Video Card Question
FireFox-89
Hardware configuration: Luna - Active
AMD Ryzen 7 3700X @ Stock | Noctua NH-U14S
Gigabyte B550 Gaming X V2 Revision 1.3 | BIOS version FHa
Corsair Vengeance LPX 2x16GB DDR4-3600 | Timings 18-22-22-42
ASUS GeForce RTX 3060 Ti Strix OC 8GB
SeaSonic M12II 850w 80+ Bronze PSU
Terra - Active
AMD Ryzen 7 2700X @ Stock | Noctua C14S
ASRock B450M/ac R2.0 | BIOS version p10.60
G.Skill Trident RGB 2x8GB DDR4-2800 | Timings 15-15-15-36
Asus GeForce GTX 1070 Ti Strix OC 8GB
be quiet! Pure Power 13 M 550W 80+ Gold PSU
Anubis - Active
Intel Xeon E5-2695 V4 @ Stock | Cooler Master Hyper 212
Gigabyte X99-SOC Champion | BIOS version F23c
Corsair Vengeance LPX 4x8GB @ 2400 | Timings 20-18-18-40 (Needs Sorting)
2x Sapphire Radeon RX 580 Nitro+ 4GB
SeaSonic Prime Platinum 750w 80+ Platinum PSU
All machines running F@H v8.5.5
Video Card Question
Post by FireFox-89 »
Hey,
I didn't notice any other topics (although didn't look very thoroughly) regarding 2 different video card manufacturers in a single machine. My idea is to install both of my Quadro K4000 (GK106) video cards in Anubis alongside the Sapphire Radeon RX 580 Nitro+ even though each card is only capable of around 35-40,000 PPD which isn't much but at least there is an additional 2 compute devices chewing through work units. I've been told that it's as simple as installing both NVIDIA and AMD drivers but I can't help thinking that they would conflict with each other.
Has anyone here done this and if so how did you go about it.
Thanks fellow folders :D
Do you even fold bro?
Re: Video Card Question
Yes, folks have successful installed both the AMD drivers and the nVidia drivers in the same OS. It tends to be a difficult installation and the order that the steps are taken seems to be part of the challenge, but it can work.
FireFox-89
Terra - Active
Anubis - Active
bruce wrote:Yes, folks have successful installed both the AMD drivers and the nVidia drivers in the same OS. It tends to be a difficult installation and the order that the steps are taken seems to be part of the challenge, but it can work.
Ohh nice, have you tried it or is it more hassle than it's worth haha
Not personally, and maybe.
Paragon
Hardware configuration: Rig1 (Dedicated SMP): AMD Phenom II X6 1100T, Gigabyte GA-880GMA-USB3 board, 8 GB Kingston 1333 DDR3 Ram, Seasonic S12 II 380 Watt PSU, Noctua CPU Cooler
Rig2 (Part-Time GPU): Intel Q6600, Gigabyte 965P-S3 Board, EVGA 460 GTX Graphics, 8 GB Kingston 800 DDR2 Ram, Seasonic Gold X-650 PSU, Artic Cooling Freezer 7 CPU Cooler
Post by Paragon »
I've done this and it wasn't too bad. You want to start with what you think your "main" card will be. This is not necessarily the fastest card in the system, but the one that has the output on the back that will drive your primary display. Basically, get the machine up and running with this primary card first (be it either Nvidia or AMD). Here, you just follow the installation like normal...usually the automatic installation settings work fine. Make sure you get the system stable in this config before going farther. By this, I mean all OS updates installed, latest driver version installed, etc. Make sure it recognizes the card and folds.
Next, it is worth making sure your motherboard BIOS won't be fighting you. Typically this just means updating it to the latest version...check your motherboard manufacturer's website for any updates.
With the latest BIOS and a stable system, you are ready to install the card from the other GPU manufacturer. Do a fresh reboot just to make sure all updates / settings are working, then shut the rig down. Install the second card. Make sure when you reboot, your monitor output is connected to the first card (same output plug if possible).
Upon reboot, you should still have no issues with the graphics...you should have display at your intended resolution. Depending on the OS, it might pop up with an installer for the new device that it will have detected.
Here, you want to kill that and install the latest drivers for the second card manually. Download them from the vendors website and run the installer. Do not install anything other than the driver (use the advanced install options to select driver only. Skip any fancy control panels, adrenaline software, audio drivers, etc.). You just want the bare driver for the card, so that it is recognized as a device.
Once the install is complete, reboot the machine. With any luck, you should just find that your graphics work as they had previously, but you have a new device listed in your device manager that shows up as the make / model of the second card you added.
FireFox-89
Terra - Active
Anubis - Active
Ohh nice, gonna try and give it a shot tomorrow, the PC in question doesn't have a display as I connect to it via TeamViewer which the idea do have it connected to the wireless network and only having a power cable plugged in her.
if you run Linux, you also need the OpenCL driver installed. Both should be by the vendor, not open source.
Paragon
Post by Paragon »
JimboPalmer wrote:if you run Linux, you also need the OpenCL driver installed. Both should be by the vendor, not open source.
That's right. If this is going on Linux, you'll need the Nvidia proprietary drivers from the PPA, and then separately install OpenCL. AMD provides their own install of their proprietary drivers, with info on how to install OpenCL. It is a bit of a pain, but doable.
