Dear board member,
I would like to contribute the power of my server for folding the molecule structure of corona virus.
I am running a docker software on a synology (linux) server. The docker software is able to connect to the "dockerhub" repository: => registry.hub.docker. com
There are so many images that I am overwhelmed to decide which one to install.
Can anybody help me with that, please?
thanks Karsten
Folding under Synology Linux
Re: Folding under Synology Linux
It appears synology Linux is closer connected to Redhat. So the RPM packages would be for you:
https://foldingathome.org/alternative-downloads/
Welcome to the F@H Forum Freiblick,
If you're familiar with Docker and know what you're doing, have a look here: https://github.com/FoldingAtHome/containers
