My Windows 7 PC hung up a couple of times after switching to a new router and a new ISP (fyi - old was DSL, new is cable).
I "resolved" this by unplugging the cable from the new router provided by the ISP and re-plugging the cable from the old router (and ISP).
I will try reinstalling FAH while in the "new" configuration. If the issues reoccur after installation, I'll update this post.
Maybe, or maybe not, this points to an issue which can be addressed?
cool runnings
Windows 7 Hangs if ISP or Router is "new"
Sailor.SFBay
Re: Windows 7 Hangs if ISP or Router is "new"
You need to update your choice of OS.
Never heard of that but maybe the router firmware can be updated too. Windows 7 is on ESU updates already so you only get security updates if registered for ESU until Jan 2023
Sailor.SFBay
I uninstalled, including "data" then installed latest version.
Used my passkey, etc, but for this install I'm connected to my "new" ISP.
Yes, still same version of Windows 7!
So far (in the last hour) no more freezing up of PC.
However, the log shows a number of errors!
Are these expected? As a newbie here, I don't know, and am unable to go through a learning curve now.
For now, I'll just watch and verify that I'm getting points by completion of work
*********************** Log Started 2020-05-18T18:34:23Z ***********************
18:34:23:Trying to access database...
18:34:23:Successfully acquired database lock
18:34:23:Downloading GPUs.txt from assign1.foldingathome.org:80
18:34:23:Connecting to assign1.foldingathome.org:80
18:34:24:Read GPUs.txt
18:34:25:Enabled folding slot 00: PAUSED cpu:2 (not configured)
18:34:27:Enabled folding slot 01: PAUSED gpu:0:Trinity [Radeon HD 7660D] S 584614 (not configured)
18:34:27:****************************** FAHClient ******************************
18:34:27: Version: 7.6.13
18:34:27: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:34:27: Copyright: 2020 foldingathome.org
18:34:27: Homepage: https://foldingathome.org/
18:34:27: Date: Apr 27 2020
18:34:27: Time: 21:21:01
18:34:27: Revision: 5a652817f46116b6e135503af97f18e094414e3b
18:34:27: Branch: master
18:34:27: Compiler: Visual C++ 2008
18:34:27: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:34:27: Platform: win32 10
18:34:27: Bits: 32
18:34:27: Mode: Release
18:34:27: Args: --open-web-control
18:34:27:******************************** CBang ********************************
18:34:27: Date: Apr 24 2020
18:34:27: Time: 17:07:55
18:34:27: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
18:34:27: Bits: 32
18:34:27:******************************* System ********************************
18:34:27: CPU: AMD A10-5700 APU with Radeon(tm) HD Graphics
18:34:27: CPU ID: AuthenticAMD Family 21 Model 16 Stepping 1
18:34:27: CPUs: 4
18:34:27: Memory: 11.43GiB
18:34:27: Free Memory: 6.62GiB
18:34:27: Threads: WINDOWS_THREADS
18:34:27: OS Version: 6.1
18:34:27: Has Battery: false
18:34:27: On Battery: false
18:34:27: UTC Offset: -7
18:34:27: PID: 14668
18:34:27: CWD: C:\Users\David\AppData\Roaming\FAHClient
18:34:27: Win32 Service: false
18:34:27: OS: Windows 7 Home Premium
18:34:27: OS Arch: AMD64
18:34:27: GPUs: 1
18:34:27: GPU 0: Bus:0 Slot:1 Func:0 AMD:5 Trinity [Radeon HD 7660D] S 584614
18:34:27: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
18:34:27: specified module could not be found.
