ERROR:Guru Meditation, UNKNOWN_ENUM (-1073740791 = 0xc00004
Houd.ini
Post by Houd.ini »
Hey, I have a dedicated folding machine that has been running 24/7 for a couple of months now, but the last few days I have been losing contact with it through FAHcontrol, and when I hook a screen up to that machine it has been logged out of Windows 10 or restarted to the login prompt, the last time it happened the machine was off. Here is the last part of the log:
*********************** Log Started 2020-05-12T21:14:30Z ***********************
19:48:24:WU01:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
19:49:42:WU02:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
*********************** Log Started 2020-05-15T21:53:32Z ***********************
21:53:32:Trying to access database...
21:53:32:Successfully acquired database lock
21:53:32:Read GPUs.txt
21:53:32:Enabled folding slot 00: READY cpu:6
21:53:33:Enabled folding slot 01: READY gpu:0:GK104 [GeForce GTX 770] 3213
21:53:33:****************************** FAHClient ******************************
21:53:33:        Version: 7.6.13
21:53:33:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:53:33:      Copyright: 2020 foldingathome.org
21:53:33:       Homepage: https://foldingathome.org/
21:53:33:           Date: Apr 27 2020
21:53:33:           Time: 21:21:01
21:53:33:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
21:53:33:         Branch: master
21:53:33:       Compiler: Visual C++ 2008
21:53:33:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:53:33:       Platform: win32 10
21:53:33:           Bits: 32
21:53:33:           Mode: Release
21:53:33:         Config: C:\Users\frodi\AppData\Roaming\FAHClient\config.xml
21:53:33:******************************** CBang ********************************
21:53:33:           Date: Apr 24 2020
21:53:33:           Time: 17:07:55
21:53:33:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
21:53:33:           Bits: 32
21:53:33:******************************* System ********************************
21:53:33:            CPU: Intel(R) Xeon(R) CPU W3520 @ 2.67GHz
21:53:33:         CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
21:53:33:           CPUs: 8
21:53:33:         Memory: 6.00GiB
21:53:33:    Free Memory: 4.36GiB
21:53:33:        Threads: WINDOWS_THREADS
21:53:33:     OS Version: 6.2
21:53:33:    Has Battery: false
21:53:33:     On Battery: false
21:53:33:     UTC Offset: 2
21:53:33:            PID: 8424
21:53:33:            CWD: C:\Users\frodi\AppData\Roaming\FAHClient
21:53:33:  Win32 Service: false
21:53:33:             OS: Windows 10 Enterprise
21:53:33:        OS Arch: AMD64
21:53:33:           GPUs: 1
21:53:33:          GPU 0: Bus:3 Slot:0 Func:0 NVIDIA:3 GK104 [GeForce GTX 770] 3213
21:53:33:  CUDA Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:3.0 Driver:11.0
21:53:33:OpenCL Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:445.75
21:53:33:******************************* libFAH ********************************
21:53:33:           Date: Apr 15 2020
21:53:33:           Time: 14:53:14
21:53:33:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
21:53:33:           Bits: 32
21:53:33:***********************************************************************
21:53:34:<config>
21:53:34:  <!-- Folding Slot Configuration -->
21:53:34:  <cause v='COVID_19'/>
21:53:34:
21:53:34:  <!-- HTTP Server -->
21:53:34:  <allow v='127.0.0.1 192.168.1.180'/>
21:53:34:
21:53:34:  <!-- Network -->
21:53:34:  <proxy v=':8080'/>
21:53:34:
21:53:34:  <!-- Remote Command Server -->
21:53:34:  <command-allow-no-pass v='127.0.0.1 192.168.1.180'/>
21:53:34:
21:53:34:  <!-- Slot Control -->
21:53:34:  <power v='full'/>
