12:33:42:WU02:FS01:0x22:Completed 3200000 out of 8000000 steps (40%)
12:37:20:WU02:FS01:0x22:Completed 3280000 out of 8000000 steps (41%)
12:40:57:WU02:FS01:0x22:Completed 3360000 out of 8000000 steps (42%)
12:56:47:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
12:56:47:WARNING:WU02:FS01:FahCore returned: WU_STALLED (127 = 0x7f)
12:56:47:WU02:FS01:Starting
12:56:47:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Swedis\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 13456 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
12:56:47:WU02:FS01:Started FahCore on PID 10444
12:56:48:WU02:FS01:Core PID:7416
12:56:48:WU02:FS01:FahCore 0x22 started
12:56:48:WU02:FS01:0x22:*********************** Log Started 2020-05-22T12:56:48Z ***********************
12:56:49:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
12:56:49:WU02:FS01:0x22: Type: 0x22
12:56:49:WU02:FS01:0x22: Core: Core22
12:56:49:WU02:FS01:0x22: Website: https://foldingathome.org/
12:56:49:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
12:56:49:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
12:56:49:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
12:56:49:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 10444 -checkpoint 15
12:56:49:WU02:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
12:56:49:WU02:FS01:0x22: Config: <none>
12:56:49:WU02:FS01:0x22:************************************ Build *************************************
12:56:49:WU02:FS01:0x22: Version: 0.0.5
12:56:49:WU02:FS01:0x22: Date: Apr 22 2020
12:56:49:WU02:FS01:0x22: Time: 04:42:59
12:56:49:WU02:FS01:0x22: Repository: Git
12:56:49:WU02:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
12:56:49:WU02:FS01:0x22: Branch: HEAD
12:56:49:WU02:FS01:0x22: Compiler: Visual C++ 2008
12:56:49:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:56:49:WU02:FS01:0x22: Platform: win32 10
12:56:49:WU02:FS01:0x22: Bits: 64
12:56:49:WU02:FS01:0x22: Mode: Release
12:56:49:WU02:FS01:0x22:************************************ System ************************************
12:56:49:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i7-4820K CPU @ 3.70GHz
12:56:49:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 62 Stepping 4
12:56:49:WU02:FS01:0x22: CPUs: 8
12:56:49:WU02:FS01:0x22: Memory: 15.94GiB
12:56:49:WU02:FS01:0x22:Free Memory: 13.19GiB
12:56:49:WU02:FS01:0x22: Threads: WINDOWS_THREADS
12:56:49:WU02:FS01:0x22: OS Version: 6.2
12:56:49:WU02:FS01:0x22:Has Battery: false
12:56:49:WU02:FS01:0x22: On Battery: false
12:56:49:WU02:FS01:0x22: UTC Offset: 2
12:56:49:WU02:FS01:0x22: PID: 7416
12:56:49:WU02:FS01:0x22: CWD: C:\Users\Swedis\AppData\Roaming\FAHClient\work
12:56:49:WU02:FS01:0x22: OS: Windows 10 Pro
12:56:49:WU02:FS01:0x22: OS Arch: AMD64
12:56:49:WU02:FS01:0x22:********************************************************************************
12:56:49:WU02:FS01:0x22:Project: 14564 (Run 188, Clone 0, Gen 45)
12:56:49:WU02:FS01:0x22:Unit: 0x0000004ecedfaa925eb08d3de02ccba6
12:56:49:WU02:FS01:0x22:Digital signatures verified
12:56:49:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
12:56:49:WU02:FS01:0x22:Version 0.0.5
12:56:49:WU02:FS01:0x22: Found a checkpoint file
12:57:19:WU02:FS01:0x22:Completed 3400000 out of 8000000 steps (42%)
12:57:19:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
12:59:55:WU02:FS01:0x22:Completed 3440000 out of 8000000 steps (43%)
13:05:08:WU02:FS01:0x22:Completed 3520000 out of 8000000 steps (44%)
14:18:39:WU02:FS01:0x22:Completed 4240000 out of 8000000 steps (53%)
14:27:52:WU02:FS01:0x22:Completed 4320000 out of 8000000 steps (54%)
14:28:14:FS01:Paused
14:28:14:FS01:Shutting core down
14:28:15:WU02:FS01:0x22:WARNING:Console control signal 1 on PID 7416
14:28:15:WU02:FS01:0x22:Exiting, please wait. . .