18:34:27:
18:34:27:OpenCL Device 0: Platform:0 Device:0 Bus:0 Slot:1 Compute:1.2 Driver:1800.8
18:34:27:******************************* libFAH ********************************
18:34:27: Date: Apr 15 2020
18:34:27: Time: 14:53:14
18:34:27: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
18:34:27: Bits: 32
18:34:27:***********************************************************************
18:34:27:<config>
18:34:27: <!-- Folding Slots -->
18:34:27: <slot id='0' type='CPU'/>
18:34:27: <slot id='1' type='GPU'/>
18:34:27:</config>
18:34:36:17:127.0.0.1:New Web session
18:35:24:Saving configuration to config.xml
18:35:24:<config>
18:35:24: <!-- Folding Slots -->
18:35:24: <slot id='0' type='CPU'/>
18:35:24: <slot id='1' type='GPU'/>
18:35:24:</config>
18:35:24:Set client configured
18:35:24:WU00:FS00:Connecting to assign1.foldingathome.org:80
18:35:24:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:35:24:WU00:FS00:Assigned to work server 155.247.164.213
18:35:24:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 155.247.164.213
18:35:24:WU00:FS00:Connecting to 155.247.164.213:8080
18:35:24:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:35:24:WU01:FS01:Connecting to assign2.foldingathome.org:80
18:35:25:WU00:FS00:Downloading 2.83MiB
18:35:25:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:35:25:WU01:FS01:Connecting to assign3.foldingathome.org:80
18:35:25:WU01:FS01:Assigned to work server 128.252.203.10
18:35:25:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Trinity [Radeon HD 7660D] S 584614 from 128.252.203.10
18:35:25:WU01:FS01:Connecting to 128.252.203.10:8080
18:35:25:WU00:FS00:Download complete
18:35:26:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14724 run:457 clone:0 gen:81 core:0xa7 unit:0x000000569bf7a4d55ea2d2de28f82ebe
18:35:26:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
18:35:26:WU00:FS00:Connecting to cores.foldingathome.org:80
18:35:26:WU00:FS00:FahCore a7: Downloading 6.71MiB
18:35:28:WU00:FS00:FahCore a7: Download complete
18:35:28:WU00:FS00:Valid core signature
18:35:28:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
18:35:28:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
18:35:28:WU00:FS00:Starting
18:35:28:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\David\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 14668 -checkpoint 15 -np 2
18:35:30:WU00:FS00:Started FahCore on PID 8964
18:35:34:WU00:FS00:Core PID:15220
18:35:34:WU00:FS00:FahCore 0xa7 started
18:35:35:WU00:FS00:0xa7:*********************** Log Started 2020-05-18T18:35:34Z ***********************
18:35:35:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:35:35:WU00:FS00:0xa7: Type: 0xa7
18:35:35:WU00:FS00:0xa7: Core: Gromacs
18:35:35:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 8964 -checkpoint 15 -np 2
18:35:35:WU00:FS00:0xa7:************************************ CBang *************************************
18:35:35:WU00:FS00:0xa7: Date: Oct 26 2019
18:35:35:WU00:FS00:0xa7: Time: 01:38:25
18:35:35:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:35:35:WU00:FS00:0xa7: Branch: master
18:35:35:WU00:FS00:0xa7: Compiler: Visual C++ 2008
18:35:35:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:35:35:WU00:FS00:0xa7: Platform: win32 10
18:35:35:WU00:FS00:0xa7: Bits: 64
18:35:35:WU00:FS00:0xa7: Mode: Release
18:35:35:WU00:FS00:0xa7:************************************ System ************************************
18:35:35:WU00:FS00:0xa7: CPU: AMD A10-5700 APU with Radeon(tm) HD Graphics
18:35:35:WU00:FS00:0xa7: CPU ID: AuthenticAMD Family 21 Model 16 Stepping 1
18:35:35:WU00:FS00:0xa7: CPUs: 4
18:35:35:WU00:FS00:0xa7: Memory: 11.43GiB
18:35:35:WU00:FS00:0xa7:Free Memory: 6.46GiB
18:35:35:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
18:35:35:WU00:FS00:0xa7: OS Version: 6.1
18:35:35:WU00:FS00:0xa7:Has Battery: false
18:35:35:WU00:FS00:0xa7: On Battery: false
18:35:35:WU00:FS00:0xa7: UTC Offset: -7
18:35:35:WU00:FS00:0xa7: PID: 15220
18:35:35:WU00:FS00:0xa7: CWD: C:\Users\David\AppData\Roaming\FAHClient\work