21:53:34:
21:53:34:  <!-- User Information -->
21:53:34:  <passkey v='*****'/>
21:53:34:  <team v='37651'/>
21:53:34:  <user v='Houd.ini'/>
21:53:34:
21:53:34:  <!-- Folding Slots -->
21:53:34:  <slot id='0' type='CPU'>
21:53:34:    <cpus v='6'/>
21:53:34:  </slot>
21:53:34:  <slot id='1' type='GPU'/>
21:53:34:</config>
21:53:34:WU02:FS01:Starting
21:53:34:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\frodi\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 8424 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:53:34:WU02:FS01:Started FahCore on PID 8536
21:53:34:WU02:FS01:Core PID:8560
21:53:34:WU02:FS01:FahCore 0x22 started
21:53:35:WU02:FS01:0x22:*********************** Log Started 2020-05-15T21:53:34Z ***********************
21:53:35:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:53:35:WU02:FS01:0x22:       Type: 0x22
21:53:35:WU02:FS01:0x22:       Core: Core22
21:53:35:WU02:FS01:0x22:    Website: https://foldingathome.org/
21:53:35:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:53:35:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:53:35:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:53:35:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 8536 -checkpoint 15
21:53:35:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
21:53:35:WU02:FS01:0x22:             0 -gpu 0
21:53:35:WU02:FS01:0x22:     Config: <none>
21:53:35:WU02:FS01:0x22:************************************ Build *************************************
21:53:35:WU02:FS01:0x22:    Version: 0.0.2
21:53:35:WU02:FS01:0x22:       Date: Dec 6 2019
21:53:35:WU02:FS01:0x22:       Time: 21:30:31
21:53:35:WU02:FS01:0x22: Repository: Git
21:53:35:WU02:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
21:53:35:WU02:FS01:0x22:     Branch: HEAD
21:53:35:WU02:FS01:0x22:   Compiler: Visual C++ 2008
21:53:35:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:53:35:WU02:FS01:0x22:   Platform: win32 10
21:53:35:WU02:FS01:0x22:       Bits: 64
21:53:35:WU02:FS01:0x22:       Mode: Release
21:53:35:WU02:FS01:0x22:************************************ System ************************************
21:53:35:WU02:FS01:0x22:        CPU: Intel(R) Xeon(R) CPU W3520 @ 2.67GHz
21:53:35:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
21:53:35:WU02:FS01:0x22:       CPUs: 8
21:53:35:WU02:FS01:0x22:     Memory: 6.00GiB
21:53:35:WU02:FS01:0x22:Free Memory: 4.34GiB
21:53:35:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
21:53:35:WU02:FS01:0x22: OS Version: 6.2
21:53:35:WU02:FS01:0x22:Has Battery: false
21:53:35:WU02:FS01:0x22: On Battery: false
21:53:35:WU02:FS01:0x22: UTC Offset: 2
21:53:35:WU02:FS01:0x22:        PID: 8560
21:53:35:WU02:FS01:0x22:        CWD: C:\Users\frodi\AppData\Roaming\FAHClient\work
21:53:35:WU02:FS01:0x22:         OS: Windows 10 Pro
21:53:35:WU02:FS01:0x22:    OS Arch: AMD64
21:53:35:WU02:FS01:0x22:********************************************************************************
21:53:35:WU02:FS01:0x22:Project: 11749 (Run 0, Clone 8278, Gen 14)
21:53:35:WU02:FS01:0x22:Unit: 0x0000001f8ca304e75e6bb94110f16d67
21:53:35:WU02:FS01:0x22:Digital signatures verified
21:53:35:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:53:35:WU02:FS01:0x22:Version 0.0.2
21:53:35:WU02:FS01:0x22:  Found a checkpoint file
21:53:35:WU01:FS00:Starting
21:53:35:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\frodi\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 8424 -checkpoint 15 -np 6
21:53:35:WU01:FS00:Started FahCore on PID 8588
21:53:35:WU01:FS00:Core PID:8612
21:53:35:WU01:FS00:FahCore 0xa7 started
21:53:36:WU01:FS00:0xa7:*********************** Log Started 2020-05-15T21:53:35Z ***********************
