01:Server responded WORK_ACK (400)
18:19:51:WU01:Cleaning up
18:19:51:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
18:19:52:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
18:19:52:WU02:FS00:Starting
18:19:52:WARNING:WU02:FS00:Changed SMP threads from 15 to 16 this can cause some work units to fail
18:19:52:WARNING:WU02:FS00:AS lowered CPUs from 16 to 15
18:19:52:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 17668 -checkpoint 15 -np 15
18:19:52:WU02:FS00:Started FahCore on PID 15952
18:19:52:WU02:FS00:Core PID:7084
18:19:52:WU02:FS00:FahCore 0xa7 started
18:19:52:WU02:FS00:0xa7:*********************** Log Started 2020-05-24T18:19:52Z ***********************
18:19:52:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:19:52:WU02:FS00:0xa7: Type: 0xa7
18:19:52:WU02:FS00:0xa7: Core: Gromacs
18:19:52:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 705 -lifeline 15952 -checkpoint 15 -np
18:19:52:WU02:FS00:0xa7: 15
18:19:52:WU02:FS00:0xa7:************************************ CBang *************************************
18:19:52:WU02:FS00:0xa7: Date: Oct 26 2019
18:19:52:WU02:FS00:0xa7: Time: 01:38:25
18:19:52:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:19:52:WU02:FS00:0xa7: Branch: master
18:19:52:WU02:FS00:0xa7: Compiler: Visual C++ 2008
18:19:52:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:19:52:WU02:FS00:0xa7: Platform: win32 10
18:19:52:WU02:FS00:0xa7: Bits: 64
18:19:52:WU02:FS00:0xa7: Mode: Release
18:19:52:WU02:FS00:0xa7:************************************ System ************************************
18:19:52:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
18:19:52:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
18:19:52:WU02:FS00:0xa7: CPUs: 16
18:19:52:WU02:FS00:0xa7: Memory: 31.73GiB
18:19:52:WU02:FS00:0xa7:Free Memory: 24.05GiB
18:19:52:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
18:19:52:WU02:FS00:0xa7: OS Version: 6.2
18:19:52:WU02:FS00:0xa7:Has Battery: true
18:19:52:WU02:FS00:0xa7: On Battery: false
18:19:52:WU02:FS00:0xa7: UTC Offset: 2
18:19:52:WU02:FS00:0xa7: PID: 7084
18:19:52:WU02:FS00:0xa7: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
18:19:52:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
18:19:52:WU02:FS00:0xa7: Version: 0.0.18
18:19:52:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:19:52:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
18:19:52:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
18:19:52:WU02:FS00:0xa7: Time: 01:52:30
18:19:52:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:19:53:WU02:FS00:0xa7: Platform: win32 10
18:19:53:WU02:FS00:0xa7: Bits: 64
18:19:53:WU02:FS00:0xa7: Mode: Release
18:19:53:WU02:FS00:0xa7:************************************ Build *************************************
18:19:53:WU02:FS00:0xa7: SIMD: avx_256
18:19:53:WU02:FS00:0xa7:********************************************************************************
18:19:53:WU02:FS00:0xa7:Project: 14719 (Run 223, Clone 0, Gen 46)
18:19:53:WU02:FS00:0xa7:Unit: 0x000000372879986c5ea968f44ca437a1
18:19:53:WU02:FS00:0xa7:Digital signatures verified
18:19:53:WU02:FS00:0xa7:Calling: mdrun -s frame46.tpr -o frame46.trr -cpi state.cpt -cpt 15 -nt 15
18:19:53:WU02:FS00:0xa7:Steps: first=0 total=250000
18:19:54:WU02:FS00:0xa7:Completed 99312 out of 250000 steps (39%)
18:19:54:Removing old file 'configs/config-20200510-182417.xml'
18:19:54:Saving configuration to config.xml
18:19:54:<config>
18:19:54: <!-- Network -->
18:19:54: <proxy v=':8080'/>
18:19:54:
18:19:54: <!-- Slot Control -->
18:19:54: <power v='full'/>
18:19:54:
18:19:54: <!-- User Information -->
18:19:54: <passkey v='********************************'/>
18:19:54: <team v='10813'/>
18:19:54: <user v='Ian_Worthington'/>
18:19:54:
18:19:54: <!-- Folding Slots -->
18:19:54: <slot id='0' type='CPU'/>
18:19:54:</config>
18:19:57:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:20:29:WU02:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
18:22:02:WU02:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
18:23:25:WU02:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
18:24:44:WU02:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
18:26:07:WU02:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
18:27:28:WU02:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
18:29:27:WU02:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
18:31:31:WU02:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
18:33:35:WU02:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
18:35:41:WU02:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
18:37:46:WU02:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
18:39:48:WU02:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
18:41:47:WU02:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
18:43:48:WU02:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
18:45:47:WU02:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
18:47:45:WU02:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
18:49:43:WU02:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
18:51:45:WU02:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
18:53:45:WU02:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
18:55:44:WU02:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
18:57:43:WU02:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
18:59:43:WU02:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
19:01:42:WU02:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
19:03:41:WU02:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
19:05:41:WU02:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
19:07:40:WU02:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
19:09:37:WU02:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
19:11:35:WU02:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
19:13:33:WU02:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
19:15:31:WU02:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
19:17:29:WU02:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
19:19:28:WU02:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
19:21:27:WU02:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
19:23:26:WU02:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
19:25:29:WU02:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
19:27:29:WU02:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
19:29:19:WU02:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
19:31:26:WU02:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
19:33:27:WU02:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
19:35:30:WU02:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
19:37:32:WU02:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
19:39:31:WU02:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
19:41:29:WU02:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
19:43:27:WU02:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
19:45:25:WU02:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
19:47:24:WU02:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
19:49:21:WU02:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
19:51:20:WU02:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
19:53:19:WU02:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
19:55:19:WU02:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
19:57:19:WU02:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
19:59:18:WU02:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
20:01:18:WU02:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
20:03:16:WU02:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
20:05:16:WU02:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
20:07:15:WU02:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
20:09:14:WU02:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
20:11:14:WU02:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
20:13:13:WU02:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
20:15:13:WU02:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
20:15:14:WU00:FS00:Connecting to 65.254.110.245:8080
20:15:15:WU00:FS00:Assigned to work server 3.21.157.11
20:15:15:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:16 from 3.21.157.11
20:15:15:WU00:FS00:Connecting to 3.21.157.11:8080
20:15:16:WU00:FS00:Downloading 2.83MiB
20:15:19:WU00:FS00:Download complete
20:15:19:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14702 run:997 clone:0 gen:44 core:0xa7 unit:0x0000002e03159d0b5eae29bc2008eb29
20:17:12:WU02:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
20:17:14:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
20:17:14:WU02:FS00:0xa7:Saving result file dhdl.xvg
20:17:14:WU02:FS00:0xa7:Saving result file frame46.trr
20:17:14:WU02:FS00:0xa7:Saving result file md.log
20:17:14:WU02:FS00:0xa7:Saving result file pullf.xvg
20:17:14:WU02:FS00:0xa7:Saving result file pullx.xvg
20:17:14:WU02:FS00:0xa7:Saving result file science.log
20:17:14:WU02:FS00:0xa7:Saving result file traj_comp.xtc
20:17:14:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
20:17:15:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:17:15:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14719 run:223 clone:0 gen:46 core:0xa7 unit:0x000000372879986c5ea968f44ca437a1
20:17:15:WU02:FS00:Uploading 6.80MiB to 40.121.152.108
20:17:15:WU02:FS00:Connecting to 40.121.152.108:8080
20:17:15:WU00:FS00:Starting
20:17:15:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 17668 -checkpoint 15 -np 16
20:17:15:WU00:FS00:Started FahCore on PID 18072
20:17:15:WU00:FS00:Core PID:1600
20:17:15:WU00:FS00:FahCore 0xa7 started
20:17:15:WU00:FS00:0xa7:*********************** Log Started 2020-05-24T20:17:15Z ***********************
20:17:15:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:17:15:WU00:FS00:0xa7: Type: 0xa7
20:17:15:WU00:FS00:0xa7: Core: Gromacs
20:17:15:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 18072 -checkpoint 15 -np
20:17:15:WU00:FS00:0xa7: 16
20:17:15:WU00:FS00:0xa7:************************************ CBang *************************************
20:17:15:WU00:FS00:0xa7: Date: Oct 26 2019
20:17:15:WU00:FS00:0xa7: Time: 01:38:25
20:17:15:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:17:15:WU00:FS00:0xa7: Branch: master
20:17:15:WU00:FS00:0xa7: Compiler: Visual C++ 2008
20:17:15:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:17:15:WU00:FS00:0xa7: Platform: win32 10
20:17:15:WU00:FS00:0xa7: Bits: 64
20:17:15:WU00:FS00:0xa7: Mode: Release
20:17:15:WU00:FS00:0xa7:************************************ System ************************************
20:17:15:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
20:17:15:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
20:17:15:WU00:FS00:0xa7: CPUs: 16
20:17:15:WU00:FS00:0xa7: Memory: 31.73GiB
20:17:15:WU00:FS00:0xa7:Free Memory: 22.26GiB
20:17:15:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
20:17:15:WU00:FS00:0xa7: OS Version: 6.2
20:17:15:WU00:FS00:0xa7:Has Battery: true
20:17:15:WU00:FS00:0xa7: On Battery: false
20:17:15:WU00:FS00:0xa7: UTC Offset: 2
20:17:15:WU00:FS00:0xa7: PID: 1600
20:17:15:WU00:FS00:0xa7: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
20:17:15:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:17:15:WU00:FS00:0xa7: Version: 0.0.18
20:17:15:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:17:15:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
20:17:15:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
20:17:15:WU00:FS00:0xa7: Time: 01:52:30
20:17:15:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:17:15:WU00:FS00:0xa7:************************************ Build *************************************
20:17:15:WU00:FS00:0xa7: SIMD: avx_256
20:17:15:WU00:FS00:0xa7:********************************************************************************
20:17:15:WU00:FS00:0xa7:Project: 14702 (Run 997, Clone 0, Gen 44)
20:17:15:WU00:FS00:0xa7:Unit: 0x0000002e03159d0b5eae29bc2008eb29
20:17:15:WU00:FS00:0xa7:Reading tar file core.xml
20:17:15:WU00:FS00:0xa7:Reading tar file frame44.tpr
20:17:15:WU00:FS00:0xa7:Digital signatures verified
20:17:15:WU00:FS00:0xa7:Calling: mdrun -s frame44.tpr -o frame44.trr -cpt 15 -nt 16
20:17:21:WU02:FS00:Upload 7.35%
20:17:21:WU00:FS00:0xa7:Steps: first=0 total=250000
20:17:23:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
20:17:27:WU02:FS00:Upload 13.78%
20:17:33:WU02:FS00:Upload 20.21%
20:17:39:WU02:FS00:Upload 26.64%
20:17:45:WU02:FS00:Upload 33.07%
20:17:51:WU02:FS00:Upload 36.75%
20:17:58:WU02:FS00:Upload 44.10%
20:18:04:WU02:FS00:Upload 51.45%
20:18:10:WU02:FS00:Upload 58.80%
20:18:16:WU02:FS00:Upload 66.15%
20:18:22:WU02:FS00:Upload 72.58%
20:18:28:WU02:FS00:Upload 79.93%
20:18:34:WU02:FS00:Upload 86.36%
20:18:40:WU02:FS00:Upload 93.71%
20:18:46:WU02:FS00:Upload 100.00%
20:18:46:WU02:FS00:Upload complete
20:18:46:WU02:FS00:Server responded WORK_ACK (400)
20:18:47:WU02:FS00:Final credit estimate, 2962.00 points
20:18:47:WU02:FS00:Cleaning up
20:19:16:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
20:21:09:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
20:23:03:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
20:24:58:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
20:26:51:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
20:28:45:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
20:30:33:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
20:32:04:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
20:33:51:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
20:35:37:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
20:37:19:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
20:38:36:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
20:39:53:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
20:41:09:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
20:42:25:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
20:43:42:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
20:44:59:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
20:46:14:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
20:47:31:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
20:48:46:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
20:50:03:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
20:51:19:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
20:52:34:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
20:53:52:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
20:55:13:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
20:56:32:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
20:57:49:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
20:59:10:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
21:00:24:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
21:01:38:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
21:02:54:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
21:04:09:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
21:05:25:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
21:06:40:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
21:07:55:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
21:09:09:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
21:10:24:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
21:11:40:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
21:12:56:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
21:14:11:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
21:15:27:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
21:16:41:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
21:17:57:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
21:19:13:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
21:20:31:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
21:21:48:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
21:23:04:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
21:24:22:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
21:25:42:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
21:26:58:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
21:28:14:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
21:29:37:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
21:31:22:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
21:32:53:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
21:34:40:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
21:36:26:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
21:37:53:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
21:39:09:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
21:40:24:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
21:41:55:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
21:43:49:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
21:45:43:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
21:47:31:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
21:49:25:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
21:51:20:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
21:53:14:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
21:55:09:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
21:57:03:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
21:58:54:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
22:00:45:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
22:02:25:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
22:04:23:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
22:06:31:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
22:08:42:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
22:10:33:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
22:12:22:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
22:14:07:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
22:15:57:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
22:17:59:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
22:19:57:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
22:22:00:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
22:24:06:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
22:26:05:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
22:28:05:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
22:30:05:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
22:32:10:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
22:34:14:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
22:36:17:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
22:38:18:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
22:40:18:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
22:42:14:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
22:44:11:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
22:46:09:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
22:48:07:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
22:50:05:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
22:52:05:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
22:54:06:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
22:56:03:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
22:58:09:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
22:58:09:WU01:FS00:Connecting to 65.254.110.245:8080
22:58:10:WU01:FS00:Assigned to work server 150.136.14.110
22:58:10:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:16 from 150.136.14.110
22:58:10:WU01:FS00:Connecting to 150.136.14.110:8080
22:58:10:WU01:FS00:Downloading 3.27MiB
22:58:15:WU01:FS00:Download complete
22:58:15:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16418 run:0 clone:1748 gen:229 core:0xa7 unit:0x0000010196880e6e5e825575eb15c80a
23:00:06:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
23:00:08:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
23:00:08:WU00:FS00:0xa7:Saving result file dhdl.xvg
23:00:08:WU00:FS00:0xa7:Saving result file frame44.trr
23:00:08:WU00:FS00:0xa7:Saving result file md.log
23:00:08:WU00:FS00:0xa7:Saving result file pullf.xvg
23:00:08:WU00:FS00:0xa7:Saving result file pullx.xvg
23:00:08:WU00:FS00:0xa7:Saving result file science.log
23:00:08:WU00:FS00:0xa7:Saving result file traj_comp.xtc
23:00:08:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
23:00:08:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:00:08:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14702 run:997 clone:0 gen:44 core:0xa7 unit:0x0000002e03159d0b5eae29bc2008eb29
23:00:08:WU00:FS00:Uploading 6.80MiB to 3.21.157.11
23:00:08:WU00:FS00:Connecting to 3.21.157.11:8080
23:00:08:WU01:FS00:Starting
23:00:08:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 17668 -checkpoint 15 -np 16
23:00:08:WU01:FS00:Started FahCore on PID 18696
23:00:08:WU01:FS00:Core PID:1512
23:00:08:WU01:FS00:FahCore 0xa7 started
23:00:09:WU01:FS00:0xa7:*********************** Log Started 2020-05-24T23:00:08Z ***********************
23:00:09:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:00:09:WU01:FS00:0xa7: Type: 0xa7
23:00:09:WU01:FS00:0xa7: Core: Gromacs
23:00:09:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 18696 -checkpoint 15 -np
23:00:09:WU01:FS00:0xa7: 16
23:00:09:WU01:FS00:0xa7:************************************ CBang *************************************
23:00:09:WU01:FS00:0xa7: Date: Oct 26 2019
23:00:09:WU01:FS00:0xa7: Time: 01:38:25
23:00:09:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:00:09:WU01:FS00:0xa7: Branch: master
23:00:09:WU01:FS00:0xa7: Compiler: Visual C++ 2008
23:00:09:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:00:09:WU01:FS00:0xa7: Platform: win32 10
23:00:09:WU01:FS00:0xa7: Bits: 64
23:00:09:WU01:FS00:0xa7: Mode: Release
23:00:09:WU01:FS00:0xa7:************************************ System ************************************
23:00:09:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
23:00:09:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
23:00:09:WU01:FS00:0xa7: CPUs: 16
23:00:09:WU01:FS00:0xa7: Memory: 31.73GiB
23:00:09:WU01:FS00:0xa7:Free Memory: 20.57GiB
23:00:09:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
23:00:09:WU01:FS00:0xa7: OS Version: 6.2
23:00:09:WU01:FS00:0xa7:Has Battery: true
23:00:09:WU01:FS00:0xa7: On Battery: false
23:00:09:WU01:FS00:0xa7: UTC Offset: 2
23:00:09:WU01:FS00:0xa7: PID: 1512
23:00:09:WU01:FS00:0xa7: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
23:00:09:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
23:00:09:WU01:FS00:0xa7: Version: 0.0.18
23:00:09:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:00:09:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
23:00:09:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
23:00:09:WU01:FS00:0xa7: Time: 01:52:30
23:00:09:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:00:09:WU01:FS00:0xa7:************************************ Build *************************************
23:00:09:WU01:FS00:0xa7: SIMD: avx_256
23:00:09:WU01:FS00:0xa7:********************************************************************************
23:00:09:WU01:FS00:0xa7:Project: 16418 (Run 0, Clone 1748, Gen 229)
23:00:09:WU01:FS00:0xa7:Unit: 0x0000010196880e6e5e825575eb15c80a
23:00:09:WU01:FS00:0xa7:Reading tar file core.xml
23:00:09:WU01:FS00:0xa7:Reading tar file frame229.tpr
23:00:09:WU01:FS00:0xa7:Digital signatures verified
23:00:09:WU01:FS00:0xa7:Calling: mdrun -s frame229.tpr -o frame229.trr -x frame229.xtc -cpt 15 -nt 16
23:00:12:WU01:FS00:0xa7:Steps: first=57250000 total=250000
23:00:13:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
23:00:14:WU00:FS00:Upload 8.28%
23:00:20:WU00:FS00:Upload 14.71%
23:00:26:WU00:FS00:Upload 22.07%
23:00:32:WU00:FS00:Upload 28.51%
23:00:38:WU00:FS00:Upload 35.86%
23:00:44:WU00:FS00:Upload 43.22%
23:00:50:WU00:FS00:Upload 50.58%
23:00:56:WU00:FS00:Upload 57.94%
23:01:02:WU00:FS00:Upload 65.29%
23:01:08:WU00:FS00:Upload 71.73%
23:01:14:WU00:FS00:Upload 79.09%
23:01:20:WU00:FS00:Upload 86.44%
23:01:26:WU00:FS00:Upload 92.88%
23:01:32:WU00:FS00:Upload 99.32%
23:01:33:WU00:FS00:Upload complete
23:01:33:WU00:FS00:Server responded WORK_ACK (400)
23:01:33:WU00:FS00:Final credit estimate, 4202.00 points
23:01:33:WU00:FS00:Cleaning up
23:01:50:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
23:03:25:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
23:05:04:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
23:06:42:WU01:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
23:08:19:WU01:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
23:09:57:WU01:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
23:11:37:WU01:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
23:13:11:WU01:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
23:14:49:WU01:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
23:16:32:WU01:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
23:18:05:WU01:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
23:19:37:WU01:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
23:21:07:WU01:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
23:22:16:WU01:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
23:23:28:WU01:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
23:24:38:WU01:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
23:25:50:WU01:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
23:26:59:WU01:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
23:28:11:WU01:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
23:29:19:WU01:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
23:30:43:WU01:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
23:32:10:WU01:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
23:33:35:WU01:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
23:35:06:WU01:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
23:36:39:WU01:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
23:38:08:WU01:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
23:39:15:WU01:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
23:40:26:WU01:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
23:41:35:WU01:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
23:42:43:WU01:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
23:43:51:WU01:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
23:45:01:WU01:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
23:46:12:WU01:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
23:47:18:WU01:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
23:48:28:WU01:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
23:49:37:WU01:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
23:50:49:WU01:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
23:51:57:WU01:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
23:53:09:WU01:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
23:54:18:WU01:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
23:55:29:WU01:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
23:56:42:WU01:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
23:57:50:WU01:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
23:59:01:WU01:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
00:00:09:WU01:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
00:01:20:WU01:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
00:02:28:WU01:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
00:03:37:WU01:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
00:04:47:WU01:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
00:05:56:WU01:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
00:07:12:WU01:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
00:08:19:WU01:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
00:09:28:WU01:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
00:10:36:WU01:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
00:11:44:WU01:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
00:12:58:WU01:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
00:14:04:WU01:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
00:15:13:WU01:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
00:16:25:WU01:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
00:17:32:WU01:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
******************************* Date: 2020-05-25 *******************************
00:19:03:WU01:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
