Windows & Linux Conurrently
- Hardware configuration: 2 iMacs and 1 dedicated Windows 10 Pro rig with 1 RTX 2070 Super and 1 RTX 2060 KO
I am enjoying my foray into Folding@home (formerly a SETI devotee) and looking for ways to increase my FAH productivity. My question: Would it be possible and/or worthwhile to run FAH concurrently using both the Windows App and Linux App on a HP Spectre laptop running Windows 10 v2004 and WSL2 installed?
Re: Windows & Linux Conurrently
not really a good idea, you would be dividing the same hardware resources between the two running clients and it would not gain you or the project anything. if you have another machine running linux you can set folding then it's possible to do that with the same username and passkey as the windows install
Welcome to Folding@Home!
I am not sure what you are hoping to accomplish, but F@H does not share well, even with F@H. It is almost a given that you will do less science, and make fewer points. F@H wants to be the lowest Priority job, balancing that across OS's will be sub optimal.
OTOH, Best of luck!
OTOH, Best of luck!
Thank you for the replies. Bottom line is that I am trying to maximize productivity on my Windows 10 laptop which is only reporting 15-20% of the points per day we get in our iMacs. There may be other reasons for this such as delayed downloads in the Windows app but I am surprised at the relatively poor folding performance of my HP Spectre. Perhaps I need some additional FAH advanced configuration. Not sure. Alternatively, I don't need the laptop for work at the moment so perhaps I would be better off just converting it to Linux.
Ah Low points!
I would make sure you have a passkey and that it is entered corectly.
https://foldingathome.org/support/faq/points/passkey/
posting the first 200 lines of your log will give us more clues.
viewtopic.php?f=24&t=26036
Warnings and Errors
*********************** Log Started 2020-05-21T00:27:38Z ***********************
00:29:45:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 2516
00:29:47:WARNING:WU00:FS00:Changed SMP threads from 3 to 7 this can cause some work units to fail
00:29:47:WARNING:WU00:FS00:AS lowered CPUs from 7 to 3
00:30:06:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
00:30:27:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:30:28:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:30:49:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
00:32:22:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
00:33:22:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
Full Log:
00:27:38:Trying to access database...
00:27:38:Successfully acquired database lock
00:27:38:Downloading GPUs.txt from assign1.foldingathome.org:80
00:27:38:Connecting to assign1.foldingathome.org:80
00:27:38:Read GPUs.txt
00:27:38:Enabled folding slot 00: PAUSED cpu:3 (not configured)
00:27:39:Enabled folding slot 01: PAUSED gpu:0:GP108 [GeForce MX150] (not configured)
00:27:39:****************************** FAHClient ******************************
00:27:39: Version: 7.6.13
00:27:39: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:27:39: Copyright: 2020 foldingathome.org
00:27:39: Homepage: https://foldingathome.org/
00:27:39: Date: Apr 27 2020
00:27:39: Time: 21:21:01
00:27:39: Revision: 5a652817f46116b6e135503af97f18e094414e3b
00:27:39: Branch: master
00:27:39: Compiler: Visual C++ 2008
00:27:39: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:27:39: Platform: win32 10
00:27:39: Bits: 32
00:27:39: Mode: Release
00:27:39: Args: --open-web-control
00:27:39:******************************** CBang ********************************
00:27:39: Date: Apr 24 2020
00:27:39: Time: 17:07:55
00:27:39: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
00:27:39: Bits: 32
00:27:39:******************************* System ********************************
00:27:39: CPU: Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz
00:27:39: CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
00:27:39: CPUs: 8
00:27:39: Memory: 15.88GiB
00:27:39: Free Memory: 11.77GiB
00:27:39: Threads: WINDOWS_THREADS
00:27:39: OS Version: 6.2
00:27:39: Has Battery: true
00:27:39: On Battery: false
00:27:39: UTC Offset: -4
00:27:39: PID: 7528
00:27:39: CWD: C:\Users\david\AppData\Roaming\FAHClient
00:27:39: Win32 Service: false
00:27:39: OS: Windows 10 Enterprise
00:27:39: OS Arch: AMD64
00:27:39: GPUs: 1
00:27:39: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GP108 [GeForce MX150]
00:27:39: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:9.2
00:27:39:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:27.20
00:27:39:******************************* libFAH ********************************
00:27:39: Date: Apr 15 2020
00:27:39: Time: 14:53:14