21:53:36:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:53:36:WU01:FS00:0xa7:       Type: 0xa7
21:53:36:WU01:FS00:0xa7:       Core: Gromacs
21:53:36:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 8588 -checkpoint 15 -np 6
21:53:36:WU01:FS00:0xa7:************************************ CBang *************************************
21:53:36:WU01:FS00:0xa7:       Date: Oct 26 2019
21:53:36:WU01:FS00:0xa7:       Time: 01:38:35
21:53:36:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:53:36:WU01:FS00:0xa7:     Branch: master
21:53:36:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
21:53:36:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:53:36:WU01:FS00:0xa7:   Platform: win32 10
21:53:36:WU01:FS00:0xa7:       Bits: 64
21:53:36:WU01:FS00:0xa7:       Mode: Release
21:53:36:WU01:FS00:0xa7:************************************ System ************************************
21:53:36:WU01:FS00:0xa7:        CPU: Intel(R) Xeon(R) CPU W3520 @ 2.67GHz
21:53:36:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
21:53:36:WU01:FS00:0xa7:       CPUs: 8
21:53:36:WU01:FS00:0xa7:     Memory: 6.00GiB
21:53:36:WU01:FS00:0xa7:Free Memory: 4.31GiB
21:53:36:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
21:53:36:WU01:FS00:0xa7: OS Version: 6.2
21:53:36:WU01:FS00:0xa7:Has Battery: false
21:53:36:WU01:FS00:0xa7: On Battery: false
21:53:36:WU01:FS00:0xa7: UTC Offset: 2
21:53:36:WU01:FS00:0xa7:        PID: 8612
21:53:36:WU01:FS00:0xa7:        CWD: C:\Users\frodi\AppData\Roaming\FAHClient\work
21:53:36:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
21:53:36:WU01:FS00:0xa7:    Version: 0.0.18
21:53:36:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:53:36:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:53:36:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
21:53:36:WU01:FS00:0xa7:       Time: 01:52:44
21:53:36:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:53:36:WU01:FS00:0xa7:************************************ Build *************************************
21:53:36:WU01:FS00:0xa7:       SIMD: sse2
21:53:36:WU01:FS00:0xa7:********************************************************************************
21:53:36:WU01:FS00:0xa7:Project: 14802 (Run 377, Clone 2, Gen 5)
21:53:36:WU01:FS00:0xa7:Unit: 0x0000000503159d0b5eb180df1e13f907
21:53:36:WU01:FS00:0xa7:Digital signatures verified
21:53:36:WU01:FS00:0xa7:Calling: mdrun -s frame5.tpr -o frame5.trr -cpi state.cpt -cpt 15 -nt 6
21:53:36:WU01:FS00:0xa7:ERROR:Guru Meditation #c2dd460e8a770d53.7d5a3f08441a231e (26361.27281) '01/01/pullx.xvg'
21:53:36:WU01:FS00:0xa7:WARNING:Unexpected exit() call
21:53:36:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
21:53:36:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
21:53:36:WU01:FS00:0xa7:Saving result file dhdl.xvg
21:53:36:WU01:FS00:0xa7:Saving result file frame5.trr
21:53:36:WU01:FS00:0xa7:Saving result file md.log
21:53:36:WU01:FS00:0xa7:Saving result file pullf.xvg
21:53:36:WU01:FS00:0xa7:ERROR:Guru Meditation #d8d35aae5c8426d.48447d81c55ea517 (12190.12635) '01/01/pullf.xvg'
21:53:45:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:53:45:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:53:45:WU01:FS00:Starting
21:53:45:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\frodi\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 8424 -checkpoint 15 -np 6
21:53:45:WU01:FS00:Started FahCore on PID 888
21:53:45:WU01:FS00:Core PID:1124
21:53:45:WU01:FS00:FahCore 0xa7 started
21:53:45:WU01:FS00:0xa7:*********************** Log Started 2020-05-15T21:53:45Z ***********************
21:53:45:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:53:45:WU01:FS00:0xa7:       Type: 0xa7
