Losing work and could not connect
Oakwheel
Post by Oakwheel »
Three times when I have started the FAH client (v. 5.03) on my machine I have lost all of the frames that I had done in the previous session. Most recently I lost 65 of 250 and was back to zero. This is pretty disheartening for me and wasteful for you. Is there some way this kind of situation can be avoided?
Also, all day today the client was unable to connect to "Work Server (results)," although I had an internet connection and no settings on my firewall have changed (FAH has access to the internet). Is this issue on my end ?
Any thoughts on these problems?
Thanks.
sortofageek
Post by sortofageek »
How are you shutting down the client? Do you wait a bit before restarting your computer?
Are you overclocking?
Please post relevant info from FAHlog-Prev.txt and FAHlog.txt.
Edit: Removed reference which applies to console client.
The Windows GUI V5.03 can be shut down using the context menu (right click) on the icon in systray and clicking Quit. (Do not use Pause.)
Are you running Windows Vista?
uncle fuzzy
Post by uncle fuzzy »
If you shut down your computer while the 5.03 client is paused, you'll lose your work. It must be running or stopped before shut down.
Oakwheel
Re: Losing work and could not connect
Post by Oakwheel »
Thanks for the responses.
To reply:
No, I am not using Vista. Am using XP SP2.
No, I was not overclocking when the frames got lost. There were a few occasions (2 that I know of) when I was running the FAH client and the system rebooted due to an unstable overclocking. But those were not among the times I wrote about in my post, when I lost the frames I had done. At any rate, now I run the client only at confirmed settings, until I test and thoroughly confirm more aggressive OC's by the usual means (which won't be for a while).
In reference to shutting down the client, the responses indicate that it should be manually shut down each time the computer is shut down or rebooted. I now do that, in an abundance of caution after the frame loses. But on some occasions in the past, I didn't, relying on it to terminate safely like the other programs that run in the Windows tray (antivirus, antispyware etc.). I presume when the program is manually shut down it routinely saves its work. Also, in the configuration menu, advanced tab, the checkpoint slider is set to 6 minutes, which I think is more frequent than the default. I would have assumed this would save all work more than 6 minutes old, even if the pc crashed.
I append the part of FAHlog-Prev.txt (the full text is in excess of the posting limits), which goes back to the relevant time period for the frame loses. It shows several places where the work unit was deleted because of an issue with the digital signature, as well as some reports of pc system instability (although I am certain there have only been 2 incidents of OC resets, and the all temps in the system are far under any thermal thresholds).
------------------------ Opening Log file [December 17 15:47:22]
# Windows Graphical Edition ###################################################
                       Folding@Home Client Version 5.03
                          http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@Home
[15:47:22] - Ask before connecting: No
[15:47:22] - User name: Oakwheel (Team 31574)
[15:47:22] - User ID: 699E8B4557618F18
[15:47:22] - Machine ID: 1
[15:47:22]
[15:47:22] Loaded queue successfully.
[15:47:22] Initialization complete
[15:47:22] + Benchmarking ...
[15:47:24] - Preparing to get new work unit...
[15:47:24] + Attempting to get work packet
[15:47:24] - Connecting to assignment server
[15:47:26] - Successful: assigned to (171.65.103.162).
[15:47:26] + News From Folding@Home: Welcome to Folding@Home
[15:47:26] Loaded queue successfully.
[15:47:26] - Couldn't send HTTP request to server
[15:47:26]   (Got status 503)
[15:47:26] + Could not connect to Work Server
[15:47:26] - Error: Attempt #1  to get work failed, and no other work to do.
             Waiting before retry.
[15:47:31] + Attempting to get work packet
[15:47:31] - Connecting to assignment server
[15:47:32] - Successful: assigned to (171.65.103.162).
[15:47:32] + News From Folding@Home: Welcome to Folding@Home
[15:47:32] Loaded queue successfully.
[15:47:32] - Couldn't send HTTP request to server
[15:47:32]   (Got status 503)
[15:47:32] + Could not connect to Work Server
[15:47:32] - Error: Attempt #2  to get work failed, and no other work to do.
[15:47:44] + Attempting to get work packet
[15:47:44] - Connecting to assignment server
[15:47:45] - Successful: assigned to (171.65.103.162).
[15:47:45] + News From Folding@Home: Welcome to Folding@Home
[15:47:45] Loaded queue successfully.
[15:47:45] - Couldn't send HTTP request to server
[15:47:45]   (Got status 503)
[15:47:45] + Could not connect to Work Server
[15:47:45] - Error: Attempt #3  to get work failed, and no other work to do.
[15:48:20] + Attempting to get work packet
[15:48:20] - Connecting to assignment server
[15:48:21] - Successful: assigned to (171.65.103.162).
[15:48:21] + News From Folding@Home: Welcome to Folding@Home
[15:48:21] Loaded queue successfully.
[15:48:32] + Closed connections
[15:48:32]
[15:48:32] + Processing work unit
[15:48:32] Core required: FahCore_78.exe
[15:48:32] Core found.
[15:48:32] Working on Unit 01 [December 17 15:48:32]
[15:48:32] + Working ...
[15:48:32]
[15:48:32] *------------------------------*
[15:48:32] Folding@Home Gromacs Core
[15:48:32] Version 1.90 (March 8, 2006)
[15:48:32]
[15:48:32] Preparing to commence simulation
[15:48:32] - Looking at optimizations...
[15:48:32] - Created dyn
[15:48:32] - Files status OK
[15:48:34] - Expanded 3065020 -> 16578189 (decompressed 540.8 percent)
[15:48:35] - Starting from initial work packet
[15:48:35]
[15:48:35] Project: 2417 (Run 24, Clone 25, Gen 11)
[15:48:35]
[15:48:35] Assembly optimizations on if available.
[15:48:35] Entering M.D.
[15:48:42] Protein: p2417_Ribo_Cl
[15:48:42]
[15:48:42] Writing local files
[15:48:44] Extra SSE boost OK.
[15:48:44] Writing local files
[15:48:44] Completed 0 out of 250000 steps  (0)
[15:50:53] Quit 101 - Fatal error: NaN detected: (ener[13])
[15:50:53]
[15:50:53] Simulation instability has been encountered. The run has entered a
[15:50:53]   state from which no further progress can be made.
[15:50:53] This may be the correct result of the simulation, however if you
[15:50:53]   often see other project units terminating early like this
[15:50:53]   too, you may wish to check the stability of your computer (issues
[15:50:53]   such as high temperature, overclocking, etc.).
[15:50:53] Going to send back what have done.
[15:50:53] logfile size: 7600
[15:50:53] - Writing 8163 bytes of core data to disk...
[15:50:53]   ... Done.
[15:50:54]
[15:50:54] Folding@home Core Shutdown: EARLY_UNIT_END
[15:50:57] CoreStatus = 72 (114)
[15:50:57] Sending work to server
[15:50:57] + Attempting to send results
[15:50:57] - Couldn't send HTTP request to server
[15:50:57]   (Got status 503)
[15:50:57] + Could not connect to Work Server (results)
[15:50:57]     (171.65.103.162:8080)
[15:50:57] - Error: Could not transmit unit 01 (completed December 17) to work server.
[15:50:57]   Keeping unit 01 in queue.
[15:50:58] - Couldn't send HTTP request to server
[15:50:58] + Could not connect to Work Server (results)
[15:50:58]     (171.65.103.100:8080)
[15:50:58]   Could not transmit unit 01 to Collection server; keeping in queue.
[15:50:58] - Preparing to get new work unit...
[15:50:58] + Attempting to get work packet
[15:50:58] - Connecting to assignment server
[15:50:59] - Successful: assigned to (171.65.103.162).
[15:50:59] + News From Folding@Home: Welcome to Folding@Home
[15:50:59] Loaded queue successfully.
[15:50:59] - Couldn't send HTTP request to server
[15:50:59] + Could not connect to Work Server
[15:50:59] - Error: Attempt #1  to get work failed, and no other work to do.
[15:51:15] + Attempting to get work packet
[15:51:15] - Connecting to assignment server
[15:51:15] - Successful: assigned to (171.65.103.162).
[15:51:15] + News From Folding@Home: Welcome to Folding@Home
[15:51:16] Loaded queue successfully.
[15:51:16] - Couldn't send HTTP request to server
[15:51:16]   (Got status 503)
[15:51:16] + Could not connect to Work Server
[15:51:16] - Error: Attempt #2  to get work failed, and no other work to do.
[15:51:28] + Attempting to get work packet
[15:51:28] - Connecting to assignment server
[15:51:29] - Successful: assigned to (171.65.103.162).
[15:51:29] + News From Folding@Home: Welcome to Folding@Home
[15:51:29] Loaded queue successfully.
[15:51:29] - Couldn't send HTTP request to server
[15:51:29]   (Got status 503)
[15:51:29] + Could not connect to Work Server
[15:51:29] - Error: Attempt #3  to get work failed, and no other work to do.
[15:51:35] Opening C:\Program Files\Folding@Home\MyFolding.html...
[15:51:54] + Attempting to get work packet
[15:51:54] - Connecting to assignment server
[15:51:54] - Successful: assigned to (171.65.103.162).
[15:51:54] + News From Folding@Home: Welcome to Folding@Home
[15:51:54] Loaded queue successfully.
[15:51:54] - Couldn't send HTTP request to server
[15:51:54]   (Got status 503)
[15:51:54] + Could not connect to Work Server
[15:51:54] - Error: Attempt #4  to get work failed, and no other work to do.
[15:52:42] + Attempting to get work packet
[15:52:42] - Connecting to assignment server
[15:52:42] - Successful: assigned to (171.65.103.162).
[15:52:42] + News From Folding@Home: Welcome to Folding@Home
[15:52:43] Loaded queue successfully.
[15:52:43] - Couldn't send HTTP request to server
[15:52:43]   (Got status 503)
[15:52:43] + Could not connect to Work Server
[15:52:43] - Error: Attempt #5  to get work failed, and no other work to do.
[15:54:04] + Attempting to get work packet
[15:54:04] - Connecting to assignment server
[15:54:04] - Successful: assigned to (171.65.103.162).
[15:54:04] + News From Folding@Home: Welcome to Folding@Home
[15:54:04] Loaded queue successfully.
[15:54:05] - Couldn't send HTTP request to server
[15:54:05]   (Got status 503)
[15:54:05] + Could not connect to Work Server
[15:54:05] - Error: Attempt #6  to get work failed, and no other work to do.
[15:56:52] + Attempting to get work packet
[15:56:52] - Connecting to assignment server
[15:56:53] - Successful: assigned to (171.65.103.162).
[15:56:53] + News From Folding@Home: Welcome to Folding@Home
[15:56:53] Loaded queue successfully.
[15:56:53] - Couldn't send HTTP request to server
[15:56:53]   (Got status 503)
[15:56:53] + Could not connect to Work Server
[15:56:53] - Error: Attempt #7  to get work failed, and no other work to do.
Folding@Home Client Shutdown.
--- Opening Log file [December 17 16:26:38]
[16:26:38] - Ask before connecting: No
[16:26:38] - User name: Oakwheel (Team 31574)
[16:26:38] - User ID: 699E8B4557618F18
[16:26:38] - Machine ID: 1
[16:26:38]
[16:26:38] Loaded queue successfully.
[16:26:38] Initialization complete
[16:26:38] + Benchmarking ...
[16:26:40] - Preparing to get new work unit...
[16:26:40] + Attempting to get work packet
[16:26:40] + Attempting to send results
[16:26:40] - Connecting to assignment server
[16:26:41] - Couldn't send HTTP request to server
[16:26:41]   (Got status 503)
[16:26:41] + Could not connect to Work Server (results)
[16:26:41]     (171.65.103.162:8080)
[16:26:41] - Error: Could not transmit unit 01 (completed December 17) to work server.