00:27:39: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
00:27:39: Bits: 32
00:27:39:***********************************************************************
00:27:39:<config>
00:27:39: <!-- Folding Slots -->
00:27:39: <slot id='0' type='CPU'/>
00:27:39: <slot id='1' type='GPU'/>
00:27:39:</config>
00:27:44:17:127.0.0.1:New Web session
00:28:39:Saving configuration to config.xml
00:28:39:<config>
00:28:39: <!-- Folding Slots -->
00:28:39: <slot id='0' type='CPU'/>
00:28:39: <slot id='1' type='GPU'/>
00:28:39:</config>
00:28:39:Set client configured
00:28:39:WU00:FS00:Connecting to assign1.foldingathome.org:80
00:28:39:WU00:FS00:Assigned to work server 130.237.11.145
00:28:39:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 130.237.11.145
00:28:39:WU00:FS00:Connecting to 130.237.11.145:8080
00:28:40:WU00:FS00:Downloading 4.49MiB
00:28:42:WU00:FS00:Download complete
00:28:42:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16805 run:10 clone:897 gen:2 core:0xa7 unit:0x0000000282ed0b915eb420467ff407dc
00:28:42:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
00:28:42:WU00:FS00:Connecting to cores.foldingathome.org:80
00:28:43:WU00:FS00:FahCore a7: Downloading 6.71MiB
00:28:43:WU00:FS00:FahCore a7: Download complete
00:28:44:WU00:FS00:Valid core signature
00:28:44:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
00:28:44:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
00:28:44:WU00:FS00:Starting
00:28:44:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\david\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 7528 -checkpoint 15 -np 3
00:28:44:WU00:FS00:Started FahCore on PID 7380
00:28:44:WU00:FS00:Core PID:2516
00:28:44:WU00:FS00:FahCore 0xa7 started
00:28:44:WU00:FS00:0xa7:*********************** Log Started 2020-05-21T00:28:44Z ***********************
00:28:44:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:28:44:WU00:FS00:0xa7: Type: 0xa7
00:28:44:WU00:FS00:0xa7: Core: Gromacs
00:28:44:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 7380 -checkpoint 15 -np 3
00:28:44:WU00:FS00:0xa7:************************************ CBang *************************************
00:28:44:WU00:FS00:0xa7: Date: Oct 26 2019
00:28:44:WU00:FS00:0xa7: Time: 01:38:25
00:28:44:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
00:28:44:WU00:FS00:0xa7: Branch: master
00:28:44:WU00:FS00:0xa7: Compiler: Visual C++ 2008
00:28:44:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:28:44:WU00:FS00:0xa7: Platform: win32 10
00:28:44:WU00:FS00:0xa7: Bits: 64
00:28:44:WU00:FS00:0xa7: Mode: Release
00:28:44:WU00:FS00:0xa7:************************************ System ************************************
00:28:44:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz
00:28:44:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
00:28:44:WU00:FS00:0xa7: CPUs: 8
00:28:44:WU00:FS00:0xa7: Memory: 15.88GiB
00:28:44:WU00:FS00:0xa7:Free Memory: 11.23GiB
00:28:44:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
00:28:44:WU00:FS00:0xa7: OS Version: 6.2
00:28:44:WU00:FS00:0xa7:Has Battery: true
00:28:44:WU00:FS00:0xa7: On Battery: false
00:28:44:WU00:FS00:0xa7: UTC Offset: -4
00:28:44:WU00:FS00:0xa7: PID: 2516
00:28:44:WU00:FS00:0xa7: CWD: C:\Users\david\AppData\Roaming\FAHClient\work
00:28:44:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
00:28:44:WU00:FS00:0xa7: Version: 0.0.18
00:28:44:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:28:44:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
00:28:44:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
00:28:44:WU00:FS00:0xa7: Time: 01:52:30
00:28:44:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
00:28:44:WU00:FS00:0xa7:************************************ Build *************************************
00:28:44:WU00:FS00:0xa7: SIMD: avx_256
00:28:44:WU00:FS00:0xa7:********************************************************************************
00:28:44:WU00:FS00:0xa7:Project: 16805 (Run 10, Clone 897, Gen 2)
00:28:44:WU00:FS00:0xa7:Unit: 0x0000000282ed0b915eb420467ff407dc
00:28:44:WU00:FS00:0xa7:Reading tar file core.xml
00:28:44:WU00:FS00:0xa7:Reading tar file frame2.tpr
00:28:44:WU00:FS00:0xa7:Digital signatures verified
00:28:44:WU00:FS00:0xa7:Calling: mdrun -s frame2.tpr -o frame2.trr -cpt 15 -nt 3
00:28:44:WU00:FS00:0xa7:Steps: first=1000000 total=500000
00:28:47:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
00:29:40:Saving configuration to config.xml
00:29:40:<config>
00:29:40: <!-- User Information -->
00:29:40: <passkey v='*****'/>
00:29:40: <team v='258580'/>
00:29:40: <user v='KDNA'/>
00:29:40:
00:29:40: <!-- Folding Slots -->
00:29:40: <slot id='0' type='CPU'/>
00:29:40: <slot id='1' type='GPU'/>
00:29:40:</config>
00:29:45:FS00:Shutting core down
00:29:45:WU00:FS00:0xa7:Exiting, please wait. . .