21:53:45:WU01:FS00:0xa7:       Core: Gromacs
21:53:45:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 888 -checkpoint 15 -np 6
21:53:45:WU01:FS00:0xa7:************************************ CBang *************************************
21:53:45:WU01:FS00:0xa7:       Date: Oct 26 2019
21:53:45:WU01:FS00:0xa7:       Time: 01:38:35
21:53:45:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:53:45:WU01:FS00:0xa7:     Branch: master
21:53:45:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
21:53:45:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:53:45:WU01:FS00:0xa7:   Platform: win32 10
21:53:45:WU01:FS00:0xa7:       Bits: 64
21:53:45:WU01:FS00:0xa7:       Mode: Release
21:53:45:WU01:FS00:0xa7:************************************ System ************************************
21:53:45:WU01:FS00:0xa7:        CPU: Intel(R) Xeon(R) CPU W3520 @ 2.67GHz
21:53:45:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
21:53:45:WU01:FS00:0xa7:       CPUs: 8
21:53:45:WU01:FS00:0xa7:     Memory: 6.00GiB
21:53:46:WU01:FS00:0xa7:Free Memory: 4.01GiB
21:53:46:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
21:53:46:WU01:FS00:0xa7: OS Version: 6.2
21:53:46:WU01:FS00:0xa7:Has Battery: false
21:53:46:WU01:FS00:0xa7: On Battery: false
21:53:46:WU01:FS00:0xa7: UTC Offset: 2
21:53:46:WU01:FS00:0xa7:        PID: 1124
21:53:46:WU01:FS00:0xa7:        CWD: C:\Users\frodi\AppData\Roaming\FAHClient\work
21:53:46:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
21:53:46:WU01:FS00:0xa7:    Version: 0.0.18
21:53:46:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:53:46:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:53:46:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
21:53:46:WU01:FS00:0xa7:       Date: Oct 26 2019
21:53:46:WU01:FS00:0xa7:       Time: 01:52:44
21:53:46:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:53:46:WU01:FS00:0xa7:     Branch: master
21:53:46:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
21:53:46:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:53:46:WU01:FS00:0xa7:   Platform: win32 10
21:53:46:WU01:FS00:0xa7:       Bits: 64
21:53:46:WU01:FS00:0xa7:       Mode: Release
21:53:46:WU01:FS00:0xa7:************************************ Build *************************************
21:53:46:WU01:FS00:0xa7:       SIMD: sse2
21:53:46:WU01:FS00:0xa7:********************************************************************************
21:53:46:WU01:FS00:0xa7:Project: 14802 (Run 377, Clone 2, Gen 5)
21:53:46:WU01:FS00:0xa7:Unit: 0x0000000503159d0b5eb180df1e13f907
21:53:46:WU01:FS00:0xa7:Digital signatures verified
21:53:46:WU01:FS00:0xa7:Calling: mdrun -s frame5.tpr -o frame5.trr -cpi state.cpt -cpt 15 -nt 6
21:53:46:WU01:FS00:0xa7:ERROR:Guru Meditation #c2dd460e8a770d53.7d5a3f08441a231e (26361.27281) '01/01/pullx.xvg'
21:53:46:WU01:FS00:0xa7:WARNING:Unexpected exit() call
21:53:46:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
21:53:46:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
21:53:46:WU01:FS00:0xa7:Saving result file dhdl.xvg
21:53:46:WU01:FS00:0xa7:Saving result file frame5.trr
21:53:46:WU01:FS00:0xa7:Saving result file md.log
21:53:46:WU01:FS00:0xa7:Saving result file pullf.xvg
21:53:46:WU01:FS00:0xa7:ERROR:Guru Meditation #d8d35aae5c8426d.48447d81c55ea517 (12190.12635) '01/01/pullf.xvg'
21:53:46:WU02:FS01:0x22:Completed 450000 out of 2000000 steps (22%)
21:53:46:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:53:49:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:53:49:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:54:45:WU01:FS00:Starting