[16:26:41] + Attempting to send results
[16:26:41] - Successful: assigned to (171.65.103.162).
[16:26:41] + News From Folding@Home: Welcome to Folding@Home
[16:26:41] Loaded queue successfully.
[16:26:41] - Error: Attempt #1  to get work failed, and no other work to do.
[16:26:47] + Attempting to get work packet
[16:26:47] - Connecting to assignment server
[16:26:47] - Couldn't send HTTP request to server
[16:26:47] + Could not connect to Work Server (results)
[16:26:47]     (171.65.103.100:8080)
[16:26:47]   Could not transmit unit 01 to Collection server; keeping in queue.
[16:26:48] - Successful: assigned to (171.65.103.162).
[16:26:48] + News From Folding@Home: Welcome to Folding@Home
[16:26:48] Loaded queue successfully.
[16:27:04] + Closed connections
[16:27:04]
[16:27:04] + Processing work unit
[16:27:04] Core required: FahCore_78.exe
[16:27:04] Core found.
[16:27:04] Working on Unit 02 [December 17 16:27:04]
[16:27:04] + Working ...
[16:27:04]
[16:27:04] *------------------------------*
[16:27:04] Folding@Home Gromacs Core
[16:27:04] Version 1.90 (March 8, 2006)
[16:27:04]
[16:27:04] Preparing to commence simulation
[16:27:04] - Looking at optimizations...
[16:27:04] - Created dyn
[16:27:04] - Files status OK
[16:27:06] - Expanded 3061850 -> 16578193 (decompressed 541.4 percent)
[16:27:07] - Error: Bad work unit. Digital signatures don't match
[16:27:07] Error: Could not open work file
[16:27:07]
[16:27:07] Folding@home Core Shutdown: FILE_IO_ERROR
[16:27:10] CoreStatus = 75 (117)
[16:27:10] Error opening or reading from a file.
[16:27:10] Deleting current work unit & continuing...
[16:27:14] + Attempting to send results
[16:27:15] - Couldn't send HTTP request to server
[16:27:15]   (Got status 503)
[16:27:15] + Could not connect to Work Server (results)
[16:27:15]     (171.65.103.162:8080)
[16:27:15] - Error: Could not transmit unit 01 (completed December 17) to work server.
[16:27:15] + Attempting to send results
[16:27:28] - Couldn't send HTTP request to server
[16:27:28] + Could not connect to Work Server (results)
[16:27:28]     (171.65.103.100:8080)
[16:27:28]   Could not transmit unit 01 to Collection server; keeping in queue.
[16:27:28] - Preparing to get new work unit...
[16:27:28] + Attempting to get work packet
[16:27:28] - Connecting to assignment server
[16:27:28] - Successful: assigned to (171.65.103.162).
[16:27:28] + News From Folding@Home: Welcome to Folding@Home
[16:27:28] Loaded queue successfully.
[16:27:40] + Closed connections
[16:27:45]
[16:27:45] + Processing work unit
[16:27:45] Core required: FahCore_78.exe
[16:27:45] Core found.
[16:27:45] Working on Unit 03 [December 17 16:27:45]
[16:27:45] + Working ...
[16:27:46]
[16:27:46] *------------------------------*
[16:27:46] Folding@Home Gromacs Core
[16:27:46] Version 1.90 (March 8, 2006)
[16:27:46]
[16:27:46] Preparing to commence simulation
[16:27:46] - Looking at optimizations...
[16:27:46] - Created dyn
[16:27:46] - Files status OK
[16:27:48] - Expanded 3060270 -> 16578173 (decompressed 541.7 percent)
[16:27:48] - Starting from initial work packet
[16:27:48]
[16:27:48] Project: 2417 (Run 43, Clone 2, Gen 12)
[16:27:48]
[16:27:48] Assembly optimizations on if available.
[16:27:48] Entering M.D.
[16:27:55] Protein: p2417_Ribo_Cl
[16:27:55]
[16:27:55] Writing local files
[16:27:57] Extra SSE boost OK.
[16:27:58] Writing local files
[16:27:58] Completed 0 out of 250000 steps  (0)
--- Opening Log file [December 17 19:10:30]
[19:10:30] - Ask before connecting: No
[19:10:30] - User name: Oakwheel (Team 31574)
[19:10:30] - User ID: 699E8B4557618F18
[19:10:30] - Machine ID: 1
[19:10:30]
[19:10:30] Loaded queue successfully.
[19:10:30] Initialization complete
[19:10:30] + Benchmarking ...
[19:10:32]
[19:10:32] + Processing work unit
[19:10:32] + Attempting to send results
[19:10:32] Core required: FahCore_78.exe
[19:10:32] Core found.
[19:10:33] Working on Unit 03 [December 17 19:10:33]
[19:10:33] + Working ...
[19:10:33] - Couldn't send HTTP request to server
[19:10:33]   (Got status 503)
[19:10:33] + Could not connect to Work Server (results)
[19:10:33]     (171.65.103.162:8080)
[19:10:33] - Error: Could not transmit unit 01 (completed December 17) to work server.
[19:10:33] + Attempting to send results
[19:10:33]
[19:10:33] *------------------------------*
[19:10:33] Folding@Home Gromacs Core
[19:10:33] Version 1.90 (March 8, 2006)
[19:10:33]
[19:10:33] Preparing to commence simulation
[19:10:33] - Ensuring status. Please wait.
[19:10:36] - Couldn't send HTTP request to server
[19:10:36] + Could not connect to Work Server (results)
[19:10:36]     (171.65.103.100:8080)
[19:10:36]   Could not transmit unit 01 to Collection server; keeping in queue.
[19:10:51] - Looking at optimizations...
[19:10:51] - Working with standard loops on this execution.
[19:10:51] - Previous termination of core was improper.
[19:10:51] - Files status OK
[19:10:53] - Expanded 3060270 -> 16578173 (decompressed 541.7 percent)
[19:10:53]
[19:10:53] Project: 2417 (Run 43, Clone 2, Gen 12)
[19:10:53]
[19:10:53] Entering M.D.
[19:11:15] (Starting from checkpoint)
[19:11:15] Protein: p2417_Ribo_Cl
[19:11:15]
[19:11:15] Writing local files
[19:11:18] Writing local files
[19:11:18] Completed 0 out of 250000 steps  (0)
[19:32:44] Printing Queue Information
CURRENT QUEUE:
00  EMPTY
01  DONE      "Folding@Home" (78) 171.65.103.162:8080  December 17 15:48->December 17 15:50:57
02  EMPTY
03 *READY     "Folding@Home" (78) 171.65.103.162:8080  December 17 16:27 | March 8 16:27
04  EMPTY
05  EMPTY
06  EMPTY
07  EMPTY
08  EMPTY
09  EMPTY
[19:56:02] Writing local files
[19:56:02] Completed 2500 out of 250000 steps  (1)
[20:41:39] Writing local files
[20:41:39] Completed 5000 out of 250000 steps  (2)
[21:27:39] Writing local files
[21:27:40] Completed 7500 out of 250000 steps  (3)
[22:13:48] Writing local files
[22:13:49] Completed 10000 out of 250000 steps  (4)
--- Opening Log file [December 17 22:27:12]
[22:27:12] - Ask before connecting: No
[22:27:12] - User name: Oakwheel (Team 31574)
[22:27:12] - User ID: 699E8B4557618F18
[22:27:12] - Machine ID: 1
[22:27:12]
[22:27:12] Loaded queue successfully.
[22:27:12] Initialization complete
[22:27:12] + Benchmarking ...
[22:27:14]
[22:27:14] + Processing work unit
[22:27:14] + Attempting to send results
[22:27:14] Core required: FahCore_78.exe
[22:27:14] Core found.
[22:27:14] Working on Unit 03 [December 17 22:27:14]
[22:27:14] + Working ...
[22:27:14] - Couldn't send HTTP request to server
[22:27:14]   (Got status 503)
[22:27:14] + Could not connect to Work Server (results)
[22:27:14]     (171.65.103.162:8080)
[22:27:14] - Error: Could not transmit unit 01 (completed December 17) to work server.
[22:27:15]
[22:27:15] *------------------------------*
[22:27:15] Folding@Home Gromacs Core
[22:27:15] Version 1.90 (March 8, 2006)
[22:27:15]
[22:27:15] Preparing to commence simulation
[22:27:15] - Looking at optimizations...
[22:27:15] - Files status OK
[22:27:16] - Couldn't send HTTP request to server
[22:27:16] + Could not connect to Work Server (results)
[22:27:16]     (171.65.103.100:8080)
[22:27:16]   Could not transmit unit 01 to Collection server; keeping in queue.
[22:27:18] - Expanded 3060270 -> 16578173 (decompressed 541.7 percent)
[22:27:18]
[22:27:18] Project: 2417 (Run 43, Clone 2, Gen 12)
[22:27:18]
[22:27:18] Assembly optimizations on if available.
[22:27:18] Entering M.D.
[22:27:40] (Starting from checkpoint)
[22:27:40] Protein: p2417_Ribo_Cl
[22:27:40]
[22:27:40] Writing local files
[22:27:40] Completed 10327 out of 250000 steps  (4)
[22:27:42] Extra SSE boost OK.
[22:40:54] Writing local files
[22:40:54] Completed 12500 out of 250000 steps  (5)
[22:47:12] Quit 101 - Fatal error: NaN detected: (ener[38])
[22:47:12]
[22:47:12] Simulation instability has been encountered. The run has entered a
[22:47:12]   state from which no further progress can be made.
[22:47:12] This may be the correct result of the simulation, however if you
[22:47:12]   often see other project units terminating early like this
[22:47:12]   too, you may wish to check the stability of your computer (issues
[22:47:12]   such as high temperature, overclocking, etc.).
[22:47:12] Going to send back what have done.
[22:47:12] logfile size: 30202
[22:47:12] - Writing 30765 bytes of core data to disk...
[22:47:12]   ... Done.
[22:47:12]
[22:47:12] Folding@home Core Shutdown: EARLY_UNIT_END
[22:47:16] CoreStatus = 72 (114)
[22:47:16] Sending work to server
[22:47:16] + Attempting to send results
[22:47:17] + Results successfully sent
[22:47:17] Thank you for your contribution to Folding@Home.
[22:47:21] + Attempting to send results
[22:47:22] + Results successfully sent
[22:47:22] Thank you for your contribution to Folding@Home.
[22:47:22] - Preparing to get new work unit...
[22:47:22] + Attempting to get work packet
[22:47:22] - Connecting to assignment server
[22:47:22] - Successful: assigned to (171.65.103.162).
[22:47:22] + News From Folding@Home: Welcome to Folding@Home
[22:47:22] Loaded queue successfully.
[22:47:35] + Closed connections
[22:47:40]
[22:47:40] + Processing work unit
[22:47:40] Core required: FahCore_78.exe
[22:47:40] Core found.
[22:47:40] Working on Unit 04 [December 17 22:47:40]
[22:47:40] + Working ...
[22:47:40]
[22:47:40] *------------------------------*
[22:47:40] Folding@Home Gromacs Core
[22:47:40] Version 1.90 (March 8, 2006)
[22:47:40]
[22:47:40] Preparing to commence simulation
[22:47:40] - Looking at optimizations...