00:29:45:WU01:FS01:Connecting to assign1.foldingathome.org:80
00:29:45:WU01:FS01:Assigned to work server 128.252.203.10
00:29:45:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP108 [GeForce MX150] from 128.252.203.10
00:29:45:WU01:FS01:Connecting to 128.252.203.10:8080
00:29:46:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
00:29:47:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
00:29:47:WU00:FS00:Starting
00:29:47:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\david\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 7528 -checkpoint 15 -np 3
00:29:47:WU00:FS00:Started FahCore on PID 2204
00:29:47:WU00:FS00:Core PID:8032
00:29:47:WU00:FS00:FahCore 0xa7 started
00:29:47:WU00:FS00:0xa7:*********************** Log Started 2020-05-21T00:29:47Z ***********************
00:29:47:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:29:47:WU00:FS00:0xa7: Type: 0xa7
00:29:47:WU00:FS00:0xa7: Core: Gromacs
00:29:47:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 2204 -checkpoint 15 -np 3
00:29:47:WU00:FS00:0xa7:************************************ CBang *************************************
00:29:47:WU00:FS00:0xa7: Date: Oct 26 2019
00:29:47:WU00:FS00:0xa7: Time: 01:38:25
00:29:47:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
00:29:47:WU00:FS00:0xa7: Branch: master
00:29:47:WU00:FS00:0xa7: Compiler: Visual C++ 2008
00:29:47:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:29:47:WU00:FS00:0xa7: Platform: win32 10
00:29:47:WU00:FS00:0xa7: Bits: 64
00:29:47:WU00:FS00:0xa7: Mode: Release
00:29:47:WU00:FS00:0xa7:************************************ System ************************************
00:29:47:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz
00:29:47:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
00:29:47:WU00:FS00:0xa7: CPUs: 8
00:29:47:WU00:FS00:0xa7: Memory: 15.88GiB
00:29:47:WU00:FS00:0xa7:Free Memory: 11.22GiB
00:29:47:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
00:29:47:WU00:FS00:0xa7: OS Version: 6.2
00:29:47:WU00:FS00:0xa7:Has Battery: true
00:29:47:WU00:FS00:0xa7: On Battery: false
00:29:47:WU00:FS00:0xa7: UTC Offset: -4
00:29:47:WU00:FS00:0xa7: PID: 8032
00:29:47:WU00:FS00:0xa7: CWD: C:\Users\david\AppData\Roaming\FAHClient\work
00:29:47:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
00:29:47:WU00:FS00:0xa7: Version: 0.0.18
00:29:47:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:29:47:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
00:29:47:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
00:29:47:WU00:FS00:0xa7: Time: 01:52:30
00:29:47:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
00:29:47:WU00:FS00:0xa7:************************************ Build *************************************
00:29:47:WU00:FS00:0xa7: SIMD: avx_256
00:29:47:WU00:FS00:0xa7:********************************************************************************
00:29:47:WU00:FS00:0xa7:Project: 16805 (Run 10, Clone 897, Gen 2)
00:29:47:WU00:FS00:0xa7:Unit: 0x0000000282ed0b915eb420467ff407dc
00:29:47:WU00:FS00:0xa7:Digital signatures verified
00:29:47:WU00:FS00:0xa7:Calling: mdrun -s frame2.tpr -o frame2.trr -cpi state.cpt -cpt 15 -nt 3
00:29:47:WU00:FS00:0xa7:Steps: first=1000000 total=500000
00:29:50:WU00:FS00:0xa7:Completed 387 out of 500000 steps (0%)
00:30:06:WU01:FS01:Connecting to 128.252.203.10:80
00:30:27:WU01:FS01:Connecting to assign1.foldingathome.org:80
00:30:28:WU01:FS01:Connecting to assign2.foldingathome.org:80
00:30:28:WU01:FS01:Assigned to work server 3.133.76.19
00:30:28:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP108 [GeForce MX150] from 3.133.76.19
00:30:28:WU01:FS01:Connecting to 3.133.76.19:8080
00:30:41:Saving configuration to config.xml
00:30:41:<config>
