Project: 14818 (Run 1692, Clone 0, Gen 41)
Breach
Post by Breach »
Not sure what happened here:
08:45:27:WU02:FS00:0xa7:             6
08:45:27:WU02:FS00:0xa7:************************************ CBang *************************************
08:45:27:WU02:FS00:0xa7:       Date: Oct 26 2019
08:45:27:WU02:FS00:0xa7:       Time: 01:38:25
08:45:27:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
08:45:27:WU02:FS00:0xa7:     Branch: master
08:45:27:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
08:45:27:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:45:27:WU02:FS00:0xa7:   Platform: win32 10
08:45:27:WU02:FS00:0xa7:       Bits: 64
08:45:27:WU02:FS00:0xa7:       Mode: Release
08:45:27:WU02:FS00:0xa7:************************************ System ************************************
08:45:27:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
08:45:27:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
08:45:27:WU02:FS00:0xa7:       CPUs: 8
08:45:27:WU02:FS00:0xa7:     Memory: 15.94GiB
08:45:27:WU02:FS00:0xa7:Free Memory: 8.93GiB
08:45:27:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
08:45:27:WU02:FS00:0xa7: OS Version: 6.2
08:45:27:WU02:FS00:0xa7:Has Battery: false
08:45:27:WU02:FS00:0xa7: On Battery: false
08:45:27:WU02:FS00:0xa7: UTC Offset: 2
08:45:27:WU02:FS00:0xa7:        PID: 21320
08:45:27:WU02:FS00:0xa7:        CWD: C:\Users\alexa\AppData\Roaming\FAHClient\work
08:45:27:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
08:45:27:WU02:FS00:0xa7:    Version: 0.0.18
08:45:27:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:45:27:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:45:27:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
08:45:27:WU02:FS00:0xa7:       Time: 01:52:30
08:45:27:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
08:45:27:WU02:FS00:0xa7:************************************ Build *************************************
08:45:27:WU02:FS00:0xa7:       SIMD: avx_256
08:45:27:WU02:FS00:0xa7:********************************************************************************
08:45:27:WU02:FS00:0xa7:Project: 14818 (Run 1692, Clone 0, Gen 41)
08:45:27:WU02:FS00:0xa7:Unit: 0x0000002e2879986c5ea8dcd3c0ac8e4d
08:45:27:WU02:FS00:0xa7:Digital signatures verified
08:45:27:WU02:FS00:0xa7:Calling: mdrun -s frame41.tpr -o frame41.trr -cpi state.cpt -cpt 10 -nt 6
08:45:27:WU02:FS00:0xa7:ERROR:Guru Meditation #fecdd19d3f279047.f26efa1a6d65b726 (7239.7890) '02/01/pullx.xvg'
08:45:27:WU02:FS00:0xa7:WARNING:Unexpected exit() call
08:45:27:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
08:45:27:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
08:45:27:WU02:FS00:0xa7:Saving result file dhdl.xvg
08:45:27:WU02:FS00:0xa7:Saving result file frame41.trr
08:45:27:WU02:FS00:0xa7:Saving result file md.log
08:45:27:WU02:FS00:0xa7:Saving result file pullf.xvg
08:45:27:WU02:FS00:0xa7:ERROR:Guru Meditation #f16cd81b867de3b3.b303fd2641113214 (3390.3707) '02/01/pullf.xvg'
08:45:30:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
08:45:30:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
08:45:30:WARNING:WU02:FS00:Too many errors, failing
08:45:30:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:14818 run:1692 clone:0 gen:41 core:0xa7 unit:0x0000002e2879986c5ea8dcd3c0ac8e4d
08:45:30:WU02:FS00:Uploading 2.08MiB to 40.121.152.108
08:45:30:WU02:FS00:Connecting to 40.121.152.108:8080
08:45:30:WU00:FS00:Connecting to assign1.foldingathome.org:80
08:45:31:WU00:FS00:Assigned to work server 128.252.203.1
08:45:31:WU00:FS00:Requesting new work unit for slot 00: READY cpu:6 from 128.252.203.1
08:45:31:WU00:FS00:Connecting to 128.252.203.1:8080
08:45:32:WU00:FS00:Downloading 5.82MiB
08:45:34:WU02:FS00:Upload complete
08:45:34:WU02:FS00:Server responded WORK_QUIT (404)
08:45:34:WARNING:WU02:FS00:Server did not like results, dumping
08:45:34:WU02:FS00:Cleaning up
Re: Project: 14818 (Run 1692, Clone 0, Gen 41)
Generally speaking, this error:
Means that the checkpoint was corrupted. That can happen due to few reasons; improper shutdown, anti-virus/anti-malware/anti-spyware/anti-ransomware, corrupted files, storage issues. You may need to work through the list to see what happened.