18:35:35:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
18:35:35:WU00:FS00:0xa7: Version: 0.0.18
18:35:35:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:35:35:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
18:35:35:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
18:35:35:WU00:FS00:0xa7: Time: 01:52:30
18:35:35:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:35:35:WU00:FS00:0xa7:************************************ Build *************************************
18:35:35:WU00:FS00:0xa7: SIMD: avx_256
18:35:35:WU00:FS00:0xa7:********************************************************************************
18:35:35:WU00:FS00:0xa7:Project: 14724 (Run 457, Clone 0, Gen 81)
18:35:35:WU00:FS00:0xa7:Unit: 0x000000569bf7a4d55ea2d2de28f82ebe
18:35:35:WU00:FS00:0xa7:Reading tar file core.xml
18:35:35:WU00:FS00:0xa7:Reading tar file frame81.tpr
18:35:35:WU00:FS00:0xa7:Digital signatures verified
18:35:35:WU00:FS00:0xa7:Calling: mdrun -s frame81.tpr -o frame81.trr -cpt 15 -nt 2
18:35:35:WU00:FS00:0xa7:Steps: first=0 total=250000
18:35:37:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
18:35:46:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
18:35:46:WU01:FS01:Connecting to 128.252.203.10:80
18:37:05:WU01:FS01:Downloading 29.70MiB
18:37:11:WU01:FS01:Download 42.51%
18:37:15:49:127.0.0.1:New Web session
18:37:16:WU01:FS01:Download complete
18:37:16:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11760 run:0 clone:5002 gen:13 core:0x22 unit:0x0000002480fccb0a5e6f094f7dac98d0
18:37:16:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
18:37:16:WU01:FS01:Connecting to cores.foldingathome.org:80
18:37:17:WU01:FS01:FahCore 22: Downloading 4.04MiB
18:37:18:WU01:FS01:FahCore 22: Download complete
18:37:18:WU01:FS01:Valid core signature
18:37:18:WU01:FS01:Unpacked 13.50MiB to cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe
18:37:18:WU01:FS01:Starting
18:37:18:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\David\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 14668 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:37:20:WU01:FS01:Started FahCore on PID 16032
18:37:24:WU01:FS01:Core PID:16140
18:37:24:WU01:FS01:FahCore 0x22 started
18:37:24:WU01:FS01:0x22:*********************** Log Started 2020-05-18T18:37:24Z ***********************
18:37:24:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:37:24:WU01:FS01:0x22: Type: 0x22
18:37:24:WU01:FS01:0x22: Core: Core22
18:37:24:WU01:FS01:0x22: Website: https://foldingathome.org/
18:37:24:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
18:37:24:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
18:37:24:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
18:37:24:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 16032 -checkpoint 15
18:37:24:WU01:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:37:24:WU01:FS01:0x22: Config: <none>
18:37:24:WU01:FS01:0x22:************************************ Build *************************************
18:37:24:WU01:FS01:0x22: Version: 0.0.5
18:37:24:WU01:FS01:0x22: Date: Apr 22 2020
18:37:24:WU01:FS01:0x22: Time: 04:42:59
18:37:24:WU01:FS01:0x22: Repository: Git
18:37:24:WU01:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
18:37:24:WU01:FS01:0x22: Branch: HEAD
18:37:24:WU01:FS01:0x22: Compiler: Visual C++ 2008
18:37:24:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:37:24:WU01:FS01:0x22: Platform: win32 10
18:37:24:WU01:FS01:0x22: Bits: 64
18:37:24:WU01:FS01:0x22: Mode: Release
18:37:24:WU01:FS01:0x22:************************************ System ************************************
18:37:24:WU01:FS01:0x22: CPU: AMD A10-5700 APU with Radeon(tm) HD Graphics
18:37:24:WU01:FS01:0x22: CPU ID: AuthenticAMD Family 21 Model 16 Stepping 1
18:37:24:WU01:FS01:0x22: CPUs: 4
18:37:24:WU01:FS01:0x22: Memory: 11.43GiB
18:37:24:WU01:FS01:0x22:Free Memory: 6.35GiB
18:37:24:WU01:FS01:0x22: Threads: WINDOWS_THREADS
18:37:24:WU01:FS01:0x22: OS Version: 6.1
18:37:24:WU01:FS01:0x22:Has Battery: false