00:30:41: <!-- Slot Control -->
00:30:41: <power v='FULL'/>
00:30:41:
00:30:41: <!-- User Information -->
00:30:41: <passkey v='*****'/>
00:30:41: <team v='258580'/>
00:30:41: <user v='KDNA'/>
00:30:41:
00:30:41: <!-- Folding Slots -->
00:30:41: <slot id='0' type='CPU'/>
00:30:41: <slot id='1' type='GPU'/>
00:30:41:</config>
00:30:49:WU01:FS01:Connecting to 3.133.76.19:80
00:32:16:WU01:FS01:Downloading 20.50MiB
00:32:20:WU01:FS01:Download complete
00:32:20:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14445 run:0 clone:621 gen:13 core:0x22 unit:0x0000001a03854c135ea7b8914cb6e57d
00:32:20:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
00:32:20:WU01:FS01:Connecting to cores.foldingathome.org:80
00:32:21:WU01:FS01:FahCore 22: Downloading 4.04MiB
00:32:22:WU01:FS01:FahCore 22: Download complete
00:32:22:WU01:FS01:Valid core signature
00:32:22:WU01:FS01:Unpacked 13.50MiB to cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe
00:32:22:WU01:FS01:Starting
00:33:22:WU01:FS01:Starting
00:34:59:WU01:FS01:Starting
00:34:59:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
00:37:37:WU01:FS01:Starting
00:37:37:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
GPU Issues:
https://www.techpowerup.com/gpu-specs/g ... x150.c2959
If you download and install the driver from Nvidia, this should almost do as well as a GT 1030, Nvidia's slowest discrete card. It meets all the F@H Prerequisites, and should finish before any deadline if run 24/7
https://www.nvidia.com/en-us/drivers/results/159424/
This is not an Nvidia OpenCL, if I had to guess, Intel.
CPU issues:
00:27:39: CPUs: 8
You have 8 threads but are only using 3 of them, I would Up that to 6 if it was me.
Use this boilerplate to set it to 6
If you have GPUs, F@H reserves one CPU per GPU to feed it data across the PCIE bus.
F@H has difficulty with large primes and their multiples number of CPUs.
7 is always large, 5 is sometimes large, and 3 is never large. Try to choose a number that is a multiple of 2 and/or 3.
2, 3, 4, 6, and 8 are good numbers of CPUs to choose.
5 may work most of the time. 7 will bite you
Type the number you want, and click save.
Once the GPU has a good driver, and the CPUs are hard coded to 6, lets see a new log!
CPU issues:
00:27:39: CPUs: 8
Thank you for your help. Did a complete reinstall of Windows 10 Pro v2004 and updated anything and everything including Nvidia drivers. Also hard coded the CPU to 6 although F@H seems to want to reduce that to 3. FAH Points per Day have already improved dramatically (x10) and are approaching double what i get on my iMacs. Still seeing some error messages. Logs will follow.
Warnings & Errors
*********************** Log Started 2020-05-21T14:58:06Z ***********************
15:05:52:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 784
15:05:53:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:05:56:WARNING:WU00:FS00:Changed SMP threads from 3 to 7 this can cause some work units to fail
15:05:56:WARNING:WU00:FS00:AS lowered CPUs from 7 to 3
15:06:14:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
15:24:13:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 7284
15:24:21:WARNING:WU00:FS00:Changed SMP threads from 7 to 6 this can cause some work units to fail
15:24:21:WARNING:WU00:FS00:AS lowered CPUs from 6 to 3
It would be a good idea to change the CPU slot to 6 threads ...Use advanced control and configure it for this - I guess it is currently using -1 as the default and you have an 8 thread CPU.
Sometimes an AS will assign you a lower thread count due to lack of WUs available for your thread count … but in the case of 7 that is just a "bad number" as FAH doesn't like thread counts that are a multiple of primes greater than 3.