00:20:41:WU01:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
00:22:22:WU01:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
00:23:59:WU01:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
00:25:35:WU01:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
00:27:15:WU01:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
00:28:53:WU01:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
00:30:33:WU01:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
00:32:18:WU01:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
00:33:59:WU01:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
00:35:39:WU01:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
00:37:16:WU01:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
00:39:00:WU01:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
00:40:44:WU01:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
00:42:21:WU01:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
00:44:04:WU01:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
00:45:45:WU01:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
00:47:23:WU01:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
00:49:05:WU01:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
00:50:47:WU01:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
00:52:28:WU01:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
00:54:04:WU01:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
00:55:45:WU01:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
00:57:23:WU01:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
00:59:00:WU01:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
01:00:38:WU01:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
01:02:14:WU01:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
01:03:51:WU01:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
01:05:28:WU01:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
01:07:07:WU01:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
01:08:45:WU01:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
01:10:21:WU01:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
01:11:59:WU01:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
01:13:37:WU01:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
01:15:13:WU01:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
01:16:54:WU01:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
01:18:22:WU01:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
01:19:36:WU01:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
01:20:46:WU01:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
01:20:48:WU00:FS00:Connecting to 65.254.110.245:8080
01:20:49:WU00:FS00:Assigned to work server 206.223.170.146
01:20:49:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:16 from 206.223.170.146
01:20:49:WU00:FS00:Connecting to 206.223.170.146:8080
01:20:51:WU00:FS00:Downloading 8.47MiB
01:20:57:WU00:FS00:Download 46.49%
01:21:02:WU00:FS00:Download complete
01:21:02:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14235 run:67 clone:3 gen:26 core:0xa7 unit:0x00000022cedfaa925ea376e6fafd3c3d
01:21:59:WU01:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
01:22:01:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
01:22:01:WU01:FS00:0xa7:Saving result file frame229.trr
01:22:01:WU01:FS00:0xa7:Saving result file frame229.xtc
01:22:01:WU01:FS00:0xa7:Saving result file md.log
01:22:01:WU01:FS00:0xa7:Saving result file science.log
01:22:01:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
01:22:02:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:22:02:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:16418 run:0 clone:1748 gen:229 core:0xa7 unit:0x0000010196880e6e5e825575eb15c80a
01:22:02:WU01:FS00:Uploading 2.75MiB to 150.136.14.110
01:22:02:WU01:FS00:Connecting to 150.136.14.110:8080
01:22:02:WU00:FS00:Starting
01:22:02:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 17668 -checkpoint 15 -np 16
01:22:02:WU00:FS00:Started FahCore on PID 8516
01:22:02:WU00:FS00:Core PID:22716
01:22:02:WU00:FS00:FahCore 0xa7 started
01:22:02:WU00:FS00:0xa7:*********************** Log Started 2020-05-25T01:22:02Z ***********************
01:22:02:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
01:22:02:WU00:FS00:0xa7: Type: 0xa7
01:22:02:WU00:FS00:0xa7: Core: Gromacs
01:22:02:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 8516 -checkpoint 15 -np
01:22:02:WU00:FS00:0xa7: 16
01:22:02:WU00:FS00:0xa7:************************************ CBang *************************************
01:22:02:WU00:FS00:0xa7: Date: Oct 26 2019
01:22:02:WU00:FS00:0xa7: Time: 01:38:25
01:22:02:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
01:22:02:WU00:FS00:0xa7: Branch: master
01:22:02:WU00:FS00:0xa7: Compiler: Visual C++ 2008
01:22:02:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:22:02:WU00:FS00:0xa7: Platform: win32 10
01:22:02:WU00:FS00:0xa7: Bits: 64
01:22:02:WU00:FS00:0xa7: Mode: Release
01:22:02:WU00:FS00:0xa7:************************************ System ************************************
01:22:02:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
01:22:02:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
01:22:02:WU00:FS00:0xa7: CPUs: 16
01:22:02:WU00:FS00:0xa7: Memory: 31.73GiB
01:22:02:WU00:FS00:0xa7:Free Memory: 21.52GiB
01:22:02:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
01:22:02:WU00:FS00:0xa7: OS Version: 6.2
01:22:02:WU00:FS00:0xa7:Has Battery: true
01:22:02:WU00:FS00:0xa7: On Battery: false
01:22:02:WU00:FS00:0xa7: UTC Offset: 2
01:22:02:WU00:FS00:0xa7: PID: 22716
01:22:02:WU00:FS00:0xa7: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
01:22:02:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
01:22:02:WU00:FS00:0xa7: Version: 0.0.18
01:22:02:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:22:02:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
01:22:02:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
01:22:02:WU00:FS00:0xa7: Time: 01:52:30
01:22:02:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
01:22:03:WU00:FS00:0xa7: Branch: master
01:22:03:WU00:FS00:0xa7: Compiler: Visual C++ 2008
01:22:03:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:22:03:WU00:FS00:0xa7: Platform: win32 10
01:22:03:WU00:FS00:0xa7: Bits: 64
01:22:03:WU00:FS00:0xa7: Mode: Release
01:22:03:WU00:FS00:0xa7:************************************ Build *************************************
01:22:03:WU00:FS00:0xa7: SIMD: avx_256
01:22:03:WU00:FS00:0xa7:********************************************************************************
01:22:03:WU00:FS00:0xa7:Project: 14235 (Run 67, Clone 3, Gen 26)
01:22:03:WU00:FS00:0xa7:Unit: 0x00000022cedfaa925ea376e6fafd3c3d
01:22:03:WU00:FS00:0xa7:Reading tar file core.xml
01:22:03:WU00:FS00:0xa7:Reading tar file frame26.tpr
01:22:03:WU00:FS00:0xa7:Digital signatures verified
01:22:03:WU00:FS00:0xa7:Calling: mdrun -s frame26.tpr -o frame26.trr -x frame26.xtc -cpt 15 -nt 16
01:22:03:WU00:FS00:0xa7:Steps: first=6500000 total=250000
01:22:04:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
01:22:09:WU01:FS00:Upload 6.83%
01:22:15:WU01:FS00:Upload 13.66%
01:22:22:WU01:FS00:Upload 20.48%
01:22:30:WU01:FS00:Upload 27.31%
01:22:36:WU01:FS00:Upload 34.14%
01:22:42:WU01:FS00:Upload 40.97%
01:22:49:WU01:FS00:Upload 47.80%
01:22:56:WU01:FS00:Upload 59.17%
01:23:02:WU01:FS00:Upload 63.73%
01:23:09:WU01:FS00:Upload 70.55%
01:23:15:WU01:FS00:Upload 77.38%
01:23:22:WU01:FS00:Upload 84.21%
01:23:32:WU01:FS00:Upload 91.04%
01:23:42:WU01:FS00:Upload 95.59%
01:23:48:WU01:FS00:Upload 100.00%
01:23:51:WU01:FS00:Upload complete
01:23:51:WU01:FS00:Server responded WORK_ACK (400)
01:23:51:WU01:FS00:Final credit estimate, 3688.00 points
01:23:51:WU01:FS00:Cleaning up
01:25:53:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
01:29:45:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
01:34:11:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
01:38:44:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
01:42:34:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
01:46:15:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
01:50:10:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
01:54:01:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
01:57:45:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
02:01:33:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
02:05:17:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
02:09:01:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
02:12:44:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
02:16:28:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
02:20:49:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
02:25:56:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
02:31:14:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
02:36:39:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
02:41:58:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
02:47:06:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
02:52:14:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
02:57:19:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
03:02:24:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
03:07:28:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
03:12:34:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
03:17:35:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
03:21:40:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
03:25:27:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
03:29:17:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
03:33:40:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
03:38:20:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
03:42:05:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
03:45:52:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
03:49:38:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
03:53:23:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
03:57:09:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
04:00:54:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
04:04:39:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
04:08:25:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
04:12:10:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
04:15:54:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
04:20:23:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
04:25:33:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
04:30:40:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
04:36:04:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
04:41:19:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
04:46:23:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
04:51:25:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
04:56:34:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
05:01:38:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
05:06:41:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
05:11:46:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
05:16:50:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
05:20:57:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
05:24:50:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
05:28:37:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
05:32:57:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
05:37:34:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
05:41:26:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
05:45:08:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
05:48:49:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
05:52:32:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
05:56:13:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
05:59:51:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
06:03:27:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
06:07:08:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
06:10:46:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
06:14:24:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
06:18:16:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
06:23:18:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
06:28:26:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
06:33:43:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
06:39:12:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
06:44:19:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
06:49:24:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
06:54:30:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
06:59:37:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
07:04:41:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
07:09:50:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
07:14:54:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
07:19:24:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
07:23:11:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
07:26:55:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
07:30:52:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
07:35:22:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
07:39:45:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
07:43:30:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
07:47:15:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
07:51:02:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
07:54:50:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
07:58:44:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
08:02:32:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
08:06:16:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
08:10:05:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
08:13:51:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
08:17:40:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
08:22:49:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
08:27:56:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
08:33:13:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
08:33:14:WU01:FS00:Connecting to 65.254.110.245:8080
08:33:14:WU01:FS00:Assigned to work server 40.114.52.201
08:33:14:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:16 from 40.114.52.201
08:33:14:WU01:FS00:Connecting to 40.114.52.201:8080
08:33:15:WU01:FS00:Downloading 2.14MiB
08:33:17:WU01:FS00:Download complete
08:33:17:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13851 run:0 clone:10733 gen:107 core:0xa7 unit:0x00000086287234c95e730270ee26c4d6
08:38:42:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
08:38:51:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
08:38:51:WU00:FS00:0xa7:Saving result file frame26.trr
08:38:51:WU00:FS00:0xa7:Saving result file frame26.xtc
08:38:51:WU00:FS00:0xa7:Saving result file md.log
08:38:51:WU00:FS00:0xa7:Saving result file science.log
08:38:51:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
08:38:52:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:38:52:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14235 run:67 clone:3 gen:26 core:0xa7 unit:0x00000022cedfaa925ea376e6fafd3c3d
08:38:52:WU00:FS00:Uploading 7.13MiB to 206.223.170.146
08:38:52:WU00:FS00:Connecting to 206.223.170.146:8080
08:38:52:WU01:FS00:Starting
08:38:52:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 17668 -checkpoint 15 -np 16
08:38:52:WU01:FS00:Started FahCore on PID 16392
08:38:52:WU01:FS00:Core PID:22948
08:38:52:WU01:FS00:FahCore 0xa7 started
08:38:52:WU01:FS00:0xa7:*********************** Log Started 2020-05-25T08:38:52Z ***********************
08:38:52:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:38:52:WU01:FS00:0xa7: Type: 0xa7
08:38:52:WU01:FS00:0xa7: Core: Gromacs
08:38:52:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 16392 -checkpoint 15 -np
08:38:52:WU01:FS00:0xa7: 16
08:38:52:WU01:FS00:0xa7:************************************ CBang *************************************
08:38:52:WU01:FS00:0xa7: Date: Oct 26 2019
08:38:52:WU01:FS00:0xa7: Time: 01:38:25
08:38:52:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
08:38:52:WU01:FS00:0xa7: Branch: master
08:38:52:WU01:FS00:0xa7: Compiler: Visual C++ 2008
08:38:52:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:38:52:WU01:FS00:0xa7: Platform: win32 10
08:38:52:WU01:FS00:0xa7: Bits: 64
08:38:52:WU01:FS00:0xa7: Mode: Release
08:38:52:WU01:FS00:0xa7:************************************ System ************************************
08:38:52:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
08:38:52:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
08:38:52:WU01:FS00:0xa7: CPUs: 16
08:38:52:WU01:FS00:0xa7: Memory: 31.73GiB
08:38:52:WU01:FS00:0xa7:Free Memory: 20.48GiB
08:38:52:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
08:38:52:WU01:FS00:0xa7: OS Version: 6.2
08:38:52:WU01:FS00:0xa7:Has Battery: true
08:38:52:WU01:FS00:0xa7: On Battery: false
08:38:52:WU01:FS00:0xa7: UTC Offset: 2
08:38:52:WU01:FS00:0xa7: PID: 22948
08:38:52:WU01:FS00:0xa7: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
08:38:52:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
08:38:52:WU01:FS00:0xa7: Version: 0.0.18
08:38:52:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:38:52:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
08:38:52:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
08:38:52:WU01:FS00:0xa7: Time: 01:52:30
08:38:52:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
08:38:52:WU01:FS00:0xa7:************************************ Build *************************************
08:38:52:WU01:FS00:0xa7: SIMD: avx_256
08:38:52:WU01:FS00:0xa7:********************************************************************************
08:38:52:WU01:FS00:0xa7:Project: 13851 (Run 0, Clone 10733, Gen 107)
08:38:52:WU01:FS00:0xa7:Unit: 0x00000086287234c95e730270ee26c4d6
08:38:52:WU01:FS00:0xa7:Reading tar file core.xml
08:38:52:WU01:FS00:0xa7:Reading tar file frame107.tpr
08:38:52:WU01:FS00:0xa7:Digital signatures verified
08:38:52:WU01:FS00:0xa7:Calling: mdrun -s frame107.tpr -o frame107.trr -x frame107.xtc -e frame107.edr -cpt 15 -nt 16
08:38:54:WU01:FS00:0xa7:Steps: first=53500000 total=500000
08:38:55:WU01:FS00:0xa7:Completed 1 out of 500000 steps (0%)
08:38:58:WU00:FS00:Upload 8.77%
08:39:04:WU00:FS00:Upload 14.90%
08:39:10:WU00:FS00:Upload 21.04%
08:39:16:WU00:FS00:Upload 28.05%
08:39:22:WU00:FS00:Upload 35.07%
08:39:28:WU00:FS00:Upload 42.08%
08:39:34:WU00:FS00:Upload 49.10%
08:39:40:WU00:FS00:Upload 56.11%
08:39:46:WU00:FS00:Upload 63.12%
08:39:52:WU00:FS00:Upload 70.14%
08:39:58:WU00:FS00:Upload 76.27%
08:40:04:WU00:FS00:Upload 83.29%
08:40:10:WU00:FS00:Upload 89.42%
08:40:16:WU00:FS00:Upload 96.44%
08:40:20:WU00:FS00:Upload complete
08:40:20:WU00:FS00:Server responded WORK_ACK (400)
08:40:20:WU00:FS00:Final credit estimate, 16137.00 points
08:40:20:WU00:FS00:Cleaning up
08:41:28:WU01:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
08:44:00:WU01:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
08:46:31:WU01:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
08:49:05:WU01:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
08:51:37:WU01:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
08:54:10:WU01:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
08:56:51:WU01:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
08:59:24:WU01:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
09:01:56:WU01:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
09:04:30:WU01:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
09:07:02:WU01:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
09:09:36:WU01:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
09:12:13:WU01:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
09:14:46:WU01:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
09:17:18:WU01:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
09:19:42:WU01:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
09:21:44:WU01:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
09:23:46:WU01:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
09:25:48:WU01:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
09:27:57:WU01:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
09:30:14:WU01:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
09:32:49:WU01:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
09:35:30:WU01:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
09:38:24:WU01:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
09:40:51:WU01:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
09:43:04:WU01:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
09:45:08:WU01:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
09:47:20:WU01:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
09:49:20:WU01:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
09:51:36:WU01:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
09:53:49:WU01:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
09:56:03:WU01:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
09:58:21:WU01:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
10:00:40:WU01:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
10:02:58:WU01:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
10:05:02:WU01:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
10:07:10:WU01:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
10:09:19:WU01:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
10:11:23:WU01:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
10:13:40:WU01:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
10:15:55:WU01:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
10:16:20:FS00:Shutting core down
10:16:20:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 22948
10:16:20:WU01:FS00:0xa7:Exiting, please wait. . .
10:16:22:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
10:16:22:Clean exit
*********************** Log Started 2020-05-25T10:18:02Z ***********************
10:18:02:Trying to access database...
10:18:02:Successfully acquired database lock
10:18:02:Downloading GPUs.txt from assign1.foldingathome.org:80
10:18:02:Connecting to assign1.foldingathome.org:80
10:18:04:Read GPUs.txt
10:18:05:Enabled folding slot 00: READY cpu:16
10:18:06:****************************** FAHClient ******************************
10:18:06: Version: 7.6.13
10:18:06: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:18:06: Copyright: 2020 foldingathome.org
10:18:06: Homepage: https://foldingathome.org/
10:18:06: Date: Apr 27 2020
10:18:06: Time: 21:21:01
10:18:06: Revision: 5a652817f46116b6e135503af97f18e094414e3b
10:18:06: Branch: master
10:18:06: Compiler: Visual C++ 2008
10:18:06: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:18:06: Platform: win32 10
10:18:06: Bits: 32
10:18:06: Mode: Release
10:18:06: Args: --open-web-control
10:18:06: Config: C:\Users\IanWo\AppData\Roaming\FAHClient\config.xml
10:18:06:******************************** CBang ********************************
10:18:06: Date: Apr 24 2020
10:18:06: Time: 17:07:55
10:18:06: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
10:18:06: Bits: 32
10:18:06:******************************* System ********************************
10:18:06: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
10:18:06: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
10:18:06: CPUs: 16
10:18:06: Memory: 31.73GiB
10:18:06: Free Memory: 19.86GiB
10:18:06: Threads: WINDOWS_THREADS
10:18:06: OS Version: 6.2
10:18:06: Has Battery: true
10:18:06: On Battery: false
10:18:06: UTC Offset: 2
10:18:06: PID: 26588
10:18:06: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient
10:18:06: Win32 Service: false
10:18:06: OS: Windows 10 Enterprise
10:18:06: OS Arch: AMD64
10:18:06: GPUs: 2
10:18:06: GPU 0: Bus:0 Slot:2 Func:0 INTEL:0 Gen9p5/GT2 [UHD Graphics 630]
10:18:06: GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:7 TU117M [GeForce GTX 1650 Mobile /
10:18:06: Max-Q]
10:18:06: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
10:18:06:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.45
10:18:06:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
10:18:06:******************************* libFAH ********************************
10:18:06: Date: Apr 15 2020
10:18:06: Time: 14:53:14
10:18:06: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
10:18:06: Bits: 32
10:18:06:***********************************************************************
10:18:06:<config>
10:18:06: <!-- Network -->
10:18:06: <proxy v=':8080'/>
10:18:06:
10:18:06: <!-- Slot Control -->
10:18:06: <power v='full'/>
10:18:06:
10:18:06: <!-- User Information -->
10:18:06: <passkey v='*****'/>
10:18:06: <team v='10813'/>
10:18:06: <user v='Ian_Worthington'/>
10:18:06:
10:18:06: <!-- Folding Slots -->
10:18:06: <slot id='0' type='CPU'/>
10:18:06:</config>
10:18:06:WU01:FS00:Starting
10:18:06:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -np 16
10:18:06:WU01:FS00:Started FahCore on PID 26768
10:18:06:WU01:FS00:Core PID:20032
10:18:06:WU01:FS00:FahCore 0xa7 started
10:18:06:WU01:FS00:0xa7:*********************** Log Started 2020-05-25T10:18:06Z ***********************
10:18:06:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:18:06:WU01:FS00:0xa7: Type: 0xa7
10:18:06:WU01:FS00:0xa7: Core: Gromacs
10:18:06:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 26768 -checkpoint 15 -np
10:18:06:WU01:FS00:0xa7: 16
10:18:06:WU01:FS00:0xa7:************************************ CBang *************************************
10:18:06:WU01:FS00:0xa7: Date: Oct 26 2019
10:18:06:WU01:FS00:0xa7: Time: 01:38:25
10:18:06:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:18:06:WU01:FS00:0xa7: Branch: master
10:18:06:WU01:FS00:0xa7: Compiler: Visual C++ 2008
10:18:06:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:18:06:WU01:FS00:0xa7: Platform: win32 10
10:18:06:WU01:FS00:0xa7: Bits: 64
10:18:06:WU01:FS00:0xa7: Mode: Release
10:18:06:WU01:FS00:0xa7:************************************ System ************************************
10:18:06:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
10:18:06:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
10:18:06:WU01:FS00:0xa7: CPUs: 16
10:18:06:WU01:FS00:0xa7: Memory: 31.73GiB
10:18:06:WU01:FS00:0xa7:Free Memory: 19.82GiB
10:18:06:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
10:18:06:WU01:FS00:0xa7: OS Version: 6.2
10:18:06:WU01:FS00:0xa7:Has Battery: true
10:18:06:WU01:FS00:0xa7: On Battery: false
10:18:06:WU01:FS00:0xa7: UTC Offset: 2
10:18:06:WU01:FS00:0xa7: PID: 20032
10:18:06:WU01:FS00:0xa7: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
10:18:06:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
10:18:06:WU01:FS00:0xa7: Version: 0.0.18
10:18:06:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:18:06:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
10:18:06:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
10:18:06:WU01:FS00:0xa7: Time: 01:52:30
10:18:06:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:18:06:WU01:FS00:0xa7:************************************ Build *************************************
10:18:06:WU01:FS00:0xa7: SIMD: avx_256
10:18:06:WU01:FS00:0xa7:********************************************************************************
10:18:06:WU01:FS00:0xa7:Project: 13851 (Run 0, Clone 10733, Gen 107)
10:18:06:WU01:FS00:0xa7:Unit: 0x00000086287234c95e730270ee26c4d6
10:18:06:WU01:FS00:0xa7:Digital signatures verified
10:18:06:WU01:FS00:0xa7:Calling: mdrun -s frame107.tpr -o frame107.trr -x frame107.xtc -e frame107.edr -cpi state.cpt -cpt 15 -nt 16
10:18:06:WU01:FS00:0xa7:Steps: first=53500000 total=500000
10:18:08:WU01:FS00:0xa7:Completed 206042 out of 500000 steps (41%)
10:18:09:17:127.0.0.1:New Web session
10:19:20:Adding folding slot 01: READY gpu:0:Gen9p5/GT2 [UHD Graphics 630]
10:19:20:Removing old file 'configs/config-20200520-143435.xml'
10:19:20:Saving configuration to config.xml
10:19:20:<config>
10:19:20: <!-- Network -->
10:19:20: <proxy v=':8080'/>
10:19:20:
10:19:20: <!-- Slot Control -->
10:19:20: <power v='full'/>
10:19:20:
10:19:20: <!-- User Information -->
10:19:20: <passkey v='*****'/>
10:19:20: <team v='10813'/>
10:19:20: <user v='Ian_Worthington'/>
10:19:20:
10:19:20: <!-- Folding Slots -->
10:19:20: <slot id='0' type='CPU'/>
10:19:20: <slot id='1' type='GPU'/>
10:19:20:</config>
10:19:20:FS00:Shutting core down
10:19:20:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 20032
10:19:20:WU01:FS00:0xa7:Exiting, please wait. . .
