Asus Crossfire iv motherboard
3.4 ghz AMD chip
16 gigs memory
Nvidea GeForce 8800 GTS video card
Windows 10
I am a newby and want to participate but I don't know where to go from here. The icon shows up on the desktop and when I click it a window opens permitting me to choose several things. I have tried both "when system is idle" and "when system is busy" but neither button that is supposed to going a a circle showing activity is doing anything. No matter how long I wait, the circle icon never shows up and the percentage of use is zero. Suggestions please.
Neither the CPU nor the GPU shows any activity
Re: Neither the CPU nor the GPU shows any activity
Welcome to the F@H Forum arstart
Can you please post the log file? Ensure you include the first 100 lines which will inform us of what the system configuration is and what the client settings are. If you require guidance, please view this topic: viewtopic.php?f=24&t=26036
Essentially, you can fold on your CPU but not on your GPU as it doesn't have Double Precision support. However, let's see your configuration and take it from there
way too old to fold.
https://www.techpowerup.com/gpu-specs/g ... s-512.c758
F@H tests against cards that can do OpenCL 1.2 and do Double Precision Floating Point math (FP64) This card does neither.
It is about 13 years old, think dog years, and if it could fold, would never finish in time.
F@H started warning users in 2013 that this generation of cards was nearing End of Life, they pulled the plug in 2014
https://folding.typepad.com/news/2013/0 ... ore78.html
https://foldingathome.org/2014/09/12/fa ... d-of-life/
I restarted and my cpu3 is working. My chip has 4 cores but for some reason it is only using #3. Since my GPU is too old, I will have to look for a replacement that will work. Thanks for the help.
The way you can change from 3 CPUs to 4 CPUs is as follows:
Open up Advanced Control (AKA FAHControl) -> Configure -> Slots Tab -> CPU -> Edit -> Change value from -1 to 3 -> OK -> Save
The next WU it downloads will use all 4 CPUs.
When you get a compatible GPU, it might be better to reduce it back to 3 to have 1 CPU to feed the GPU with data so it folds without issues
It is reserving one CPU to feed data to your GPU. If you remove the GPU slot, then the next Work Unit should use all 4. The current one is fixed at 3.arstart wrote:I restarted and my cpu3 is working. My chip has 4 cores but for some reason it is only using #3. Since my GPU is too old, I will have to look for a replacement that will work. Thanks for the help.
On this white field should be a gpu item, click it and then click remove.
Thanks for all the advice. My computer is actually running Linux MX. It is not showing the areas some folks have advised me to click on to get all the cores to work. But, it is working. As time goes along, maybe I can get the other 3 cores to work too. Again, thanks for the help.
I am not a Linux user but if you find an application called FAHcontrol it should look similar to my description for Windows