21:54:45:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\frodi\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 8424 -checkpoint 15 -np 6
21:54:45:WU01:FS00:Started FahCore on PID 912
21:54:45:WU01:FS00:Core PID:1052
21:54:45:WU01:FS00:FahCore 0xa7 started
21:54:46:WU01:FS00:0xa7:*********************** Log Started 2020-05-15T21:54:45Z ***********************
21:54:46:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:54:46:WU01:FS00:0xa7:       Type: 0xa7
21:54:46:WU01:FS00:0xa7:       Core: Gromacs
21:54:46:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 912 -checkpoint 15 -np 6
21:54:46:WU01:FS00:0xa7:************************************ CBang *************************************
21:54:46:WU01:FS00:0xa7:       Date: Oct 26 2019
21:54:46:WU01:FS00:0xa7:       Time: 01:38:35
21:54:46:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:54:46:WU01:FS00:0xa7:     Branch: master
21:54:46:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
21:54:46:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:54:46:WU01:FS00:0xa7:   Platform: win32 10
21:54:46:WU01:FS00:0xa7:       Bits: 64
21:54:46:WU01:FS00:0xa7:       Mode: Release
21:54:46:WU01:FS00:0xa7:************************************ System ************************************
21:54:46:WU01:FS00:0xa7:        CPU: Intel(R) Xeon(R) CPU W3520 @ 2.67GHz
21:54:46:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
21:54:46:WU01:FS00:0xa7:       CPUs: 8
21:54:46:WU01:FS00:0xa7:     Memory: 6.00GiB
21:54:46:WU01:FS00:0xa7:Free Memory: 4.15GiB
21:54:46:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
21:54:46:WU01:FS00:0xa7: OS Version: 6.2
21:54:46:WU01:FS00:0xa7:Has Battery: false
21:54:46:WU01:FS00:0xa7: On Battery: false
21:54:46:WU01:FS00:0xa7: UTC Offset: 2
21:54:46:WU01:FS00:0xa7:        PID: 1052
21:54:46:WU01:FS00:0xa7:        CWD: C:\Users\frodi\AppData\Roaming\FAHClient\work
21:54:46:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
21:54:46:WU01:FS00:0xa7:    Version: 0.0.18
21:54:46:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:54:46:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:54:46:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
21:54:46:WU01:FS00:0xa7:       Time: 01:52:44
21:54:46:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:54:46:WU01:FS00:0xa7:************************************ Build *************************************
21:54:46:WU01:FS00:0xa7:       SIMD: sse2
21:54:46:WU01:FS00:0xa7:********************************************************************************
21:54:46:WU01:FS00:0xa7:Project: 14802 (Run 377, Clone 2, Gen 5)
21:54:46:WU01:FS00:0xa7:Unit: 0x0000000503159d0b5eb180df1e13f907
21:54:46:WU01:FS00:0xa7:Digital signatures verified
21:54:46:WU01:FS00:0xa7:Calling: mdrun -s frame5.tpr -o frame5.trr -cpi state.cpt -cpt 15 -nt 6
21:54:46:WU01:FS00:0xa7:ERROR:Guru Meditation #c2dd460e8a770d53.7d5a3f08441a231e (26361.27281) '01/01/pullx.xvg'
21:54:46:WU01:FS00:0xa7:WARNING:Unexpected exit() call
21:54:46:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
21:54:46:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
21:54:46:WU01:FS00:0xa7:Saving result file dhdl.xvg
21:54:46:WU01:FS00:0xa7:Saving result file frame5.trr
21:54:46:WU01:FS00:0xa7:Saving result file md.log
21:54:46:WU01:FS00:0xa7:Saving result file pullf.xvg
21:54:46:WU01:FS00:0xa7:ERROR:Guru Meditation #d8d35aae5c8426d.48447d81c55ea517 (12190.12635) '01/01/pullf.xvg'
21:54:48:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:54:49:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:55:12:FS00:Paused
21:55:12:FS01:Paused
21:55:13:FS01:Shutting core down
21:55:13:WU02:FS01:0x22:WARNING:Console control signal 1 on PID 8560
21:55:13:WU02:FS01:0x22:Exiting, please wait. . .