10:19:20:WU00:FS01:Connecting to assign1.foldingathome.org:80
10:19:21:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
10:19:21:WU00:FS01:Connecting to assign2.foldingathome.org:80
10:19:21:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
10:19:22:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
10:19:22:WU00:FS01:Connecting to assign3.foldingathome.org:80
10:19:22:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
10:19:22:WU01:FS00:Starting
10:19:22:WARNING:WU01:FS00:Changed SMP threads from 16 to 15 this can cause some work units to fail
10:19:22:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -np 15
10:19:22:WU01:FS00:Started FahCore on PID 26740
10:19:22:WU01:FS00:Core PID:9276
10:19:22:WU01:FS00:FahCore 0xa7 started
10:19:22:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
10:19:22:WU00:FS01:Connecting to assign4.foldingathome.org:80
10:19:23:WU01:FS00:0xa7:*********************** Log Started 2020-05-25T10:19:22Z ***********************
10:19:23:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:19:23:WU01:FS00:0xa7: Type: 0xa7
10:19:23:WU01:FS00:0xa7: Core: Gromacs
10:19:23:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 26740 -checkpoint 15 -np
10:19:23:WU01:FS00:0xa7: 15
10:19:23:WU01:FS00:0xa7:************************************ CBang *************************************
10:19:23:WU01:FS00:0xa7: Date: Oct 26 2019
10:19:23:WU01:FS00:0xa7: Time: 01:38:25
10:19:23:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:19:23:WU01:FS00:0xa7: Branch: master
10:19:23:WU01:FS00:0xa7: Compiler: Visual C++ 2008
10:19:23:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:19:23:WU01:FS00:0xa7: Platform: win32 10
10:19:23:WU01:FS00:0xa7: Bits: 64
10:19:23:WU01:FS00:0xa7: Mode: Release
10:19:23:WU01:FS00:0xa7:************************************ System ************************************
10:19:23:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
10:19:23:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
10:19:23:WU01:FS00:0xa7: CPUs: 16
10:19:23:WU01:FS00:0xa7: Memory: 31.73GiB
10:19:23:WU01:FS00:0xa7:Free Memory: 19.80GiB
10:19:23:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
10:19:23:WU01:FS00:0xa7: OS Version: 6.2
10:19:23:WU01:FS00:0xa7:Has Battery: true
10:19:23:WU01:FS00:0xa7: On Battery: false
10:19:23:WU01:FS00:0xa7: UTC Offset: 2
10:19:23:WU01:FS00:0xa7: PID: 9276
10:19:23:WU01:FS00:0xa7: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
10:19:23:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
10:19:23:WU01:FS00:0xa7: Version: 0.0.18
10:19:23:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:19:23:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
10:19:23:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
10:19:23:WU01:FS00:0xa7: Time: 01:52:30
10:19:23:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:19:23:WU01:FS00:0xa7:************************************ Build *************************************
10:19:23:WU01:FS00:0xa7: SIMD: avx_256
10:19:23:WU01:FS00:0xa7:********************************************************************************
10:19:23:WU01:FS00:0xa7:Project: 13851 (Run 0, Clone 10733, Gen 107)
10:19:23:WU01:FS00:0xa7:Unit: 0x00000086287234c95e730270ee26c4d6
10:19:23:WU01:FS00:0xa7:Digital signatures verified
10:19:23:WU01:FS00:0xa7:Calling: mdrun -s frame107.tpr -o frame107.trr -x frame107.xtc -e frame107.edr -cpi state.cpt -cpt 15 -nt 15
10:19:23:WU01:FS00:0xa7:Steps: first=53500000 total=500000
10:19:24:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
10:19:24:ERROR:WU00:FS01:Exception: Could not get an assignment
10:19:24:WU00:FS01:Connecting to assign1.foldingathome.org:80
10:19:25:WU01:FS00:0xa7:Completed 209182 out of 500000 steps (41%)
10:19:25:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
10:19:25:WU00:FS01:Connecting to assign2.foldingathome.org:80
10:19:26:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
10:19:26:WU00:FS01:Connecting to assign3.foldingathome.org:80
10:19:26:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
10:19:26:WU00:FS01:Connecting to assign4.foldingathome.org:80
10:19:27:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
10:19:27:ERROR:WU00:FS01:Exception: Could not get an assignment
10:19:49:WU01:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
10:20:04:Removing old file 'configs/config-20200521-213820.xml'
10:20:04:Saving configuration to config.xml
10:20:04:<config>
10:20:04: <!-- Network -->
10:20:04: <proxy v=':8080'/>
10:20:04:
10:20:04: <!-- Slot Control -->
10:20:04: <power v='full'/>
10:20:04:
10:20:04: <!-- User Information -->
10:20:04: <passkey v='*****'/>
10:20:04: <team v='10813'/>
10:20:04: <user v='Ian_Worthington'/>
10:20:04:
10:20:04: <!-- Folding Slots -->
10:20:04: <slot id='0' type='CPU'/>
10:20:04: <slot id='1' type='GPU'/>
10:20:04:</config>
10:20:24:WU00:FS01:Connecting to assign1.foldingathome.org:80
10:20:25:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
10:20:25:WU00:FS01:Connecting to assign2.foldingathome.org:80
10:20:26:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
10:20:26:WU00:FS01:Connecting to assign3.foldingathome.org:80
10:20:26:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
10:20:26:WU00:FS01:Connecting to assign4.foldingathome.org:80
10:20:27:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
10:20:27:ERROR:WU00:FS01:Exception: Could not get an assignment
10:21:53:WU01:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
10:22:01:WU00:FS01:Connecting to assign1.foldingathome.org:80
10:22:02:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
10:22:02:WU00:FS01:Connecting to assign2.foldingathome.org:80
10:22:03:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
10:22:03:WU00:FS01:Connecting to assign3.foldingathome.org:80
10:22:03:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
10:22:03:WU00:FS01:Connecting to assign4.foldingathome.org:80
10:22:04:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
10:22:04:ERROR:WU00:FS01:Exception: Could not get an assignment
10:23:57:WU01:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
10:24:39:WU00:FS01:Connecting to assign1.foldingathome.org:80
10:24:39:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
10:24:39:WU00:FS01:Connecting to assign2.foldingathome.org:80
10:24:39:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
10:24:39:WU00:FS01:Connecting to assign3.foldingathome.org:80
10:24:40:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
10:24:40:WU00:FS01:Connecting to assign4.foldingathome.org:80
10:24:41:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
10:24:41:ERROR:WU00:FS01:Exception: Could not get an assignment
10:25:43:31:127.0.0.1:New Web session
10:26:14:WU01:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
10:28:26:WU01:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
10:28:53:WU00:FS01:Connecting to assign1.foldingathome.org:80
10:28:54:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
10:28:54:WU00:FS01:Connecting to assign2.foldingathome.org:80
10:28:54:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
10:28:54:WU00:FS01:Connecting to assign3.foldingathome.org:80
10:28:55:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
10:28:55:WU00:FS01:Connecting to assign4.foldingathome.org:80
10:28:55:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
10:28:55:ERROR:WU00:FS01:Exception: Could not get an assignment
10:31:00:WU01:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
10:33:42:WU01:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
10:35:44:WU00:FS01:Connecting to assign1.foldingathome.org:80
10:35:45:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
10:35:45:WU00:FS01:Connecting to assign2.foldingathome.org:80
10:35:45:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
10:35:45:WU00:FS01:Connecting to assign3.foldingathome.org:80
10:35:46:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
10:35:46:WU00:FS01:Connecting to assign4.foldingathome.org:80
10:35:46:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
10:35:46:ERROR:WU00:FS01:Exception: Could not get an assignment
10:36:51:WU01:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
10:39:49:WU01:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
10:42:16:WU01:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
10:44:39:WU01:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
10:46:39:WU01:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
10:46:50:WU00:FS01:Connecting to assign1.foldingathome.org:80
10:46:50:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
10:46:50:WU00:FS01:Connecting to assign2.foldingathome.org:80
10:46:51:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
10:46:51:WU00:FS01:Connecting to assign3.foldingathome.org:80
10:46:52:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
10:46:52:WU00:FS01:Connecting to assign4.foldingathome.org:80
10:46:52:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
10:46:52:ERROR:WU00:FS01:Exception: Could not get an assignment
10:48:54:WU01:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
10:51:12:WU01:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
10:54:02:WU01:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
10:57:03:WU01:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
11:00:00:WU01:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
11:03:02:WU01:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
11:04:47:WU00:FS01:Connecting to assign1.foldingathome.org:80
11:04:48:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
11:04:48:WU00:FS01:Connecting to assign2.foldingathome.org:80
11:04:52:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
11:04:52:WU00:FS01:Connecting to assign3.foldingathome.org:80
11:04:53:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
11:04:53:WU00:FS01:Connecting to assign4.foldingathome.org:80
11:04:55:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
11:04:55:ERROR:WU00:FS01:Exception: Could not get an assignment
11:06:22:WU01:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
11:09:46:WU01:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
11:12:48:WU01:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
11:15:12:WU01:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
11:17:32:WU01:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
11:19:47:WU01:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
11:22:10:WU01:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
11:24:17:WU01:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
11:26:29:WU01:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
11:28:45:WU01:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
11:31:10:WU01:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
11:33:39:WU01:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
11:33:49:WU00:FS01:Connecting to assign1.foldingathome.org:80
11:33:49:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
11:33:49:WU00:FS01:Connecting to assign2.foldingathome.org:80
11:33:50:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
11:33:50:WU00:FS01:Connecting to assign3.foldingathome.org:80
11:33:50:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
11:33:50:WU00:FS01:Connecting to assign4.foldingathome.org:80
11:33:51:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
11:33:51:ERROR:WU00:FS01:Exception: Could not get an assignment
11:36:29:WU01:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
11:39:12:WU01:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
11:41:36:WU01:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
11:43:50:WU01:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
11:46:14:WU01:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
11:48:25:WU01:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
11:50:30:WU01:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
11:52:43:WU01:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
11:55:02:WU01:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
11:57:18:WU01:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
11:59:27:WU01:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
12:01:35:WU01:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
12:03:46:WU01:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
12:06:01:WU01:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
12:08:20:WU01:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
12:10:38:WU01:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
12:12:54:WU01:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
12:15:01:WU01:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
12:17:24:WU01:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
12:19:38:WU01:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
12:20:47:WU00:FS01:Connecting to assign1.foldingathome.org:80
12:20:48:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:20:48:WU00:FS01:Connecting to assign2.foldingathome.org:80
12:20:49:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:20:49:WU00:FS01:Connecting to assign3.foldingathome.org:80
12:20:49:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:20:49:WU00:FS01:Connecting to assign4.foldingathome.org:80
12:20:50:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:20:50:ERROR:WU00:FS01:Exception: Could not get an assignment
12:21:39:WU01:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
12:23:41:WU01:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
12:26:01:WU01:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
12:28:10:WU01:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
12:30:16:WU01:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
12:34:04:WU01:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
12:37:27:WU01:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
12:40:14:WU01:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
12:40:14:WU02:FS00:Connecting to assign1.foldingathome.org:80
12:40:15:WU02:FS00:Assigned to work server 69.94.66.7
12:40:15:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:15 from 69.94.66.7
12:40:15:WU02:FS00:Connecting to 69.94.66.7:8080
12:40:15:WU02:FS00:Downloading 2.84MiB
12:40:18:WU02:FS00:Download complete
12:40:18:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14379 run:589 clone:3 gen:87 core:0xa7 unit:0x00000067455e42075e933032449ef745
12:42:55:WU01:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
12:42:57:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
12:42:57:WU01:FS00:0xa7:Saving result file frame107.edr
12:42:57:WU01:FS00:0xa7:Saving result file frame107.trr
12:42:57:WU01:FS00:0xa7:Saving result file frame107.xtc
12:42:57:WU01:FS00:0xa7:Saving result file md.log
12:42:57:WU01:FS00:0xa7:Saving result file science.log
12:42:57:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
12:42:57:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:42:57:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13851 run:0 clone:10733 gen:107 core:0xa7 unit:0x00000086287234c95e730270ee26c4d6
12:42:57:WU01:FS00:Uploading 2.49MiB to 40.114.52.201
12:42:57:WU01:FS00:Connecting to 40.114.52.201:8080
12:42:57:WU02:FS00:Starting
12:42:57:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -np 15
12:42:57:WU02:FS00:Started FahCore on PID 12328
12:42:58:WU02:FS00:Core PID:3488
12:42:58:WU02:FS00:FahCore 0xa7 started
12:42:59:WU02:FS00:0xa7:*********************** Log Started 2020-05-25T12:42:59Z ***********************
12:42:59:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:42:59:WU02:FS00:0xa7: Type: 0xa7
12:42:59:WU02:FS00:0xa7: Core: Gromacs
12:42:59:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 706 -lifeline 12328 -checkpoint 15 -np
12:42:59:WU02:FS00:0xa7: 15
12:42:59:WU02:FS00:0xa7:************************************ CBang *************************************
12:42:59:WU02:FS00:0xa7: Date: Oct 26 2019
12:42:59:WU02:FS00:0xa7: Time: 01:38:25
12:42:59:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
12:42:59:WU02:FS00:0xa7: Branch: master
12:42:59:WU02:FS00:0xa7: Compiler: Visual C++ 2008
12:42:59:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:42:59:WU02:FS00:0xa7: Platform: win32 10
12:42:59:WU02:FS00:0xa7: Bits: 64
12:42:59:WU02:FS00:0xa7: Mode: Release
12:42:59:WU02:FS00:0xa7:************************************ System ************************************
12:42:59:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
12:42:59:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
12:42:59:WU02:FS00:0xa7: CPUs: 16
12:42:59:WU02:FS00:0xa7: Memory: 31.73GiB
12:42:59:WU02:FS00:0xa7:Free Memory: 18.84GiB
12:42:59:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
12:42:59:WU02:FS00:0xa7: OS Version: 6.2
12:42:59:WU02:FS00:0xa7:Has Battery: true
12:42:59:WU02:FS00:0xa7: On Battery: false
12:42:59:WU02:FS00:0xa7: UTC Offset: 2
12:42:59:WU02:FS00:0xa7: PID: 3488
12:42:59:WU02:FS00:0xa7: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
12:42:59:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
12:42:59:WU02:FS00:0xa7: Version: 0.0.18
12:42:59:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:42:59:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
12:42:59:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
12:42:59:WU02:FS00:0xa7: Time: 01:52:30
12:42:59:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
12:42:59:WU02:FS00:0xa7:************************************ Build *************************************
12:42:59:WU02:FS00:0xa7: SIMD: avx_256
12:42:59:WU02:FS00:0xa7:********************************************************************************
12:42:59:WU02:FS00:0xa7:Project: 14379 (Run 589, Clone 3, Gen 87)
12:42:59:WU02:FS00:0xa7:Unit: 0x00000067455e42075e933032449ef745
12:42:59:WU02:FS00:0xa7:Reading tar file core.xml
12:42:59:WU02:FS00:0xa7:Reading tar file frame87.tpr
12:42:59:WU02:FS00:0xa7:Digital signatures verified
12:42:59:WU02:FS00:0xa7:Calling: mdrun -s frame87.tpr -o frame87.trr -cpt 15 -nt 15
12:43:03:WU01:FS00:Upload 20.10%
Re: System unusable whilst GPU folding
12:43:04:WU02:FS00:0xa7:Steps: first=0 total=250000
12:43:06:WU02:FS00:0xa7:Completed 1 out of 250000 steps (0%)
12:43:09:WU01:FS00:Upload 40.20%
12:43:15:WU01:FS00:Upload 57.79%
12:43:21:WU01:FS00:Upload 77.90%
12:43:27:WU01:FS00:Upload 95.48%
12:43:29:WU01:FS00:Upload complete
12:43:29:WU01:FS00:Server responded WORK_ACK (400)
12:43:29:WU01:FS00:Final credit estimate, 5496.00 points
12:43:29:WU01:FS00:Cleaning up
12:45:16:WU02:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
12:47:27:WU02:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
12:49:38:WU02:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
12:51:48:WU02:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
12:53:56:WU02:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
12:56:03:WU02:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
12:58:09:WU02:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
13:00:18:WU02:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
13:02:17:WU02:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
13:03:56:WU02:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
13:05:51:WU02:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
13:07:41:WU02:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
13:09:28:WU02:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
13:11:23:WU02:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
13:13:24:WU02:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
13:15:21:WU02:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
13:17:06:WU02:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
13:19:02:WU02:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
13:20:48:WU00:FS01:Connecting to assign1.foldingathome.org:80
13:20:48:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
13:20:48:WU00:FS01:Connecting to assign2.foldingathome.org:80
13:20:49:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
13:20:49:WU00:FS01:Connecting to assign3.foldingathome.org:80
13:20:49:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
13:20:49:WU02:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
13:20:49:WU00:FS01:Connecting to assign4.foldingathome.org:80
13:20:50:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
13:20:50:ERROR:WU00:FS01:Exception: Could not get an assignment
13:22:40:WU02:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
13:24:29:WU02:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
13:26:20:WU02:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
13:28:09:WU02:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
13:30:04:WU02:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
13:32:13:WU02:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
13:34:08:WU02:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
13:36:16:WU02:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
13:38:19:WU02:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
13:40:11:WU02:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
13:41:53:WU02:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
13:44:06:WU02:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
13:45:57:WU02:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
13:47:41:WU02:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
13:49:31:WU02:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
13:51:12:WU02:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
13:53:04:WU02:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
13:54:53:WU02:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
13:56:43:WU02:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
13:58:33:WU02:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
14:00:29:WU02:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
14:02:39:WU02:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
14:04:44:WU02:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
14:06:49:WU02:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
14:08:54:WU02:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
14:10:53:WU02:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
14:12:43:WU02:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
14:14:39:WU02:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
14:16:41:WU02:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
14:18:39:WU02:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
14:20:36:WU02:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
14:20:48:WU00:FS01:Connecting to assign1.foldingathome.org:80
14:20:48:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
14:20:48:WU00:FS01:Connecting to assign2.foldingathome.org:80
14:20:50:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
14:20:50:WU00:FS01:Connecting to assign3.foldingathome.org:80
14:20:51:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
14:20:51:WU00:FS01:Connecting to assign4.foldingathome.org:80
14:20:53:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
14:20:53:ERROR:WU00:FS01:Exception: Could not get an assignment
14:22:31:WU02:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
14:24:20:WU02:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
14:26:04:WU02:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
14:28:35:WU02:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
14:30:53:WU02:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
14:33:31:WU02:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
14:36:08:WU02:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
14:38:44:WU02:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
14:41:11:WU02:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
14:43:27:WU02:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
14:45:33:WU02:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
14:47:37:WU02:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
14:49:43:WU02:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
14:51:49:WU02:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
14:53:42:WU02:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
14:55:48:WU02:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
14:57:44:WU02:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
14:59:53:WU02:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
15:01:52:WU02:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
15:03:51:WU02:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
15:05:52:WU02:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
15:07:51:WU02:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
15:09:46:WU02:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
15:11:51:WU02:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
15:13:51:WU02:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
15:15:51:WU02:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
15:17:52:WU02:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
15:19:55:WU02:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
15:20:48:WU00:FS01:Connecting to assign1.foldingathome.org:80
15:20:48:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:20:48:WU00:FS01:Connecting to assign2.foldingathome.org:80
15:20:49:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:20:49:WU00:FS01:Connecting to assign3.foldingathome.org:80
15:20:50:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