14:28:15:WU02:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
14:28:15:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
14:28:46:FS01:Unpaused
14:28:47:WU02:FS01:Starting
14:28:47:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Swedis\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 13456 -checkpoint 5 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
14:28:47:WU02:FS01:Started FahCore on PID 11908
14:28:47:WU02:FS01:Core PID:7212
14:28:47:WU02:FS01:FahCore 0x22 started
14:28:47:WU02:FS01:0x22:*********************** Log Started 2020-05-22T14:28:47Z ***********************
14:28:47:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:28:47:WU02:FS01:0x22: Type: 0x22
14:28:47:WU02:FS01:0x22: Core: Core22
14:28:47:WU02:FS01:0x22: Website: https://foldingathome.org/
14:28:47:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
14:28:47:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
14:28:47:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
14:28:47:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 11908 -checkpoint 5
14:28:47:WU02:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
14:28:47:WU02:FS01:0x22: Config: <none>
14:28:47:WU02:FS01:0x22:************************************ Build *************************************
14:28:47:WU02:FS01:0x22: Version: 0.0.5
14:28:47:WU02:FS01:0x22: Date: Apr 22 2020
14:28:47:WU02:FS01:0x22: Time: 04:42:59
14:28:47:WU02:FS01:0x22: Repository: Git
14:28:47:WU02:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
14:28:47:WU02:FS01:0x22: Branch: HEAD
14:28:47:WU02:FS01:0x22: Compiler: Visual C++ 2008
14:28:47:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:28:47:WU02:FS01:0x22: Platform: win32 10
14:28:47:WU02:FS01:0x22: Bits: 64
14:28:47:WU02:FS01:0x22: Mode: Release
14:28:47:WU02:FS01:0x22:************************************ System ************************************
14:28:47:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i7-4820K CPU @ 3.70GHz
14:28:47:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 62 Stepping 4
14:28:47:WU02:FS01:0x22: CPUs: 8
14:28:47:WU02:FS01:0x22: Memory: 15.94GiB
14:28:47:WU02:FS01:0x22:Free Memory: 12.95GiB
14:28:47:WU02:FS01:0x22: Threads: WINDOWS_THREADS
14:28:47:WU02:FS01:0x22: OS Version: 6.2
14:28:47:WU02:FS01:0x22:Has Battery: false
14:28:47:WU02:FS01:0x22: On Battery: false
14:28:47:WU02:FS01:0x22: UTC Offset: 2
14:28:47:WU02:FS01:0x22: PID: 7212
14:28:47:WU02:FS01:0x22: CWD: C:\Users\Swedis\AppData\Roaming\FAHClient\work
14:28:47:WU02:FS01:0x22: OS: Windows 10 Pro
14:28:47:WU02:FS01:0x22: OS Arch: AMD64
14:28:47:WU02:FS01:0x22:********************************************************************************
14:28:47:WU02:FS01:0x22:Project: 14564 (Run 188, Clone 0, Gen 45)
14:28:47:WU02:FS01:0x22:Unit: 0x0000004ecedfaa925eb08d3de02ccba6
14:28:47:WU02:FS01:0x22:Digital signatures verified
14:28:47:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:28:47:WU02:FS01:0x22:Version 0.0.5
14:28:50:WU02:FS01:0x22: Found a checkpoint file
14:29:00:WU02:FS01:0x22:Completed 4320000 out of 8000000 steps (54%)
14:29:00:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:32:42:WU02:FS01:0x22:Completed 4400000 out of 8000000 steps (55%)
14:36:19:WU02:FS01:0x22:Completed 4480000 out of 8000000 steps (56%)
14:39:56:WU02:FS01:0x22:Completed 4560000 out of 8000000 steps (57%)
16:54:45:WU02:FS01:0x22:Completed 7520000 out of 8000000 steps (94%)
16:58:25:WU02:FS01:0x22:Completed 7600000 out of 8000000 steps (95%)
17:02:05:WU02:FS01:0x22:Completed 7680000 out of 8000000 steps (96%)
17:13:38:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
17:13:38:WARNING:WU02:FS01:FahCore returned: WU_STALLED (127 = 0x7f)
17:13:38:WU02:FS01:Starting
17:13:38:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Swedis\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 13456 -checkpoint 5 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
17:13:38:WU02:FS01:Started FahCore on PID 11788
17:13:38:WU02:FS01:Core PID:8388
17:13:38:WU02:FS01:FahCore 0x22 started