21:55:13:WU02:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
21:55:13:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
21:55:34:Removing old file 'configs/config-20200419-021619.xml'
21:55:34:Saving configuration to config.xml
21:55:34:<config>
21:55:34:  <!-- Folding Slot Configuration -->
21:55:34:  <cause v='COVID_19'/>
21:55:34:
21:55:34:  <!-- HTTP Server -->
21:55:34:  <allow v='127.0.0.1 192.168.1.180'/>
21:55:34:
21:55:34:  <!-- Network -->
21:55:34:  <proxy v=':8080'/>
21:55:34:
21:55:34:  <!-- Remote Command Server -->
21:55:34:  <command-allow-no-pass v='127.0.0.1 192.168.1.180'/>
21:55:34:
21:55:34:  <!-- Slot Control -->
21:55:34:  <power v='full'/>
21:55:34:
21:55:34:  <!-- User Information -->
21:55:34:  <passkey v='*****'/>
21:55:34:  <team v='37651'/>
21:55:34:  <user v='Houd.ini'/>
21:55:34:
21:55:34:  <!-- Folding Slots -->
21:55:34:  <slot id='0' type='CPU'>
21:55:34:    <cpus v='6'/>
21:55:34:    <paused v='true'/>
21:55:34:  </slot>
21:55:34:  <slot id='1' type='GPU'>
21:55:34:  </slot>
21:55:34:</config>
21:53:33:           Bits: 32
21:53:33:           Bits: 32
21:53:33:           CPUs: 8
21:53:33:            PID: 8424
21:53:33:           GPUs: 1
21:53:33:           Bits: 32
21:53:34:<config>
21:53:34:
21:53:34:
21:53:34:
21:53:34:
21:53:34:
21:53:34:
21:53:34:  </slot>
21:53:34:</config>
21:55:34:<config>
21:55:34:
21:55:34:
21:55:34:
21:55:34:
21:55:34:
21:55:34:
21:55:34:  </slot>
21:55:34:  </slot>
21:55:34:</config>
Any idea of what happened here?
Before this happened I decreased the CPU slots from 7 to 6 threads to see if I would receive higher PPD from the GPU, as I had upgraded another folder a week ago and found that I got more PPD by reserving more than one thread per GPU on that machine. I also installed the latest version of FAH a few days ago.
Re: ERROR:Guru Meditation, UNKNOWN_ENUM (-1073740791 = 0xc00
Welcome to the F@H Forum Houd.ini,
Please note that generally speaking, the Guru Meditation error is cause by storage related issues. It can be corrupted checkpoints, anti-virus/anti-malware/anti-spyware/anti-ransomware that could corrupt the files due to false positive.
What is strange is that your system appears to stuck in a loop of trying to run it while the normal expected behavior is that it will dump the WU.
Houd.ini
Post by Houd.ini »
Thanks for the answer! This is a brand new Windows 10 installation, the only other software installed is Firefox, the Nvidia driver, Hardware Monitor, MSI Afterburner and CPU Z. It is installed on an ancient SSD tough, could that be the culprit?
I restarted the folding, and it is chugging along with a 5 hour ETA for the CPU folding, so we'll see if it crashes again.
You can check the health of the SSD to see how it performs.
BTW, if the system is dedicated to folding, you may want to consider running Linux (Ubuntu/Mint) on it instead of Windows. Currently, Linux has a performance edge over Windows and it isn't too difficult to install Linux and setup the CPU and your Nvidia GPU for folding.
FAH has a bug that can cause Guru Meditation. It's certainly not the only possible cause, but knowing about this one is worth thinking about.
Any well written program that happens to write permananet data to disk (like FAH's checkpoints) should protect itself against the loss of data. When you decide to shut down you OS you don't just yank the power cord, you tell the OS to do an orderly shutdown. It will then notify all active programs to perpare for the shutdown by closing all files. Then, if a program resists that notification, the OS will decide to FORCE the program to shut down without the proper preparation ... probably creating a problem with the program is restarted.
The current version of FAHCore_a7 no longer accepts that notification to prepare for shutdown. Bug reports have been filed, but until the program is fixed, the simple work-around is to PAUSE the slot running FAHCore_a7 (using your CPU to fold) before shutting down.
TPL
Post by TPL »
I was using antimalware software on my older PC. It announced that some of it's features are not on, do I want to switch them on? Answered yes and Guru started metitation. I switched it completely off and everything went back to normal.
Btw, you can't use 7 CPUs anyway, if you try, AS will automatically reduce CPUs to 6. 7 is a prime number >3. It has no meaning on this error though.