18:37:24:WU01:FS01:0x22: On Battery: false
18:37:24:WU01:FS01:0x22: UTC Offset: -7
18:37:24:WU01:FS01:0x22: PID: 16140
18:37:24:WU01:FS01:0x22: CWD: C:\Users\David\AppData\Roaming\FAHClient\work
18:37:24:WU01:FS01:0x22: OS: Windows 7 Home Premium Service Pack 1
18:37:24:WU01:FS01:0x22: OS Arch: AMD64
18:37:24:WU01:FS01:0x22:********************************************************************************
18:37:24:WU01:FS01:0x22:Project: 11760 (Run 0, Clone 5002, Gen 13)
18:37:24:WU01:FS01:0x22:Unit: 0x0000002480fccb0a5e6f094f7dac98d0
18:37:24:WU01:FS01:0x22:Reading tar file core.xml
18:37:24:WU01:FS01:0x22:Reading tar file integrator.xml
18:37:24:WU01:FS01:0x22:Reading tar file state.xml
18:37:25:WU01:FS01:0x22:Reading tar file system.xml
18:37:25:WU01:FS01:0x22:Digital signatures verified
18:37:25:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:37:25:WU01:FS01:0x22:Version 0.0.5
18:37:32:WU01:FS01:0x22:ERROR:exception: No compatible OpenCL platform is available
18:37:32:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
18:37:32:WU01:FS01:0x22:Saving result file science.log
18:37:32:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
18:37:32:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:37:32:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11760 run:0 clone:5002 gen:13 core:0x22 unit:0x0000002480fccb0a5e6f094f7dac98d0
18:37:32:WU01:FS01:Uploading 8.00KiB to 128.252.203.10
18:37:32:WU01:FS01:Connecting to 128.252.203.10:8080
18:37:33:WU02:FS01:Connecting to assign1.foldingathome.org:80
18:37:33:WU02:FS01:Assigned to work server 128.252.203.10
18:37:33:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Trinity [Radeon HD 7660D] S 584614 from 128.252.203.10
18:37:33:WU02:FS01:Connecting to 128.252.203.10:8080
18:37:41:WU01:FS01:Upload 100.00%
18:37:54:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
18:37:54:WU02:FS01:Connecting to 128.252.203.10:80
18:38:50:WARNING:WU01:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
18:38:50:WU01:FS01:Trying to send results to collection server
18:38:50:WU01:FS01:Uploading 8.00KiB to 52.224.109.74
18:38:50:WU01:FS01:Connecting to 52.224.109.74:8080
18:38:50:WU01:FS01:Upload complete
18:38:50:WU01:FS01:Server responded WORK_ACK (400)
18:38:50:WU01:FS01:Cleaning up
18:39:13:WU02:FS01:Downloading 51.20MiB
18:39:19:WU02:FS01:Download 21.73%
18:39:25:WU02:FS01:Download 44.93%
18:39:31:WU02:FS01:Download 77.28%
18:39:35:WU02:FS01:Download complete
18:39:35:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11763 run:0 clone:1544 gen:55 core:0x22 unit:0x0000007680fccb0a5e6d8139c4f9cbff
18:39:35:WU02:FS01:Starting
18:39:35:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\David\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 14668 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:39:37:WU02:FS01:Started FahCore on PID 15640
18:39:39:WU02:FS01:Core PID:7584
18:39:39:WU02:FS01:FahCore 0x22 started
18:39:39:WU02:FS01:0x22:*********************** Log Started 2020-05-18T18:39:39Z ***********************
18:39:39:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:39:39:WU02:FS01:0x22: Type: 0x22
18:39:39:WU02:FS01:0x22: Core: Core22
18:39:39:WU02:FS01:0x22: Website: https://foldingathome.org/
18:39:39:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
18:39:39:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
18:39:39:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
18:39:39:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 15640 -checkpoint 15
18:39:39:WU02:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:39:39:WU02:FS01:0x22: Config: <none>
18:39:39:WU02:FS01:0x22:************************************ Build *************************************
18:39:39:WU02:FS01:0x22: Version: 0.0.5
18:39:39:WU02:FS01:0x22: Date: Apr 22 2020
18:39:39:WU02:FS01:0x22: Time: 04:42:59
18:39:39:WU02:FS01:0x22: Repository: Git
18:39:39:WU02:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
18:39:39:WU02:FS01:0x22: Branch: HEAD
