I've searched the forums for this issue and have read MANY posts, but none of them address my specific problem.
Here it is:
In "On Idle" mode, I have discovered that the ONLY way my Mac will start folding is for the screen to turn off. I can control when the screen turns off in the power settings, so I thought I had it all figured out. Then I noticed something odd; after the client has been working for a while (20 min or so) it mysteriously pauses, but the screen stays off. I checked the log file and found THIS:
09:14:11:WU01:FS00:0xa7:Project: 16437 (Run 0, Clone 2716, Gen 57)
09:14:11:WU01:FS00:0xa7:Unit: 0x0000004080fccb015ea74da03ad31167
09:14:11:WU01:FS00:0xa7:Digital signatures verified
09:14:11:WU01:FS00:0xa7:Calling: mdrun -s frame57.tpr -o frame57.trr -x frame57.xtc -cpi state.cpt -cpt 15 -nt 4
09:14:11:WU01:FS00:0xa7:Steps: first=14250000 total=250000
09:14:11:WU01:FS00:0xa7:Completed 118192 out of 250000 steps (47%)
[removed redundant entries for brevity]
09:44:15:WU01:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
09:47:27:FS00:Shutting core down
09:47:27:WU01:FS00:0xa7:Caught signal SIGINT(2) on PID 1213
09:47:27:WU01:FS00:0xa7:Exiting, please wait. . .
09:47:31:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
09:47:31:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)This is the where the mysterious pause occurs. What is making it stop?
Now the real problem. After folding stops, it WON'T START AGAIN. As long as the screen stays off, folding remains paused... indefinitely. FahClient is waiting for the screen to "turn off" but it can't, because it's already off! Logic. The only way to get the folding to start again is to "wake up" the screen and then let it time out / turn off again. The cycle then repeats: after 20-40 min (sometimes a hour or so) the folding pauses and never restarts as long as the screen stays off. When I check FAH in the morning, I find that very little progress was made overnight, so I've been switching it to "While I'm working" mode at night. Not a great solution.
Any ideas of how I might fix it? Look closely at the last 5 lines of the log file and let me know what you think.
Thanks so much!
-Brian