Houd.ini
Post by Houd.ini »
The WU that did this was automagically dumped after I started folding again, all seems ok now. I find it a bit strange that it made my machine actually turn off, I can't remember seeing that even with a good old Windows BSOD.
I have indeed considered Linux, I have actually tried to get it running several times, but always encountered annoying bugs or errors. Ubuntu kept locking me out, it is supposedly a known bug for years, this happened on both 19.10 and 20.04. Linux Mint did not do this, however it kept erroring out on my GTX 1650 (another foldig machine) so I just gave up.
Thanks for all the tips!
Houd.ini wrote:...Linux Mint did not do this, however it kept erroring out on my GTX 1650 (another foldig machine) so I just gave up...
Under Linux, to fold on the GPU, you will need Nvidia drivers that are closed-sourced and OpenCL package installed (sudo apt install ocl-icd-opencl-dev). After that, you can (in theory) fold on it without issues.
Houd.ini
Post by Houd.ini »
Yeah, I got the Nvidia driver installed without problems (which is really straight forward on Mint thankfully), i followed some recipe for openCL packages which seemed to work(no errors given), even FAHcontrol installed properly (unlike Ubuntu). I managed to add a GPU slot which seemed to work with a restart, but it just kept erroring out on the GPU slot when it had downloaded a WU and started folding. At that point, I was so fed up with trying to get GPU folding on Linux working that I rebooted into Windows and had a beer instead. The ridiculous Ubuntu errors was what threw me off the most though, I had just installed the OS and rebooted after an update or installation of the Nvidia driver, and now I can't even log in to the OS! I type my password (which I know was correct), but I am immediately given the login prompt again! I ofc googled it, it goes by the name of Ubuntu login loop or similar.
I have not actually tried Linux Mint on this particular machine though, so I am inclined to try again, will see when the current GPU WU is finished in about 8 hours...
Houd.ini wrote:Yeah, I got the Nvidia driver installed without problems (which is really straight forward on Mint thankfully), i followed some recipe for openCL packages which seemed to work(no errors given), even FAHcontrol installed properly (unlike Ubuntu). I managed to add a GPU slot which seemed to work with a restart, but it just kept erroring out on the GPU slot when it had downloaded a WU and started folding....
That's great work... when you try next time, please save the log and post it here so we can help you :)
FAHControl has python 2 dependencies which might have caused issues on the latest version of Ubuntu. I don't know the situation on Mint. While I am not a Linux user, I do know that getting Nvidia GPUs to fold under Linux is a lot easier than AMD GPUs currently. Fingers crossed, the next round of Mint will be lucky for you :)
TPL
Post by TPL »
I'm running on Mint 19.3 with GTX 1650 Mobile. I had to install latest Nvidia driver and OpenCL. (And I'm not sure if driver update was even necessary). After that needed also set GPU index manually. It works flawlessly after that.
Houd.ini
Post by Houd.ini »
FAHcontrol failed to install on both latest versions of Ubuntu actually, but installed flawlessly on Mint. I am going to try Mint once more, thanks for the help and encouragement! The machine was off again today, so I am eager to try Linux. This all started after I upgraded to the latest FAH installer.
TPL wrote:I'm running on Mint 19.3 with GTX 1650 Mobile. I had to install latest Nvidia driver and OpenCL. (And I'm not sure if driver update was even necessary). After that needed also set GPU index manually. It works flawlessly after that.
How did you install OpenCL exactly? I am going to try Linux Mint 19.3 in a few hours .
TPL
Post by TPL »
For last driver, this was very useful: https://easylinuxtipsproject.blogspot.c ... a.html?m=1
For OpenCL I'm not sure any more but think it was this: https://ubuntu.pkgs.org/18.04/ubuntu-ma ... 4.deb.html
Houd.ini wrote:...How did you install OpenCL exactly? I am going to try Linux Mint 19.3 in a few hours .
I have seen command used here in the Forums:
Not sure how that relates to TPL's post above.
TPL
Post by TPL »
I'm sorry, I didn't actually answer the question. I found this from somewhere:"Even better: ocl-icd-opencl-dev installs everything for OpenCL 1.2 (problems with OpenCL 2.0 still)". So IIRC I just downloaded that installer and just double clicked it.