[22:47:40] - Created dyn
[22:47:40] - Files status OK
[22:47:42] - Expanded 3067012 -> 16578197 (decompressed 540.5 percent)
[22:47:42] - Error: Bad work unit. Digital signatures don't match
[22:47:42] Error: Could not open work file
[22:47:42]
[22:47:42] Folding@home Core Shutdown: FILE_IO_ERROR
[22:47:46] CoreStatus = 75 (117)
[22:47:46] Error opening or reading from a file.
[22:47:46] Deleting current work unit & continuing...
[22:47:50] - Preparing to get new work unit...
[22:47:50] + Attempting to get work packet
[22:47:50] - Connecting to assignment server
[22:47:51] - Successful: assigned to (171.65.103.162).
[22:47:51] + News From Folding@Home: Welcome to Folding@Home
[22:47:51] Loaded queue successfully.
[22:47:51] - Couldn't send HTTP request to server
[22:47:51]   (Got status 503)
[22:47:51] + Could not connect to Work Server
[22:47:51] - Error: Attempt #1  to get work failed, and no other work to do.
[22:48:08] + Attempting to get work packet
[22:48:08] - Connecting to assignment server
[22:48:08] - Successful: assigned to (171.65.103.162).
[22:48:08] + News From Folding@Home: Welcome to Folding@Home
[22:48:08] Loaded queue successfully.
[22:48:21] + Closed connections
[22:48:26]
[22:48:26] + Processing work unit
[22:48:26] Core required: FahCore_78.exe
[22:48:26] Core found.
[22:48:26] Working on Unit 05 [December 17 22:48:26]
[22:48:26] + Working ...
[22:48:26]
[22:48:26] *------------------------------*
[22:48:26] Folding@Home Gromacs Core
[22:48:26] Version 1.90 (March 8, 2006)
[22:48:26]
[22:48:26] Preparing to commence simulation
[22:48:26] - Looking at optimizations...
[22:48:26] - Created dyn
[22:48:26] - Files status OK
[22:48:28] - Expanded 3065995 -> 16578197 (decompressed 540.7 percent)
[22:48:29] - Starting from initial work packet
[22:48:29]
[22:48:29] Project: 2418 (Run 12, Clone 87, Gen 8)
[22:48:29]
[22:48:29] Assembly optimizations on if available.
[22:48:29] Entering M.D.
[22:48:36] Protein: p2418_Ribo_Mg
[22:48:36]
[22:48:36] Writing local files
[22:48:38] Extra SSE boost OK.
[22:48:38] Writing local files
[22:48:38] Completed 0 out of 250000 steps  (0)
[22:48:44] Quit 101 - Fatal error: NaN detected: (ener[13])
[22:48:44]
[22:48:44] Simulation instability has been encountered. The run has entered a
[22:48:44]   state from which no further progress can be made.
[22:48:44] This may be the correct result of the simulation, however if you
[22:48:44]   often see other project units terminating early like this
[22:48:44]   too, you may wish to check the stability of your computer (issues
[22:48:44]   such as high temperature, overclocking, etc.).
[22:48:44] Going to send back what have done.
[22:48:44] logfile size: 7599
[22:48:44] - Writing 8162 bytes of core data to disk...
[22:48:44]   ... Done.
[22:48:44]
[22:48:44] Folding@home Core Shutdown: EARLY_UNIT_END
[22:48:48] CoreStatus = 72 (114)
[22:48:48] Sending work to server
[22:48:48] + Attempting to send results
[22:48:49] - Couldn't send HTTP request to server
[22:48:49]   (Got status 503)
[22:48:49] + Could not connect to Work Server (results)
[22:48:49]     (171.65.103.162:8080)
[22:48:49] - Error: Could not transmit unit 05 (completed December 17) to work server.
[22:48:49]   Keeping unit 05 in queue.
[22:48:49] + Attempting to send results
[22:49:02] - Couldn't send HTTP request to server
[22:49:02] + Could not connect to Work Server (results)
[22:49:02]     (171.65.103.100:8080)
[22:49:02]   Could not transmit unit 05 to Collection server; keeping in queue.
[22:49:02] - Preparing to get new work unit...
[22:49:02] + Attempting to get work packet
[22:49:02] - Connecting to assignment server
[22:49:03] - Successful: assigned to (171.65.103.162).
[22:49:03] + News From Folding@Home: Welcome to Folding@Home
[22:49:03] Loaded queue successfully.
[22:49:03] - Couldn't send HTTP request to server
[22:49:03]   (Got status 503)
[22:49:03] + Could not connect to Work Server
[22:49:03] - Error: Attempt #1  to get work failed, and no other work to do.
[22:49:19] + Attempting to get work packet
[22:49:19] - Connecting to assignment server
[22:49:19] - Successful: assigned to (171.65.103.162).
[22:49:19] + News From Folding@Home: Welcome to Folding@Home
[22:49:19] Loaded queue successfully.
[22:49:19] + Could not connect to Work Server
[22:49:19] - Error: Attempt #2  to get work failed, and no other work to do.
[22:49:30] + Attempting to get work packet
[22:49:30] - Connecting to assignment server
[22:49:30] - Successful: assigned to (171.65.103.162).
[22:49:30] + News From Folding@Home: Welcome to Folding@Home
[22:49:31] Loaded queue successfully.
[22:49:44] + Attempting to send results
[22:49:45] + Results successfully sent
[22:49:45] Thank you for your contribution to Folding@Home.
[22:49:45] + Closed connections
[22:49:50]
[22:49:50] + Processing work unit
[22:49:50] Core required: FahCore_78.exe
[22:49:50] Core found.
[22:49:50] Working on Unit 06 [December 17 22:49:50]
[22:49:50] + Working ...
[22:49:50]
[22:49:50] *------------------------------*
[22:49:50] Folding@Home Gromacs Core
[22:49:50] Version 1.90 (March 8, 2006)
[22:49:50]
[22:49:50] Preparing to commence simulation
[22:49:50] - Looking at optimizations...
[22:49:50] - Created dyn
[22:49:50] - Files status OK
[22:49:52] - Expanded 3062605 -> 16578209 (decompressed 541.3 percent)
[22:49:53] - Error: Bad work unit. Digital signatures don't match
[22:49:53] Error: Could not open work file
[22:49:53]
[22:49:53] Folding@home Core Shutdown: FILE_IO_ERROR
[22:49:56] CoreStatus = 75 (117)
[22:49:56] Error opening or reading from a file.
[22:49:56] Deleting current work unit & continuing...
[22:50:00] - Preparing to get new work unit...
[22:50:00] + Attempting to get work packet
[22:50:00] - Connecting to assignment server
[22:50:01] - Successful: assigned to (171.65.103.162).
[22:50:01] + News From Folding@Home: Welcome to Folding@Home
[22:50:01] Loaded queue successfully.
[22:50:01] - Couldn't send HTTP request to server
[22:50:01]   (Got status 503)
[22:50:01] + Could not connect to Work Server
[22:50:01] - Error: Attempt #1  to get work failed, and no other work to do.
[22:50:13] + Attempting to get work packet
[22:50:13] - Connecting to assignment server
[22:50:13] - Successful: assigned to (171.65.103.162).
[22:50:13] + News From Folding@Home: Welcome to Folding@Home
[22:50:13] Loaded queue successfully.
[22:50:14] - Couldn't send HTTP request to server
[22:50:14]   (Got status 503)
[22:50:14] + Could not connect to Work Server
[22:50:14] - Error: Attempt #2  to get work failed, and no other work to do.
[22:50:27] + Attempting to get work packet
[22:50:27] - Connecting to assignment server
[22:50:27] - Successful: assigned to (171.65.103.162).
[22:50:27] + News From Folding@Home: Welcome to Folding@Home
[22:50:28] Loaded queue successfully.
[22:50:28] - Couldn't send HTTP request to server
[22:50:28]   (Got status 503)
[22:50:28] + Could not connect to Work Server
[22:50:28] - Error: Attempt #3  to get work failed, and no other work to do.
[22:50:53] + Attempting to get work packet
[22:50:53] - Connecting to assignment server
[22:50:53] - Successful: assigned to (171.65.103.162).
[22:50:53] + News From Folding@Home: Welcome to Folding@Home
[22:50:54] Loaded queue successfully.
[22:51:08] + Closed connections
[22:51:13]
[22:51:13] + Processing work unit
[22:51:13] Core required: FahCore_78.exe
[22:51:13] Core found.
[22:51:13] Working on Unit 07 [December 17 22:51:13]
[22:51:13] + Working ...
[22:51:13]
[22:51:13] *------------------------------*
[22:51:13] Folding@Home Gromacs Core
[22:51:13] Version 1.90 (March 8, 2006)
[22:51:13]
[22:51:13] Preparing to commence simulation
[22:51:13] - Looking at optimizations...
[22:51:13] - Created dyn
[22:51:13] - Files status OK
[22:51:15] - Expanded 3064234 -> 16578209 (decompressed 541.0 percent)
[22:51:16] - Error: Bad work unit. Digital signatures don't match
[22:51:16] Error: Could not open work file
[22:51:16]
[22:51:16] Folding@home Core Shutdown: FILE_IO_ERROR
[22:51:19] CoreStatus = 75 (117)
[22:51:19] Error opening or reading from a file.
[22:51:19] Deleting current work unit & continuing...
[22:51:23] - Preparing to get new work unit...
[22:51:23] + Attempting to get work packet
[22:51:23] - Connecting to assignment server
[22:51:24] - Successful: assigned to (171.65.103.162).
[22:51:24] + News From Folding@Home: Welcome to Folding@Home
[22:51:24] Loaded queue successfully.
[22:51:24] - Couldn't send HTTP request to server
[22:51:24] + Could not connect to Work Server
[22:51:24] - Error: Attempt #1  to get work failed, and no other work to do.
[22:51:37] + Attempting to get work packet
[22:51:37] - Connecting to assignment server
[22:51:37] - Successful: assigned to (171.65.103.162).
[22:51:37] + News From Folding@Home: Welcome to Folding@Home
[22:51:38] Loaded queue successfully.
[22:51:38] - Couldn't send HTTP request to server
[22:51:38]   (Got status 503)
[22:51:38] + Could not connect to Work Server
[22:51:38] - Error: Attempt #2  to get work failed, and no other work to do.
[22:51:49] + Attempting to get work packet
[22:51:49] - Connecting to assignment server
[22:51:49] - Successful: assigned to (171.65.103.162).
[22:51:49] + News From Folding@Home: Welcome to Folding@Home
[22:51:49] Loaded queue successfully.
[22:51:49] - Couldn't send HTTP request to server
[22:51:49]   (Got status 503)
[22:51:49] + Could not connect to Work Server
[22:51:49] - Error: Attempt #3  to get work failed, and no other work to do.
[22:52:13] + Attempting to get work packet
[22:52:13] - Connecting to assignment server
[22:52:14] - Successful: assigned to (171.65.103.162).
[22:52:14] + News From Folding@Home: Welcome to Folding@Home
[22:52:14] Loaded queue successfully.
[22:52:14] - Couldn't send HTTP request to server
[22:52:14]   (Got status 503)
[22:52:14] + Could not connect to Work Server
[22:52:14] - Error: Attempt #4  to get work failed, and no other work to do.
[22:53:07] + Attempting to get work packet
[22:53:07] - Connecting to assignment server
[22:53:08] - Successful: assigned to (171.65.103.162).
[22:53:08] + News From Folding@Home: Welcome to Folding@Home
[22:53:08] Loaded queue successfully.
[22:53:24] + Closed connections
[22:53:29]
[22:53:29] + Processing work unit
[22:53:29] Core required: FahCore_78.exe
[22:53:29] Core found.
[22:53:29] Working on Unit 08 [December 17 22:53:29]
[22:53:29] + Working ...