15:20:50:WU00:FS01:Connecting to assign4.foldingathome.org:80
15:20:50:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
15:20:50:ERROR:WU00:FS01:Exception: Could not get an assignment
15:21:54:WU02:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
15:23:53:WU02:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
15:25:54:WU02:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
15:27:52:WU02:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
15:29:51:WU02:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
15:32:14:WU02:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
15:34:28:WU02:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
15:36:48:WU02:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
15:39:06:WU02:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
15:41:21:WU02:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
15:43:20:WU02:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
15:45:21:WU02:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
15:47:21:WU02:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
15:49:18:WU02:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
15:51:17:WU02:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
15:53:22:WU02:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
15:55:27:WU02:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
15:57:30:WU02:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
15:59:32:WU02:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
16:01:27:WU02:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
16:03:29:WU02:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
16:03:29:WU01:FS00:Connecting to assign1.foldingathome.org:80
16:03:30:WU01:FS00:Assigned to work server 128.252.203.4
16:03:30:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:15 from 128.252.203.4
16:03:30:WU01:FS00:Connecting to 128.252.203.4:8080
16:03:31:ERROR:WU01:FS00:Exception: Server did not assign work unit
16:03:31:WU01:FS00:Connecting to assign1.foldingathome.org:80
16:03:32:WU01:FS00:Assigned to work server 155.247.164.213
16:03:32:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:15 from 155.247.164.213
16:03:32:WU01:FS00:Connecting to 155.247.164.213:8080
16:03:33:WU01:FS00:Downloading 2.82MiB
16:03:39:WU01:FS00:Download 62.10%
16:03:42:WU01:FS00:Download complete
16:03:42:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14823 run:330 clone:1 gen:40 core:0xa7 unit:0x0000002d9bf7a4d55ea30d94cfba13df
16:05:36:WU02:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
16:05:39:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
16:05:39:WU02:FS00:0xa7:Saving result file dhdl.xvg
16:05:39:WU02:FS00:0xa7:Saving result file frame87.trr
16:05:39:WU02:FS00:0xa7:Saving result file md.log
16:05:39:WU02:FS00:0xa7:Saving result file pullf.xvg
16:05:39:WU02:FS00:0xa7:Saving result file pullx.xvg
16:05:39:WU02:FS00:0xa7:Saving result file science.log
16:05:39:WU02:FS00:0xa7:Saving result file traj_comp.xtc
16:05:39:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
16:05:39:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:05:39:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14379 run:589 clone:3 gen:87 core:0xa7 unit:0x00000067455e42075e933032449ef745
16:05:39:WU02:FS00:Uploading 6.48MiB to 69.94.66.7
16:05:39:WU02:FS00:Connecting to 69.94.66.7:8080
16:05:39:WU01:FS00:Starting
16:05:39:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -np 15
16:05:39:WU01:FS00:Started FahCore on PID 22516
16:05:40:WU01:FS00:Core PID:21908
16:05:40:WU01:FS00:FahCore 0xa7 started
16:05:40:WU01:FS00:0xa7:*********************** Log Started 2020-05-25T16:05:40Z ***********************
16:05:40:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:05:40:WU01:FS00:0xa7: Type: 0xa7
16:05:40:WU01:FS00:0xa7: Core: Gromacs
16:05:40:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 22516 -checkpoint 15 -np
16:05:40:WU01:FS00:0xa7: 15
16:05:40:WU01:FS00:0xa7:************************************ CBang *************************************
16:05:40:WU01:FS00:0xa7: Date: Oct 26 2019
16:05:40:WU01:FS00:0xa7: Time: 01:38:25
16:05:40:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
16:05:40:WU01:FS00:0xa7: Branch: master
16:05:40:WU01:FS00:0xa7: Compiler: Visual C++ 2008
16:05:40:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:05:40:WU01:FS00:0xa7: Platform: win32 10
16:05:40:WU01:FS00:0xa7: Bits: 64
16:05:40:WU01:FS00:0xa7: Mode: Release
16:05:40:WU01:FS00:0xa7:************************************ System ************************************
16:05:40:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
16:05:40:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
16:05:40:WU01:FS00:0xa7: CPUs: 16
16:05:40:WU01:FS00:0xa7: Memory: 31.73GiB
16:05:40:WU01:FS00:0xa7:Free Memory: 20.19GiB
16:05:40:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
16:05:40:WU01:FS00:0xa7: OS Version: 6.2
16:05:40:WU01:FS00:0xa7:Has Battery: true
16:05:40:WU01:FS00:0xa7: On Battery: false
16:05:40:WU01:FS00:0xa7: UTC Offset: 2
16:05:40:WU01:FS00:0xa7: PID: 21908
16:05:40:WU01:FS00:0xa7: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
16:05:40:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
16:05:40:WU01:FS00:0xa7: Version: 0.0.18
16:05:40:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:05:40:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
16:05:40:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
16:05:40:WU01:FS00:0xa7: Time: 01:52:30
16:05:40:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
16:05:40:WU01:FS00:0xa7:************************************ Build *************************************
16:05:40:WU01:FS00:0xa7: SIMD: avx_256
16:05:40:WU01:FS00:0xa7:********************************************************************************
16:05:40:WU01:FS00:0xa7:Project: 14823 (Run 330, Clone 1, Gen 40)
16:05:40:WU01:FS00:0xa7:Unit: 0x0000002d9bf7a4d55ea30d94cfba13df
16:05:40:WU01:FS00:0xa7:Reading tar file core.xml
16:05:40:WU01:FS00:0xa7:Reading tar file frame40.tpr
16:05:40:WU01:FS00:0xa7:Digital signatures verified
16:05:40:WU01:FS00:0xa7:Calling: mdrun -s frame40.tpr -o frame40.trr -cpt 15 -nt 15
16:05:40:WU01:FS00:0xa7:Steps: first=0 total=250000
16:05:42:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
16:05:45:WU02:FS00:Upload 5.79%
16:05:51:WU02:FS00:Upload 11.58%
16:05:57:WU02:FS00:Upload 18.34%
16:06:03:WU02:FS00:Upload 24.13%
16:06:09:WU02:FS00:Upload 31.85%
16:06:15:WU02:FS00:Upload 38.60%
16:06:21:WU02:FS00:Upload 45.36%
16:06:27:WU02:FS00:Upload 52.11%
16:06:36:WU02:FS00:Upload 58.87%
16:06:42:WU02:FS00:Upload 64.66%
16:06:48:WU02:FS00:Upload 70.45%
16:06:54:WU02:FS00:Upload 76.24%
16:07:00:WU02:FS00:Upload 82.03%
16:07:06:WU02:FS00:Upload 86.86%
16:07:12:WU02:FS00:Upload 93.61%
16:07:18:WU02:FS00:Upload 100.00%
16:07:19:WU02:FS00:Upload complete
16:07:19:WU02:FS00:Server responded WORK_ACK (400)
16:07:19:WU02:FS00:Final credit estimate, 3462.00 points
16:07:19:WU02:FS00:Cleaning up
16:07:39:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
16:09:33:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
16:11:28:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
16:13:22:WU01:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
16:15:14:WU01:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
16:17:02:WU01:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
******************************* Date: 2020-05-25 *******************************
16:18:59:WU01:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
16:20:48:WU00:FS01:Connecting to assign1.foldingathome.org:80
16:20:48:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:20:48:WU00:FS01:Connecting to assign2.foldingathome.org:80
16:20:49:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
16:20:49:WU00:FS01:Connecting to assign3.foldingathome.org:80
16:20:49:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:20:49:WU00:FS01:Connecting to assign4.foldingathome.org:80
16:20:50:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:20:50:ERROR:WU00:FS01:Exception: Could not get an assignment
16:20:56:WU01:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
16:22:51:WU01:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
16:24:43:WU01:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
16:26:38:WU01:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
16:28:40:WU01:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
16:30:52:WU01:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
16:33:15:WU01:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
16:35:30:WU01:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
16:37:44:WU01:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
16:39:50:WU01:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
16:41:38:WU01:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
16:43:40:WU01:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
16:45:18:WU01:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
16:46:55:WU01:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
16:48:52:WU01:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
16:50:50:WU01:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
16:52:50:WU01:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
16:54:48:WU01:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
16:56:54:WU01:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
16:58:52:WU01:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
17:00:57:WU01:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
17:02:55:WU01:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
17:04:52:WU01:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
17:06:58:WU01:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
17:08:49:WU01:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
17:10:37:WU01:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
17:12:28:WU01:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
17:14:16:WU01:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
17:16:12:WU01:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
17:18:07:WU01:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
17:20:01:WU01:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
17:20:48:WU00:FS01:Connecting to assign1.foldingathome.org:80
17:20:49:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
17:20:49:WU00:FS01:Connecting to assign2.foldingathome.org:80
17:20:49:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
17:20:49:WU00:FS01:Connecting to assign3.foldingathome.org:80
17:20:50:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
17:20:50:WU00:FS01:Connecting to assign4.foldingathome.org:80
17:20:50:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
17:20:50:ERROR:WU00:FS01:Exception: Could not get an assignment
17:21:46:WU01:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
17:23:26:WU01:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
17:25:16:WU01:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
17:27:25:WU01:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
17:29:12:WU01:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
17:31:08:WU01:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
17:31:55:53:127.0.0.1:New Web session
17:33:07:WU01:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
17:33:54:Removing old file 'configs/config-20200522-084213.xml'
17:33:54:Saving configuration to config.xml
17:33:54:<config>
17:33:54: <!-- Network -->
17:33:54: <proxy v=':8080'/>
17:33:54:
17:33:54: <!-- Slot Control -->
17:33:54: <power v='full'/>
17:33:54:
17:33:54: <!-- User Information -->
17:33:54: <passkey v='*****'/>
17:33:54: <team v='10813'/>
17:33:54: <user v='Ian_Worthington'/>
17:33:54:
17:33:54: <!-- Folding Slots -->
17:33:54: <slot id='0' type='CPU'/>
17:33:54:</config>
17:33:54:FS00:Shutting core down
17:33:54:WU00:FS01:Slot ID 1 no longer exists and not yet downloaded, dumping
17:33:54:WU00:FS01:Cleaning up
17:33:55:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 21908
17:33:55:WU01:FS00:0xa7:Exiting, please wait. . .
17:33:56:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
17:33:56:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:33:56:WU01:FS00:Starting
17:33:56:WARNING:WU01:FS00:Changed SMP threads from 15 to 16 this can cause some work units to fail
17:33:56:WARNING:WU01:FS00:AS lowered CPUs from 16 to 15
17:33:56:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -np 15
17:33:56:WU01:FS00:Started FahCore on PID 24416
17:33:56:WU01:FS00:Core PID:27704
17:33:56:WU01:FS00:FahCore 0xa7 started
17:33:57:WU01:FS00:0xa7:*********************** Log Started 2020-05-25T17:33:56Z ***********************
17:33:57:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:33:57:WU01:FS00:0xa7: Type: 0xa7
17:33:57:WU01:FS00:0xa7: Core: Gromacs
17:33:57:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 24416 -checkpoint 15 -np
17:33:57:WU01:FS00:0xa7: 15
17:33:57:WU01:FS00:0xa7:************************************ CBang *************************************
17:33:57:WU01:FS00:0xa7: Date: Oct 26 2019
17:33:57:WU01:FS00:0xa7: Time: 01:38:25
17:33:57:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:33:57:WU01:FS00:0xa7: Branch: master
17:33:57:WU01:FS00:0xa7: Compiler: Visual C++ 2008
17:33:57:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:33:57:WU01:FS00:0xa7: Platform: win32 10
17:33:57:WU01:FS00:0xa7: Bits: 64
17:33:57:WU01:FS00:0xa7: Mode: Release
17:33:57:WU01:FS00:0xa7:************************************ System ************************************
17:33:57:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
17:33:57:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
17:33:57:WU01:FS00:0xa7: CPUs: 16
17:33:57:WU01:FS00:0xa7: Memory: 31.73GiB
17:33:57:WU01:FS00:0xa7:Free Memory: 18.91GiB
17:33:57:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
17:33:57:WU01:FS00:0xa7: OS Version: 6.2
17:33:57:WU01:FS00:0xa7:Has Battery: true
17:33:57:WU01:FS00:0xa7: On Battery: false
17:33:57:WU01:FS00:0xa7: UTC Offset: 2
17:33:57:WU01:FS00:0xa7: PID: 27704
17:33:57:WU01:FS00:0xa7: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
17:33:57:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
17:33:57:WU01:FS00:0xa7: Version: 0.0.18
17:33:57:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:33:57:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
17:33:57:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
17:33:57:WU01:FS00:0xa7: Time: 01:52:30
17:33:57:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:33:57:WU01:FS00:0xa7:************************************ Build *************************************
17:33:57:WU01:FS00:0xa7: SIMD: avx_256
17:33:57:WU01:FS00:0xa7:********************************************************************************
17:33:57:WU01:FS00:0xa7:Project: 14823 (Run 330, Clone 1, Gen 40)
17:33:57:WU01:FS00:0xa7:Unit: 0x0000002d9bf7a4d55ea30d94cfba13df
17:33:57:WU01:FS00:0xa7:Digital signatures verified
17:33:57:WU01:FS00:0xa7:Calling: mdrun -s frame40.tpr -o frame40.trr -cpi state.cpt -cpt 15 -nt 15
17:34:01:WU01:FS00:0xa7:Steps: first=0 total=250000
17:34:03:WU01:FS00:0xa7:Completed 113515 out of 250000 steps (45%)
17:34:11:Removing old file 'configs/config-20200522-084314.xml'
17:34:11:Saving configuration to config.xml
17:34:11:<config>
17:34:11: <!-- Network -->
17:34:11: <proxy v=':8080'/>
17:34:11:
17:34:11: <!-- Slot Control -->
17:34:11: <power v='full'/>
17:34:11:
17:34:11: <!-- User Information -->
17:34:11: <passkey v='*****'/>
17:34:11: <team v='10813'/>
17:34:11: <user v='Ian_Worthington'/>
17:34:11:
17:34:11: <!-- Folding Slots -->
17:34:11: <slot id='0' type='CPU'/>
17:34:11:</config>
17:34:20:Adding folding slot 01: READY gpu:0:Gen9p5/GT2 [UHD Graphics 630]
17:34:20:Removing old file 'configs/config-20200522-084718.xml'
17:34:20:Saving configuration to config.xml
17:34:20:<config>
17:34:20: <!-- Network -->
17:34:20: <proxy v=':8080'/>
17:34:20:
17:34:20: <!-- Slot Control -->
17:34:20: <power v='full'/>
17:34:20:
17:34:20: <!-- User Information -->
17:34:20: <passkey v='*****'/>
17:34:20: <team v='10813'/>
17:34:20: <user v='Ian_Worthington'/>
17:34:20:
17:34:20: <!-- Folding Slots -->
17:34:20: <slot id='0' type='CPU'/>
17:34:20: <slot id='1' type='GPU'/>
17:34:20:</config>
17:34:20:FS00:Shutting core down
17:34:20:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 27704
17:34:20:WU01:FS00:0xa7:Exiting, please wait. . .
17:34:21:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
17:34:22:WU00:FS01:Connecting to assign1.foldingathome.org:80
17:34:22:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:34:25:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
17:34:25:WU00:FS01:Connecting to assign2.foldingathome.org:80
17:34:30:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
17:34:30:WU00:FS01:Connecting to assign3.foldingathome.org:80
17:34:34:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
17:34:34:WU00:FS01:Connecting to assign4.foldingathome.org:80
17:34:38:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
17:34:38:ERROR:WU00:FS01:Exception: Could not get an assignment
17:34:38:WU00:FS01:Connecting to assign1.foldingathome.org:80
17:34:42:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
17:34:42:WU00:FS01:Connecting to assign2.foldingathome.org:80
17:34:45:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
17:34:45:WU00:FS01:Connecting to assign3.foldingathome.org:80
17:34:46:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
17:34:47:WU00:FS01:Connecting to assign4.foldingathome.org:80
17:34:47:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
17:34:47:ERROR:WU00:FS01:Exception: Could not get an assignment
17:34:56:WU01:FS00:Starting
17:34:56:WARNING:WU01:FS00:Changed SMP threads from 16 to 15 this can cause some work units to fail
17:34:56:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -np 15
17:34:56:WU01:FS00:Started FahCore on PID 28556
17:34:56:WU01:FS00:Core PID:8348
17:34:56:WU01:FS00:FahCore 0xa7 started
17:34:57:WU01:FS00:0xa7:*********************** Log Started 2020-05-25T17:34:56Z ***********************
17:34:57:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:34:57:WU01:FS00:0xa7: Type: 0xa7
17:34:57:WU01:FS00:0xa7: Core: Gromacs
17:34:57:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 28556 -checkpoint 15 -np
17:34:57:WU01:FS00:0xa7: 15
17:34:57:WU01:FS00:0xa7:************************************ CBang *************************************
17:34:57:WU01:FS00:0xa7: Date: Oct 26 2019
17:34:57:WU01:FS00:0xa7: Time: 01:38:25
17:34:57:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:34:57:WU01:FS00:0xa7: Branch: master
17:34:57:WU01:FS00:0xa7: Compiler: Visual C++ 2008
17:34:57:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:34:57:WU01:FS00:0xa7: Platform: win32 10
17:34:57:WU01:FS00:0xa7: Bits: 64
17:34:57:WU01:FS00:0xa7: Mode: Release
17:34:57:WU01:FS00:0xa7:************************************ System ************************************
17:34:57:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
17:34:57:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
17:34:57:WU01:FS00:0xa7: CPUs: 16
17:34:57:WU01:FS00:0xa7: Memory: 31.73GiB
17:34:57:WU01:FS00:0xa7:Free Memory: 20.19GiB
17:34:57:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
17:34:57:WU01:FS00:0xa7: OS Version: 6.2
17:34:57:WU01:FS00:0xa7:Has Battery: true
17:34:57:WU01:FS00:0xa7: On Battery: false
17:34:57:WU01:FS00:0xa7: UTC Offset: 2
17:34:57:WU01:FS00:0xa7: PID: 8348
17:34:57:WU01:FS00:0xa7: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
17:34:57:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
17:34:57:WU01:FS00:0xa7: Version: 0.0.18
17:34:57:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:34:57:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
17:34:57:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
17:34:57:WU01:FS00:0xa7: Time: 01:52:30
17:34:57:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:34:57:WU01:FS00:0xa7:************************************ Build *************************************
17:34:57:WU01:FS00:0xa7: SIMD: avx_256
17:34:57:WU01:FS00:0xa7:********************************************************************************
17:34:57:WU01:FS00:0xa7:Project: 14823 (Run 330, Clone 1, Gen 40)
17:34:57:WU01:FS00:0xa7:Unit: 0x0000002d9bf7a4d55ea30d94cfba13df
17:34:57:WU01:FS00:0xa7:Digital signatures verified
17:34:57:WU01:FS00:0xa7:Calling: mdrun -s frame40.tpr -o frame40.trr -cpi state.cpt -cpt 15 -nt 15
17:35:02:WU01:FS00:0xa7:Steps: first=0 total=250000
17:35:04:WU01:FS00:0xa7:Completed 113886 out of 250000 steps (45%)
17:35:12:Removing old file 'configs/config-20200522-090032.xml'
17:35:12:Saving configuration to config.xml
17:35:12:<config>
17:35:12: <!-- Network -->
17:35:12: <proxy v=':8080'/>
17:35:12:
17:35:12: <!-- Slot Control -->
17:35:12: <power v='full'/>
17:35:12:
17:35:12: <!-- User Information -->
17:35:12: <passkey v='*****'/>
17:35:12: <team v='10813'/>
17:35:12: <user v='Ian_Worthington'/>
17:35:12:
17:35:12: <!-- Folding Slots -->
17:35:12: <slot id='0' type='CPU'/>
17:35:12: <slot id='1' type='GPU'/>
17:35:12:</config>
17:35:38:WU00:FS01:Connecting to assign1.foldingathome.org:80
17:35:43:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
17:35:43:WU00:FS01:Connecting to assign2.foldingathome.org:80
17:35:47:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
17:35:47:WU00:FS01:Connecting to assign3.foldingathome.org:80
17:35:51:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
17:35:51:WU00:FS01:Connecting to assign4.foldingathome.org:80
17:35:52:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
17:35:52:ERROR:WU00:FS01:Exception: Could not get an assignment
17:35:58:WU01:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
17:37:16:WU00:FS01:Connecting to assign1.foldingathome.org:80
17:37:16:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
17:37:16:WU00:FS01:Connecting to assign2.foldingathome.org:80
17:37:17:WARNING:WU00:FS01:Failed to get assignment from 'a
17:37:17:WU00:FS01:Connecting to assign3.foldingathome.org:80
17:37:17:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
17:37:17:WU00:FS01:Connecting to assign4.foldingathome.org:80
17:37:18:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
17:37:18:ERROR:WU00:FS01:Exception: Could not get an assignment
17:37:21:Adding folding slot 02: READY gpu:0:Gen9p5/GT2 [UHD Graphics 630]
17:37:21:Removing old file 'configs/config-20200522-112050.xml'
17:37:21:Saving configuration to config.xml
17:37:21:<config>
17:37:21: <!-- Network -->
17:37:21: <proxy v=':8080'/>
17:37:21:
17:37:21: <!-- Slot Control -->
17:37:21: <power v='full'/>
17:37:21:
17:37:21: <!-- User Information -->
17:37:21: <passkey v='*****'/>
17:37:21: <team v='10813'/>
17:37:21: <user v='Ian_Worthington'/>
17:37:21:
17:37:21: <!-- Folding Slots -->
17:37:21: <slot id='0' type='CPU'/>
17:37:21: <slot id='2' type='GPU'>
17:37:21: <gpu-index v='0'/>
17:37:21: </slot>
17:37:21:</config>
17:37:22:WU00:FS01:Slot ID 1 no longer exists and not yet downloaded, dumping
17:37:22:WU00:FS01:Cleaning up
17:37:22:WU00:FS02:Connecting to assign1.foldingathome.org:80
17:37:22:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
17:37:22:WU00:FS02:Connecting to assign2.foldingathome.org:80
17:37:23:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
17:37:23:WU00:FS02:Connecting to assign3.foldingathome.org:80
17:37:23:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
17:37:23:WU00:FS02:Connecting to assign4.foldingathome.org:80
17:37:24:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
17:37:24:ERROR:WU00:FS02:Exception: Could not get an assignment
17:37:24:WU00:FS02:Connecting to assign1.foldingathome.org:80
17:37:24:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
17:37:24:WU00:FS02:Connecting to assign2.foldingathome.org:80
17:37:25:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
17:37:25:WU00:FS02:Connecting to assign3.foldingathome.org:80
17:37:25:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
17:37:25:WU00:FS02:Connecting to assign4.foldingathome.org:80
17:37:26:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
17:37:26:ERROR:WU00:FS02:Exception: Could not get an assignment
17:37:53:WU01:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
17:37:55:Adding folding slot 01: READY gpu:1:TU117M [GeForce GTX 1650 Mobile / Max-Q]
17:37:55:Removing old file 'configs/config-20200522-122517.xml'
17:37:55:Saving configuration to config.xml
17:37:55:<config>
17:37:55: <!-- Network -->
17:37:55: <proxy v=':8080'/>
17:37:55:
17:37:55: <!-- Slot Control -->
17:37:55: <power v='full'/>
17:37:55:
17:37:55: <!-- User Information -->
17:37:55: <passkey v='*****'/>
17:37:55: <team v='10813'/>
17:37:55: <user v='Ian_Worthington'/>
17:37:55:
17:37:55: <!-- Folding Slots -->
17:37:55: <slot id='0' type='CPU'/>
17:37:55: <slot id='2' type='GPU'>
17:37:55: <gpu-index v='0'/>
17:37:55: </slot>
17:37:55: <slot id='1' type='GPU'>
17:37:55: <gpu-index v='1'/>
17:37:55: </slot>
17:37:55:</config>
17:37:55:FS00:Shutting core down
17:37:55:WU02:FS01:Connecting to assign1.foldingathome.org:80
17:37:55:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 8348
17:37:55:WU01:FS00:0xa7:Exiting, please wait. . .
