ERROR:Guru Meditation UNKNOWN_ENUM (-1073740777 = 0xc0000417
m_vokhm
Hardware configuration: CPU: Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz (4 kernels)
Memory: 16 GiB
No GPU
Post by m_vokhm »
I've been successfully folding 24/7 since 31.03.20, but yesterday the client suddenly crashed and then went into a loop, every its attempt to restart was immediately followed by the same crash. I could not continue folding and had to stop the client. The log says the following:
18:21:00:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
18:21:19:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
18:21:19:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
18:21:19:WU00:FS00:Starting
18:21:19:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\misa\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 4084 -checkpoint 15 -np 3
18:21:19:WU00:FS00:Started FahCore on PID 1636
18:21:19:Started thread 24 on PID 4084
18:21:19:WU00:FS00:Core PID:7072
18:21:19:WU00:FS00:FahCore 0xa7 started
18:21:20:WU00:FS00:0xa7:*********************** Log Started 2020-05-16T18:21:20Z ***********************
18:21:20:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:21:20:WU00:FS00:0xa7:       Type: 0xa7
18:21:20:WU00:FS00:0xa7:       Core: Gromacs
18:21:20:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 1636 -checkpoint 15 -np 3
18:21:20:WU00:FS00:0xa7:************************************ CBang *************************************
18:21:20:WU00:FS00:0xa7:       Date: Oct 26 2019
18:21:20:WU00:FS00:0xa7:       Time: 01:38:25
18:21:20:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:21:20:WU00:FS00:0xa7:     Branch: master
18:21:20:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
18:21:20:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:21:20:WU00:FS00:0xa7:   Platform: win32 10
18:21:20:WU00:FS00:0xa7:       Bits: 64
18:21:20:WU00:FS00:0xa7:       Mode: Release
18:21:20:WU00:FS00:0xa7:************************************ System ************************************
18:21:20:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz
18:21:20:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
18:21:20:WU00:FS00:0xa7:       CPUs: 4
18:21:20:WU00:FS00:0xa7:     Memory: 15.87GiB
18:21:20:WU00:FS00:0xa7:Free Memory: 10.50GiB
18:21:20:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
18:21:20:WU00:FS00:0xa7: OS Version: 6.1
18:21:20:WU00:FS00:0xa7:Has Battery: false
18:21:20:WU00:FS00:0xa7: On Battery: false
18:21:20:WU00:FS00:0xa7: UTC Offset: 5
18:21:20:WU00:FS00:0xa7:        PID: 7072
18:21:20:WU00:FS00:0xa7:        CWD: C:\Users\misa\AppData\Roaming\FAHClient\work
18:21:20:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
18:21:20:WU00:FS00:0xa7:    Version: 0.0.18
18:21:20:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:21:20:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
18:21:20:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
18:21:20:WU00:FS00:0xa7:       Time: 01:52:30
18:21:20:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:21:20:WU00:FS00:0xa7:************************************ Build *************************************
18:21:20:WU00:FS00:0xa7:       SIMD: avx_256
18:21:20:WU00:FS00:0xa7:********************************************************************************
18:21:20:WU00:FS00:0xa7:Project: 16440 (Run 0, Clone 2013, Gen 48)
18:21:20:WU00:FS00:0xa7:Unit: 0x0000003080fccb015ea8eb676e4bc03f
18:21:20:WU00:FS00:0xa7:Digital signatures verified
18:21:20:WU00:FS00:0xa7:Calling: mdrun -s frame48.tpr -o frame48.trr -x frame48.xtc -cpi state.cpt -cpt 15 -nt 3
18:21:20:WU00:FS00:0xa7:Steps: first=12000000 total=250000
18:21:22:WU00:FS00:0xa7:Completed 56731 out of 250000 steps (22%)
18:21:23:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
18:21:23:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
18:22:19:WU00:FS00:Starting
18:22:19:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\misa\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 4084 -checkpoint 15 -np 3
18:22:19:WU00:FS00:Started FahCore on PID 6544
18:22:19:Started thread 25 on PID 4084
18:22:19:WU00:FS00:Core PID:6836
18:22:19:WU00:FS00:FahCore 0xa7 started
18:22:20:WU00:FS00:0xa7:*********************** Log Started 2020-05-16T18:22:20Z ***********************
18:22:20:WU00:FS00:0xa7:********************************************************************************
18:22:20:WU00:FS00:0xa7:Project: 16440 (Run 0, Clone 2013, Gen 48)
18:22:20:WU00:FS00:0xa7:Unit: 0x0000003080fccb015ea8eb676e4bc03f
18:22:20:WU00:FS00:0xa7:Digital signatures verified
18:22:20:WU00:FS00:0xa7:Calling: mdrun -s frame48.tpr -o frame48.trr -x frame48.xtc -cpi state.cpt -cpt 15 -nt 3
18:22:20:WU00:FS00:0xa7:ERROR:Guru Meditation #f1d9c7d906d65b6b.1c67b7094ca6b096 (426508.461516) '00/01/frame48.xtc'
18:22:20:WU00:FS00:0xa7:WARNING:Unexpected exit() call
18:22:20:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
18:22:20:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
18:22:20:WU00:FS00:0xa7:Saving result file frame48.trr
18:22:20:WU00:FS00:0xa7:Saving result file frame48.xtc
18:22:32:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
18:22:32:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740777 = 0xc0000417)
18:22:50:Started thread 26 on PID 4084
18:23:19:WU00:FS00:Starting
18:23:19:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\misa\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 4084 -checkpoint 15 -np 3
18:23:19:WU00:FS00:Started FahCore on PID 6712
18:23:19:Started thread 27 on PID 4084
18:23:19:WU00:FS00:Core PID:7432
18:23:19:WU00:FS00:FahCore 0xa7 started
18:23:20:WU00:FS00:0xa7:*********************** Log Started 2020-05-16T18:23:20Z ***********************
My computer is
Windows Server 2008 R2 Standard, Intel Core i5-4460 3.2 GHz, RAM 16 GB,
system disk -- SanDisk Ultra II 240GB SSD.
No configuration changes were made recently, no new software installed.
disk utilities report that disks are OK.
What may be the reason of such a behavior and how can I recover and continue folding?
TPL
Re: ERROR:Guru Meditation UNKNOWN_ENUM (-1073740777 = 0xc000
Post by TPL »
You could try with the latest client version, it seems to be old.
To manually dump the problematic WU, go to C:\Users\misa\AppData\Roaming\FAHClient\work and delete folder 00. (In log WU00). Then restart folding.
m_vokhm
Memory: 16 GiB
No GPU
Post by m_vokhm »
Thanks for the prompt response!
Deleting the folder 00 has helped.
Regarding the latest version, I just don't know how to update it without completely removing and reinstalling the client.
TPL
Post by TPL »
I think in Windows its enough to just download new installer and let it do it's job. https://foldingathome.org/start-folding/ Just stop it first.
Please someone correct if I'm wrong.
Anyway it is not a giant job to remove old installation and reinstall. Then check of configuration in both cases is needed. Maybe thats the most recommendable method.
m_vokhm
Memory: 16 GiB
No GPU
Post by m_vokhm »
"Anyway it is not a giant job to remove old installation and reinstall"
You're right, of course, but right now I have an urgent work to do. I'll try a little later