[22:53:29]
[22:53:29] *------------------------------*
[22:53:29] Folding@Home Gromacs Core
[22:53:29] Version 1.90 (March 8, 2006)
[22:53:29]
[22:53:29] Preparing to commence simulation
[22:53:29] - Looking at optimizations...
[22:53:29] - Created dyn
[22:53:29] - Files status OK
[22:53:31] - Expanded 3059582 -> 16578185 (decompressed 541.8 percent)
[22:53:32] - Error: Bad work unit. Digital signatures don't match
[22:53:32] Error: Could not open work file
[22:53:32]
[22:53:32] Folding@home Core Shutdown: FILE_IO_ERROR
[22:53:36] CoreStatus = 75 (117)
[22:53:36] Error opening or reading from a file.
[22:53:36] Deleting current work unit & continuing...
[22:53:40] - Preparing to get new work unit...
[22:53:40] + Attempting to get work packet
[22:53:40] - Connecting to assignment server
[22:53:40] - Successful: assigned to (171.65.103.162).
[22:53:40] + News From Folding@Home: Welcome to Folding@Home
[22:53:40] Loaded queue successfully.
[22:53:54] + Closed connections
[22:53:59]
[22:53:59] + Processing work unit
[22:53:59] Core required: FahCore_78.exe
[22:53:59] Core found.
[22:53:59] Working on Unit 09 [December 17 22:53:59]
[22:53:59] + Working ...
[22:53:59]
[22:53:59] *------------------------------*
[22:53:59] Folding@Home Gromacs Core
[22:53:59] Version 1.90 (March 8, 2006)
[22:53:59]
[22:53:59] Preparing to commence simulation
[22:53:59] - Looking at optimizations...
[22:53:59] - Created dyn
[22:53:59] - Files status OK
[22:54:01] - Expanded 3065348 -> 16578177 (decompressed 540.8 percent)
[22:54:01] - Error: Bad work unit. Digital signatures don't match
[22:54:01] Error: Could not open work file
[22:54:01]
[22:54:01] Folding@home Core Shutdown: FILE_IO_ERROR
[22:54:05] CoreStatus = 75 (117)
[22:54:05] Error opening or reading from a file.
[22:54:05] Deleting current work unit & continuing...
[22:54:09] - Preparing to get new work unit...
[22:54:09] + Attempting to get work packet
[22:54:09] - Connecting to assignment server
[22:54:09] - Successful: assigned to (171.65.103.162).
[22:54:09] + News From Folding@Home: Welcome to Folding@Home
[22:54:10] Loaded queue successfully.
[22:54:10] - Couldn't send HTTP request to server
[22:54:10]   (Got status 503)
[22:54:10] + Could not connect to Work Server
[22:54:10] - Error: Attempt #1  to get work failed, and no other work to do.
[22:54:24] + Attempting to get work packet
[22:54:24] - Connecting to assignment server
[22:54:25] - Successful: assigned to (171.65.103.162).
[22:54:25] + News From Folding@Home: Welcome to Folding@Home
[22:54:25] Loaded queue successfully.
[22:54:25] - Couldn't send HTTP request to server
[22:54:25] + Could not connect to Work Server
[22:54:25] - Error: Attempt #2  to get work failed, and no other work to do.
[22:54:46] + Attempting to get work packet
[22:54:46] - Connecting to assignment server
[22:54:46] - Successful: assigned to (171.65.103.162).
[22:54:46] + News From Folding@Home: Welcome to Folding@Home
[22:54:46] Loaded queue successfully.
[22:55:02] + Closed connections
[22:55:07]
[22:55:07] + Processing work unit
[22:55:07] Core required: FahCore_78.exe
[22:55:07] Core found.
[22:55:07] Working on Unit 00 [December 17 22:55:07]
[22:55:07] + Working ...
[22:55:07]
[22:55:07] *------------------------------*
[22:55:07] Folding@Home Gromacs Core
[22:55:07] Version 1.90 (March 8, 2006)
[22:55:07]
[22:55:07] Preparing to commence simulation
[22:55:07] - Looking at optimizations...
[22:55:07] - Created dyn
[22:55:07] - Files status OK
[22:55:09] - Expanded 3066748 -> 16578209 (decompressed 540.5 percent)
[22:55:10] - Error: Bad work unit. Digital signatures don't match
[22:55:10] Error: Could not open work file
[22:55:10]
[22:55:10] Folding@home Core Shutdown: FILE_IO_ERROR
[22:55:13] CoreStatus = 75 (117)
[22:55:13] Error opening or reading from a file.
[22:55:13] Deleting current work unit & continuing...
[22:55:17] - Preparing to get new work unit...
[22:55:17] + Attempting to get work packet
[22:55:17] - Connecting to assignment server
[22:55:18] - Successful: assigned to (171.65.103.162).
[22:55:18] + News From Folding@Home: Welcome to Folding@Home
[22:55:18] Loaded queue successfully.
[22:55:18] - Couldn't send HTTP request to server
[22:55:18] + Could not connect to Work Server
[22:55:18] - Error: Attempt #1  to get work failed, and no other work to do.
[22:55:31] + Attempting to get work packet
[22:55:31] - Connecting to assignment server
[22:55:31] - Successful: assigned to (171.65.103.162).
[22:55:31] + News From Folding@Home: Welcome to Folding@Home
[22:55:31] Loaded queue successfully.
[22:55:31] - Couldn't send HTTP request to server
[22:55:31]   (Got status 503)
[22:55:31] + Could not connect to Work Server
[22:55:31] - Error: Attempt #2  to get work failed, and no other work to do.
[22:55:53] + Attempting to get work packet
[22:55:53] - Connecting to assignment server
[22:55:53] - Successful: assigned to (171.65.103.162).
[22:55:53] + News From Folding@Home: Welcome to Folding@Home
[22:55:54] Loaded queue successfully.
[22:55:54] - Couldn't send HTTP request to server
[22:55:54] + Could not connect to Work Server
[22:55:54] - Error: Attempt #3  to get work failed, and no other work to do.
[22:56:17] + Attempting to get work packet
[22:56:17] - Connecting to assignment server
[22:56:18] - Successful: assigned to (171.65.103.162).
[22:56:18] + News From Folding@Home: Welcome to Folding@Home
[22:56:18] Loaded queue successfully.
[22:56:18] - Couldn't send HTTP request to server
[22:56:18]   (Got status 503)
[22:56:18] + Could not connect to Work Server
[22:56:18] - Error: Attempt #4  to get work failed, and no other work to do.
[22:57:02] + Attempting to get work packet
[22:57:02] - Connecting to assignment server
[22:57:02] - Successful: assigned to (171.65.103.162).
[22:57:02] + News From Folding@Home: Welcome to Folding@Home
[22:57:03] Loaded queue successfully.
[22:57:20] + Closed connections
[22:57:25]
[22:57:25] + Processing work unit
[22:57:25] Core required: FahCore_78.exe
[22:57:25] Core found.
[22:57:25] Working on Unit 01 [December 17 22:57:25]
[22:57:25] + Working ...
[22:57:25]
[22:57:25] *------------------------------*
[22:57:25] Folding@Home Gromacs Core
[22:57:25] Version 1.90 (March 8, 2006)
[22:57:25]
[22:57:25] Preparing to commence simulation
[22:57:25] - Looking at optimizations...
[22:57:25] - Created dyn
[22:57:25] - Files status OK
[22:57:27] - Expanded 3065791 -> 16578185 (decompressed 540.7 percent)
[22:57:27] - Error: Bad work unit. Digital signatures don't match
[22:57:27] Error: Could not open work file
[22:57:27]
[22:57:27] Folding@home Core Shutdown: FILE_IO_ERROR
[22:57:31] CoreStatus = 75 (117)
[22:57:31] Error opening or reading from a file.
[22:57:31] Deleting current work unit & continuing...
[22:57:35] - Preparing to get new work unit...
[22:57:35] + Attempting to get work packet
[22:57:35] - Connecting to assignment server
[22:57:35] - Successful: assigned to (171.65.103.162).
[22:57:35] + News From Folding@Home: Welcome to Folding@Home
[22:57:35] Loaded queue successfully.
[22:57:48] + Closed connections
[22:57:53]
[22:57:53] + Processing work unit
[22:57:53] Core required: FahCore_78.exe
[22:57:53] Core found.
[22:57:53] Working on Unit 02 [December 17 22:57:53]
[22:57:53] + Working ...
[22:57:53]
[22:57:53] *------------------------------*
[22:57:53] Folding@Home Gromacs Core
[22:57:53] Version 1.90 (March 8, 2006)
[22:57:53]
[22:57:53] Preparing to commence simulation
[22:57:53] - Looking at optimizations...
[22:57:53] - Created dyn
[22:57:53] - Files status OK
[22:57:55] - Expanded 3065348 -> 16578177 (decompressed 540.8 percent)
[22:57:55] - Error: Bad work unit. Digital signatures don't match
[22:57:55] Error: Could not open work file
[22:57:55]
[22:57:55] Folding@home Core Shutdown: FILE_IO_ERROR
[22:57:59] CoreStatus = 75 (117)
[22:57:59] Error opening or reading from a file.
[22:57:59] Deleting current work unit & continuing...
[22:58:03] - Preparing to get new work unit...
[22:58:03] + Attempting to get work packet
[22:58:03] - Connecting to assignment server
[22:58:04] - Successful: assigned to (171.65.103.162).
[22:58:04] + News From Folding@Home: Welcome to Folding@Home
[22:58:04] Loaded queue successfully.
[22:58:27] + Closed connections
[22:58:32]
[22:58:32] + Processing work unit
[22:58:32] Core required: FahCore_78.exe
[22:58:32] Core found.
[22:58:32] Working on Unit 03 [December 17 22:58:32]
[22:58:32] + Working ...
[22:58:32]
[22:58:32] *------------------------------*
[22:58:32] Folding@Home Gromacs Core
[22:58:32] Version 1.90 (March 8, 2006)
[22:58:32]
[22:58:32] Preparing to commence simulation
[22:58:32] - Looking at optimizations...
[22:58:32] - Created dyn
[22:58:32] - Files status OK
[22:58:34] - Expanded 3063984 -> 16578233 (decompressed 541.0 percent)
[22:58:34] - Starting from initial work packet
[22:58:34]
[22:58:34] Project: 2418 (Run 32, Clone 94, Gen 8)
[22:58:34]
[22:58:34] Assembly optimizations on if available.
[22:58:34] Entering M.D.
[22:58:41] Protein: p2418_Ribo_Mg
[22:58:41]
[22:58:41] Writing local files
[22:58:44] Extra SSE boost OK.
[22:58:44] Writing local files
[22:58:44] Completed 0 out of 250000 steps  (0)
[22:59:15] Quit 101 - Fatal error: NaN detected: (ener[38])
[22:59:15]
[22:59:15] Simulation instability has been encountered. The run has entered a
[22:59:15]   state from which no further progress can be made.
[22:59:15] This may be the correct result of the simulation, however if you
[22:59:15]   often see other project units terminating early like this
[22:59:15]   too, you may wish to check the stability of your computer (issues
[22:59:15]   such as high temperature, overclocking, etc.).
[22:59:15] Going to send back what have done.
[22:59:15] logfile size: 7600
[22:59:15] - Writing 8163 bytes of core data to disk...
[22:59:15]   ... Done.
[22:59:16]
[22:59:16] Folding@home Core Shutdown: EARLY_UNIT_END
[22:59:18] CoreStatus = 72 (114)
[22:59:18] Sending work to server
[22:59:18] + Attempting to send results
[22:59:19] + Results successfully sent
[22:59:19] Thank you for your contribution to Folding@Home.