17:37:56:WU02:FS01:Assigned to work server 13.82.98.119
17:37:56:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:TU117M [GeForce GTX 1650 Mobile / Max-Q] from 13.82.98.119
17:37:56:WU02:FS01:Connecting to 13.82.98.119:8080
17:37:56:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:37:56:WU01:FS00:Starting
17:37:56:WARNING:WU01:FS00:Changed SMP threads from 15 to 14 this can cause some work units to fail
17:37:56:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -np 14
17:37:56:WU01:FS00:Started FahCore on PID 11916
17:37:56:WU01:FS00:Core PID:3908
17:37:56:WU01:FS00:FahCore 0xa7 started
17:37:57:WU01:FS00:0xa7:*********************** Log Started 2020-05-25T17:37:56Z ***********************
17:37:57:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:37:57:WU01:FS00:0xa7: Type: 0xa7
17:37:57:WU01:FS00:0xa7: Core: Gromacs
17:37:57:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 11916 -checkpoint 15 -np
17:37:57:WU01:FS00:0xa7: 14
17:37:57:WU01:FS00:0xa7:************************************ CBang *************************************
17:37:57:WU01:FS00:0xa7: Date: Oct 26 2019
17:37:57:WU01:FS00:0xa7: Time: 01:38:25
17:37:57:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:37:57:WU01:FS00:0xa7: Branch: master
17:37:57:WU01:FS00:0xa7: Compiler: Visual C++ 2008
17:37:57:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:37:57:WU01:FS00:0xa7: Platform: win32 10
17:37:57:WU01:FS00:0xa7: Bits: 64
17:37:57:WU01:FS00:0xa7: Mode: Release
17:37:57:WU01:FS00:0xa7:************************************ System ************************************
17:37:57:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
17:37:57:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
17:37:57:WU01:FS00:0xa7: CPUs: 16
17:37:57:WU01:FS00:0xa7: Memory: 31.73GiB
17:37:57:WU01:FS00:0xa7:Free Memory: 19.29GiB
17:37:57:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
17:37:57:WU01:FS00:0xa7: OS Version: 6.2
17:37:57:WU01:FS00:0xa7:Has Battery: true
17:37:57:WU01:FS00:0xa7: On Battery: false
17:37:57:WU01:FS00:0xa7: UTC Offset: 2
17:37:57:WU01:FS00:0xa7: PID: 3908
17:37:57:WU01:FS00:0xa7: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
17:37:57:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
17:37:57:WU01:FS00:0xa7: Version: 0.0.18
17:37:57:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:37:57:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
17:37:57:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
17:37:57:WU01:FS00:0xa7: Time: 01:52:30
17:37:57:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:37:57:WU01:FS00:0xa7:************************************ Build *************************************
17:37:57:WU01:FS00:0xa7: SIMD: avx_256
17:37:57:WU01:FS00:0xa7:********************************************************************************
17:37:57:WU01:FS00:0xa7:Project: 14823 (Run 330, Clone 1, Gen 40)
17:37:57:WU01:FS00:0xa7:Unit: 0x0000002d9bf7a4d55ea30d94cfba13df
17:37:57:WU01:FS00:0xa7:Digital signatures verified
17:37:57:WU01:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
17:37:57:WU01:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
17:37:57:WU01:FS00:0xa7:Calling: mdrun -s frame40.tpr -o frame40.trr -cpi state.cpt -cpt 15 -nt 12
17:37:57:WU01:FS00:0xa7:Steps: first=0 total=250000
17:37:58:WU01:FS00:0xa7:Completed 117526 out of 250000 steps (47%)
17:37:58:WU02:FS01:Downloading 124.80MiB
17:38:04:WU02:FS01:Download 2.15%
17:38:10:WU02:FS01:Download 4.46%
17:38:15:Removing old file 'configs/config-20200522-122921.xml'
17:38:15:Saving configuration to config.xml
17:38:15:<config>
17:38:15: <!-- Network -->
17:38:15: <proxy v=':8080'/>
17:38:15:
17:38:15: <!-- Slot Control -->
17:38:15: <power v='full'/>
17:38:15:
17:38:15: <!-- User Information -->
17:38:15: <passkey v='*****'/>
17:38:15: <team v='10813'/>
17:38:15: <user v='Ian_Worthington'/>
17:38:15:
17:38:15: <!-- Folding Slots -->
17:38:15: <slot id='0' type='CPU'/>
17:38:15: <slot id='2' type='GPU'>
17:38:15: <gpu-index v='0'/>
17:38:15: </slot>
17:38:15: <slot id='1' type='GPU'>
17:38:15: <gpu-index v='1'/>
17:38:15: </slot>
17:38:15:</config>
17:38:16:WU02:FS01:Download 6.71%
17:38:22:WU02:FS01:Download 8.96%
17:38:24:WU00:FS02:Connecting to assign1.foldingathome.org:80
17:38:27:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
17:38:27:WU00:FS02:Connecting to assign2.foldingathome.org:80
17:38:28:WU02:FS01:Download 11.17%
17:38:32:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
17:38:32:WU00:FS02:Connecting to assign3.foldingathome.org:80
17:38:34:WU02:FS01:Download 13.72%
17:38:34:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
17:38:34:WU00:FS02:Connecting to assign4.foldingathome.org:80
17:38:36:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
17:38:36:ERROR:WU00:FS02:Exception: Could not get an assignment
17:38:40:WU02:FS01:Download 16.08%
17:38:40:Adding folding slot 03: READY gpu:0:Gen9p5/GT2 [UHD Graphics 630]
17:38:40:Removing old file 'configs/config-20200522-123022.xml'
17:38:40:Saving configuration to config.xml
17:38:40:<config>
17:38:40: <!-- Network -->
17:38:40: <proxy v=':8080'/>
17:38:40:
17:38:40: <!-- Slot Control -->
17:38:40: <power v='full'/>
17:38:40:
17:38:40: <!-- User Information -->
17:38:40: <passkey v='*****'/>
17:38:40: <team v='10813'/>
17:38:40: <user v='Ian_Worthington'/>
17:38:40:
17:38:40: <!-- Folding Slots -->
17:38:40: <slot id='0' type='CPU'/>
17:38:40: <slot id='2' type='GPU'>
17:38:40: <gpu-index v='0'/>
17:38:40: </slot>
17:38:40: <slot id='1' type='GPU'>
17:38:40: <gpu-index v='1'/>
17:38:40: </slot>
17:38:40: <slot id='3' type='GPU'>
17:38:40: </slot>
17:38:40:</config>
17:38:40:FS00:Shutting core down
17:38:40:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 3908
17:38:40:WU01:FS00:0xa7:Exiting, please wait. . .
17:38:40:WU03:FS03:Connecting to assign1.foldingathome.org:80
17:38:41:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
17:38:41:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:38:43:WARNING:WU03:FS03:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
17:38:43:WU03:FS03:Connecting to assign2.foldingathome.org:80
17:38:45:WARNING:WU03:FS03:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
17:38:45:WU03:FS03:Connecting to assign3.foldingathome.org:80
17:38:46:WU02:FS01:Download 18.23%
17:38:48:WARNING:WU03:FS03:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
17:38:48:WU03:FS03:Connecting to assign4.foldingathome.org:80
17:38:50:Removing old file 'configs/config-20200522-123426.xml'
17:38:50:Saving configuration to config.xml
17:38:50:<config>
17:38:50: <!-- Network -->
17:38:50: <proxy v=':8080'/>
17:38:50:
17:38:50: <!-- Slot Control -->
17:38:50: <power v='full'/>
17:38:50:
17:38:50: <!-- User Information -->
17:38:50: <passkey v='*****'/>
17:38:50: <team v='10813'/>
17:38:50: <user v='Ian_Worthington'/>
17:38:50:
17:38:50: <!-- Folding Slots -->
17:38:50: <slot id='0' type='CPU'/>
17:38:50: <slot id='2' type='GPU'>
17:38:50: <gpu-index v='0'/>
17:38:50: </slot>
17:38:50: <slot id='1' type='GPU'>
17:38:50: <gpu-index v='1'/>
17:38:50: </slot>
17:38:50:</config>
17:38:50:WARNING:WU03:FS03:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
17:38:50:ERROR:WU03:FS03:Exception: Could not get an assignment
17:38:50:WU03:Slot ID 3 no longer exists and not yet downloaded, dumping
17:38:50:WU03:Cleaning up
17:38:52:WU02:FS01:Download 20.48%
17:38:56:WU01:FS00:Starting
17:38:56:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -np 14
17:38:56:WU01:FS00:Started FahCore on PID 6052
17:38:56:WU01:FS00:Core PID:30572
17:38:56:WU01:FS00:FahCore 0xa7 started
17:38:57:WU01:FS00:0xa7:*********************** Log Started 2020-05-25T17:38:56Z ***********************
17:38:57:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:38:57:WU01:FS00:0xa7: Type: 0xa7
17:38:57:WU01:FS00:0xa7: Core: Gromacs
17:38:57:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 6052 -checkpoint 15 -np
17:38:57:WU01:FS00:0xa7: 14
17:38:57:WU01:FS00:0xa7:************************************ CBang *************************************
17:38:57:WU01:FS00:0xa7: Date: Oct 26 2019
17:38:57:WU01:FS00:0xa7: Time: 01:38:25
17:38:57:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:38:57:WU01:FS00:0xa7: Branch: master
17:38:57:WU01:FS00:0xa7: Compiler: Visual C++ 2008
17:38:57:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:38:57:WU01:FS00:0xa7: Platform: win32 10
17:38:57:WU01:FS00:0xa7: Bits: 64
17:38:57:WU01:FS00:0xa7: Mode: Release
17:38:57:WU01:FS00:0xa7:************************************ System ************************************
17:38:57:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
17:38:57:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
17:38:57:WU01:FS00:0xa7: CPUs: 16
17:38:57:WU01:FS00:0xa7: Memory: 31.73GiB
17:38:57:WU01:FS00:0xa7:Free Memory: 19.65GiB
17:38:57:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
17:38:57:WU01:FS00:0xa7: OS Version: 6.2
17:38:57:WU01:FS00:0xa7:Has Battery: true
17:38:57:WU01:FS00:0xa7: On Battery: false
17:38:57:WU01:FS00:0xa7: UTC Offset: 2
17:38:57:WU01:FS00:0xa7: PID: 30572
17:38:57:WU01:FS00:0xa7: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
17:38:57:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
17:38:57:WU01:FS00:0xa7: Version: 0.0.18
17:38:57:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:38:57:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
17:38:57:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
17:38:57:WU01:FS00:0xa7: Time: 01:52:30
17:38:57:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:38:57:WU01:FS00:0xa7:************************************ Build *************************************
17:38:57:WU01:FS00:0xa7: SIMD: avx_256
17:38:57:WU01:FS00:0xa7:********************************************************************************
17:38:57:WU01:FS00:0xa7:Project: 14823 (Run 330, Clone 1, Gen 40)
17:38:57:WU01:FS00:0xa7:Unit: 0x0000002d9bf7a4d55ea30d94cfba13df
17:38:57:WU01:FS00:0xa7:Digital signatures verified
17:38:57:WU01:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
17:38:57:WU01:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
17:38:57:WU01:FS00:0xa7:Calling: mdrun -s frame40.tpr -o frame40.trr -cpi state.cpt -cpt 15 -nt 12
17:38:57:WU01:FS00:0xa7:Steps: first=0 total=250000
17:38:57:WU01:FS00:0xa7:Completed 118574 out of 250000 steps (47%)
17:38:58:WU02:FS01:Download 22.74%
17:39:04:WU02:FS01:Download 24.59%
17:39:10:WU02:FS01:Download 26.89%
17:39:16:WU02:FS01:Download 29.15%
17:39:22:WU02:FS01:Download 31.45%
17:39:28:WU02:FS01:Download 33.80%
17:39:34:WU02:FS01:Download 36.16%
17:39:40:WU02:FS01:Download 38.61%
17:39:46:WU02:FS01:Download 41.06%
17:39:51:WU01:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
17:39:52:WU02:FS01:Download 43.27%
17:39:58:WU02:FS01:Download 45.27%
17:40:01:WU00:FS02:Connecting to assign1.foldingathome.org:80
17:40:02:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
17:40:02:WU00:FS02:Connecting to assign2.foldingathome.org:80
17:40:04:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
17:40:04:WU00:FS02:Connecting to assign3.foldingathome.org:80
17:40:04:WU02:FS01:Download 47.53%
17:40:06:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
17:40:06:WU00:FS02:Connecting to assign4.foldingathome.org:80
17:40:08:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
17:40:08:ERROR:WU00:FS02:Exception: Could not get an assignment
17:40:10:WU02:FS01:Download 49.63%
17:40:16:WU02:FS01:Download 51.83%
17:40:22:WU02:FS01:Download 54.09%
17:40:28:WU02:FS01:Download 56.29%
17:40:34:WU02:FS01:Download 58.54%
17:40:40:WU02:FS01:Download 60.30%
17:40:46:WU02:FS01:Download 62.50%
17:40:52:WU02:FS01:Download 64.65%
17:40:58:WU02:FS01:Download 66.71%
17:41:04:WU02:FS01:Download 68.96%
17:41:10:WU02:FS01:Download 71.06%
17:41:16:WU02:FS01:Download 73.32%
17:41:22:WU02:FS01:Download 75.57%
17:41:28:WU02:FS01:Download 77.27%
17:41:34:WU02:FS01:Download 79.13%
17:41:39:WU01:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
17:41:40:WU02:FS01:Download 81.23%
17:41:46:WU02:FS01:Download 83.48%
17:41:52:WU02:FS01:Download 85.74%
17:41:58:WU02:FS01:Download 87.94%
17:42:04:WU02:FS01:Download 90.09%
17:42:10:WU02:FS01:Download 92.05%
17:42:16:WU02:FS01:Download 94.35%
17:42:22:WU02:FS01:Download 96.50%
17:42:28:WU02:FS01:Download 98.81%
17:42:31:WU02:FS01:Download complete
17:42:31:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14417 run:0 clone:435 gen:68 core:0x22 unit:0x0000005e0d5262775e84c8a604b23260
17:42:31:WU02:FS01:Starting
17:42:31:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
17:42:31:WU02:FS01:Started FahCore on PID 11852
17:42:43:WU02:FS01:Core PID:25792
17:42:43:WU02:FS01:FahCore 0x22 started
17:42:43:WU00:FS02:Connecting to assign1.foldingathome.org:80
17:42:44:WU02:FS01:0x22:*********************** Log Started 2020-05-25T17:42:44Z ***********************
17:42:44:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
17:42:44:WU02:FS01:0x22: Type: 0x22
17:42:44:WU02:FS01:0x22: Core: Core22
17:42:44:WU02:FS01:0x22: Website: https://foldingathome.org/
17:42:44:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
17:42:44:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
17:42:44:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
17:42:44:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 11852 -checkpoint 15
17:42:44:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
17:42:44:WU02:FS01:0x22: 0 -gpu 0
17:42:44:WU02:FS01:0x22: Config: <none>
17:42:44:WU02:FS01:0x22:************************************ Build *************************************
17:42:44:WU02:FS01:0x22: Version: 0.0.5
17:42:44:WU02:FS01:0x22: Date: Apr 22 2020
17:42:44:WU02:FS01:0x22: Time: 04:42:59
17:42:44:WU02:FS01:0x22: Repository: Git
17:42:44:WU02:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
17:42:44:WU02:FS01:0x22: Branch: HEAD
17:42:44:WU02:FS01:0x22: Compiler: Visual C++ 2008
17:42:44:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:42:44:WU02:FS01:0x22: Platform: win32 10
17:42:44:WU02:FS01:0x22: Bits: 64
17:42:44:WU02:FS01:0x22: Mode: Release
17:42:44:WU02:FS01:0x22:************************************ System ************************************
17:42:44:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
17:42:44:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
17:42:44:WU02:FS01:0x22: CPUs: 16
17:42:44:WU02:FS01:0x22: Memory: 31.73GiB
17:42:44:WU02:FS01:0x22:Free Memory: 18.64GiB
17:42:44:WU02:FS01:0x22: Threads: WINDOWS_THREADS
17:42:44:WU02:FS01:0x22: OS Version: 6.2
17:42:44:WU02:FS01:0x22:Has Battery: true
17:42:44:WU02:FS01:0x22: On Battery: false
17:42:44:WU02:FS01:0x22: UTC Offset: 2
17:42:44:WU02:FS01:0x22: PID: 25792
17:42:44:WU02:FS01:0x22: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
17:42:44:WU02:FS01:0x22: OS: Windows 10 Pro
17:42:44:WU02:FS01:0x22: OS Arch: AMD64
17:42:44:WU02:FS01:0x22:********************************************************************************
17:42:44:WU02:FS01:0x22:Project: 14417 (Run 0, Clone 435, Gen 68)
17:42:44:WU02:FS01:0x22:Unit: 0x0000005e0d5262775e84c8a604b23260
17:42:44:WU02:FS01:0x22:Reading tar file core.xml
17:42:44:WU02:FS01:0x22:Reading tar file integrator.xml
17:42:44:WU02:FS01:0x22:Reading tar file state.xml
17:42:45:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
17:42:45:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:42:45:WU00:FS02:Connecting to assign2.foldingathome.org:80
17:42:46:WU02:FS01:0x22:Reading tar file system.xml
17:42:46:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
17:42:46:WU00:FS02:Connecting to assign3.foldingathome.org:80
17:42:47:WU02:FS01:0x22:Digital signatures verified
17:42:47:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
17:42:47:WU02:FS01:0x22:Version 0.0.5
17:42:48:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
17:42:48:WU00:FS02:Connecting to assign4.foldingathome.org:80
17:42:49:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
17:42:49:ERROR:WU00:FS02:Exception: Could not get an assignment
17:43:29:WU01:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
17:44:00:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
17:44:00:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:46:52:WU01:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
17:46:58:WU00:FS02:Connecting to assign1.foldingathome.org:80
17:47:00:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
17:47:00:WU00:FS02:Connecting to assign2.foldingathome.org:80
17:47:00:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
17:47:00:WU00:FS02:Connecting to assign3.foldingathome.org:80
17:47:01:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
17:47:01:WU00:FS02:Connecting to assign4.foldingathome.org:80
17:47:02:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
17:47:02:ERROR:WU00:FS02:Exception: Could not get an assignment
17:50:05:FS01:Shutting core down
17:50:05:WU02:FS01:0x22:WARNING:Console control signal 1 on PID 25792
17:50:05:WU02:FS01:0x22:Exiting, please wait. . .