18:39:39:WU02:FS01:0x22: Compiler: Visual C++ 2008
18:39:39:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:39:39:WU02:FS01:0x22: Platform: win32 10
18:39:39:WU02:FS01:0x22: Bits: 64
18:39:39:WU02:FS01:0x22: Mode: Release
18:39:39:WU02:FS01:0x22:************************************ System ************************************
18:39:39:WU02:FS01:0x22: CPU: AMD A10-5700 APU with Radeon(tm) HD Graphics
18:39:39:WU02:FS01:0x22: CPU ID: AuthenticAMD Family 21 Model 16 Stepping 1
18:39:39:WU02:FS01:0x22: CPUs: 4
18:39:39:WU02:FS01:0x22: Memory: 11.43GiB
18:39:39:WU02:FS01:0x22:Free Memory: 6.35GiB
18:39:39:WU02:FS01:0x22: Threads: WINDOWS_THREADS
18:39:39:WU02:FS01:0x22: OS Version: 6.1
18:39:39:WU02:FS01:0x22:Has Battery: false
18:39:39:WU02:FS01:0x22: On Battery: false
18:39:39:WU02:FS01:0x22: UTC Offset: -7
18:39:39:WU02:FS01:0x22: PID: 7584
18:39:39:WU02:FS01:0x22: CWD: C:\Users\David\AppData\Roaming\FAHClient\work
18:39:39:WU02:FS01:0x22: OS: Windows 7 Home Premium Service Pack 1
18:39:39:WU02:FS01:0x22: OS Arch: AMD64
18:39:39:WU02:FS01:0x22:********************************************************************************
18:39:39:WU02:FS01:0x22:Project: 11763 (Run 0, Clone 1544, Gen 55)
18:39:39:WU02:FS01:0x22:Unit: 0x0000007680fccb0a5e6d8139c4f9cbff
18:39:39:WU02:FS01:0x22:Reading tar file core.xml
18:39:39:WU02:FS01:0x22:Reading tar file integrator.xml
18:39:39:WU02:FS01:0x22:Reading tar file state.xml
18:39:40:WU02:FS01:0x22:Reading tar file system.xml
18:39:41:WU02:FS01:0x22:Digital signatures verified
18:39:41:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:39:41:WU02:FS01:0x22:Version 0.0.5
18:39:51:WU02:FS01:0x22:ERROR:exception: No compatible OpenCL platform is available
18:39:51:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
18:39:51:WU02:FS01:0x22:Saving result file science.log
18:39:51:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
18:39:52:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:39:52:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11763 run:0 clone:1544 gen:55 core:0x22 unit:0x0000007680fccb0a5e6d8139c4f9cbff
18:39:52:WU02:FS01:Uploading 8.00KiB to 128.252.203.10
18:39:52:WU02:FS01:Connecting to 128.252.203.10:8080
18:39:52:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:39:52:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:39:52:WU01:FS01:Connecting to assign2.foldingathome.org:80
18:39:53:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:39:53:WU01:FS01:Connecting to assign3.foldingathome.org:80
18:39:53:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:39:53:WU01:FS01:Connecting to assign4.foldingathome.org:80
18:39:53:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
18:39:53:ERROR:WU01:FS01:Exception: Could not get an assignment
18:39:53:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:39:53:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:39:53:WU01:FS01:Connecting to assign2.foldingathome.org:80
18:39:54:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:39:54:WU01:FS01:Connecting to assign3.foldingathome.org:80
18:39:54:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:39:54:WU01:FS01:Connecting to assign4.foldingathome.org:80
18:39:54:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
18:39:54:ERROR:WU01:FS01:Exception: Could not get an assignment
18:40:13:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
18:40:13:WU02:FS01:Connecting to 128.252.203.10:80
18:40:29:Saving configuration to config.xml
18:40:29:<config>
18:40:29: <!-- User Information -->
18:40:29: <passkey v='*****'/>
18:40:29: <team v='262405'/>
18:40:29: <user v='Sailor.SFBay'/>
18:40:29:
18:40:29: <!-- Folding Slots -->
18:40:29: <slot id='0' type='CPU'/>
18:40:29: <slot id='1' type='GPU'/>
18:40:29:</config>
18:40:34:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:40:34:WU02:FS01:Trying to send results to collection server
18:40:34:WU02:FS01:Uploading 8.00KiB to 52.224.109.74
18:40:34:WU02:FS01:Connecting to 52.224.109.74:8080
18:40:34:WU02:FS01:Upload complete