[22:59:23] - Preparing to get new work unit...
[22:59:23] + Attempting to get work packet
[22:59:23] - Connecting to assignment server
[22:59:24] - Successful: assigned to (171.65.103.162).
[22:59:24] + News From Folding@Home: Welcome to Folding@Home
[22:59:24] Loaded queue successfully.
[22:59:36] + Closed connections
[22:59:41]
[22:59:41] + Processing work unit
[22:59:41] Core required: FahCore_78.exe
[22:59:41] Core found.
[22:59:41] Working on Unit 04 [December 17 22:59:41]
[22:59:41] + Working ...
[22:59:41]
[22:59:41] *------------------------------*
[22:59:41] Folding@Home Gromacs Core
[22:59:41] Version 1.90 (March 8, 2006)
[22:59:41]
[22:59:41] Preparing to commence simulation
[22:59:41] - Looking at optimizations...
[22:59:41] - Created dyn
[22:59:41] - Files status OK
[22:59:43] - Expanded 3066454 -> 16578209 (decompressed 540.6 percent)
[22:59:43] - Error: Bad work unit. Digital signatures don't match
[22:59:43] Error: Could not open work file
[22:59:43]
[22:59:43] Folding@home Core Shutdown: FILE_IO_ERROR
[22:59:47] CoreStatus = 75 (117)
[22:59:47] Error opening or reading from a file.
[22:59:47] Deleting current work unit & continuing...
[22:59:51] - Preparing to get new work unit...
[22:59:51] + Attempting to get work packet
[22:59:51] - Connecting to assignment server
[22:59:51] - Successful: assigned to (171.65.103.162).
[22:59:51] + News From Folding@Home: Welcome to Folding@Home
[22:59:52] Loaded queue successfully.
[23:00:03] + Closed connections
[23:00:08]
[23:00:08] + Processing work unit
[23:00:08] Core required: FahCore_78.exe
[23:00:08] Core found.
[23:00:08] Working on Unit 05 [December 17 23:00:08]
[23:00:08] + Working ...
[23:00:08]
[23:00:08] *------------------------------*
[23:00:08] Folding@Home Gromacs Core
[23:00:08] Version 1.90 (March 8, 2006)
[23:00:08]
[23:00:08] Preparing to commence simulation
[23:00:08] - Looking at optimizations...
[23:00:08] - Created dyn
[23:00:08] - Files status OK
[23:00:10] - Expanded 3065450 -> 16578209 (decompressed 540.8 percent)
[23:00:11] - Error: Bad work unit. Digital signatures don't match
[23:00:11] Error: Could not open work file
[23:00:11]
[23:00:11] Folding@home Core Shutdown: FILE_IO_ERROR
[23:00:15] CoreStatus = 75 (117)
[23:00:15] Error opening or reading from a file.
[23:00:15] Deleting current work unit & continuing...
[23:00:19] - Preparing to get new work unit...
[23:00:19] + Attempting to get work packet
[23:00:19] - Connecting to assignment server
[23:00:19] - Successful: assigned to (171.65.103.162).
[23:00:19] + News From Folding@Home: Welcome to Folding@Home
[23:00:19] Loaded queue successfully.
[23:00:31] + Closed connections
[23:00:36]
[23:00:36] + Processing work unit
[23:00:36] Core required: FahCore_78.exe
[23:00:36] Core found.
[23:00:36] Working on Unit 06 [December 17 23:00:36]
[23:00:36] + Working ...
[23:00:36]
[23:00:36] *------------------------------*
[23:00:36] Folding@Home Gromacs Core
[23:00:36] Version 1.90 (March 8, 2006)
[23:00:36]
[23:00:36] Preparing to commence simulation
[23:00:36] - Looking at optimizations...
[23:00:36] - Created dyn
[23:00:36] - Files status OK
[23:00:38] - Expanded 3062407 -> 16578209 (decompressed 541.3 percent)
[23:00:38] - Error: Bad work unit. Digital signatures don't match
[23:00:38] Error: Could not open work file
[23:00:38]
[23:00:38] Folding@home Core Shutdown: FILE_IO_ERROR
[23:00:42] CoreStatus = 75 (117)
[23:00:42] Error opening or reading from a file.
[23:00:42] Deleting current work unit & continuing...
[23:00:46] - Preparing to get new work unit...
[23:00:46] + Attempting to get work packet
[23:00:46] - Connecting to assignment server
[23:00:47] - Successful: assigned to (171.65.103.162).
[23:00:47] + News From Folding@Home: Welcome to Folding@Home
[23:00:47] Loaded queue successfully.
[23:00:58] + Closed connections
[23:01:03]
[23:01:03] + Processing work unit
[23:01:03] Core required: FahCore_78.exe
[23:01:03] Core found.
[23:01:03] Working on Unit 07 [December 17 23:01:03]
[23:01:03] + Working ...
[23:01:04]
[23:01:04] *------------------------------*
[23:01:04] Folding@Home Gromacs Core
[23:01:04] Version 1.90 (March 8, 2006)
[23:01:04]
[23:01:04] Preparing to commence simulation
[23:01:04] - Looking at optimizations...
[23:01:04] - Created dyn
[23:01:04] - Files status OK
[23:01:06] - Expanded 3062107 -> 16578209 (decompressed 541.3 percent)
[23:01:06] - Error: Bad work unit. Digital signatures don't match
[23:01:06] Error: Could not open work file
[23:01:06]
[23:01:06] Folding@home Core Shutdown: FILE_IO_ERROR
[23:01:10] CoreStatus = 75 (117)
[23:01:10] Error opening or reading from a file.
[23:01:10] Deleting current work unit & continuing...
[23:01:14] - Preparing to get new work unit...
[23:01:14] + Attempting to get work packet
[23:01:14] - Connecting to assignment server
[23:01:14] - Successful: assigned to (171.65.103.162).
[23:01:14] + News From Folding@Home: Welcome to Folding@Home
[23:01:14] Loaded queue successfully.
[23:01:28] + Closed connections
[23:01:33]
[23:01:33] + Processing work unit
[23:01:33] Core required: FahCore_78.exe
[23:01:33] Core found.
[23:01:33] Working on Unit 08 [December 17 23:01:33]
[23:01:33] + Working ...
[23:01:34]
[23:01:34] *------------------------------*
[23:01:34] Folding@Home Gromacs Core
[23:01:34] Version 1.90 (March 8, 2006)
[23:01:34]
[23:01:34] Preparing to commence simulation
[23:01:34] - Looking at optimizations...
[23:01:34] - Created dyn
[23:01:34] - Files status OK
[23:01:36] - Expanded 3065072 -> 16578209 (decompressed 540.8 percent)
[23:01:36] - Starting from initial work packet
[23:01:36]
[23:01:36] Project: 2418 (Run 33, Clone 55, Gen 8)
[23:01:36]
[23:01:36] Assembly optimizations on if available.
[23:01:36] Entering M.D.
[23:01:43] Protein: p2418_Ribo_Mg
[23:01:43]
[23:01:43] Writing local files
[23:01:45] Extra SSE boost OK.
[23:01:45] Writing local files
[23:01:46] Completed 0 out of 250000 steps  (0)
[23:03:13] Quit 101 - Fatal error: NaN detected: (ener[13])
[23:03:13]
[23:03:13] Simulation instability has been encountered. The run has entered a
[23:03:13]   state from which no further progress can be made.
[23:03:13] This may be the correct result of the simulation, however if you
[23:03:13]   often see other project units terminating early like this
[23:03:13]   too, you may wish to check the stability of your computer (issues
[23:03:13]   such as high temperature, overclocking, etc.).
[23:03:13] Going to send back what have done.
[23:03:13] logfile size: 7599
[23:03:13] - Writing 8162 bytes of core data to disk...
[23:03:13]   ... Done.
[23:03:13]
[23:03:13] Folding@home Core Shutdown: EARLY_UNIT_END
[23:03:16] CoreStatus = 72 (114)
[23:03:16] Sending work to server
[23:03:16] + Attempting to send results
[23:03:16] - Couldn't send HTTP request to server
[23:03:16]   (Got status 503)
[23:03:16] + Could not connect to Work Server (results)
[23:03:16]     (171.65.103.162:8080)
[23:03:16] - Error: Could not transmit unit 08 (completed December 17) to work server.
[23:03:16]   Keeping unit 08 in queue.
[23:03:23] - Couldn't send HTTP request to server
[23:03:23] + Could not connect to Work Server (results)
[23:03:23]     (171.65.103.100:8080)
[23:03:23]   Could not transmit unit 08 to Collection server; keeping in queue.
[23:03:23] - Preparing to get new work unit...
[23:03:23] + Attempting to get work packet
[23:03:23] - Connecting to assignment server
[23:03:23] - Successful: assigned to (171.65.103.162).
[23:03:23] + News From Folding@Home: Welcome to Folding@Home
[23:03:24] Loaded queue successfully.
[23:03:37] + Attempting to send results
[23:03:38] + Results successfully sent
[23:03:38] Thank you for your contribution to Folding@Home.
[23:03:38] + Closed connections
[23:03:43]
[23:03:43] + Processing work unit
[23:03:43] Core required: FahCore_78.exe
[23:03:43] Core found.
[23:03:43] Working on Unit 09 [December 17 23:03:43]
[23:03:43] + Working ...
[23:03:43]
[23:03:43] *------------------------------*
[23:03:43] Folding@Home Gromacs Core
[23:03:43] Version 1.90 (March 8, 2006)
[23:03:43]
[23:03:43] Preparing to commence simulation
[23:03:43] - Looking at optimizations...
[23:03:43] - Created dyn
[23:03:43] - Files status OK
[23:03:45] - Expanded 3067124 -> 16578181 (decompressed 540.5 percent)
[23:03:46] - Error: Bad work unit. Digital signatures don't match
[23:03:46] Error: Could not open work file
[23:03:46]
[23:03:46] Folding@home Core Shutdown: FILE_IO_ERROR
[23:03:49] CoreStatus = 75 (117)
[23:03:49] Error opening or reading from a file.
[23:03:49] Deleting current work unit & continuing...
[23:03:53] - Preparing to get new work unit...
[23:03:53] + Attempting to get work packet
[23:03:53] - Connecting to assignment server
[23:03:54] - Successful: assigned to (171.65.103.162).
[23:03:54] + News From Folding@Home: Welcome to Folding@Home
[23:03:54] Loaded queue successfully.
[23:04:05] + Closed connections
[23:04:10]
[23:04:10] + Processing work unit
[23:04:10] Core required: FahCore_78.exe
[23:04:10] Core found.
[23:04:10] Working on Unit 00 [December 17 23:04:10]
[23:04:10] + Working ...
[23:04:10]
[23:04:10] *------------------------------*
[23:04:10] Folding@Home Gromacs Core
[23:04:10] Version 1.90 (March 8, 2006)
[23:04:10]
[23:04:10] Preparing to commence simulation
[23:04:10] - Looking at optimizations...
[23:04:10] - Created dyn
[23:04:10] - Files status OK
[23:04:12] - Expanded 3067124 -> 16578181 (decompressed 540.5 percent)
[23:04:13] - Starting from initial work packet
[23:04:13]
[23:04:13] Project: 2417 (Run 4, Clone 2, Gen 12)
[23:04:13]
[23:04:13] Assembly optimizations on if available.
[23:04:13] Entering M.D.
[23:04:20] Protein: p2417_Ribo_Cl
[23:04:20]
[23:04:20] Writing local files
[23:04:22] Extra SSE boost OK.
