08:31:36:WU00:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
08:35:12:WU00:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
08:35:16:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
08:35:16:WU00:FS01:0x22:Saving result file checkpointState.xml
08:35:19:WU00:FS01:0x22:Saving result file checkpt.crc
08:35:19:WU00:FS01:0x22:Saving result file positions.xtc
08:35:21:WU00:FS01:0x22:Saving result file science.log
08:35:21:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
08:35:21:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:35:21:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14438 run:0 clone:29 gen:19 core:0x22 unit:0x0000001a03854c135e9fc39c6a25c27f
08:35:21:WU00:FS01:Uploading 78.05MiB to 3.133.76.19
08:35:21:WU00:FS01:Connecting to 3.133.76.19:8080
08:35:27:WU00:FS01:Upload 1.36%
08:35:28:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
08:35:28:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14438 run:0 clone:29 gen:19 core:0x22 unit:0x0000001a03854c135e9fc39c6a25c27f
08:35:28:WU00:FS01:Uploading 78.05MiB to 3.133.76.19
08:35:28:WU00:FS01:Connecting to 3.133.76.19:8080
08:35:34:WU00:FS01:Upload 1.84%
08:35:35:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
08:35:43:FS01:Paused
08:35:48:Removing old file 'configs/config-20200513-023020.xml'
08:35:48:Saving configuration to config.xml
08:35:48:<config>
08:35:48: <!-- Folding Slot Configuration -->
08:35:48: <max-packet-size v='10'/>
08:35:48:
08:35:48: <!-- Network -->
08:35:48: <proxy v=':8080'/>
08:35:48:
08:35:48: <!-- Slot Control -->
08:35:48: <pause-on-start v='true'/>
08:35:48:
08:35:48: <!-- User Information -->
08:35:48: <passkey v='*****'/>
08:35:48: <team v='76140'/>
08:35:48: <user v='Badsinger'/>
08:35:48:
08:35:48: <!-- Work Unit Control -->
08:35:48: <next-unit-percentage v='100'/>
08:35:48:
08:35:48: <!-- Folding Slots -->
08:35:48: <slot id='1' type='GPU'>
08:35:48: <paused v='true'/>
08:35:48: </slot>
08:35:48:</config>
08:36:29:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14438 run:0 clone:29 gen:19 core:0x22 unit:0x0000001a03854c135e9fc39c6a25c27f
08:36:29:WU00:FS01:Uploading 78.05MiB to 3.133.76.19
08:36:29:WU00:FS01:Connecting to 3.133.76.19:8080
08:36:35:WU00:FS01:Upload 1.84%
08:36:39:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
08:38:06:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14438 run:0 clone:29 gen:19 core:0x22 unit:0x0000001a03854c135e9fc39c6a25c27f
08:38:06:WU00:FS01:Uploading 78.05MiB to 3.133.76.19
08:38:06:WU00:FS01:Connecting to 3.133.76.19:8080
08:38:12:WU00:FS01:Upload 1.84%
08:38:13:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
08:40:43:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14438 run:0 clone:29 gen:19 core:0x22 unit:0x0000001a03854c135e9fc39c6a25c27f
08:40:43:WU00:FS01:Uploading 78.05MiB to 3.133.76.19
08:40:43:WU00:FS01:Connecting to 3.133.76.19:8080
08:40:49:WU00:FS01:Upload 1.84%
08:40:50:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
08:44:57:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14438 run:0 clone:29 gen:19 core:0x22 unit:0x0000001a03854c135e9fc39c6a25c27f
08:44:57:WU00:FS01:Uploading 78.05MiB to 3.133.76.19
08:44:57:WU00:FS01:Connecting to 3.133.76.19:8080
08:45:03:WU00:FS01:Upload 1.52%
08:45:05:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed02:38:08:WU00:FS01:0x22:Reading tar file core.xml
02:38:08:WU00:FS01:0x22:Reading tar file integrator.xml
02:38:08:WU00:FS01:0x22:Reading tar file state.xml
02:38:08:WU00:FS01:0x22:Reading tar file system.xml
02:38:08:WU00:FS01:0x22:Digital signatures verified
02:38:08:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
02:38:08:WU00:FS01:0x22:Version 0.0.5
02:38:23:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
02:38:23:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:41:54:WU00:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
02:43:23:FS01:Finishing
02:45:28:WU00:FS01:0x22:Completed 40000 out of 2000000 steps (2%) Thanks for the help.