18:40:34:WU02:FS01:Server responded WORK_ACK (400)
18:40:34:WU02:FS01:Cleaning up
18:40:54:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:40:54:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:40:54:WU01:FS01:Connecting to assign2.foldingathome.org:80
18:40:54:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:40:54:WU01:FS01:Connecting to assign3.foldingathome.org:80
18:40:54:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:40:54:WU01:FS01:Connecting to assign4.foldingathome.org:80
18:40:54:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
18:40:54:ERROR:WU01:FS01:Exception: Could not get an assignment
18:42:31:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:42:31:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:42:31:WU01:FS01:Connecting to assign2.foldingathome.org:80
18:42:31:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:42:31:WU01:FS01:Connecting to assign3.foldingathome.org:80
18:42:32:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:42:32:WU01:FS01:Connecting to assign4.foldingathome.org:80
18:42:32:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
18:42:32:ERROR:WU01:FS01:Exception: Could not get an assignment
18:45:08:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:45:08:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:45:08:WU01:FS01:Connecting to assign2.foldingathome.org:80
18:45:09:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:45:09:WU01:FS01:Connecting to assign3.foldingathome.org:80
18:45:09:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
18:45:09:WU01:FS01:Connecting to assign4.foldingathome.org:80
18:45:09:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
18:45:09:ERROR:WU01:FS01:Exception: Could not get an assignment
18:45:45:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
18:49:22:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:49:23:WU01:FS01:Assigned to work server 3.133.76.19
18:49:23:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Trinity [Radeon HD 7660D] S 584614 from 3.133.76.19
18:49:23:WU01:FS01:Connecting to 3.133.76.19:8080
There are two types of errors connected with your GPU folding. Both are probably not correctable, and I am going to recommend you delete the GPU slot.
The main error is this:
That indicates OpenCL support has not been installed. Drivers from MS Windows Update will not include this. Downloaded from AMD's support site, you may have to hunt for the last version supporting your iGPU that includes working OpenCL support for Terascale based GPUs.
The second problem is that it appears the Radeon HD 7660D iGPU was misclassified as having Double Precision support. What information I can find indicates just support for Single Precision - https://www.techpowerup.com/gpu-specs/r ... d-igp.c825. So even with proper OpenCL support installed, it would not be usable for F@h.
18:37:32:WU01:FS01:0x22:ERROR:exception: No compatible OpenCL platform is availableThe second problem is that it appears the Radeon HD 7660D iGPU was misclassified as having Double Precision support. What information I can find indicates just support for Single Precision - https://www.techpowerup.com/gpu-specs/r ... d-igp.c825. So even with proper OpenCL support installed, it would not be usable for F@h.
NRT_AntiKytherA
I found this folded but it was ridiculously slow, so I abandoned folding with the GPU portion of the Athlon 5350 and used the 4 CPU cores alone. However, since I have stopped using that machine in the office as much at the moment I have stopped turning it on just to fold. It may be prudent to remove it from the GPU list because unless the machine is on 24/7 and doing nothing else it really won't complete units in time.
techpowerup have the wrong frequency for the GPU but it's kind of irrelevant. Even at 600MHz it's pretty much useless with the number of cores it has.
0x1002:0x9830:1:5:Temash [Radeon HD 8400]
The Radeon HD 8400 is at least from a slightly newer generation of GPU chip, so it at least does have Double Precision as part of an AMD APU.