[23:04:22] Writing local files
[23:04:22] Completed 0 out of 250000 steps  (0)
[23:05:00] Quit 101 - Fatal error: NaN detected: (ener[38])
[23:05:00]
[23:05:00] Simulation instability has been encountered. The run has entered a
[23:05:00]   state from which no further progress can be made.
[23:05:00] This may be the correct result of the simulation, however if you
[23:05:00]   often see other project units terminating early like this
[23:05:00]   too, you may wish to check the stability of your computer (issues
[23:05:00]   such as high temperature, overclocking, etc.).
[23:05:00] Going to send back what have done.
[23:05:00] logfile size: 7599
[23:05:00] - Writing 8162 bytes of core data to disk...
[23:05:00]   ... Done.
[23:05:00]
[23:05:00] Folding@home Core Shutdown: EARLY_UNIT_END
[23:05:04] CoreStatus = 72 (114)
[23:05:04] Sending work to server
[23:05:04] + Attempting to send results
[23:05:05] + Results successfully sent
[23:05:05] Thank you for your contribution to Folding@Home.
[23:05:09] - Preparing to get new work unit...
[23:05:09] + Attempting to get work packet
[23:05:09] - Connecting to assignment server
[23:05:10] - Successful: assigned to (171.65.103.162).
[23:05:10] + News From Folding@Home: Welcome to Folding@Home
[23:05:10] Loaded queue successfully.
[23:05:10] - Couldn't send HTTP request to server
[23:05:10]   (Got status 503)
[23:05:10] + Could not connect to Work Server
[23:05:10] - Error: Attempt #1  to get work failed, and no other work to do.
[23:05:16] + Attempting to get work packet
[23:05:16] - Connecting to assignment server
[23:05:16] - Successful: assigned to (171.65.103.162).
[23:05:16] + News From Folding@Home: Welcome to Folding@Home
[23:05:16] Loaded queue successfully.
[23:05:17] - Couldn't send HTTP request to server
[23:05:17]   (Got status 503)
[23:05:17] + Could not connect to Work Server
[23:05:17] - Error: Attempt #2  to get work failed, and no other work to do.
[23:05:33] + Attempting to get work packet
[23:05:33] - Connecting to assignment server
[23:05:34] - Successful: assigned to (171.65.103.162).
[23:05:34] + News From Folding@Home: Welcome to Folding@Home
[23:05:34] Loaded queue successfully.
[23:05:34] - Couldn't send HTTP request to server
[23:05:34]   (Got status 503)
[23:05:34] + Could not connect to Work Server
[23:05:34] - Error: Attempt #3  to get work failed, and no other work to do.
[23:05:56] + Attempting to get work packet
[23:05:56] - Connecting to assignment server
[23:05:57] - Successful: assigned to (171.65.103.162).
[23:05:57] + News From Folding@Home: Welcome to Folding@Home
[23:05:57] Loaded queue successfully.
[23:06:11] + Closed connections
[23:06:16]
[23:06:16] + Processing work unit
[23:06:16] Core required: FahCore_78.exe
[23:06:16] Core found.
[23:06:16] Working on Unit 01 [December 17 23:06:16]
[23:06:16] + Working ...
[23:06:16]
[23:06:16] *------------------------------*
[23:06:16] Folding@Home Gromacs Core
[23:06:16] Version 1.90 (March 8, 2006)
[23:06:16]
[23:06:16] Preparing to commence simulation
[23:06:16] - Looking at optimizations...
[23:06:16] - Created dyn
[23:06:16] - Files status OK
[23:06:18] - Expanded 3065995 -> 16578197 (decompressed 540.7 percent)
[23:06:19] - Error: Bad work unit. Digital signatures don't match
[23:06:19] Error: Could not open work file
[23:06:19]
[23:06:19] Folding@home Core Shutdown: FILE_IO_ERROR
[23:06:22] CoreStatus = 75 (117)
[23:06:22] Error opening or reading from a file.
[23:06:22] Deleting current work unit & continuing...
[23:06:26] - Preparing to get new work unit...
[23:06:26] + Attempting to get work packet
[23:06:26] - Connecting to assignment server
[23:06:27] - Successful: assigned to (171.65.103.162).
[23:06:27] + News From Folding@Home: Welcome to Folding@Home
[23:06:27] Loaded queue successfully.
[23:06:27] - Couldn't send HTTP request to server
[23:06:27] + Could not connect to Work Server
[23:06:27] - Error: Attempt #1  to get work failed, and no other work to do.
[23:06:32] + Attempting to get work packet
[23:06:32] - Connecting to assignment server
[23:06:33] - Successful: assigned to (171.65.103.162).
[23:06:33] + News From Folding@Home: Welcome to Folding@Home
[23:06:33] Loaded queue successfully.
[23:06:48] + Closed connections
[23:06:53]
[23:06:53] + Processing work unit
[23:06:53] Core required: FahCore_78.exe
[23:06:53] Core found.
[23:06:53] Working on Unit 02 [December 17 23:06:53]
[23:06:53] + Working ...
[23:06:53]
[23:06:53] *------------------------------*
[23:06:53] Folding@Home Gromacs Core
[23:06:53] Version 1.90 (March 8, 2006)
[23:06:53]
[23:06:53] Preparing to commence simulation
[23:06:53] - Looking at optimizations...
[23:06:53] - Created dyn
[23:06:53] - Files status OK
[23:06:55] - Expanded 3067400 -> 16578197 (decompressed 540.4 percent)
[23:06:56] - Error: Bad work unit. Digital signatures don't match
[23:06:56] Error: Could not open work file
[23:06:56]
[23:06:56] Folding@home Core Shutdown: FILE_IO_ERROR
[23:07:00] CoreStatus = 75 (117)
[23:07:00] Error opening or reading from a file.
[23:07:00] Deleting current work unit & continuing...
[23:07:04] - Preparing to get new work unit...
[23:07:04] + Attempting to get work packet
[23:07:04] - Connecting to assignment server
[23:07:04] - Successful: assigned to (171.65.103.162).
[23:07:04] + News From Folding@Home: Welcome to Folding@Home
[23:07:04] Loaded queue successfully.
[23:07:04] - Couldn't send HTTP request to server
[23:07:04]   (Got status 503)
[23:07:04] + Could not connect to Work Server
[23:07:04] - Error: Attempt #1  to get work failed, and no other work to do.
codysluder
Post by codysluder »
The digital signature issue isn't related to losing work. It only happens when you download a new WU which was damaged during the download process. Either your ISP isn't doing their job or you've got a bad ethernet cable or a weak WiFi signal or some other piece of equipment that it's working well. Actually, it could also be something that is getting corrupted by your anti-virus software or something like that.
Whatever the communications problem, it's confirmed by the numerous could-not-connect errors that you're getting.
The I/O ERRORs are a lot more frequent than they should be. (Now that I think of it, they could also be causing the digital signature problem, but not the could-not-connect errors.) You might have some hardware issue with your disk or the ATA chips that drive it. You said you were only overclocked at the confirmed level, which probably means that you still are overclocked but you feel comfortable that you won't be getting BSODs, etc. What did you do to confirm whether the ATA chipset is working within or outside of its stable range?
It will save all the work only if your disk creates an accurate set of files that can be read back without error.
The default is 15 minutes and I find that to be a reasonable number. I rarely shut down and never crash and if it's going to be one or two more minutes before the next checkpoint, I just wait before shutting down so the average amount of work that I have to repeat is smaller than you might guess.
Oakwheel
Post by Oakwheel »
Whatever the cause of the issues identified from the log texts earlier, they seem to have resolved. I have reviewed the logs since then, and they indicate that the client is chugging thru the WU's uneventfully. Below I have attached a sample of what the log reads like now. Thanks.
--- Opening Log file [December 23 15:49:55]
[15:49:55] - Ask before connecting: No
[15:49:55] - User name: Oakwheel (Team 31574)
[15:49:55] - User ID: 699E8B4557618F18
[15:49:55] - Machine ID: 1
[15:49:55]
[15:49:55] Loaded queue successfully.
[15:49:55] Initialization complete
[15:49:55] + Benchmarking ...
[15:49:57]
[15:49:57] + Processing work unit
[15:49:57] Core required: FahCore_78.exe
[15:49:57] Core found.
[15:49:57] Working on Unit 06 [December 23 15:49:57]
[15:49:57] + Working ...
[15:49:58]
[15:49:58] *------------------------------*
[15:49:58] Folding@Home Gromacs Core
[15:49:58] Version 1.90 (March 8, 2006)
[15:49:58]
[15:49:58] Preparing to commence simulation
[15:49:58] - Looking at optimizations...
[15:49:58] - Files status OK
[15:50:00] - Expanded 3065611 -> 16578197 (decompressed 540.7 percent)
[15:50:01]
[15:50:01] Project: 2427 (Run 26, Clone 75, Gen 15)
[15:50:01]
[15:50:01] Assembly optimizations on if available.
[15:50:01] Entering M.D.
[15:50:22] (Starting from checkpoint)
[15:50:23] Protein: p2427_Ribo_Cl_aux
[15:50:23]
[15:50:23] Writing local files
[15:50:23] Completed 192500 out of 250000 steps  (77)
[15:50:24] Extra SSE boost OK.
[16:05:57] Writing local files
[16:05:57] Completed 195000 out of 250000 steps  (78)
[16:21:30] Writing local files
[16:21:30] Completed 197500 out of 250000 steps  (79)
[16:37:02] Writing local files
[16:37:02] Completed 200000 out of 250000 steps  (80)
[16:52:35] Writing local files
[16:52:35] Completed 202500 out of 250000 steps  (81)
[17:08:08] Writing local files
[17:08:08] Completed 205000 out of 250000 steps  (82)
[17:23:41] Writing local files
[17:23:41] Completed 207500 out of 250000 steps  (83)
[17:39:13] Writing local files
[17:39:13] Completed 210000 out of 250000 steps  (84)
[17:54:46] Writing local files
[17:54:46] Completed 212500 out of 250000 steps  (85)
[18:10:19] Writing local files
[18:10:19] Completed 215000 out of 250000 steps  (86)
[18:26:01] Writing local files
[18:26:01] Completed 217500 out of 250000 steps  (87)
[18:41:44] Writing local files
[18:41:44] Completed 220000 out of 250000 steps  (88)
[18:57:32] Writing local files
[18:57:32] Completed 222500 out of 250000 steps  (89)
[19:13:25] Writing local files
[19:13:25] Completed 225000 out of 250000 steps  (90)
[19:29:00] Writing local files
[19:29:01] Completed 227500 out of 250000 steps  (91)
[19:44:57] Writing local files
[19:44:58] Completed 230000 out of 250000 steps  (92)
[20:00:41] Writing local files
[20:00:41] Completed 232500 out of 250000 steps  (93)
[20:16:14] Writing local files
[20:16:14] Completed 235000 out of 250000 steps  (94)
[20:31:47] Writing local files
[20:31:48] Completed 237500 out of 250000 steps  (95)
[20:47:21] Writing local files
[20:47:21] Completed 240000 out of 250000 steps  (96)
[21:02:55] Writing local files
[21:02:55] Completed 242500 out of 250000 steps  (97)
[21:18:29] Writing local files
[21:18:29] Completed 245000 out of 250000 steps  (98)
[21:34:02] Writing local files
[21:34:02] Completed 247500 out of 250000 steps  (99)
[21:49:36] Writing local files
[21:49:36] Completed 250000 out of 250000 steps  (100)
[21:49:36] Writing final coordinates.
[21:49:37] Past main M.D. loop
[21:49:57] + Working...