17:50:05:WU02:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
17:50:07:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
17:50:27:Removing old file 'configs/config-20200522-125547.xml'
17:50:27:Saving configuration to config.xml
17:50:27:<config>
17:50:27: <!-- Network -->
17:50:27: <proxy v=':8080'/>
17:50:27:
17:50:27: <!-- Slot Control -->
17:50:27: <power v='full'/>
17:50:27:
17:50:27: <!-- User Information -->
17:50:27: <passkey v='*****'/>
17:50:27: <team v='10813'/>
17:50:27: <user v='Ian_Worthington'/>
17:50:27:
17:50:27: <!-- Folding Slots -->
17:50:27: <slot id='0' type='CPU'/>
17:50:27: <slot id='2' type='GPU'>
17:50:27: <gpu-index v='0'/>
17:50:27: </slot>
17:50:27: <slot id='1' type='GPU'>
17:50:27: <gpu-index v='1'/>
17:50:27: <idle v='true'/>
17:50:27: </slot>
17:50:27:</config>
17:51:04:WU01:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
17:52:29:Removing old file 'configs/config-20200522-131708.xml'
17:52:29:Saving configuration to config.xml
17:52:29:<config>
17:52:29: <!-- Network -->
17:52:29: <proxy v=':8080'/>
17:52:29:
17:52:29: <!-- Slot Control -->
17:52:29: <power v='full'/>
17:52:29:
17:52:29: <!-- User Information -->
17:52:29: <passkey v='*****'/>
17:52:29: <team v='10813'/>
17:52:29: <user v='Ian_Worthington'/>
17:52:29:
17:52:29: <!-- Folding Slots -->
17:52:29: <slot id='0' type='CPU'/>
17:52:29: <slot id='2' type='GPU'>
17:52:29: <gpu-index v='0'/>
17:52:29: <idle v='true'/>
17:52:29: </slot>
17:52:29: <slot id='1' type='GPU'>
17:52:29: <gpu-index v='1'/>
17:52:29: </slot>
17:52:29:</config>
17:53:02:WU01:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
17:54:50:WU01:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
17:56:29:WU01:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
17:58:09:WU01:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
17:59:49:WU01:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
17:59:52:71:127.0.0.1:New Web session
18:01:29:WU01:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
18:03:16:WU01:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
18:05:03:WU01:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
18:06:48:WU01:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
18:08:34:WU01:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
18:10:19:WU01:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
18:12:06:WU01:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
18:13:55:WU01:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
18:15:42:WU01:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
18:17:30:WU01:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
18:19:27:WU01:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
18:21:24:WU01:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
18:23:23:WU01:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
18:25:07:WU01:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
18:26:48:WU01:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
18:28:39:WU01:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
18:30:29:WU01:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
18:32:29:WU01:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
18:34:18:WU01:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
18:36:08:WU01:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
18:38:00:WU01:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
18:39:55:WU01:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
18:41:39:WU01:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
18:43:25:WU01:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
18:45:15:WU01:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
18:47:02:WU01:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
18:47:15:WU00:FS02:Connecting to assign1.foldingathome.org:80
18:47:15:WU02:FS01:Starting
18:47:15:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
18:47:15:WU02:FS01:Started FahCore on PID 24708
18:47:15:WU02:FS01:Core PID:22884
18:47:15:WU02:FS01:FahCore 0x22 started
18:47:15:WU02:FS01:0x22:*********************** Log Started 2020-05-25T18:47:15Z ***********************
18:47:15:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:47:15:WU02:FS01:0x22: Type: 0x22
18:47:16:WU02:FS01:0x22: Core: Core22
18:47:16:WU02:FS01:0x22: Website: https://foldingathome.org/
18:47:16:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
18:47:16:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
18:47:16:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
18:47:16:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 24708 -checkpoint 15
18:47:16:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
18:47:16:WU02:FS01:0x22: 0 -gpu 0
18:47:16:WU02:FS01:0x22: Config: <none>
18:47:16:WU02:FS01:0x22:************************************ Build *************************************
18:47:16:WU02:FS01:0x22: Version: 0.0.5
18:47:16:WU02:FS01:0x22: Date: Apr 22 2020
18:47:16:WU02:FS01:0x22: Time: 04:42:59
18:47:16:WU02:FS01:0x22: Repository: Git
18:47:16:WU02:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
18:47:16:WU02:FS01:0x22: Branch: HEAD
18:47:16:WU02:FS01:0x22: Compiler: Visual C++ 2008
18:47:16:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:47:16:WU02:FS01:0x22: Platform: win32 10
18:47:16:WU02:FS01:0x22: Bits: 64
18:47:16:WU02:FS01:0x22: Mode: Release
18:47:16:WU02:FS01:0x22:************************************ System ************************************
18:47:16:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
18:47:16:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
18:47:16:WU02:FS01:0x22: CPUs: 16
18:47:16:WU02:FS01:0x22: Memory: 31.73GiB
18:47:16:WU02:FS01:0x22:Free Memory: 19.20GiB
18:47:16:WU02:FS01:0x22: Threads: WINDOWS_THREADS
18:47:16:WU02:FS01:0x22: OS Version: 6.2
18:47:16:WU02:FS01:0x22:Has Battery: true
18:47:16:WU02:FS01:0x22: On Battery: false
18:47:16:WU02:FS01:0x22: UTC Offset: 2
18:47:16:WU02:FS01:0x22: PID: 22884
18:47:16:WU02:FS01:0x22: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
18:47:16:WU02:FS01:0x22: OS: Windows 10 Pro
18:47:16:WU02:FS01:0x22: OS Arch: AMD64
18:47:16:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:47:16:WU02:FS01:0x22:********************************************************************************
18:47:16:WU00:FS02:Connecting to assign2.foldingathome.org:80
18:47:16:WU02:FS01:0x22:Project: 14417 (Run 0, Clone 435, Gen 68)
18:47:16:WU02:FS01:0x22:Unit: 0x0000005e0d5262775e84c8a604b23260
18:47:16:WU02:FS01:0x22:Digital signatures verified
18:47:16:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:47:16:WU02:FS01:0x22:Version 0.0.5
18:47:16:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:47:16:WU00:FS02:Connecting to assign3.foldingathome.org:80
18:47:17:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:47:17:WU00:FS02:Connecting to assign4.foldingathome.org:80
18:47:18:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
18:47:18:ERROR:WU00:FS02:Exception: Could not get an assignment
18:48:23:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
18:48:23:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:48:52:WU00:FS02:Connecting to assign1.foldingathome.org:80
18:48:52:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:48:52:WU00:FS02:Connecting to assign2.foldingathome.org:80
18:48:53:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:48:53:WU00:FS02:Connecting to assign3.foldingathome.org:80
18:48:53:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:48:53:WU00:FS02:Connecting to assign4.foldingathome.org:80
18:48:54:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
18:48:54:ERROR:WU00:FS02:Exception: Could not get an assignment
18:50:05:WU01:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
18:51:19:FS01:Shutting core down
18:51:20:WU02:FS01:0x22:WARNING:Console control signal 1 on PID 22884
18:51:20:WU02:FS01:0x22:Exiting, please wait. . .
18:51:20:WU02:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
18:51:23:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
18:51:49:WU00:FS02:Connecting to assign1.foldingathome.org:80
18:51:49:WU02:FS01:Starting
18:51:49:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
18:51:49:WU02:FS01:Started FahCore on PID 13144
18:51:49:WU02:FS01:Core PID:7144
18:51:49:WU02:FS01:FahCore 0x22 started
18:51:50:WU02:FS01:0x22:*********************** Log Started 2020-05-25T18:51:50Z ***********************
18:51:50:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:51:50:WU02:FS01:0x22: Type: 0x22
18:51:50:WU02:FS01:0x22: Core: Core22
18:51:50:WU02:FS01:0x22: Website: https://foldingathome.org/
18:51:50:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
18:51:50:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
18:51:50:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
18:51:50:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 13144 -checkpoint 15
18:51:50:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
18:51:50:WU02:FS01:0x22: 0 -gpu 0
18:51:50:WU02:FS01:0x22: Config: <none>
18:51:50:WU02:FS01:0x22:************************************ Build *************************************
18:51:50:WU02:FS01:0x22: Version: 0.0.5
18:51:50:WU02:FS01:0x22: Date: Apr 22 2020
18:51:50:WU02:FS01:0x22: Time: 04:42:59
18:51:50:WU02:FS01:0x22: Repository: Git
18:51:50:WU02:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
18:51:50:WU02:FS01:0x22: Branch: HEAD
18:51:50:WU02:FS01:0x22: Compiler: Visual C++ 2008
18:51:50:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:51:50:WU02:FS01:0x22: Platform: win32 10
18:51:50:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:51:50:WU02:FS01:0x22: Bits: 64
18:51:50:WU00:FS02:Connecting to assign2.foldingathome.org:80
18:51:50:WU02:FS01:0x22: Mode: Release
18:51:50:WU02:FS01:0x22:************************************ System ************************************
18:51:50:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
18:51:50:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
18:51:50:WU02:FS01:0x22: CPUs: 16
18:51:50:WU02:FS01:0x22: Memory: 31.73GiB
18:51:50:WU02:FS01:0x22:Free Memory: 19.41GiB
18:51:50:WU02:FS01:0x22: Threads: WINDOWS_THREADS
18:51:50:WU02:FS01:0x22: OS Version: 6.2
18:51:51:WU02:FS01:0x22:Has Battery: true
18:51:51:WU02:FS01:0x22: On Battery: false
18:51:51:WU02:FS01:0x22: UTC Offset: 2
18:51:51:WU02:FS01:0x22: PID: 7144
18:51:51:WU02:FS01:0x22: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
18:51:51:WU02:FS01:0x22: OS: Windows 10 Pro
18:51:51:WU02:FS01:0x22: OS Arch: AMD64
18:51:51:WU02:FS01:0x22:********************************************************************************
18:51:51:WU02:FS01:0x22:Project: 14417 (Run 0, Clone 435, Gen 68)
18:51:51:WU02:FS01:0x22:Unit: 0x0000005e0d5262775e84c8a604b23260
18:51:51:WU02:FS01:0x22:Digital signatures verified
18:51:51:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:51:51:WU02:FS01:0x22:Version 0.0.5
18:51:52:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:51:52:WU00:FS02:Connecting to assign3.foldingathome.org:80
18:51:53:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:51:53:WU00:FS02:Connecting to assign4.foldingathome.org:80
18:51:53:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
18:51:53:ERROR:WU00:FS02:Exception: Could not get an assignment
18:53:15:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
18:53:15:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:53:48:WU01:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
18:56:03:WU00:FS02:Connecting to assign1.foldingathome.org:80
18:56:03:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:56:03:WU00:FS02:Connecting to assign2.foldingathome.org:80
18:56:04:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:56:04:WU00:FS02:Connecting to assign3.foldingathome.org:80
18:56:04:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:56:04:WU00:FS02:Connecting to assign4.foldingathome.org:80
18:56:05:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
18:56:05:ERROR:WU00:FS02:Exception: Could not get an assignment
18:58:53:WU01:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
18:59:46:WU02:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
19:02:54:WU00:FS02:Connecting to assign1.foldingathome.org:80
19:02:55:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:02:55:WU00:FS02:Connecting to assign2.foldingathome.org:80
19:02:55:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
19:02:55:WU00:FS02:Connecting to assign3.foldingathome.org:80
19:02:56:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
19:02:56:WU00:FS02:Connecting to assign4.foldingathome.org:80
19:02:56:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
19:02:56:ERROR:WU00:FS02:Exception: Could not get an assignment
19:04:08:WU01:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
19:06:20:WU02:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
19:09:24:WU01:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
19:12:52:WU02:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
19:14:00:WU00:FS02:Connecting to assign1.foldingathome.org:80
19:14:00:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:14:00:WU00:FS02:Connecting to assign2.foldingathome.org:80
19:14:01:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
19:14:01:WU00:FS02:Connecting to assign3.foldingathome.org:80
19:14:01:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
19:14:01:WU00:FS02:Connecting to assign4.foldingathome.org:80
19:14:02:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
19:14:02:ERROR:WU00:FS02:Exception: Could not get an assignment
19:14:33:WU01:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
19:19:24:WU02:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
19:19:42:WU01:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
19:24:55:WU01:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
19:25:56:WU02:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
19:30:18:WU01:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
19:30:52:FS01:Shutting core down
19:30:52:WU02:FS01:0x22:WARNING:Console control signal 1 on PID 7144
19:30:52:WU02:FS01:0x22:Exiting, please wait. . .
19:30:52:WU02:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
19:30:54:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
19:31:44:WU02:FS01:Starting
19:31:44:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
19:31:44:WU02:FS01:Started FahCore on PID 29436
19:31:44:WU02:FS01:Core PID:25440
19:31:44:WU02:FS01:FahCore 0x22 started
19:31:45:WU02:FS01:0x22:*********************** Log Started 2020-05-25T19:31:45Z ***********************
19:31:45:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
19:31:45:WU02:FS01:0x22: Type: 0x22
19:31:45:WU02:FS01:0x22: Core: Core22
19:31:45:WU02:FS01:0x22: Website: https://foldingathome.org/
19:31:45:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
19:31:45:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
19:31:46:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
19:31:46:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 29436 -checkpoint 15
19:31:46:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
19:31:46:WU02:FS01:0x22: 0 -gpu 0
19:31:46:WU02:FS01:0x22: Config: <none>
19:31:46:WU02:FS01:0x22:************************************ Build *************************************
19:31:46:WU02:FS01:0x22: Version: 0.0.5
19:31:46:WU02:FS01:0x22: Date: Apr 22 2020
19:31:46:WU02:FS01:0x22: Time: 04:42:59
19:31:46:WU02:FS01:0x22: Repository: Git
19:31:46:WU02:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
19:31:46:WU02:FS01:0x22: Branch: HEAD
19:31:46:WU02:FS01:0x22: Compiler: Visual C++ 2008
19:31:46:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:31:46:WU02:FS01:0x22: Platform: win32 10
19:31:46:WU02:FS01:0x22: Bits: 64
19:31:46:WU02:FS01:0x22: Mode: Release
19:31:46:WU02:FS01:0x22:************************************ System ************************************
19:31:46:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
19:31:46:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
19:31:46:WU02:FS01:0x22: CPUs: 16
19:31:46:WU02:FS01:0x22: Memory: 31.73GiB
19:31:46:WU02:FS01:0x22:Free Memory: 17.73GiB
19:31:46:WU02:FS01:0x22: Threads: WINDOWS_THREADS
19:31:46:WU02:FS01:0x22: OS Version: 6.2
19:31:46:WU02:FS01:0x22:Has Battery: true
19:31:46:WU02:FS01:0x22: On Battery: false
19:31:46:WU02:FS01:0x22: UTC Offset: 2
19:31:46:WU02:FS01:0x22: PID: 25440
19:31:46:WU02:FS01:0x22: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
19:31:46:WU02:FS01:0x22: OS: Windows 10 Pro
19:31:46:WU02:FS01:0x22: OS Arch: AMD64
19:31:46:WU02:FS01:0x22:********************************************************************************
19:31:46:WU02:FS01:0x22:Project: 14417 (Run 0, Clone 435, Gen 68)
19:31:46:WU02:FS01:0x22:Unit: 0x0000005e0d5262775e84c8a604b23260
19:31:46:WU02:FS01:0x22:Digital signatures verified
19:31:46:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:31:46:WU02:FS01:0x22:Version 0.0.5
19:31:47:WU02:FS01:0x22: Found a checkpoint file
19:31:56:WU00:FS02:Connecting to assign1.foldingathome.org:80
19:31:57:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:31:57:WU00:FS02:Connecting to assign2.foldingathome.org:80
19:31:57:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
19:31:57:WU00:FS02:Connecting to assign3.foldingathome.org:80
19:31:58:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
19:31:58:WU00:FS02:Connecting to assign4.foldingathome.org:80
19:31:58:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
19:31:58:ERROR:WU00:FS02:Exception: Could not get an assignment
19:32:15:FS01:Shutting core down
19:32:15:WU02:FS01:0x22:WARNING:Console control signal 1 on PID 25440
19:32:15:WU02:FS01:0x22:Exiting, please wait. . .
19:33:06:WU02:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
19:33:06:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:33:07:WU02:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
19:33:07:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
19:33:07:WU02:FS01:Starting
19:33:07:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
19:33:08:WU02:FS01:Started FahCore on PID 28704
19:33:08:WU02:FS01:Core PID:28944
19:33:08:WU02:FS01:FahCore 0x22 started
19:33:08:WU02:FS01:0x22:*********************** Log Started 2020-05-25T19:33:08Z ***********************
19:33:08:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
19:33:08:WU02:FS01:0x22: Type: 0x22
19:33:08:WU02:FS01:0x22: Core: Core22
19:33:08:WU02:FS01:0x22: Website: https://foldingathome.org/
19:33:08:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
19:33:08:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
19:33:08:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
19:33:08:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 28704 -checkpoint 15
19:33:08:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
19:33:08:WU02:FS01:0x22: 0 -gpu 0
19:33:08:WU02:FS01:0x22: Config: <none>
19:33:08:WU02:FS01:0x22:************************************ Build *************************************
19:33:08:WU02:FS01:0x22: Version: 0.0.5
19:33:08:WU02:FS01:0x22: Date: Apr 22 2020
19:33:08:WU02:FS01:0x22: Time: 04:42:59
19:33:08:WU02:FS01:0x22: Repository: Git
19:33:08:WU02:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
19:33:08:WU02:FS01:0x22: Branch: HEAD
19:33:08:WU02:FS01:0x22: Compiler: Visual C++ 2008
19:33:08:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:33:08:WU02:FS01:0x22: Platform: win32 10
19:33:08:WU02:FS01:0x22: Bits: 64
19:33:08:WU02:FS01:0x22: Mode: Release
19:33:08:WU02:FS01:0x22:************************************ System ************************************
19:33:08:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
19:33:08:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
19:33:08:WU02:FS01:0x22: CPUs: 16
19:33:08:WU02:FS01:0x22: Memory: 31.73GiB
19:33:08:WU02:FS01:0x22:Free Memory: 17.73GiB
19:33:08:WU02:FS01:0x22: Threads: WINDOWS_THREADS
19:33:08:WU02:FS01:0x22: OS Version: 6.2
19:33:08:WU02:FS01:0x22:Has Battery: true
19:33:08:WU02:FS01:0x22: On Battery: false
19:33:08:WU02:FS01:0x22: UTC Offset: 2
19:33:08:WU02:FS01:0x22: PID: 28944
19:33:08:WU02:FS01:0x22: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
19:33:08:WU02:FS01:0x22: OS: Windows 10 Pro
19:33:08:WU02:FS01:0x22: OS Arch: AMD64
19:33:08:WU02:FS01:0x22:********************************************************************************
19:33:08:WU02:FS01:0x22:Project: 14417 (Run 0, Clone 435, Gen 68)
19:33:08:WU02:FS01:0x22:Unit: 0x0000005e0d5262775e84c8a604b23260
19:33:08:WU02:FS01:0x22:Digital signatures verified
19:33:08:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:33:08:WU02:FS01:0x22:Version 0.0.5
19:33:08:WU02:FS01:0x22: Found a checkpoint file
19:33:38:WU01:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
19:34:17:WU02:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
19:34:18:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:37:26:FS01:Shutting core down
19:37:27:WU02:FS01:0x22:WARNING:Console control signal 1 on PID 28944
19:37:27:WU02:FS01:0x22:Exiting, please wait. . .
19:37:27:WU02:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
19:37:29:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
19:37:56:WU02:FS01:Starting
19:37:56:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
19:37:56:WU02:FS01:Started FahCore on PID 26380
19:37:56:WU02:FS01:Core PID:25372
19:37:56:WU02:FS01:FahCore 0x22 started
19:37:57:WU02:FS01:0x22:*********************** Log Started 2020-05-25T19:37:57Z ***********************
19:37:57:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
19:37:57:WU02:FS01:0x22: Type: 0x22
19:37:57:WU02:FS01:0x22: Core: Core22
19:37:57:WU02:FS01:0x22: Website: https://foldingathome.org/
19:37:57:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
19:37:57:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
19:37:57:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
19:37:57:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 26380 -checkpoint 15
19:37:57:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
19:37:57:WU02:FS01:0x22: 0 -gpu 0
19:37:57:WU02:FS01:0x22: Config: <none>
19:37:57:WU02:FS01:0x22:************************************ Build *************************************
19:37:57:WU02:FS01:0x22: Version: 0.0.5
19:37:57:WU02:FS01:0x22: Date: Apr 22 2020
19:37:57:WU02:FS01:0x22: Time: 04:42:59
19:37:57:WU02:FS01:0x22: Repository: Git
19:37:57:WU02:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
19:37:57:WU02:FS01:0x22: Branch: HEAD
19:37:57:WU02:FS01:0x22: Compiler: Visual C++ 2008
19:37:57:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:37:57:WU02:FS01:0x22: Platform: win32 10
19:37:57:WU02:FS01:0x22: Bits: 64
19:37:57:WU02:FS01:0x22: Mode: Release
19:37:57:WU02:FS01:0x22:************************************ System ************************************
19:37:57:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
19:37:57:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
19:37:57:WU02:FS01:0x22: CPUs: 16
19:37:57:WU02:FS01:0x22: Memory: 31.73GiB
19:37:57:WU02:FS01:0x22:Free Memory: 17.77GiB
19:37:57:WU02:FS01:0x22: Threads: WINDOWS_THREADS
19:37:57:WU02:FS01:0x22: OS Version: 6.2
19:37:57:WU02:FS01:0x22:Has Battery: true
19:37:57:WU02:FS01:0x22: On Battery: false
19:37:57:WU02:FS01:0x22: UTC Offset: 2
19:37:57:WU02:FS01:0x22: PID: 25372
19:37:57:WU02:FS01:0x22: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
19:37:57:WU02:FS01:0x22: OS: Windows 10 Pro
19:37:57:WU02:FS01:0x22: OS Arch: AMD64
19:37:57:WU02:FS01:0x22:********************************************************************************
19:37:57:WU02:FS01:0x22:Project: 14417 (Run 0, Clone 435, Gen 68)
19:37:57:WU02:FS01:0x22:Unit: 0x0000005e0d5262775e84c8a604b23260
19:37:57:WU02:FS01:0x22:Digital signatures verified
19:37:57:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:37:57:WU02:FS01:0x22:Version 0.0.5
19:37:59:WU02:FS01:0x22: Found a checkpoint file
19:38:27:WU01:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
19:39:22:WU02:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
19:39:22:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:42:20:WU01:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
19:45:57:WU02:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
19:48:26:WU01:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
19:51:58:FS01:Shutting core down
19:51:58:WU02:FS01:0x22:WARNING:Console control signal 1 on PID 25372
19:51:58:WU02:FS01:0x22:Exiting, please wait. . .