17:13:39:WU02:FS01:0x22:*********************** Log Started 2020-05-22T17:13:39Z ***********************
17:13:39:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
17:13:39:WU02:FS01:0x22: Type: 0x22
17:13:39:WU02:FS01:0x22: Core: Core22
17:13:39:WU02:FS01:0x22: Website: https://foldingathome.org/
17:13:39:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
17:13:39:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
17:13:39:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
17:13:39:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 11788 -checkpoint 5
17:13:39:WU02:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
17:13:39:WU02:FS01:0x22: Config: <none>
17:13:39:WU02:FS01:0x22:************************************ Build *************************************
17:13:39:WU02:FS01:0x22: Version: 0.0.5
17:13:39:WU02:FS01:0x22: Date: Apr 22 2020
17:13:39:WU02:FS01:0x22: Time: 04:42:59
17:13:39:WU02:FS01:0x22: Repository: Git
17:13:39:WU02:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
17:13:39:WU02:FS01:0x22: Branch: HEAD
17:13:39:WU02:FS01:0x22: Compiler: Visual C++ 2008
17:13:39:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:13:39:WU02:FS01:0x22: Platform: win32 10
17:13:39:WU02:FS01:0x22: Bits: 64
17:13:39:WU02:FS01:0x22: Mode: Release
17:13:39:WU02:FS01:0x22:************************************ System ************************************
17:13:39:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i7-4820K CPU @ 3.70GHz
17:13:39:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 62 Stepping 4
17:13:39:WU02:FS01:0x22: CPUs: 8
17:13:39:WU02:FS01:0x22: Memory: 15.94GiB
17:13:39:WU02:FS01:0x22:Free Memory: 12.83GiB
17:13:39:WU02:FS01:0x22: Threads: WINDOWS_THREADS
17:13:39:WU02:FS01:0x22: OS Version: 6.2
17:13:39:WU02:FS01:0x22:Has Battery: false
17:13:39:WU02:FS01:0x22: On Battery: false
17:13:39:WU02:FS01:0x22: UTC Offset: 2
17:13:39:WU02:FS01:0x22: PID: 8388
17:13:39:WU02:FS01:0x22: CWD: C:\Users\Swedis\AppData\Roaming\FAHClient\work
17:13:39:WU02:FS01:0x22: OS: Windows 10 Pro
17:13:39:WU02:FS01:0x22: OS Arch: AMD64
17:13:39:WU02:FS01:0x22:********************************************************************************
17:13:39:WU02:FS01:0x22:Project: 14564 (Run 188, Clone 0, Gen 45)
17:13:39:WU02:FS01:0x22:Unit: 0x0000004ecedfaa925eb08d3de02ccba6
17:13:39:WU02:FS01:0x22:Digital signatures verified
17:13:39:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
17:13:39:WU02:FS01:0x22:Version 0.0.5
17:13:39:WU02:FS01:0x22: Found a checkpoint file
17:13:50:WU02:FS01:0x22:Completed 7700000 out of 8000000 steps (96%)
17:13:50:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:16:35:WU02:FS01:0x22:Completed 7760000 out of 8000000 steps (97%)
17:20:18:WU02:FS01:0x22:Completed 7840000 out of 8000000 steps (98%)
17:23:59:WU02:FS01:0x22:Completed 7920000 out of 8000000 steps (99%)
17:27:39:WU02:FS01:0x22:Completed 8000000 out of 8000000 steps (100%)
17:27:39:WU01:FS01:Connecting to assign1.foldingathome.org:80
17:27:40:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
17:27:40:WU01:FS01:Connecting to assign2.foldingathome.org:80
17:27:40:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
17:27:40:WU02:FS01:0x22:Saving result file checkpointState.xml
17:27:40:WU01:FS01:Assigned to work server 206.223.170.146
17:27:40:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Hawaii [Radeon R9 200/300X Series] from 206.223.170.146
17:27:40:WU01:FS01:Connecting to 206.223.170.146:8080
17:27:40:WU02:FS01:0x22:Saving result file checkpt.crc
17:27:40:WU02:FS01:0x22:Saving result file positions.xtc
17:27:41:WU02:FS01:0x22:Saving result file science.log
17:27:41:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
17:27:41:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:27:41:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:14564 run:188 clone:0 gen:45 core:0x22 unit:0x0000004ecedfaa925eb08d3de02ccba6
17:27:41:WU02:FS01:Uploading 5.69MiB to 206.223.170.146
17:27:41:WU02:FS01:Connecting to 206.223.170.146:8080