[21:50:37]
[21:50:37] Finished Work Unit:
[21:50:37] - Reading up to 2111496 from "work/wudata_06.arc": Read 2111496
[21:50:37] - Reading up to 40480 from "work/wudata_06.xtc": Read 40480
[21:50:37] goefile size: 0
[21:50:37] logfile size: 189682
[21:50:37] Leaving Run
[21:50:41] - Writing 2600382 bytes of core data to disk...
[21:50:41]   ... Done.
[21:50:41] - Shutting down core
[21:50:41]
[21:50:41] Folding@home Core Shutdown: FINISHED_UNIT
[21:50:45] CoreStatus = 64 (100)
[21:50:45] Sending work to server
[21:50:45] + Attempting to send results
[21:51:15] + Results successfully sent
[21:51:15] Thank you for your contribution to Folding@Home.
[21:51:15] + Number of Units Completed: 10
[21:51:20] - Preparing to get new work unit...
[21:51:20] + Attempting to get work packet
[21:51:20] - Connecting to assignment server
[21:51:20] - Successful: assigned to (171.65.103.162).
[21:51:20] + News From Folding@Home: Welcome to Folding@Home
[21:51:20] Loaded queue successfully.
[21:51:21] - Couldn't send HTTP request to server
[21:51:21]   (Got status 503)
[21:51:21] + Could not connect to Work Server
[21:51:21] - Error: Attempt #1  to get work failed, and no other work to do.
[21:51:31] + Attempting to get work packet
[21:51:31] - Connecting to assignment server
[21:51:31] - Successful: assigned to (171.65.103.162).
[21:51:31] + News From Folding@Home: Welcome to Folding@Home
[21:51:31] Loaded queue successfully.
[21:51:42] + Closed connections
[21:51:42]
[21:51:42] + Processing work unit
[21:51:42] Core required: FahCore_78.exe
[21:51:42] Core found.
[21:51:42] Working on Unit 07 [December 23 21:51:42]
[21:51:42] + Working ...
[21:51:43]
[21:51:43] *------------------------------*
[21:51:43] Folding@Home Gromacs Core
[21:51:43] Version 1.90 (March 8, 2006)
[21:51:43]
[21:51:43] Preparing to commence simulation
[21:51:43] - Looking at optimizations...
[21:51:43] - Created dyn
[21:51:43] - Files status OK
[21:51:45] - Expanded 3066294 -> 16578189 (decompressed 540.6 percent)
[21:51:45] - Starting from initial work packet
[21:51:45]
[21:51:45] Project: 2417 (Run 45, Clone 62, Gen 13)
[21:51:45]
[21:51:45] Assembly optimizations on if available.
[21:51:45] Entering M.D.
[21:51:52] Protein: p2417_Ribo_Cl
[21:51:52]
[21:51:52] Writing local files
[21:51:54] Extra SSE boost OK.
[21:51:55] Writing local files
[21:51:55] Completed 0 out of 250000 steps  (0)
--- Opening Log file [December 24 05:03:31]
# Windows Graphical Edition ###################################################
                       Folding@Home Client Version 5.03
                          http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@Home
[05:03:31] - Ask before connecting: No
[05:03:31] - User name: Oakwheel (Team 31574)
[05:03:31] - User ID: 699E8B4557618F18
[05:03:31] - Machine ID: 1
[05:03:31]
[05:03:31] Loaded queue successfully.
[05:03:31] Initialization complete
[05:03:31] + Benchmarking ...
[05:03:33]
[05:03:33] + Processing work unit
[05:03:33] Core required: FahCore_78.exe
[05:03:33] Core found.
[05:03:34] Working on Unit 07 [December 24 05:03:34]
[05:03:34] + Working ...
[05:03:35]
[05:03:35] *------------------------------*
[05:03:35] Folding@Home Gromacs Core
[05:03:35] Version 1.90 (March 8, 2006)
[05:03:35]
[05:03:35] Preparing to commence simulation
[05:03:35] - Looking at optimizations...
[05:03:35] - Files status OK
[05:03:38] - Expanded 3066294 -> 16578189 (decompressed 540.6 percent)
[05:03:39]
[05:03:39] Project: 2417 (Run 45, Clone 62, Gen 13)
[05:03:39]
[05:03:39] Assembly optimizations on if available.
[05:03:39] Entering M.D.
[05:04:00] (Starting from checkpoint)
[05:04:00] Protein: p2417_Ribo_Cl
[05:04:00]
[05:04:00] Writing local files
[05:04:07] Extra SSE boost OK.
[05:04:10] Writing local files
[05:04:14] Completed 0 out of 250000 steps  (0)
[05:20:06] Writing local files
[05:20:06] Completed 2500 out of 250000 steps  (1)
[05:35:41] Writing local files
[05:35:41] Completed 5000 out of 250000 steps  (2)
[05:51:13] Writing local files
[05:51:13] Completed 7500 out of 250000 steps  (3)
[06:06:44] Writing local files
[06:06:44] Completed 10000 out of 250000 steps  (4)
[06:22:15] Writing local files
[06:22:15] Completed 12500 out of 250000 steps  (5)
[06:37:46] Writing local files
[06:37:46] Completed 15000 out of 250000 steps  (6)
[06:53:17] Writing local files
[06:53:17] Completed 17500 out of 250000 steps  (7)
[07:08:47] Writing local files
[07:08:48] Completed 20000 out of 250000 steps  (8)
[07:24:18] Writing local files
[07:24:18] Completed 22500 out of 250000 steps  (9)
[07:39:49] Writing local files
[07:39:49] Completed 25000 out of 250000 steps  (10)
[07:55:20] Writing local files
[07:55:20] Completed 27500 out of 250000 steps  (11)
[08:10:50] Writing local files
[08:10:50] Completed 30000 out of 250000 steps  (12)
[08:26:21] Writing local files
[08:26:21] Completed 32500 out of 250000 steps  (13)
[08:41:52] Writing local files
[08:41:52] Completed 35000 out of 250000 steps  (14)
[08:57:23] Writing local files
[08:57:23] Completed 37500 out of 250000 steps  (15)
[09:12:53] Writing local files
[09:12:54] Completed 40000 out of 250000 steps  (16)
[09:28:24] Writing local files
[09:28:24] Completed 42500 out of 250000 steps  (17)
[09:43:55] Writing local files
[09:43:55] Completed 45000 out of 250000 steps  (18)
[09:59:26] Writing local files
[09:59:26] Completed 47500 out of 250000 steps  (19)
[10:14:57] Writing local files
[10:14:57] Completed 50000 out of 250000 steps  (20)
[10:30:27] Writing local files
[10:30:28] Completed 52500 out of 250000 steps  (21)
[10:45:58] Writing local files
[10:45:58] Completed 55000 out of 250000 steps  (22)
[11:01:29] Writing local files
[11:01:29] Completed 57500 out of 250000 steps  (23)
[11:03:33] + Working...
[11:17:00] Writing local files
[11:17:00] Completed 60000 out of 250000 steps  (24)
[11:32:31] Writing local files
[11:32:32] Completed 62500 out of 250000 steps  (25)
[11:48:02] Writing local files
[11:48:02] Completed 65000 out of 250000 steps  (26)
[12:03:34] Writing local files
[12:03:35] Completed 67500 out of 250000 steps  (27)
[12:08:50] + Paused
[12:08:50] Suspending work thread...
--- Opening Log file [December 24 15:47:57]
[15:47:57] - Ask before connecting: No
[15:47:57] - User name: Oakwheel (Team 31574)
[15:47:57] - User ID: 699E8B4557618F18
[15:47:57] - Machine ID: 1
[15:47:57]
[15:47:58] Loaded queue successfully.
[15:47:58] Initialization complete
[15:47:58] + Benchmarking ...
[15:48:00]
[15:48:00] + Processing work unit
[15:48:00] Core required: FahCore_78.exe
[15:48:00] Core found.
[15:48:00] Working on Unit 07 [December 24 15:48:00]
[15:48:00] + Working ...
[15:48:01]
[15:48:01] *------------------------------*
[15:48:01] Folding@Home Gromacs Core
[15:48:01] Version 1.90 (March 8, 2006)
[15:48:01]
[15:48:01] Preparing to commence simulation
[15:48:01] - Looking at optimizations...
[15:48:01] - Files status OK
[15:48:04] - Expanded 3066294 -> 16578189 (decompressed 540.6 percent)
[15:48:05]
[15:48:05] Project: 2417 (Run 45, Clone 62, Gen 13)
[15:48:05]
[15:48:05] Assembly optimizations on if available.
[15:48:05] Entering M.D.
[15:48:26] (Starting from checkpoint)
[15:48:26] Protein: p2417_Ribo_Cl
[15:48:26]
[15:48:26] Writing local files
[15:48:27] Completed 67500 out of 250000 steps  (27)
[15:48:28] Extra SSE boost OK.
[16:04:05] Writing local files
[16:04:05] Completed 70000 out of 250000 steps  (28)
[16:19:38] Writing local files
[16:19:38] Completed 72500 out of 250000 steps  (29)
[16:35:09] Writing local files
[16:35:09] Completed 75000 out of 250000 steps  (30)
[16:50:40] Writing local files
[16:50:40] Completed 77500 out of 250000 steps  (31)
[17:06:11] Writing local files
[17:06:12] Completed 80000 out of 250000 steps  (32)
[17:21:54] Writing local files
[17:21:54] Completed 82500 out of 250000 steps  (33)
[17:37:35] Writing local files
[17:37:36] Completed 85000 out of 250000 steps  (34)
[17:53:16] Writing local files
[17:53:16] Completed 87500 out of 250000 steps  (35)
[18:09:02] Writing local files
[18:09:02] Completed 90000 out of 250000 steps  (36)
[18:24:35] Writing local files
[18:24:35] Completed 92500 out of 250000 steps  (37)
[18:40:06] Writing local files
[18:40:06] Completed 95000 out of 250000 steps  (38)
[18:55:36] Writing local files
[18:55:36] Completed 97500 out of 250000 steps  (39)
[19:11:07] Writing local files
[19:11:07] Completed 100000 out of 250000 steps  (40)
[19:26:37] Writing local files
[19:26:37] Completed 102500 out of 250000 steps  (41)
[19:42:07] Writing local files
[19:42:08] Completed 105000 out of 250000 steps  (42)
[19:57:38] Writing local files
[19:57:38] Completed 107500 out of 250000 steps  (43)
[20:13:09] Writing local files
[20:13:09] Completed 110000 out of 250000 steps  (44)
[20:28:39] Writing local files
[20:28:40] Completed 112500 out of 250000 steps  (45)
[20:44:12] Writing local files
[20:44:12] Completed 115000 out of 250000 steps  (46)
[20:59:45] Writing local files
[20:59:45] Completed 117500 out of 250000 steps  (47)
[21:15:27] Writing local files
[21:15:27] Completed 120000 out of 250000 steps  (48)
[21:31:08] Writing local files
[21:31:10] Completed 122500 out of 250000 steps  (49)
[21:41:35] + Paused
[21:41:35] Suspending work thread...
[22:09:00] + Working ...
[22:09:00] Resuming work thread...