19:51:58:WU02:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
19:52:01:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
19:52:58:WU01:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
19:54:54:WU01:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
19:56:36:WU01:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
19:56:36:WU03:FS00:Connecting to assign1.foldingathome.org:80
19:56:37:WU03:FS00:Assigned to work server 168.245.198.125
19:56:37:WU03:FS00:Requesting new work unit for slot 00: RUNNING cpu:14 from 168.245.198.125
19:56:37:WU03:FS00:Connecting to 168.245.198.125:8080
19:56:38:WU03:FS00:Downloading 872.50KiB
19:56:39:WU03:FS00:Download complete
19:56:39:WU03:FS00:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:16425 run:1799 clone:1 gen:115 core:0xa7 unit:0x00000090a8f5c67d5e913fb924ce8288
19:58:16:WU01:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
19:58:17:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
19:58:17:WU01:FS00:0xa7:Saving result file dhdl.xvg
19:58:17:WU01:FS00:0xa7:Saving result file frame40.trr
19:58:17:WU01:FS00:0xa7:Saving result file md.log
19:58:17:WU01:FS00:0xa7:Saving result file pullf.xvg
19:58:17:WU01:FS00:0xa7:Saving result file pullx.xvg
19:58:17:WU01:FS00:0xa7:Saving result file science.log
19:58:17:WU01:FS00:0xa7:Saving result file traj_comp.xtc
19:58:17:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
19:58:18:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:58:18:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14823 run:330 clone:1 gen:40 core:0xa7 unit:0x0000002d9bf7a4d55ea30d94cfba13df
19:58:18:WU01:FS00:Uploading 6.82MiB to 155.247.164.213
19:58:18:WU01:FS00:Connecting to 155.247.164.213:8080
19:58:18:WU03:FS00:Starting
19:58:18:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -np 14
19:58:18:WU03:FS00:Started FahCore on PID 3548
19:58:18:WU03:FS00:Core PID:28032
19:58:18:WU03:FS00:FahCore 0xa7 started
19:58:18:WU03:FS00:0xa7:*********************** Log Started 2020-05-25T19:58:18Z ***********************
19:58:18:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:58:18:WU03:FS00:0xa7: Type: 0xa7
19:58:18:WU03:FS00:0xa7: Core: Gromacs
19:58:18:WU03:FS00:0xa7: Args: -dir 03 -suffix 01 -version 706 -lifeline 3548 -checkpoint 15 -np
19:58:18:WU03:FS00:0xa7: 14
19:58:18:WU03:FS00:0xa7:************************************ CBang *************************************
19:58:18:WU03:FS00:0xa7: Date: Oct 26 2019
19:58:18:WU03:FS00:0xa7: Time: 01:38:25
19:58:18:WU03:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
19:58:18:WU03:FS00:0xa7: Branch: master
19:58:18:WU03:FS00:0xa7: Compiler: Visual C++ 2008
19:58:18:WU03:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:58:18:WU03:FS00:0xa7: Platform: win32 10
19:58:18:WU03:FS00:0xa7: Bits: 64
19:58:18:WU03:FS00:0xa7: Mode: Release
19:58:18:WU03:FS00:0xa7:************************************ System ************************************
19:58:18:WU03:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
19:58:18:WU03:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
19:58:18:WU03:FS00:0xa7: CPUs: 16
19:58:18:WU03:FS00:0xa7: Memory: 31.73GiB
19:58:18:WU03:FS00:0xa7:Free Memory: 20.67GiB
19:58:18:WU03:FS00:0xa7: Threads: WINDOWS_THREADS
19:58:18:WU03:FS00:0xa7: OS Version: 6.2
19:58:18:WU03:FS00:0xa7:Has Battery: true
19:58:18:WU03:FS00:0xa7: On Battery: false
19:58:18:WU03:FS00:0xa7: UTC Offset: 2
19:58:18:WU03:FS00:0xa7: PID: 28032
19:58:18:WU03:FS00:0xa7: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
19:58:18:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
19:58:18:WU03:FS00:0xa7: Version: 0.0.18
19:58:18:WU03:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:58:18:WU03:FS00:0xa7: Copyright: 2019 foldingathome.org
19:58:18:WU03:FS00:0xa7: Homepage: https://foldingathome.org/
19:58:18:WU03:FS00:0xa7: Time: 01:52:30
19:58:18:WU03:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
19:58:18:WU03:FS00:0xa7:************************************ Build *************************************
19:58:18:WU03:FS00:0xa7: SIMD: avx_256
19:58:18:WU03:FS00:0xa7:********************************************************************************
19:58:18:WU03:FS00:0xa7:Project: 16425 (Run 1799, Clone 1, Gen 115)
19:58:18:WU03:FS00:0xa7:Unit: 0x00000090a8f5c67d5e913fb924ce8288
19:58:18:WU03:FS00:0xa7:Reading tar file core.xml
19:58:18:WU03:FS00:0xa7:Reading tar file frame115.tpr
19:58:18:WU03:FS00:0xa7:Digital signatures verified
19:58:18:WU03:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
19:58:18:WU03:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
19:58:18:WU03:FS00:0xa7:Calling: mdrun -s frame115.tpr -o frame115.trr -x frame115.xtc -cpt 15 -nt 12
19:58:18:WU03:FS00:0xa7:Steps: first=115000000 total=1000000
19:58:19:WU03:FS00:0xa7:Completed 1 out of 1000000 steps (0%)
19:58:24:WU01:FS00:Upload 7.33%
19:58:30:WU01:FS00:Upload 13.74%
19:58:36:WU01:FS00:Upload 20.15%
19:58:42:WU01:FS00:Upload 25.65%
19:58:48:WU01:FS00:Upload 32.06%
19:58:54:WU01:FS00:Upload 39.39%
19:59:00:WU01:FS00:Upload 45.80%
19:59:06:WU01:FS00:Upload 51.30%
19:59:12:WU01:FS00:Upload 57.71%
19:59:18:WU01:FS00:Upload 64.12%
19:59:24:WU01:FS00:Upload 70.54%
19:59:30:WU01:FS00:Upload 76.95%
19:59:36:WU01:FS00:Upload 83.36%
19:59:42:WU01:FS00:Upload 89.77%
19:59:48:WU01:FS00:Upload 96.19%
19:59:52:WU01:FS00:Upload complete
19:59:52:WU01:FS00:Server responded WORK_ACK (400)
19:59:52:WU01:FS00:Final credit estimate, 3482.00 points
19:59:52:WU01:FS00:Cleaning up
20:00:08:WU03:FS00:0xa7:Completed 10000 out of 1000000 steps (1%)
20:01:54:WU03:FS00:0xa7:Completed 20000 out of 1000000 steps (2%)
20:03:42:WU03:FS00:0xa7:Completed 30000 out of 1000000 steps (3%)
20:05:32:WU03:FS00:0xa7:Completed 40000 out of 1000000 steps (4%)
20:07:29:WU03:FS00:0xa7:Completed 50000 out of 1000000 steps (5%)
20:09:15:WU03:FS00:0xa7:Completed 60000 out of 1000000 steps (6%)
20:11:00:WU03:FS00:0xa7:Completed 70000 out of 1000000 steps (7%)
20:12:47:WU03:FS00:0xa7:Completed 80000 out of 1000000 steps (8%)
20:14:31:WU03:FS00:0xa7:Completed 90000 out of 1000000 steps (9%)
20:16:17:WU00:FS02:Connecting to assign1.foldingathome.org:80
20:16:17:WU02:FS01:Starting
20:16:17:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:16:17:WU02:FS01:Started FahCore on PID 28912
20:16:18:WU02:FS01:Core PID:26288
20:16:18:WU02:FS01:FahCore 0x22 started
20:16:18:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
20:16:18:WU00:FS02:Connecting to assign2.foldingathome.org:80
20:16:18:WU02:FS01:0x22:*********************** Log Started 2020-05-25T20:16:18Z ***********************
20:16:18:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:16:18:WU02:FS01:0x22: Type: 0x22
20:16:18:WU02:FS01:0x22: Core: Core22
20:16:18:WU02:FS01:0x22: Website: https://foldingathome.org/
20:16:18:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:16:18:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:16:18:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
20:16:18:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 28912 -checkpoint 15
20:16:18:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
20:16:18:WU02:FS01:0x22: 0 -gpu 0
20:16:18:WU02:FS01:0x22: Config: <none>
20:16:18:WU02:FS01:0x22:************************************ Build *************************************
20:16:18:WU02:FS01:0x22: Version: 0.0.5
20:16:18:WU02:FS01:0x22: Date: Apr 22 2020
20:16:18:WU02:FS01:0x22: Time: 04:42:59
20:16:18:WU02:FS01:0x22: Repository: Git
20:16:18:WU02:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
20:16:18:WU02:FS01:0x22: Branch: HEAD
20:16:18:WU02:FS01:0x22: Compiler: Visual C++ 2008
20:16:18:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:16:18:WU02:FS01:0x22: Platform: win32 10
20:16:18:WU02:FS01:0x22: Bits: 64
20:16:18:WU02:FS01:0x22: Mode: Release
20:16:18:WU02:FS01:0x22:************************************ System ************************************
20:16:18:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
20:16:18:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
20:16:18:WU02:FS01:0x22: CPUs: 16
20:16:18:WU02:FS01:0x22: Memory: 31.73GiB
20:16:18:WU02:FS01:0x22:Free Memory: 19.93GiB
20:16:18:WU02:FS01:0x22: Threads: WINDOWS_THREADS
20:16:18:WU02:FS01:0x22: OS Version: 6.2
20:16:18:WU02:FS01:0x22:Has Battery: true
20:16:18:WU02:FS01:0x22: On Battery: false
20:16:18:WU02:FS01:0x22: UTC Offset: 2
20:16:18:WU02:FS01:0x22: PID: 26288
20:16:18:WU02:FS01:0x22: OS: Windows 10 Pro
20:16:18:WU02:FS01:0x22: OS Arch: AMD64
20:16:18:WU02:FS01:0x22:********************************************************************************
20:16:18:WU02:FS01:0x22:Project: 14417 (Run 0, Clone 435, Gen 68)
20:16:18:WU02:FS01:0x22:Unit: 0x0000005e0d5262775e84c8a604b23260
20:16:18:WU02:FS01:0x22:Digital signatures verified
20:16:18:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:16:18:WU02:FS01:0x22:Version 0.0.5
20:16:19:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
20:16:19:WU00:FS02:Connecting to assign3.foldingathome.org:80
20:16:19:WU02:FS01:0x22: Found a checkpoint file
20:16:20:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
20:16:20:WU00:FS02:Connecting to assign4.foldingathome.org:80
20:16:20:WU03:FS00:0xa7:Completed 100000 out of 1000000 steps (10%)
20:16:21:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
20:16:21:ERROR:WU00:FS02:Exception: Could not get an assignment
20:17:14:WU02:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
20:17:14:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:19:29:WU03:FS00:0xa7:Completed 110000 out of 1000000 steps (11%)
20:20:56:FS01:Shutting core down
20:20:56:WU02:FS01:0x22:WARNING:Console control signal 1 on PID 26288
20:20:56:WU02:FS01:0x22:Exiting, please wait. . .
20:20:56:WU02:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
20:20:57:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
20:21:25:WU02:FS01:Starting
20:21:25:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:21:25:WU02:FS01:Started FahCore on PID 23232
20:21:25:WU02:FS01:Core PID:16660
20:21:25:WU02:FS01:FahCore 0x22 started
20:21:26:WU02:FS01:0x22:*********************** Log Started 2020-05-25T20:21:25Z ***********************
20:21:26:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:21:26:WU02:FS01:0x22: Type: 0x22
20:21:26:WU02:FS01:0x22: Core: Core22
20:21:26:WU02:FS01:0x22: Website: https://foldingathome.org/
20:21:26:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:21:26:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:21:26:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
20:21:26:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 23232 -checkpoint 15
20:21:26:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
20:21:26:WU02:FS01:0x22: 0 -gpu 0
20:21:26:WU02:FS01:0x22: Config: <none>
20:21:26:WU02:FS01:0x22:************************************ Build *************************************
20:21:26:WU02:FS01:0x22: Version: 0.0.5
20:21:26:WU02:FS01:0x22: Date: Apr 22 2020
20:21:26:WU02:FS01:0x22: Time: 04:42:59
20:21:26:WU02:FS01:0x22: Repository: Git
20:21:26:WU02:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
20:21:26:WU02:FS01:0x22: Branch: HEAD
20:21:26:WU02:FS01:0x22: Compiler: Visual C++ 2008
20:21:26:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:21:26:WU02:FS01:0x22: Platform: win32 10
20:21:26:WU02:FS01:0x22: Bits: 64
20:21:26:WU02:FS01:0x22: Mode: Release
20:21:26:WU02:FS01:0x22:************************************ System ************************************
20:21:26:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
20:21:26:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
20:21:26:WU02:FS01:0x22: CPUs: 16
20:21:26:WU02:FS01:0x22: Memory: 31.73GiB
20:21:26:WU02:FS01:0x22:Free Memory: 20.01GiB
20:21:26:WU02:FS01:0x22: Threads: WINDOWS_THREADS
20:21:26:WU02:FS01:0x22: OS Version: 6.2
20:21:26:WU02:FS01:0x22:Has Battery: true
20:21:26:WU02:FS01:0x22: On Battery: false
20:21:26:WU02:FS01:0x22: UTC Offset: 2
20:21:26:WU02:FS01:0x22: PID: 16660
20:21:26:WU02:FS01:0x22: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
20:21:26:WU02:FS01:0x22: OS: Windows 10 Pro
20:21:26:WU02:FS01:0x22: OS Arch: AMD64
20:21:26:WU02:FS01:0x22:********************************************************************************
20:21:26:WU02:FS01:0x22:Project: 14417 (Run 0, Clone 435, Gen 68)
20:21:26:WU02:FS01:0x22:Unit: 0x0000005e0d5262775e84c8a604b23260
20:21:26:WU02:FS01:0x22:Digital signatures verified
20:21:26:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:21:26:WU02:FS01:0x22:Version 0.0.5
20:21:28:WU02:FS01:0x22: Found a checkpoint file
20:22:41:WU02:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
20:22:41:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:23:01:WU03:FS00:0xa7:Completed 120000 out of 1000000 steps (12%)
20:27:50:WU03:FS00:0xa7:Completed 130000 out of 1000000 steps (13%)
20:29:08:WU02:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
20:33:16:WU03:FS00:0xa7:Completed 140000 out of 1000000 steps (14%)
20:35:12:FS01:Shutting core down
20:35:12:WU02:FS01:0x22:WARNING:Console control signal 1 on PID 16660
20:35:12:WU02:FS01:0x22:Exiting, please wait. . .
20:35:12:WU02:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
20:35:13:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
20:37:20:WU03:FS00:0xa7:Completed 150000 out of 1000000 steps (15%)
20:39:06:WU03:FS00:0xa7:Completed 160000 out of 1000000 steps (16%)
20:41:00:WU03:FS00:0xa7:Completed 170000 out of 1000000 steps (17%)
20:42:52:WU03:FS00:0xa7:Completed 180000 out of 1000000 steps (18%)
20:44:52:WU03:FS00:0xa7:Completed 190000 out of 1000000 steps (19%)
20:46:47:WU03:FS00:0xa7:Completed 200000 out of 1000000 steps (20%)
20:48:39:WU03:FS00:0xa7:Completed 210000 out of 1000000 steps (21%)
Re: System unusable whilst GPU folding
Thanks Jimbo, there be logs!
From FAH's perspective, your sysem information is here.
and here:
You have two slots, one which runs on your CPU and one which runs on your GPU. They operate independently on two different assignments. You have one supported GPU and ie's set to run on idle. Your Intel UHD Graphics 630 iGPU is not supported.
To get the maximum out of your CPU, FAHCore_a7 is using avx_256 instructions. Perhaps you need to leave more CPU resources for whatever else you choose to do with your computer.
18:17:52:******************************* System ********************************
18:17:52: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
18:17:52: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
18:17:52: CPUs: 16
18:17:52: Memory: 31.73GiB
18:17:52: Free Memory: 25.07GiB
18:17:52: Threads: WINDOWS_THREADS
18:17:52: OS Version: 6.2
18:17:52: Has Battery: true
18:17:52: On Battery: false
18:17:52: UTC Offset: 2
18:17:52: PID: 17668
18:17:52: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient
18:17:52: OS: Windows 10 Enterprise
18:17:52: OS Arch: AMD64
18:17:52: GPUs: 1
18:17:52: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU117M [GeForce GTX 1650 Mobile /
18:17:52: Max-Q]
18:17:52: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
18:17:52:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.45
18:17:52:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
18:17:52: Win32 Service: false
18:17:52:***********************************************************************
18:17:52:<config>
18:17:52: <!-- Network -->
18:17:52: <proxy v=':8080'/>
18:17:52:
18:17:52: <!-- Slot Control -->
18:17:52: <power v='full'/>
18:17:52:
18:17:52: <!-- User Information -->
18:17:52: <passkey v='********************************'/>
18:17:52: <team v='10813'/>
18:17:52: <user v='Ian_Worthington'/>
18:17:52:
18:17:52: <!-- Folding Slots -->
18:17:52: <slot id='0' type='CPU'>
18:17:52: <paused v='true'/>
18:17:52: </slot>
18:17:52: <slot id='1' type='GPU'>
18:17:52: <idle v='true'/>
18:17:52: </slot>
18:17:52:</config>
How about starting in FAHControl: Configure + slots + cpu + edit + change the -1 at the top of that screen to, say, 12 and see how you like it.
Won't that affect Cpu folding rather than Gpu folding?bruce wrote:How about starting in FAHControl: Configure + slots + cpu + edit + change the -1 at the top of that screen to, say, 12 and see how you like it.
Your system initially knew it had 2 GPUs one an Intel and one an Nvidia, as the Intel is not compatible with F@H it is not selected
18:17:52: GPUs: 1
18:17:52: Max-Q]
18:17:52:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.45 <--- Nvidia Driver
18:17:52:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20 <--- Intel Driver
Nvidia uses a trick they used to call Optimus but now call Max-Q to lower power consumption by using an Intel GPU until you need more powerful graphics, then using a Nvidia GPU.
https://www.geforce.com/hardware/techno ... technology
Our problem is that F@H fails on the Intel GPU before it has a chance to switch to the Nvidia GPU. You got the message:
18:19:50:FS00:Shutting core down
18:19:50:WARNING:WU01:Slot ID 1 no longer exists and there are no other matching slots, dumping
18:19:50:WU01:Sending unit results: id:01 state:SEND error:DUMPED project:16441 run:342 clone:2 gen:34 core:0x22 unit:0x0000002c80fccb015ea997ffe0adf4f9
I have no one magic way to always use the Nvidia GPU, and if you do, expect your Laptop to be hotter and more power hungry.
Back when I used Optimus it was selectable in the BIOS, more recently It was selectable in the Nvidia Control Panel under 3D settings. At least one volunteer has found that if he always is running MSI Afterburner, it never switches to Intel, an odd workaround.
https://www.msi.com/page/afterburner
As I say, should you succeed, closely monitor your temperatures!
(If you get GPU folding to work, do consider bruce's suggestion to use 12 CPUs. As a CPU only folder, your PC is fine at 16)
18:17:52: GPUs: 1
18:17:52: Max-Q]
Yes, but looking at your logs, I see you running only CPU folding.IanWorthington wrote:Won't that affect Cpu folding rather than Gpu folding?
CPUs are managed by the OS, with task priorities and interrupts and virtual storage. And FAH can allocate work to all of your CPU threads or any number less than all.
GPUs are not managed by an OS. They're either on or off. Work sent to it is processed by whatever resources it has and then returned. A work packet sent from your OS to update something on your screen has to compete with a work packet sent by FAH.
you can manually pause your GPU and there won't be any screen lag. You can unpause and depending on the speed of your GPU and the complexity and sequence of FAH's work packets, you may see screen lag.
the only kind of GPU moderation that FAH can to is to run only when your OS says your mouse and keyboard are idle and it will pause automatically just like (inversely) it would wake up from a screensaver when you move your mouse or type something.
Not quite sure why you're saying I'm only folding on the CPU. This (below) seems, to me, to say that I'm folding on the Nvidia, no?
Also I don't understand
Resource Manager is saying that _a7 is running 13 threads. Is setting it to 12 not a reduction, and why would that be helpful?