[22:14:16] Writing local files
[22:14:17] Completed 125000 out of 250000 steps  (50)
[22:29:49] Writing local files
[22:29:50] Completed 127500 out of 250000 steps  (51)
[22:45:20] Writing local files
[22:45:20] Completed 130000 out of 250000 steps  (52)
[23:00:51] Writing local files
[23:00:52] Completed 132500 out of 250000 steps  (53)
[23:16:22] Writing local files
[23:16:22] Completed 135000 out of 250000 steps  (54)
[23:31:53] Writing local files
[23:31:53] Completed 137500 out of 250000 steps  (55)
[23:47:24] Writing local files
[23:47:24] Completed 140000 out of 250000 steps  (56)
[00:02:54] Writing local files
[00:02:54] Completed 142500 out of 250000 steps  (57)
[00:18:25] Writing local files
[00:18:25] Completed 145000 out of 250000 steps  (58)
[00:33:56] Writing local files
[00:33:56] Completed 147500 out of 250000 steps  (59)
[00:49:27] Writing local files
[00:49:27] Completed 150000 out of 250000 steps  (60)
[01:04:57] Writing local files
[01:04:58] Completed 152500 out of 250000 steps  (61)
[01:20:28] Writing local files
[01:20:28] Completed 155000 out of 250000 steps  (62)
[01:35:59] Writing local files
[01:35:59] Completed 157500 out of 250000 steps  (63)
[01:51:30] Writing local files
[01:51:30] Completed 160000 out of 250000 steps  (64)
[02:07:01] Writing local files
[02:07:01] Completed 162500 out of 250000 steps  (65)
[02:22:32] Writing local files
[02:22:32] Completed 165000 out of 250000 steps  (66)
[02:38:03] Writing local files
[02:38:03] Completed 167500 out of 250000 steps  (67)
[02:53:34] Writing local files
[02:53:34] Completed 170000 out of 250000 steps  (68)
[03:09:10] Writing local files
[03:09:11] Completed 172500 out of 250000 steps  (69)
[03:24:42] Writing local files
[03:24:42] Completed 175000 out of 250000 steps  (70)
[03:40:13] Writing local files
[03:40:13] Completed 177500 out of 250000 steps  (71)
[03:48:00] + Working...
[03:55:44] Writing local files
[03:55:44] Completed 180000 out of 250000 steps  (72)
[04:11:19] Writing local files
[04:11:19] Completed 182500 out of 250000 steps  (73)
[04:26:55] Writing local files
[04:26:55] Completed 185000 out of 250000 steps  (74)
[04:42:30] Writing local files
[04:42:30] Completed 187500 out of 250000 steps  (75)
[04:58:04] Writing local files
[04:58:04] Completed 190000 out of 250000 steps  (76)
[05:13:36] Writing local files
[05:13:36] Completed 192500 out of 250000 steps  (77)
[05:29:14] Writing local files
[05:29:14] Completed 195000 out of 250000 steps  (78)
[05:44:48] Writing local files
[05:44:48] Completed 197500 out of 250000 steps  (79)
[06:00:21] Writing local files
[06:00:21] Completed 200000 out of 250000 steps  (80)
[06:15:52] Writing local files
[06:15:53] Completed 202500 out of 250000 steps  (81)
[06:31:23] Writing local files
[06:31:23] Completed 205000 out of 250000 steps  (82)
[06:46:53] Writing local files
[06:46:54] Completed 207500 out of 250000 steps  (83)
[07:02:24] Writing local files
[07:02:25] Completed 210000 out of 250000 steps  (84)
[07:17:55] Writing local files
[07:17:55] Completed 212500 out of 250000 steps  (85)
[07:33:26] Writing local files
[07:33:26] Completed 215000 out of 250000 steps  (86)
[07:48:56] Writing local files
[07:48:57] Completed 217500 out of 250000 steps  (87)
[08:04:27] Writing local files
[08:04:27] Completed 220000 out of 250000 steps  (88)
[08:19:58] Writing local files
[08:19:58] Completed 222500 out of 250000 steps  (89)
[08:35:29] Writing local files
[08:35:29] Completed 225000 out of 250000 steps  (90)
[08:50:59] Writing local files
[08:51:00] Completed 227500 out of 250000 steps  (91)
[09:06:30] Writing local files
[09:06:30] Completed 230000 out of 250000 steps  (92)
[09:22:05] Writing local files
[09:22:05] Completed 232500 out of 250000 steps  (93)
[09:37:36] Writing local files
[09:37:36] Completed 235000 out of 250000 steps  (94)
[09:48:00] + Working...
[09:53:07] Writing local files
[09:53:07] Completed 237500 out of 250000 steps  (95)
[10:08:38] Writing local files
[10:08:38] Completed 240000 out of 250000 steps  (96)
[10:24:09] Writing local files
[10:24:09] Completed 242500 out of 250000 steps  (97)
[10:39:40] Writing local files
[10:39:40] Completed 245000 out of 250000 steps  (98)
[10:55:11] Writing local files
[10:55:11] Completed 247500 out of 250000 steps  (99)
[11:10:42] Writing local files
[11:10:42] Completed 250000 out of 250000 steps  (100)
[11:10:42] Writing final coordinates.
[11:10:44] Past main M.D. loop
[11:11:45]
[11:11:45] Finished Work Unit:
[11:11:45] - Reading up to 2111496 from "work/wudata_07.arc": Read 2111496
[11:11:45] - Reading up to 71956 from "work/wudata_07.xtc": Read 71956
[11:11:45] goefile size: 0
[11:11:45] logfile size: 181990
[11:11:45] Leaving Run
[11:11:46] - Writing 2622150 bytes of core data to disk...
[11:11:46]   ... Done.
[11:11:47] - Shutting down core
[11:11:47]
[11:11:47] Folding@home Core Shutdown: FINISHED_UNIT
[11:11:51] CoreStatus = 64 (100)
[11:11:51] Sending work to server
[11:11:51] + Attempting to send results
[11:11:51] - Couldn't send HTTP request to server
[11:11:51] + Could not connect to Work Server (results)
[11:11:51]     (171.65.103.162:8080)
[11:11:51] - Error: Could not transmit unit 07 (completed December 25) to work server.
[11:11:51]   Keeping unit 07 in queue.
[11:12:17] + Results successfully sent
[11:12:17] Thank you for your contribution to Folding@Home.
[11:12:17] + Number of Units Completed: 11
[11:12:18]   Successfully sent unit 07 to Collection server.
[11:12:18] - Preparing to get new work unit...
[11:12:18] + Attempting to get work packet
[11:12:18] - Connecting to assignment server
[11:12:18] - Successful: assigned to (171.64.65.111).
[11:12:18] + News From Folding@Home: Welcome to Folding@Home
[11:12:18] Loaded queue successfully.
[11:12:20] + Closed connections
[11:12:20]
[11:12:20] + Processing work unit
[11:12:20] Core required: FahCore_81.exe
[11:12:20] Core found.
[11:12:20] Working on Unit 08 [December 25 11:12:20]
[11:12:20] + Working ...
[11:12:21]
[11:12:21] *------------------------------*
[11:12:21] Folding@Home Gromacs Simulated Tempering Core
[11:12:21] Version 1.10 (Oct 4, 2007)
[11:12:21]
[11:12:21] Preparing to commence simulation
[11:12:21] - Looking at optimizations...
[11:12:21] - Created dyn
[11:12:21] - Files status OK
[11:12:22] - Expanded 469031 -> 2292782 (decompressed 488.8 percent)
[11:12:22] - Starting from initial work packet
[11:12:22]
[11:12:22] Project: 4114 (Run 41, Clone 2, Gen 1)
[11:12:22]
[11:12:22] Assembly optimizations on if available.
[11:12:22] Entering M.D.
[11:12:28] Protein: p4114_villinwt_folded_Amber03_Native
[11:12:28]
[11:12:28] Writing local files
[11:12:28] Extra SSE boost OK.
[11:12:28] Completed 0 out of 1500000 steps  (0)
[11:19:02] Writing local files
[11:19:02] Completed 15000 out of 1500000 steps  (1)
[11:25:36] Writing local files
[11:25:36] Completed 30000 out of 1500000 steps  (2)
[11:32:10] Writing local files
[11:32:10] Completed 45000 out of 1500000 steps  (3)
[11:38:43] Writing local files
[11:38:43] Completed 60000 out of 1500000 steps  (4)
[11:45:17] Writing local files
[11:45:17] Completed 75000 out of 1500000 steps  (5)
[11:51:50] Writing local files
[11:51:50] Completed 90000 out of 1500000 steps  (6)
[11:58:24] Writing local files
[11:58:24] Completed 105000 out of 1500000 steps  (7)
[12:04:58] Writing local files
[12:04:58] Completed 120000 out of 1500000 steps  (8)
[12:11:32] Writing local files
[12:11:32] Completed 135000 out of 1500000 steps  (9)
[12:18:06] Writing local files
[12:18:06] Completed 150000 out of 1500000 steps  (10)
[12:24:40] Writing local files
[12:24:40] Completed 165000 out of 1500000 steps  (11)
[12:31:14] Writing local files
[12:31:14] Completed 180000 out of 1500000 steps  (12)
[12:37:48] Writing local files
[12:37:48] Completed 195000 out of 1500000 steps  (13)
[12:44:22] Writing local files
[12:44:22] Completed 210000 out of 1500000 steps  (14)
[12:50:57] Writing local files
[12:50:57] Completed 225000 out of 1500000 steps  (15)
[12:53:59] Opening C:\Program Files\Folding@Home\MyFolding.html...
[12:57:33] Writing local files
[12:57:33] Completed 240000 out of 1500000 steps  (16)
[13:04:11] Writing local files
[13:04:11] Completed 255000 out of 1500000 steps  (17)
[13:10:51] Writing local files
[13:10:51] Completed 270000 out of 1500000 steps  (18)
[13:17:28] Writing local files
[13:17:28] Completed 285000 out of 1500000 steps  (19)
[13:24:07] Writing local files
[13:24:07] Completed 300000 out of 1500000 steps  (20)
[13:30:42] Writing local files
[13:30:42] Completed 315000 out of 1500000 steps  (21)
[13:37:17] Writing local files
[13:37:17] Completed 330000 out of 1500000 steps  (22)
[13:43:54] Writing local files
[13:43:54] Completed 345000 out of 1500000 steps  (23)
[13:50:31] Writing local files
[13:50:31] Completed 360000 out of 1500000 steps  (24)
[13:57:08] Writing local files
[13:57:08] Completed 375000 out of 1500000 steps  (25)
[14:03:44] Writing local files
[14:03:44] Completed 390000 out of 1500000 steps  (26)
[14:10:45] Writing local files
[14:10:45] Completed 405000 out of 1500000 steps  (27)
[14:17:23] Writing local files
[14:17:23] Completed 420000 out of 1500000 steps  (28)
[14:24:03] Writing local files
[14:24:04] Completed 435000 out of 1500000 steps  (29)
[14:30:56] Writing local files
[14:30:56] Completed 450000 out of 1500000 steps  (30)
[14:37:36] Writing local files
[14:37:36] Completed 465000 out of 1500000 steps  (31)
[14:44:15] Writing local files
[14:44:15] Completed 480000 out of 1500000 steps  (32)
[14:51:03] Writing local files
[14:51:03] Completed 495000 out of 1500000 steps  (33)
[14:57:45] Writing local files
[14:57:45] Completed 510000 out of 1500000 steps  (34)
[15:04:22] Writing local files
[15:04:22] Completed 525000 out of 1500000 steps  (35)
[15:11:13] Writing local files
[15:11:14] Completed 540000 out of 1500000 steps  (36)
[15:17:51] Writing local files
[15:17:51] Completed 555000 out of 1500000 steps  (37)
[15:24:27] Writing local files
[15:24:27] Completed 570000 out of 1500000 steps  (38)
[15:30:49] Opening C:\Program Files\Folding@Home\MyFolding.html...
[15:31:04] Writing local files
[15:31:04] Completed 585000 out of 1500000 steps  (39)
[15:37:42] Writing local files
[15:37:43] Completed 600000 out of 1500000 steps  (40)