12:12:31:<config>
12:12:31: <!-- Network -->
12:12:31: <proxy v=':8080'/>
12:12:31:
12:12:31: <!-- Slot Control -->
12:12:31: <power v='full'/>
12:12:31:
12:12:31: <!-- User Information -->
12:12:31: <passkey v='*****'/>
12:12:31: <team v='10813'/>
12:12:31: <user v='Ian_Worthington'/>
12:12:31:
12:12:31: <!-- Folding Slots -->
12:12:31: <slot id='0' type='CPU'/>
12:12:31: <slot id='2' type='GPU'>
12:12:31: <gpu-index v='0'/>
12:12:31: <idle v='true'/>
12:12:31: </slot>
12:12:31: <slot id='1' type='GPU'>
12:12:31: <gpu-index v='1'/>
12:12:31: </slot>
12:12:31:</config>
12:13:55:WU03:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
12:17:34:WU03:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
12:21:15:WU03:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
12:25:07:WU03:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
12:26:03:WU00:FS02:Connecting to assign1.foldingathome.org:80
12:26:03:WU01:FS01:Starting
12:26:03:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:26:03:WU01:FS01:Started FahCore on PID 28308
12:26:03:WU01:FS01:Core PID:31684
12:26:03:WU01:FS01:FahCore 0x22 started
12:26:04:WU01:FS01:0x22:*********************** Log Started 2020-05-26T12:26:04Z ***********************
12:26:04:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
12:26:04:WU01:FS01:0x22: Type: 0x22
12:26:04:WU01:FS01:0x22: Core: Core22
12:26:04:WU01:FS01:0x22: Website: https://foldingathome.org/
12:26:04:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
12:26:04:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
12:26:04:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
12:26:04:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 28308 -checkpoint 15
12:26:04:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
12:26:04:WU01:FS01:0x22: 0 -gpu 0
12:26:04:WU01:FS01:0x22: Config: <none>
12:26:04:WU01:FS01:0x22:************************************ Build *************************************
12:26:04:WU01:FS01:0x22: Version: 0.0.5
12:26:04:WU01:FS01:0x22: Date: Apr 22 2020
12:26:04:WU01:FS01:0x22: Time: 04:42:59
12:26:04:WU01:FS01:0x22: Repository: Git
12:26:04:WU01:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
12:26:04:WU01:FS01:0x22: Branch: HEAD
12:26:04:WU01:FS01:0x22: Compiler: Visual C++ 2008
12:26:04:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:26:04:WU01:FS01:0x22: Platform: win32 10
12:26:04:WU01:FS01:0x22: Bits: 64
12:26:04:WU01:FS01:0x22: Mode: Release
12:26:04:WU01:FS01:0x22:************************************ System ************************************
12:26:04:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
12:26:04:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
12:26:04:WU01:FS01:0x22: CPUs: 16
12:26:04:WU01:FS01:0x22: Memory: 31.73GiB
12:26:04:WU01:FS01:0x22:Free Memory: 18.43GiB
12:26:04:WU01:FS01:0x22: Threads: WINDOWS_THREADS
12:26:04:WU01:FS01:0x22: OS Version: 6.2
12:26:04:WU01:FS01:0x22:Has Battery: true
12:26:04:WU01:FS01:0x22: On Battery: false
12:26:04:WU01:FS01:0x22: UTC Offset: 2
12:26:04:WU01:FS01:0x22: PID: 31684
12:26:04:WU01:FS01:0x22: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
12:26:04:WU01:FS01:0x22: OS: Windows 10 Pro
12:26:04:WU01:FS01:0x22: OS Arch: AMD64
12:26:04:WU01:FS01:0x22:********************************************************************************
12:26:04:WU01:FS01:0x22:Project: 14251 (Run 380, Clone 2, Gen 44)
12:26:04:WU01:FS01:0x22:Unit: 0x00000041cedfaa925eab0322f8476280
12:26:04:WU01:FS01:0x22:Digital signatures verified
12:26:04:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
12:26:04:WU01:FS01:0x22:Version 0.0.5
12:26:05:WU01:FS01:0x22: Found a checkpoint file
12:26:08:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:26:08:WU00:FS02:Connecting to assign2.foldingathome.org:80
12:26:10:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:26:10:WU00:FS02:Connecting to assign3.foldingathome.org:80
12:26:11:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:26:11:WU00:FS02:Connecting to assign4.foldingathome.org:80
12:26:13:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:26:13:ERROR:WU00:FS02:Exception: Could not get an assignment
12:27:27:WU01:FS01:0x22:Completed 60000 out of 500000 steps (12%)
12:27:27:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
12:27:40:WU00:FS02:Connecting to assign1.foldingathome.org:80
12:27:41:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:27:41:WU00:FS02:Connecting to assign2.foldingathome.org:80
12:27:43:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:27:43:WU00:FS02:Connecting to assign3.foldingathome.org:80
12:27:45:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:27:45:WU00:FS02:Connecting to assign4.foldingathome.org:80
12:27:46:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:27:46:ERROR:WU00:FS02:Exception: Could not get an assignment
12:30:03:FS01:Shutting core down
12:30:03:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 31684
12:30:03:WU01:FS01:0x22:Exiting, please wait. . .
12:30:03:WU01:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
12:30:06:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
12:30:37:WU03:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
12:34:39:WU03:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
12:34:58:WU00:FS02:Connecting to assign1.foldingathome.org:80
12:34:59:WU01:FS01:Starting
12:34:59:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:34:59:WU01:FS01:Started FahCore on PID 36816
12:34:59:WU01:FS01:Core PID:36704
12:34:59:WU01:FS01:FahCore 0x22 started
12:34:59:WU01:FS01:0x22:*********************** Log Started 2020-05-26T12:34:59Z ***********************
12:34:59:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
12:34:59:WU01:FS01:0x22: Type: 0x22
12:34:59:WU01:FS01:0x22: Core: Core22
12:34:59:WU01:FS01:0x22: Website: https://foldingathome.org/
12:34:59:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
12:34:59:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
12:34:59:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
12:34:59:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 36816 -checkpoint 15
12:34:59:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
12:34:59:WU01:FS01:0x22: 0 -gpu 0
12:34:59:WU01:FS01:0x22: Config: <none>
12:34:59:WU01:FS01:0x22:************************************ Build *************************************
12:34:59:WU01:FS01:0x22: Version: 0.0.5
12:34:59:WU01:FS01:0x22: Date: Apr 22 2020
12:34:59:WU01:FS01:0x22: Time: 04:42:59
12:34:59:WU01:FS01:0x22: Repository: Git
12:34:59:WU01:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
12:34:59:WU01:FS01:0x22: Branch: HEAD
12:34:59:WU01:FS01:0x22: Compiler: Visual C++ 2008
12:34:59:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:34:59:WU01:FS01:0x22: Platform: win32 10
12:35:00:WU01:FS01:0x22: Bits: 64
12:35:00:WU01:FS01:0x22: Mode: Release
12:35:00:WU01:FS01:0x22:************************************ System ************************************
12:35:00:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
12:35:00:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
12:35:00:WU01:FS01:0x22: CPUs: 16
12:35:00:WU01:FS01:0x22: Memory: 31.73GiB
12:35:00:WU01:FS01:0x22:Free Memory: 18.68GiB
12:35:00:WU01:FS01:0x22: Threads: WINDOWS_THREADS
12:35:00:WU01:FS01:0x22: OS Version: 6.2
12:35:00:WU01:FS01:0x22:Has Battery: true
12:35:00:WU01:FS01:0x22: On Battery: false
12:35:00:WU01:FS01:0x22: UTC Offset: 2
12:35:00:WU01:FS01:0x22: PID: 36704
12:35:00:WU01:FS01:0x22: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
12:35:00:WU01:FS01:0x22: OS: Windows 10 Pro
12:35:00:WU01:FS01:0x22: OS Arch: AMD64
12:35:00:WU01:FS01:0x22:********************************************************************************
12:35:00:WU01:FS01:0x22:Project: 14251 (Run 380, Clone 2, Gen 44)
12:35:00:WU01:FS01:0x22:Unit: 0x00000041cedfaa925eab0322f8476280
12:35:00:WU01:FS01:0x22:Digital signatures verified
12:35:00:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
12:35:00:WU01:FS01:0x22:Version 0.0.5
12:35:00:WU01:FS01:0x22: Found a checkpoint file
12:35:03:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:35:03:WU00:FS02:Connecting to assign2.foldingathome.org:80
12:35:05:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:35:05:WU00:FS02:Connecting to assign3.foldingathome.org:80
12:35:07:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:35:07:WU00:FS02:Connecting to assign4.foldingathome.org:80
12:35:09:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:35:09:ERROR:WU00:FS02:Exception: Could not get an assignment
12:36:28:WU01:FS01:0x22:Completed 60000 out of 500000 steps (12%)
12:36:28:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
12:39:13:WU00:FS02:Connecting to assign1.foldingathome.org:80
12:39:14:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:39:14:WU00:FS02:Connecting to assign2.foldingathome.org:80
12:39:15:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:39:15:WU00:FS02:Connecting to assign3.foldingathome.org:80
12:39:17:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:39:17:WU00:FS02:Connecting to assign4.foldingathome.org:80
12:39:19:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:39:19:ERROR:WU00:FS02:Exception: Could not get an assignment
12:41:13:WU01:FS01:0x22:Completed 65000 out of 500000 steps (13%)
12:42:09:WU03:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
12:45:54:WU01:FS01:0x22:Completed 70000 out of 500000 steps (14%)
12:46:04:WU00:FS02:Connecting to assign1.foldingathome.org:80
12:46:05:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:46:05:WU00:FS02:Connecting to assign2.foldingathome.org:80
12:46:07:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:46:07:WU00:FS02:Connecting to assign3.foldingathome.org:80
12:46:08:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:46:08:WU00:FS02:Connecting to assign4.foldingathome.org:80
12:46:10:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:46:10:ERROR:WU00:FS02:Exception: Could not get an assignment
12:50:34:WU01:FS01:0x22:Completed 75000 out of 500000 steps (15%)
12:52:24:WU03:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
12:55:15:WU01:FS01:0x22:Completed 80000 out of 500000 steps (16%)
12:57:12:WU00:FS02:Connecting to assign1.foldingathome.org:80
12:57:14:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:57:14:WU00:FS02:Connecting to assign2.foldingathome.org:80
12:57:16:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:57:16:WU00:FS02:Connecting to assign3.foldingathome.org:80
12:57:17:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:57:17:WU00:FS02:Connecting to assign4.foldingathome.org:80
12:57:18:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:57:18:ERROR:WU00:FS02:Exception: Could not get an assignment
13:00:53:WU01:FS01:0x22:Completed 85000 out of 500000 steps (17%)
13:02:37:WU03:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
13:05:34:WU01:FS01:0x22:Completed 90000 out of 500000 steps (18%)
13:10:15:WU01:FS01:0x22:Completed 95000 out of 500000 steps (19%)
13:13:06:WU03:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
13:14:56:WU01:FS01:0x22:Completed 100000 out of 500000 steps (20%)
13:15:07:WU00:FS02:Connecting to assign1.foldingathome.org:80
13:15:07:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
13:15:07:WU00:FS02:Connecting to assign2.foldingathome.org:80
13:15:08:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
13:15:08:WU00:FS02:Connecting to assign3.foldingathome.org:80
13:15:09:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
13:15:09:WU00:FS02:Connecting to assign4.foldingathome.org:80
13:15:09:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
13:15:09:ERROR:WU00:FS02:Exception: Could not get an assignment
13:20:33:WU01:FS01:0x22:Completed 105000 out of 500000 steps (21%)
13:22:08:FS01:Shutting core down
13:22:08:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 36704
13:22:08:WU01:FS01:0x22:Exiting, please wait. . .
13:22:08:WU01:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
13:22:11:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
13:23:16:WU03:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
13:27:12:WU03:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
13:31:03:WU03:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
13:31:20:WU01:FS01:Starting
13:31:20:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\IanWo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 26588 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
13:31:20:WU01:FS01:Started FahCore on PID 31160
13:31:20:WU01:FS01:Core PID:25364
13:31:20:WU01:FS01:FahCore 0x22 started
13:31:21:WU01:FS01:0x22:*********************** Log Started 2020-05-26T13:31:21Z ***********************
13:31:21:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
13:31:21:WU01:FS01:0x22: Type: 0x22
13:31:21:WU01:FS01:0x22: Core: Core22
13:31:21:WU01:FS01:0x22: Website: https://foldingathome.org/
13:31:21:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
13:31:21:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
13:31:21:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
13:31:21:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 31160 -checkpoint 15
13:31:21:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
13:31:21:WU01:FS01:0x22: 0 -gpu 0
13:31:21:WU01:FS01:0x22: Config: <none>
13:31:21:WU01:FS01:0x22:************************************ Build *************************************
13:31:21:WU01:FS01:0x22: Version: 0.0.5
13:31:21:WU01:FS01:0x22: Date: Apr 22 2020
13:31:21:WU01:FS01:0x22: Time: 04:42:59
13:31:21:WU01:FS01:0x22: Repository: Git
13:31:21:WU01:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
13:31:21:WU01:FS01:0x22: Branch: HEAD
13:31:21:WU01:FS01:0x22: Compiler: Visual C++ 2008
13:31:21:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:31:21:WU01:FS01:0x22: Platform: win32 10
13:31:21:WU01:FS01:0x22: Bits: 64
13:31:21:WU01:FS01:0x22: Mode: Release
13:31:21:WU01:FS01:0x22:************************************ System ************************************
13:31:21:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
13:31:21:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
13:31:21:WU01:FS01:0x22: CPUs: 16
13:31:21:WU01:FS01:0x22: Memory: 31.73GiB
13:31:21:WU01:FS01:0x22:Free Memory: 18.21GiB
13:31:21:WU01:FS01:0x22: Threads: WINDOWS_THREADS
13:31:21:WU01:FS01:0x22: OS Version: 6.2
13:31:21:WU01:FS01:0x22:Has Battery: true
13:31:21:WU01:FS01:0x22: On Battery: false
13:31:21:WU01:FS01:0x22: UTC Offset: 2
13:31:21:WU01:FS01:0x22: PID: 25364
13:31:21:WU01:FS01:0x22: CWD: C:\Users\IanWo\AppData\Roaming\FAHClient\work
13:31:21:WU01:FS01:0x22: OS: Windows 10 Pro
13:31:21:WU01:FS01:0x22: OS Arch: AMD64
13:31:21:WU01:FS01:0x22:********************************************************************************
13:31:21:WU01:FS01:0x22:Project: 14251 (Run 380, Clone 2, Gen 44)
13:31:21:WU01:FS01:0x22:Unit: 0x00000041cedfaa925eab0322f8476280
13:31:21:WU01:FS01:0x22:Digital signatures verified
13:31:21:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
13:31:21:WU01:FS01:0x22:Version 0.0.5
13:31:22:WU01:FS01:0x22: Found a checkpoint file
13:32:52:WU01:FS01:0x22:Completed 100000 out of 500000 steps (20%)
13:32:52:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
13:37:35:WU01:FS01:0x22:Completed 105000 out of 500000 steps (21%)
13:38:51:WU03:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
13:42:15:WU01:FS01:0x22:Completed 110000 out of 500000 steps (22%)
13:44:09:WU00:FS02:Connecting to assign1.foldingathome.org:80
13:44:10:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
13:44:10:WU00:FS02:Connecting to assign2.foldingathome.org:80
13:44:11:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
13:44:11:WU00:FS02:Connecting to assign3.foldingathome.org:80
13:44:12:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
13:44:12:WU00:FS02:Connecting to assign4.foldingathome.org:80
13:44:13:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
13:44:13:ERROR:WU00:FS02:Exception: Could not get an assignment
13:46:56:WU01:FS01:0x22:Completed 115000 out of 500000 steps (23%)
13:49:20:WU03:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
13:51:35:WU01:FS01:0x22:Completed 120000 out of 500000 steps (24%)
13:57:12:WU01:FS01:0x22:Completed 125000 out of 500000 steps (25%)
13:59:49:WU03:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
14:01:53:WU01:FS01:0x22:Completed 130000 out of 500000 steps (26%)
14:06:33:WU01:FS01:0x22:Completed 135000 out of 500000 steps (27%)
14:10:24:WU03:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
14:11:14:WU01:FS01:0x22:Completed 140000 out of 500000 steps (28%)
14:16:50:WU01:FS01:0x22:Completed 145000 out of 500000 steps (29%)
14:20:38:WU03:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
14:21:29:WU01:FS01:0x22:Completed 150000 out of 500000 steps (30%)
14:26:09:WU01:FS01:0x22:Completed 155000 out of 500000 steps (31%)
14:30:49:WU01:FS01:0x22:Completed 160000 out of 500000 steps (32%)
14:31:08:WU00:FS02:Connecting to assign1.foldingathome.org:80
14:31:08:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
14:31:08:WU00:FS02:Connecting to assign2.foldingathome.org:80
14:31:09:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
14:31:09:WU00:FS02:Connecting to assign3.foldingathome.org:80
14:31:10:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
14:31:10:WU00:FS02:Connecting to assign4.foldingathome.org:80
14:31:10:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
14:31:11:ERROR:WU00:FS02:Exception: Could not get an assignment
14:31:28:WU03:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
14:36:26:WU01:FS01:0x22:Completed 165000 out of 500000 steps (33%)
14:40:44:WU03:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
14:41:05:WU01:FS01:0x22:Completed 170000 out of 500000 steps (34%)
14:45:44:WU01:FS01:0x22:Completed 175000 out of 500000 steps (35%)
14:50:14:WU03:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
14:50:23:WU01:FS01:0x22:Completed 180000 out of 500000 steps (36%)
14:55:56:WU01:FS01:0x22:Completed 185000 out of 500000 steps (37%)
14:59:39:WU03:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
15:00:36:WU01:FS01:0x22:Completed 190000 out of 500000 steps (38%)
15:05:15:WU01:FS01:0x22:Completed 195000 out of 500000 steps (39%)
15:09:20:WU03:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
15:09:54:WU01:FS01:0x22:Completed 200000 out of 500000 steps (40%)
15:15:27:WU01:FS01:0x22:Completed 205000 out of 500000 steps (41%)
15:18:40:WU03:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
15:20:06:WU01:FS01:0x22:Completed 210000 out of 500000 steps (42%)
15:24:46:WU01:FS01:0x22:Completed 215000 out of 500000 steps (43%)
15:28:18:WU03:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
15:29:24:WU01:FS01:0x22:Completed 220000 out of 500000 steps (44%)
15:31:08:WU00:FS02:Connecting to assign1.foldingathome.org:80
15:31:09:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:31:09:WU00:FS02:Connecting to assign2.foldingathome.org:80
15:31:09:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:31:09:WU00:FS02:Connecting to assign3.foldingathome.org:80
15:31:10:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
15:31:10:WU00:FS02:Connecting to assign4.foldingathome.org:80
15:31:11:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
15:31:11:ERROR:WU00:FS02:Exception: Could not get an assignment
15:35:01:WU01:FS01:0x22:Completed 225000 out of 500000 steps (45%)
15:37:46:WU03:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
15:39:39:WU01:FS01:0x22:Completed 230000 out of 500000 steps (46%)
15:44:18:WU01:FS01:0x22:Completed 235000 out of 500000 steps (47%)
15:47:20:WU03:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
15:48:57:WU01:FS01:0x22:Completed 240000 out of 500000 steps (48%)
15:54:31:WU01:FS01:0x22:Completed 245000 out of 500000 steps (49%)
15:56:41:WU03:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
15:59:10:WU01:FS01:0x22:Completed 250000 out of 500000 steps (50%)
16:03:49:WU01:FS01:0x22:Completed 255000 out of 500000 steps (51%)
16:06:23:WU03:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
16:08:30:WU01:FS01:0x22:Completed 260000 out of 500000 steps (52%)
16:14:10:WU01:FS01:0x22:Completed 265000 out of 500000 steps (53%)
16:16:15:WU03:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
16:18:51:WU01:FS01:0x22:Completed 270000 out of 500000 steps (54%)
******************************* Date: 2020-05-26 *******************************
16:23:32:WU01:FS01:0x22:Completed 275000 out of 500000 steps (55%)
16:27:52:WU03:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
16:28:14:WU01:FS01:0x22:Completed 280000 out of 500000 steps (56%)
16:31:08:WU00:FS02:Connecting to assign1.foldingathome.org:80
16:31:08:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:31:08:WU00:FS02:Connecting to assign2.foldingathome.org:80
16:31:09:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
16:31:09:WU00:FS02:Connecting to assign3.foldingathome.org:80
16:31:09:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:31:09:WU00:FS02:Connecting to assign4.foldingathome.org:80
16:31:10:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:31:10:ERROR:WU00:FS02:Exception: Could not get an assignment
16:33:56:WU01:FS01:0x22:Completed 285000 out of 500000 steps (57%)
16:38:35:WU01:FS01:0x22:Completed 290000 out of 500000 steps (58%)
16:38:57:WU03:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
16:42:45:FS01:Shutting core down
16:42:45:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 25364
16:42:45:WU01:FS01:0x22:Exiting, please wait. . .
16:42:45:WU01:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
16:42:49:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
16:45:49:WU03:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
16:49:44:WU03:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
16:53:26:WU03:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
16:57:13:WU03:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
17:00:57:WU03:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
17:04:51:WU03:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
17:08:51:WU03:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
17:12:46:WU03:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
17:16:50:WU03:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
17:20:52:WU03:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
17:24:45:WU03:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
17:28:30:WU03:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
17:32:16:WU03:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
17:36:05:WU03:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
